Need Help (s-video to component) Please look... - AVS Forum
post #1 of 3 Old 01-08-2007, 12:08 PM - Thread Starter
myrddin's Avatar
I had to change out my satellite receiver today and found out it only has s-video and rca output. On my receiver I use for my home theater it will not let me use s-video in to component out... I need to find a cable or converter to alow me to use the s-video out to component ( in other words I need to plug a s-video cable into a component input)
Can anyone help?
Not sure what to do.
myrddin is offline
post #2 of 3 Old 01-09-2007, 12:01 AM
Rupert's Avatar
You could use an S-Video to Component transcoder like this:
http://www.atlona.com/product.php?pr...cat=305&page=1
But, at $ 200 for the transcoder, I would probably look in to replacing the satellite box with something that has a component output.
Rupert is offline
post #3 of 3 Old 01-24-2007, 04:01 PM
Dmercurio1's Avatar
Not quite sure but these might work if used together. the first one is E B A Y
http://cgi.*********/7pin-S-Video-SV...QQcmdZViewItem
http://www.atacom.com/program/print_...R0&USER_ID=www
Dmercurio1 is offline
User Tag List
