Plasma install - AVS Forum
post #1 of 3 Old 01-20-2007, 11:10 AM - Thread Starter
fgzar's Avatar
Hello,
I have done an extensive research and have finally decided to purchase either the Pioneer PDP-5070HD PureVision 50" Plasma HDTV or Pioneer PDP-4270HD PureVision 42" Plasma HDTV. However, I have one dilemma. I intend to install the television above my fireplace which gives me exactly 38 1/2" (height) area to work with. The 50" is 38" high and the 42" is 28" high; and I really really really want the 50". Does "forcing" the 50" in such a tight space makes sense AND is it even possible to accomplish this using a tilt wall mount?
Thanks for you assistance!
fgzar is offline
post #2 of 3 Old 01-20-2007, 12:56 PM
ekdo's Avatar
Plasma's produce a lot of heat and they are vented on the top as heat rises. So you definitely need a few inches of clearance on the top.
ekdo is offline
post #3 of 3 Old 01-20-2007, 06:19 PM - Thread Starter
fgzar's Avatar
Thanks! I just realized that the 50" is actually 28.25" high (and not 38") and the 42" is 26.25" high. So, I've got 10" for venting with the 50". Yessssssssssssssssss!
fgzar is offline
User Tag List
