How to mount Center channel? Creativity apply! - AVS Forum | Home Theater Discussions And Reviews
Old 02-09-2007, 09:53 PM - Thread Starter
Corren's Avatar
OK, so I need your help. I'm trying to figure out how to mount my center chanell speaker. You can see a photo of my room here:
http://pssbl.members.winisp.net/ken/center.jpg
I'm thinking hanging from the shelf immediatley below the TV. This is where it gets interesting.
The TV Shelf is Painted MDF, looks like about 3/4 or 5/8s thick. Then, there is about a 4-5 inch thick drywall box, and then the area below, where the reciever and xbox will go. The problem is, the box below the tv has no studs in it that my stud finder can detect, as well as no studs on the sides. So I have no idea how to mount it.
The center channel is a Monitor Audio R225 which is about 30 inches long by 4 or 5 tall and deep. It's screw mounts are two on each end. Something like this:
Code:
| x                                        x |
| x                                        x |
Any thoughts?
Corren is offline
Old 02-10-2007, 12:16 PM
trekguy's Avatar
Is http://pssbl.members.winisp.net/ken/center.jpg a bad or logon protected link?
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
Old 02-10-2007, 09:56 PM - Thread Starter
Corren's Avatar
fixed
Corren is offline
Old 02-11-2007, 08:05 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
Have you considered adding a shelf in the box to hold the center?
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
