Coat Wood Bar Top? - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #211 of 221 Old 12-16-2013, 04:48 PM
tattooedmick's Avatar
Bar is finished. After mocking up the wood flooring I decided to go a different route. Used full sheets of patina copper instead. Covered the entire surface in Etex. Came out great with one exception. I thought I was doing a good thing by sealing all the seams and joints with silicone. Didn't know the Etex will not adhere to it. In fact it pulls away from it like oil and water. Planning a second coat shortly and hopefully the Etex will pool over the silicone and harden. Bar came out better than I could have hoped though.
Neuner likes this.
tattooedmick is offline
post #212 of 221 Old 12-16-2013, 07:24 PM - Thread Starter
Neuner's Avatar
I love the look of the copper! That turned out awesome.
Neuner is offline
post #213 of 221 Old 12-17-2013, 05:26 PM
malbols's Avatar
Nice job Mick
malbols is offline
post #214 of 221 Old 12-24-2013, 07:34 PM
Javatime's Avatar
Very nice! Glad to see Neuner's post still going.
Javatime is offline
post #215 of 221 Old 07-22-2014, 07:37 AM
SuwaneeLiving's Avatar
Liked: 0
Filling Gaps Before Epoxy Seal/Flood Coats
First time poster here on the forum. (What a wealth of info!!!) I am getting ready to buy some Etex to begin my pour on my bar back and would like some advice on filling the more obvious gaps between my wood flooring planks i used for my top. I have read a ton of different approaches in regards to accomplishing this from wood putty to even clear caulk, which was Neuner's approach. I am leaning towards the clear caulk route because i feel that the wood putty will look bad compared to the natural wood grain. Have any others used the clear caulk approach, and if so was it silicone based? Everything I have read states that epoxy will not bond properly to silicone based caulks.
I have included a couple pics of my bar back progress and also a couple close-ups of the gaps I am referencing...
G
ID:	174114   Click image for larger version
ID:	174122   Click image for larger version
ID:	174130   Click image for larger version
SuwaneeLiving is offline
post #216 of 221 Old 07-22-2014, 07:51 AM - Thread Starter
Neuner's Avatar
Originally Posted by SuwaneeLiving View Post
...in regards to accomplishing this from wood putty to even clear caulk, which was Neuner's approach.
G
No, I did not use caulk or wood putty. I didn't use anything. I poured the Etex on top and it seeped inbetween the joints.
I like your top, it turned out really well.
Neuner is offline
post #217 of 221 Old 07-22-2014, 07:56 AM
Liked: 0
My mistake, I thought I had read one of your posts in which you used clear caulk on a gap about 1/8" thick, but left the rest as is. I was planning on letting the epoxy just do its thing upon the initial pour but thought i might be able to limit the amount of bubbles or leakage on the more obvious spots.
Thanks for your feedback!
G
post #218 of 221 Old 07-22-2014, 08:08 AM - Thread Starter
Neuner's Avatar
The gap was in the seam of the counter substrate. I didn't account for a higher tolerance with it because I didn't think it mattered. That is where the epoxy ran through onto the floor on my first pour. I think I remember putting some kind of tape underneath for the second pour to seal it up.
If I were to do it again, I'd seal up the substrate gaps somehow. I would be afraid to use caulk near the top surface because it's flexible and might allow movement which could ruin the finish if under stress unless someone here has tried otherwise and found it to be acceptable.
Neuner is offline
post #219 of 221 Old 09-20-2016, 08:36 AM
Liked: 0
It is glass thick & smooth all the way across. The second coat filled in all of the bubbles and craters and you can never tell they were there. However, in certain spots, when you look at it with the glare, you can see what looks like colorful oil rings. Not sure what is causing this. It should be fully set & useable here shortly and I will see if they can be wiped off. It's not real noticeable, you have to point it out, but it still annoys me b/c I know it's there.
Originally Posted by Vinculum View Post
Looks GREAT! Much better than those ridges from the planks.
After its good and cured, just clean the top with a mild cleaner and rag. I used some sort of orange based cleaner and it took 99% of those oil marks away.
Thread resurrection.
First time poster, how did you guys rid of the oil rings. I made this tabletop and I have a lot of oil rings.
I can't attached any pictures yet.
gleech is offline
post #220 of 221 Old 09-20-2016, 08:49 AM - Thread Starter
Neuner's Avatar
Happy to see this thread is still being used. It's been a long time and it's been years since I sold the house. I *think* over time and with the help of some car turtle wax, the oil rings went away. I may have noticed at first but none of my family or guests did.
Neuner is offline
post #221 of 221 Old 09-20-2016, 10:43 AM
Liked: 0
Hi, thanks for sharing your cure for the problem. I emailed envirotex about the oil rings. I coated my work in the basement and did not check the humidity and I only check for temperature. They told me that the humidity or moisture got absorbed by the coating within the first ten minutes after pouring. Hopefully this will help others. Check your humidity level before you work and use dehumidifier if you have to.
I dont want to spend any more money on the tabletop so I have to lived with it and try to clean and wax it from time to time.
gleech is offline
