Modifying a front projector; feasable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-03-2007, 03:55 PM - Thread Starter
redspectacle's Avatar
Hello! This is my first post ever so please be kind. I wanted to talk about the lamp lifespans on these projectors(way to short). I own a Mitsubishi HD1000U, and I'm in love with the dang thing. Perfect for my console games. The thing is, I play so much my bulb is starting to wear. In six months I've accumulated 1795 hours on the bulb and I figure I'll have to replace it by the end of the year, if not sooner. This worries me since the bulbs are particularly expensive compared to the cost of the unit. As a remedy to the short lifespan I'm looking to pump light in from an external source like an L.E.D. array via fiberoptics or build a mirrored enclosure. I've found a few places that will sell 2000 lumen LED arrays @6500k with an estimated 12000hr lifespan. Can anyone here tell me if they have even heard of what I plan to do or if anyone has had any succes doing something similar? I plan to do this by the end of july and will post before/after pics if successful, but it would be nice to hear some advice/caution beforehand. My biggest concern right now is achieveing light uniformity. Thanks in advance.
redspectacle is offline
post #2 of 12 Old 07-03-2007, 04:52 PM
bqmeister's Avatar
Good luck.
I would think - not feasible, but what do I know.
As long as you're prepared to have a paperweight when you're done, go for it. If it works, great. If it doesn't work, you'd likely need to buy a new projector.
bqmeister is offline
post #3 of 12 Old 07-03-2007, 05:45 PM
MidLife's Avatar
What level of heat do LED arrays produce?
I am assuming heat is the biggest factor in bulb life, second to energizing off and on.
There's tale of some tungsten bulbs from the 1930s that have never been turned off and are still lighted today!
I think the efficiencies we've introduced have achieved obselesence. (sp)
A remote light source fed to the projector throught fiber optics is an very interesting idea. Least it would cut out the fan noise.
MidLife is offline
post #4 of 12 Old 07-04-2007, 11:02 AM
drunkpenguin's Avatar
Quoted: 1091 Post(s)
Liked: 1036
Those hundred year old bulbs are also very dim compared to modern bulbs. I would think anything would be possible. Just because nobody has invented it yet doesn't mean it wont work. Sure you might kill your pj, but you might also become a millionaire in the end! What about halogens? Don't they run much cooler than other bulbs?
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is online now
post #5 of 12 Old 07-04-2007, 01:56 PM
Steve Scherrer's Avatar
I wish I could contribute technically to this thread, but I can't--sorry!
But I have often wondered why it is we are stuck with this bulb technology in these projectors--and part of me says that if there were other solutions to present bright or brighter bulbs, with less heat and much longer life, then it would have been done already.
And another more cynical part of me believes that the bulbs are money-generators for these companies, with people have to replace the bulbs periodically, therefore companies don't want to remove that revenue source.
Don't know the answer, though. It certainly seems like it should be able to work.
Registered U.S. Patent and Trademark Attorney
Steve Scherrer is offline
post #6 of 12 Old 07-05-2007, 02:08 PM - Thread Starter
I decided to buy a small but powerful flashlight to shine into the projector as a cheap test. Pending the outcome of this experiment I will buy a CFL bulb accordingly. I'm looking at a few rated at 2000 to 2500 lumens with 10,000 hour lifespans but I am unfamiliar with what color temperature to buy. I'm thinking 6500k as that is most like daylight but if anyone has any better suggestions I'm willing to listen to arguements.
post #7 of 12 Old 07-05-2007, 02:42 PM
victor-eyd's Avatar
If you are not aware already, the current projectors have an electronic connection to the lamp assemblies which not only feedback lamp life info but if a lamp is there at all. If you remove the lamp assembly to try your led test, the projector will read it as no lamp found and will not turn on.
Victor
Free cake! Free cake!
- Mordecai and Rigby
Big Screen/Small Space! My 13x12 Bedroom HT
Think small, project big!
Small theaters gallery
victor-eyd is offline
post #8 of 12 Old 07-07-2007, 10:32 AM
coolhand's Avatar
Quoted: 67 Post(s)
Liked: 37
Ummm...
I would be shocked if this worked. I am interested to see you try though...
1800 hours in 180 days = 10 hrs/day. Might want to find a PJ with a lower bulb cost next time. Still, if you think its going to last another 1800 hours you might have already found the best bulb in all the land.
coolhand is offline
post #9 of 12 Old 07-26-2007, 10:41 PM
Roger Lococco's Avatar
Quoted: 28 Post(s)
Liked: 38
redspectacle, did you ever get your alternate light source to work?
Roger Lococco is offline
post #10 of 12 Old 07-27-2007, 09:13 PM
Stew4msu's Avatar
He electrocuted himself.
Stew4msu is offline
post #11 of 12 Old 08-25-2007, 01:40 PM
cozmogeek's Avatar
Quoted: 26 Post(s)
Here's what I do...
I got a separate savings account at my bank and I direct deposit $15 or $25 per paycheck in there. By the time I need a new bulb I already have the money sitting there and there's no big expense to buy it. I don't miss the little bit of money out of each check, and I'll never suddenly find myself needing to spend $400 on a lamp without having any money.
cozmogeek is offline
post #12 of 12 Old 08-25-2007, 01:45 PM
victor-eyd's Avatar
The view from his front yard
