Blu-ray Imports (General discussion, announcements and retailers) - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #541 of 1382 Old 10-30-2008, 10:31 AM
King_David's Avatar
Originally Posted by Phantom Stranger View Post
http://www.amazon.co.uk/Terminator-2...5322786&sr=8-1
The best deal is to pick two other Blu-rays also since Terminator 2 is part of the Buy 2 get 1 free BD sale going on there.
It lists the format as PAL. Will that play on US BD players?
King_David is offline
post #542 of 1382 Old 10-30-2008, 10:37 AM
dneily's Avatar
I just received an e-mail from amazon.co.uk saying that my order for Education Rita has been cancelled. Apparently the release has been postponed indefinitely.
dneily is offline
post #543 of 1382 Old 10-30-2008, 12:07 PM
DCSholtis's Avatar
PAL has no bearing on Blu Rays. However IF there are any SD extras on the discs those extras COULD be PAL and only the extras would be unplayable on US BD players.
DCSholtis is offline
post #544 of 1382 Old 10-30-2008, 04:28 PM
King_David's Avatar
Great. I don't care about extras.
post #545 of 1382 Old 10-30-2008, 06:50 PM
pointless2's Avatar
Has that actually been found to be true that PAL or NTSC are co-resident on BD disc? On HD DVD, all extras, regardless of resolution, are in HD DVD format, not PAL or NTSC. The only exceptions are where the extras are on a second disc from the main feature (or the reverse side of a combo disc).
I'd be surprised that the BDA would box themselves into such a trap. It seems like a technical nightmare.
pointless2 is offline
post #546 of 1382 Old 10-31-2008, 09:28 AM
msgohan's Avatar
Yes. American PS3s (and I assume all unmodified Region A players) will refuse to play any PAL content, whether it be on Region 0 DVDs, Blu-ray extras, or even the main Blu-ray content itself (1080i50 encodes). There isn't even a warning message saying why it refuses to play the BD content. It just appears to be loading and then cycles back to whatever menu was already showing...
Panasonic CX850 (TC-55CX850U, 2015)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #547 of 1382 Old 11-01-2008, 08:19 AM
homerx's Avatar
I don't really see it that way as those PAL extras were intended for PAL regions.not for the importers so much.
but, I hoping much like DVD their will be a blu-ray player able to play those extras and convert them to NTSC. I've got a phillips player that plays PAL DVDs with no modified. it will play different regions with a simple code... I got it at the wal*mart.
so hopfully phillps or some one else will make a BD player that can do this out of the BOX. the LG combo player has such a code for other regions. not sure if it will play PAL discs. I intend on getting this player as theirs a few region locked discs I want.. plus my HD-DVD player has been acting up a bit.. but I'm going to get an A2 or A35 to replace that. then save the A1 as they are still putting out firmware which may correct some of the issues.
anyway, back on topic. I've got several blu-ray imports that have PAL extras. like said it trys to load the extra but simply reverts back to the main menu. what scares me more I the 1080i/50 issue some have come across. which is very diffrent as that may take more to over come
homerx is offline
post #548 of 1382 Old 11-01-2008, 09:53 AM
Josh Z's Avatar
Quoted: 2146 Post(s)
Liked: 1441
The LG BH200 will play PAL discs, but it outputs them as PAL. It will not convert to NTSC. Likewise, PAL extras on Blu-ray discs are output at 50 Hz.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #549 of 1382 Old 11-01-2008, 10:41 AM
DCSholtis's Avatar
You just have to make sure your TV accepts PAL/50Hz or 60Hz signals. Mine accepts 60Hz and I'm fine with PAL after applying the BH 200 hack.
post #550 of 1382 Old 11-03-2008, 12:32 PM
DCSholtis's Avatar
Rolling Stones "Biggest Bang" is back up on Amazon France. 11/24 release date.
post #551 of 1382 Old 11-04-2008, 12:01 PM
Grifter02's Avatar
I think you're confusing yourself here. Both HD DVD and Blu-Ray are the same in that the main movie is encoded at the world wide 1080p HD standard (barring a few very rare 1080i or 720p releases). The non-HD special features are encoded in either PAL or NTSC depending on the region it is intended to be sold in, but you will never find a disc that has both PAL AND NTSC video. There's nothing that can be done about the fact that some countries use PAL SD video and some use NTSC SD video, both HD DVD and Blu-Ray have to deal with the same situation. However, the main feature on either HD format is in a format that would be playable anywhere in the world, provided it's not region-locked.
Grifter02 is offline
post #552 of 1382 Old 11-04-2008, 05:32 PM
homerx's Avatar
really? I wasn't aware it also played the pal extras on a blu-ray disc I knew their was a PAL hack for SD and a Blu-ray Region hack.
so I'm really considering this player now. although I may wait for a better player down the road as I'm sure their will be one. but this could be a good A1 replacement
homerx is offline
post #553 of 1382 Old 11-04-2008, 05:57 PM
SirDrexl's Avatar
Just to be sure it's clear, if they are output as PAL, your display has to actually support PAL for you to be able to view them. I don't think PAL support in televisions is that common in the US, but I have heard that dual NTSC/PAL support is more common in Europe and other places. If you have a projector, it may display them though.
SirDrexl is offline
post #554 of 1382 Old 11-04-2008, 07:00 PM
homerx's Avatar
yep, I'm aware of it outputing in PAL....
homerx is offline
post #555 of 1382 Old 11-04-2008, 11:18 PM
DCSholtis's Avatar
The PAL hack for SD would work for the Blu Rays as well. The extras would be in PAL SD. But it depends on your TV, if your TV accepts 50 or 60hz signals you'll be fine.
post #556 of 1382 Old 11-05-2008, 03:56 AM
ng3
ng3's Avatar
Any news on French REC, region lock? English sub?
ng3 is offline
post #557 of 1382 Old 11-05-2008, 06:02 PM
Kannisto's Avatar
Region B locked, no English subs, forced French subs with original Spanish audio, and it's a 1080i / 25fps disc so the movie doesn't play in most region A hw even if the region code is somehow bypassed.
I got it and watched it on my computer setup with English subs I added to it on the PC.
See my post here also:
http://www.avsforum.com/avs-vb/showt...7#post14962447
HD DVD: 387 (new: Taking Lives ; list)
Blu-ray: 262 (new: North Face (UK) ; list)
HD DVD-R: 262 (new: Charlie Wilson's War ; list)
Kannisto is offline
post #558 of 1382 Old 11-06-2008, 09:00 AM
ng3
ng3's Avatar
Thanks. How abt German version (release on 20 Nov 08) or Japan version?
ng3 is offline
post #559 of 1382 Old 11-06-2008, 08:02 PM
Kannisto's Avatar
Neither Japanese nor the German version seem to be coming with English subs. I don't know if German version would be different from the other European versions that are all 1080i/25fps. I'm getting the Japanese version when it comes out on 26th of November as it can't be 25 fps being released in region A area.
German version:
http://www.cinefacts.de/blu_ray/db/details.php?id=45477
Kannisto is offline
post #560 of 1382 Old 11-08-2008, 03:02 PM
SneakerPimp's Avatar
Gritty Korean Military Horror The Guard Post aka GP 506 is getting a UK Blu-ray release from Showbox on December 29, 2008.
http://www.amazon.co.uk/exec/obidos/ASIN/B001KJ8MXW/
SneakerPimp is offline
post #561 of 1382 Old 11-09-2008, 04:30 PM
Jason One's Avatar
Johnny Mnemonic is coming to Japan on 12/19. CDJapan says it will be the longer Japanese version.
Links: Amazon.co.jp, CDJapan
Jason One is offline
post #562 of 1382 Old 11-09-2008, 10:58 PM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 46
http://av.watch.impress.co.jp/docs/20081110/whv.htm
Warner Japan to release The Fall featuring lo(u)ssy audio on BD-25.
Blu-ray : 340
lgans316 is offline
post #563 of 1382 Old 11-10-2008, 07:42 AM
kakoserrano's Avatar
Does anybody knows if the Universal titles that have just arrived at Australia (Miami Vice, 40yo Virgin, etc) are region coded? No news on liesinc yet...
kakoserrano is offline
post #564 of 1382 Old 11-10-2008, 03:30 PM
fugueness's Avatar
Not if the running time is 96min, as indicated on CDJapan's site. The Japanese version is 106min.
fugueness is offline
post #565 of 1382 Old 11-10-2008, 07:57 PM
Kannisto's Avatar
It's only expected to include the longer version as an SD extra on the disc but the main presentation will be the international cut, not the Japanese one.
Kannisto is offline
post #566 of 1382 Old 11-11-2008, 05:18 PM
petoluk's Avatar
Hi guys!
Just got Fistful of Dollars BRD from Italy. Screenshots can be found here (mouse over the labels to switch between the 3 versions), the specs follow:
Code:
        Total   Video
PER UN PUGNO DI DOLLARI                                         AVC     1:39:54 25 237 530 624  47 599 551 822  33,68   27,00   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 1.0 192Kbps
DISC INFO:
Disc Size:      47 599 551 822 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Size:           25 237 530 624 bytes
Length:         1:39:54 (h:m:s)
Total Bitrate:  33,68 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      25 237 530 624  1:39:54.333     0:00:00.000     1:39:54.333
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    27000 kbps      1080p / 24fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Italian         4608 kbps       5.1 / 48kHz / 16-bit / 4608kbps
Dolby Digital Audio             English         192 kbps        1.0 / 48kHz / 192kbps
Dolby Digital Audio             Italian         192 kbps        1.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         17,731 kbps
Presentation Graphics           Italian         18,134 kbps
According to the cover, the disc is regions ABC...
Cheers!
Peto
petoluk is offline
post #567 of 1382 Old 11-15-2008, 06:22 AM
DigitalfreakNYC's Avatar
Quoted: 56 Post(s)
5 WB titles in Feb in Germany
Robin Hood: Prince of Thieves
A History of Violence
Amadeus
A Time To Kill
Pelican Brief
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #568 of 1382 Old 11-15-2008, 06:46 AM
Henke007's Avatar
great titles
HD DVD 300+
BD 500+
Henke007 is offline
post #569 of 1382 Old 11-15-2008, 07:24 AM
gubarenko's Avatar
Russian movie Admiral aka Kolchak has been released here recently:
ABC coded, DTS HD MA 7.1 (got some really nice battle scenes), English subs, BD-25
Grossed near 40 millions of dollars.
more info about movie
http://us.imdb.com/title/tt1101026/
Video: Sony BRAVIA KD-49X8505B / Pioneer VSX-LX53 / 500GB PS4
Audio: Music Hall MMF 9.1 / Marantz NA7004 / Quadral Platinum M4 (Front) + KEF KHT-3005 (Rear) + KEF HTB2 (Sub)
gubarenko is offline
post #570 of 1382 Old 11-15-2008, 07:24 PM
Quoted: 56 Post(s)
Shawshank in Germany
1/15/09
DTS-HD
- exklusives Making of
- The Charlie Rose Show (OV, dt. UT)
- Booklet
- Audiokommentar
- Bildergalerien
Reply Blu-ray Software
blu-ray , region 1
