The Mummy comparison *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 231 Old 07-18-2008, 04:59 AM - Thread Starter
Xylon's Avatar
If there is a gun pointed at my head and asked to choose which one is Blu-ray or HD DVD, there is a 50% chance that I will survive
Its that close in terms of PQ and AQ. But using screenshots we will be able to see the difference. Including cropping and resizing at 200%. I won't be including the DVD version this time.
What you get here is less artifacts (visible only and discernable by looking at the screenshots) on Blu-ray but more pronounced EE . EE is visible on both formats. Blu-ray has a new encode with higher bitrate 23.30 mbps compared to HD DVD at 17.00 mbps. DNR is added and more pronounced in some scenes.
No major difference in PQ.
For the first time I made some serious attempt at comparing sound quality and it convinces me that I would rather leave that to people with audiophile ears with equipment to match it. I only have a Paradigm monitor 7 with CC-390 center speaker and pair of ADP-390 for rear and side speaker surrounds. Even with that speaker setup I can't really distinguish which one is better. Although the DTS-MA track from Blu-ray is tad bit louder (?) Is that better? Bear in mind my opinion on the AQ only applies to this title.
If we are going to see any worthwhile improvements it wil be a remastering. There is still dust and specks here and there. And the complete removal of EE.
In the end the higher bitrate and lossless sound will give the Blu-ray version the edge. Regardless if its discernible or not. If both versions were released at the same time, I will choose Blu-ray.
HD DVD File size: 20 GB
Bitrate: 17.00 mbps
Blu-ray File size: 26.40 GB
Bitrate: 23.30 mbps
Code:
        Total   Video
The Mummy                                                       VC-1    2:04:53 31,593,603,072  35,810,635,675  33.73   23.30   DTS-HD Master 5.1 4649Kbps (48kHz/24-bit) DTS-HD Hi-Res 2.0 192Kbps
PLAYLIST REPORT:
Length:         2:04:53 (h:m:s)
Total Bitrate:  33.73 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      31,593,603,072  2:04:53.235     0:00:00.000     2:04:53.235
VIDEO:
Codec               Bitrate         Description
VC-1 Video          23301 kbps      1080p / 23.976fps
VC-1 Video          1421 kbps       480p / 23.976fps
AUDIO:
DTS-HD Master Audio             English         4649 kbps       5.1 / 48kHz / 24-bit / 4649kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
DTS Audio                       French          768 kbps        5.1 / 48kHz / 24-bit / 768kbps
DTS Audio                       Spanish         768 kbps        5.1 / 48kHz / 24-bit / 768kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48kHz / 192kbps
DTS-HD Audio                    English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         27 kbps
Presentation Graphics           French          20 kbps
Presentation Graphics           French          1 kbps
Presentation Graphics           Spanish         19 kbps
Presentation Graphics           Spanish         1 kbps
CHAPTERS:
Number          Time            Name
1               0:00:00.000     Chapter 1
2               0:07:10.596     Chapter 2
3               0:12:19.196     Chapter 3
4               0:23:19.689     Chapter 4
5               0:29:03.283     Chapter 5
6               0:36:46.204     Chapter 6
7               0:43:38.866     Chapter 7
8               0:49:06.568     Chapter 8
9               0:53:34.127     Chapter 9
10              0:57:29.612     Chapter 10
11              1:11:13.310     Chapter 11
12              1:18:48.265     Chapter 12
13              1:27:29.577     Chapter 13
14              1:30:03.940     Chapter 14
15              1:36:32.828     Chapter 15
16              1:43:58.899     Chapter 16
17              1:49:44.828     Chapter 17
18              1:56:52.088     Chapter 18
19              2:04:52.985     Chapter 19
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00000.M2TS      4113 (0x1011)   0xEA            7493.24         21,824,944,735  118,722,507     23300.96
00000.M2TS      4352 (0x1100)   0x86            7493.24         4,354,896,096   24,835,802      4649.42
00000.M2TS      4353 (0x1101)   0x82            7493.24         719,350,784     4,214,946       768.00
00000.M2TS      4354 (0x1102)   0x82            7493.24         719,350,784     4,214,946       768.00
00000.M2TS      4355 (0x1103)   0x81            7493.24         179,837,952     1,170,820       192.00
00000.M2TS      4356 (0x1104)   0x81            7493.24         179,837,952     1,170,820       192.00
00000.M2TS      4608 (0x1200)   0x90            7493.24         25,390,479      146,689         27.11
00000.M2TS      4609 (0x1201)   0x90            7493.24         17,358,355      100,600         18.53
00000.M2TS      4610 (0x1202)   0x90            7493.24         18,923,234      109,459         20.20
00000.M2TS      4611 (0x1203)   0x90            7493.24         472,150         2,769           0.50
00000.M2TS      4612 (0x1204)   0x90            7493.24         569,007         3,354           0.61
00000.M2TS      4357 (0x1105)   0x81            7493.24         179,837,952     1,170,820       192.00
00000.M2TS      6912 (0x1B00)   0xEA            7493.24         1,330,565,316   7,381,705       1420.55
00000.M2TS      6656 (0x1A00)   0xA2            7493.24         179,836,928     1,053,732       192.00
Xylon is offline
post #2 of 231 Old 07-18-2008, 04:59 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 231 Old 07-18-2008, 04:59 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #4 of 231 Old 07-18-2008, 05:00 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 231 Old 07-18-2008, 05:00 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #6 of 231 Old 07-18-2008, 05:01 AM - Thread Starter
Xylon's Avatar
Hmmmm . . . .
Xylon is offline
post #7 of 231 Old 07-18-2008, 05:01 AM - Thread Starter
Xylon's Avatar
That is it for now. Close ups and "money shots" later And I know what screenshot you guys want to see
Xylon is offline
post #8 of 231 Old 07-18-2008, 06:08 AM
Kram Sacul's Avatar
I bet it's going to have the same EE, occasional DNR, and white specks, but better compression. Blu-ray FTW.
Kram Sacul is offline
post #9 of 231 Old 07-18-2008, 06:11 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 47
May be when both encodes are reported to be minted from the same master with a little bit of tweaking. If the comparison pix shows no major differences I won't be purchasing these movies.
Blu-ray : 340
lgans316 is offline
post #10 of 231 Old 07-18-2008, 06:39 AM
Gary Murrell's Avatar
just as I imagined, the BD has a slightly finer grain structure, which is splendid, same master obviously
you can see VC1's slight motion blur in effect on the last zoom in shot with the guy falling from the camel, as well as the slight grain reduction I already mentioned
thanks dude
-Gary
Gary Murrell is offline
post #11 of 231 Old 07-18-2008, 06:44 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 47
Thanks Xylon for saving my $$$. Will stay away from both movies. Also let's keep in mind that both Mummy titles are ranked too low even in the HD DVD PQ thread.
Blu-ray : 340
lgans316 is offline
post #12 of 231 Old 07-18-2008, 06:57 AM
Adam_ME's Avatar
Quoted: 35 Post(s)
If the DTS HD-MA track is a noticable improvement, I'll replace the HD-DVD when there's a really good sale for Universal titles.
Adam_ME is offline
post #13 of 231 Old 07-18-2008, 07:07 AM
Grubert's Avatar
thanks dude
-Gary
Also blocking on the white horse on the foreground:
Freedom is the freedom to say that two plus two make four. If that is granted, all else follows.
-George Orwell, Nineteen Eighty-Four
Grubert is offline
post #14 of 231 Old 07-18-2008, 07:20 AM
stumlad's Avatar
Thanks Xylon.
So far I'm on "keep hd dvd" mode. The blu-ray appears ever-so-slightly better, but I doubt I could tell without mouseovers and careful examination.
stumlad is offline
post #15 of 231 Old 07-18-2008, 07:27 AM
Kram Sacul's Avatar
"Transparent to the master"
The differences are interesting. VC-1's softening plays with the contrast so the AVC encode has more "pop" in certain areas. I'd post a waggle mouseover link but the frames aren't lined up exact. The BRD is a few pixels lower.
post #16 of 231 Old 07-18-2008, 07:35 AM
Vader424242's Avatar
Quoted: 79 Post(s)
Liked: 67
I thought that both were VC-1....?
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #17 of 231 Old 07-18-2008, 07:46 AM
Kram Sacul's Avatar
Doh, you're right. I had a flashback. Substitute AVC for lower bitrate VC-1.
post #18 of 231 Old 07-18-2008, 07:57 AM
BuckNaked's Avatar
Originally Posted by stumlad View Post
So far I'm on "keep HD DVD" mode. The Blu-ray appears ever-so-slightly better, but I doubt I could tell without mouse-overs and careful examination.
I'm with you. Also, the HD DVD cost me about $5.
BuckNaked is offline
post #19 of 231 Old 07-18-2008, 08:13 AM
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
I can't believe that Universal would put out these titles on Blu that were on HD DVD and not get rid of that damn EE. I will definately keep my HD DVD copies. I think any chance of The 40 Year Old Virgin being EE free or close to it are slim and none.
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #20 of 231 Old 07-18-2008, 08:16 AM
MovieSwede's Avatar
Quoted: 124 Post(s)
Liked: 87
Remasters cost money, the reason why they release this, is because it helps promote Mummy 3. Not that they will make large $ on the BD.
Sure EE free transfer is always nice, but the market isnt there yet.
MovieSwede is offline
post #21 of 231 Old 07-18-2008, 08:46 AM
I am happy to be able to get this on BD, I think Universals stuff is going to look even better on BD along with the DTS Master audio, all titles should be a upgrade, plus I sold all my HD-DVD's long ago
-Gary
post #22 of 231 Old 07-18-2008, 08:53 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 47
I felt the opposite after viewing the above caps which looks underwhelming.
Blu-ray : 340
lgans316 is offline
post #23 of 231 Old 07-18-2008, 08:56 AM
FoxyMulder's Avatar
I think that the bigger the market for Blu Ray gets the worse the transfers will become as we will and up with DNR end edge enhanced films which are catering for the "Wow it's 25 years old and it looks just like a brand new film" crowd. I have seen comments like that with regards Patton and some other movies....If that does happen then i will not buy but unfortunately there are countless others who seem happy with mediocrity.
FoxyMulder is offline
post #24 of 231 Old 07-18-2008, 09:20 AM
bplewis24's Avatar
Agreed.
Thanks for the work, Xylon.
Brandon
bplewis24 is offline
post #25 of 231 Old 07-18-2008, 10:00 AM
Honey1's Avatar
i'll buy the BD if I find a cheap used copy in Paris (where I live) or during my next stay in the US, if only because I'd like to compare the BD with the HDDVD on my gear! But I won't order the BD online to have it shipped to France.
By the way, what about Mummy 2 and The Scoprion King?
Honey1 is offline
post #26 of 231 Old 07-18-2008, 11:12 AM
Kitsuneko's Avatar
I'm trying to restrain myself here, but let me just say that more EE was not what I was hoping for for these 'remastered' movies.
Kitsuneko is offline
post #27 of 231 Old 07-18-2008, 11:17 AM
Matt_Stevens's Avatar
Liked: 48
The EE is in the master. You cannot get rid of it. No different than with 2001.
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
post #28 of 231 Old 07-18-2008, 11:22 AM
Paul Arnette's Avatar
Quoted: 39 Post(s)
Maybe I am misunderstanding, but I don't believe this is a case of more EE being applied to the BD vs. the HD DVD. The BD is simply more 'transparent to the master', which contained a finite amount of EE. This is simply a case where the BD exposes more of the flaws in the master than the HD DVD, correct?
Paul Arnette is offline
post #29 of 231 Old 07-18-2008, 11:29 AM
Kitsuneko's Avatar
Doesn't look that way to me, but I guess I could be wrong. I'm just so fed up with Universal's edge enhanced DVDs, seeing it on HD media just makes me depressed.
Don't get me wrong, I see the improvements over the HD-DVD, and this won't stop me enjoying the movies (they're not exactly my favorite movies anyway, so no great loss), but I hope Universal improve their catalogue releases in the future.
post #30 of 231 Old 07-18-2008, 12:04 PM
bplewis24's Avatar
This is confirmed somewhere (on both counts)?
Brandon
Reply Blu-ray Software
