Band of Brothers DVD, HBO MPEG-2, HD DVD & Blu-ray comparison *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 257 Old 11-15-2008, 05:17 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #2 of 257 Old 11-15-2008, 05:17 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 257 Old 11-15-2008, 05:17 AM - Thread Starter
Xylon's Avatar
The log file for the HBO version is for the entire series. The file info for the HD DVD and Blu-ray is for the episode "Curahee"
HBO Mpeg-2
File size: 58.60 GB
Bitrate: 12.80 Mbps
Code:
Sequence Summary:
File Size Processed: 58.61 GB, Play Time: 10h:19m:37s
1920 x 1088, 29.97 fps (15.79 fps Telecine), 14.25 Mbps (12.80 Mbps Average).
Average Video Quality: 98.94 KB/Frame, 0.39 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
50 of 587079 video frames found with errors.
52 of 1161794 audio frames found with errors.
1348216 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log
HD DVD File size: 12.10 GB
Bitrate: ? mbps
Blu-ray File size: 17.10 GB
Bitrate: 27.74 mbps
Code:
        Total   Video
00000.mpls                                                      VC-1    1:13:14 18,405,949,440  33,978,762,427  33.51   27.74   DTS-HD Master 5.1 2166Kbps (48kHz/16-bit) DTS-HD Hi-Res 1.0 96Kbps
DISC INFO:
Disc Size:      33,978,762,427 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:13:14 (h:m:s)
Total Bitrate:  33.51 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      18,405,949,440  1:13:14.139     0:00:00.000     1:13:14.139
VIDEO:
Codec               Bitrate         Description
VC-1 Video          27741 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
VC-1 Video          832 kbps        480p / 23.976fps / 16:9 / Advanced Profile 2
VC-1 Video          204 kbps        480p / 23.976fps / 4:3 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         2166 kbps       5.1 / 48kHz / 16-bit / 2166kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
Dolby Digital Audio             French          192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48kHz / 192kbps
DTS-HD Audio                    English         96 kbps         1.0 / 48kHz / 96kbps
SUBTITLES:
Presentation Graphics           English         31 kbps
Presentation Graphics           English         33 kbps
Presentation Graphics           French          29 kbps
Presentation Graphics           French          2 kbps
Presentation Graphics           Portuguese      29 kbps
Presentation Graphics           Spanish         29 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:04:06.246     22,697 kbps     55,236 kbps     00:00:02.252    32,133 kbps     00:02:21.183    30,704 kbps     00:02:16.511    118,334 bytes   876,818 bytes   00:02:54.966
2               0:04:06.246     0:04:20.010     27,848 kbps     47,328 kbps     00:04:26.057    34,396 kbps     00:04:42.365    32,820 kbps     00:04:37.194    145,186 bytes   835,802 bytes   00:05:45.595
3               0:08:26.256     0:15:18.084     29,255 kbps     44,293 kbps     00:11:53.421    35,053 kbps     00:09:28.693    33,388 kbps     00:09:24.564    152,520 bytes   700,666 bytes   00:08:40.395
4               0:23:44.340     0:09:50.506     29,696 kbps     52,735 kbps     00:33:33.303    35,357 kbps     00:26:26.418    33,175 kbps     00:33:24.419    154,819 bytes   710,178 bytes   00:23:59.104
5               0:33:34.846     0:09:00.665     28,600 kbps     49,762 kbps     00:36:20.762    35,295 kbps     00:36:16.966    33,368 kbps     00:41:45.670    149,106 bytes   723,436 bytes   00:39:03.216
6               0:42:35.511     0:09:39.371     29,755 kbps     43,000 kbps     00:49:18.747    34,338 kbps     00:50:07.463    32,588 kbps     00:50:42.206    155,126 bytes   722,674 bytes   00:43:23.059
7               0:52:14.882     0:17:18.204     28,932 kbps     49,454 kbps     01:01:19.968    37,982 kbps     01:06:42.040    34,717 kbps     01:06:42.999    150,837 bytes   764,117 bytes   00:59:53.715
8               1:09:33.086     0:03:41.054     8,763 kbps      43,917 kbps     01:13:09.885    27,634 kbps     01:13:05.840    20,882 kbps     01:13:02.295    45,687 bytes    464,669 bytes   01:11:38.252
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00000.M2TS      4113 (0x1011)   0xEA            4394.14         15,237,477,849  82,876,016      27,741
00000.M2TS      4352 (0x1100)   0x86            4394.14         1,189,462,556   7,126,156       2,166
00000.M2TS      6912 (0x1B00)   0xEA            4394.14         456,909,505     2,556,386       832
00000.M2TS      6913 (0x1B01)   0xEA            4394.14         112,278,343     686,565         204
00000.M2TS      6656 (0x1A00)   0xA2            4394.14         52,729,856      308,964         96
00000.M2TS      4608 (0x1200)   0x90            4394.14         17,150,088      97,976          31
00000.M2TS      4609 (0x1201)   0x90            4394.14         16,121,976      92,112          29
00000.M2TS      4610 (0x1202)   0x90            4394.14         16,050,545      91,809          29
00000.M2TS      4611 (0x1203)   0x90            4394.14         15,898,047      90,818          29
00000.M2TS      4612 (0x1204)   0x90            4394.14         17,929,616      102,328         33
00000.M2TS      4613 (0x1205)   0x90            4394.14         1,018,452       5,825           2
00000.M2TS      4353 (0x1101)   0x81            4394.14         105,459,456     686,585         192
00000.M2TS      4354 (0x1102)   0x81            4394.14         105,459,456     686,585         192
00000.M2TS      6657 (0x1A01)   0xA2            4394.14         52,729,856      308,964         96
Xylon is offline
post #4 of 257 Old 11-15-2008, 05:18 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 257 Old 11-15-2008, 05:18 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #6 of 257 Old 11-15-2008, 05:18 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #7 of 257 Old 11-15-2008, 05:18 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #8 of 257 Old 11-15-2008, 05:19 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #9 of 257 Old 11-15-2008, 05:19 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #10 of 257 Old 11-15-2008, 05:20 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #11 of 257 Old 11-15-2008, 05:20 AM - Thread Starter
Xylon's Avatar
Xylon is offline
post #12 of 257 Old 11-15-2008, 05:21 AM - Thread Starter
Xylon's Avatar
Remastered?
Yes
Let's all pretend that the HD DVD version does not exist and this "A" title is now available on HD. Its better than DVD in PQ and of course the AQ is reference quality. It should be good enough I think.
Back to reality . . . . . .
To those who already have the HD DVD version the PQ is closer to what the film makers intent including the HBO broadcast(setting aside the artifacts caused by low bitrates). Grainy and dirty look preserved. The Blu-ray is just a bit more smoother and cleaner on the early episodes. I still need to watch Episode 5-10. Does it get better or worse (Bastogne episode comes to mind)? In the early episodes I will compare the "grain and HF detail sucking" to the level of The Mummy Returns and U-571. It varies from scene to scene.
I am not going to say that skip this Blu-ray and buy the HD DVD because the format is dead and the price for the set is just too expensive. If you have the money and want the best PQ available then why not? The most disappointed group of people will be the ones who get watch the HD DVD version. Frustrating isn't it?
Finally a proper non-import version is finally out with English menu and extra features and lossless sound but you can't help but wonder what if Warner just left the DNR dial alone.
Xylon is offline
post #13 of 257 Old 11-15-2008, 06:05 AM
micnic77's Avatar
Oh dear, where to get the DNR free HD DVDs now? (I'll pass completely)
micnic77 is offline
post #14 of 257 Old 11-15-2008, 07:19 AM
filthy6's Avatar
Oh, dear
DNR strikes again....
filthy6 is offline
post #15 of 257 Old 11-15-2008, 07:34 AM
6SpeedTA95's Avatar
Quoted: 145 Post(s)
Liked: 45
I'd like to see some more screens from what I've read the DNR comes and goes...it seems to be substantial in these shots.
6SpeedTA95 is offline
post #16 of 257 Old 11-15-2008, 07:53 AM
Gary Murrell's Avatar
oh ****!!
-Gary
Gary Murrell is offline
post #17 of 257 Old 11-15-2008, 08:02 AM
rr6966's Avatar
Quoted: 37 Post(s)
Liked: 53
I've got all three versions, and I find the HD-DVD more detailed but the Blu is not bad in my opinion.
rr6966 is offline
post #18 of 257 Old 11-15-2008, 08:05 AM
tsb
tsb's Avatar
Although I am passionately against DNR, we need some close-ups to really judge IMO. I see the DNR for sure, but I'm not seeing much difference in detail, and I don't see the waxiness. Perhaps I'm trying too hard to convince myself I don't need the $200 HD DVD set. In fact, none of the transfers are that awe-inspiring regardless. Maybe I've been watching HTWWW too much.
Xylon - What does it look like in motion?
tsb is offline
post #19 of 257 Old 11-15-2008, 08:33 AM
Kram Sacul's Avatar
Universal
1. To add a layer of DNR to the Blu-ray Disc version of a movie or tv show
2. When a studio inadvertently increases the value of the HD-DVD or other previous version by releasing an inferior or compromised version on Blu-ray Disc
usage example: "HBO pulled a Universal with this release"
related entries: downgrade, dumb down, Warner, Pattonize, Traffic, Dracula
see also: Pan's Labyrinth, The Mummy, The Mummy Returns, U-571, The Thing
Kram Sacul is offline
post #20 of 257 Old 11-15-2008, 08:37 AM
Dave_6's Avatar
Quoted: 35 Post(s)
Sooooo glad I decided to keep my HD DVD versions!
LG OLED65B6P
Oppo UDP-203
Denon AVR-X4200W
PS4 Pro
Xbox One S
Dave_6 is offline
post #21 of 257 Old 11-15-2008, 08:43 AM
metalsaber's Avatar
Quoted: 1028 Post(s)
Liked: 844
Yes it comes and goes. Personally it looks and sounds pretty good.
metalsaber is offline
post #22 of 257 Old 11-15-2008, 08:44 AM
Stevie76's Avatar
Doesn´t seem to turn anything to wax to my eyes.
I´ve seen lot worse.
I´ll still buy and enjoy it. The world won´t come to an end to me
But some people will chop my head of for saying this
Stevie76 is offline
post #23 of 257 Old 11-15-2008, 08:46 AM
bplewis24's Avatar
Prepare to be ridiculed.
Brandon
bplewis24 is offline
post #24 of 257 Old 11-15-2008, 09:32 AM
MidnightWatcher's Avatar
Quoted: 60 Post(s)
Liked: 31
The DNR on the BD is slight, I don't think it reduces the overall detail much if at all. If the HD DVD PQ is a 9.9/10, the BD is a solid 9.8/10 imo.
MidnightWatcher is offline
post #25 of 257 Old 11-15-2008, 09:48 AM
Cal1981's Avatar
Quoted: 364 Post(s)
Liked: 399
I wonder if the Blu-ray uses some DNR to trim down the grain a bit? I suppose you can debate it either way. I have the SD-DVD version and just got the Blu-ray set. I only watched a few minutes of the first episode but there is a significant difference. The Blu-ray is brighter and cleaner. I like the thumbnails with the real vets speaking as their counterparts are onscreen. The only drawback, and this is an issue with my Phillips BD player, is that I have to change the audio from primary to mixed. It downshifts the audio to DD5.1 but lets you hear the soundtrack and the commentary. It's not a biggie since I usually watch an episode normally first and then go back and watch it with the commentary on. Phillips is supposed to be working on a FW fix for this.
Cal1981 is offline
post #26 of 257 Old 11-15-2008, 10:43 AM
LouBarlow's Avatar
Could the OP explain how exactly he ensured that the test was scientifically carried out? Grain quantity varies from frame to frame and as 35mm film stock produces 24 frames a second, I'm wondering how exactly he ensured that the same frame is being compared in each shot here? Grabbing from the same time-stamp is not enough.
Detail levels look identical to me, which makes me think that the transfers are nigh on the same. Talk of 'waxiness' is plainly ridiculous though, as anyone who has actually watched the set will know.
LouBarlow is offline
post #27 of 257 Old 11-15-2008, 10:49 AM
eric.exe's Avatar
Quoted: 39 Post(s)
Liked: 29
The DNR is very light in screenshots, but how does it look in motion? It is that "stuck" grain or show other anomalies? Just because there is still grain doesn't mean it is rendered naturally.
What a shame. Warner is finally using a decent bitrate and they had to go muck with the image.
eric.exe is online now
post #28 of 257 Old 11-15-2008, 10:59 AM
AmishFury's Avatar
because xylon has been doing this for a while... and likely goes to the approximate timestamp then does a frame by frame search for the exact frame
AmishFury is offline
post #29 of 257 Old 11-15-2008, 11:02 AM
bruceames's Avatar
Quoted: 524 Post(s)
Liked: 358
I've compared facial closeups of both versions, and the HD DVD clearly has more detail. To me, that's where it's easiest to pick up the difference in detail levels.
bruceames is offline
post #30 of 257 Old 11-15-2008, 11:05 AM
zinfamous's Avatar
agreed. super overreaction here based on selected STILL pics. I've watched all ten episodes. DNR is certainly present at places, but there is also grainy detail throughout. Episode 7 is a good example: both waxyness and high detail in certain shots of Wahlberg's character.
Take it how you will. Choose to react with pics that overemphasize the bad, or react on examples that overemphasize the good.
zinfamous is offline
Reply Blu-ray Software
