The Dark Knight comparison *PIX* - Page 54 - AVS Forum | Home Theater Discussions And Reviews
post #1591 of 1594 Old 07-15-2010, 02:49 AM
dvdmike007's Avatar
Liked: 50
Really? Nolan stated in interviews that he didnt want to use IMAX has the cameras were to bulky for the stunts
dvdmike007 is offline
post #1592 of 1594 Old 07-15-2010, 06:49 AM
Seventhson's Avatar
Test
Seventhson is offline
post #1593 of 1594 Old 07-15-2010, 08:23 AM
Sujay's Avatar
He's using standard 65mm 5-perf, which isn't IMAX stock, which is 70mm 15-perf, so you won't get the vertical height or changing aspect ratios, it's just much higher film quality. So it's similar, but not exactly. I'm really excited to see it.
Sujay is offline
post #1594 of 1594 Old 07-15-2010, 08:42 AM
dvdmike007's Avatar
Liked: 50
Ah I see, I thought it was just 35mm, I regret having tickets for a non IMAX version
Reply Blu-ray Software
