King Kong comparison *PIX* - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 390 Old 01-17-2009, 05:02 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 46
Originally Posted by Andrew_HD View Post
Could someone give an explanation for so much empty space on this disc?
Andrew
1) Unwillingness to re-encode at a higher bit rate.
2) Unwillingness / lackluster attitude to feature film extras in the remaining space when UNI had created separate encodes and featured all film extras on the overseas release of Jarhead and The Thing.
3) The studio is planning to feature extra materials and/or provide high bit rate treatment on the inevitable and unannounced Collector's Edition.
Hey, isn't that Warner Bros?
All that's implied in it. Isn't it ?
Blu-ray : 340
lgans316 is offline
post #182 of 390 Old 01-17-2009, 05:08 AM
Andrew_HD's Avatar
Sorry, I've forgotten
Andrew_HD is offline
post #183 of 390 Old 01-17-2009, 05:23 AM
patrick99's Avatar
Originally Posted by lgans316 View Post
PS3 bitrate meter goes low = Excellent PQ. Lower bit rate rules. Author movies for DVD and not BD. Long live Warner. I am quite surprised to see many people having prejudiced thoughts on why NOT higher bit rates can't produce better PQ.
Indeed. It almost seems sometimes as if the format war was still going on.
patrick99 is offline
post #184 of 390 Old 01-17-2009, 09:10 AM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1321
Without mentioning names, the format war is certainly still going on in some heads.
DavidHir is online now
post #185 of 390 Old 01-17-2009, 10:38 AM
Rob Tomlin's Avatar
Very true and sad.
Rob Tomlin is offline
post #186 of 390 Old 01-17-2009, 10:47 AM
Saw this BD already,Speaking hornestly I did not see any flawed of ths film's picture as mentioned in my cinemascope screen 96".This BD is perfect for sight and sound,cheap too.May be you picked a bad one,I guess?
butsu is offline
post #187 of 390 Old 01-17-2009, 10:49 AM
Vincent Pereira's Avatar
Although the average bit-rate is almost the same as the HD-DVD, doesn't the fact that the Blu-ray hits several peaks in the 40 mb/s range (as indicated by Xylon's posted graph) indicate that this WAS re-encoded, since HD-DVD couldn't go anywhere near that high? Or am I missing something (i.e., spikes due to seamless branching perhaps...)?
Vincent
Vincent Pereira is offline
post #188 of 390 Old 01-17-2009, 11:46 AM
Gareth Flynn's Avatar
Perhaps they intend to use the same encode on international editions which may need more space for extra languages?
Gareth Flynn is offline
post #189 of 390 Old 01-17-2009, 11:49 AM
HighDeath's Avatar
29.4 is the maximum AVERAGE bit rate for a HDDVD, it doesn't mean you can't get peaks of a higher bit rate. What you guys have to understand is that the compression is based on the quality of the master, one of the things that determines its bit rate and compression adjustments is the granularity of the master. There is no reason to jump to a 30Mb/s average if you can grab more meaningful info from the master. Depending on the software you use, you can't even decide what is the average bit rate, you just leave it to the software itself, you just adjust the parameters.
You guys give too much credit to the compression...
HighDeath is offline
post #190 of 390 Old 01-17-2009, 11:57 AM
ILJG's Avatar
I thought average bit rate was always determined after the encoding has "done its thing" anyway.
Ya think?
Still looking for a movie theatre that shows movies the way they're SUPPOSED to be viewed...
...with a bitrate meter and screencaps.
ILJG is offline
post #191 of 390 Old 01-17-2009, 12:08 PM
HighDeath's Avatar
Not always, it depends on the software and the people working on the compression. You can aim for an average bit rate, and that is why some BDs come with a higher bit rate than actually needed, and some times lower due to size limits.
post #192 of 390 Old 01-17-2009, 02:02 PM
Andrew_HD's Avatar
Hehehe- do you work in authoring house?
I do and I've done hundreds encodes for DVD and Blu-ray and there can be such a thing like unspecified average bitrate, but in 95% cases everything is planned (especially when you have such a long movie).
I don't know Universal rules and future plans, but there is no reason to leave so much empty space, when movie is so long. If they have plans to put more extras on the next release than they should do new encode for it.
King Kong has very good master that's why they could go so low and still have very good quality, but in the same time this video can be improved and be a real demo material.
Andrew
post #193 of 390 Old 01-17-2009, 02:10 PM
Andrew_HD's Avatar
Can be- but this is just lazy way and done to save money.
Come on- encoding is relatively cheap (BD-J programing is expensive) and it's a Warner, so they should do it in a right way.
Andrew
post #194 of 390 Old 01-17-2009, 02:16 PM
Toe
Toe's Avatar
Quoted: 1461 Post(s)
Liked: 1832
Some Blockbuster, Walmart and Best Buy stores have copies already on the shelves $19.99. A heads up to those who wants to get it early.
I also saw one at my local Blockbuster. No luck at Best Buy though in my area.
Toe is online now
post #195 of 390 Old 01-17-2009, 02:28 PM
Deviation's Avatar
How much was it at Blockbuster? Then tend to overcharge pretty heavily in my experience.
Deviation is offline
post #196 of 390 Old 01-17-2009, 02:29 PM
Andrew_HD's Avatar
You aim for it and you get it. Encoders do it with quite good tolerance (eg. 1%). There is no such a thing like higher bitrate than needed. Higher bitrate better quality. There is a point when differences which you get are very small, but increasing bitrate still improves video. If there is macroblocking in KK encode it's definitelly not a good sign. Sometimes you can't get rid of it, becuase of the very complicated scene, but in most cases you can.
Another bad sign of this encode is that some scenes look worse than on HD-DVD encode. This should not happen if done properly and this is the main reason to say that it can be improved.
Andrew
post #197 of 390 Old 01-17-2009, 02:30 PM
Toe
Toe's Avatar
Liked: 1832
I actualy saw it for rent so I dont know how much they are selling it for.
Toe is online now
post #198 of 390 Old 01-17-2009, 02:31 PM
FoxyMulder's Avatar
Andrew
It's Universal....Warner owns the original 1933 version which i hear is coming out this year.
FoxyMulder is offline
post #199 of 390 Old 01-17-2009, 02:34 PM
HighDeath's Avatar
Yes i do, i actually own one! And although i don't see where our posts clashes, since i clearly said you can do it both ways, 95% seem a BIG number in my experience. I would say that most of the time there is a size limit, and the encoding will be based on this size limit, but not rarely just based on parameters. But usually this size limit is MORE than enough for a quality transfer of the MASTER.
It is very good that you brought this up, maybe people will start giving more credits to the master instead of the compression which they think is the devil behind every picture problem. The master is what should dictate the quality.
But i disagree about this logic of throwing the bit rate down if you have a good master, it doesn't make much sense if you have space left. When you get a good master you should encode it the best way possible to keep the details and avoid introducing artifacts. Lowering the average bit rate for such a good master is counterproductive, does not save any money (if space is not a problem) and throws away all the money spent in the mastering and all the quality work behind the mastering process. So it is really a nonsense.
post #200 of 390 Old 01-17-2009, 02:52 PM
Andrew_HD's Avatar
I have almost always size limit issue, but I do operas which are sometimes 4 hours long + I need lossless stereo and surround track to be on the disc (+ extras). When size is not an issue than BD maximum bitrate limit is the next factor. So I have either full disc or bitrate peaking to the limits. So far everyone is very happy
I wish good movies where also released in this way. I've seen already few discs with 40% empty space and not very good encode- it doesn't make a sense for me.
Exactly. It's even more important when you have a good master to do it in the best possible way.
Andrew
post #201 of 390 Old 01-17-2009, 02:53 PM
Andrew_HD's Avatar
Sorry
Andrew
post #202 of 390 Old 01-17-2009, 03:14 PM
Mr. Hanky's Avatar
Quoted: 80 Post(s)
Liked: 77
Although the average bit-rate is almost the same as the HD-DVD, doesn't the fact that the Blu-ray hits several peaks in the 40 mb/s range (as indicated by Xylon's posted graph) indicate that this WAS re-encoded...
This brings up another interesting point- were any of the pix comparisons we have seen so far, associated with those bitrate pks? If so, which ones? If not, why weren't any posted? It seems those would be the ones we would want to concentrate on if we were really interested in seeing the differences between the 2 encodes. If we are just noting image differences in the moments where bitrate is plodding along at 16 Mb/s (just picking a number, here), should it be any surprise that the results are nearly identical? It's like comparing a Camry to a Corvette at 30 mph. What is even the point of the test, if 30 mph is the criteria? No one is disputing that either one would do any better a job at that speed, but it is fairly certain that Corvette drivers overwhelmingly choose the Corvette for reasons that occur elsewhere than 30 mph.
It still doesn't erase the fact that there was plenty of room left on the disc that could have been used for a higher avg bitrate, though. If it is enough to eliminate the blocking artifacts and preserve detail down to the grain/noise, whether at full white level or full black level or anywhere in between, it would be worth it.
Margot Robbie is THE most exquisite human creature on the face of the planet, in this moment in time.
Mr. Hanky is offline
post #203 of 390 Old 01-17-2009, 03:44 PM
Andrew_HD's Avatar
As I said some time ago another problem is that screengrabs are not taken from the same type of frame (or maybe Xylon improved it and they are).
If one frame is an "I" and than the same scene in 2nd encode is a "B" frame than "I" frame will almost always look better, even if the whole encode is worse.
Solution for this is to take few frames in row from both encodes and compare all of them. If the difference is constant than you can more accurate say which one is better.
Andrew
post #204 of 390 Old 01-17-2009, 04:08 PM
42041's Avatar
Liked: 55
I'm curious, how are digital intermediates and old HD masters stored? Is it a lossless (or close to it) format?
42041 is offline
post #205 of 390 Old 01-17-2009, 05:21 PM
Andrew
Is there any way of 'guessing' where an I frame is? For example, if the film features a quick edit where the entire scene changes from one frame to the next (no fades or anything), would that have to be encoded as an I-frame?
post #206 of 390 Old 01-17-2009, 05:27 PM
42041's Avatar
Liked: 55
If you have the capability of opening a blu-ray video stream on your computer, the ffdshow video decoder has on on-screen display that can display the frame type on AVC encoded material and a lot of other information. Doesn't seem to work for VC1 though. On all the blu-rays I've got, the scene change frames are I-frames.
42041 is offline
post #207 of 390 Old 01-17-2009, 06:05 PM
HighDeath's Avatar
You can keep the lossless file you get from the scanner, but it will take about 50MB per frame in a 4K sample (More than 7TB for 100 minutes). Some do keep this.
You usually backup in the same format used for mastering, Apple ProRes 4:2:2 or Cineform 12-bit 4:4:4 raw for instance, an average of 250Mb/s. You can also get DVCPRO HD 4:2:2 around 100Mb/s, quite common when the source is a digital camera. And, in this last case (DVCPRO HD), a H.264 4.1 High Profile (8-bit 4:2:0 subsampled) transfer from this source, with an average bit rate of about 25Mb/s, should be more than enough.
I don't know what you mean by OLD, but tape was (and you can say still is...) a way to go.
About the frames, I frames are the base used by the B frames around it. A B-frame (compressed frame) does not necessarily means worse quality (You also have to consider the decoder and the specific frame), B-Frames are actually the compression per se (or a considerable part of it), the more B-frames more quality per Mb can be fit, the more I-frames (Full picture data) you decide to use the less compressed the video will be (In a way, better say "will be able to be"...) but since the B-frames will have more reference with more I-Frames, the motion will/should look better.
The B-frame holds only part of the data necessary to construct the whole frame, the rest is captured from the near I-Frames around used as references. Suppose you have a stationary background, you don't need to repeat all the data for the background in the B-frame, you can just reference it to an I-Frame next to it and before it. And that is what B-Frame stands for, Bi-predictive frame. H.264 also allows you to use a previous decoded B-Frame as a reference frame.
I suggest you guys visit http://forum.doom9.org/ lots of useful tech info about all this there.
The compression and ecoding follow many parameters, like motion estimation, the kind of B-Frames, the reference method, the entropy, decoding intensity, time and money...
In the end, bit rate does not mean much, you have to check the parameters not the Bit Rate. You may get the same quality with a lower bit rate, or you can waste bandwidth to facilitate decoding (Less compression). Pirates can often teach you a think or two about this bit rate thing...
post #208 of 390 Old 01-17-2009, 06:25 PM
ILJG's Avatar
ILJG is offline
post #209 of 390 Old 01-17-2009, 06:52 PM
Kram Sacul's Avatar
Who cares about wasting bandwidth? This is friggin Blu-ray not HD-DVD. They should've cranked the bitrate up if they weren't going to put any effort into extras.
Kram Sacul is offline
post #210 of 390 Old 01-18-2009, 12:46 AM
Hughmc's Avatar
Quoted: 13 Post(s)
Liked: 39
Wouldn't a new compression scheme that does use a higher bitrate and that does better deal with the granularity of the master make a difference? Isn't that a given and wouldn't it have to if one did exist?
Hughmc is offline
Reply Blu-ray Software
