IpMan - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 181 Old 02-26-2011, 02:32 PM
Chant's Avatar
Originally Posted by RuffinJourneyMan View Post
Okay, so I'm no geek about this kind of stuff. It might be just dumb luck, but try this with the Panasonic DMP-BD85 when the menu freezes up on the Ip Man Blu-Ray Disc.
When the menu freezes, on your remote control press the number zero (0) three times. This should make the movie start. Once the movie starts, you can press the Pop-Up menu button on you remote control to toggle with the settings and see all of the extra features.
This worked for me. I too bought the Blu-Ray disc and took it back because I thought it was a faulty disc. I don't know if this works for other Panasonic Blu-Ray players but it worked for my Panasonic DMP-BD85.
Hope it works for you all out there!
Thanks, this has happened twice lately and your fix was on time.
Chanter
Chant is offline
Reply Blu-ray Software
