crouching tiger hidden dragon - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 129 Old 07-02-2009, 03:01 PM
hazel_wu's Avatar
Originally Posted by Josh Z View Post
It was promised, but it didn't come to pass. Sony claims that it can't be done, at least not for the amount of money they're willing to pay.
I heard it's not about money, but more about compatibility.
It is of course possible to include movable subs, but not all players support it well enough to be used commercially.
hazel_wu is offline
post #92 of 129 Old 07-02-2009, 03:07 PM
eric.exe's Avatar
Quoted: 16 Post(s)
They could always include 2 sets of subtitles, one completely inside the frame, and one out.
eric.exe is online now
post #93 of 129 Old 07-03-2009, 04:08 PM
Penton-Man's Avatar
You've got to get out more.
Another AVS member already asked that question directly to me and your answer can be found here ..
http://forum.blu-ray.com/showpost.ph...postcount=9971
Penton-Man is offline
post #94 of 129 Old 07-03-2009, 04:10 PM
Penton-Man's Avatar
If you care to vote, then vote with this information in mind, as there has been a recent reversal of fortune for option #1 proponents .
http://forum.blu-ray.com/showpost.ph...&postcount=144
post #95 of 129 Old 07-03-2009, 05:31 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3035
Although I currently don't have a CIH setup, I do feel sympathy for those that do and have to live with the current state of affairs.
For my 73" RPTV, I prefer subs in the lower black bar for 2:35 (etc.) AR.
I have seen films where subs are between the bars and it annoys me.
Primarily because I only have 73" to work with.
Nonetheless, the guys with CIH certainly do need a solution.
For everyone involved, I just can't think of anything working better than movable subs...
Any other ideas?
oink is offline
post #96 of 129 Old 07-03-2009, 06:45 PM
eric.exe's Avatar
Quoted: 16 Post(s)
Originally Posted by Penton-Man View Post
You’ve got to get out more.
Another AVS member already asked that question directly to me and your answer can be found here …..
Get out more? What does that have to do with subtitles?
Also, I find it incredibly hard to believe that making an extra set of subtitles costs a significant amount, considering I can adjust subtitle height with this FREE Blu-ray re-authoring program:
It takes about 5 minutes to extract the subtitles, and them mux them back into the movie file with a different height.
post #97 of 129 Old 07-04-2009, 09:18 AM
giantchicken's Avatar
Amazon.uk shipped my copy of CTHD. Looking forward to seeing this one in HD--I had to drive three hours to get to a theater that was playing this during its theatrical release, so I guess it's appropriate that I had to go to great lengths to get it on blu-ray.
PETER JACKSON: The theatrical versions are the definitive versions.
giantchicken is offline
post #98 of 129 Old 07-04-2009, 10:23 AM
AlexBC's Avatar
That's right Eric, there's simply no logic behind it being so expensive or diffult to do.
AlexBC is offline
post #99 of 129 Old 07-04-2009, 10:55 AM
oink's Avatar
Liked: 3035
WOW, that's very cool.
Like Alex said, what the heck is so hard here?
Why can't this kind of thing be burned onto a chip and put into players allowing the user control?
oink is offline
post #100 of 129 Old 07-04-2009, 03:29 PM
srw1000's Avatar
Quoted: 123 Post(s)
Liked: 89
That post states:
It is technically possible to have up to 32 subtitle streams, but if we double them up, then of course we will only have 16 languages.
The additional problem is that there is a significant cost to preparing dual streams and this is difficult to justify. Hence the reason that other studios don't do it, to my knowledge.
How much is significant?
srw1000 is offline
post #101 of 129 Old 07-05-2009, 07:38 PM
DJWV's Avatar
I have several quick and possibly silly questions for the tech savvy crew here...
1. There will not be an individual U.S. release outside the trilogy box set, correct? Can't find it anywhere online still.
2. So I need to buy a region free BluRay, right?
3. I want to confirm the region free BluRay will work on my PS3. Will it?
4. Where is the best and most trusted site to make this purchase if this is the case?
THANKS,
A simply guy with simple BluRay needs (with a lot of simple questions)
DJWV is offline
post #102 of 129 Old 07-06-2009, 12:12 AM
My copy will be here from the UK in a week or so. I'll let you know how my PS3 handles it.
post #103 of 129 Old 07-06-2009, 12:21 PM
Nlandeh's Avatar
Play.com still lists this as steelbook. Has anyone ordered their copy from them and can confirm if its a steelbook?
Nlandeh is offline
post #104 of 129 Old 07-06-2009, 12:32 PM
eric.exe's Avatar
Quoted: 16 Post(s)
http://forum.blu-ray.com/showpost.ph...2&postcount=73
post #105 of 129 Old 07-06-2009, 02:54 PM
DJWV's Avatar
Thanks GiantChicken, let me know.
DJWV is offline
post #106 of 129 Old 07-07-2009, 06:07 AM
paku's Avatar
A review from DVD Times with better screenshots, and it looks excellent.
(The ones on DVD Active look like they were taken at half vertical resolution or something, there's some fairly prominent aliasing.)
paku is offline
post #107 of 129 Old 07-07-2009, 10:40 AM
johnovox's Avatar
Quoted: 24 Post(s)
I know I am biased because I have a CIH setup, but I think the simple solution is to have the subs in the picture frame no matter what the aspect ratio is. With one simple solution, there should be no additional cost and everyone can see the subs.
johnovox is offline
post #108 of 129 Old 07-07-2009, 11:12 AM - Thread Starter
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
seriously SS from dvd Active were pretty depressing to look at as far as pq was concerned!
Still it is pretty soft, film like look, but as long as it is faithful to its theatric look I am contented! Some how I did like DTV HD presentation of it that always looked pale though in front of curse of golden flower, that had a very different look and feel to it.
zoro is offline
post #109 of 129 Old 07-07-2009, 12:12 PM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
If you care to vote, then vote with this information in mind, as there has been a recent reversal of fortune for option #1 proponents ………….
What?? No subtitles in the picture? We have to "lobby" to make Sony do this? (even though they did this on "Mongol")
What is the "ooohh so mighty BD Java" used for??
We where promised moveable subtitles (at least 2 positions), 2 subtitle sizes and 2 subtitle colors as a mandatory specs in BD!
Have Sony not yet understood that BD is a consumer product meant to serve the consumers (so they are willing to pay for it) and not a product serving their industrial partner politics, money pincing on features and a general lack of understanding of what are the needs of the paying consumers and what makes a great consumer product?
coolscan is offline
post #110 of 129 Old 07-07-2009, 02:17 PM - Thread Starter
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
Originally Posted by coolscan View Post
What?? No subtitles in the picture? We have to "lobby" to make Sony do this? (even though they did this on "Mogul")
I think you meant " MONGOL" Yes! Sony are pretty good in re authoring to sell you another one lol.
zoro is offline
post #111 of 129 Old 07-07-2009, 03:13 PM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
Thank you! "fixed".
coolscan is offline
post #112 of 129 Old 07-08-2009, 02:26 PM
tienvg's Avatar
I got mine today from amazon.uk, it is the steelbook edition
Took 4 days to get to south florida..
tienvg is offline
post #113 of 129 Old 07-08-2009, 05:44 PM
Thunderbolt8's Avatar
Thunderbolt8 is offline
post #114 of 129 Old 07-08-2009, 05:51 PM - Thread Starter
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
zoro is offline
post #115 of 129 Old 07-09-2009, 11:21 AM
Got mine today and hadn't been expecting a steelbook.
post #116 of 129 Old 07-09-2009, 03:27 PM
ZenAmako's Avatar
could not see!
Click on your address bar and hit enter to see the pics.
ZenAmako is offline
post #117 of 129 Old 07-09-2009, 05:38 PM - Thread Starter
zoro's Avatar
Quoted: 224 Post(s)
Liked: 41
thanks
zoro is offline
post #118 of 129 Old 07-11-2009, 10:43 AM
robertc88's Avatar
Read through the thread linked to find cuts on the US release:
http://forum.blu-ray.com/showthread....rouching+tiger
robertc88 is offline
post #119 of 129 Old 07-11-2009, 01:52 PM
tokerblue's Avatar
Quoted: 102 Post(s)
Liked: 73
Haven't found the answer to the earlier question... is the Steelbook edition region locked or can U.S. players play it? Also, I looked on AmazonUK's description and it said it was PAL format.
tokerblue is online now
post #120 of 129 Old 07-11-2009, 03:23 PM
I got the steelbook from Amazon UK and it is region free and plays in both my Vaio laptop and PS3.
PAL is not an issue with Blu-ray, as far as I understand.
Reply Blu-ray Software
