The Good, The Bad and the Ugly comparison *PIX* - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #181 of 532 Old 05-15-2009, 06:33 AM
Pincho's Avatar
Originally Posted by KMFDMvsEnya View Post
If revisionism is the justification then one could also argue that since film has a more limited dynamic range than video that it should be digitally tweaked to increase contrast.
Oh wait that has been done with some recent releases and results have generally been poor, or done by distorted TV picture tricks. Never mind that it distorts picture quality and changes the artistic intent, unless of course it is proper restoration.
Although the Mona Lisa would look better with neon colors.
Or perhaps do away with 24 frame motion blur which is also an inherent by product of shooting on film and at that frame rate. I'm sure that some do not like that blurring and prefer a more 'life-like' appearance. Oops again can be done with some TVs with interpolation and really how good does that look, fake quite frankly.
Otherwise we could argue nonsensical tangents till the moon turns red.
Best Regards
KvE
PS If Unicorns were in every shot those to should be removed. ;}~
All of your ideas mentioned throw the image from realistic looking to fake looking... they are not like grain removal which does the opposite, to make something change from fake looking to more realistic looking.
Genius is an insult to my intelligence!
Pincho is offline
post #182 of 532 Old 05-15-2009, 06:41 AM
Pincho's Avatar
Originally Posted by jrcorwin View Post
...what? You say grain is a fault. Fine. That's your opinion and you're welcome to it of course. Filmmakers, both past and present, appear to disagree with you. I'll side with them.
They had no choice. Oldschool breeds oldschool, now we have a new medium. We are no longer film viewers, we are now digital viewers. We have moved on, and directors have had their jobs for so long that they find it hard to learn new tricks.. (The old dog quote)
Pincho is offline
post #183 of 532 Old 05-15-2009, 06:42 AM
bosque11's Avatar
If you feel DNR looks realistic, you must know a lot of waxy-looking people.
bosque11 is offline
post #184 of 532 Old 05-15-2009, 06:47 AM
Pincho's Avatar
I said grain removal. I didn't say anything about removing details from people's faces.
Pincho is offline
post #185 of 532 Old 05-15-2009, 06:48 AM
Pecker's Avatar
Quoted: 42 Post(s)
Liked: 27
Originally Posted by Rigby Reardon View Post
Here's another consideration (from someone who is by no means an expert on film restoration, but knows a thing or two about video encoding): Grain is essentially noise that is hard to compress, thus consuming bandwidth when using lossy video compression. While that might sound surprising to some of you, grain reduction is often used to reduce artifacting and/or preserve more (!) high-frequency detail in the final encode. This is simply because grain reduction in many cases frees up bandwidth for a better encode. In some cases it can obviate the use of "brickwall" low-pass pre-encode filters that make the image more compressible.
To further add to the confusion , some systems (such as the DVO Grain Management software) have a "regrain" option that allows the technician to replace "ugly" or difficult to encode grain with artificial, "cleaner" grain. So when you see grain on a BD, it is not necessarily the original film grain ...
I've often suspected this.
Compression on DVD & Blu-ray Disc only works because of the principle that most frames are almost identical to the frame just before and just after it - a TV showing 'static' is supposed to be one of the most difficult things to encode.
Grain is random on film, so the encode must change every pixel which shows grain 24 times every second.
I can see why excessive grain would use up bandwidth at a frightening pace.
Steve W
Pecker is offline
post #186 of 532 Old 05-15-2009, 06:50 AM
jrcorwin's Avatar
No....we are not. The vast majority of films are produced on actual film stock.
jrcorwin is offline
post #187 of 532 Old 05-15-2009, 06:50 AM
jrcorwin's Avatar
Remove the grain and you remove detail.
jrcorwin is offline
post #188 of 532 Old 05-15-2009, 07:02 AM
Pincho's Avatar
Oldschool.. you want to stay oldschool that is up to you. But digital will replace 35mm in the next 2 years.
No.. you remove grain. You are quoting two opposing polar arguments which isn't logical.
Pincho is offline
post #189 of 532 Old 05-15-2009, 07:05 AM
jrcorwin's Avatar
You don't get it and that's fine. I'm not going to attack you over it. You've made your point and I've made mine. It's time for both of us to move on from this topic entirely.
jrcorwin is offline
post #190 of 532 Old 05-15-2009, 07:05 AM
Deviation's Avatar
There's no detail hiding "behind" the grain. The grain isn't a layer that you can remove with DNR to reveal the detail beneath. Grain is part of the image and removing it takes detail along with it. Period.
Deviation is offline
post #191 of 532 Old 05-15-2009, 07:07 AM
Pincho's Avatar
It is opaque, so you just brighten it to see the detail beneath. You make it's colour match the colour on the next, and previous frame where the grain has moved away from.
Pincho is offline
post #192 of 532 Old 05-15-2009, 07:22 AM
Pecker's Avatar
Quoted: 42 Post(s)
Liked: 27
That can't work, because at the same time you'd be sampling something with the 'correct' colour and evening it out using the grain in the next or previous frame, so you'd be taking away as much as you were giving.
Also, grain has its own look, which this removes.
Steve W
Pecker is offline
post #193 of 532 Old 05-15-2009, 07:27 AM
ack_bk's Avatar
Quoted: 603 Post(s)
Liked: 687
Originally Posted by ChuckZ View Post
300 was supposed to look very grainy. It was added digitally.
Yes, and you also had people concerned that there was something wrong with their Blu-Ray players and their displays because of all the grain.
I think the studios are honestly in a Catch-22 when it comes to grain.
Personally, I would rather have the grain and keep the detail then scrub it away and end up with waxy looking people.
ack_bk is offline
post #194 of 532 Old 05-15-2009, 07:27 AM
Rob Tomlin's Avatar
It's not an argument though.. it's a fact. Grain was originally a fault, and was learned to be lived with.
Grain is no more a "fault" than a painters canvas is.
Rob Tomlin is offline
post #195 of 532 Old 05-15-2009, 07:34 AM
Pincho's Avatar
Painters often hide the canvas beneath the thick paint. I'm a painter myself. Paintings are also vague, and are not supposed to look photo-realistic. Photo-realistic is a term taken from a camera, and a movie uses a camera, therefore a movie should look photo-realistic, as it includes all of the facilities for realism. The creation of the camera was to capture real life as closely as possible, and the objective of an painting is to capture real life as loosely as possible.
Pincho is offline
post #196 of 532 Old 05-15-2009, 07:34 AM
bt12483's Avatar
This is not the place to argue "better than DVD" excuses. You have to do better than that.
I think it's funny how your "tone" has changed since the days of posting HD DVD *PIX* threads....
From Beowulf HD DVD *PIX* thread:
Thats ok. I'm not imposing anything at all. What matters is its an obvious improment over standard definition.
Why is it that "obvious improvements over SD" used to be "what matters"....yet now "you have to do better than that"?
bt12483 is offline
post #197 of 532 Old 05-15-2009, 07:37 AM
Pincho's Avatar
Steve W
I'm not sure that this is correct. the skin pores that you don't want to remove should be stationary, and the grain should move. Therefore the waxy face can most likely be eliminated. I'm pretty sure that a graphic designer can do this by hand, but would take ages to do it. I always say that a computer can do what a human can do, but teaching it is difficult.
Pincho is offline
post #198 of 532 Old 05-15-2009, 07:41 AM
spectator's Avatar
That's the worst aesthetics lesson I've ever read!
I don't feel special...
spectator is offline
post #199 of 532 Old 05-15-2009, 07:41 AM
Rob Tomlin's Avatar
No, the intent of movies are not to recreate "real life as closely as possible".
post #200 of 532 Old 05-15-2009, 07:42 AM
Stinky-Dinkins's Avatar
Hahahahaha, what?!?
Stinky-Dinkins is offline
post #201 of 532 Old 05-15-2009, 07:44 AM
Pincho's Avatar
That becomes clear in the Jurassic Park thread, where the dinosaurs are all scrutinised with how realistic they look. People do want realism in most cases, but struggle to cope with change.
Pincho is offline
post #202 of 532 Old 05-15-2009, 07:47 AM
Pincho's Avatar
Originally Posted by Stinky-Dinkins View Post
Hahahahaha, what?!?
People do not buy photo-realistic paintings. They think that the artist is not being creative enough. The camera however was designed to capture real life.. originally of family members. A movie is a portrayal of a story that isn't supposed to stray into art that might throw you out of the real life environment. It should be believable in a sense, otherwise you aren't engrossed in the story fully.
Pincho is offline
post #203 of 532 Old 05-15-2009, 07:50 AM
spectator's Avatar
Just stop, Pincho, please! You clearly aren't an art history or aesthetics teacher and, frankly, thank God for it.
post #204 of 532 Old 05-15-2009, 07:51 AM
Rob Tomlin's Avatar
But wait, he is a painter. And a photographer!
post #205 of 532 Old 05-15-2009, 07:51 AM
There are about a billion different styles of approaching painting, and realism is one of, if not the, most popular genres (and account for some of history's most famous pieces.)
http://en.wikipedia.org/wiki/Realism_(visual_arts)
Likewise there are about a billion different ways of stylized photography that [purposefully] produce images far different than what your eyes can perceive. Different filters, etc.
I really don't have much of an opinion of The Good The Bad and the Ugly, but your painting/camera comparison was just asinine. It just makes very little sense.
post #206 of 532 Old 05-15-2009, 07:52 AM
jrcorwin's Avatar
My oh my
jrcorwin is offline
post #207 of 532 Old 05-15-2009, 07:53 AM
ack_bk's Avatar
Quoted: 603 Post(s)
Liked: 687
I find the animated Pixar more engrossing than about 95% of the movies out there that are shot on film. How do you explain that?
Sorry, but I call BS. The story is what makes a movie engrossing. You can tell a story with hand puppets and still engross the audience.
ack_bk is offline
post #208 of 532 Old 05-15-2009, 07:53 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 326 Post(s)
Liked: 6665
Ok, enough! Talk about the BD please. Although I can't believe there's really something new to be said.
larry
Ich bin hier und du bist mein Sofa
PooperScooper is offline
post #209 of 532 Old 05-15-2009, 07:55 AM
jrcorwin's Avatar
larry
Haha...ain't that the truth...
jrcorwin is offline
post #210 of 532 Old 05-15-2009, 10:32 AM
Scarfather's Avatar
Are we still discussing the actual topic? I saw that the thread has gone back to an argument instead of actual discussing.
Anyways, for what it's worth, here is a review from blu-ray.com: http://www.blu-ray.com/movies/movies...55&show=review
Scarfather is offline
Reply Blu-ray Software
The Good The Bad And The Ugly Blu Ray Widescreen
