NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #3871 of 5099 Old 01-21-2012, 06:57 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Kuros View Post
Has the data for the Dolby TrueHD audio track been mis-reported?
Do you mean the low bitrate? That is indeed pretty low, but not unheard of - TrueHD does a pretty good job of compressing out silence, so if the surround channels are frequently inactive then it's probably reasonable for a 16-bit track.
Here is my list of 5.1 TrueHD tracks ordered by bitrate ascending (apologies if this page is slow to load):
http://www.cinemasquid.com/blu-ray/m...t-rate&dir=asc
I haven't done it myself in awhile, but you can spot check numbers by demuxing the raw streams using eac3to, TSMuxer, etc. and dividing stream sizes by duration. It's kind of pain in the ass, although this is how benes et al. came up with the original specs prior to BDInfo. Worth noting that if you demux a single stream into a container like M2TS instead of as raw stream, the numbers will be ~10-15% higher than what BDInfo reports.
Cinema Squid is offline
post #3872 of 5099 Old 01-21-2012, 09:07 PM
eNoize's Avatar
Quoted: 51 Post(s)
Liked: 90
[US] The English Patient
Region A Locked
Studio: Lionsgate Home Entertainment
UPC: 031398147626
Release Date: 2012-01-31
Aspect Ratio: 1.85:1
Code:
        Total   Video
00800.MPLS                                                      AVC     2:41:52 36,197,074,944  46,205,922,301  29.81   23.49   DTS-HD Master 5.1 4204Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     THE_ENGLISH_PATIENT
Disc Size:      46,205,922,301 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 2:41:52 (h:m:s)
Total Bitrate:          29.81 Mbps
VIDEO:
MPEG-4 AVC Video        23491 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4204 kbps       5.1 / 48 kHz / 4204 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         36.758 kbps
Presentation Graphics           English         42.837 kbps
Presentation Graphics           Spanish         33.996 kbps
FILES:
00800.M2TS      0:00:00.000     2:41:52.703     36,197,074,944  29,814
CHAPTERS:
1               0:00:00.000     0:11:51.085     24,715 kbps     37,170 kbps     00:06:14.123    35,476 kbps     00:06:36.938    34,941 kbps     00:06:31.974    128,845 bytes   315,561 bytes   00:11:51.085
2               0:11:51.085     0:15:39.396     27,496 kbps     37,849 kbps     00:13:52.248    36,874 kbps     00:21:46.430    36,620 kbps     00:21:43.593    143,350 bytes   437,576 bytes   00:13:44.824
3               0:27:30.482     0:16:25.901     24,200 kbps     37,318 kbps     00:43:38.699    36,444 kbps     00:30:26.032    35,196 kbps     00:30:25.031    126,168 bytes   508,908 bytes   00:30:26.074
4               0:43:56.383     0:09:05.169     24,165 kbps     34,072 kbps     00:46:34.458    32,915 kbps     00:46:34.082    31,951 kbps     00:47:43.235    125,987 bytes   372,876 bytes   00:47:41.149
5               0:53:01.553     0:05:42.091     21,847 kbps     32,451 kbps     00:54:29.683    29,845 kbps     00:54:26.221    28,416 kbps     00:54:36.564    113,901 bytes   259,464 bytes   00:55:25.989
6               0:58:43.645     0:12:43.763     23,551 kbps     37,576 kbps     01:10:20.466    36,180 kbps     01:10:16.712    33,953 kbps     01:09:05.015    122,782 bytes   339,485 bytes   01:03:53.621
7               1:11:27.408     0:13:23.219     26,931 kbps     37,620 kbps     01:22:07.297    36,693 kbps     01:19:09.369    35,077 kbps     01:19:04.990    140,408 bytes   343,713 bytes   01:21:30.343
8               1:24:50.627     0:09:44.542     25,744 kbps     37,483 kbps     01:30:55.616    36,795 kbps     01:30:54.615    35,415 kbps     01:30:52.697    134,217 bytes   400,900 bytes   01:32:24.080
9               1:34:35.169     0:10:28.252     26,965 kbps     37,462 kbps     01:39:06.482    35,455 kbps     01:35:45.656    34,168 kbps     01:35:44.738    140,584 bytes   294,640 bytes   01:39:07.066
10              1:45:03.422     0:10:32.089     21,066 kbps     36,882 kbps     01:53:07.197    34,293 kbps     01:55:24.751    33,456 kbps     01:55:19.329    109,826 bytes   363,868 bytes   01:55:23.791
11              1:55:35.511     0:05:09.308     25,692 kbps     49,468 kbps     02:00:07.116    36,091 kbps     02:00:14.624    33,263 kbps     02:00:11.287    133,944 bytes   548,577 bytes   02:00:14.874
12              2:00:44.820     0:07:56.350     19,250 kbps     35,576 kbps     02:06:18.320    31,279 kbps     02:06:14.733    29,405 kbps     02:06:13.857    100,360 bytes   343,814 bytes   02:02:33.888
13              2:08:41.171     0:06:34.102     18,853 kbps     30,303 kbps     02:09:31.346    29,188 kbps     02:11:08.819    27,384 kbps     02:08:53.183    98,290 bytes    299,284 bytes   02:08:53.225
14              2:15:15.273     0:08:56.994     21,805 kbps     37,227 kbps     02:22:36.422    36,633 kbps     02:22:36.422    36,362 kbps     02:22:36.422    113,679 bytes   387,979 bytes   02:16:15.041
15              2:24:12.268     0:04:57.213     23,456 kbps     37,647 kbps     02:24:51.182    35,547 kbps     02:24:51.099    33,046 kbps     02:24:48.680    122,290 bytes   448,422 bytes   02:24:57.647
16              2:29:09.482     0:12:43.220     15,848 kbps     37,810 kbps     02:35:30.487    36,909 kbps     02:35:26.525    36,734 kbps     02:36:06.815    82,630 bytes    324,678 bytes   02:35:10.551
STREAM DIAGNOSTICS:
00800.M2TS      4113 (0x1011)   0x1B            AVC                                     9712.536                23,491                  28,519,600,126  155,133,478
00800.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9712.536                4,204                   5,103,528,836   29,252,320
00800.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           9712.536                224                     271,955,712     1,517,610
00800.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9712.536                224                     271,955,712     1,517,610
00800.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9712.536                37                      44,627,337      252,215
00800.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           9712.536                43                      52,007,998      294,348
00800.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           9712.536                34                      41,274,287      233,449
M. Enois Duarte
High-Def Digest
eNoize is offline
post #3873 of 5099 Old 01-22-2012, 01:04 AM
saginawjuggalo's Avatar
Quoted: 47 Post(s)
Liked: 51
Code:
        Total   Video
00004.MPLS                                                      AVC     1:44:27 32,551,280,640  41,027,145,199  41.55   35.00   DTS-HD Master 5.1 4147Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     WONDERLAND
Disc Size:      41,027,145,199 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:44:27.094 (h:m:s.ms)
Total Bitrate:          41.55 Mbps
VIDEO:
MPEG-4 AVC Video        35004 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4147 kbps       5.1 / 48 kHz / 4147 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit / DN -4dB)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         44.239 kbps
Presentation Graphics           English         47.532 kbps
Presentation Graphics           Spanish         41.899 kbps
FILES:
00312.M2TS      0:00:00.000     1:44:27.094     32,551,280,640  41,552
CHAPTERS:
1               0:00:00.000     0:06:01.110     32,846 kbps     39,610 kbps     00:00:57.849    37,304 kbps     00:04:19.759    37,005 kbps     00:04:52.959    171,223 bytes   394,237 bytes   00:01:27.879
2               0:06:01.110     0:08:57.578     35,760 kbps     39,267 kbps     00:12:45.556    37,365 kbps     00:11:50.084    36,962 kbps     00:11:45.079    186,436 bytes   421,696 bytes   00:09:33.155
3               0:14:58.689     0:04:30.937     35,799 kbps     40,939 kbps     00:16:32.658    37,385 kbps     00:16:19.311    36,894 kbps     00:17:47.441    186,641 bytes   558,351 bytes   00:19:28.834
4               0:19:29.626     0:05:19.277     35,129 kbps     40,930 kbps     00:21:02.636    37,094 kbps     00:22:44.029    36,886 kbps     00:22:16.710    183,146 bytes   372,460 bytes   00:20:02.159
5               0:24:48.904     0:06:03.321     36,182 kbps     39,382 kbps     00:25:31.863    37,320 kbps     00:25:27.859    36,969 kbps     00:27:59.260    188,639 bytes   348,707 bytes   00:29:08.496
6               0:30:52.225     0:04:50.415     36,179 kbps     40,982 kbps     00:33:32.552    37,375 kbps     00:34:04.292    37,086 kbps     00:32:25.652    188,623 bytes   359,213 bytes   00:33:33.177
7               0:35:42.640     0:04:35.608     35,714 kbps     40,388 kbps     00:39:50.012    37,268 kbps     00:37:36.337    36,893 kbps     00:38:54.415    186,198 bytes   411,251 bytes   00:39:01.130
8               0:40:18.249     0:03:58.446     36,347 kbps     38,842 kbps     00:40:33.264    37,200 kbps     00:40:29.385    36,935 kbps     00:40:57.746    189,494 bytes   359,632 bytes   00:40:34.140
9               0:44:16.695     0:08:03.858     36,084 kbps     39,410 kbps     00:51:19.409    37,276 kbps     00:49:25.462    36,997 kbps     00:49:20.499    188,125 bytes   346,224 bytes   00:49:31.051
10              0:52:20.554     0:04:54.877     36,177 kbps     43,480 kbps     00:53:23.533    37,169 kbps     00:56:52.659    36,928 kbps     00:54:33.228    188,611 bytes   464,570 bytes   00:53:24.075
11              0:57:15.431     0:04:55.962     36,232 kbps     39,462 kbps     00:58:09.068    37,129 kbps     00:59:54.632    36,873 kbps     00:58:37.639    188,896 bytes   395,062 bytes   00:57:17.308
12              1:02:11.394     0:07:50.553     36,367 kbps     39,219 kbps     01:05:03.232    37,122 kbps     01:05:05.109    36,914 kbps     01:03:19.003    189,602 bytes   363,783 bytes   01:04:36.747
13              1:10:01.947     0:10:30.838     36,250 kbps     39,834 kbps     01:20:03.590    37,225 kbps     01:18:29.079    36,982 kbps     01:20:08.345    188,989 bytes   359,257 bytes   01:18:12.145
14              1:20:32.786     0:08:24.170     36,299 kbps     40,938 kbps     01:25:39.926    37,112 kbps     01:25:04.224    36,950 kbps     01:21:55.035    189,246 bytes   355,656 bytes   01:25:37.298
15              1:28:56.956     0:08:15.828     36,273 kbps     39,564 kbps     01:34:05.014    37,208 kbps     01:34:01.093    36,901 kbps     01:29:37.288    189,109 bytes   346,160 bytes   01:32:48.020
16              1:37:12.785     0:07:14.308     23,237 kbps     38,645 kbps     01:37:13.452    37,238 kbps     01:37:34.849    36,911 kbps     01:39:15.866    121,161 bytes   384,231 bytes   01:38:46.378
STREAM DIAGNOSTICS:
00312.M2TS      4113 (0x1011)   0x1B            AVC                                     6266.927                35,005                  27,421,467,524  149,117,321
00312.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6266.927                4,148                   3,249,082,648   18,634,926
00312.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6266.927                224                     175,478,912     979,235
00312.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6266.927                44                      34,655,912      197,068
00312.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6266.927                48                      37,236,279      211,965
00312.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6266.927                42                      32,823,091      187,412
JVC DLA-RS40 w/003 lamp,DIY False-wall 125" acoustically transparent screen,Darbee Darblet,Sanyo PLV-Z2000 (gaming),7.1 DIYSoundGroup 1099 x3 LCR & Slanted Volt 6 rears x4,Onkyo TX-NR818,Emotiva LPA-1,Behringer EP4000 (x2),Sealed Stereo Integrity HT18"s (x8),Balanced MiniDSP,Cross·Spectrum UMIK-1,DIY Acoustic Treatments,PS3,Sony BDP-S590,Seiki SR4KP1 Region Free BDP,Toshiba HD-A1,Roku,Outdoor Antenna,APC H15 power conditioner,Harmony Smart Control,Rebuilding*HTPC,Leather Theater seating etc.
saginawjuggalo is offline
post #3874 of 5099 Old 01-22-2012, 04:11 PM
ricabullah's Avatar
Cinema Squid,
FYI:
http://www.quadraphonicquad.com/foru...HD-DVD-too!%29
Chronical Tester
ricabullah is offline
post #3875 of 5099 Old 01-23-2012, 05:11 AM
Mizu_Ger's Avatar
Not sure. It was a rental so I don't have the disk anymore. It does seem very low, but I assume they can use whatever bitrate they want.
Mizu_Ger is offline
post #3876 of 5099 Old 01-23-2012, 05:22 AM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
Originally Posted by Big C View Post
Unless you care more about audio than video, don't buy any BDs from Image Entertainment! They are recorded onto single-layer 25GB discs, resulting in a lower video bitrate. If you have a nice TV, don't hold it back! I will not buy a BD from Image Entertainment unless they take full advantage of the format! I didn't even check for "Children of the Corn." If you're not a fan of sequels like I'm not, get the Anchor Bay editions. If you already have it, then don't waste time on the Image Entertainment editions. If you are a fan of sequels, make sure that the Japan Hellraiser box set is multi-region and add that one to your collection. The specs are similar to the Anchor Bay editions (at least for "Hellraiser I").
At least Image Entertainment didn't revert to an MPEG2 encode. By keeping an MPEG4 encode, the video shouldn't be as bad at a lower bitrate as an MPEG2 encode would have been. Also, the Image Entertainment edition uses DTS-HD Master Audio, which is an upgrade from the Anchor Bay edition. I found CinemaSquid's specs for "Hellraiser." I would also like someone to post the specs for the Image Entertainment edition of the 1984 "Children of the Corn" film. I have a feeling it'll probibly have 16-bit audio, but with a higher bitrate, it'll be closer to CD sound.
Big C is offline
post #3877 of 5099 Old 01-24-2012, 04:24 PM
eNoize's Avatar
Quoted: 51 Post(s)
Liked: 90
[US] Nothing in Common
Region A Locked
Studio: Image Entertainment
UPC: 014381753356
Code:
        Total   Video
00001.MPLS                                                      AVC     1:58:57 23,096,229,888  23,790,142,047  25.89   22.90   LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     NOTHING_IN_COMMON
Disc Size:      23,790,142,047 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:58:57 (h:m:s)
Total Bitrate:          25.89 Mbps
VIDEO:
MPEG-4 AVC Video        22901 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         31.186 kbps
Presentation Graphics           Spanish         37.210 kbps
FILES:
00011.M2TS      0:00:00.000     1:58:57.130     23,096,229,888  25,889
CHAPTERS:
1               0:00:00.000     0:07:23.234     21,257 kbps     41,706 kbps     00:00:03.837    33,405 kbps     00:02:37.240    28,410 kbps     00:02:37.240    110,814 bytes   537,471 bytes   00:02:37.282
2               0:07:23.234     0:05:35.209     21,436 kbps     30,610 kbps     00:08:51.155    27,836 kbps     00:08:50.530    25,663 kbps     00:08:49.153    111,760 bytes   492,529 bytes   00:12:47.892
3               0:12:58.444     0:06:34.102     22,112 kbps     30,301 kbps     00:19:24.955    26,260 kbps     00:18:04.124    25,820 kbps     00:17:59.119    115,284 bytes   512,211 bytes   00:18:08.504
4               0:19:32.546     0:06:33.351     24,976 kbps     42,227 kbps     00:26:00.016    32,102 kbps     00:25:58.306    31,175 kbps     00:20:49.164    130,212 bytes   554,102 bytes   00:23:46.633
5               0:26:05.897     0:09:09.382     21,194 kbps     27,729 kbps     00:34:17.805    23,567 kbps     00:31:56.456    23,227 kbps     00:26:07.607    110,497 bytes   458,903 bytes   00:32:00.668
6               0:35:15.279     0:05:39.672     25,526 kbps     39,292 kbps     00:35:25.498    34,020 kbps     00:35:55.653    33,670 kbps     00:35:50.356    133,079 bytes   629,400 bytes   00:38:37.606
7               0:40:54.952     0:08:55.743     23,275 kbps     37,021 kbps     00:45:08.664    32,916 kbps     00:45:04.827    32,586 kbps     00:44:59.822    121,347 bytes   598,869 bytes   00:45:08.706
8               0:49:50.696     0:06:23.174     26,704 kbps     38,262 kbps     00:52:59.843    33,807 kbps     00:53:05.390    33,051 kbps     00:51:06.021    139,223 bytes   621,181 bytes   00:50:40.704
9               0:56:13.870     0:06:29.847     24,496 kbps     38,845 kbps     00:57:09.175    32,962 kbps     00:57:22.856    32,472 kbps     00:57:17.642    127,710 bytes   587,719 bytes   00:57:25.275
10              1:02:43.718     0:07:19.981     21,647 kbps     33,850 kbps     01:04:38.666    27,133 kbps     01:03:34.602    26,708 kbps     01:03:34.602    112,856 bytes   556,351 bytes   01:04:39.208
11              1:10:03.699     0:08:53.032     21,780 kbps     34,326 kbps     01:13:08.008    30,340 kbps     01:11:49.013    28,622 kbps     01:11:43.966    113,552 bytes   517,564 bytes   01:13:08.133
12              1:18:56.732     0:07:37.790     21,596 kbps     28,602 kbps     01:20:12.849    24,804 kbps     01:24:43.244    24,305 kbps     01:22:30.820    112,594 bytes   472,863 bytes   01:24:40.825
13              1:26:34.522     0:06:24.550     22,025 kbps     31,888 kbps     01:32:23.788    28,884 kbps     01:32:06.479    28,139 kbps     01:32:04.018    114,826 bytes   518,255 bytes   01:31:34.780
14              1:32:59.073     0:07:21.649     23,356 kbps     33,369 kbps     01:34:11.187    28,680 kbps     01:33:56.213    28,563 kbps     01:33:51.250    121,767 bytes   494,481 bytes   01:33:43.159
15              1:40:20.723     0:07:46.048     23,889 kbps     34,982 kbps     01:46:19.414    31,844 kbps     01:46:21.666    31,581 kbps     01:46:16.661    124,548 bytes   536,054 bytes   01:46:56.535
16              1:48:06.771     0:10:50.358     22,748 kbps     40,244 kbps     01:52:29.367    34,676 kbps     01:52:34.831    34,183 kbps     01:52:29.367    118,614 bytes   578,761 bytes   01:53:19.042
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     7137.047                22,901                  20,430,659,640  111,136,564
00011.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           7137.047                1,542                   1,376,038,664   8,564,556
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7137.047                31                      27,822,575      162,490
00011.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7137.047                37                      33,196,580      190,157
M. Enois Duarte
High-Def Digest
eNoize is offline
post #3878 of 5099 Old 01-25-2012, 03:54 AM
Stephen Dawson's Avatar
True Grit - 1969 - UK versionhttp://www.imdb.com/title/tt0065126/
Distributed by Paramount Home Entertainment (UK)
Region free, confirmed with multiregion Blu-ray player
Seems to be pretty much the same as the US version, except for a different language package.
Code:
        Total   Video
00001.MPLS                                                      AVC     2:08:04 38,512,594,944  42,106,522,771  40.09   31.94   DTS-HD Master 5.1 3238Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     TRUE_GRIT
Disc Size:      42,106,522,771 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:08:04.677 (h:m:s.ms)
Total Bitrate:          40.09 Mbps
VIDEO:
MPEG-4 AVC Video        31938 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3238 kbps       5.1 / 48 kHz / 3238 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             German          224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Italian         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
Dolby Digital Audio             Hungarian       224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         45.230 kbps
Presentation Graphics           English         47.138 kbps
Presentation Graphics           French          40.919 kbps
Presentation Graphics           German          41.022 kbps
Presentation Graphics           Italian         40.117 kbps
Presentation Graphics           Spanish         40.916 kbps
Presentation Graphics           Dutch           34.424 kbps
Presentation Graphics           Bulgarian       42.013 kbps
Presentation Graphics           Chinese         29.898 kbps
Presentation Graphics           Croatian        36.725 kbps
Presentation Graphics           Danish          39.060 kbps
Presentation Graphics           Estonian        42.419 kbps
Presentation Graphics           Finnish         38.309 kbps
Presentation Graphics           Greek           38.989 kbps
Presentation Graphics           Hebrew          25.713 kbps
Presentation Graphics           Hindi           29.222 kbps
Presentation Graphics           Hungarian       40.554 kbps
Presentation Graphics           Korean          27.220 kbps
Presentation Graphics           Latvian         38.177 kbps
Presentation Graphics           Norwegian       36.294 kbps
Presentation Graphics           Portuguese      39.566 kbps
Presentation Graphics           Romanian        37.820 kbps
Presentation Graphics           Serbian         35.556 kbps
Presentation Graphics           Swedish         37.772 kbps
Presentation Graphics           Thai            33.305 kbps
Presentation Graphics           English         56.796 kbps
Presentation Graphics           French          47.875 kbps
Presentation Graphics           German          49.566 kbps
Presentation Graphics           Italian         48.482 kbps
Presentation Graphics           Spanish         48.132 kbps
Presentation Graphics           Lithuanian      39.401 kbps
Presentation Graphics           Chinese         30.827 kbps
FILES:
00125.M2TS      0:00:00.000     2:08:04.677     38,512,594,944  40,093
CHAPTERS:
1               0:00:00.000     0:12:54.774     31,951 kbps     44,619 kbps     00:05:14.397    35,383 kbps     00:00:09.718    34,329 kbps     00:00:09.592    166,570 bytes   616,642 bytes   00:01:04.522
2               0:12:54.774     0:05:43.676     32,047 kbps     39,130 kbps     00:13:34.063    34,332 kbps     00:13:34.063    33,800 kbps     00:12:58.778    167,080 bytes   519,932 bytes   00:13:45.908
3               0:18:38.450     0:12:41.719     31,402 kbps     38,751 kbps     00:30:11.434    34,274 kbps     00:26:07.023    33,121 kbps     00:26:02.811    163,718 bytes   512,249 bytes   00:26:15.365
4               0:31:20.169     0:16:47.881     31,604 kbps     41,701 kbps     00:34:41.370    34,246 kbps     00:35:15.780    33,737 kbps     00:35:15.822    164,770 bytes   578,578 bytes   00:34:42.371
5               0:48:08.051     0:11:42.743     32,647 kbps     44,457 kbps     00:54:11.998    37,650 kbps     00:57:18.643    36,560 kbps     00:57:26.401    170,206 bytes   645,560 bytes   00:54:38.775
6               0:59:50.795     0:18:41.662     31,455 kbps     48,163 kbps     01:03:47.782    35,280 kbps     01:01:13.294    34,948 kbps     01:01:11.626    163,992 bytes   680,090 bytes   00:59:51.504
7               1:18:32.457     0:07:23.943     32,654 kbps     41,592 kbps     01:21:36.182    34,996 kbps     01:21:32.262    34,303 kbps     01:19:13.874    170,242 bytes   575,897 bytes   01:19:27.763
8               1:25:56.401     0:09:49.297     32,075 kbps     44,534 kbps     01:34:33.751    35,188 kbps     01:30:57.160    34,476 kbps     01:30:51.988    167,225 bytes   759,776 bytes   01:34:33.959
9               1:35:45.698     0:06:29.263     32,472 kbps     44,391 kbps     01:36:36.707    36,133 kbps     01:36:41.212    34,550 kbps     01:36:36.707    169,297 bytes   681,699 bytes   01:38:16.432
10              1:42:14.962     0:05:58.107     32,383 kbps     41,974 kbps     01:47:21.184    35,357 kbps     01:45:09.177    34,411 kbps     01:45:08.343    168,830 bytes   595,614 bytes   01:47:29.568
11              1:48:13.069     0:13:46.033     32,391 kbps     43,784 kbps     01:50:02.596    36,820 kbps     01:49:58.675    35,395 kbps     01:50:07.976    168,873 bytes   670,654 bytes   02:00:06.324
12              2:01:59.103     0:05:06.889     31,132 kbps     41,238 kbps     02:04:09.942    34,185 kbps     02:06:47.641    33,141 kbps     02:06:43.137    162,306 bytes   556,764 bytes   02:04:10.901
13              2:07:05.993     0:00:58.683     29,384 kbps     41,227 kbps     02:07:56.293    33,886 kbps     02:07:06.619    33,139 kbps     02:07:06.619    153,412 bytes   519,064 bytes   02:07:43.197
STREAM DIAGNOSTICS:
00125.M2TS      4113 (0x1011)   0x1B            AVC                                     7684.594                31,939                  30,679,487,622  166,844,567
00125.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7684.594                3,238                   3,110,367,240   18,106,575
00125.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7684.594                224                     215,171,712     1,200,735
00125.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            7684.594                224                     215,171,712     1,200,735
00125.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            7684.594                224                     215,171,712     1,200,735
00125.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           7684.594                224                     215,171,712     1,200,735
00125.M2TS      4357 (0x1105)   0x81            AC3             spa (Spanish)           7684.594                224                     215,171,712     1,200,735
00125.M2TS      4358 (0x1106)   0x81            AC3             hun (Hungarian)         7684.594                224                     215,171,712     1,200,735
00125.M2TS      4359 (0x1107)   0x81            AC3             eng (English)           7684.594                224                     215,171,712     1,200,735
00125.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7684.594                45                      43,447,012      245,511
00125.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7684.594                47                      45,280,186      256,150
00125.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7684.594                41                      39,306,426      223,130
00125.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            7684.594                41                      39,404,646      224,008
00125.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           7684.594                40                      38,535,776      219,119
00125.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           7684.594                41                      39,303,463      223,416
00125.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             7684.594                34                      33,066,753      188,371
00125.M2TS      4615 (0x1207)   0x90            PGS             bul (Bulgarian)         7684.594                42                      40,357,429      229,442
00125.M2TS      4616 (0x1208)   0x90            PGS             zho (Chinese)           7684.594                30                      28,719,788      165,852
00125.M2TS      4617 (0x1209)   0x90            PGS             hrv (Croatian)          7684.594                37                      35,277,921      201,543
00125.M2TS      4618 (0x120A)   0x90            PGS             dan (Danish)            7684.594                39                      37,520,308      213,714
00125.M2TS      4619 (0x120B)   0x90            PGS             est (Estonian)          7684.594                42                      40,747,108      231,297
00125.M2TS      4620 (0x120C)   0x90            PGS             fin (Finnish)           7684.594                38                      36,798,589      209,349
00125.M2TS      4621 (0x120D)   0x90            PGS             ell (Greek)             7684.594                39                      37,452,403      213,387
00125.M2TS      4622 (0x120E)   0x90            PGS             heb (Hebrew)            7684.594                26                      24,699,493      144,073
00125.M2TS      4623 (0x120F)   0x90            PGS             hin (Hindi)             7684.594                29                      28,070,014      162,361
00125.M2TS      4624 (0x1210)   0x90            PGS             hun (Hungarian)         7684.594                41                      38,955,248      221,534
00125.M2TS      4625 (0x1211)   0x90            PGS             kor (Korean)            7684.594                27                      26,147,572      151,919
00125.M2TS      4626 (0x1212)   0x90            PGS             lav (Latvian)           7684.594                38                      36,672,059      209,121
00125.M2TS      4627 (0x1213)   0x90            PGS             nor (Norwegian)         7684.594                36                      34,863,270      199,003
00125.M2TS      4628 (0x1214)   0x90            PGS             por (Portuguese)        7684.594                40                      38,006,445      216,116
00125.M2TS      4629 (0x1215)   0x90            PGS             ron (Romanian)          7684.594                38                      36,329,125      207,012
00125.M2TS      4630 (0x1216)   0x90            PGS             srp (Serbian)           7684.594                36                      34,154,115      195,441
00125.M2TS      4631 (0x1217)   0x90            PGS             swe (Swedish)           7684.594                38                      36,283,086      206,625
00125.M2TS      4632 (0x1218)   0x90            PGS             tha (Thai)              7684.594                33                      31,992,453      183,681
00125.M2TS      4633 (0x1219)   0x90            PGS             eng (English)           7684.594                57                      54,557,297      306,982
00125.M2TS      4634 (0x121A)   0x90            PGS             fra (French)            7684.594                48                      45,988,259      260,842
00125.M2TS      4635 (0x121B)   0x90            PGS             deu (German)            7684.594                50                      47,612,756      269,500
00125.M2TS      4636 (0x121C)   0x90            PGS             ita (Italian)           7684.594                48                      46,570,622      263,991
00125.M2TS      4637 (0x121D)   0x90            PGS             spa (Spanish)           7684.594                48                      46,234,525      262,172
00125.M2TS      4638 (0x121E)   0x90            PGS             lit (Lithuanian)        7684.594                39                      37,848,263      215,555
00125.M2TS      4639 (0x121F)   0x90            PGS             zho (Chinese)           7684.594                31                      29,612,338      170,690
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #3879 of 5099 Old 01-25-2012, 04:28 AM
THX 1138 - 1971 - UK version
Distributed by Warner Home Video (UK) Limited
Seems to be identical to US version, aside from a slightly different report for disc size.
English DD2.0 is a commentary. English DD5.1 is sound effects only.
Code:
        Total   Video
00100.MPLS                                                      VC-1    1:28:31 21,487,878,144  29,778,561,838  32.37   24.09   DTS-HD Master 5.1 3533Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     THX_1138
Disc Size:      29,778,561,838 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:28:31.347 (h:m:s.ms)
Total Bitrate:          32.37 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
VC-1 Video              24089 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3533 kbps       5.1 / 48 kHz / 3533 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
* Presentation Graphics         Japanese        16.791 kbps
Presentation Graphics           English         28.277 kbps
Presentation Graphics           French          17.817 kbps
Presentation Graphics           German          30.457 kbps
Presentation Graphics           Spanish         25.389 kbps
Presentation Graphics           Dutch           24.267 kbps
Presentation Graphics           Spanish         24.132 kbps
Presentation Graphics           Danish          21.125 kbps
Presentation Graphics           Finnish         24.574 kbps
Presentation Graphics           Norwegian       23.846 kbps
Presentation Graphics           Swedish         20.226 kbps
* Presentation Graphics         Japanese        43.776 kbps
FILES:
00010.M2TS      0:00:00.000     1:28:31.347     21,487,878,144  32,365
CHAPTERS:
1               0:00:00.000     0:02:57.176     7,056 kbps      40,191 kbps     00:00:04.295    30,807 kbps     00:00:03.253    25,868 kbps     00:00:02.210    37,161 bytes    294,611 bytes   00:00:09.009
2               0:02:57.176     0:02:12.090     24,303 kbps     44,032 kbps     00:03:54.734    33,821 kbps     00:04:20.677    31,864 kbps     00:04:15.672    127,955 bytes   398,725 bytes   00:03:51.773
3               0:05:09.267     0:02:36.865     27,420 kbps     47,890 kbps     00:06:12.080    35,113 kbps     00:07:28.030    31,978 kbps     00:07:27.947    142,953 bytes   414,894 bytes   00:06:12.121
4               0:07:46.132     0:04:16.005     23,649 kbps     32,804 kbps     00:07:59.770    30,806 kbps     00:11:54.714    28,843 kbps     00:09:00.790    123,293 bytes   276,268 bytes   00:08:26.923
5               0:12:02.138     0:04:25.348     25,848 kbps     46,185 kbps     00:13:37.107    33,838 kbps     00:14:48.804    31,112 kbps     00:14:44.341    134,759 bytes   314,403 bytes   00:13:19.799
6               0:16:27.486     0:02:49.669     22,903 kbps     43,658 kbps     00:18:15.511    33,932 kbps     00:18:12.007    30,623 kbps     00:18:10.005    119,407 bytes   259,108 bytes   00:18:15.803
7               0:19:17.156     0:05:05.305     23,960 kbps     42,759 kbps     00:21:21.071    32,100 kbps     00:21:28.745    31,717 kbps     00:21:21.071    124,916 bytes   355,998 bytes   00:21:21.113
8               0:24:22.461     0:05:50.308     23,652 kbps     33,571 kbps     00:25:43.917    31,413 kbps     00:25:42.832    30,606 kbps     00:25:36.618    123,310 bytes   273,958 bytes   00:25:44.459
9               0:30:12.769     0:04:34.315     25,535 kbps     44,434 kbps     00:33:06.734    33,319 kbps     00:33:06.734    31,213 kbps     00:30:31.454    133,129 bytes   531,362 bytes   00:30:32.664
10              0:34:47.085     0:03:50.229     23,945 kbps     33,867 kbps     00:37:50.643    32,549 kbps     00:37:49.308    31,954 kbps     00:37:44.387    126,187 bytes   357,742 bytes   00:37:39.507
11              0:38:37.314     0:04:37.527     26,556 kbps     40,374 kbps     00:41:28.194    35,205 kbps     00:41:26.650    31,847 kbps     00:41:38.621    138,451 bytes   340,184 bytes   00:41:28.235
12              0:43:14.842     0:02:50.753     24,934 kbps     34,008 kbps     00:46:03.677    32,502 kbps     00:45:10.791    31,757 kbps     00:45:49.997    129,992 bytes   222,858 bytes   00:45:11.792
13              0:46:05.596     0:05:59.984     23,916 kbps     35,772 kbps     00:50:40.829    34,586 kbps     00:50:36.825    30,784 kbps     00:50:31.862    124,688 bytes   219,408 bytes   00:50:37.993
14              0:52:05.580     0:03:15.361     23,736 kbps     31,789 kbps     00:54:29.724    30,129 kbps     00:54:27.305    27,105 kbps     00:54:26.054    123,750 bytes   220,033 bytes   00:53:44.471
15              0:55:20.942     0:03:58.821     23,482 kbps     29,016 kbps     00:58:13.406    28,214 kbps     00:58:03.146    27,856 kbps     00:58:04.814    122,425 bytes   213,459 bytes   00:56:35.350
16              0:59:19.764     0:02:10.463     25,339 kbps     45,646 kbps     01:01:23.471    33,331 kbps     01:01:23.471    31,389 kbps     00:59:23.393    132,106 bytes   441,655 bytes   00:59:25.228
17              1:01:30.228     0:03:10.982     23,116 kbps     31,116 kbps     01:01:58.631    29,148 kbps     01:01:57.588    28,678 kbps     01:01:30.228    120,518 bytes   298,896 bytes   01:03:13.122
18              1:04:41.210     0:02:16.511     26,515 kbps     47,751 kbps     01:05:10.489    32,938 kbps     01:04:55.850    30,929 kbps     01:04:55.808    138,237 bytes   351,836 bytes   01:05:06.652
19              1:06:57.722     0:02:35.864     25,058 kbps     28,351 kbps     01:07:06.272    27,884 kbps     01:07:02.268    27,466 kbps     01:07:01.017    130,640 bytes   231,559 bytes   01:07:43.017
20              1:09:33.586     0:02:43.163     26,142 kbps     39,170 kbps     01:11:38.168    34,635 kbps     01:11:34.206    30,568 kbps     01:11:29.201    136,290 bytes   307,386 bytes   01:11:38.919
21              1:12:16.749     0:04:42.448     25,937 kbps     36,597 kbps     01:15:32.528    32,388 kbps     01:13:26.110    29,486 kbps     01:13:21.063    135,223 bytes   298,487 bytes   01:13:29.238
22              1:16:59.197     0:04:56.838     26,532 kbps     37,511 kbps     01:18:01.176    33,966 kbps     01:19:36.313    31,809 kbps     01:19:35.479    138,327 bytes   281,759 bytes   01:21:55.994
23              1:21:56.036     0:02:54.591     26,063 kbps     42,400 kbps     01:23:05.355    32,881 kbps     01:23:03.061    30,569 kbps     01:22:57.722    135,878 bytes   279,920 bytes   01:23:05.397
24              1:24:50.627     0:03:40.720     20,485 kbps     34,812 kbps     01:25:00.887    28,687 kbps     01:25:00.595    26,057 kbps     01:25:00.595    107,754 bytes   261,287 bytes   01:25:10.104
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    5311.223                24,090                  15,993,127,648  86,995,972
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5311.223                3,533                   2,345,432,412   13,573,357
00010.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5311.223                640                     424,988,160     2,490,165
00010.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            5311.223                640                     424,988,160     2,490,165
00010.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           5311.223                640                     424,988,160     2,490,165
00010.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           5311.223                192                     127,495,680     830,050
00010.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           5311.223                448                     297,545,472     1,660,410
00010.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          5311.223                17                      11,147,634      65,827
00010.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5311.223                28                      18,773,710      108,128
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5311.223                18                      11,828,935      68,961
00010.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            5311.223                30                      20,220,745      116,253
00010.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           5311.223                25                      16,856,066      97,286
00010.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             5311.223                24                      16,111,044      93,251
00010.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           5311.223                24                      16,021,378      92,696
00010.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            5311.223                21                      14,025,242      80,473
00010.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           5311.223                25                      16,314,984      93,589
00010.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         5311.223                24                      15,831,695      91,717
00010.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           5311.223                20                      13,428,139      78,050
00010.M2TS      4619 (0x120B)   0x90            PGS             jpn (Japanese)          5311.223                44                      29,063,623      164,962
1000
Stephen Dawson
hifi-writer.com
post #3880 of 5099 Old 01-25-2012, 04:31 AM
The Cup - 2011 - Australian version
Distributed by Roadshow Entertainment
Region free, confirmed with AnyDVD HD. Featurette is 1080i50.
DD256kbps is stereo version of main audio. DD192kbps is English Audio Descriptive
Code:
        Total   Video
00003.MPLS                                                      AVC     1:46:11 28,210,243,584  41,581,574,826  35.42   29.45   DTS-HD Master 5.1 3622Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     THE CUP
Disc Size:      41,581,574,826 bytes
Protection:     AACS
BD-Java:        No
Extras:         50Hz Content
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:46:11.698 (h:m:s.ms)
Total Bitrate:          35.42 Mbps
VIDEO:
MPEG-4 AVC Video        29453 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3622 kbps       5.1 / 48 kHz / 3622 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         256 kbps        2.0 / 48 kHz / 256 kbps
SUBTITLES:
Presentation Graphics           English         60.399 kbps
FILES:
00000.M2TS      0:00:00.000     1:46:11.698     28,210,243,584  35,419
CHAPTERS:
1               0:00:00.000     0:05:48.431     27,337 kbps     47,103 kbps     00:04:47.078    40,869 kbps     00:01:27.337    39,235 kbps     00:01:26.878    142,506 bytes   485,686 bytes   00:01:38.389
2               0:05:48.431     0:06:06.908     31,199 kbps     54,790 kbps     00:10:27.084    42,580 kbps     00:09:58.764    37,492 kbps     00:07:16.185    162,656 bytes   550,868 bytes   00:06:49.575
3               0:11:55.339     0:09:21.394     32,022 kbps     52,793 kbps     00:14:29.952    41,159 kbps     00:20:21.553    39,752 kbps     00:20:20.010    166,948 bytes   571,127 bytes   00:13:03.199
4               0:21:16.733     0:08:16.245     29,469 kbps     50,379 kbps     00:22:43.612    41,791 kbps     00:26:25.375    38,265 kbps     00:23:50.303    153,636 bytes   568,240 bytes   00:23:27.406
5               0:29:32.979     0:09:31.153     31,365 kbps     46,885 kbps     00:30:31.329    42,964 kbps     00:30:30.954    39,572 kbps     00:30:27.951    163,522 bytes   515,014 bytes   00:33:11.656
6               0:39:04.133     0:10:54.445     30,568 kbps     51,465 kbps     00:43:18.512    42,813 kbps     00:43:17.803    39,597 kbps     00:43:17.720    159,370 bytes   589,717 bytes   00:40:13.786
7               0:49:58.578     0:12:19.572     30,727 kbps     47,540 kbps     00:54:52.831    43,171 kbps     00:54:52.539    37,571 kbps     00:57:10.260    160,199 bytes   462,148 bytes   00:50:02.249
8               1:02:18.151     0:07:17.478     31,526 kbps     50,539 kbps     01:02:19.193    43,264 kbps     01:03:57.542    40,024 kbps     01:05:07.320    164,363 bytes   516,659 bytes   01:06:41.831
9               1:09:35.629     0:11:34.276     33,287 kbps     54,542 kbps     01:09:40.467    43,438 kbps     01:09:36.589    39,481 kbps     01:11:37.001    173,545 bytes   453,135 bytes   01:09:38.591
10              1:21:09.906     0:07:53.514     33,172 kbps     47,911 kbps     01:25:28.414    40,408 kbps     01:25:28.414    38,280 kbps     01:28:25.091    172,945 bytes   475,032 bytes   01:27:45.843
11              1:29:03.421     0:11:13.005     29,119 kbps     45,461 kbps     01:29:42.085    37,863 kbps     01:35:33.144    37,172 kbps     01:33:12.295    151,811 bytes   536,340 bytes   01:31:54.258
12              1:40:16.427     0:05:55.271     3,491 kbps      6,126 kbps      01:41:42.429    5,976 kbps      01:41:40.427    5,707 kbps      01:41:36.131    18,203 bytes    178,768 bytes   01:41:44.640
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6371.532                29,454                  23,458,124,234  127,579,175
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6371.532                3,622                   2,885,017,360   16,673,025
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6371.532                256                     203,894,784     1,194,696
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6371.532                192                     152,920,320     995,575
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6371.532                60                      48,105,840      272,405
1000
Stephen Dawson
hifi-writer.com
post #3881 of 5099 Old 01-25-2012, 10:24 AM
Mizu_Ger's Avatar
44 Inch Chest (UK)
MOMENTUM PICTURES HOME ENT
Region B locked (AnyDVD HD)
Code:
        Total   Video
00000.MPLS                                                      AVC     1:34:51 17,514,580,416  21,139,469,494  24.62   19.86   DTS-HD Master 5.1 2923Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MP885BR
Disc Size:      21,139,469,494 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:34:51.769 (h:m:s.ms)
Total Bitrate:          24.62 Mbps
VIDEO:
MPEG-4 AVC Video        19862 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2923 kbps       5.1 / 48 kHz / 2923 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         39.674 kbps
FILES:
00000.M2TS      0:00:00.000     1:34:51.769     17,514,580,416  24,617
CHAPTERS:
1               0:00:00.000     0:07:52.096     16,370 kbps     38,125 kbps     00:05:28.661    30,142 kbps     00:05:24.866    28,637 kbps     00:05:25.199    85,336 bytes    464,526 bytes   00:01:00.185
2               0:07:52.096     0:08:34.305     24,934 kbps     33,104 kbps     00:12:01.387    30,490 kbps     00:12:24.118    29,946 kbps     00:14:02.675    129,995 bytes   409,764 bytes   00:14:58.647
3               0:16:26.402     0:05:30.329     21,075 kbps     32,597 kbps     00:17:08.318    31,207 kbps     00:16:33.283    30,165 kbps     00:16:28.779    109,875 bytes   411,564 bytes   00:20:35.943
4               0:21:56.732     0:09:19.100     20,487 kbps     35,100 kbps     00:23:32.035    29,560 kbps     00:24:05.444    28,995 kbps     00:24:25.505    106,812 bytes   456,085 bytes   00:23:30.325
5               0:31:15.832     0:11:04.872     22,342 kbps     32,199 kbps     00:35:30.461    28,821 kbps     00:35:26.374    27,085 kbps     00:35:21.744    116,482 bytes   401,393 bytes   00:40:48.154
6               0:42:20.704     0:05:32.999     20,983 kbps     32,007 kbps     00:45:12.251    29,924 kbps     00:45:42.739    28,319 kbps     00:45:39.737    109,394 bytes   418,243 bytes   00:42:46.021
7               0:47:53.704     0:07:28.781     21,211 kbps     30,251 kbps     00:54:18.588    26,215 kbps     00:54:21.383    25,084 kbps     00:54:16.878    110,586 bytes   408,634 bytes   00:54:19.089
8               0:55:22.485     0:05:37.795     23,117 kbps     35,426 kbps     01:00:33.630    30,570 kbps     01:00:33.630    29,765 kbps     00:55:31.453    120,519 bytes   454,490 bytes   01:01:00.239
9               1:01:00.281     0:09:08.256     20,096 kbps     28,584 kbps     01:01:34.315    26,570 kbps     01:01:57.296    26,403 kbps     01:01:56.129    104,773 bytes   408,926 bytes   01:07:52.026
10              1:10:08.537     0:08:47.944     19,883 kbps     34,838 kbps     01:18:13.105    30,967 kbps     01:13:31.824    27,788 kbps     01:17:57.964    103,663 bytes   407,233 bytes   01:18:07.182
11              1:18:56.481     0:08:26.047     19,693 kbps     29,277 kbps     01:21:06.695    23,978 kbps     01:20:32.410    22,892 kbps     01:25:52.355    102,672 bytes   392,698 bytes   01:26:33.646
12              1:27:22.528     0:07:29.240     7,637 kbps      28,355 kbps     01:27:27.325    26,496 kbps     01:27:23.321    22,555 kbps     01:27:22.820    39,825 bytes    399,430 bytes   01:29:10.345
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5691.686                19,862                  14,131,237,477  76,881,204
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5691.686                2,923                   2,079,550,444   11,854,030
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5691.686                256                     182,040,576     1,066,644
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5691.686                256                     182,037,504     1,066,626
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5691.686                40                      28,226,851      162,597
Mizu_Ger is offline
post #3882 of 5099 Old 01-25-2012, 06:23 PM
ricabullah's Avatar
Code:
        Total   Video
00001.mpls                                                      AVC     1:39:59 29.131.259.904  33.210.541.875  38,84   27,76   Dolby TrueHD 5.1 5120Kbps (96kHz/24-bit)
Code:
DISC INFO:
Disc Title:     SEX_LIES_VIDEOTAPE
Disc Size:      33.210.541.875 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:39:59 (h:m:s)
Total Bitrate:  38,84 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00011.M2TS      29.131.259.904  1:39:59.994     0:00:00.000     1:39:59.994
VIDEO:
Codec               Bitrate         Description
MPEG-4 AVC Video    27763 kbps      1080p / 23,976fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         5120 kbps       5.1 / 96kHz / 24-bit / 5120kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              French          1288 kbps       5.1 / 48kHz / 16-bit / 1288kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         37,504 kbps
Presentation Graphics           English         31,930 kbps
Presentation Graphics           French          34,888 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:05:19.903     27.704 kbps     59.012 kbps     00:00:10.010    34.798 kbps     00:04:34.733    32.651 kbps     00:00:47.548    144.438 bytes   751.575 bytes   00:00:10.052
2               0:05:19.903     0:05:35.752     28.201 kbps     36.596 kbps     00:10:42.892    32.896 kbps     00:10:38.805    32.078 kbps     00:10:39.347    147.028 bytes   466.472 bytes   00:10:50.233
3               0:10:55.655     0:03:51.898     28.084 kbps     34.593 kbps     00:14:38.294    30.554 kbps     00:14:38.294    29.355 kbps     00:14:36.626    146.418 bytes   461.610 bytes   00:14:38.503
4               0:14:47.553     0:05:43.594     27.891 kbps     33.829 kbps     00:18:15.720    30.555 kbps     00:19:09.148    30.391 kbps     00:19:04.143    145.410 bytes   419.500 bytes   00:18:48.627
5               0:20:31.147     0:02:10.296     27.439 kbps     43.491 kbps     00:22:14.083    30.828 kbps     00:22:13.415    29.525 kbps     00:22:13.415    143.053 bytes   449.009 bytes   00:22:14.250
6               0:22:41.443     0:07:34.830     28.049 kbps     33.927 kbps     00:27:03.205    30.378 kbps     00:27:02.871    30.021 kbps     00:27:02.871    146.234 bytes   484.729 bytes   00:23:04.258
7               0:30:16.273     0:03:39.719     27.349 kbps     31.492 kbps     00:31:55.080    29.593 kbps     00:30:16.773    29.141 kbps     00:30:16.815    142.585 bytes   414.254 bytes   00:30:53.852
8               0:33:55.992     0:06:15.917     28.685 kbps     35.629 kbps     00:34:52.841    31.993 kbps     00:34:06.002    31.668 kbps     00:33:56.785    149.551 bytes   466.510 bytes   00:34:36.783
9               0:40:11.909     0:09:38.829     27.661 kbps     35.445 kbps     00:40:15.038    30.261 kbps     00:40:11.909    29.600 kbps     00:49:12.324    144.211 bytes   424.333 bytes   00:47:20.796
10              0:49:50.738     0:07:02.964     28.005 kbps     37.573 kbps     00:49:53.032    33.407 kbps     00:50:03.000    32.555 kbps     00:50:03.000    146.004 bytes   454.913 bytes   00:49:53.282
11              0:56:53.702     0:09:37.076     27.622 kbps     39.304 kbps     00:57:42.834    34.968 kbps     00:57:38.997    33.286 kbps     00:57:38.997    144.007 bytes   491.918 bytes   00:57:42.876
12              1:06:30.778     0:02:32.278     29.598 kbps     39.441 kbps     01:07:45.436    33.904 kbps     01:06:31.029    32.792 kbps     01:06:30.778    154.308 bytes   492.983 bytes   01:08:57.508
13              1:09:03.056     0:07:55.266     27.789 kbps     35.399 kbps     01:12:46.821    31.355 kbps     01:09:11.939    30.723 kbps     01:09:11.147    144.877 bytes   494.385 bytes   01:12:46.862
14              1:16:58.322     0:16:58.142     28.035 kbps     47.193 kbps     01:31:33.530    34.128 kbps     01:31:31.361    32.199 kbps     01:17:17.466    146.159 bytes   562.527 bytes   01:17:47.621
15              1:33:56.464     0:03:32.838     30.279 kbps     35.588 kbps     01:36:18.064    32.664 kbps     01:35:15.835    32.060 kbps     01:35:48.409    157.863 bytes   452.938 bytes   01:37:00.898
16              1:37:29.302     0:02:30.692     16.776 kbps     38.734 kbps     01:39:39.765    35.296 kbps     01:39:38.848    32.732 kbps     01:39:36.554    87.465 bytes    472.974 bytes   01:39:40.600
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Lang. Code      Lang. Name      Seconds         Bytes           Packets         Bitrate
00011.M2TS      4113 (0x1011)   0x1B            AVC                                             5999,99         20.822.143.078  113.248.193     27.763
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng             English         5999,99         4.319.841.276   26.610.289      5.760
00011.M2TS      4353 (0x1101)   0x83            TrueHD          fra             French          5999,99         1.446.209.512   10.277.643      1.928
00011.M2TS      4354 (0x1102)   0x81            AC3             eng             English         5999,99         144.000.000     937.500         192
00011.M2TS      4608 (0x1200)   0x90            PGS             eng             English         5999,99         28.128.222      160.908         38
00011.M2TS      4609 (0x1201)   0x90            PGS             eng             English         5999,99         23.947.834      139.429         32
00011.M2TS      4610 (0x1202)   0x90            PGS             fra             French          5999,99         26.165.896      150.318         35
_ _ _ _
Chronical Tester
post #3883 of 5099 Old 01-27-2012, 12:25 PM
Mizu_Ger's Avatar
Drive (UK)
Icon Home Entertainment
Code:
        Total   Video
00000.MPLS                                                      AVC     1:40:31 25,252,442,688  35,585,268,150  33.49   27.10   DTS-HD Master 5.1 2405Kbps (48kHz/24-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     DRIVE
Disc Size:      35,585,268,150 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:40:31.692 (h:m:s.ms)
Total Bitrate:          33.49 Mbps
VIDEO:
MPEG-4 AVC Video        27100 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2405 kbps       5.1 / 48 kHz / 2405 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         23.444 kbps
FILES:
00000.M2TS      0:00:00.000     1:40:31.692     25,252,442,688  33,493
CHAPTERS:
1               0:00:00.000     0:10:22.580     26,227 kbps     63,319 kbps     00:01:30.507    38,747 kbps     00:02:27.230    34,623 kbps     00:02:25.061    136,729 bytes   634,146 bytes   00:01:31.341
2               0:10:22.580     0:06:36.395     27,748 kbps     50,430 kbps     00:11:47.373    37,816 kbps     00:11:45.121    34,117 kbps     00:11:44.453    144,666 bytes   819,451 bytes   00:10:23.080
3               0:16:58.976     0:09:00.665     29,245 kbps     36,429 kbps     00:22:38.106    32,678 kbps     00:20:57.214    32,208 kbps     00:20:40.447    152,468 bytes   463,209 bytes   00:24:44.357
4               0:25:59.641     0:07:13.641     29,204 kbps     43,328 kbps     00:30:54.269    34,822 kbps     00:30:32.247    33,489 kbps     00:30:27.242    152,257 bytes   664,045 bytes   00:30:54.310
5               0:33:13.282     0:09:44.500     28,923 kbps     42,114 kbps     00:39:48.928    32,940 kbps     00:40:45.109    32,145 kbps     00:42:42.726    150,792 bytes   643,523 bytes   00:39:49.053
6               0:42:57.783     0:08:25.213     29,196 kbps     34,768 kbps     00:45:39.653    33,039 kbps     00:45:45.534    31,995 kbps     00:49:36.974    152,216 bytes   413,871 bytes   00:50:56.762
7               0:51:22.996     0:11:18.761     29,115 kbps     54,755 kbps     00:58:04.063    33,473 kbps     00:55:35.457    32,177 kbps     00:53:54.147    151,791 bytes   702,869 bytes   00:58:04.105
8               1:02:41.758     0:10:54.737     29,141 kbps     47,312 kbps     01:02:59.609    36,021 kbps     01:02:58.691    34,310 kbps     01:07:53.652    151,930 bytes   499,486 bytes   01:02:59.692
9               1:13:36.495     0:08:05.651     29,004 kbps     43,782 kbps     01:19:08.785    33,692 kbps     01:14:31.300    32,879 kbps     01:16:21.034    151,214 bytes   655,678 bytes   01:19:08.910
10              1:21:42.147     0:06:22.673     28,479 kbps     44,456 kbps     01:25:07.894    37,580 kbps     01:26:33.479    34,784 kbps     01:26:33.479    148,477 bytes   539,083 bytes   01:24:26.311
11              1:28:04.821     0:05:18.067     27,772 kbps     59,436 kbps     01:30:04.107    39,498 kbps     01:30:01.813    36,334 kbps     01:29:56.265    144,793 bytes   862,983 bytes   01:33:22.847
12              1:33:22.888     0:07:08.803     7,785 kbps      57,121 kbps     01:35:37.022    36,704 kbps     01:34:45.763    32,070 kbps     01:34:44.887    40,595 bytes    501,003 bytes   01:34:47.890
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6031.609                27,100                  20,432,163,047  111,129,665
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6031.609                2,405                   1,813,321,188   10,439,025
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6031.609                2,310                   1,741,953,516   9,650,712
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6031.609                23                      17,675,850      101,668
Mizu_Ger is offline
post #3884 of 5099 Old 01-27-2012, 12:27 PM
Mizu_Ger's Avatar
Killer Elite (UK)
Entertainment in Video
Code:
        Total   Video
00000.MPLS                                                      AVC     2:06:12 20,017,090,560  22,335,414,638  21.15   18.00   DTS-HD Master 5.1 1938Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     KILLER ELITE
Disc Size:      22,335,414,638 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:06:12.606 (h:m:s.ms)
Total Bitrate:          21.15 Mbps
VIDEO:
MPEG-4 AVC Video        18000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1938 kbps       5.1 / 48 kHz / 1938 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         30.106 kbps
FILES:
00000.M2TS      0:00:00.000     2:06:12.606     20,017,090,560  21,147
CHAPTERS:
1               0:00:00.000     0:09:01.749     17,454 kbps     32,889 kbps     00:03:16.196    29,558 kbps     00:03:22.368    26,900 kbps     00:03:20.783    90,990 bytes    422,978 bytes   00:03:23.411
2               0:09:01.749     0:11:31.065     20,807 kbps     31,943 kbps     00:15:08.782    29,236 kbps     00:10:26.626    25,777 kbps     00:10:21.787    108,480 bytes   524,681 bytes   00:15:09.366
3               0:20:32.814     0:09:11.092     19,309 kbps     30,787 kbps     00:25:35.492    28,098 kbps     00:23:34.955    27,479 kbps     00:23:31.576    100,667 bytes   564,087 bytes   00:27:17.010
4               0:29:43.907     0:09:43.583     19,468 kbps     32,587 kbps     00:37:10.394    27,890 kbps     00:34:36.240    27,390 kbps     00:34:34.572    101,497 bytes   502,686 bytes   00:39:04.300
5               0:39:27.490     0:07:37.456     20,201 kbps     36,486 kbps     00:43:14.883    29,513 kbps     00:43:45.789    28,512 kbps     00:43:41.785    105,319 bytes   502,202 bytes   00:41:52.551
6               0:47:04.947     0:09:26.857     20,680 kbps     35,070 kbps     00:55:25.905    28,018 kbps     00:47:47.197    26,623 kbps     00:47:42.276    107,814 bytes   551,330 bytes   00:55:31.202
7               0:56:31.805     0:12:19.613     20,228 kbps     32,797 kbps     01:00:48.478    29,125 kbps     01:00:48.227    27,781 kbps     01:00:47.060    105,457 bytes   557,242 bytes   01:02:47.930
8               1:08:51.418     0:05:16.524     23,463 kbps     32,085 kbps     01:11:53.851    29,274 kbps     01:12:00.065    28,372 kbps     01:11:44.842    122,325 bytes   619,960 bytes   01:11:54.852
9               1:14:07.943     0:09:25.731     20,444 kbps     31,730 kbps     01:17:08.832    28,970 kbps     01:18:33.625    27,795 kbps     01:18:33.417    106,587 bytes   508,700 bytes   01:17:09.833
10              1:23:33.675     0:09:04.168     19,966 kbps     37,393 kbps     01:31:47.793    34,315 kbps     01:31:47.084    30,605 kbps     01:31:43.497    104,094 bytes   500,853 bytes   01:31:38.201
11              1:32:37.843     0:08:01.898     20,751 kbps     29,547 kbps     01:38:23.564    25,604 kbps     01:38:12.219    24,562 kbps     01:34:54.271    108,184 bytes   450,270 bytes   01:39:27.294
12              1:40:39.742     0:25:32.864     9,582 kbps      29,077 kbps     01:58:47.245    28,132 kbps     01:58:43.616    27,382 kbps     01:58:40.571    49,958 bytes    530,705 bytes   01:57:23.661
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7572.440                18,000                  17,038,293,139  92,704,499
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7572.440                1,939                   1,834,907,076   11,134,351
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7572.440                30                      28,497,361      163,109
Mizu_Ger is offline
post #3885 of 5099 Old 01-27-2012, 12:29 PM
Mizu_Ger's Avatar
The Tourist (UK)
Optimum Home Entertainment
Region B Locked (AnyDVD HD)
Code:
        Total   Video
00000.MPLS                                                      AVC     1:43:09 30,209,169,408  41,378,132,594  39.05   30.60   DTS-HD Master 5.1 1916Kbps (48kHz/16-bit) DTS 2.0 768Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     THE_TOURIST
Disc Size:      41,378,132,594 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:43:09.041 (h:m:s.ms)
Total Bitrate:          39.05 Mbps
VIDEO:
MPEG-4 AVC Video        30598 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         1916 kbps       5.1 / 48 kHz / 1916 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          1656 kbps       5.1 / 48 kHz / 1656 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
DTS-HD Master Audio             German          1663 kbps       5.1 / 48 kHz / 1663 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 16-bit)
DTS Audio                       English         768 kbps        2.0 / 48 kHz / 768 kbps / 16-bit
SUBTITLES:
Presentation Graphics           French          20.547 kbps
Presentation Graphics           English         25.324 kbps
Presentation Graphics           German          23.147 kbps
Presentation Graphics           French          0.525 kbps
Presentation Graphics           English         1.576 kbps
Presentation Graphics           German          1.415 kbps
Presentation Graphics           French          50.850 kbps
Presentation Graphics           German          44.839 kbps
FILES:
00000.M2TS      0:00:00.000     1:43:09.041     30,209,169,408  39,049
CHAPTERS:
1               0:00:00.000     0:08:03.208     31,044 kbps     47,158 kbps     00:04:32.500    40,422 kbps     00:04:31.541    39,771 kbps     00:06:26.416    161,671 bytes   400,219 bytes   00:06:29.541
2               0:08:03.208     0:03:48.916     29,119 kbps     42,043 kbps     00:11:36.458    38,021 kbps     00:11:32.500    36,334 kbps     00:11:32.375    151,660 bytes   345,380 bytes   00:11:39.458
3               0:11:52.125     0:09:06.958     32,918 kbps     48,968 kbps     00:14:05.666    40,696 kbps     00:14:05.583    38,457 kbps     00:17:51.875    171,448 bytes   360,766 bytes   00:15:52.583
4               0:20:59.083     0:05:45.291     33,854 kbps     44,326 kbps     00:21:18.875    39,835 kbps     00:22:03.083    39,595 kbps     00:22:01.250    176,321 bytes   398,184 bytes   00:22:08.000
5               0:26:44.375     0:03:38.750     32,859 kbps     41,365 kbps     00:27:55.583    36,550 kbps     00:27:51.875    35,761 kbps     00:27:46.791    171,143 bytes   308,875 bytes   00:28:49.416
6               0:30:23.125     0:03:45.666     30,811 kbps     36,631 kbps     00:31:55.000    35,203 kbps     00:31:37.833    34,434 kbps     00:31:32.750    160,472 bytes   299,826 bytes   00:34:08.666
7               0:34:08.791     0:05:37.083     30,357 kbps     46,494 kbps     00:36:17.500    36,528 kbps     00:36:14.333    34,682 kbps     00:35:56.083    158,110 bytes   319,065 bytes   00:37:22.166
8               0:39:45.875     0:10:06.208     31,475 kbps     44,650 kbps     00:45:15.375    39,841 kbps     00:45:12.208    38,065 kbps     00:45:07.166    163,934 bytes   371,724 bytes   00:43:59.541
9               0:49:52.083     0:07:43.625     33,215 kbps     43,756 kbps     00:51:37.000    40,046 kbps     00:52:42.583    38,482 kbps     00:52:42.666    172,996 bytes   373,514 bytes   00:52:45.208
10              0:57:35.708     0:05:37.458     31,759 kbps     38,655 kbps     01:02:50.166    36,413 kbps     01:02:38.000    36,156 kbps     01:02:39.166    165,409 bytes   448,106 bytes   01:02:51.208
11              1:03:13.166     0:03:23.208     31,808 kbps     42,197 kbps     01:06:28.625    38,133 kbps     01:06:26.791    36,809 kbps     01:06:25.083    165,665 bytes   322,523 bytes   01:03:40.916
12              1:06:36.375     0:07:20.916     32,533 kbps     44,588 kbps     01:10:50.708    39,607 kbps     01:10:50.833    39,215 kbps     01:10:48.541    169,443 bytes   336,359 bytes   01:10:55.666
13              1:13:57.291     0:02:54.125     33,603 kbps     41,547 kbps     01:13:59.458    38,037 kbps     01:13:59.458    36,193 kbps     01:16:41.375    175,016 bytes   342,604 bytes   01:16:49.416
14              1:16:51.416     0:08:30.875     32,475 kbps     44,808 kbps     01:24:44.666    40,415 kbps     01:24:42.750    39,594 kbps     01:24:42.500    169,142 bytes   395,392 bytes   01:18:33.458
15              1:25:22.291     0:09:08.291     36,022 kbps     39,489 kbps     01:31:53.208    37,820 kbps     01:29:57.500    37,085 kbps     01:29:58.583    187,616 bytes   357,414 bytes   01:34:01.375
16              1:34:30.583     0:08:38.458     10,495 kbps     38,888 kbps     01:34:46.083    37,557 kbps     01:36:18.291    37,235 kbps     01:36:18.291    54,666 bytes    303,289 bytes   01:34:46.125
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6188.875                30,599                  23,671,671,377  128,737,193
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6188.875                1,916                   1,482,591,588   9,014,546
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       fra (French)            6188.875                1,656                   1,281,172,668   7,561,602
00000.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            6188.875                1,663                   1,286,735,824   7,591,580
00000.M2TS      4355 (0x1103)   0x82            DTS             eng (English)           6188.875                768                     594,148,352     3,481,338
00000.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6188.875                21                      15,895,661      91,800
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6188.875                25                      19,591,486      112,217
00000.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            6188.875                23                      17,907,214      102,184
00000.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            6188.875                1                       405,924         2,396
00000.M2TS      4612 (0x1204)   0x90            PGS             eng (English)           6188.875                2                       1,218,951       7,064
00000.M2TS      4613 (0x1205)   0x90            PGS             deu (German)            6188.875                1                       1,094,304       6,370
00000.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            6188.875                51                      39,339,284      223,496
00000.M2TS      4615 (0x1207)   0x90            PGS             deu (German)            6188.875                45                      34,688,636      200,275
Mizu_Ger is offline
post #3886 of 5099 Old 01-27-2012, 04:20 PM - Thread Starter
[US] 50/50 (Additional Details)
Region Locked (A) (Confirmed w/ TMT 5 set to all three regions)
Studio: Summit Entertainment
UPC: 0025192108518
Release Date: 2012-01-24
Aspect Ratio: 1.78:1
English DD 2.0 is a commentary (w/ English and Spanish commentary subs).
Code:
        Total   Video
[US] 50/50                                                      AVC     1:40:02 23,422,273,536  28,546,600,246  31.21   24.75   DTS-HD Master 5.1 3675Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     50_50
Disc Size:      28,546,600,246 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:40:02.997 (h:m:s.ms)
Total Bitrate:          31.21 Mbps
VIDEO:
MPEG-4 AVC Video        24748 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3675 kbps       5.1 / 48 kHz / 3675 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         48.050 kbps
Presentation Graphics           Spanish         35.402 kbps
Presentation Graphics           English         106.259 kbps
Presentation Graphics           Spanish         70.115 kbps
FILES:
00001.M2TS      0:00:00.000     1:40:02.997     23,422,273,536  31,214
CHAPTERS:
1               0:00:00.000     0:05:34.625     24,153 kbps     43,341 kbps     00:00:20.437    29,347 kbps     00:02:02.580    28,022 kbps     00:00:38.705    125,909 bytes   643,054 bytes   00:01:16.910
2               0:05:34.625     0:04:37.277     25,207 kbps     36,365 kbps     00:07:44.505    28,779 kbps     00:05:47.430    28,469 kbps     00:05:47.430    131,419 bytes   510,854 bytes   00:06:06.866
3               0:10:11.902     0:06:57.166     25,315 kbps     37,962 kbps     00:10:44.685    32,316 kbps     00:16:44.670    32,146 kbps     00:16:44.753    131,982 bytes   660,270 bytes   00:10:42.642
4               0:17:09.069     0:06:11.454     25,357 kbps     33,122 kbps     00:20:46.578    27,729 kbps     00:21:26.284    26,788 kbps     00:22:47.908    132,198 bytes   587,368 bytes   00:17:37.848
5               0:23:20.524     0:07:55.516     25,430 kbps     38,431 kbps     00:27:19.220    33,663 kbps     00:27:19.137    30,977 kbps     00:27:16.718    132,578 bytes   612,090 bytes   00:28:46.891
6               0:31:16.040     0:06:56.624     25,506 kbps     33,111 kbps     00:32:50.677    29,342 kbps     00:32:40.333    28,421 kbps     00:32:18.102    132,978 bytes   603,294 bytes   00:36:32.064
7               0:38:12.665     0:05:37.962     25,526 kbps     36,880 kbps     00:43:16.468    29,426 kbps     00:38:45.156    28,444 kbps     00:38:42.445    133,078 bytes   479,722 bytes   00:38:52.204
8               0:43:50.627     0:07:05.133     25,579 kbps     37,720 kbps     00:46:16.982    29,735 kbps     00:46:07.931    28,804 kbps     00:46:07.890    133,356 bytes   562,390 bytes   00:44:12.691
9               0:50:55.761     0:05:43.259     25,131 kbps     35,523 kbps     00:54:04.115    28,443 kbps     00:51:16.823    27,333 kbps     00:54:45.240    131,021 bytes   608,402 bytes   00:54:58.295
10              0:56:39.020     0:06:21.422     25,434 kbps     36,130 kbps     01:00:41.095    28,797 kbps     01:01:01.824    27,565 kbps     01:00:30.001    132,600 bytes   699,137 bytes   01:01:18.633
11              1:03:00.443     0:02:22.267     25,173 kbps     30,730 kbps     01:04:26.279    26,711 kbps     01:04:54.098    26,246 kbps     01:05:05.568    131,239 bytes   518,096 bytes   01:03:32.058
12              1:05:22.710     0:05:21.529     25,157 kbps     31,737 kbps     01:09:49.935    28,109 kbps     01:06:10.341    27,359 kbps     01:06:07.797    131,156 bytes   624,256 bytes   01:06:32.571
13              1:10:44.240     0:03:54.609     24,994 kbps     32,427 kbps     01:11:00.798    26,689 kbps     01:13:31.698    26,081 kbps     01:13:25.901    130,309 bytes   431,000 bytes   01:11:00.839
14              1:14:38.849     0:05:56.522     23,938 kbps     34,153 kbps     01:17:10.083    26,271 kbps     01:19:58.835    25,863 kbps     01:19:53.789    124,803 bytes   455,780 bytes   01:17:20.761
15              1:20:35.372     0:04:00.990     25,020 kbps     34,489 kbps     01:22:25.357    27,562 kbps     01:20:35.372    26,599 kbps     01:23:29.212    130,444 bytes   539,881 bytes   01:23:29.587
16              1:24:36.362     0:03:50.939     26,336 kbps     32,673 kbps     01:26:44.449    29,417 kbps     01:26:42.113    28,427 kbps     01:26:37.108    137,306 bytes   469,199 bytes   01:24:39.699
17              1:28:27.302     0:04:21.719     25,002 kbps     31,851 kbps     01:31:47.877    27,799 kbps     01:31:01.873    27,154 kbps     01:31:02.540    130,351 bytes   503,602 bytes   01:31:19.182
18              1:32:49.021     0:07:13.975     18,983 kbps     33,791 kbps     01:33:52.043    31,992 kbps     01:33:50.249    28,975 kbps     01:33:45.244    98,988 bytes    474,977 bytes   01:38:50.966
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6002.914                24,748                  18,570,048,552  101,008,603
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6002.914                3,675                   2,757,314,004   15,920,248
00001.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           6002.914                640                     480,240,640     2,813,910
00001.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6002.914                192                     144,072,192     937,970
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6002.914                48                      36,055,390      206,464
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6002.914                35                      26,564,668      153,439
00001.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6002.914                106                     79,734,385      449,272
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6002.914                70                      52,612,473      299,974
post #3887 of 5099 Old 01-27-2012, 04:24 PM - Thread Starter
[US] Good Morning, Vietnam (Additional Details)
Region Locked (AB) (Confirmed w/ TMT 5 set to all three regions)
Studio: Disney / Touchstone
UPC: 0786936820973
Release Date: 2012-01-17
I couldn't get this to work in TMT 5 when set to region C (didn't go past Java loading), so this is presumably locked to AB.
Code:
        Total   Video
[US] Good Morning, Vietnam                                      AVC     2:01:00 26,630,713,344  29,656,366,920  29.34   23.04   DTS-HD Master 5.1 3952Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     GOOD MORNING VIETNAM
Disc Size:      29,656,366,920 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:01:00.878 (h:m:s.ms)
Total Bitrate:          29.34 Mbps
VIDEO:
MPEG-4 AVC Video        23041 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3952 kbps       5.1 / 48 kHz / 3952 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         95.616 kbps
Presentation Graphics           French          32.794 kbps
Presentation Graphics           French          0.444 kbps
FILES:
00000.M2TS      0:00:00.000     2:01:00.878     26,630,713,344  29,342
CHAPTERS:
1               0:00:00.000     0:08:56.410     22,961 kbps     44,306 kbps     00:00:23.523    38,802 kbps     00:03:42.221    34,304 kbps     00:03:12.483    119,697 bytes   439,409 bytes   00:04:51.708
2               0:08:56.410     0:14:25.406     25,210 kbps     49,106 kbps     00:16:48.966    37,924 kbps     00:15:36.894    35,750 kbps     00:15:36.894    131,434 bytes   486,589 bytes   00:15:39.939
3               0:23:21.817     0:09:29.902     25,421 kbps     44,345 kbps     00:25:57.681    39,691 kbps     00:25:56.680    36,971 kbps     00:31:55.038    132,536 bytes   423,095 bytes   00:25:55.804
4               0:32:51.719     0:07:11.681     25,457 kbps     44,510 kbps     00:36:00.783    37,720 kbps     00:35:57.905    34,636 kbps     00:37:38.839    132,722 bytes   379,822 bytes   00:35:59.949
5               0:40:03.401     0:12:18.028     24,239 kbps     45,106 kbps     00:45:21.176    37,993 kbps     00:41:14.346    36,250 kbps     00:41:06.881    126,373 bytes   412,703 bytes   00:49:14.826
6               0:52:21.429     0:14:38.878     26,453 kbps     43,530 kbps     01:03:46.239    39,497 kbps     00:52:21.429    37,431 kbps     00:52:21.429    137,913 bytes   455,048 bytes   00:59:32.068
7               1:07:00.307     0:11:19.720     23,271 kbps     57,317 kbps     01:15:19.723    39,622 kbps     01:11:32.913    37,092 kbps     01:11:32.913    121,323 bytes   473,271 bytes   01:11:56.186
8               1:18:20.028     0:12:17.903     22,077 kbps     42,950 kbps     01:20:52.472    39,150 kbps     01:20:48.468    36,088 kbps     01:20:43.797    115,100 bytes   442,553 bytes   01:27:41.381
9               1:30:37.932     0:18:05.083     19,924 kbps     46,347 kbps     01:31:47.752    40,614 kbps     01:38:32.364    36,175 kbps     01:36:19.148    103,875 bytes   544,204 bytes   01:33:06.414
10              1:48:43.016     0:12:17.862     17,375 kbps     41,591 kbps     01:51:43.905    33,336 kbps     01:54:21.813    31,237 kbps     01:54:21.813    90,593 bytes    585,562 bytes   02:00:43.903
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     7260.712                23,041                  20,912,134,196  113,755,013
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7260.712                3,952                   3,587,066,312   20,631,068
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7260.712                642                     582,254,080     3,411,645
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7260.712                96                      86,782,146      485,783
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7260.712                33                      29,764,329      171,291
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7260.712                0                       402,646         2,304
post #3888 of 5099 Old 01-27-2012, 04:33 PM - Thread Starter
[US] Stripes (Additional Details)
Region Free (ABC) (Confirmed w/ TMT 5 set to all three regions)
Studio: Sony
UPC: 0043396296305
Extended version is the only option available. English DD 2.0 is a commentary (w/ German, Portuguese and Spanish commentary subs). I believe the hidden English and Spanish subs are British English SDH and Castilian Spanish respectively, and activated when set to region B.
Code:
        Total   Video
[US] Stripes                                                    AVC     2:02:58 38,786,623,488  44,111,477,044  42.05   29.00   DTS-HD Master 5.1 2346Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     STRIPES
Disc Size:      44,111,477,044 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:02:58.371 (h:m:s.ms)
Total Bitrate:          42.05 Mbps
VIDEO:
MPEG-4 AVC Video        28996 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2346 kbps       5.1 / 48 kHz / 2346 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          2340 kbps       5.1 / 48 kHz / 2340 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             German          2384 kbps       5.1 / 48 kHz / 2384 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             Spanish         2342 kbps       5.1 / 48 kHz / 2342 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             Portuguese      192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         31.455 kbps
* Presentation Graphics         English         31.464 kbps
Presentation Graphics           English         25.830 kbps
Presentation Graphics           French          29.193 kbps
Presentation Graphics           German          35.155 kbps
Presentation Graphics           Portuguese      30.431 kbps
Presentation Graphics           Spanish         30.592 kbps
* Presentation Graphics         Spanish         31.810 kbps
Presentation Graphics           Turkish         29.514 kbps
Presentation Graphics           German          56.833 kbps
Presentation Graphics           Spanish         49.883 kbps
Presentation Graphics           Portuguese      51.872 kbps
FILES:
00450.M2TS      0:00:00.000     2:02:58.371     38,786,623,488  42,054
CHAPTERS:
1               0:00:00.000     0:11:13.798     28,725 kbps     31,970 kbps     00:00:19.811    30,245 kbps     00:00:15.807    30,022 kbps     00:00:10.552    149,752 bytes   295,274 bytes   00:04:35.400
2               0:11:13.798     0:10:36.218     29,577 kbps     31,026 kbps     00:21:49.016    30,051 kbps     00:15:33.891    29,927 kbps     00:13:07.745    154,199 bytes   320,901 bytes   00:21:50.017
3               0:21:50.017     0:09:08.881     29,651 kbps     30,906 kbps     00:24:44.649    30,021 kbps     00:24:40.729    29,913 kbps     00:22:41.985    154,589 bytes   316,256 bytes   00:21:52.019
4               0:30:58.898     0:07:27.738     29,535 kbps     30,818 kbps     00:38:06.659    29,978 kbps     00:38:02.446    29,898 kbps     00:36:38.946    153,981 bytes   280,610 bytes   00:38:26.637
5               0:38:26.637     0:03:48.645     28,019 kbps     31,793 kbps     00:38:43.988    30,211 kbps     00:38:41.444    30,043 kbps     00:38:36.439    146,077 bytes   446,217 bytes   00:38:44.905
6               0:42:15.282     0:08:01.689     29,274 kbps     32,447 kbps     00:46:44.468    30,423 kbps     00:46:40.464    29,980 kbps     00:46:09.975    152,619 bytes   340,028 bytes   00:46:20.778
7               0:50:16.972     0:09:37.702     28,156 kbps     30,645 kbps     00:53:09.811    29,970 kbps     00:53:09.728    29,904 kbps     00:53:09.728    146,795 bytes   244,416 bytes   00:59:54.549
8               0:59:54.674     0:12:03.681     29,120 kbps     32,068 kbps     01:03:02.904    30,248 kbps     01:02:58.983    30,040 kbps     01:02:53.978    151,820 bytes   427,868 bytes   01:02:02.093
9               1:11:58.355     0:09:10.424     29,028 kbps     30,681 kbps     01:19:45.155    29,983 kbps     01:18:02.427    29,905 kbps     01:17:57.297    151,339 bytes   267,037 bytes   01:13:22.523
10              1:21:08.780     0:05:50.641     29,657 kbps     31,184 kbps     01:25:53.148    30,067 kbps     01:26:06.828    29,948 kbps     01:24:42.869    154,618 bytes   302,213 bytes   01:26:03.283
11              1:26:59.422     0:04:53.751     28,858 kbps     31,149 kbps     01:29:01.294    30,090 kbps     01:29:04.213    29,944 kbps     01:28:52.285    150,454 bytes   344,911 bytes   01:29:04.255
12              1:31:53.174     0:05:18.067     28,570 kbps     30,963 kbps     01:35:39.817    30,197 kbps     01:37:04.318    29,954 kbps     01:36:59.355    148,953 bytes   387,701 bytes   01:34:51.936
13              1:37:11.242     0:07:47.925     28,161 kbps     31,338 kbps     01:39:57.908    30,026 kbps     01:44:31.848    29,921 kbps     01:43:43.592    146,818 bytes   390,813 bytes   01:40:00.869
14              1:44:59.167     0:06:41.901     29,495 kbps     31,543 kbps     01:45:08.051    30,175 kbps     01:45:02.129    29,935 kbps     01:45:19.938    153,775 bytes   389,556 bytes   01:45:07.134
15              1:51:41.069     0:04:56.504     29,295 kbps     32,812 kbps     01:56:25.770    30,267 kbps     01:56:21.766    30,021 kbps     01:56:16.761    152,730 bytes   330,987 bytes   01:55:29.047
16              1:56:37.573     0:06:20.797     28,276 kbps     33,513 kbps     02:02:50.154    30,686 kbps     02:02:46.400    30,260 kbps     02:02:41.395    147,436 bytes   342,973 bytes   02:02:18.456
STREAM DIAGNOSTICS:
00450.M2TS      4113 (0x1011)   0x1B            AVC                                     7378.246                28,997                  26,743,071,856  145,445,920
00450.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7378.246                2,346                   2,163,499,316   12,874,785
00450.M2TS      4353 (0x1101)   0x86            DTS-HD MA       fra (French)            7378.246                2,340                   2,158,363,108   12,852,020
00450.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            7378.246                2,384                   2,198,430,392   13,147,166
00450.M2TS      4355 (0x1103)   0x86            DTS-HD MA       spa (Spanish)           7378.246                2,342                   2,159,690,128   12,846,040
00450.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        7378.246                192                     177,081,600     1,152,875
00450.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7378.246                192                     177,081,600     1,152,875
00450.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7378.246                31                      29,010,911      166,584
00450.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7378.246                31                      29,019,362      166,630
00450.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           7378.246                26                      23,822,594      140,629
00450.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            7378.246                29                      26,924,656      154,934
00450.M2TS      4612 (0x1204)   0x90            PGS             deu (German)            7378.246                35                      32,423,773      185,263
00450.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        7378.246                30                      28,066,126      161,603
00450.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           7378.246                31                      28,214,436      162,212
00450.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           7378.246                32                      29,337,861      168,471
00450.M2TS      4616 (0x1208)   0x90            PGS             tur (Turkish)           7378.246                30                      27,220,479      156,970
00450.M2TS      4617 (0x1209)   0x90            PGS             deu (German)            7378.246                57                      52,416,841      297,431
00450.M2TS      4618 (0x120A)   0x90            PGS             spa (Spanish)           7378.246                50                      46,006,673      261,897
00450.M2TS      4619 (0x120B)   0x90            PGS             por (Portuguese)        7378.246                52                      47,841,344      272,155
Cinema Squid is offline
post #3889 of 5099 Old 01-27-2012, 04:47 PM - Thread Starter
Cinema Squid's Avatar
[US] First Squad (Additional Details)
Studio: Anchor Bay
UPC: 0013132179490
Two separately encoded cuts are provided: a "long version" interspersed with live action fictional documentary-style interviews and a "short version" without these interviews.
For the long version's English dub, the interview portions are kept in Russian audio while the anime portions are in English. Unfortunately, there is not a separate, smaller subtitle track to translate just the interview parts.
Code:
        Total   Video
First Squad: Long Version                                       AVC     1:12:53 21,687,318,528  38,616,004,394  39.67   27.11   Dolby TrueHD 5.1 3509Kbps (48kHz/24-bit)
             Short Version                                      AVC     1:00:28 16,025,634,816  38,616,004,394  35.33   16.84   Dolby TrueHD 5.1 3692Kbps (48kHz/24-bit)
Long Version
Code:
DISC INFO:
Disc Title:     First Squad
Disc Size:      38,616,004,394 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:12:53.327 (h:m:s.ms)
Total Bitrate:          39.67 Mbps
VIDEO:
MPEG-4 AVC Video        27105 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3509 kbps       5.1 / 48 kHz / 3509 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby TrueHD Audio              Russian         3581 kbps       5.1 / 48 kHz / 3581 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby Digital Audio             Russian         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         32.982 kbps
FILES:
00004.M2TS      0:00:00.000     1:12:53.327     21,687,318,528  39,672
CHAPTERS:
1               0:00:00.000     1:12:53.327     27,105 kbps     63,360 kbps     00:39:30.326    40,487 kbps     00:57:31.197    37,137 kbps     00:24:42.564    141,315 bytes   981,052 bytes   00:18:02.039
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     4373.202                27,106                  14,817,606,198  80,591,773
00004.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           4373.202                3,957                   2,162,973,059   15,282,756
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4373.202                192                     104,960,256     683,335
00004.M2TS      4354 (0x1102)   0x83            TrueHD          rus (Russian)           4373.202                4,029                   2,202,409,431   15,417,435
00004.M2TS      4355 (0x1103)   0x81            AC3             rus (Russian)           4373.202                192                     104,960,256     683,335
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4373.202                33                      18,030,356      101,802
Short Version
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:00:28.583 (h:m:s.ms)
Total Bitrate:          35.33 Mbps
VIDEO:
MPEG-4 AVC Video        16844 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3692 kbps       5.1 / 48 kHz / 3692 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby TrueHD Audio              Russian         3775 kbps       5.1 / 48 kHz / 3775 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby TrueHD Audio              Japanese        3731 kbps       5.1 / 48 kHz / 3731 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby Digital Audio             Japanese        192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         28.001 kbps
Presentation Graphics           English         27.067 kbps
FILES:
00005.M2TS      0:00:00.000     1:00:28.583     16,025,634,816  35,332
CHAPTERS:
1               0:00:00.000     1:00:28.583     16,844 kbps     51,546 kbps     00:15:30.888    28,707 kbps     00:17:38.182    25,588 kbps     00:11:49.834    87,818 bytes    862,421 bytes   00:15:30.930
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     3628.458                16,845                  7,640,116,336   41,573,176
00005.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           3628.458                4,140                   1,877,817,340   13,224,788
00005.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           3628.458                192                     87,086,592      566,970
00005.M2TS      4354 (0x1102)   0x83            TrueHD          rus (Russian)           3628.458                4,223                   1,915,597,220   13,393,135
00005.M2TS      4355 (0x1103)   0x81            AC3             rus (Russian)           3628.458                192                     87,086,592      566,970
00005.M2TS      4356 (0x1104)   0x83            TrueHD          jpn (Japanese)          3628.458                4,179                   1,895,424,703   13,271,967
00005.M2TS      4357 (0x1105)   0x81            AC3             jpn (Japanese)          3628.458                192                     87,086,592      566,970
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3628.458                28                      12,700,598      71,974
00005.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           3628.458                27                      12,276,731      69,626
post #3890 of 5099 Old 01-28-2012, 09:04 AM
Patsfan123's Avatar
Quoted: 272 Post(s)
Liked: 181
Code:
        Total   Video
00045.MPLS                                                      AVC     2:03:50 33,997,166,592  35,812,795,594  36.60   28.09   DTS-HD Master 5.1 4395Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     THE_PEACEMAKER
Disc Size:      35,812,795,594 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:03:50.464 (h:m:s.ms)
Total Bitrate:          36.60 Mbps
VIDEO:
MPEG-4 AVC Video        28093 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4395 kbps       5.1 / 48 kHz / 4395 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         44.078 kbps
Presentation Graphics           English         51.940 kbps
Presentation Graphics           French          34.772 kbps
Presentation Graphics           Spanish         33.824 kbps
Presentation Graphics           Portuguese      38.067 kbps
Presentation Graphics           French          2.172 kbps
Presentation Graphics           Spanish         2.268 kbps
Presentation Graphics           Portuguese      2.320 kbps
Presentation Graphics           English         2.216 kbps
FILES:
00057.M2TS      0:00:00.000     2:03:50.464     33,997,166,592  36,603
CHAPTERS:
1               0:00:00.000     0:15:49.740     28,098 kbps     37,565 kbps     00:06:04.072    36,041 kbps     00:05:22.488    35,354 kbps     00:11:09.919    146,482 bytes   637,638 bytes   00:02:42.787
2               0:15:49.740     0:01:03.897     27,358 kbps     37,181 kbps     00:16:50.050    35,745 kbps     00:16:46.005    35,109 kbps     00:16:43.419    142,632 bytes   303,077 bytes   00:16:46.588
3               0:16:53.637     0:10:06.897     27,606 kbps     36,863 kbps     00:20:18.634    35,919 kbps     00:19:19.533    35,440 kbps     00:20:09.625    143,925 bytes   453,698 bytes   00:22:02.988
4               0:27:00.535     0:02:02.914     29,924 kbps     33,166 kbps     00:27:01.244    32,619 kbps     00:27:46.998    32,523 kbps     00:27:42.869    156,010 bytes   338,157 bytes   00:28:47.016
5               0:29:03.450     0:12:48.058     27,606 kbps     40,493 kbps     00:40:09.573    35,107 kbps     00:31:21.880    33,601 kbps     00:40:04.443    143,927 bytes   600,925 bytes   00:40:10.533
6               0:41:51.509     0:05:54.187     29,010 kbps     35,475 kbps     00:46:08.307    32,849 kbps     00:46:44.343    31,677 kbps     00:43:44.955    151,242 bytes   376,238 bytes   00:41:57.223
7               0:47:45.696     0:11:24.642     29,702 kbps     37,497 kbps     00:50:51.047    35,926 kbps     00:49:04.733    35,544 kbps     00:49:02.981    154,851 bytes   401,785 bytes   00:52:01.701
8               0:59:10.338     0:10:18.409     26,429 kbps     37,051 kbps     01:08:57.508    34,752 kbps     01:09:01.595    33,295 kbps     01:08:58.342    137,790 bytes   625,552 bytes   01:08:58.425
9               1:09:28.747     0:02:10.088     28,240 kbps     36,809 kbps     01:09:44.930    35,217 kbps     01:09:41.343    33,677 kbps     01:11:10.182    147,228 bytes   308,881 bytes   01:10:22.259
10              1:11:38.836     0:05:25.575     27,764 kbps     37,699 kbps     01:13:40.666    35,752 kbps     01:16:11.275    35,076 kbps     01:16:09.189    144,750 bytes   639,035 bytes   01:12:32.639
11              1:17:04.411     0:07:11.514     28,350 kbps     37,105 kbps     01:17:40.530    35,965 kbps     01:17:36.526    35,017 kbps     01:17:33.523    147,803 bytes   638,160 bytes   01:22:36.910
12              1:24:15.925     0:05:10.059     30,348 kbps     36,245 kbps     01:28:46.029    35,809 kbps     01:28:08.283    35,541 kbps     01:28:08.241    158,223 bytes   310,371 bytes   01:28:10.285
13              1:29:25.985     0:09:46.085     28,850 kbps     41,252 kbps     01:31:58.513    35,977 kbps     01:34:52.228    35,862 kbps     01:31:21.559    150,411 bytes   639,908 bytes   01:31:59.430
14              1:39:12.071     0:13:56.710     26,978 kbps     37,371 kbps     01:41:01.764    36,027 kbps     01:50:27.495    32,917 kbps     01:40:24.268    140,652 bytes   637,333 bytes   01:45:41.752
15              1:53:08.782     0:04:46.077     31,936 kbps     37,379 kbps     01:56:23.309    36,040 kbps     01:54:16.850    35,898 kbps     01:54:11.886    166,499 bytes   358,308 bytes   01:57:43.556
16              1:57:54.859     0:05:55.605     24,591 kbps     42,664 kbps     02:03:44.917    36,256 kbps     01:59:11.644    36,033 kbps     01:59:06.639    128,220 bytes   387,780 bytes   02:03:45.292
STREAM DIAGNOSTICS:
00057.M2TS      4113 (0x1011)   0x1B            AVC                                     7430.298                28,093                  26,092,683,562  141,911,862
00057.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7430.298                4,395                   4,082,127,952   23,346,056
00057.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7430.298                640                     594,439,680     3,483,045
00057.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7430.298                640                     594,439,680     3,483,045
00057.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        7430.298                640                     594,439,680     3,483,045
00057.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7430.298                44                      40,940,374      230,756
00057.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7430.298                52                      48,241,914      272,171
00057.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7430.298                35                      32,296,304      182,958
00057.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7430.298                34                      31,416,151      178,200
00057.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        7430.298                38                      35,357,350      200,370
00057.M2TS      4613 (0x1205)   0x90            PGS             fra (French)            7430.298                2                       2,017,245       11,664
00057.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           7430.298                2                       2,106,232       12,150
00057.M2TS      4615 (0x1207)   0x90            PGS             por (Portuguese)        7430.298                2                       2,155,229       12,413
00057.M2TS      4616 (0x1208)   0x90            PGS             eng (English)           7430.298                2                       2,057,890       11,876
LG 65C6P FW: 04.31.00 | Denon AVR-S930H 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Pioneer SP‑T22A‑LR | eD A2-300 | Oppo UDP-203 | Xbox One S | Panasonic DMP-BDT110 | Chromecast Ultra
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501
Collection: Blu-ray
Patsfan123 is offline
post #3891 of 5099 Old 01-28-2012, 09:44 AM
Patsfan123's Avatar
Quoted: 272 Post(s)
Liked: 181
Yes, the cover really says that. I think they had to change the title slightly since it is not the US theatrical cut. This is the edited European cut which removes the most blatant scenes showing Islam as being the terrorists' motivation for hijacking the plane. Keep in mind this was released in 1996. It is still rated R and the back cover states: "This R-rated version contains material different from the original R-rated version." Also this is one of WB's most impressive looking catalog titles.
Code:
        Total   Video
00100.MPLS                                                      AVC     2:12:41 40,066,062,336  40,827,179,516  40.26   30.54   DTS-HD Master 5.1 4236Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     EXECUTIVE_DECISION
Disc Size:      40,827,179,516 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 2:12:41.411 (h:m:s.ms)
Total Bitrate:          40.26 Mbps
VIDEO:
MPEG-4 AVC Video        30543 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4236 kbps       5.1 / 48 kHz / 4236 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48 kHz / 192 kbps / DN -4dB
Dolby Digital Audio             Portuguese      192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
* Dolby Digital Audio           Japanese        640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         23.528 kbps
Presentation Graphics           French          19.254 kbps
Presentation Graphics           German          23.989 kbps
Presentation Graphics           Spanish         22.539 kbps
Presentation Graphics           Dutch           21.159 kbps
Presentation Graphics           Spanish         21.447 kbps
Presentation Graphics           Portuguese      22.557 kbps
Presentation Graphics           Danish          20.047 kbps
Presentation Graphics           Finnish         19.337 kbps
Presentation Graphics           Norwegian       17.817 kbps
Presentation Graphics           Swedish         18.600 kbps
* Presentation Graphics         Japanese        16.242 kbps
* Presentation Graphics         Japanese        0.655 kbps
Presentation Graphics           French          0.566 kbps
Presentation Graphics           German          0.542 kbps
Presentation Graphics           Spanish         0.707 kbps
FILES:
00066.M2TS      0:00:00.000     2:12:41.411     40,066,062,336  40,260
CHAPTERS:
1               0:00:00.000     0:04:51.666     28,977 kbps     48,950 kbps     00:00:08.216    41,720 kbps     00:00:08.091    38,836 kbps     00:00:08.091    151,050 bytes   749,407 bytes   00:00:03.253
2               0:04:51.666     0:01:54.155     28,598 kbps     38,701 kbps     00:06:38.606    34,641 kbps     00:06:38.898    32,225 kbps     00:06:33.935    149,097 bytes   452,423 bytes   00:06:41.984
3               0:06:45.822     0:03:21.117     33,280 kbps     48,431 kbps     00:07:20.773    39,298 kbps     00:07:12.223    38,126 kbps     00:07:20.731    173,508 bytes   535,331 bytes   00:07:15.393
4               0:10:06.939     0:00:44.669     30,575 kbps     42,114 kbps     00:10:45.436    33,832 kbps     00:10:45.436    32,616 kbps     00:10:40.389    159,403 bytes   419,302 bytes   00:10:31.922
5               0:10:51.609     0:03:50.563     31,816 kbps     42,955 kbps     00:12:36.505    37,951 kbps     00:12:36.505    36,016 kbps     00:10:51.609    165,875 bytes   470,193 bytes   00:11:44.453
6               0:14:42.172     0:02:09.462     32,925 kbps     43,928 kbps     00:15:23.088    37,459 kbps     00:16:00.501    36,638 kbps     00:16:00.542    171,657 bytes   458,255 bytes   00:15:29.011
7               0:16:51.635     0:05:45.595     33,087 kbps     43,612 kbps     00:22:07.576    38,045 kbps     00:17:27.838    37,421 kbps     00:17:29.339    172,501 bytes   513,209 bytes   00:19:38.385
8               0:22:37.230     0:03:03.266     33,167 kbps     46,025 kbps     00:23:38.083    38,757 kbps     00:23:38.083    37,584 kbps     00:22:37.230    172,920 bytes   511,365 bytes   00:24:16.746
9               0:25:40.497     0:06:56.457     30,246 kbps     42,403 kbps     00:30:44.133    38,991 kbps     00:30:43.800    38,080 kbps     00:30:43.341    157,687 bytes   554,219 bytes   00:27:22.223
10              0:32:36.955     0:06:54.080     30,426 kbps     52,530 kbps     00:38:09.954    39,750 kbps     00:34:05.168    38,176 kbps     00:36:30.813    158,628 bytes   532,521 bytes   00:36:47.330
11              0:39:31.035     0:05:02.343     30,330 kbps     58,599 kbps     00:43:16.135    40,442 kbps     00:43:40.200    38,703 kbps     00:43:40.326    158,124 bytes   537,526 bytes   00:43:16.176
12              0:44:33.379     0:04:49.872     29,423 kbps     40,652 kbps     00:48:02.254    36,538 kbps     00:48:20.606    34,270 kbps     00:46:23.822    153,398 bytes   472,688 bytes   00:46:09.349
13              0:49:23.251     0:03:54.359     27,424 kbps     36,011 kbps     00:50:50.005    30,306 kbps     00:52:23.932    29,158 kbps     00:52:43.410    142,974 bytes   401,242 bytes   00:50:49.296
14              0:53:17.611     0:06:10.995     29,507 kbps     43,302 kbps     00:53:17.611    38,226 kbps     00:54:45.699    36,949 kbps     00:54:44.364    153,836 bytes   518,895 bytes   00:54:04.032
15              0:59:28.606     0:04:30.228     29,729 kbps     40,585 kbps     01:00:23.494    36,998 kbps     01:00:23.494    35,445 kbps     01:02:04.554    154,995 bytes   482,203 bytes   01:00:23.536
16              1:03:58.835     0:03:05.560     32,978 kbps     49,798 kbps     01:06:13.302    39,949 kbps     01:05:46.984    37,639 kbps     01:06:22.019    171,930 bytes   498,002 bytes   01:06:36.575
17              1:07:04.395     0:01:05.857     34,282 kbps     40,109 kbps     01:07:38.471    36,978 kbps     01:07:16.824    36,647 kbps     01:07:39.346    178,733 bytes   447,503 bytes   01:08:01.660
18              1:08:10.252     0:02:40.368     30,820 kbps     39,997 kbps     01:09:01.804    36,748 kbps     01:09:23.993    35,705 kbps     01:09:22.700    160,681 bytes   485,075 bytes   01:10:36.607
19              1:10:50.621     0:04:00.615     29,319 kbps     38,627 kbps     01:12:05.696    32,088 kbps     01:11:26.115    31,031 kbps     01:14:07.192    152,856 bytes   455,586 bytes   01:11:26.949
20              1:14:51.236     0:05:25.742     28,726 kbps     37,343 kbps     01:15:17.804    34,169 kbps     01:15:13.842    33,002 kbps     01:15:08.837    149,763 bytes   449,882 bytes   01:19:49.367
21              1:20:16.978     0:02:01.412     32,895 kbps     42,742 kbps     01:21:06.486    38,013 kbps     01:21:01.982    36,063 kbps     01:20:57.477    171,499 bytes   497,994 bytes   01:20:40.168
22              1:22:18.391     0:02:22.725     32,057 kbps     44,620 kbps     01:22:35.367    38,248 kbps     01:22:35.367    37,224 kbps     01:22:34.324    167,131 bytes   441,703 bytes   01:24:07.375
23              1:24:41.117     0:06:30.723     31,210 kbps     43,804 kbps     01:29:52.261    39,555 kbps     01:30:58.536    38,177 kbps     01:30:59.412    162,715 bytes   619,587 bytes   01:29:15.516
24              1:31:11.841     0:03:07.103     32,436 kbps     42,626 kbps     01:33:52.960    38,092 kbps     01:34:05.681    36,966 kbps     01:33:27.935    169,108 bytes   668,331 bytes   01:33:53.836
25              1:34:18.944     0:06:55.456     29,606 kbps     50,116 kbps     01:40:13.006    38,027 kbps     01:40:12.965    33,714 kbps     01:40:08.377    154,350 bytes   525,207 bytes   01:40:13.882
26              1:41:14.401     0:02:14.134     32,519 kbps     41,419 kbps     01:43:17.608    38,114 kbps     01:43:13.729    37,233 kbps     01:41:34.880    169,539 bytes   502,252 bytes   01:42:49.621
27              1:43:28.535     0:03:13.401     31,551 kbps     45,167 kbps     01:45:17.227    38,832 kbps     01:45:53.388    37,116 kbps     01:43:28.535    164,491 bytes   514,740 bytes   01:45:13.640
28              1:46:41.937     0:03:20.742     31,494 kbps     46,539 kbps     01:48:55.403    40,722 kbps     01:48:30.587    37,707 kbps     01:48:30.587    164,194 bytes   619,123 bytes   01:48:31.421
29              1:50:02.679     0:01:10.028     33,983 kbps     41,456 kbps     01:50:07.142    38,482 kbps     01:50:44.054    37,324 kbps     01:50:05.473    177,174 bytes   458,721 bytes   01:51:09.621
30              1:51:12.707     0:01:25.710     34,510 kbps     49,969 kbps     01:51:16.086    38,536 kbps     01:52:03.591    37,573 kbps     01:51:52.956    179,919 bytes   467,565 bytes   01:52:28.116
31              1:52:38.418     0:02:18.471     35,513 kbps     47,400 kbps     01:53:04.402    41,899 kbps     01:52:45.550    39,803 kbps     01:52:45.008    185,150 bytes   650,605 bytes   01:53:04.944
32              1:54:56.890     0:01:55.073     30,320 kbps     43,975 kbps     01:56:33.403    35,106 kbps     01:55:19.078    34,101 kbps     01:55:14.240    158,077 bytes   403,529 bytes   01:55:54.113
33              1:56:51.963     0:01:17.118     29,833 kbps     46,430 kbps     01:57:13.109    36,276 kbps     01:57:13.026    33,268 kbps     01:57:38.801    155,535 bytes   484,388 bytes   01:57:13.735
34              1:58:09.082     0:03:40.720     28,778 kbps     46,887 kbps     02:00:40.483    38,258 kbps     02:00:57.667    35,881 kbps     02:00:55.373    150,033 bytes   590,703 bytes   01:58:35.441
35              2:01:49.802     0:03:32.587     31,055 kbps     54,067 kbps     02:02:15.244    38,989 kbps     02:02:14.952    37,691 kbps     02:04:30.713    161,905 bytes   494,824 bytes   02:04:31.964
36              2:05:22.389     0:02:37.824     33,443 kbps     45,352 kbps     02:07:05.367    39,070 kbps     02:06:36.964    38,067 kbps     02:06:37.214    174,354 bytes   463,823 bytes   02:06:19.280
37              2:08:00.214     0:04:41.197     21,508 kbps     53,222 kbps     02:12:34.780    33,107 kbps     02:08:19.024    32,467 kbps     02:08:13.477    112,165 bytes   760,321 bytes   02:12:34.947
STREAM DIAGNOSTICS:
00066.M2TS      4113 (0x1011)   0x1B            AVC                                     7961.328                30,543                  30,395,342,396  165,304,399
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7961.328                4,236                   4,215,429,432   24,150,926
00066.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7961.328                640                     636,992,000     3,732,375
00066.M2TS      4354 (0x1102)   0x81            AC3             deu (German)            7961.328                640                     636,992,000     3,732,375
00066.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           7961.328                640                     636,992,000     3,732,375
00066.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           7961.328                192                     191,097,600     1,244,125
00066.M2TS      4357 (0x1105)   0x81            AC3             por (Portuguese)        7961.328                192                     191,097,600     1,244,125
00066.M2TS      4358 (0x1106)   0x81            AC3             jpn (Japanese)          7961.328                640                     636,992,000     3,732,375
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7961.328                24                      23,414,139      136,743
00066.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7961.328                19                      19,161,547      112,667
00066.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            7961.328                24                      23,873,366      138,917
00066.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7961.328                23                      22,430,048      130,988
00066.M2TS      4612 (0x1204)   0x90            PGS             nld (Dutch)             7961.328                21                      21,057,322      122,667
00066.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           7961.328                21                      21,343,093      124,519
00066.M2TS      4614 (0x1206)   0x90            PGS             por (Portuguese)        7961.328                23                      22,447,955      130,936
00066.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            7961.328                20                      19,950,386      117,127
00066.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           7961.328                19                      19,243,912      113,364
00066.M2TS      4617 (0x1209)   0x90            PGS             nor (Norwegian)         7961.328                18                      17,731,366      105,090
00066.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           7961.328                19                      18,509,860      109,251
00066.M2TS      4619 (0x120B)   0x90            PGS             jpn (Japanese)          7961.328                16                      16,163,325      95,848
00066.M2TS      4620 (0x120C)   0x90            PGS             jpn (Japanese)          7961.328                1                       652,332         4,352
00066.M2TS      4621 (0x120D)   0x90            PGS             fra (French)            7961.328                1                       562,823         3,234
00066.M2TS      4622 (0x120E)   0x90            PGS             deu (German)            7961.328                1                       539,780         3,115
00066.M2TS      4623 (0x120F)   0x90            PGS             spa (Spanish)           7961.328                1                       703,609         4,025
Collection: Blu-ray
post #3892 of 5099 Old 01-28-2012, 08:32 PM
Phantom Stranger's Avatar
Quoted: 435 Post(s)
Liked: 326
It's not surprising about the censorship, particularly since WB typically will only use one encode for the entire world. What is surprising is the very high 30.54 Mbps video encode, especially for a minor catalog property. That is the highest figure I've seen from Warner in years, if ever. Did the people in charge finally realize their disastrous choices, encoding many BDs at 15 Mbps, were not getting the job done?
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #3893 of 5099 Old 01-29-2012, 07:04 AM
lgans316's Avatar
Quoted: 74 Post(s)
Liked: 47
Or someone snoozed off during encoding and didn't realize they encoded at twice the usual bit rate using the International cut, finally giving up redoing the whole encode.
Blu-ray : 340
lgans316 is offline
post #3894 of 5099 Old 01-29-2012, 03:40 PM
Stephen Dawson's Avatar
There are a number of marked differences between 'traditional' WB Blu-ray releases and this one. The VBR has been creeping up since the early days, and these days they are typically around 22Mbps, rather than the 12.5-16Mbps which used to be so common.
Still, 30Mbps is unusual.
Also of note is that MPEG4 AVC is used instead of VC1, and that a 24 bit encode is used for the main audio.
Could it be that WB got the mastering done in Europe by some off-site facility?
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #3895 of 5099 Old 01-29-2012, 08:09 PM
Alkaline's Avatar
While I had to do a double take when I remembered this is Warner and saw that video bitrate, which is easily the highest I've seen for any Warner title, AVC (and maybe to a lesser degree 24 bit audio) has become their standard practice as of late, at least for new titles. I can think of several recent AVC releases, but only two with 24 bit audio - Inception (VC-1, released seemingly right before the AVC transition) and Crazy Stupid Love.
Alkaline is offline
post #3896 of 5099 Old 01-30-2012, 02:11 PM
paku's Avatar
Quoted: 12 Post(s)
Title: Redline
Year: 2009
Aspect: 1.78:1
Country: US
Studio: Manga
Region: A
Code:
        Total   Video
00004.MPLS                                                      AVC     1:42:48 31,292,860,416  47,159,474,064  40.58   29.92   Dolby TrueHD 5.1 3555Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     Redline
Disc Size:      47,159,474,064 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:42:48.662 (h:m:s.ms)
Total Bitrate:          40.58 Mbps
VIDEO:
MPEG-4 AVC Video        29919 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3555 kbps       5.1 / 48 kHz / 3555 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
Dolby TrueHD Audio              Japanese        1838 kbps       5.1 / 48 kHz / 1838 kbps / 16-bit (AC3 Embedded: 5.1 / 48 kHz / 448 kbps / DN -4dB)
SUBTITLES:
Presentation Graphics           English         26.984 kbps
Presentation Graphics           English         0.243 kbps
FILES:
00004.M2TS      0:00:00.000     1:42:48.662     31,292,860,416  40,583
CHAPTERS:
1               0:00:00.000     1:42:48.662     29,919 kbps     56,607 kbps     00:01:28.004    40,272 kbps     00:40:44.942    37,239 kbps     00:30:04.594    155,985 bytes   934,596 bytes   00:00:56.181
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     6168.537                29,920                  23,070,169,033  125,468,134
00004.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6168.537                4,003                   3,086,720,612   21,170,584
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6168.537                192                     148,048,128     963,855
00004.M2TS      4354 (0x1102)   0x83            TrueHD          jpn (Japanese)          6168.537                2,286                   1,762,844,472   14,021,252
00004.M2TS      4355 (0x1103)   0x81            AC3             jpn (Japanese)          6168.537                192                     148,048,128     963,855
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6168.537                27                      20,806,872      120,719
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6168.537                0                       187,711         1,122
paku is offline
post #3897 of 5099 Old 01-30-2012, 11:29 PM
McCrutchy's Avatar
Halloween II (1981) (Additional Details)
Studio: Universal
Release Date: (not yet released, must be exchanged with Universal)
UPC: None supplied
Region ABC (Confirmed by my own standalone Panasonic DMP-BD35 Multiregion and Region A BD-RE drive with AnyDVD HD).
This version re-instates the original "Moustapha Akkad Presents" title card, which had previously been replaced with an "MCA / A Universal Company Presents" title card.
The corrected disc also supplies an English: DTS-HD MA 5.1 audio option at 3730 kbps for the main feature, whereas the original disc had lossy English: DTS 5.1 audio at 768 kbps. The 2.0 audio remains unchanged.
The rest of the disc is bit-for-bit identical to the original release.
Code:
        Total   Video
00800.MPLS                                                      AVC     1:32:31 26,480,867,328  46,635,957,133  38.16   31.65   DTS-HD Master 5.1 3730Kbps (48kHz/24-bit) DTS 2.0 768Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     HALLOWEEN_2_DOM
Disc Size:      46,635,957,133 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:32:31.546 (h:m:s.ms)
Total Bitrate:          38.16 Mbps
VIDEO:
MPEG-4 AVC Video        31647 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3730 kbps       5.1 / 48 kHz / 3730 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       English         768 kbps        2.0 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         22.735 kbps
Presentation Graphics           Spanish         18.680 kbps
Presentation Graphics           French          19.334 kbps
FILES:
50201.M2TS      0:00:00.000     1:32:31.546     26,480,867,328  38,160
CHAPTERS:
1               0:00:00.000     0:04:18.132     34,130 kbps     41,380 kbps     00:02:28.648    39,938 kbps     00:03:19.908    39,866 kbps     00:02:52.589    177,911 bytes   443,705 bytes   00:03:11.858
2               0:04:18.132     0:03:00.180     24,112 kbps     27,357 kbps     00:04:25.556    25,770 kbps     00:07:02.004    25,558 kbps     00:06:58.126    125,709 bytes   319,207 bytes   00:07:17.311
3               0:07:18.312     0:05:05.555     33,759 kbps     41,377 kbps     00:09:05.836    39,975 kbps     00:08:43.523    39,829 kbps     00:09:20.268    176,003 bytes   355,902 bytes   00:08:48.194
4               0:12:23.868     0:05:01.509     33,032 kbps     41,038 kbps     00:16:11.011    39,446 kbps     00:17:11.155    39,232 kbps     00:16:33.784    172,215 bytes   252,180 bytes   00:16:07.091
5               0:17:25.377     0:02:34.487     31,956 kbps     38,803 kbps     00:17:26.754    36,206 kbps     00:19:22.911    35,569 kbps     00:19:49.855    166,603 bytes   287,516 bytes   00:19:05.602
6               0:19:59.865     0:02:02.580     33,405 kbps     38,579 kbps     00:20:27.559    37,213 kbps     00:20:25.432    36,721 kbps     00:20:24.556    174,159 bytes   234,619 bytes   00:20:30.229
7               0:22:02.446     0:04:47.412     29,778 kbps     36,070 kbps     00:22:41.026    34,955 kbps     00:22:39.024    34,678 kbps     00:23:34.454    155,251 bytes   272,530 bytes   00:23:48.635
8               0:26:49.858     0:06:33.142     34,213 kbps     41,805 kbps     00:31:08.867    39,441 kbps     00:32:10.470    39,228 kbps     00:31:47.989    178,371 bytes   264,638 bytes   00:29:40.278
9               0:33:23.001     0:08:04.442     31,617 kbps     40,183 kbps     00:41:10.634    39,036 kbps     00:40:43.357    38,609 kbps     00:40:38.727    164,834 bytes   278,156 bytes   00:40:22.420
10              0:41:27.443     0:02:54.757     31,304 kbps     39,231 kbps     00:41:34.950    37,633 kbps     00:41:30.946    36,903 kbps     00:41:27.610    163,205 bytes   238,983 bytes   00:41:36.452
11              0:44:22.201     0:10:40.931     32,349 kbps     40,105 kbps     00:47:38.772    39,440 kbps     00:47:36.854    37,976 kbps     00:47:24.258    168,655 bytes   247,381 bytes   00:52:09.668
12              0:55:03.133     0:03:37.091     31,399 kbps     40,781 kbps     00:58:02.187    39,208 kbps     00:58:02.312    38,425 kbps     00:56:28.676    163,702 bytes   241,491 bytes   00:58:04.689
13              0:58:40.225     0:04:37.944     29,781 kbps     39,613 kbps     01:00:53.441    37,389 kbps     01:00:50.188    35,583 kbps     01:00:45.183    155,266 bytes   224,314 bytes   01:03:18.169
14              1:03:18.169     0:04:21.177     32,544 kbps     39,164 kbps     01:07:10.067    37,326 kbps     01:03:20.630    36,883 kbps     01:03:27.512    169,669 bytes   246,358 bytes   01:07:02.435
15              1:07:39.346     0:05:36.419     33,296 kbps     40,977 kbps     01:10:30.559    39,622 kbps     01:10:26.555    39,028 kbps     01:11:59.732    173,591 bytes   252,780 bytes   01:11:41.714
16              1:13:15.766     0:12:18.362     31,256 kbps     38,023 kbps     01:19:27.679    36,319 kbps     01:18:33.917    35,957 kbps     01:18:29.162    162,955 bytes   297,223 bytes   01:19:47.991
17              1:25:34.129     0:02:26.980     34,964 kbps     40,567 kbps     01:25:43.555    39,270 kbps     01:25:47.767    38,542 kbps     01:27:51.057    182,288 bytes   259,625 bytes   01:25:44.222
18              1:28:01.109     0:04:30.436     24,726 kbps     40,416 kbps     01:28:22.922    38,320 kbps     01:28:18.918    37,796 kbps     01:28:13.913    128,929 bytes   603,347 bytes   01:28:23.923
STREAM DIAGNOSTICS:
50201.M2TS      4113 (0x1011)   0x1B            AVC                                     5551.463                31,648                  21,961,324,286  119,435,018
50201.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5551.463                3,730                   2,588,293,056   14,933,891
50201.M2TS      4353 (0x1101)   0x82            DTS             eng (English)           5551.463                768                     532,948,992     3,122,748
50201.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5551.463                23                      15,776,564      91,004
50201.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5551.463                19                      12,962,632      75,012
50201.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5551.463                19                      13,416,891      77,502
Video Birate: 5-Second Window
Video Bitrate: 10-Second Window
Video Frame Size (Min / Max)
Video Frame Type Counts
Video Frame Type Sizes
McCrutchy is offline
post #3898 of 5099 Old 01-31-2012, 03:17 AM
McCrutchy's Avatar
Don't Be a Menace to South Central While Drinking Your Juice in the Hood (1996) (Additional Details)
Studio: Lionsgate
Release Date: 2011-10-10
EAN: 5060223761817
Region B LOCKED (Confirmed by my own standalone Panasonic DMP-BD35 Multiregion and Region A BD-RE drive with AnyDVD HD).
The US edition is from Echo Bridge Entertainment and has not been scanned yet. I don't own it to compare, but according to the Blu-ray.com review, it is 1080i with an English: DTS-HD MA 5.1 track and no subtitles. It also appears to be the 89-minute theatrical version of the film.
This UK release is from Lionsgate and runs 94 minutes, which I believe is the length of the unrated version released on the 2005 SE DVD editions. Note that the film is presented here in 1080p23.976 resolution.
English SDH subtitles are available in white font.
The extras from the US BD have been ported over, with the exception of the music video.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:34:14 22,916,010,432  25,611,933,659  32.42   28.52   DTS-HD Master 5.1 2303Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     DONT_BE_A_MENACE
Disc Size:      25,611,933,659 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:34:14.857 (h:m:s.ms)
Total Bitrate:          32.42 Mbps
VIDEO:
MPEG-4 AVC Video        28515 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2303 kbps       5.1 / 48 kHz / 2303 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         38.693 kbps
FILES:
00000.M2TS      0:00:00.000     1:34:14.857     22,916,010,432  32,419
CHAPTERS:
1               0:00:00.000     0:04:59.716     18,236 kbps     44,791 kbps     00:04:34.190    37,098 kbps     00:04:33.106    34,481 kbps     00:03:21.284    95,061 bytes    670,347 bytes   00:02:38.116
2               0:04:59.716     0:04:19.050     29,715 kbps     41,324 kbps     00:05:06.723    34,751 kbps     00:05:04.304    32,939 kbps     00:05:13.104    154,921 bytes   423,162 bytes   00:07:57.518
3               0:09:18.766     0:06:24.175     29,396 kbps     36,018 kbps     00:10:22.997    32,865 kbps     00:13:16.295    32,067 kbps     00:13:39.026    153,258 bytes   396,043 bytes   00:10:12.153
4               0:15:42.942     0:02:10.421     28,602 kbps     35,823 kbps     00:16:40.249    33,974 kbps     00:17:19.913    32,276 kbps     00:17:19.997    149,119 bytes   392,700 bytes   00:15:46.820
5               0:17:53.363     0:03:06.394     29,216 kbps     36,556 kbps     00:20:20.594    33,322 kbps     00:18:17.054    32,542 kbps     00:20:00.407    152,318 bytes   388,951 bytes   00:17:57.951
6               0:20:59.758     0:02:03.748     29,383 kbps     35,547 kbps     00:21:58.775    32,880 kbps     00:22:17.461    32,472 kbps     00:22:16.293    153,189 bytes   370,656 bytes   00:22:04.281
7               0:23:03.507     0:04:20.760     28,686 kbps     36,057 kbps     00:26:15.949    32,632 kbps     00:25:46.962    31,522 kbps     00:25:45.085    149,555 bytes   432,749 bytes   00:25:15.138
8               0:27:24.267     0:04:58.089     29,080 kbps     36,390 kbps     00:31:28.052    33,441 kbps     00:31:24.674    31,676 kbps     00:29:55.001    151,610 bytes   443,685 bytes   00:28:50.895
9               0:32:22.357     0:03:50.605     29,457 kbps     35,996 kbps     00:33:06.776    34,539 kbps     00:35:40.596    32,913 kbps     00:35:37.760    153,575 bytes   406,716 bytes   00:34:13.342
10              0:36:12.962     0:06:02.278     29,698 kbps     35,854 kbps     00:37:56.232    33,947 kbps     00:39:51.931    32,652 kbps     00:39:51.097    154,830 bytes   597,192 bytes   00:42:15.032
11              0:42:15.241     0:07:40.877     29,866 kbps     35,645 kbps     00:44:25.537    33,061 kbps     00:44:24.370    31,880 kbps     00:43:32.192    155,707 bytes   501,417 bytes   00:49:55.993
12              0:49:56.118     0:04:50.999     29,753 kbps     35,832 kbps     00:54:27.847    33,527 kbps     00:51:05.395    32,066 kbps     00:50:46.376    155,119 bytes   363,766 bytes   00:50:17.514
13              0:54:47.117     0:02:02.455     29,697 kbps     36,201 kbps     00:54:48.118    32,726 kbps     00:55:47.927    31,580 kbps     00:54:58.795    154,824 bytes   383,489 bytes   00:54:48.243
14              0:56:49.572     0:01:12.572     29,725 kbps     35,567 kbps     00:56:51.574    32,770 kbps     00:57:35.285    31,821 kbps     00:57:49.883    154,970 bytes   398,811 bytes   00:58:01.895
15              0:58:02.145     0:01:13.156     29,146 kbps     35,976 kbps     00:58:50.235    34,129 kbps     00:58:48.566    32,228 kbps     00:58:48.566    151,952 bytes   449,167 bytes   00:59:11.673
16              0:59:15.301     0:01:35.804     29,046 kbps     35,839 kbps     00:59:47.250    32,212 kbps     01:00:00.722    31,442 kbps     00:59:57.677    151,433 bytes   388,055 bytes   00:59:41.452
17              1:00:51.105     0:01:17.911     30,427 kbps     36,077 kbps     01:01:34.107    33,950 kbps     01:01:36.234    32,756 kbps     01:01:48.955    158,633 bytes   425,381 bytes   01:01:03.117
18              1:02:09.016     0:01:33.426     30,101 kbps     35,945 kbps     01:02:29.704    33,481 kbps     01:02:55.480    31,928 kbps     01:02:54.771    156,931 bytes   409,582 bytes   01:02:29.746
19              1:03:42.443     0:03:14.110     29,159 kbps     36,033 kbps     01:04:30.741    33,441 kbps     01:06:46.001    32,404 kbps     01:06:43.249    152,024 bytes   402,037 bytes   01:04:41.669
20              1:06:56.554     0:02:57.343     29,792 kbps     36,396 kbps     01:06:57.680    34,287 kbps     01:09:46.974    33,262 kbps     01:09:42.678    155,320 bytes   414,582 bytes   01:06:57.722
21              1:09:53.898     0:02:06.042     29,315 kbps     35,639 kbps     01:09:55.524    33,093 kbps     01:11:08.681    31,838 kbps     01:11:04.843    152,836 bytes   370,777 bytes   01:10:31.227
22              1:11:59.940     0:01:34.928     30,600 kbps     34,505 kbps     01:12:34.892    32,515 kbps     01:12:00.649    32,064 kbps     01:12:00.649    159,536 bytes   328,956 bytes   01:12:13.996
23              1:13:34.868     0:06:05.615     29,828 kbps     35,979 kbps     01:19:04.906    34,436 kbps     01:19:20.005    33,276 kbps     01:19:14.666    155,508 bytes   477,079 bytes   01:19:40.442
24              1:19:40.484     0:01:58.743     29,134 kbps     35,329 kbps     01:20:46.299    32,387 kbps     01:20:31.785    31,373 kbps     01:20:30.408    151,890 bytes   477,093 bytes   01:19:40.692
25              1:21:39.227     0:04:26.099     28,955 kbps     37,100 kbps     01:24:49.417    32,356 kbps     01:22:53.468    31,425 kbps     01:21:41.730    150,957 bytes   416,152 bytes   01:24:49.459
26              1:26:05.326     0:02:21.266     29,421 kbps     36,925 kbps     01:26:16.588    34,363 kbps     01:26:16.588    33,164 kbps     01:26:12.333    153,387 bytes   418,809 bytes   01:28:17.208
27              1:28:26.592     0:01:00.894     23,160 kbps     39,395 kbps     01:29:03.296    32,573 kbps     01:29:03.296    31,057 kbps     01:28:38.146    120,747 bytes   423,304 bytes   01:28:28.928
28              1:29:27.487     0:04:47.370     23,624 kbps     42,895 kbps     01:32:43.516    40,379 kbps     01:32:41.347    37,319 kbps     01:32:37.635    123,202 bytes   532,694 bytes   01:32:43.683
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5654.774                28,516                  20,156,458,113  109,626,648
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5654.774                2,303                   1,627,798,024   9,380,505
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5654.774                39                      27,350,377      157,635
Video Bitrate: 5-Second Window
Extra Feature: Deleted Scene
Code:
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00002.MPLS
Length: 0:01:47.607
Total Bitrate: 32.90 Mbps
Video: MPEG-4 AVC Video / 29686 kbps / 1080i / 29.970 fps / 16:9 / High Profile 4.1
Audio: English / LPCM Audio / 2.0 / 48 kHz / 1536 kbps / 16-bit
Extra Feature: Hood Movie Gumbo
Code:
Playlist: 00003.MPLS
Length: 0:04:28.067
Total Bitrate: 32.89 Mbps
Video: MPEG-4 AVC Video / 29682 kbps / 1080i / 29.970 fps / 16:9 / High Profile 4.1
Extra Feature: Behind the Scenes
Code:
Playlist: 00004.MPLS
Length: 0:03:23.169
Total Bitrate: 32.80 Mbps
Video: MPEG-4 AVC Video / 29588 kbps / 1080i / 29.970 fps / 16:9 / High Profile 4.1
post #3899 of 5099 Old 01-31-2012, 07:08 AM
sschen's Avatar
Quoted: 18 Post(s)
Studio: Sony Pictures
Release Date: December 23 2011
Aspect Ratio: 2.40:1
Region FREE (Tested using RF modded Oppo BDP83 set to all three BD Regions)
Code:
        Total   Video
00001.MPLS                                                      AVC     1:27:27 23,957,907,456  29,080,124,828  36.53   24.60   DTS-HD Master 5.1 2362Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     PRIEST
Disc Size:      29,080,124,828 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:27:27.242 (h:m:s.ms)
Total Bitrate:          36.53 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        24599 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
* MPEG-4 AVC Video      1301 kbps           480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         2362 kbps       5.1 / 48 kHz / 2362 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             German          2378 kbps       5.1 / 48 kHz / 2378 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             Italian         2384 kbps       5.1 / 48 kHz / 2384 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
* DTS Express                   English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         20.724 kbps
Presentation Graphics           English         18.799 kbps
Presentation Graphics           German          22.336 kbps
Presentation Graphics           Italian         18.430 kbps
Presentation Graphics           Danish          20.023 kbps
Presentation Graphics           Finnish         18.492 kbps
Presentation Graphics           Norwegian       17.542 kbps
Presentation Graphics           Swedish         19.983 kbps
Presentation Graphics           Turkish         20.202 kbps
Presentation Graphics           English         75.787 kbps
Presentation Graphics           German          71.863 kbps
Presentation Graphics           Italian         63.823 kbps
* Presentation Graphics         English         45.217 kbps
* Presentation Graphics         German          32.453 kbps
* Presentation Graphics         Italian         29.167 kbps
FILES:
00001.M2TS      0:00:00.000     1:27:27.242     23,957,907,456  36,526
CHAPTERS:
1               0:00:00.000     0:04:20.885     22,357 kbps     44,850 kbps     00:02:57.594    29,009 kbps     00:02:42.620    26,553 kbps     00:03:22.952    116,540 bytes   765,342 bytes   00:03:47.268
2               0:04:20.885     0:06:14.082     23,941 kbps     42,906 kbps     00:08:08.196    28,217 kbps     00:08:37.642    26,616 kbps     00:08:36.057    124,818 bytes   558,664 bytes   00:07:51.762
3               0:10:34.967     0:03:46.684     22,661 kbps     49,523 kbps     00:12:00.428    26,837 kbps     00:11:56.465    25,350 kbps     00:11:51.502    118,143 bytes   527,077 bytes   00:12:00.970
4               0:14:21.652     0:04:47.662     23,991 kbps     44,878 kbps     00:18:51.088    29,266 kbps     00:16:53.595    28,214 kbps     00:16:53.554    125,080 bytes   547,124 bytes   00:16:50.175
5               0:19:09.314     0:05:37.795     24,228 kbps     36,678 kbps     00:24:42.314    27,368 kbps     00:19:37.968    26,128 kbps     00:19:32.963    126,315 bytes   599,263 bytes   00:20:41.240
6               0:24:47.110     0:04:16.881     24,715 kbps     39,043 kbps     00:27:35.403    30,650 kbps     00:27:35.403    28,806 kbps     00:27:37.989    128,852 bytes   653,398 bytes   00:26:17.200
7               0:29:03.992     0:06:04.572     24,165 kbps     38,365 kbps     00:29:46.493    29,478 kbps     00:30:00.799    27,426 kbps     00:30:56.729    125,987 bytes   618,546 bytes   00:32:34.869
8               0:35:08.564     0:05:32.165     23,833 kbps     35,176 kbps     00:36:28.019    27,444 kbps     00:39:03.799    26,760 kbps     00:39:03.007    124,252 bytes   646,932 bytes   00:38:27.179
9               0:40:40.729     0:05:06.472     23,528 kbps     43,816 kbps     00:44:37.591    30,477 kbps     00:41:02.042    30,025 kbps     00:41:01.375    122,666 bytes   661,847 bytes   00:42:26.544
10              0:45:47.202     0:05:27.410     23,034 kbps     35,813 kbps     00:48:08.176    30,295 kbps     00:48:15.809    29,217 kbps     00:48:10.888    120,091 bytes   548,074 bytes   00:49:20.999
11              0:51:14.613     0:05:40.548     24,462 kbps     37,495 kbps     00:52:53.003    28,632 kbps     00:52:35.277    26,679 kbps     00:53:18.653    127,535 bytes   648,618 bytes   00:55:58.813
12              0:56:55.161     0:04:58.214     24,607 kbps     34,702 kbps     00:59:57.468    29,021 kbps     00:59:56.092    27,092 kbps     00:59:55.258    128,290 bytes   485,091 bytes   00:57:24.566
13              1:01:53.376     0:02:46.374     24,402 kbps     31,378 kbps     01:03:48.449    27,820 kbps     01:03:48.449    26,307 kbps     01:02:17.859    127,219 bytes   576,286 bytes   01:02:27.368
14              1:04:39.750     0:05:21.487     24,513 kbps     37,268 kbps     01:08:37.863    29,250 kbps     01:05:02.523    28,223 kbps     01:05:02.523    127,799 bytes   544,742 bytes   01:06:55.553
15              1:10:01.238     0:03:55.610     25,336 kbps     38,988 kbps     01:12:01.984    31,058 kbps     01:11:59.064    29,410 kbps     01:13:46.839    132,088 bytes   512,155 bytes   01:12:00.524
16              1:13:56.849     0:13:30.392     27,960 kbps     44,728 kbps     01:21:39.853    33,182 kbps     01:21:39.686    31,257 kbps     01:21:12.284    145,779 bytes   643,958 bytes   01:17:55.253
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     5247.159                24,599                  16,134,472,246  87,761,426
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5247.159                2,363                   1,549,562,052   9,243,395
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5247.159                192                     125,934,336     819,885
00001.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            5247.159                2,378                   1,559,469,628   9,295,667
00001.M2TS      4355 (0x1103)   0x86            DTS-HD MA       ita (Italian)           5247.159                2,384                   1,563,907,112   9,315,254
00001.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           5247.159                192                     125,934,336     819,885
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5247.159                21                      13,592,830      78,389
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5247.159                19                      12,330,202      72,092
00001.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            5247.159                22                      14,650,031      84,249
00001.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           5247.159                18                      12,088,405      70,290
00001.M2TS      4612 (0x1204)   0x90            PGS             dan (Danish)            5247.159                20                      13,133,168      75,837
00001.M2TS      4613 (0x1205)   0x90            PGS             fin (Finnish)           5247.159                18                      12,128,694      70,367
00001.M2TS      4614 (0x1206)   0x90            PGS             nor (Norwegian)         5247.159                18                      11,506,044      67,028
00001.M2TS      4615 (0x1207)   0x90            PGS             swe (Swedish)           5247.159                20                      13,106,646      75,707
00001.M2TS      4616 (0x1208)   0x90            PGS             tur (Turkish)           5247.159                20                      13,250,725      76,546
00001.M2TS      4617 (0x1209)   0x90            PGS             eng (English)           5247.159                76                      49,708,976      280,817
00001.M2TS      4618 (0x120A)   0x90            PGS             deu (German)            5247.159                72                      47,135,475      266,835
00001.M2TS      4619 (0x120B)   0x90            PGS             ita (Italian)           5247.159                64                      41,862,030      238,019
00001.M2TS      4620 (0x120C)   0x90            PGS             eng (English)           5247.159                45                      29,658,057      167,704
00001.M2TS      4621 (0x120D)   0x90            PGS             deu (German)            5247.159                32                      21,285,791      119,443
00001.M2TS      4622 (0x120E)   0x90            PGS             ita (Italian)           5247.159                29                      19,130,730      107,828
00001.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           5247.159                192                     125,935,616     737,904
00001.M2TS      6912 (0x1B00)   0x1B            AVC                                     5247.159                1,301                   853,152,671     4,704,548
sschen is offline
post #3900 of 5099 Old 01-31-2012, 11:12 AM
Mizu_Ger's Avatar
Kill List (UK) Rental
Studiocanal
The 3 LPCM tracks (@ 1536 kbps) are 2 commentaries and an audio descriptive track.
Code:
        Total   Video
00000.MPLS                                                      AVC     1:35:29 28,421,636,544  35,732,826,086  39.68   26.98   LPCM 2.0 2304Kbps (48kHz/24-bit)          DTS-HD Master 5.1 3159Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     KILL_LIST
Disc Size:      35,732,826,086 bytes
Protection:     AACS
BD-Java:        No
Extras:         50Hz Content
BDInfo:         0.5.8
PLAYLIST REPORT:
Length:                 1:35:29.724 (h:m:s.ms)
Total Bitrate:          39.68 Mbps
VIDEO:
MPEG-4 AVC Video        26977 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
DTS-HD Master Audio             English         3159 kbps       5.1 / 48 kHz / 3159 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         23.882 kbps
FILES:
00000.M2TS      0:00:00.000     1:35:29.724     28,421,636,544  39,683
CHAPTERS:
1               0:00:00.000     0:11:23.516     26,501 kbps     59,889 kbps     00:01:12.614    35,346 kbps     00:01:12.572    32,743 kbps     00:07:43.546    138,157 bytes   533,109 bytes   00:01:13.615
2               0:11:23.516     0:10:11.152     29,184 kbps     36,402 kbps     00:14:10.891    33,145 kbps     00:15:20.294    32,129 kbps     00:20:40.197    152,153 bytes   427,247 bytes   00:11:31.565
3               0:21:34.668     0:05:31.622     29,001 kbps     40,735 kbps     00:22:02.779    32,997 kbps     00:22:02.779    31,687 kbps     00:25:52.300    151,197 bytes   491,057 bytes   00:22:02.821
4               0:27:06.291     0:08:46.400     28,735 kbps     38,800 kbps     00:33:02.689    32,521 kbps     00:27:27.103    31,467 kbps     00:31:35.226    149,810 bytes   604,207 bytes   00:33:02.730
5               0:35:52.692     0:06:00.109     28,818 kbps     42,733 kbps     00:37:02.553    33,608 kbps     00:36:35.193    32,908 kbps     00:36:29.770    150,244 bytes   557,816 bytes   00:36:51.167
6               0:41:52.801     0:09:30.653     29,165 kbps     41,585 kbps     00:50:03.834    33,965 kbps     00:50:29.651    33,457 kbps     00:51:05.228    152,052 bytes   612,518 bytes   00:45:53.000
7               0:51:23.455     0:06:15.166     29,890 kbps     44,319 kbps     00:53:55.690    35,714 kbps     00:52:51.668    34,041 kbps     00:52:50.542    155,832 bytes   436,178 bytes   00:57:29.529
8               0:57:38.621     0:08:02.398     28,737 kbps     38,001 kbps     01:04:22.066    33,057 kbps     01:05:35.973    32,433 kbps     01:05:30.426    149,821 bytes   523,248 bytes   01:04:22.108
9               1:05:41.020     0:05:28.036     29,263 kbps     38,359 kbps     01:08:28.354    34,285 kbps     01:10:56.794    33,797 kbps     01:10:56.794    152,563 bytes   555,252 bytes   01:08:28.395
10              1:11:09.056     0:07:05.716     21,990 kbps     48,243 kbps     01:15:36.657    38,534 kbps     01:15:35.239    34,413 kbps     01:15:35.280    114,644 bytes   472,042 bytes   01:15:37.407
11              1:18:14.773     0:08:21.834     26,028 kbps     57,468 kbps     01:23:29.796    37,877 kbps     01:26:20.508    33,090 kbps     01:26:16.212    135,698 bytes   574,410 bytes   01:19:21.006
12              1:26:36.608     0:08:53.115     18,306 kbps     38,465 kbps     01:27:29.619    34,162 kbps     01:29:36.788    33,597 kbps     01:29:36.621    95,457 bytes    555,026 bytes   01:27:49.430
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5729.641                26,978                  19,321,521,940  105,089,843
00000.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5729.641                2,310                   1,654,744,580   9,167,560
00000.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           5729.641                3,159                   2,262,189,372   12,848,374
00000.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           5729.641                1,543                   1,104,986,928   6,877,512
00000.M2TS      4355 (0x1103)   0x80            LPCM            eng (English)           5729.641                1,543                   1,104,796,056   6,876,324
00000.M2TS      4356 (0x1104)   0x80            LPCM            eng (English)           5729.641                1,543                   1,105,033,200   6,877,800
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5729.641                24                      17,104,946      99,947
Mizu_Ger is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
