NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #1351 of 5099 Old 03-07-2010, 05:35 AM
Stephen Dawson's Avatar
Home - 2009 - Australian version
Distributed by Universal Pictures (Australasia) Pty Ltd
Region Free, confirmed with AnyDVD HD, but main program is in 1080i50 format, which may cause problems for some equipment.
Seems to be similar, but not identical to, German version shown on front page. Although same 1080i50, VC1 format is used, the video bitrate is a bit higher and the language package is different.
The Australian version is also, um, blessed with a planet-saving 20% reduced carbon footprint in the packaging!
Code:
        Total   Video
00001.MPLS                                                      VC-1    1:29:34 23,734,056,960  23,831,150,641  35.33   26.83   DTS-HD Master 5.1 4323Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     HOME_BD_AUS
Disc Size:      23,831,150,641 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:29:34 (h:m:s)
Total Bitrate:          35.33 Mbps
VIDEO:
VC-1 Video              26826 kbps          1080i / 25 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4323 kbps       5.1 / 48 kHz / 4323 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD High-Res Audio           French          2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         39.256 kbps
Presentation Graphics           Swedish         38.063 kbps
Presentation Graphics           Danish          38.629 kbps
Presentation Graphics           Norwegian       39.052 kbps
Presentation Graphics           Finnish         39.840 kbps
FILES:
00001.M2TS      0:00:00.000     1:29:34.000     23,734,056,960  35,332
CHAPTERS:
1               0:00:00.000     0:04:26.760     16,163 kbps     38,155 kbps     00:03:01.440    34,847 kbps     00:02:47.000    34,416 kbps     00:02:46.960    80,801 bytes    759,976 bytes   00:04:15.960
2               0:04:26.760     0:05:13.240     25,495 kbps     50,020 kbps     00:08:24.360    40,126 kbps     00:07:06.680    39,519 kbps     00:05:12.720    127,475 bytes   753,900 bytes   00:08:21.920
3               0:09:40.000     0:04:30.799     33,294 kbps     47,861 kbps     00:13:54.320    42,096 kbps     00:10:17.200    39,482 kbps     00:10:11.960    166,470 bytes   862,441 bytes   00:11:57.840
4               0:14:10.800     0:05:40.200     33,669 kbps     54,021 kbps     00:15:34.480    41,836 kbps     00:18:21.400    39,944 kbps     00:17:18.560    168,344 bytes   885,565 bytes   00:19:50.880
5               0:19:51.000     0:04:31.359     31,003 kbps     57,231 kbps     00:24:17.560    41,494 kbps     00:24:03.760    40,075 kbps     00:22:01.560    155,016 bytes   796,446 bytes   00:22:10.800
6               0:24:22.359     0:07:43.640     32,996 kbps     50,837 kbps     00:25:00.359    42,860 kbps     00:24:27.280    40,702 kbps     00:29:50.560    164,981 bytes   977,444 bytes   00:26:33.640
7               0:32:06.000     0:03:14.000     34,217 kbps     47,454 kbps     00:33:42.040    41,327 kbps     00:32:17.440    39,552 kbps     00:33:35.680    171,085 bytes   778,547 bytes   00:33:06.960
8               0:35:20.000     0:04:19.840     29,701 kbps     47,399 kbps     00:36:57.680    41,159 kbps     00:36:11.439    39,747 kbps     00:36:11.319    148,503 bytes   722,242 bytes   00:38:20.120
9               0:39:39.840     0:04:48.439     29,419 kbps     47,322 kbps     00:42:02.720    41,415 kbps     00:42:54.479    40,214 kbps     00:42:52.480    147,094 bytes   685,320 bytes   00:44:23.760
10              0:44:28.279     0:03:31.720     28,657 kbps     49,914 kbps     00:44:39.120    41,268 kbps     00:46:51.040    39,390 kbps     00:45:05.040    143,286 bytes   790,953 bytes   00:47:54.840
11              0:48:00.000     0:03:18.279     30,364 kbps     44,052 kbps     00:49:18.399    41,168 kbps     00:48:36.880    40,178 kbps     00:48:36.760    151,820 bytes   787,112 bytes   00:50:13.279
12              0:51:18.279     0:04:53.280     21,158 kbps     45,387 kbps     00:55:12.720    42,130 kbps     00:51:22.720    41,120 kbps     00:51:18.880    105,789 bytes   711,416 bytes   00:55:13.399
13              0:56:11.560     0:03:15.439     26,467 kbps     53,697 kbps     00:56:17.600    41,957 kbps     00:57:44.920    40,488 kbps     00:59:16.960    132,333 bytes   897,812 bytes   00:59:24.640
14              0:59:27.000     0:03:32.000     23,173 kbps     44,082 kbps     01:01:39.320    41,536 kbps     01:01:37.320    39,555 kbps     01:01:35.080    115,866 bytes   775,069 bytes   00:59:49.520
15              1:02:59.000     0:04:37.000     18,095 kbps     49,028 kbps     01:05:53.720    36,485 kbps     01:05:04.600    34,834 kbps     01:05:02.760    90,477 bytes    622,716 bytes   01:04:01.240
16              1:07:36.000     0:03:30.960     25,659 kbps     48,441 kbps     01:09:38.400    40,926 kbps     01:09:55.760    40,035 kbps     01:09:50.640    128,297 bytes   739,444 bytes   01:09:57.680
17              1:11:06.960     0:06:22.239     16,882 kbps     52,992 kbps     01:17:10.760    40,743 kbps     01:11:21.600    39,620 kbps     01:11:16.400    84,607 bytes    727,641 bytes   01:14:00.400
18              1:17:29.200     0:03:28.920     28,332 kbps     48,826 kbps     01:18:44.680    41,317 kbps     01:18:31.480    40,275 kbps     01:19:48.160    141,660 bytes   774,119 bytes   01:20:47.360
19              1:20:58.120     0:04:05.880     28,305 kbps     49,241 kbps     01:22:25.880    41,055 kbps     01:22:09.960    40,241 kbps     01:22:05.120    141,596 bytes   778,425 bytes   01:23:26.920
20              1:25:04.000     0:04:30.000     24,836 kbps     52,069 kbps     01:28:14.000    41,128 kbps     01:27:49.600    38,815 kbps     01:28:06.560    124,328 bytes   746,684 bytes   01:26:42.640
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0xEA            VC-1                                    5373.840                26,827                  18,020,217,901  98,016,467
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5373.840                4,323                   2,904,183,976   16,621,156
00001.M2TS      4353 (0x1101)   0x85            DTS-HD HR       fra (French)            5373.840                2,046                   1,374,401,864   8,061,008
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5373.840                39                      26,370,019      148,024
00001.M2TS      4609 (0x1201)   0x90            PGS             swe (Swedish)           5373.840                38                      25,568,826      144,000
00001.M2TS      4610 (0x1202)   0x90            PGS             dan (Danish)            5373.840                39                      25,949,274      146,041
00001.M2TS      4611 (0x1203)   0x90            PGS             nor (Norwegian)         5373.840                39                      26,233,217      147,558
00001.M2TS      4612 (0x1204)   0x90            PGS             fin (Finnish)           5373.840                40                      26,762,588      150,566
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1352 of 5099 Old 03-07-2010, 07:15 AM
Patsfan123's Avatar
Quoted: 106 Post(s)
Liked: 65
Certain studios have been using that packaging in the US for a year now starting with QoS.
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is online now
post #1353 of 5099 Old 03-08-2010, 11:33 AM - Thread Starter
Cinema Squid's Avatar
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
A   [US] 2009   (500) Days of Summer                                            AVC     1080p24 2.40:1  34.99   1:35:04 30,580,740,096  45,589,418,332  42.89   DTS-MA  5.1    48/24  3405
ABC [US] 2009   2012        AVC     1080p24 2.40:1  21.99   2:37:49 37,814,421,504  41,661,659,465  31.95   DTS-MA  5.1    48/24  4167
A   [US] 2009   Astro Boy                                                       AVC     1080p24 2.35:1  29.58   1:33:48 25,403,062,272  33,349,821,458  36.11   DTS-MA  5.1    48/24  3957
A   [US] 1956   Bigger Than Life                                                AVC     1080p24 2.55:1  35.10   1:35:21 28,228,706,304  46,152,830,489  39.47   LPCM    1.0    48/24  1152
ABC [AU] 2009   Blessed                                                         AVC     1080p24         20.08   1:55:33 22,470,785,472  23,507,099,636  25.93   DTS-MA  5.1    48/16  1791  / TrueHD  5.1    48/16  1199
A   [US] 2009   Broken Embraces                                                 AVC     1080p24 2.35:1  26.93   2:07:32 31,825,778,688  39,931,918,013  33.27   DTS-MA  5.1    48/24  3858
ABC [US] 2002   Cabin Fever                                                     AVC     1080p24 2.40:1  19.82   1:37:48 19,630,798,848  23,012,296,544  26.76   DTS-MA  7.1    48/24  5206
ABC [US] 1981   Clash of the Titans                                                VC-1    1080p24 1.78:1  31.08   1:57:56 32,263,458,816  35,025,537,147  36.48   DTS-MA  5.1    48/24  1649
ABC [UK] 2009   The Day of the Triffids: Part 1                                 AVC     1080p24*1.78:1  21.99   1:32:53 17,793,183,744  45,808,291,036  25.54   DTS-MA  5.1    48/16  1954  / AC3     2.0    48     224
                                         Part 2                                 AVC     1080p24*1.78:1  22.00   1:32:54 17,758,629,888                  25.49   DTS-MA  5.1    48/12  1901  / AC3     2.0    48     224
A   [US] 1978   Days of Heaven                                                  AVC     1080p24 1.78:1  34.95   1:34:00 28,876,320,768  47,242,482,400  40.96   DTS-MA  5.1    48/24  3737
ABC [AU] 2007   The Diving Bell and the Butterfly                               AVC     1080p24*1.85:1  30.00   1:51:45 30,307,713,024  30,370,502,556  36.16   DTS-MA  5.1    48/16  1957  / TrueHD  5.1    48/16  1349
ABC [US] 2009   Doctor Who: The Waters of Mars                                  VC-1    1080i60 1.78:1  30.31   1:02:04 15,856,730,112  32,647,968,548  34.06   DTS-HR  5.1    48/16  2046
A   [US] 1994   Drop Zone                                                       AVC     1080p24 2.35:1  22.00   1:41:32 21,343,420,416  21,928,471,210  28.03   DTS-MA  5.1    48/24  4448
ABC [AU] 1994   Forrest Gump                                                    AVC     1080p24 2.35:1  26.56   2:22:09 38,835,130,368  44,897,746,188  36.43   DTS-MA  5.1    48/24  4094
ABC [HK] 2009   The Founding of a Republic                                      AVC     1080p24 2.35:1  27.97   2:20:57 40,360,378,368  44,721,887,347  38.18   DTS-MA  7.1    48/16  2758  / TrueHD  7.1    48/16  2136  / AC3     5.1    48     640
ABC [AU] 2008   Franklyn                                                        AVC     1080p24*2.35:1  18.96   1:37:58 18,625,790,400  24,028,668,808  25.35   TrueHD  5.1    48/16  1756  / LPCM    2.0    48/16  1536
A   [US] 2009   Grace                                                           VC-1    1080p24 2.35:1  16.16   1:24:31 14,634,838,464  18,667,450,786  23.09   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [AU] 2009   Home                                                            VC-1    1080i50 1.78:1  26.83   1:29:34 23,734,056,960  23,831,150,641  35.33   DTS-MA  5.1    48/24  4323
A   [US] 2009   The House of the Devil                                          AVC     1080p24 1.78:1  23.00   1:35:12 20,522,330,112  23,063,913,240  28.74   DTS-MA  5.1    48/16  1892  / LPCM    2.0    48/16  1536
ABC [UK] 2009   Infestation                                                     AVC     1080p24 1.85:1  24.65   1:31:05 19,802,897,088  21,332,321,812  28.99   DTS-MA  5.1    48/16  2096  / AC3     5.1    48     448
A   [US] 2009   Jennifer's Body: Unrated (seamless)                             AVC     1080p24 1.85:1  25.82   1:47:29 26,985,363,456  47,300,060,504  33.48   DTS-MA  5.1    48/24  3803
                                 Theatrical (seamless)                          AVC     1080p24 1.85:1  25.83   1:42:21 25,708,726,272                  33.49   DTS-MA  5.1    48/24  3809
    [DE] 2008   Kill Switch                                                     AVC     1080p24 1.78:1  19.29   1:32:37 17,168,924,352  20,859,132,232  24.72   DTS-HR  5.1    48/16  2559
ABC [UK] 2008   Let the Right One In                                            AVC     1080p24 2.35:1  19.38   1:54:35 21,458,085,888  23,126,296,320  24.97   DTS-MA  5.1    48/24  3545  / AC3     5.0    48     448
ABC [US] 1989   Lethal Weapon 2                                                 VC-1    1080p24 2.35:1  22.73   1:54:24 21,402,163,200  22,125,119,578  24.94   AC3     5.1    48     640
 B  [UK] 1931   M                                                               AVC     1080p24 1.18:1  29.97   1:50:45 30,990,206,976  44,632,355,878  37.31   DTS-MA  2.0    48/16  1564
 B  [UK] 1999   Magnolia                                                        VC-1    1080p24 2.40:1  21.36   3:08:39 36,274,434,048  40,645,999,280  25.64   TrueHD  5.1    48/16  1559
ABC [AU] 1993   Map of the Human Heart                                          AVC     1080p24 2.35:1  24.45   1:49:14 24,311,058,432  24,403,500,616  29.67   DTS-MA  2.0    48/16  1630  / TrueHD  2.0    48/16  639
ABC [HK] 2009   Mulan                                                           AVC     1080p24 2.35:1  22.39   1:54:09 23,453,939,712  23,713,794,774  27.40   DTS-MA  5.1    48/16  2133  / AC3     5.1    48     640
ABC [DE] 1997   My Best Friend's Wedding                                        AVC     1080p24 2.40:1  26.96   1:44:52 29,612,169,216  33,739,257,150  37.65   TrueHD  5.1    48/16  1572
ABC [US] 1984   The Neverending Story                                           VC-1    1080p24 2.40:1  23.06   1:34:04 19,294,752,768  19,471,971,628  27.35   DTS-MA  5.1    48/16  2222
 B  [AU] 2004   The Passion of the Christ: Theatrical (seamless)                AVC     1080p24 2.40:1  22.39   2:06:32 27,384,158,208  41,722,050,280  28.86   DTS-MA  5.1    48/24  3959
                                           Recut (seamless)                     AVC     1080p24 2.40:1  22.37   2:01:51 26,278,612,992                  28.76   DTS-MA  5.1    48/24  3901
A   [US] 1996   The Phantom                                                     AVC     1080p24 2.35:1  22.99   1:40:18 22,925,438,976  23,524,253,985  30.48   DTS-MA  7.1    48/24  5824
ABC [UK] 2008   Pontypool                                                       AVC     1080p24 2.35:1  20.00   1:36:32 17,959,176,192  23,089,111,250  24.81   DTS-MA  5.1    48/16  1813
ABC [US] 2008   Ponyo                                                              AVC     1080p24 1.85:1  22.57   1:42:54 22,950,408,192  44,302,151,481  29.74   AC3     5.1-EX 48     640
ABC [US] 2006   Poultrygeist: Night of the Chicken Dead                         AVC     1080p24 1.78:1  15.00   1:42:53 12,690,720,768  24,314,451,930  16.45   AC3     2.0    48     192
A   [US] 2009   Precious                                                        AVC     1080p24 1.85:1  34.80   1:49:49 33,817,675,776  46,888,963,760  41.06   DTS-MA  5.1    48/24  3198
ABC [AU] 2009   The Private Lives of Pippa Lee                                  AVC     1080i50 1.85:1  27.93   1:34:11 24,286,359,552  24,381,532,560  34.38   DTS-MA  5.1    48/16  2008  / TrueHD  5.1    48/16  1322
A   [US] 1987   The Running Man                                                 AVC     1080p24 1.78:1  24.99   1:40:43 24,654,686,208  28,231,106,436  32.64   DTS-MA  7.1    48/24  5427
A   [US] 1962   Sanjuro                                                         AVC     1080p24 2.35:1  34.99   1:35:57 31,689,117,696  42,493,590,459  44.04   DTS-MA  3.0    48/24  2173  / LPCM    1.0    48/24  1152
A   [US] 2009   Sorority Row                                                    AVC     1080p24 2.40:1  29.95   1:40:58 29,647,423,488  38,110,743,078  39.15   DTS-MA  5.1    48/24  4072
ABC [US] 2008   Soul Power                                                      AVC     1080p24 1.78:1  27.94   1:32:30 26,758,311,936  32,845,094,376  38.57   DTS-MA  5.1    48/24  4029
ABC [US] 1995   Toy Story                                                       AVC     1080p24 1.78:1  23.57   1:21:03 20,933,124,096  43,286,933,371  34.44   DTS-MA  5.1-ES 48/24  4429  / DTS-MA  2.0    48/24  2116
ABC [US] 1990   Two Evil Eyes                                                   AVC     1080p24 1.78:1  36.08   1:59:55 41,966,407,680  46,805,104,072  46.66   DTS-MA  7.1    48/24  4662  / TrueHD  7.1    48/16  1668  / AC3     5.1-EX 48     448
ABC [US] 2009   Up in the Air                                                   AVC     1080p24 1.85:1  31.52   1:49:20 32,656,533,504  42,589,883,527  39.83   DTS-MA  5.1    48/24  3838
A   [US] 1961   Yojimbo                                                         AVC     1080p24 2.35:1  34.98   1:50:51 36,736,069,632  48,558,069,845  44.19   DTS-MA  3.0    48/24  2307  / LPCM    1.0    48/24  1152
EDIT: I modified the format of the "blu-specs.txt" file to include the URL of the specs posting as the first column in each line. This makes the file too large to directly attach to the post, so it's a download link now.
Cinema Squid is offline
post #1354 of 5099 Old 03-09-2010, 04:48 PM
Patsfan123's Avatar
Quoted: 106 Post(s)
Liked: 65
Code:
        Total   Video
00001.MPLS                                                      AVC     1:49:20 32,656,533,504  42,599,867,933  39.82   31.52   DTS-HD Master 5.1 3838Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     UP_IN_THE_AIR
Disc Size:      42,599,867,933 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:49:20 (h:m:s)
Total Bitrate:          39.82 Mbps
VIDEO:
MPEG-4 AVC Video        31523 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3838 kbps       5.1 / 48 kHz / 3838 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         42.547 kbps
Presentation Graphics           English         44.164 kbps
Presentation Graphics           French          32.101 kbps
Presentation Graphics           Spanish         36.984 kbps
Presentation Graphics           Portuguese      35.948 kbps
FILES:
00001.M2TS      0:00:00.000     1:49:20.554     32,656,533,504  39,822
CHAPTERS:
1               0:00:00.000     0:07:41.294     31,913 kbps     59,156 kbps     00:00:23.481    39,193 kbps     00:01:35.011    36,874 kbps     00:01:29.964    166,367 bytes   772,531 bytes   00:02:34.988
2               0:07:41.294     0:03:25.705     32,508 kbps     42,090 kbps     00:11:05.289    35,191 kbps     00:08:54.825    34,721 kbps     00:08:54.825    169,482 bytes   696,504 bytes   00:11:06.999
3               0:11:06.999     0:07:10.513     31,368 kbps     40,621 kbps     00:16:55.806    34,995 kbps     00:16:42.584    33,706 kbps     00:16:43.585    163,539 bytes   703,740 bytes   00:11:07.792
4               0:18:17.513     0:07:26.529     31,949 kbps     44,296 kbps     00:21:49.933    36,633 kbps     00:22:49.451    35,737 kbps     00:21:13.605    166,565 bytes   739,798 bytes   00:18:23.018
5               0:25:44.042     0:05:18.192     31,927 kbps     47,271 kbps     00:27:04.623    38,202 kbps     00:27:03.288    35,710 kbps     00:26:58.450    166,452 bytes   627,417 bytes   00:31:02.235
6               0:31:02.235     0:05:02.927     32,249 kbps     42,744 kbps     00:32:14.015    34,854 kbps     00:33:58.995    34,692 kbps     00:33:53.990    168,132 bytes   653,819 bytes   00:31:05.572
7               0:36:05.162     0:06:55.790     31,754 kbps     42,586 kbps     00:38:41.569    36,132 kbps     00:38:58.836    34,753 kbps     00:39:09.889    165,550 bytes   741,667 bytes   00:40:42.731
8               0:43:00.953     0:06:14.999     31,467 kbps     47,408 kbps     00:45:13.377    37,314 kbps     00:45:12.000    35,970 kbps     00:45:13.377    164,055 bytes   712,578 bytes   00:45:13.419
9               0:49:15.953     0:04:04.077     31,889 kbps     39,794 kbps     00:52:38.530    33,656 kbps     00:51:26.708    33,379 kbps     00:50:38.827    166,256 bytes   558,857 bytes   00:49:22.751
10              0:53:20.030     0:06:40.400     31,821 kbps     45,880 kbps     00:54:42.278    37,611 kbps     00:54:24.469    35,095 kbps     00:54:25.553    165,899 bytes   590,328 bytes   00:56:01.149
11              1:00:00.430     0:07:38.332     32,059 kbps     43,122 kbps     01:02:30.496    39,010 kbps     01:02:46.971    36,107 kbps     01:02:30.496    167,141 bytes   589,541 bytes   01:00:02.890
12              1:07:38.763     0:10:00.808     31,654 kbps     46,746 kbps     01:14:17.202    37,668 kbps     01:10:02.615    35,566 kbps     01:09:57.610    165,031 bytes   688,507 bytes   01:14:14.408
13              1:17:39.571     0:07:08.553     32,288 kbps     44,103 kbps     01:23:06.481    37,818 kbps     01:17:51.625    35,649 kbps     01:17:46.870    168,334 bytes   738,876 bytes   01:17:43.700
14              1:24:48.124     0:03:53.274     31,570 kbps     45,676 kbps     01:24:49.375    34,887 kbps     01:24:49.375    33,757 kbps     01:27:05.261    164,590 bytes   650,315 bytes   01:28:41.399
15              1:28:41.399     0:04:44.283     32,041 kbps     49,974 kbps     01:33:23.806    37,373 kbps     01:33:20.678    36,085 kbps     01:29:19.520    167,047 bytes   690,100 bytes   01:32:11.317
16              1:33:25.683     0:07:09.011     31,854 kbps     43,172 kbps     01:35:22.591    36,982 kbps     01:35:22.299    35,310 kbps     01:33:54.170    166,070 bytes   675,687 bytes   01:40:34.695
17              1:40:34.695     0:03:33.546     32,132 kbps     38,874 kbps     01:42:21.218    34,433 kbps     01:42:17.256    34,100 kbps     01:42:24.555    167,519 bytes   725,939 bytes   01:40:38.824
18              1:44:08.242     0:05:12.311     24,405 kbps     61,858 kbps     01:49:14.631    36,937 kbps     01:48:27.125    35,713 kbps     01:48:27.751    127,272 bytes   747,769 bytes   01:49:14.839
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     6560.471                31,523                  25,850,722,547  140,585,533
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6560.471                3,838                   3,147,615,256   18,128,189
00001.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6560.471                640                     524,846,080     3,075,270
00001.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6560.471                640                     524,846,080     3,075,270
00001.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        6560.471                640                     524,846,080     3,075,270
00001.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6560.471                224                     183,696,128     1,025,090
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6560.471                43                      34,891,207      199,036
00001.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6560.471                44                      36,217,883      206,656
00001.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6560.471                32                      26,325,284      152,489
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6560.471                37                      30,329,048      174,506
00001.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6560.471                36                      29,480,200      168,987
Collection: Blu-ray
post #1355 of 5099 Old 03-10-2010, 02:33 PM
Paranormal Activity - 2007 - Australian version
Distributed by Icon Film Distribution Pty Ltd
Locked to Region B, confirmed with AnyDVD HD. Also has a 1080i50 extra.
Contains two versions of movie: the theatrical and the 'alternate' version. This is done using seamless branching, and the only difference between the two is that the last 6:22 of the theatrical is replaced with a 4:54 different section in the alternate version.
One point of interest: as with the US version this one uses DTS-MA HD 5.1 24/48 audio, but has a 768kbps core rather than 1509kbps. The consequences for the overall bitrate seem to be huge: 2928kbps for the Australian (theatrical) version, 3678kbps for the equivalent US version.
Theatrical:
Code:
        Total   Video
00000.MPLS                                                      AVC     1:26:43 24,938,328,960  28,850,973,765  38.34   29.43   DTS-HD Master 5.1 2928Kbps (48kHz/24-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     PARANORMAL ACTIVITY
Disc Size:      28,850,973,765 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:26:43 (h:m:s)
Total Bitrate:          38.34 Mbps
VIDEO:
MPEG-4 AVC Video        29425 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2928 kbps       5.1 / 48 kHz / 2928 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
LPCM Audio                      English         2304 kbps       2.0 / 48 kHz / 2304 kbps / 24-bit
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         53.697 kbps
FILES:
00000.M2TS      0:00:00.000     1:20:21.566     23,475,900,864  38,951
00002.M2TS      1:20:21.566     0:06:22.048     1,462,428,096   30,620
CHAPTERS:
1               0:00:00.000     0:07:28.030     29,436 kbps     44,341 kbps     00:00:53.428    40,600 kbps     00:00:49.466    37,675 kbps     00:04:27.308    153,450 bytes   448,392 bytes   00:00:05.088
2               0:07:28.030     0:04:09.082     30,429 kbps     43,342 kbps     00:07:34.537    37,673 kbps     00:09:07.797    36,691 kbps     00:09:08.381    158,644 bytes   432,876 bytes   00:09:17.890
3               0:11:37.113     0:09:11.550     32,586 kbps     46,027 kbps     00:14:45.467    38,306 kbps     00:11:45.871    36,607 kbps     00:13:28.432    169,891 bytes   406,697 bytes   00:13:32.811
4               0:20:48.664     0:08:00.396     28,824 kbps     44,846 kbps     00:22:10.037    40,544 kbps     00:22:07.826    36,852 kbps     00:22:07.826    150,275 bytes   379,748 bytes   00:22:53.705
5               0:28:49.060     0:08:40.895     30,287 kbps     44,286 kbps     00:29:23.094    40,471 kbps     00:29:21.843    36,692 kbps     00:29:21.843    157,900 bytes   403,673 bytes   00:29:07.996
6               0:37:29.956     0:07:01.379     29,252 kbps     44,115 kbps     00:39:44.256    39,236 kbps     00:41:29.487    34,628 kbps     00:39:20.149    152,507 bytes   380,133 bytes   00:43:57.217
7               0:44:31.335     0:07:28.823     30,699 kbps     43,879 kbps     00:51:24.623    38,629 kbps     00:51:21.077    37,692 kbps     00:47:35.352    160,051 bytes   459,205 bytes   00:47:35.394
8               0:52:00.158     0:07:07.885     30,127 kbps     44,468 kbps     00:56:06.988    39,557 kbps     00:56:47.403    36,674 kbps     00:56:45.819    157,070 bytes   371,503 bytes   00:58:32.300
9               0:59:08.044     0:06:36.979     29,044 kbps     42,905 kbps     01:00:19.198    38,759 kbps     01:00:16.654    36,093 kbps     01:00:16.654    151,420 bytes   366,206 bytes   01:00:16.696
10              1:05:45.024     0:07:41.419     28,241 kbps     44,133 kbps     01:06:53.926    40,488 kbps     01:06:53.843    36,778 kbps     01:06:51.674    147,233 bytes   360,445 bytes   01:06:38.494
11              1:13:26.443     0:06:55.123     30,630 kbps     44,586 kbps     01:15:18.931    36,673 kbps     01:19:37.731    35,779 kbps     01:19:34.644    159,707 bytes   406,153 bytes   01:13:38.414
12              1:20:21.566     0:06:22.048     22,206 kbps     41,486 kbps     01:20:23.777    39,167 kbps     01:20:22.901    37,826 kbps     01:20:22.609    115,797 bytes   420,609 bytes   01:20:29.533
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     4821.483                29,998                  18,079,403,530  98,326,291
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4821.483                2,939                   1,771,306,468   10,087,992
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           4821.483                2,310                   1,392,469,416   7,714,512
00000.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           4821.483                1,542                   929,598,696     5,785,884
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4821.483                57                      34,165,200      194,118
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     381.965                 22,211                  1,060,470,441   5,768,400
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           381.965                 2,792                   133,328,828     761,514
00002.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           381.965                 2,311                   110,336,040     611,280
00002.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           381.965                 1,543                   73,659,240      458,460
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           381.965                 16                      762,555         4,386
Alternate:
Code:
        Total   Video
00002.MPLS                                                      AVC     1:25:15 24,510,534,528  28,850,973,765  38.33   29.39   DTS-HD Master 5.1 2956Kbps (48kHz/24-bit) LPCM 2.0 2304Kbps (48kHz/24-bit)
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:25:15 (h:m:s)
Total Bitrate:          38.33 Mbps
VIDEO:
MPEG-4 AVC Video        29386 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2956 kbps       5.1 / 48 kHz / 2956 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 768 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         54.731 kbps
FILES:
00001.M2TS      1:20:21.566     0:04:54.293     1,034,633,664   28,121
CHAPTERS:
12              1:20:21.566     0:04:54.293     19,368 kbps     41,128 kbps     01:20:26.655    39,233 kbps     01:20:22.692    37,773 kbps     01:20:22.442    101,004 bytes   433,986 bytes   01:20:29.533
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     294.211                 19,373                  712,481,769     3,876,281
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           294.211                 3,238                   119,074,832     673,725
00001.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           294.211                 2,311                   84,992,396      470,872
00001.M2TS      4354 (0x1102)   0x80            LPCM            eng (English)           294.211                 1,543                   56,740,076      353,154
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           294.211                 23                      834,771         4,801
Stephen Dawson
hifi-writer.com
post #1356 of 5099 Old 03-10-2010, 07:25 PM
'Claymore' (Kureimoa) - 2007 - Australian version - Disc 1 of 3
Episodes 01-09
Distributed by Madman Entertainment Pty Ltd
Locked to Regions A & B only, confirmed with AnyDVD HD.
There are also playlists for the nine individual episodes on this disc, but these are not used. The disc instead hooks into the main 'Play All' playlist, shown here, when an individual episode is selected from the Scene Selections style menu. When the end of the episode is reached, the disc just plays on to the next episode.
Code:
        Total   Video
00001.MPLS                                                      AVC     3:25:46 47,234,734,080  47,528,898,634  30.61   23.31   Dolby TrueHD 5.1 3368Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CLAYMORE_D1
Disc Size:      47,528,898,634 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 3:25:46 (h:m:s)
Total Bitrate:          30.61 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        23312 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3368 kbps       5.1 / 48 kHz / 3368 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -3dB)
Dolby Digital Audio             Japanese        640 kbps        2.0 / 48 kHz / 640 kbps / DN -1dB
* Dolby Digital Audio           English         640 kbps        2.0 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         31.984 kbps
Presentation Graphics           English         2.350 kbps
FILES:
00041.M2TS      0:00:00.000     0:22:50.702     5,497,595,904   32,086
00042.M2TS      0:22:50.702     0:22:50.702     5,311,930,368   31,003
00051.M2TS      0:45:41.405     0:22:50.702     5,313,146,880   31,010
00052.M2TS      1:08:32.108     0:22:50.702     5,354,600,448   31,252
00053.M2TS      1:31:22.810     0:22:50.702     5,346,336,768   31,203
00054.M2TS      1:54:13.513     0:22:50.702     5,345,863,680   31,201
00055.M2TS      2:17:04.215     0:22:50.702     4,244,029,440   24,770
00056.M2TS      2:39:54.918     0:22:50.702     5,447,608,320   31,795
00057.M2TS      3:02:45.621     0:22:50.702     5,345,636,352   31,199
00040.M2TS      3:25:36.323     0:00:10.510     27,985,920      21,301
CHAPTERS:
1               0:00:00.000     0:00:58.091     18,656 kbps     25,481 kbps     00:00:41.741    22,766 kbps     00:00:06.973    21,830 kbps     00:00:02.202    77,766 bytes    202,911 bytes   00:00:11.578
2               0:00:58.091     0:00:59.959     32,021 kbps     42,280 kbps     00:01:07.267    37,703 kbps     00:01:10.904    37,217 kbps     00:01:07.734    133,556 bytes   351,580 bytes   00:01:07.767
3               0:01:58.051     0:03:36.916     25,712 kbps     39,600 kbps     00:02:09.629    38,461 kbps     00:02:09.629    37,959 kbps     00:02:04.624    107,238 bytes   347,642 bytes   00:02:01.054
4               0:05:34.967     0:04:24.397     23,171 kbps     34,181 kbps     00:07:36.456    30,989 kbps     00:07:36.422    27,974 kbps     00:07:33.719    96,641 bytes    255,056 bytes   00:07:37.457
5               0:09:59.365     0:05:41.374     22,107 kbps     46,803 kbps     00:14:32.438    38,614 kbps     00:15:14.914    36,942 kbps     00:15:09.975    92,204 bytes    282,708 bytes   00:14:33.072
6               0:15:40.739     0:05:50.049     22,892 kbps     39,311 kbps     00:20:35.067    35,545 kbps     00:20:34.666    33,752 kbps     00:20:34.499    95,477 bytes    261,827 bytes   00:21:30.756
7               0:21:30.789     0:01:09.369     34,229 kbps     40,719 kbps     00:21:46.938    38,973 kbps     00:21:44.936    38,623 kbps     00:21:42.034    142,763 bytes   477,832 bytes   00:22:40.158
8               0:22:40.158     0:00:10.543     23,050 kbps     33,018 kbps     00:22:40.158    27,656 kbps     00:22:40.158    24,080 kbps     00:22:40.158    96,137 bytes    488,828 bytes   00:22:41.159
9               0:22:50.702     0:02:31.951     23,498 kbps     31,172 kbps     00:24:21.393    30,075 kbps     00:24:17.455    28,417 kbps     00:24:16.421    98,005 bytes    241,972 bytes   00:24:21.426
10              0:25:22.654     0:00:59.959     32,986 kbps     42,699 kbps     00:25:31.830    36,733 kbps     00:25:37.435    36,398 kbps     00:25:32.297    137,578 bytes   353,604 bytes   00:25:32.330
11              0:26:22.614     0:03:04.017     23,945 kbps     33,711 kbps     00:27:01.453    30,266 kbps     00:26:22.614    29,511 kbps     00:27:48.466    99,870 bytes    251,431 bytes   00:26:24.616
12              0:29:26.631     0:04:30.937     21,741 kbps     32,525 kbps     00:30:14.913    29,747 kbps     00:32:03.421    28,563 kbps     00:31:17.909    90,678 bytes    245,513 bytes   00:31:52.477
13              0:33:57.568     0:04:46.919     22,111 kbps     34,443 kbps     00:37:31.983    31,755 kbps     00:37:29.313    28,523 kbps     00:36:04.262    92,222 bytes    269,090 bytes   00:37:31.349
14              0:38:44.488     0:05:37.003     23,705 kbps     36,723 kbps     00:42:38.422    31,084 kbps     00:40:57.488    29,964 kbps     00:40:56.353    98,872 bytes    280,999 bytes   00:44:21.492
15              0:44:21.492     0:01:09.402     35,453 kbps     40,030 kbps     00:44:41.945    38,247 kbps     00:44:37.875    38,000 kbps     00:44:33.037    147,867 bytes   478,570 bytes   00:45:30.894
16              0:45:30.894     0:00:10.510     21,259 kbps     33,569 kbps     00:45:30.894    26,181 kbps     00:45:30.894    22,123 kbps     00:45:30.894    88,667 bytes    495,889 bytes   00:45:31.895
17              0:45:41.405     0:00:55.054     20,162 kbps     27,564 kbps     00:45:47.845    24,414 kbps     00:45:46.643    23,901 kbps     00:45:43.006    84,093 bytes    196,770 bytes   00:45:52.416
18              0:46:36.460     0:00:59.993     34,505 kbps     44,664 kbps     00:46:45.636    37,979 kbps     00:46:50.974    37,501 kbps     00:46:46.103    143,916 bytes   400,568 bytes   00:46:58.515
19              0:47:36.453     0:04:46.686     24,485 kbps     37,194 kbps     00:49:01.938    34,376 kbps     00:48:58.702    32,386 kbps     00:48:54.264    102,121 bytes   268,136 bytes   00:49:02.906
20              0:52:23.140     0:04:18.124     23,393 kbps     31,050 kbps     00:54:47.250    30,009 kbps     00:54:45.348    28,914 kbps     00:54:40.744    97,567 bytes    246,445 bytes   00:53:34.678
21              0:56:41.264     0:04:50.923     23,225 kbps     34,857 kbps     00:57:07.724    29,629 kbps     00:57:07.724    27,730 kbps     00:59:36.506    96,869 bytes    277,572 bytes   00:57:07.757
22              1:01:32.188     0:05:40.039     20,815 kbps     29,646 kbps     01:03:08.584    27,798 kbps     01:07:05.354    25,293 kbps     01:03:01.144    86,815 bytes    246,256 bytes   01:03:15.892
23              1:07:12.228     0:01:09.402     36,659 kbps     41,937 kbps     01:07:56.072    39,051 kbps     01:07:26.342    38,858 kbps     01:08:06.482    152,897 bytes   486,304 bytes   01:08:21.630
24              1:08:21.630     0:00:10.477     25,055 kbps     37,006 kbps     01:08:22.198    28,471 kbps     01:08:21.630    26,025 kbps     01:08:21.630    104,499 bytes   496,906 bytes   01:08:22.631
25              1:08:32.108     0:01:09.969     20,640 kbps     28,456 kbps     01:08:34.844    26,608 kbps     01:08:33.042    24,022 kbps     01:08:33.042    86,087 bytes    204,532 bytes   01:08:35.111
26              1:09:42.077     0:01:00.060     34,325 kbps     43,781 kbps     01:09:51.253    37,875 kbps     01:09:54.890    37,344 kbps     01:09:51.720    143,165 bytes   354,832 bytes   01:10:41.303
27              1:10:42.137     0:05:04.370     25,111 kbps     39,513 kbps     01:10:46.842    36,936 kbps     01:10:44.073    31,803 kbps     01:10:43.872    104,733 bytes   317,658 bytes   01:10:47.843
28              1:15:46.508     0:04:35.642     21,887 kbps     35,919 kbps     01:16:42.230    30,828 kbps     01:16:38.894    27,283 kbps     01:16:33.889    91,287 bytes    280,446 bytes   01:16:43.098
29              1:20:22.150     0:05:40.940     21,063 kbps     29,286 kbps     01:20:42.404    25,042 kbps     01:25:20.181    24,066 kbps     01:20:42.404    87,852 bytes    204,075 bytes   01:24:12.347
30              1:26:03.091     0:03:59.872     23,804 kbps     39,586 kbps     01:28:54.529    38,404 kbps     01:28:51.025    31,786 kbps     01:28:50.725    99,281 bytes    337,568 bytes   01:29:58.326
31              1:30:02.964     0:01:09.402     36,446 kbps     40,939 kbps     01:30:40.368    39,112 kbps     01:30:19.447    38,825 kbps     01:30:14.442    152,012 bytes   494,537 bytes   01:31:12.366
32              1:31:12.366     0:00:10.443     27,449 kbps     37,747 kbps     01:31:12.366    29,841 kbps     01:31:12.366    28,440 kbps     01:31:12.366    114,484 bytes   508,952 bytes   01:31:13.367
33              1:31:22.810     0:00:34.033     20,949 kbps     28,020 kbps     01:31:53.107    25,181 kbps     01:31:51.672    22,875 kbps     01:31:46.834    87,376 bytes    206,562 bytes   01:31:31.452
34              1:31:56.844     0:00:59.993     32,241 kbps     42,793 kbps     01:32:06.020    37,721 kbps     01:32:11.626    37,297 kbps     01:32:06.487    134,470 bytes   352,613 bytes   01:32:06.521
35              1:32:56.837     0:05:27.126     23,461 kbps     38,987 kbps     01:38:11.318    38,484 kbps     01:35:31.992    34,850 kbps     01:32:57.204    97,852 bytes    333,469 bytes   01:35:34.028
36              1:38:23.964     0:03:57.237     24,164 kbps     38,122 kbps     01:38:49.323    31,629 kbps     01:38:46.520    30,079 kbps     01:38:46.320    100,784 bytes   301,547 bytes   01:38:49.556
37              1:42:21.201     0:05:29.929     22,165 kbps     34,124 kbps     01:45:32.893    30,624 kbps     01:47:15.662    30,492 kbps     01:47:10.657    92,446 bytes    302,922 bytes   01:47:10.891
38              1:47:51.131     0:05:02.468     22,876 kbps     32,101 kbps     01:51:30.583    29,280 kbps     01:48:23.830    27,249 kbps     01:48:23.830    95,413 bytes    283,939 bytes   01:48:01.608
39              1:52:53.600     0:01:09.402     34,355 kbps     40,549 kbps     01:53:09.749    38,999 kbps     01:53:09.015    38,215 kbps     01:53:04.844    143,287 bytes   466,134 bytes   01:54:03.002
40              1:54:03.002     0:00:10.510     19,371 kbps     31,200 kbps     01:54:03.002    22,588 kbps     01:54:03.002    20,141 kbps     01:54:03.002    80,795 bytes    483,088 bytes   01:54:04.003
41              1:54:13.513     0:00:29.029     26,123 kbps     33,388 kbps     01:54:19.852    30,912 kbps     01:54:18.451    30,140 kbps     01:54:18.451    108,956 bytes   286,595 bytes   01:54:32.966
42              1:54:42.542     0:00:59.959     35,359 kbps     44,694 kbps     01:54:51.718    38,820 kbps     01:55:26.619    37,915 kbps     01:55:21.948    147,476 bytes   402,327 bytes   01:55:04.597
43              1:55:42.502     0:03:57.003     20,999 kbps     39,817 kbps     01:55:47.073    38,427 kbps     01:55:43.569    32,297 kbps     01:55:42.568    87,582 bytes    350,656 bytes   01:55:46.506
44              1:59:39.505     0:04:54.160     22,834 kbps     34,329 kbps     02:02:12.558    30,820 kbps     02:03:09.014    28,935 kbps     02:03:08.981    95,236 bytes    298,171 bytes   02:02:57.570
45              2:04:33.666     0:04:36.643     24,565 kbps     35,788 kbps     02:05:04.897    32,288 kbps     02:06:19.438    31,619 kbps     02:06:17.369    102,458 bytes   285,445 bytes   02:04:49.648
46              2:09:10.309     0:06:34.026     21,961 kbps     39,177 kbps     02:10:11.803    30,991 kbps     02:10:09.468    28,007 kbps     02:15:11.069    91,597 bytes    285,266 bytes   02:15:12.370
47              2:15:44.336     0:01:09.402     37,212 kbps     41,936 kbps     02:16:35.186    39,000 kbps     02:16:00.285    38,811 kbps     02:16:38.590    155,204 bytes   502,960 bytes   02:16:53.738
48              2:16:53.738     0:00:10.477     26,088 kbps     40,011 kbps     02:17:01.546    29,758 kbps     02:16:58.176    27,107 kbps     02:16:53.738    108,809 bytes   521,773 bytes   02:16:54.739
49              2:17:04.215     0:00:35.034     17,026 kbps     22,346 kbps     02:17:05.417    21,852 kbps     02:17:05.417    21,112 kbps     02:17:05.417    71,013 bytes    251,325 bytes   02:17:09.220
50              2:17:39.250     0:00:59.959     31,751 kbps     42,448 kbps     02:17:57.769    38,802 kbps     02:17:53.765    38,031 kbps     02:17:50.462    132,427 bytes   375,786 bytes   02:17:48.927
51              2:18:39.210     0:03:21.201     16,156 kbps     28,129 kbps     02:20:47.672    24,456 kbps     02:20:44.836    20,761 kbps     02:20:44.102    67,382 bytes    247,584 bytes   02:20:15.540
52              2:22:00.411     0:04:56.429     16,446 kbps     22,457 kbps     02:26:30.181    20,628 kbps     02:26:28.246    19,705 kbps     02:25:03.728    68,592 bytes    249,928 bytes   02:23:35.606
53              2:26:56.841     0:05:21.654     15,562 kbps     24,697 kbps     02:28:52.323    23,645 kbps     02:28:48.286    20,385 kbps     02:28:45.816    64,906 bytes    246,794 bytes   02:28:51.555
54              2:32:18.496     0:06:16.576     17,326 kbps     29,930 kbps     02:38:23.994    25,716 kbps     02:38:22.726    23,470 kbps     02:34:50.648    72,263 bytes    264,146 bytes   02:34:27.524
55              2:38:35.072     0:01:09.402     33,469 kbps     41,249 kbps     02:38:49.786    39,924 kbps     02:38:50.220    38,855 kbps     02:38:46.016    139,592 bytes   443,302 bytes   02:39:44.474
56              2:39:44.474     0:00:10.443     17,540 kbps     27,615 kbps     02:39:44.474    22,491 kbps     02:39:44.474    18,101 kbps     02:39:44.474    73,155 bytes    455,893 bytes   02:39:45.475
57              2:39:54.918     0:00:24.023     21,657 kbps     28,683 kbps     02:40:17.207    25,520 kbps     02:39:55.819    23,309 kbps     02:39:55.852    90,328 bytes    264,232 bytes   02:39:57.821
58              2:40:18.942     0:00:59.959     33,517 kbps     42,706 kbps     02:40:28.118    36,717 kbps     02:40:31.755    36,404 kbps     02:40:28.585    139,792 bytes   352,613 bytes   02:40:28.618
59              2:41:18.902     0:03:37.417     25,084 kbps     39,250 kbps     02:41:19.102    38,226 kbps     02:41:19.169    31,488 kbps     02:41:18.902    104,622 bytes   288,734 bytes   02:41:34.217
60              2:44:56.319     0:04:54.193     22,933 kbps     31,866 kbps     02:49:09.539    30,486 kbps     02:49:30.660    30,307 kbps     02:49:26.022    95,648 bytes    281,224 bytes   02:46:19.469
61              2:49:50.513     0:05:56.289     23,000 kbps     32,213 kbps     02:52:57.400    28,625 kbps     02:52:41.651    27,165 kbps     02:52:38.648    95,929 bytes    264,399 bytes   02:50:15.038
62              2:55:46.802     0:05:38.971     21,331 kbps     29,804 kbps     02:57:52.395    26,956 kbps     02:57:10.252    24,733 kbps     02:57:05.247    88,968 bytes    303,606 bytes   03:01:25.774
63              3:01:25.774     0:01:09.402     35,939 kbps     40,394 kbps     03:02:12.521    38,169 kbps     03:01:42.157    37,987 kbps     03:01:37.386    149,895 bytes   487,842 bytes   03:02:35.177
64              3:02:35.177     0:00:10.443     20,720 kbps     34,751 kbps     03:02:35.177    26,142 kbps     03:02:35.177    21,420 kbps     03:02:35.177    86,421 bytes    504,596 bytes   03:02:36.178
65              3:02:45.621     0:01:31.024     22,833 kbps     31,366 kbps     03:02:58.100    29,875 kbps     03:02:54.196    27,180 kbps     03:02:49.391    95,231 bytes    260,084 bytes   03:04:10.706
66              3:04:16.645     0:00:59.959     34,243 kbps     43,706 kbps     03:04:25.821    37,757 kbps     03:04:29.458    37,414 kbps     03:04:26.288    142,822 bytes   357,344 bytes   03:04:26.321
67              3:05:16.605     0:03:11.457     22,846 kbps     39,564 kbps     03:05:20.542    36,554 kbps     03:05:18.373    30,746 kbps     03:05:16.972    95,285 bytes    347,357 bytes   03:05:21.777
68              3:08:28.063     0:05:20.153     19,974 kbps     30,687 kbps     03:10:59.848    28,803 kbps     03:10:55.944    28,307 kbps     03:10:51.173    83,308 bytes    306,293 bytes   03:11:17.599
69              3:13:48.216     0:06:06.032     23,976 kbps     38,025 kbps     03:19:43.237    36,222 kbps     03:16:59.974    34,200 kbps     03:16:59.941    99,999 bytes    228,331 bytes   03:18:57.925
70              3:19:54.248     0:04:22.195     24,446 kbps     36,949 kbps     03:21:11.192    35,741 kbps     03:21:10.024    33,092 kbps     03:21:04.786    101,961 bytes   313,245 bytes   03:21:53.734
71              3:24:16.444     0:01:09.402     36,740 kbps     41,416 kbps     03:25:00.321    39,060 kbps     03:25:11.265    38,866 kbps     03:24:45.039    153,235 bytes   489,386 bytes   03:25:25.846
72              3:25:25.846     0:00:10.477     21,295 kbps     35,093 kbps     03:25:25.846    25,571 kbps     03:25:25.846    21,610 kbps     03:25:25.846    88,818 bytes    601,937 bytes   03:25:36.323
73              3:25:36.323     0:00:10.510     16,719 kbps     18,271 kbps     03:25:36.323    18,059 kbps     03:25:36.323    17,522 kbps     03:25:36.323    69,956 bytes    639,118 bytes   03:25:39.326
STREAM DIAGNOSTICS:
00041.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,993                  4,110,581,286   22,364,151
00041.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                4,113                   704,686,886     4,903,287
00041.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00041.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1370.569                640                     109,657,600     642,525
00041.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                32                      5,554,677       32,422
00041.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       425,537         2,444
00042.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,977                  4,107,746,173   22,348,599
00042.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                3,971                   680,289,520     4,598,498
00042.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00042.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                29                      4,895,440       28,576
00042.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       374,684         2,166
00051.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,989                  4,109,891,271   22,360,317
00051.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                3,965                   679,282,892     4,586,644
00051.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00051.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                35                      5,998,979       34,795
00051.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       425,537         2,444
00052.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,997                  4,111,139,313   22,367,108
00052.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                4,068                   696,937,176     4,802,414
00052.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00052.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                28                      4,833,191       28,409
00052.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       374,684         2,166
00053.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,986                  4,109,328,051   22,357,266
00053.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                4,050                   693,806,808     4,762,876
00053.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00053.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                35                      5,951,820       34,478
00053.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       425,537         2,444
00054.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,988                  4,109,643,555   22,359,002
00054.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                3,992                   683,977,534     4,759,833
00054.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00054.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                34                      5,767,969       33,587
00054.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       374,684         2,166
00055.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                17,994                  3,082,720,321   16,777,790
00055.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                3,921                   671,825,610     4,595,390
00055.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00055.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                41                      6,954,216       40,256
00055.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       425,537         2,444
00056.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,980                  4,108,277,673   22,351,527
00056.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                3,977                   681,315,454     4,665,954
00056.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00056.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1370.569                640                     109,657,600     642,525
00056.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                22                      3,811,487       22,338
00056.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       374,684         2,166
00057.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,971                  4,106,746,828   22,343,155
00057.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                4,042                   692,398,982     4,775,376
00057.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1370.569                640                     109,657,600     642,525
00057.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                33                      5,594,455       32,419
00057.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       425,537         2,444
00040.M2TS      4113 (0x1011)   0x1B            AVC                                     10.377                  17,398                  22,567,975      122,870
00040.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           10.377                  951                     1,233,324       17,548
00040.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          10.377                  649                     842,240         4,935
00040.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           10.377                  0                       70              7
00040.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           10.377                  0                       70              7
Stephen Dawson
hifi-writer.com
post #1357 of 5099 Old 03-10-2010, 07:52 PM
themike5000's Avatar
Code:
        Total   Video
00009.MPLS                                                      AVC     2:06:13 29,983,082,496  46,045,751,129  31.67   21.84   DTS-HD Master 5.1 3924Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      46,045,751,129 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:06:13 (h:m:s)
Total Bitrate:          31.67 Mbps
VIDEO:
MPEG-4 AVC Video        21845 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3924 kbps       5.1 / 48 kHz / 3924 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          4003 kbps       5.1 / 48 kHz / 4003 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           French          24.280 kbps
Presentation Graphics           French          22.803 kbps
Presentation Graphics           French          0.505 kbps
Presentation Graphics           French          0.000 kbps
FILES:
00007.M2TS      0:00:00.000     2:06:13.524     29,983,082,496  31,671
CHAPTERS:
1               0:00:00.000     0:04:23.221     21,996 kbps     32,887 kbps     00:03:35.506    30,021 kbps     00:00:51.926    29,180 kbps     00:00:47.672    114,659 bytes   497,554 bytes   00:03:45.016
2               0:04:23.221     0:04:51.833     23,445 kbps     33,426 kbps     00:08:47.360    31,538 kbps     00:08:47.151    30,851 kbps     00:08:46.609    122,234 bytes   531,189 bytes   00:07:29.198
3               0:09:15.054     0:03:17.739     22,914 kbps     32,852 kbps     00:09:41.581    29,661 kbps     00:10:39.597    28,432 kbps     00:10:37.511    119,465 bytes   393,681 bytes   00:09:43.291
4               0:12:32.793     0:01:51.569     21,250 kbps     33,026 kbps     00:12:35.129    27,984 kbps     00:12:34.044    26,154 kbps     00:12:34.170    110,786 bytes   418,290 bytes   00:14:24.363
5               0:14:24.363     0:02:07.293     26,765 kbps     34,135 kbps     00:15:29.845    29,782 kbps     00:15:01.650    29,629 kbps     00:15:01.650    139,538 bytes   476,965 bytes   00:14:59.440
6               0:16:31.657     0:02:49.252     18,078 kbps     30,039 kbps     00:16:33.701    25,747 kbps     00:16:32.241    22,659 kbps     00:16:32.324    94,250 bytes    460,839 bytes   00:16:44.586
7               0:19:20.909     0:03:58.237     20,485 kbps     33,114 kbps     00:22:01.236    30,125 kbps     00:21:57.733    28,666 kbps     00:21:56.398    106,800 bytes   557,288 bytes   00:23:18.605
8               0:23:19.147     0:02:50.837     18,885 kbps     31,724 kbps     00:25:18.266    27,815 kbps     00:23:20.315    25,020 kbps     00:23:19.940    98,457 bytes    330,613 bytes   00:25:25.941
9               0:26:09.985     0:02:15.760     21,013 kbps     33,026 kbps     00:28:05.183    29,932 kbps     00:26:44.144    29,295 kbps     00:26:39.139    109,554 bytes   532,248 bytes   00:26:56.823
10              0:28:25.745     0:03:16.362     17,660 kbps     28,381 kbps     00:29:50.955    25,186 kbps     00:29:46.951    22,043 kbps     00:30:10.266    92,072 bytes    364,390 bytes   00:28:44.764
11              0:31:42.108     0:09:18.724     21,177 kbps     33,718 kbps     00:38:43.154    31,316 kbps     00:38:43.321    30,583 kbps     00:40:37.184    110,409 bytes   599,562 bytes   00:39:12.892
12              0:41:00.833     0:05:36.586     25,965 kbps     33,188 kbps     00:42:44.144    30,475 kbps     00:41:51.008    29,788 kbps     00:41:49.798    135,368 bytes   532,071 bytes   00:43:59.470
13              0:46:37.419     0:02:45.540     27,001 kbps     32,538 kbps     00:47:37.354    30,722 kbps     00:47:40.816    30,066 kbps     00:47:37.354    140,773 bytes   423,224 bytes   00:48:42.961
14              0:49:22.960     0:03:22.535     28,129 kbps     32,586 kbps     00:49:39.142    30,053 kbps     00:51:06.605    29,678 kbps     00:51:02.851    146,652 bytes   398,788 bytes   00:51:12.861
15              0:52:45.495     0:03:35.673     25,714 kbps     32,094 kbps     00:55:16.146    29,349 kbps     00:55:33.413    28,737 kbps     00:53:45.764    134,060 bytes   430,517 bytes   00:54:20.924
16              0:56:21.169     0:04:57.922     25,696 kbps     32,888 kbps     01:00:29.042    29,904 kbps     00:56:55.912    28,684 kbps     00:56:50.740    133,966 bytes   408,435 bytes   01:00:13.109
17              1:01:19.092     0:03:42.972     20,954 kbps     32,609 kbps     01:02:10.268    28,250 kbps     01:02:10.560    27,102 kbps     01:02:05.555    109,247 bytes   530,107 bytes   01:02:24.282
18              1:05:02.064     0:02:37.365     23,016 kbps     33,305 kbps     01:05:29.091    30,032 kbps     01:05:18.539    28,659 kbps     01:06:24.814    119,994 bytes   406,028 bytes   01:07:19.201
19              1:07:39.430     0:07:31.451     24,233 kbps     33,538 kbps     01:12:46.904    30,047 kbps     01:12:48.572    29,121 kbps     01:12:44.902    126,341 bytes   467,032 bytes   01:13:38.872
20              1:15:10.881     0:04:22.053     23,475 kbps     33,906 kbps     01:17:29.811    30,132 kbps     01:17:26.767    28,417 kbps     01:17:09.166    122,388 bytes   412,637 bytes   01:17:22.137
21              1:19:32.934     0:06:13.206     22,362 kbps     33,026 kbps     01:19:38.315    28,189 kbps     01:21:01.898    26,321 kbps     01:22:26.650    116,585 bytes   418,326 bytes   01:24:47.582
22              1:25:46.141     0:02:51.462     18,665 kbps     32,525 kbps     01:25:59.654    27,975 kbps     01:25:56.025    23,233 kbps     01:26:13.251    97,312 bytes    363,110 bytes   01:25:46.891
23              1:28:37.603     0:06:29.514     23,369 kbps     33,441 kbps     01:29:42.877    30,172 kbps     01:30:42.770    29,478 kbps     01:33:22.805    121,833 bytes   535,486 bytes   01:31:56.093
24              1:35:07.118     0:05:52.060     23,598 kbps     32,496 kbps     01:39:16.575    29,705 kbps     01:37:30.135    29,575 kbps     01:37:24.213    123,029 bytes   390,954 bytes   01:39:17.534
25              1:40:59.178     0:08:08.196     20,844 kbps     32,971 kbps     01:46:34.304    27,414 kbps     01:47:11.967    26,482 kbps     01:41:40.636    108,670 bytes   383,557 bytes   01:44:00.692
26              1:49:07.374     0:04:31.104     21,630 kbps     33,143 kbps     01:52:18.857    27,931 kbps     01:51:45.281    26,129 kbps     01:51:44.072    112,769 bytes   558,775 bytes   01:50:46.056
27              1:53:38.478     0:03:48.311     22,652 kbps     31,565 kbps     01:57:25.455    28,829 kbps     01:55:05.815    28,228 kbps     01:55:05.440    118,097 bytes   621,326 bytes   01:57:25.663
28              1:57:26.789     0:08:46.734     10,480 kbps     31,637 kbps     02:05:21.680    20,958 kbps     02:05:36.904    20,590 kbps     02:05:31.899    54,645 bytes    329,243 bytes   02:05:47.665
STREAM DIAGNOSTICS:
00007.M2TS      4113 (0x1011)   0x1B            AVC                                     7573.441                21,845                  20,680,230,961  112,498,755
00007.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            7573.441                4,003                   3,789,505,636   21,777,012
00007.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           7573.441                3,924                   3,714,862,160   21,368,823
00007.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            7573.441                24                      22,985,986      134,101
00007.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7573.441                23                      21,587,513      126,558
00007.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7573.441                1                       478,145         2,872
00007.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            7573.441                0                       70              7
There are some good comparisons across four different versions (transfers) of this movie available at http://www.hd-compare.com/2009/07/iron-man.html
themike5000 is offline
post #1358 of 5099 Old 03-11-2010, 07:29 PM
'Claymore' (Kureimoa) - 2007 - Australian version - Disc 2 of 3
Episodes 10-18
The read failed at Episode 15, apparently due to a flaw of some sort in the disc. BDInfo resumed at the next episode, so the following is slightly inaccurate, missing about 17 minutes in total. However it is close enough to stand until someone else can rescan it (this is the 'Funimation' disc, which is presumably made available in the US as well.
Code:
        Total   Video
00001.MPLS                                                      AVC     3:25:57 44,486,750,400  49,123,975,930  28.80   23.99   Dolby TrueHD 5.1 3463Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CLAYMORE_D2
Disc Size:      49,123,975,930 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 3:25:57 (h:m:s)
Total Bitrate:          28.80 Mbps
VIDEO:
MPEG-4 AVC Video        23991 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3463 kbps       5.1 / 48 kHz / 3463 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -4dB)
* Dolby Digital Audio           English         640 kbps        2.0 / 48 kHz / 640 kbps / DN -2dB
SUBTITLES:
Presentation Graphics           English         34.055 kbps
Presentation Graphics           English         2.349 kbps
FILES:
00041.M2TS      0:00:00.000     0:22:50.702     5,382,580,224   31,415
00042.M2TS      0:22:50.702     0:22:52.037     5,521,256,448   32,193
00051.M2TS      0:45:42.739     0:22:52.037     5,363,791,872   31,275
00052.M2TS      1:08:34.777     0:22:52.037     5,348,923,392   31,188
00053.M2TS      1:31:26.814     0:22:52.037     5,367,558,144   31,297
00054.M2TS      1:54:18.852     0:22:52.037     1,231,208,640   31,896
00055.M2TS      2:17:10.889     0:22:52.037     5,498,068,992   32,058
00056.M2TS      2:40:02.926     0:22:52.037     5,390,155,776   31,429
00057.M2TS      3:02:54.964     0:22:52.037     5,355,220,992   31,225
00040.M2TS      3:25:47.001     0:00:10.510     27,985,920      21,301
CHAPTERS:
1               0:00:00.000     0:01:16.009     22,044 kbps     29,148 kbps     00:01:11.237    26,090 kbps     00:01:08.001    23,913 kbps     00:00:50.116    91,901 bytes    282,100 bytes   00:01:10.270
2               0:01:16.009     0:00:59.959     35,410 kbps     44,626 kbps     00:01:25.185    38,841 kbps     00:02:00.086    37,952 kbps     00:01:55.415    147,687 bytes   402,850 bytes   00:01:38.064
3               0:02:15.969     0:04:40.013     22,579 kbps     40,157 kbps     00:02:19.339    37,002 kbps     00:02:15.969    30,533 kbps     00:02:16.035    94,172 bytes    348,953 bytes   00:02:17.971
4               0:06:55.982     0:03:36.583     22,502 kbps     30,933 kbps     00:08:57.570    28,501 kbps     00:07:09.262    27,602 kbps     00:07:04.524    93,852 bytes    288,569 bytes   00:08:26.806
5               0:10:32.565     0:05:37.537     22,455 kbps     33,377 kbps     00:12:27.913    27,786 kbps     00:12:25.911    27,286 kbps     00:13:57.436    93,657 bytes    289,090 bytes   00:14:04.476
6               0:16:10.102     0:05:20.720     23,146 kbps     37,579 kbps     00:17:28.447    36,344 kbps     00:17:26.945    30,827 kbps     00:17:26.945    96,536 bytes    279,681 bytes   00:21:27.185
7               0:21:30.822     0:01:09.402     37,293 kbps     41,543 kbps     00:22:26.912    39,038 kbps     00:21:42.634    38,809 kbps     00:21:59.351    155,542 bytes   504,656 bytes   00:22:40.225
8               0:22:40.225     0:00:10.477     26,919 kbps     38,603 kbps     00:22:40.225    29,650 kbps     00:22:40.225    27,977 kbps     00:22:40.225    112,276 bytes   520,432 bytes   00:22:41.226
9               0:22:50.702     0:00:47.047     19,756 kbps     27,673 kbps     00:22:57.876    22,334 kbps     00:23:11.890    21,476 kbps     00:23:11.890    82,398 bytes    214,327 bytes   00:23:31.009
10              0:23:37.749     0:00:59.993     34,507 kbps     44,769 kbps     00:23:46.925    37,978 kbps     00:23:52.264    37,494 kbps     00:23:47.392    143,921 bytes   400,804 bytes   00:23:59.805
11              0:24:37.742     0:04:17.590     22,607 kbps     40,080 kbps     00:24:42.280    38,298 kbps     00:24:38.677    31,784 kbps     00:24:38.009    94,291 bytes    413,057 bytes   00:24:41.746
12              0:28:55.333     0:05:41.207     22,253 kbps     33,872 kbps     00:31:16.975    30,771 kbps     00:31:13.504    28,343 kbps     00:31:12.804    92,813 bytes    288,189 bytes   00:31:38.396
13              0:34:36.541     0:04:55.595     23,510 kbps     33,402 kbps     00:36:58.182    30,250 kbps     00:35:47.812    29,974 kbps     00:35:46.110    98,055 bytes    272,675 bytes   00:35:30.695
14              0:39:32.136     0:04:50.390     23,170 kbps     31,851 kbps     00:41:59.116    28,903 kbps     00:39:39.744    28,158 kbps     00:40:04.402    96,639 bytes    284,170 bytes   00:41:35.726
15              0:44:22.526     0:01:09.402     36,851 kbps     41,587 kbps     00:45:13.410    39,193 kbps     00:45:21.785    38,985 kbps     00:45:16.780    153,700 bytes   474,792 bytes   00:45:31.929
16              0:45:31.929     0:00:10.810     24,114 kbps     38,620 kbps     00:45:31.929    29,168 kbps     00:45:31.929    25,844 kbps     00:45:31.929    100,577 bytes   490,762 bytes   00:45:32.930
17              0:45:42.739     0:01:53.046     21,719 kbps     33,909 kbps     00:46:07.297    31,767 kbps     00:46:04.094    27,579 kbps     00:46:00.224    90,585 bytes    313,914 bytes   00:46:08.866
18              0:47:35.786     0:00:59.993     34,854 kbps     43,733 kbps     00:47:44.962    37,760 kbps     00:48:26.470    37,392 kbps     00:47:45.429    145,372 bytes   362,798 bytes   00:48:34.978
19              0:48:35.779     0:03:47.660     24,520 kbps     40,252 kbps     00:48:40.884    39,137 kbps     00:48:38.649    38,613 kbps     00:48:37.381    102,267 bytes   340,908 bytes   00:48:37.781
20              0:52:23.440     0:03:31.644     23,089 kbps     31,219 kbps     00:53:30.840    29,934 kbps     00:53:27.070    28,701 kbps     00:54:20.857    96,300 bytes    298,873 bytes   00:54:20.890
21              0:55:55.085     0:04:55.595     22,557 kbps     33,047 kbps     00:58:08.017    29,977 kbps     00:58:07.917    28,617 kbps     00:58:07.951    94,083 bytes    288,287 bytes   00:56:24.647
22              1:00:50.680     0:06:23.716     21,971 kbps     34,614 kbps     01:01:46.135    29,532 kbps     01:02:34.684    29,059 kbps     01:02:33.149    91,639 bytes    293,720 bytes   01:07:05.621
23              1:07:14.397     0:01:09.402     37,046 kbps     40,995 kbps     01:07:50.900    39,244 kbps     01:07:30.780    38,964 kbps     01:07:25.875    154,514 bytes   477,615 bytes   01:08:23.799
24              1:08:23.799     0:00:10.977     20,947 kbps     38,931 kbps     01:08:23.799    30,956 kbps     01:08:23.799    22,771 kbps     01:08:23.799    87,365 bytes    495,016 bytes   01:08:24.800
25              1:08:34.777     0:00:35.034     22,108 kbps     28,696 kbps     01:08:39.415    26,827 kbps     01:08:38.280    25,510 kbps     01:08:39.315    92,208 bytes    225,503 bytes   01:09:01.570
26              1:09:09.812     0:00:59.993     35,279 kbps     44,713 kbps     01:09:18.988    38,644 kbps     01:09:53.889    37,800 kbps     01:09:49.218    147,143 bytes   402,850 bytes   01:09:31.867
27              1:10:09.805     0:03:55.802     25,733 kbps     39,313 kbps     01:10:11.840    35,437 kbps     01:10:11.407    31,534 kbps     01:10:45.908    107,330 bytes   344,590 bytes   01:10:14.810
28              1:14:05.607     0:05:33.800     21,837 kbps     32,065 kbps     01:14:37.940    27,253 kbps     01:14:13.782    25,602 kbps     01:14:12.381    91,078 bytes    302,115 bytes   01:15:23.051
29              1:19:39.407     0:04:15.054     21,953 kbps     32,088 kbps     01:22:43.658    28,855 kbps     01:22:39.654    27,259 kbps     01:22:35.550    91,563 bytes    247,881 bytes   01:22:30.178
30              1:23:54.462     0:06:11.938     22,211 kbps     33,280 kbps     01:28:27.735    30,744 kbps     01:28:02.477    28,638 kbps     01:27:57.538    92,637 bytes    311,105 bytes   01:27:25.907
31              1:30:06.401     0:01:09.402     37,220 kbps     42,277 kbps     01:31:13.401    39,124 kbps     01:30:22.550    38,947 kbps     01:30:22.550    155,240 bytes   504,165 bytes   01:31:15.803
32              1:31:15.803     0:00:11.011     18,593 kbps     38,405 kbps     01:31:15.803    27,537 kbps     01:31:15.803    20,252 kbps     01:31:15.803    77,549 bytes    520,361 bytes   01:31:16.804
33              1:31:26.814     0:00:59.059     21,485 kbps     27,481 kbps     01:31:35.790    26,267 kbps     01:31:35.790    25,433 kbps     01:31:34.155    89,609 bytes    214,534 bytes   01:31:49.237
34              1:32:25.873     0:00:59.993     35,568 kbps     44,642 kbps     01:32:35.049    38,917 kbps     01:33:09.951    38,315 kbps     01:33:05.413    148,347 bytes   402,850 bytes   01:32:47.929
35              1:33:25.866     0:03:30.777     23,295 kbps     34,967 kbps     01:33:29.737    28,115 kbps     01:35:53.147    26,657 kbps     01:34:36.671    97,161 bytes    311,671 bytes   01:33:29.870
36              1:36:56.644     0:04:53.760     23,938 kbps     33,584 kbps     01:38:55.162    31,449 kbps     01:38:52.159    28,604 kbps     01:39:15.015    99,842 bytes    300,668 bytes   01:38:20.661
37              1:41:50.404     0:06:25.651     20,954 kbps     27,943 kbps     01:43:19.726    24,819 kbps     01:43:48.622    23,950 kbps     01:43:34.675    87,397 bytes    206,595 bytes   01:42:21.368
38              1:48:16.056     0:04:42.482     23,240 kbps     33,914 kbps     01:51:05.992    28,247 kbps     01:52:33.079    26,973 kbps     01:51:22.642    96,930 bytes    242,260 bytes   01:52:58.538
39              1:52:58.538     0:01:09.402     37,492 kbps     41,407 kbps     01:53:49.422    39,219 kbps     01:53:53.326    38,989 kbps     01:53:53.193    156,372 bytes   472,718 bytes   01:54:07.941
40              1:54:07.941     0:00:10.910     27,729 kbps     39,762 kbps     01:54:16.416    30,870 kbps     01:54:12.812    30,025 kbps     01:54:07.941    115,654 bytes   492,702 bytes   01:54:08.942
41              1:54:18.852     0:02:02.989     18,704 kbps     28,166 kbps     01:54:20.920    24,269 kbps     01:54:20.787    21,520 kbps     01:54:20.587    78,009 bytes    187,726 bytes   01:56:19.839
42              1:56:21.841     0:00:59.993     35,232 kbps     44,658 kbps     01:56:31.017    38,588 kbps     01:57:05.918    37,613 kbps     01:57:01.247    146,947 bytes   402,850 bytes   01:56:43.896
43              1:57:21.834     0:04:18.224     12,362 kbps     40,628 kbps     01:57:26.806    38,262 kbps     01:57:22.802    33,089 kbps     01:57:21.868    105,816 bytes   370,592 bytes   01:57:25.838
44              2:01:40.059     0:04:41.781     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
45              2:06:21.840     0:05:02.969     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
46              2:11:24.810     0:04:25.665     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
47              2:15:50.475     0:01:09.402     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
48              2:16:59.878     0:00:11.011     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
49              2:17:10.889     0:01:31.024     22,533 kbps     29,133 kbps     02:17:56.067    26,646 kbps     02:17:13.925    25,729 kbps     02:17:12.624    93,981 bytes    249,389 bytes   02:17:18.129
50              2:18:41.913     0:00:59.993     35,650 kbps     44,723 kbps     02:18:51.089    38,876 kbps     02:19:25.990    38,480 kbps     02:19:21.319    148,691 bytes   402,327 bytes   02:19:03.968
51              2:19:41.906     0:04:13.486     22,233 kbps     29,944 kbps     02:19:42.440    27,309 kbps     02:20:44.335    25,480 kbps     02:20:39.330    92,730 bytes    244,061 bytes   02:19:42.907
52              2:23:55.393     0:03:48.528     23,244 kbps     34,889 kbps     02:26:40.358    27,830 kbps     02:26:55.606    26,360 kbps     02:24:43.841    96,947 bytes    252,830 bytes   02:25:26.617
53              2:27:43.921     0:05:36.436     22,593 kbps     35,144 kbps     02:29:57.822    31,537 kbps     02:29:55.920    28,809 kbps     02:29:50.781    94,231 bytes    265,714 bytes   02:31:05.423
54              2:33:20.357     0:05:22.155     22,566 kbps     30,985 kbps     02:37:12.856    27,713 kbps     02:35:40.564    26,483 kbps     02:35:39.530    94,119 bytes    270,592 bytes   02:35:39.563
55              2:38:42.513     0:01:09.402     37,262 kbps     41,891 kbps     02:39:49.513    39,143 kbps     02:38:58.996    38,945 kbps     02:38:53.991    155,414 bytes   510,320 bytes   02:39:51.915
56              2:39:51.915     0:00:11.011     26,374 kbps     38,851 kbps     02:39:51.915    32,781 kbps     02:39:51.915    28,811 kbps     02:39:51.915    110,003 bytes   526,849 bytes   02:39:52.916
57              2:40:02.926     0:03:38.017     23,951 kbps     39,207 kbps     02:43:36.506    34,544 kbps     02:43:33.570    31,379 kbps     02:42:57.033    99,897 bytes    289,418 bytes   02:42:14.391
58              2:43:40.944     0:00:59.993     35,490 kbps     44,731 kbps     02:43:50.120    38,916 kbps     02:44:25.021    38,134 kbps     02:44:20.350    148,021 bytes   404,046 bytes   02:44:02.999
59              2:44:40.937     0:03:23.503     21,806 kbps     30,968 kbps     02:44:43.139    29,424 kbps     02:44:42.372    25,710 kbps     02:44:40.937    90,948 bytes    246,082 bytes   02:44:44.941
60              2:48:04.441     0:04:45.318     21,610 kbps     32,304 kbps     02:48:17.454    27,723 kbps     02:48:14.017    25,378 kbps     02:48:10.113    90,131 bytes    239,587 bytes   02:51:54.671
61              2:52:49.759     0:03:54.067     22,630 kbps     38,500 kbps     02:55:55.378    28,800 kbps     02:53:34.370    26,737 kbps     02:53:01.571    94,385 bytes    229,776 bytes   02:56:25.308
62              2:56:43.826     0:04:50.890     23,457 kbps     39,587 kbps     03:01:31.380    38,880 kbps     02:58:10.513    36,988 kbps     02:58:07.309    97,837 bytes    291,420 bytes   03:00:14.436
63              3:01:34.717     0:01:09.402     37,372 kbps     41,617 kbps     03:02:21.530    39,056 kbps     03:02:01.977    38,879 kbps     03:02:28.971    155,874 bytes   512,045 bytes   03:02:44.119
64              3:02:44.119     0:00:10.844     22,009 kbps     38,731 kbps     03:02:44.119    31,055 kbps     03:02:44.119    23,644 kbps     03:02:44.119    91,798 bytes    532,509 bytes   03:02:45.120
65              3:02:54.964     0:00:34.033     30,688 kbps     39,087 kbps     03:03:22.057    37,890 kbps     03:03:22.057    34,514 kbps     03:03:18.954    127,995 bytes   193,498 bytes   03:03:23.659
66              3:03:28.998     0:00:59.993     35,196 kbps     44,647 kbps     03:03:38.173    38,482 kbps     03:04:13.075    37,642 kbps     03:04:08.404    146,797 bytes   400,804 bytes   03:03:51.053
67              3:04:28.991     0:04:17.991     21,086 kbps     40,762 kbps     03:04:32.961    35,365 kbps     03:04:29.558    28,463 kbps     03:04:29.058    87,944 bytes    346,277 bytes   03:04:33.729
68              3:08:46.982     0:04:41.814     21,992 kbps     28,585 kbps     03:08:57.159    27,626 kbps     03:08:56.425    25,430 kbps     03:08:56.425    91,725 bytes    241,845 bytes   03:12:22.497
69              3:13:28.797     0:05:02.669     22,294 kbps     30,356 kbps     03:16:34.182    26,880 kbps     03:14:53.615    26,552 kbps     03:14:48.610    92,986 bytes    270,751 bytes   03:14:55.617
70              3:18:31.466     0:05:55.154     24,039 kbps     33,187 kbps     03:24:08.536    31,808 kbps     03:24:05.633    29,796 kbps     03:24:00.428    100,264 bytes   288,061 bytes   03:24:23.117
71              3:24:26.621     0:01:09.402     37,219 kbps     41,768 kbps     03:25:10.464    39,351 kbps     03:24:42.770    39,027 kbps     03:24:38.165    155,236 bytes   500,893 bytes   03:25:36.023
72              3:25:36.023     0:00:10.977     21,578 kbps     36,982 kbps     03:25:36.023    27,168 kbps     03:25:36.023    22,983 kbps     03:25:36.023    89,997 bytes    601,937 bytes   03:25:47.001
73              3:25:47.001     0:00:10.510     16,719 kbps     18,271 kbps     03:25:47.001    18,059 kbps     03:25:47.001    17,522 kbps     03:25:47.001    69,956 bytes    639,118 bytes   03:25:50.004
STREAM DIAGNOSTICS:
00041.M2TS      4113 (0x1011)   0x1B            AVC                                     1370.569                23,981                  4,108,446,161   22,352,450
00041.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1370.569                4,149                   710,794,102     4,960,691
00041.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1370.569                31                      5,249,868       30,498
00041.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1370.569                2                       374,684         2,166
00042.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,990                  4,113,993,332   22,382,605
00042.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,161                   713,632,142     4,998,757
00042.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00042.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1371.904                640                     109,765,120     643,155
00042.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                41                      6,986,058       40,438
00042.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00051.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,992                  4,114,337,430   22,384,522
00051.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,063                   696,818,308     4,828,771
00051.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00051.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                32                      5,435,528       31,802
00051.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00052.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,979                  4,112,050,208   22,372,045
00052.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                3,992                   684,554,850     4,761,988
00052.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00052.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                34                      5,756,606       33,356
00052.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00053.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,978                  4,111,931,712   22,371,447
00053.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,103                   703,555,598     4,860,520
00053.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00053.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                33                      5,654,675       32,770
00053.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00054.M2TS      4113 (0x1011)   0x1B            AVC                                     308.775                 24,634                  950,784,365     5,172,694
00054.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           308.775                 4,004                   154,556,193     1,076,533
00054.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          308.775                 639                     24,649,319      144,429
00054.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           308.775                 34                      1,311,449       7,610
00054.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           308.775                 4                       166,377         962
00055.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,970                  4,110,594,062   22,364,143
00055.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,135                   709,077,636     4,900,350
00055.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00055.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1371.904                640                     109,765,120     643,155
00055.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                37                      6,332,314       36,793
00055.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00056.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,986                  4,113,378,178   22,379,321
00056.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,220                   723,614,290     4,975,386
00056.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00056.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                27                      4,705,310       27,417
00056.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00057.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,977                  4,111,774,900   22,370,522
00057.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,052                   694,833,272     4,791,392
00057.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00057.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                39                      6,646,630       38,565
00057.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
Stephen Dawson
hifi-writer.com
post #1359 of 5099 Old 03-11-2010, 08:55 PM
Stephen Dawson's Avatar
'Claymore' (Kureimoa) - 2007 - Australian version - Disc 3 of 3
Episodes 19-26
There are also playlists for the eight individual episodes on this disc, but these are not used. The disc instead hooks into the main 'Play All' playlist, shown here, when an individual episode is selected from the Scene Selections style menu. When the end of the episode is reached, the disc just plays on to the next episode.
Code:
        Total   Video
00001.MPLS                                                      AVC     3:02:56 43,081,414,656  48,705,139,434  31.40   23.98   Dolby TrueHD 5.1 3407Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     CLAYMORE_D3
Disc Size:      48,705,139,434 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 3:02:56 (h:m:s)
Total Bitrate:          31.40 Mbps
VIDEO:
MPEG-4 AVC Video        23981 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3407 kbps       5.1 / 48 kHz / 3407 kbps / 24-bit (AC3 Embedded: 5.1 / 48 kHz / 640 kbps / DN -6dB)
Dolby Digital Audio             Japanese        640 kbps        2.0 / 48 kHz / 640 kbps / DN -3dB
SUBTITLES:
Presentation Graphics           English         23.857 kbps
Presentation Graphics           English         2.333 kbps
FILES:
00041.M2TS      0:00:00.000     0:22:52.037     5,521,274,880   32,193
00042.M2TS      0:22:52.037     0:22:52.037     5,341,132,800   31,143
00051.M2TS      0:45:44.074     0:22:52.037     5,390,481,408   31,431
00052.M2TS      1:08:36.112     0:22:52.037     5,302,179,840   30,916
00053.M2TS      1:31:28.149     0:22:52.037     5,357,334,528   31,237
00054.M2TS      1:54:20.186     0:22:52.037     5,369,886,720   31,310
00055.M2TS      2:17:12.224     0:22:52.037     5,327,536,128   31,064
00056.M2TS      2:40:04.261     0:22:42.027     5,443,602,432   31,974
00040.M2TS      3:02:46.288     0:00:10.510     27,985,920      21,301
CHAPTERS:
1               0:00:00.000     0:01:37.030     24,179 kbps     38,952 kbps     00:00:14.647    36,234 kbps     00:00:13.880    33,951 kbps     00:00:07.607    100,811 bytes   263,505 bytes   00:00:41.908
2               0:01:37.030     0:00:59.926     35,314 kbps     44,661 kbps     00:01:46.206    38,739 kbps     00:02:21.107    37,817 kbps     00:02:16.436    147,288 bytes   402,850 bytes   00:01:59.085
3               0:02:36.956     0:04:26.833     23,556 kbps     39,603 kbps     00:02:38.091    33,808 kbps     00:02:37.123    29,746 kbps     00:02:37.123    98,248 bytes    271,433 bytes   00:02:38.958
4               0:07:03.790     0:05:17.684     23,535 kbps     37,921 kbps     00:10:29.562    36,638 kbps     00:10:28.127    35,545 kbps     00:10:23.456    98,161 bytes    238,676 bytes   00:11:08.968
5               0:12:21.474     0:04:24.264     21,833 kbps     29,518 kbps     00:12:54.907    27,198 kbps     00:12:54.140    25,295 kbps     00:12:52.972    91,062 bytes    260,903 bytes   00:14:47.720
6               0:16:45.738     0:04:45.985     21,336 kbps     28,033 kbps     00:21:21.146    27,788 kbps     00:21:19.044    26,112 kbps     00:21:19.044    88,988 bytes    244,425 bytes   00:21:31.723
7               0:21:31.723     0:01:09.402     37,364 kbps     41,568 kbps     00:22:15.600    39,216 kbps     00:21:59.017    38,935 kbps     00:21:47.873    155,840 bytes   476,605 bytes   00:22:41.126
8               0:22:41.126     0:00:10.910     20,501 kbps     38,894 kbps     00:22:41.126    27,939 kbps     00:22:41.126    22,146 kbps     00:22:41.126    85,506 bytes    493,601 bytes   00:22:42.127
9               0:22:52.037     0:01:49.042     22,047 kbps     26,786 kbps     00:22:55.040    25,790 kbps     00:22:53.505    23,898 kbps     00:22:53.605    91,953 bytes    218,251 bytes   00:22:56.041
10              0:24:41.079     0:00:59.993     35,560 kbps     44,680 kbps     00:24:50.255    38,898 kbps     00:25:25.156    38,298 kbps     00:25:20.619    148,316 bytes   402,327 bytes   00:25:03.134
11              0:25:41.072     0:04:31.037     24,586 kbps     39,609 kbps     00:25:44.843    33,312 kbps     00:29:36.341    33,115 kbps     00:29:31.336    102,542 bytes   321,450 bytes   00:25:44.075
12              0:30:12.110     0:04:11.284     19,727 kbps     31,964 kbps     00:32:19.504    25,768 kbps     00:33:11.356    24,799 kbps     00:31:55.747    82,277 bytes    228,790 bytes   00:33:12.390
13              0:34:23.394     0:05:36.002     23,554 kbps     35,035 kbps     00:36:17.875    31,429 kbps     00:36:15.973    30,047 kbps     00:36:15.973    98,239 bytes    268,748 bytes   00:36:18.509
14              0:39:59.397     0:04:24.330     22,319 kbps     32,413 kbps     00:40:30.394    29,647 kbps     00:40:28.359    28,661 kbps     00:40:23.387    93,089 bytes    273,569 bytes   00:42:13.797
15              0:44:23.727     0:01:09.402     37,368 kbps     42,142 kbps     00:45:10.541    39,266 kbps     00:44:39.877    38,969 kbps     00:44:35.272    155,854 bytes   475,459 bytes   00:45:33.130
16              0:45:33.130     0:00:10.944     30,517 kbps     39,109 kbps     00:45:37.434    37,047 kbps     00:45:33.597    33,165 kbps     00:45:33.130    127,280 bytes   492,681 bytes   00:45:34.131
17              0:45:44.074     0:00:49.048     20,028 kbps     28,914 kbps     00:46:06.663    26,280 kbps     00:46:04.561    24,638 kbps     00:45:59.690    83,533 bytes    213,615 bytes   00:45:48.145
18              0:46:33.123     0:00:59.993     34,620 kbps     44,683 kbps     00:46:42.299    37,983 kbps     00:46:47.638    37,496 kbps     00:46:42.766    144,394 bytes   402,327 bytes   00:46:55.179
19              0:47:33.116     0:05:35.034     23,271 kbps     39,411 kbps     00:47:39.823    38,543 kbps     00:47:36.086    33,800 kbps     00:51:30.520    97,061 bytes    291,088 bytes   00:47:37.120
20              0:53:08.151     0:03:44.924     24,501 kbps     38,845 kbps     00:53:49.960    33,601 kbps     00:56:36.559    29,936 kbps     00:56:37.394    102,190 bytes   250,184 bytes   00:53:22.332
21              0:56:53.076     0:05:29.629     22,792 kbps     38,849 kbps     01:02:21.270    36,043 kbps     00:56:53.076    31,980 kbps     00:56:53.076    95,062 bytes    222,083 bytes   00:58:25.835
22              1:02:22.705     0:04:52.992     21,081 kbps     38,937 kbps     01:07:09.291    38,784 kbps     01:07:09.091    32,396 kbps     01:07:04.186    87,926 bytes    243,341 bytes   01:07:15.698
23              1:07:15.698     0:01:09.402     36,985 kbps     42,243 kbps     01:08:22.698    39,126 kbps     01:07:31.747    38,880 kbps     01:07:31.847    154,257 bytes   492,289 bytes   01:08:25.101
24              1:08:25.101     0:00:11.010     27,131 kbps     37,643 kbps     01:08:33.909    30,242 kbps     01:08:25.101    29,644 kbps     01:08:25.101    113,159 bytes   495,233 bytes   01:08:26.102
25              1:08:36.112     0:02:27.013     24,586 kbps     37,304 kbps     01:09:27.329    32,317 kbps     01:08:50.960    30,335 kbps     01:08:45.955    102,542 bytes   211,853 bytes   01:10:41.904
26              1:11:03.125     0:00:59.993     34,938 kbps     44,670 kbps     01:11:12.301    38,059 kbps     01:11:47.202    37,498 kbps     01:11:12.768    145,719 bytes   402,327 bytes   01:11:25.180
27              1:12:03.118     0:03:57.570     22,239 kbps     40,103 kbps     01:12:05.554    36,931 kbps     01:12:04.086    30,894 kbps     01:12:04.386    92,754 bytes    331,272 bytes   01:12:06.121
28              1:16:00.689     0:05:00.433     22,837 kbps     33,517 kbps     01:18:36.812    28,334 kbps     01:19:14.316    27,920 kbps     01:19:14.316    95,251 bytes    234,965 bytes   01:16:22.110
29              1:21:01.122     0:05:04.137     21,406 kbps     29,428 kbps     01:22:06.655    27,817 kbps     01:23:01.142    27,264 kbps     01:22:57.672    89,280 bytes    239,703 bytes   01:21:06.828
30              1:26:05.260     0:04:02.475     23,447 kbps     32,159 kbps     01:29:41.409    29,974 kbps     01:27:51.432    28,410 kbps     01:27:46.461    97,794 bytes    271,444 bytes   01:27:33.948
31              1:30:07.735     0:01:09.402     37,097 kbps     42,284 kbps     01:31:14.735    39,337 kbps     01:30:23.885    39,054 kbps     01:30:19.280    154,725 bytes   494,101 bytes   01:31:17.138
32              1:31:17.138     0:00:11.011     26,404 kbps     38,923 kbps     01:31:25.580    29,689 kbps     01:31:22.043    28,844 kbps     01:31:17.138    110,125 bytes   512,999 bytes   01:31:18.139
33              1:31:28.149     0:02:08.995     22,492 kbps     32,317 kbps     01:31:35.857    26,527 kbps     01:33:26.634    25,299 kbps     01:32:28.709    93,809 bytes    202,849 bytes   01:31:36.357
34              1:33:37.144     0:00:59.993     34,255 kbps     44,676 kbps     01:33:46.320    37,959 kbps     01:33:51.659    37,482 kbps     01:33:46.787    142,872 bytes   397,172 bytes   01:33:59.200
35              1:34:37.138     0:04:25.565     21,931 kbps     36,861 kbps     01:34:40.841    31,341 kbps     01:34:38.639    28,375 kbps     01:34:37.805    91,469 bytes    256,211 bytes   01:34:41.142
36              1:39:02.703     0:03:48.928     23,471 kbps     34,777 kbps     01:39:54.922    34,405 kbps     01:39:51.385    33,627 kbps     01:39:47.147    97,895 bytes    198,864 bytes   01:39:54.688
37              1:42:51.632     0:06:33.226     22,362 kbps     35,373 kbps     01:43:08.081    33,955 kbps     01:43:04.645    32,852 kbps     01:43:00.641    93,268 bytes    251,010 bytes   01:48:55.562
38              1:49:24.858     0:03:34.914     23,807 kbps     38,898 kbps     01:51:57.477    35,661 kbps     01:51:56.743    30,877 kbps     01:51:56.743    99,296 bytes    244,425 bytes   01:52:59.773
39              1:52:59.773     0:01:09.402     36,988 kbps     42,194 kbps     01:53:50.690    39,121 kbps     01:53:27.901    38,883 kbps     01:53:54.427    154,269 bytes   480,290 bytes   01:54:09.175
40              1:54:09.175     0:00:11.011     25,347 kbps     37,381 kbps     01:54:17.517    28,609 kbps     01:54:13.379    27,682 kbps     01:54:09.175    105,720 bytes   495,395 bytes   01:54:10.176
41              1:54:20.186     0:00:47.046     27,865 kbps     40,986 kbps     01:54:52.185    39,155 kbps     01:54:48.147    38,346 kbps     01:54:48.948    116,219 bytes   236,787 bytes   01:54:58.725
42              1:55:07.233     0:00:59.993     34,550 kbps     44,628 kbps     01:55:16.409    37,971 kbps     01:55:21.748    37,488 kbps     01:55:16.876    144,103 bytes   400,568 bytes   01:55:29.289
43              1:56:07.226     0:05:15.114     21,596 kbps     39,827 kbps     02:00:56.549    38,986 kbps     02:00:52.612    38,891 kbps     02:00:47.540    90,074 bytes    277,286 bytes   01:56:11.230
44              2:01:22.341     0:04:18.291     28,131 kbps     44,980 kbps     02:01:37.590    40,026 kbps     02:01:33.619    39,420 kbps     02:02:45.424    117,330 bytes   309,376 bytes   02:02:55.134
45              2:05:40.633     0:06:51.277     21,104 kbps     30,905 kbps     02:06:51.136    30,200 kbps     02:11:03.455    29,110 kbps     02:11:03.455    88,021 bytes    231,444 bytes   02:07:21.834
46              2:12:31.910     0:03:19.899     19,667 kbps     31,899 kbps     02:14:48.513    29,225 kbps     02:14:46.378    26,560 kbps     02:14:41.540    82,027 bytes    246,469 bytes   02:15:51.810
47              2:15:51.810     0:01:09.402     37,052 kbps     42,356 kbps     02:16:35.620    39,258 kbps     02:16:07.959    38,979 kbps     02:16:03.388    154,539 bytes   485,880 bytes   02:17:01.213
48              2:17:01.213     0:00:11.011     24,781 kbps     36,752 kbps     02:17:09.955    27,489 kbps     02:17:06.151    27,058 kbps     02:17:01.213    103,356 bytes   501,922 bytes   02:17:02.214
49              2:17:12.224     0:01:41.034     23,714 kbps     36,176 kbps     02:18:30.268    31,053 kbps     02:18:17.122    28,694 kbps     02:18:17.022    98,908 bytes    236,513 bytes   02:18:11.950
50              2:18:53.258     0:00:59.993     34,323 kbps     43,728 kbps     02:19:02.434    37,728 kbps     02:19:06.071    37,393 kbps     02:19:02.901    143,156 bytes   357,344 bytes   02:19:02.934
51              2:19:53.251     0:04:53.793     21,578 kbps     40,967 kbps     02:20:12.170    35,915 kbps     02:19:54.119    34,839 kbps     02:20:08.767    89,998 bytes    297,349 bytes   02:19:56.254
52              2:24:47.045     0:05:41.407     23,337 kbps     41,070 kbps     02:27:11.756    39,219 kbps     02:27:07.752    36,596 kbps     02:27:03.047    97,336 bytes    268,885 bytes   02:29:06.771
53              2:30:28.452     0:04:23.796     22,120 kbps     35,301 kbps     02:34:13.177    31,591 kbps     02:34:11.909    26,813 kbps     02:34:11.375    92,259 bytes    259,767 bytes   02:34:02.967
54              2:34:52.249     0:03:51.598     23,597 kbps     39,449 kbps     02:36:47.297    37,710 kbps     02:36:44.928    33,562 kbps     02:36:41.125    98,420 bytes    310,276 bytes   02:38:43.847
55              2:38:43.847     0:01:09.402     36,860 kbps     42,282 kbps     02:39:04.301    39,525 kbps     02:39:00.297    39,121 kbps     02:38:55.325    153,739 bytes   489,014 bytes   02:39:53.250
56              2:39:53.250     0:00:11.011     27,676 kbps     38,325 kbps     02:40:01.825    31,641 kbps     02:39:58.155    30,243 kbps     02:39:53.250    115,433 bytes   510,478 bytes   02:39:54.251
57              2:40:04.261     0:01:27.020     25,454 kbps     39,105 kbps     02:41:23.440    38,603 kbps     02:41:19.069    36,869 kbps     02:41:15.265    106,163 bytes   209,452 bytes   02:41:29.246
58              2:41:31.281     0:00:59.993     33,778 kbps     43,679 kbps     02:41:40.457    37,717 kbps     02:41:46.063    37,397 kbps     02:41:40.924    140,881 bytes   357,344 bytes   02:41:40.957
59              2:42:31.274     0:05:20.953     23,968 kbps     37,264 kbps     02:44:15.412    34,970 kbps     02:46:54.771    29,288 kbps     02:46:52.135    99,965 bytes    254,920 bytes   02:47:06.116
60              2:47:52.228     0:03:43.056     20,905 kbps     34,542 kbps     02:48:38.274    31,630 kbps     02:48:35.972    26,987 kbps     02:48:35.405    87,191 bytes    230,045 bytes   02:49:06.769
61              2:51:35.285     0:05:02.201     22,649 kbps     31,653 kbps     02:56:36.485    29,899 kbps     02:53:42.612    29,712 kbps     02:53:40.743    94,465 bytes    224,966 bytes   02:54:57.386
62              2:56:37.486     0:04:58.398     22,554 kbps     37,700 kbps     03:01:21.871    31,873 kbps     03:01:19.235    29,387 kbps     03:01:14.463    94,069 bytes    369,372 bytes   03:01:20.269
63              3:01:35.885     0:01:10.403     35,382 kbps     41,075 kbps     03:02:19.695    39,083 kbps     03:01:52.034    38,865 kbps     03:01:47.196    147,571 bytes   601,937 bytes   03:02:46.288
64              3:02:46.288     0:00:10.510     16,719 kbps     18,271 kbps     03:02:46.288    18,059 kbps     03:02:46.288    17,522 kbps     03:02:46.288    69,956 bytes    639,118 bytes   03:02:49.291
STREAM DIAGNOSTICS:
00041.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,991                  4,114,110,469   22,383,126
00041.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,219                   723,577,978     5,011,101
00041.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00041.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1371.904                640                     109,765,120     643,155
00041.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                28                      4,749,094       27,647
00041.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00042.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,981                  4,112,386,211   22,373,924
00042.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                3,945                   676,462,554     4,713,975
00042.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                39                      6,766,477       39,190
00042.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00051.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,997                  4,115,258,235   22,389,457
00051.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,200                   720,229,354     4,975,754
00051.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                18                      3,162,012       18,620
00051.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00052.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,993                  4,114,476,557   22,385,269
00052.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                3,835                   657,595,502     4,517,991
00052.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                21                      3,552,661       20,951
00052.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00053.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,988                  4,113,705,685   22,381,112
00053.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,031                   691,229,988     4,810,447
00053.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                20                      3,345,650       19,648
00053.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00054.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                23,989                  4,113,792,492   22,381,408
00054.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                4,120                   706,469,422     4,874,356
00054.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1371.904                640                     109,765,120     643,155
00054.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                21                      3,582,238       21,092
00054.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       374,684         2,166
00055.M2TS      4113 (0x1011)   0x1B            AVC                                     1371.904                24,000                  4,115,666,478   22,391,665
00055.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1371.904                3,954                   678,074,466     4,642,391
00055.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1371.904                22                      3,738,769       21,952
00055.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1371.904                2                       425,537         2,444
00056.M2TS      4113 (0x1011)   0x1B            AVC                                     1361.894                23,980                  4,082,221,150   22,209,898
00056.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           1361.894                4,098                   697,679,148     4,794,778
00056.M2TS      4353 (0x1101)   0x81            AC3             jpn (Japanese)          1361.894                640                     108,963,840     638,460
00056.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           1361.894                640                     108,963,840     638,460
00056.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1361.894                23                      3,837,037       22,681
00056.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           1361.894                2                       374,684         2,166
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #1360 of 5099 Old 03-11-2010, 11:41 PM
I've thrown together some comparison screen shots here between a few different versions. http://www.hd-compare.com/2009/10/re...for-dream.html
Code:
        Total   Video
00003.MPLS                                                      AVC     1:41:34 15,925,155,840  15,994,784,719  20.91   15.00   DTS-HD Master 5.1 3815Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:
Disc Size:      15,994,784,719 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:41:34 (h:m:s)
Total Bitrate:          20.91 Mbps
VIDEO:
MPEG-4 AVC Video        15000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3815 kbps       5.1 / 48 kHz / 3815 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           French          0.023 kbps
FILES:
00003.M2TS      0:00:00.000     1:41:34.088     15,925,155,840  20,906
CHAPTERS:
1               0:00:00.000     0:03:00.597     14,591 kbps     23,951 kbps     00:01:08.443    21,302 kbps     00:01:44.771    20,633 kbps     00:02:02.455    76,056 bytes    461,989 bytes   00:01:09.319
2               0:03:00.597     0:02:28.898     8,848 kbps      18,749 kbps     00:05:22.739    16,275 kbps     00:05:21.988    14,698 kbps     00:03:30.335    46,127 bytes    389,112 bytes   00:05:26.701
3               0:05:29.495     0:02:22.600     14,436 kbps     19,637 kbps     00:05:31.247    17,673 kbps     00:05:30.121    15,406 kbps     00:05:31.247    75,265 bytes    306,236 bytes   00:07:51.721
4               0:07:52.096     0:01:12.447     12,687 kbps     20,237 kbps     00:07:52.221    15,106 kbps     00:08:36.265    14,314 kbps     00:08:32.595    66,147 bytes    298,306 bytes   00:07:52.472
5               0:09:04.544     0:03:02.515     12,491 kbps     23,000 kbps     00:09:34.740    20,425 kbps     00:09:33.823    17,210 kbps     00:09:29.068    65,120 bytes    347,237 bytes   00:11:37.238
6               0:12:07.059     0:01:51.611     13,753 kbps     20,152 kbps     00:13:54.166    18,512 kbps     00:13:50.120    17,900 kbps     00:13:46.367    71,702 bytes    316,734 bytes   00:13:58.128
7               0:13:58.671     0:02:36.531     12,833 kbps     20,506 kbps     00:16:11.387    18,844 kbps     00:16:07.383    16,964 kbps     00:16:05.381    66,907 bytes    270,968 bytes   00:16:11.512
8               0:16:35.202     0:02:23.518     14,194 kbps     19,359 kbps     00:18:42.996    16,949 kbps     00:18:24.478    16,291 kbps     00:18:20.891    74,001 bytes    242,808 bytes   00:18:15.385
9               0:18:58.720     0:04:33.982     14,661 kbps     21,116 kbps     00:22:18.211    18,358 kbps     00:19:54.026    18,212 kbps     00:19:54.026    76,437 bytes    302,603 bytes   00:21:55.063
10              0:23:32.702     0:02:16.845     13,525 kbps     22,076 kbps     00:25:24.481    17,176 kbps     00:25:23.230    15,823 kbps     00:25:18.225    70,514 bytes    256,133 bytes   00:25:24.940
11              0:25:49.547     0:01:41.518     14,161 kbps     18,582 kbps     00:26:11.236    16,844 kbps     00:26:01.935    16,204 kbps     00:26:02.227    73,829 bytes    279,206 bytes   00:26:49.357
12              0:27:31.066     0:02:13.716     15,492 kbps     21,341 kbps     00:28:02.389    19,527 kbps     00:28:00.887    19,378 kbps     00:27:54.923    80,769 bytes    284,255 bytes   00:27:36.780
13              0:29:44.783     0:01:42.936     14,955 kbps     24,808 kbps     00:31:15.582    21,748 kbps     00:31:11.411    20,150 kbps     00:31:06.614    77,966 bytes    261,526 bytes   00:30:16.523
14              0:31:27.719     0:01:16.868     13,404 kbps     19,459 kbps     00:31:40.064    16,797 kbps     00:31:40.023    15,455 kbps     00:31:35.018    69,880 bytes    269,403 bytes   00:31:43.401
15              0:32:44.587     0:01:34.094     13,943 kbps     19,512 kbps     00:33:42.353    17,247 kbps     00:33:42.353    16,772 kbps     00:33:42.270    72,690 bytes    244,822 bytes   00:33:42.520
16              0:34:18.681     0:02:55.967     14,807 kbps     25,849 kbps     00:36:03.202    22,545 kbps     00:35:59.198    21,489 kbps     00:35:54.193    77,199 bytes    253,710 bytes   00:35:17.323
17              0:37:14.649     0:09:48.170     13,826 kbps     20,791 kbps     00:37:59.568    17,946 kbps     00:43:57.343    17,723 kbps     00:45:18.257    72,085 bytes    288,108 bytes   00:37:38.172
18              0:47:02.820     0:02:18.972     17,124 kbps     26,657 kbps     00:47:55.622    25,469 kbps     00:47:55.581    24,668 kbps     00:47:55.497    89,275 bytes    287,731 bytes   00:49:03.899
19              0:49:21.792     0:02:10.713     16,966 kbps     28,888 kbps     00:51:10.650    26,529 kbps     00:50:50.589    25,431 kbps     00:50:45.542    88,452 bytes    252,130 bytes   00:49:23.210
20              0:51:32.506     0:02:45.164     16,590 kbps     19,614 kbps     00:53:00.468    18,235 kbps     00:52:59.843    17,680 kbps     00:52:58.592    86,490 bytes    243,833 bytes   00:52:24.307
21              0:54:17.671     0:02:04.707     17,522 kbps     23,723 kbps     00:54:53.081    20,289 kbps     00:55:28.575    19,681 kbps     00:54:44.114    91,350 bytes    250,767 bytes   00:55:18.857
22              0:56:22.379     0:03:54.859     14,303 kbps     22,317 kbps     01:00:00.388    19,065 kbps     00:59:57.468    16,205 kbps     00:56:41.272    74,569 bytes    260,173 bytes   01:00:00.513
23              1:00:17.238     0:02:21.724     16,337 kbps     24,443 kbps     01:01:18.841    21,263 kbps     01:01:18.132    20,327 kbps     01:01:13.169    85,174 bytes    284,491 bytes   01:02:38.588
24              1:02:38.963     0:03:24.203     18,213 kbps     31,351 kbps     01:03:33.935    27,681 kbps     01:03:32.350    26,790 kbps     01:03:33.059    94,953 bytes    318,207 bytes   01:02:42.341
25              1:06:03.167     0:07:03.840     16,986 kbps     35,246 kbps     01:06:09.882    31,731 kbps     01:06:05.711    29,828 kbps     01:06:03.876    88,557 bytes    301,563 bytes   01:06:06.837
26              1:13:07.007     0:01:00.477     13,717 kbps     20,596 kbps     01:14:05.566    18,952 kbps     01:14:02.479    17,417 kbps     01:13:57.474    71,515 bytes    228,706 bytes   01:13:20.145
27              1:14:07.484     0:02:27.939     17,859 kbps     24,209 kbps     01:14:54.239    22,801 kbps     01:14:48.108    22,705 kbps     01:14:48.734    93,107 bytes    279,130 bytes   01:14:58.744
28              1:16:35.424     0:04:23.638     17,469 kbps     28,017 kbps     01:18:42.342    25,065 kbps     01:17:03.118    24,268 kbps     01:16:38.510    91,078 bytes    277,517 bytes   01:16:49.271
29              1:20:59.062     0:04:39.070     17,527 kbps     25,387 kbps     01:21:29.426    23,209 kbps     01:21:29.301    21,788 kbps     01:21:28.758    91,376 bytes    267,035 bytes   01:23:15.949
30              1:25:38.133     0:03:37.217     18,298 kbps     26,233 kbps     01:26:39.944    24,257 kbps     01:26:36.941    21,536 kbps     01:26:34.772    95,399 bytes    280,459 bytes   01:26:18.673
31              1:29:15.350     0:04:31.688     16,976 kbps     31,110 kbps     01:30:13.741    24,134 kbps     01:30:12.031    23,635 kbps     01:30:11.989    88,504 bytes    286,786 bytes   01:31:08.588
32              1:33:47.038     0:03:33.004     14,220 kbps     21,009 kbps     01:35:21.715    19,667 kbps     01:35:19.380    19,421 kbps     01:35:17.211    74,134 bytes    252,654 bytes   01:35:25.511
33              1:37:20.042     0:04:14.045     7,573 kbps      14,443 kbps     01:38:33.324    12,747 kbps     01:38:30.946    11,369 kbps     01:40:32.026    39,488 bytes    260,595 bytes   01:38:33.449
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     6094.005                15,000                  11,426,357,393  62,185,459
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6094.005                3,815                   2,905,928,444   16,744,926
00003.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6094.005                448                     341,272,064     1,904,420
00003.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6094.005                448                     341,272,064     1,904,420
00003.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6094.005                0                       17,502          102
post #1361 of 5099 Old 03-12-2010, 12:31 PM - Thread Starter
Cinema Squid's Avatar
[US] Camille (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: National Entertainment Media
UPC: 652405000699
Release Date: 2009-09-15
Aspect Ratio: 1.78:1
Both the English audio tracks are main feature audio.
Code:
        Total   Video
[US] Camille                                                    AVC     1:30:58 16,335,564,480  16,948,875,701  23.94   20.00   DTS-HD Master 5.1 2124Kbps (48kHz/16-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     CAMILLE
Disc Size:      16,948,875,701 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:30:58 (h:m:s)
Total Bitrate:          23.94 Mbps
VIDEO:
MPEG-4 AVC Video        19999 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2124 kbps       5.1 / 48 kHz / 2124 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         34.523 kbps
Presentation Graphics           Spanish         30.051 kbps
FILES:
00004.M2TS      0:00:00.000     1:30:58.995     16,335,564,480  23,939
CHAPTERS:
1               0:00:00.000     0:07:06.551     18,882 kbps     42,941 kbps     00:00:58.099    39,209 kbps     00:00:55.513    34,233 kbps     00:00:50.508    98,430 bytes    398,247 bytes   00:00:19.978
2               0:07:06.551     0:04:08.623     20,773 kbps     30,110 kbps     00:08:55.910    26,569 kbps     00:09:21.269    26,142 kbps     00:09:21.352    108,299 bytes   336,650 bytes   00:09:49.297
3               0:11:15.174     0:07:54.432     19,431 kbps     30,114 kbps     00:11:49.583    26,100 kbps     00:11:46.664    23,842 kbps     00:11:41.992    101,304 bytes   357,345 bytes   00:12:42.511
4               0:19:09.606     0:05:38.087     20,180 kbps     39,852 kbps     00:21:51.935    34,433 kbps     00:21:57.274    30,646 kbps     00:21:51.935    105,209 bytes   376,724 bytes   00:21:52.602
5               0:24:47.694     0:06:46.405     19,970 kbps     36,625 kbps     00:25:32.531    29,516 kbps     00:25:30.987    26,712 kbps     00:25:25.982    104,116 bytes   389,440 bytes   00:25:31.154
6               0:31:34.100     0:05:20.862     20,624 kbps     38,812 kbps     00:33:03.022    26,189 kbps     00:32:59.060    25,506 kbps     00:32:54.097    107,524 bytes   350,909 bytes   00:33:00.478
7               0:36:54.962     0:06:33.434     20,104 kbps     31,513 kbps     00:38:45.114    26,315 kbps     00:38:42.528    24,507 kbps     00:38:37.315    104,815 bytes   338,339 bytes   00:42:03.020
8               0:43:28.397     0:03:05.560     20,900 kbps     30,589 kbps     00:45:28.809    27,629 kbps     00:46:22.571    26,886 kbps     00:46:19.568    108,961 bytes   439,196 bytes   00:45:02.700
9               0:46:33.957     0:05:03.761     22,085 kbps     29,369 kbps     00:49:54.241    27,284 kbps     00:49:29.216    27,063 kbps     00:49:29.216    115,139 bytes   366,518 bytes   00:46:36.919
10              0:51:37.719     0:05:01.467     21,448 kbps     34,756 kbps     00:54:33.937    31,148 kbps     00:54:32.435    29,459 kbps     00:54:25.679    111,821 bytes   393,527 bytes   00:54:27.764
11              0:56:39.187     0:04:21.219     19,339 kbps     29,721 kbps     01:00:03.433    23,784 kbps     00:59:15.802    23,305 kbps     00:59:10.255    100,823 bytes   353,052 bytes   01:01:00.365
12              1:01:00.406     0:05:33.166     23,715 kbps     33,868 kbps     01:05:48.486    27,579 kbps     01:05:17.246    26,632 kbps     01:05:10.698    123,639 bytes   377,277 bytes   01:04:51.888
13              1:06:33.572     0:06:46.114     19,748 kbps     33,080 kbps     01:08:41.283    27,004 kbps     01:08:38.614    24,980 kbps     01:08:32.942    102,956 bytes   465,241 bytes   01:09:55.441
14              1:13:19.686     0:07:33.870     21,111 kbps     39,296 kbps     01:18:06.598    33,294 kbps     01:18:04.638    27,771 kbps     01:17:41.656    110,061 bytes   355,077 bytes   01:13:34.827
15              1:20:53.557     0:06:14.332     19,591 kbps     32,790 kbps     01:21:29.467    29,797 kbps     01:21:29.217    27,805 kbps     01:21:24.004    102,141 bytes   428,736 bytes   01:27:00.840
16              1:27:07.889     0:03:51.105     10,080 kbps     17,316 kbps     01:29:48.591    16,844 kbps     01:29:46.005    16,590 kbps     01:29:45.004    52,570 bytes    208,546 bytes   01:29:49.008
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     5458.912                19,999                  13,646,597,024  74,243,921
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5458.912                2,124                   1,449,424,300   8,695,733
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5458.912                448                     305,704,448     1,705,940
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5458.912                35                      23,557,866      135,188
00004.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5458.912                30                      20,505,986      117,403
Cinema Squid is offline
post #1362 of 5099 Old 03-12-2010, 12:35 PM - Thread Starter
[US] Planet 51 (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8 set to all 3 regions)
Studio: Sony
UPC: 043396321472
Release Date: 2010-03-09
Aspect Ratio: 2.35:1
The English DD 5.1 is a descriptive audio track.
Code:
        Total   Video
[US] Planet 51                                                  AVC     1:31:01 27,979,886,592  42,765,920,031  40.99   31.98   DTS-HD Master 5.1 3815Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     PLANET51
Disc Size:      42,765,920,031 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:31:01 (h:m:s)
Total Bitrate:          40.99 Mbps
(*) Indicates included stream hidden by this playlist.
VIDEO:
MPEG-4 AVC Video        31979 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             German          2070 kbps       5.1 / 48 kHz / 2070 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         28.938 kbps
* Presentation Graphics         English         28.963 kbps
Presentation Graphics           English         32.546 kbps
Presentation Graphics           German          32.856 kbps
Presentation Graphics           Spanish         29.753 kbps
Presentation Graphics           Turkish         31.126 kbps
FILES:
00004.M2TS      0:00:00.000     1:31:01.456     27,979,886,592  40,985
CHAPTERS:
1               0:00:00.000     0:06:46.239     31,276 kbps     39,139 kbps     00:02:56.968    33,619 kbps     00:04:43.157    33,128 kbps     00:03:54.984    163,040 bytes   639,791 bytes   00:04:47.161
2               0:06:46.239     0:05:13.271     32,459 kbps     36,570 kbps     00:09:26.399    33,633 kbps     00:11:21.389    33,135 kbps     00:11:21.931    169,229 bytes   640,825 bytes   00:07:19.397
3               0:11:59.510     0:06:10.745     31,693 kbps     37,098 kbps     00:15:21.170    33,934 kbps     00:16:27.987    33,180 kbps     00:16:22.940    165,232 bytes   640,806 bytes   00:16:12.304
4               0:18:10.255     0:03:13.067     32,393 kbps     36,332 kbps     00:19:03.934    33,488 kbps     00:20:13.170    33,147 kbps     00:20:08.165    168,881 bytes   639,245 bytes   00:20:23.764
5               0:21:23.323     0:04:44.409     32,111 kbps     35,413 kbps     00:22:45.489    33,222 kbps     00:22:55.624    32,981 kbps     00:22:10.662    167,413 bytes   488,745 bytes   00:22:01.320
6               0:26:07.732     0:04:55.044     32,085 kbps     37,211 kbps     00:29:15.587    33,788 kbps     00:28:03.056    33,195 kbps     00:26:08.358    167,275 bytes   640,984 bytes   00:30:52.308
7               0:31:02.777     0:02:40.785     31,995 kbps     36,915 kbps     00:31:45.820    33,444 kbps     00:31:04.737    33,042 kbps     00:32:24.150    166,807 bytes   640,717 bytes   00:31:03.778
8               0:33:43.563     0:09:15.638     32,234 kbps     37,894 kbps     00:37:26.869    33,465 kbps     00:36:04.871    33,085 kbps     00:36:28.519    168,052 bytes   640,749 bytes   00:40:56.370
9               0:42:59.201     0:04:49.664     32,300 kbps     36,096 kbps     00:45:32.563    33,366 kbps     00:45:28.934    33,088 kbps     00:45:48.454    168,397 bytes   598,057 bytes   00:45:33.355
10              0:47:48.866     0:05:26.409     32,215 kbps     38,354 kbps     00:47:52.202    33,447 kbps     00:50:17.431    33,104 kbps     00:49:54.157    167,955 bytes   636,117 bytes   00:50:48.837
11              0:53:15.275     0:07:31.492     31,124 kbps     35,508 kbps     00:59:30.775    33,250 kbps     00:58:25.752    32,997 kbps     01:00:03.266    162,267 bytes   531,177 bytes   00:53:25.452
12              1:00:46.768     0:06:28.846     32,081 kbps     37,738 kbps     01:06:31.445    33,530 kbps     01:06:27.525    33,197 kbps     01:06:22.478    167,254 bytes   639,685 bytes   01:06:30.361
13              1:07:15.614     0:05:46.179     31,984 kbps     37,433 kbps     01:09:37.047    33,766 kbps     01:09:32.918    33,014 kbps     01:09:29.456    166,751 bytes   640,739 bytes   01:09:28.664
14              1:13:01.794     0:04:17.298     31,689 kbps     37,235 kbps     01:14:50.277    33,416 kbps     01:13:42.084    33,024 kbps     01:13:43.001    165,211 bytes   593,776 bytes   01:13:36.912
15              1:17:19.092     0:02:31.025     32,158 kbps     35,826 kbps     01:18:35.335    33,369 kbps     01:18:31.331    32,982 kbps     01:18:26.535    167,659 bytes   602,546 bytes   01:19:32.100
16              1:19:50.118     0:11:11.337     32,232 kbps     36,749 kbps     01:19:51.077    33,480 kbps     01:22:05.795    33,081 kbps     01:20:43.088    168,054 bytes   640,063 bytes   01:26:14.794
STREAM DIAGNOSTICS:
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     5461.289                31,980                  21,831,396,319  118,725,291
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5461.289                3,815                   2,604,483,260   15,006,045
00004.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5461.289                640                     436,917,760     2,560,065
00004.M2TS      4354 (0x1102)   0x86            DTS-HD MA       deu (German)            5461.289                2,070                   1,413,212,780   8,530,706
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5461.289                29                      19,755,210      113,382
00004.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5461.289                29                      19,772,478      113,475
00004.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           5461.289                33                      22,218,613      129,952
00004.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            5461.289                33                      22,430,519      128,202
00004.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           5461.289                30                      20,311,942      116,673
00004.M2TS      4613 (0x1205)   0x90            PGS             tur (Turkish)           5461.289                31                      21,249,226      121,799
post #1363 of 5099 Old 03-12-2010, 08:25 PM
Patsfan123's Avatar
Quoted: 106 Post(s)
Liked: 65
Code:
        Total   Video
00001.MPLS                                                      AVC     1:42:10 29,668,245,504  40,520,275,923  38.72   27.05   DTS-HD Master 5.1 2655Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     VOLUME_ID
Disc Size:      40,520,275,923 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:42:10 (h:m:s)
Total Bitrate:          38.72 Mbps
VIDEO:
MPEG-4 AVC Video        27053 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2655 kbps       5.1 / 48 kHz / 2655 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          2691 kbps       5.1 / 48 kHz / 2691 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
DTS-HD Master Audio             Portuguese      2733 kbps       5.1 / 48 kHz / 2733 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         36.182 kbps
Presentation Graphics           English         32.983 kbps
Presentation Graphics           French          25.363 kbps
Presentation Graphics           Spanish         29.430 kbps
Presentation Graphics           Portuguese      33.819 kbps
Presentation Graphics           Portuguese      61.673 kbps
Presentation Graphics           Spanish         65.493 kbps
FILES:
00011.M2TS      0:00:00.000     1:42:10.124     29,668,245,504  38,718
CHAPTERS:
1               0:00:00.000     0:05:07.307     27,609 kbps     43,827 kbps     00:00:15.765    32,571 kbps     00:00:14.973    31,065 kbps     00:00:15.724    143,922 bytes   533,539 bytes   00:00:16.683
2               0:05:07.307     0:08:04.692     28,108 kbps     44,519 kbps     00:05:08.349    32,324 kbps     00:08:05.318    31,109 kbps     00:05:08.349    146,540 bytes   708,783 bytes   00:09:55.094
3               0:13:11.999     0:05:31.664     27,857 kbps     35,172 kbps     00:13:17.797    29,570 kbps     00:16:47.631    28,951 kbps     00:17:14.032    145,235 bytes   497,376 bytes   00:17:49.651
4               0:18:43.664     0:05:37.170     28,185 kbps     39,514 kbps     00:20:11.460    31,447 kbps     00:21:21.280    30,565 kbps     00:18:46.500    146,944 bytes   678,830 bytes   00:20:07.164
5               0:24:20.834     0:04:40.738     27,871 kbps     35,868 kbps     00:25:01.124    30,376 kbps     00:26:48.231    29,377 kbps     00:26:48.189    145,309 bytes   599,602 bytes   00:29:01.573
6               0:29:01.573     0:08:08.279     27,929 kbps     46,299 kbps     00:32:30.281    31,244 kbps     00:29:25.972    30,692 kbps     00:29:02.157    145,610 bytes   621,906 bytes   00:29:21.342
7               0:37:09.852     0:06:01.152     28,051 kbps     50,248 kbps     00:40:25.881    32,409 kbps     00:40:25.798    30,958 kbps     00:40:25.798    146,247 bytes   644,489 bytes   00:40:26.757
8               0:43:11.005     0:03:52.190     27,555 kbps     34,176 kbps     00:44:59.154    29,728 kbps     00:43:30.107    29,109 kbps     00:43:25.102    143,659 bytes   449,093 bytes   00:45:55.544
9               0:47:03.195     0:07:34.495     27,691 kbps     37,630 kbps     00:47:44.027    31,423 kbps     00:47:40.732    31,052 kbps     00:47:35.602    144,370 bytes   486,547 bytes   00:47:20.254
10              0:54:37.691     0:06:46.114     28,565 kbps     40,033 kbps     00:54:39.734    32,968 kbps     00:54:37.899    30,873 kbps     00:59:17.804    148,923 bytes   641,357 bytes   00:59:12.465
11              1:01:23.805     0:06:03.696     27,756 kbps     34,751 kbps     01:03:50.743    31,131 kbps     01:05:29.717    30,092 kbps     01:05:27.089    144,708 bytes   689,888 bytes   01:02:14.522
12              1:07:27.501     0:04:57.005     28,242 kbps     38,819 kbps     01:12:15.414    33,212 kbps     01:12:15.414    31,734 kbps     01:12:12.036    147,242 bytes   696,433 bytes   01:09:22.783
13              1:12:24.506     0:03:54.776     27,079 kbps     39,667 kbps     01:16:01.473    31,216 kbps     01:14:35.679    30,368 kbps     01:14:16.827    141,179 bytes   572,636 bytes   01:15:07.669
14              1:16:19.283     0:06:26.469     28,224 kbps     43,054 kbps     01:22:29.611    32,735 kbps     01:22:12.469    31,274 kbps     01:17:34.941    147,148 bytes   566,473 bytes   01:21:09.990
15              1:22:45.752     0:07:34.495     27,902 kbps     49,284 kbps     01:26:55.835    32,231 kbps     01:26:54.876    30,521 kbps     01:26:55.543    145,471 bytes   584,587 bytes   01:26:46.618
16              1:30:20.248     0:11:49.875     20,262 kbps     42,557 kbps     01:37:01.190    32,353 kbps     01:35:08.160    31,108 kbps     01:35:31.434    105,647 bytes   779,038 bytes   01:38:17.766
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6130.041                27,054                  20,730,043,032  112,749,752
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6130.041                2,655                   2,034,424,232   11,998,440
00011.M2TS      4353 (0x1101)   0x86            DTS-HD MA       fra (French)            6130.041                2,691                   2,062,355,148   12,153,154
00011.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6130.041                640                     490,411,520     2,873,505
00011.M2TS      4355 (0x1103)   0x86            DTS-HD MA       por (Portuguese)        6130.041                2,733                   2,094,435,328   12,334,645
00011.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           6130.041                192                     147,123,456     957,835
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6130.041                36                      27,724,946      158,101
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6130.041                33                      25,273,809      146,917
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6130.041                25                      19,435,099      113,143
00011.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6130.041                29                      22,550,972      129,733
00011.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6130.041                34                      25,914,491      148,364
00011.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        6130.041                62                      47,258,245      268,607
00011.M2TS      4614 (0x1206)   0x90            PGS             spa (Spanish)           6130.041                65                      50,184,842      284,517
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is online now
post #1364 of 5099 Old 03-13-2010, 04:57 PM
Just filling out some missing Blu-ray info for some old movies. Again- some comparison screens/review available here:
http://www.hd-compare.com/2009/05/ba...dangerous.html
Code:
        Total   Video
00015.MPLS                                                      AVC     1:38:46 23,601,973,248  33,845,661,600  31.86   26.03   DTS-HD Hi-Res 5.1 2046Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      33,845,661,600 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:38:46 (h:m:s)
Total Bitrate:          31.86 Mbps
VIDEO:
MPEG-4 AVC Video        26031 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD High-Res Audio           English         2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD High-Res Audio           German          2046 kbps       5.1 / 48 kHz / 2046 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           English         1.253 kbps
Presentation Graphics           German          15.738 kbps
FILES:
00021.M2TS      0:00:00.000     1:38:46.041     23,601,973,248  31,862
CHAPTERS:
1               0:00:00.000     0:06:43.250     20,338 kbps     42,724 kbps     00:02:22.541    40,314 kbps     00:02:21.041    34,781 kbps     00:02:19.541    105,917 bytes   477,627 bytes   00:02:56.958
2               0:06:43.250     0:05:55.625     29,617 kbps     42,516 kbps     00:07:50.958    37,930 kbps     00:07:30.458    35,527 kbps     00:07:30.458    154,257 bytes   574,393 bytes   00:07:46.250
3               0:12:38.875     0:04:59.458     29,874 kbps     45,470 kbps     00:16:40.708    36,990 kbps     00:12:55.333    35,204 kbps     00:12:47.708    155,595 bytes   478,856 bytes   00:16:41.708
4               0:17:38.333     0:05:39.875     27,782 kbps     42,813 kbps     00:19:48.125    37,086 kbps     00:19:47.000    35,218 kbps     00:19:46.541    144,700 bytes   543,557 bytes   00:18:40.916
5               0:23:18.208     0:04:16.083     30,901 kbps     42,195 kbps     00:24:05.416    35,973 kbps     00:23:54.166    34,449 kbps     00:24:01.624    160,945 bytes   496,977 bytes   00:23:42.291
6               0:27:34.291     0:06:32.291     30,612 kbps     42,645 kbps     00:28:11.791    37,995 kbps     00:30:13.791    36,734 kbps     00:30:13.791    159,437 bytes   558,716 bytes   00:28:14.833
7               0:34:06.583     0:04:54.916     28,192 kbps     43,476 kbps     00:35:19.875    38,351 kbps     00:35:19.875    36,945 kbps     00:37:30.791    146,832 bytes   632,082 bytes   00:37:35.125
8               0:39:01.500     0:05:10.000     29,142 kbps     42,833 kbps     00:44:02.250    35,684 kbps     00:43:16.416    34,383 kbps     00:43:28.666    151,780 bytes   486,190 bytes   00:43:07.833
9               0:44:11.500     0:07:34.708     24,700 kbps     43,173 kbps     00:51:14.166    37,225 kbps     00:51:11.458    36,030 kbps     00:51:06.416    128,645 bytes   570,073 bytes   00:51:32.208
10              0:51:46.208     0:07:05.416     31,612 kbps     42,463 kbps     00:53:46.583    37,153 kbps     00:51:46.958    36,233 kbps     00:51:46.208    164,647 bytes   522,238 bytes   00:58:19.416
11              0:58:51.625     0:05:53.583     23,936 kbps     46,818 kbps     01:03:53.416    40,364 kbps     01:03:51.208    36,907 kbps     01:03:46.166    124,666 bytes   564,790 bytes   01:03:09.958
12              1:04:45.208     0:06:22.166     28,125 kbps     46,640 kbps     01:10:16.375    39,744 kbps     01:10:12.958    36,493 kbps     01:08:09.833    146,484 bytes   652,430 bytes   01:06:38.333
13              1:11:07.375     0:05:51.833     28,305 kbps     43,479 kbps     01:13:48.541    38,729 kbps     01:15:01.750    37,093 kbps     01:14:58.458    147,421 bytes   599,559 bytes   01:14:48.958
14              1:16:59.208     0:04:15.458     24,889 kbps     42,080 kbps     01:17:52.000    37,598 kbps     01:17:50.833    35,252 kbps     01:17:50.708    129,631 bytes   481,896 bytes   01:20:44.958
15              1:21:14.666     0:07:24.083     20,210 kbps     42,448 kbps     01:26:08.958    32,149 kbps     01:21:37.500    28,348 kbps     01:21:34.875    105,260 bytes   507,626 bytes   01:26:08.041
16              1:28:38.750     0:05:26.958     24,008 kbps     42,870 kbps     01:30:00.833    35,972 kbps     01:30:00.791    33,932 kbps     01:29:57.791    125,044 bytes   581,762 bytes   01:33:03.083
17              1:34:05.708     0:04:40.333     10,106 kbps     18,262 kbps     01:36:53.666    16,912 kbps     01:36:50.416    16,282 kbps     01:36:47.666    52,645 bytes    239,132 bytes   01:36:53.708
STREAM DIAGNOSTICS:
00021.M2TS      4113 (0x1011)   0x1B            AVC                                     5925.958                26,031                  19,282,350,007  104,878,704
00021.M2TS      4352 (0x1100)   0x85            DTS-HD HR       deu (German)            5925.958                2,046                   1,515,581,320   8,889,040
00021.M2TS      4353 (0x1101)   0x85            DTS-HD HR       eng (English)           5925.958                2,046                   1,515,581,320   8,889,040
00021.M2TS      4608 (0x1200)   0x90            PGS             deu (German)            5925.958                16                      11,657,641      66,254
00021.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5925.958                1                       928,255         5,345
post #1365 of 5099 Old 03-14-2010, 07:30 AM
multix's Avatar
Anybody there will post the Specifications on Toy Story 1 and 2 both from US and UK Thanks
multix is offline
post #1366 of 5099 Old 03-16-2010, 01:14 AM
msgohan's Avatar
Originally Posted by Stephen Dawson View Post
The Australian version is also, um, blessed with a planet-saving 20% reduced carbon footprint in the packaging!
Surely they'd be better off using the thinner American-style cases if that were their goal?
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #1367 of 5099 Old 03-16-2010, 01:29 AM
Oh, goodness no. Couldn't have that because then the legally required ratings logos (G, PG, M, MA, R & X) couldn't fit on!
I'd have a lot more effective shelf space if we could have the thin cases.
Stephen Dawson
hifi-writer.com
post #1368 of 5099 Old 03-16-2010, 11:17 AM
themike5000's Avatar
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:30:55 19,484,811,264  24,834,982,480  28.57   23.52   DTS-HD Master 5.1 2586Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:
Disc Size:      24,834,982,480 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:30:55 (h:m:s)
Total Bitrate:          28.57 Mbps
VIDEO:
VC-1 Video              23516 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         2586 kbps       5.1 / 48 kHz / 2586 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           Dutch           14.283 kbps
Presentation Graphics           Dutch           43.683 kbps
FILES:
00029.M2TS      0:00:00.000     1:30:55.450     19,484,811,264  28,573
CHAPTERS:
1               0:00:00.000     0:06:26.094     20,938 kbps     50,321 kbps     00:05:51.309    39,199 kbps     00:05:50.308    36,604 kbps     00:03:28.875    109,150 bytes   712,417 bytes   00:04:04.035
2               0:06:26.094     0:03:45.725     18,618 kbps     41,021 kbps     00:07:19.772    35,986 kbps     00:07:16.978    31,193 kbps     00:07:14.100    97,067 bytes    508,492 bytes   00:09:59.181
3               0:10:11.819     0:04:06.788     15,727 kbps     34,383 kbps     00:11:38.114    29,095 kbps     00:11:37.488    24,212 kbps     00:11:37.405    81,992 bytes    523,443 bytes   00:11:40.950
4               0:14:18.607     0:03:22.619     14,444 kbps     33,253 kbps     00:14:18.607    24,606 kbps     00:14:18.607    22,016 kbps     00:15:48.572    75,303 bytes    530,001 bytes   00:14:20.109
5               0:17:41.226     0:04:08.331     16,383 kbps     41,171 kbps     00:17:55.866    37,355 kbps     00:17:54.907    31,282 kbps     00:17:54.907    85,412 bytes    524,176 bytes   00:17:58.327
6               0:21:49.558     0:03:51.314     24,419 kbps     50,812 kbps     00:22:38.273    39,203 kbps     00:24:07.487    34,907 kbps     00:24:05.402    127,307 bytes   679,584 bytes   00:25:24.523
7               0:25:40.872     0:04:37.527     26,961 kbps     54,065 kbps     00:27:56.925    38,180 kbps     00:27:41.659    34,890 kbps     00:29:38.359    140,560 bytes   636,731 bytes   00:27:49.709
8               0:30:18.399     0:03:46.643     21,369 kbps     54,502 kbps     00:32:46.547    33,290 kbps     00:32:46.547    30,605 kbps     00:32:37.789    111,408 bytes   654,979 bytes   00:32:46.589
9               0:34:05.043     0:02:16.761     21,794 kbps     31,953 kbps     00:35:31.587    29,668 kbps     00:34:22.185    26,716 kbps     00:34:20.058    113,624 bytes   548,418 bytes   00:36:21.804
10              0:36:21.804     0:04:28.184     19,868 kbps     51,169 kbps     00:36:43.159    39,405 kbps     00:36:40.656    35,356 kbps     00:37:18.319    103,581 bytes   709,620 bytes   00:36:27.685
11              0:40:49.989     0:04:57.755     26,312 kbps     50,574 kbps     00:44:55.317    38,469 kbps     00:44:06.268    36,518 kbps     00:44:05.768    137,178 bytes   724,113 bytes   00:44:11.273
12              0:45:47.745     0:03:14.277     29,705 kbps     51,814 kbps     00:45:52.166    39,461 kbps     00:45:50.664    36,574 kbps     00:46:57.689    154,869 bytes   670,898 bytes   00:47:26.552
13              0:49:02.022     0:04:32.188     22,298 kbps     47,599 kbps     00:53:32.459    37,932 kbps     00:51:24.831    35,152 kbps     00:53:23.909    116,254 bytes   623,389 bytes   00:50:49.755
14              0:53:34.210     0:04:42.573     26,516 kbps     53,039 kbps     00:56:44.192    38,728 kbps     00:53:50.852    36,070 kbps     00:53:51.102    138,241 bytes   653,654 bytes   00:55:10.640
15              0:58:16.784     0:03:21.743     20,443 kbps     42,820 kbps     00:59:18.596    31,691 kbps     00:59:10.129    30,150 kbps     00:59:10.171    106,579 bytes   580,099 bytes   00:59:18.638
16              1:01:38.528     0:02:34.654     27,240 kbps     49,822 kbps     01:03:10.912    39,400 kbps     01:03:19.879    35,883 kbps     01:02:48.222    142,017 bytes   688,963 bytes   01:03:20.922
17              1:04:13.182     0:04:18.925     25,851 kbps     54,320 kbps     01:06:00.873    39,029 kbps     01:04:19.772    36,524 kbps     01:06:31.696    134,774 bytes   848,156 bytes   01:06:53.134
18              1:08:32.108     0:02:19.931     25,224 kbps     48,478 kbps     01:08:58.384    36,495 kbps     01:08:43.994    34,880 kbps     01:08:38.197    131,504 bytes   670,504 bytes   01:09:55.774
19              1:10:52.039     0:09:16.305     27,946 kbps     56,205 kbps     01:17:00.824    39,247 kbps     01:16:27.457    35,393 kbps     01:13:42.668    145,699 bytes   756,040 bytes   01:15:59.513
20              1:20:08.345     0:10:47.104     27,155 kbps     39,039 kbps     01:21:38.268    36,374 kbps     01:23:08.900    35,186 kbps     01:23:07.857    141,594 bytes   650,578 bytes   01:24:52.128
STREAM DIAGNOSTICS:
00029.M2TS      4113 (0x1011)   0xEA            VC-1                                    5455.367                23,517                  16,036,504,424  87,233,635
00029.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5455.367                640                     436,436,480     2,557,245
00029.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           5455.367                2,586                   1,763,652,244   10,433,712
00029.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5455.367                224                     152,767,104     852,495
00029.M2TS      4608 (0x1200)   0x90            PGS             nld (Dutch)             5455.367                14                      9,740,224       55,605
00029.M2TS      4609 (0x1201)   0x90            PGS             nld (Dutch)             5455.367                44                      29,789,139      167,919
Its actually a decent transfer. Compared to other releases with screens here:
http://www.hd-compare.com/2009/05/ra...ohn-rambo.html
themike5000 is offline
post #1369 of 5099 Old 03-16-2010, 02:46 PM - Thread Starter
[US] In the Loop (Additional Details)
Studio: MPI
UPC: 030306184098
Release Date: 2010-01-12
Aspect Ratio: 1.85:1
The LPCM 2.0 track is a stereo mix of main title audio.
Code:
        Total   Video
[US] In the Loop                                                AVC     1:45:56 19,810,639,872  24,413,535,321  24.93   20.00   DTS-HD Master 5.1 1675Kbps (48kHz/16-bit) LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     IN THE LOOP
Disc Size:      24,413,535,321 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:45:56 (h:m:s)
Total Bitrate:          24.93 Mbps
VIDEO:
AUDIO:
DTS-HD Master Audio             English         1675 kbps       5.1 / 48 kHz / 1675 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         78.750 kbps
Presentation Graphics           Spanish         71.945 kbps
FILES:
00000.M2TS      0:00:00.000     1:45:56.808     19,810,639,872  24,932
CHAPTERS:
1               0:00:00.000     0:05:37.628     19,696 kbps     30,695 kbps     00:04:01.741    26,399 kbps     00:00:37.871    24,773 kbps     00:03:54.776    102,671 bytes   344,249 bytes   00:02:50.628
2               0:05:37.628     0:06:27.261     20,354 kbps     38,021 kbps     00:11:01.202    29,849 kbps     00:07:03.673    26,318 kbps     00:06:59.669    106,115 bytes   273,660 bytes   00:10:38.637
3               0:12:04.890     0:05:15.231     20,166 kbps     32,788 kbps     00:16:34.326    25,032 kbps     00:16:30.447    23,860 kbps     00:16:27.569    105,137 bytes   286,854 bytes   00:15:43.317
4               0:17:20.122     0:03:50.730     19,928 kbps     29,099 kbps     00:19:07.271    25,067 kbps     00:19:05.686    24,503 kbps     00:19:00.848    103,894 bytes   262,210 bytes   00:17:26.128
5               0:21:10.852     0:04:53.042     20,729 kbps     30,219 kbps     00:22:28.680    25,507 kbps     00:21:57.274    24,042 kbps     00:21:53.979    108,070 bytes   273,841 bytes   00:23:00.754
6               0:26:03.895     0:06:07.283     19,686 kbps     31,840 kbps     00:27:02.871    26,963 kbps     00:27:12.881    23,832 kbps     00:27:06.875    102,633 bytes   342,642 bytes   00:31:00.149
7               0:32:11.179     0:06:09.577     19,360 kbps     29,426 kbps     00:33:45.523    26,025 kbps     00:32:54.514    22,823 kbps     00:34:12.008    100,936 bytes   287,415 bytes   00:32:43.378
8               0:38:20.756     0:06:08.284     19,812 kbps     30,700 kbps     00:42:04.313    25,900 kbps     00:38:21.048    24,631 kbps     00:43:52.379    103,291 bytes   304,203 bytes   00:40:49.280
9               0:44:29.041     0:04:32.230     20,675 kbps     33,679 kbps     00:44:53.107    28,183 kbps     00:47:36.019    24,838 kbps     00:47:31.014    107,790 bytes   288,749 bytes   00:44:55.401
10              0:49:01.271     0:03:38.927     21,016 kbps     30,064 kbps     00:51:47.687    25,489 kbps     00:51:36.718    25,207 kbps     00:51:34.758    109,566 bytes   268,835 bytes   00:49:48.527
11              0:52:40.198     0:06:32.433     19,912 kbps     30,562 kbps     00:54:20.548    25,479 kbps     00:53:36.922    24,503 kbps     00:52:55.505    103,811 bytes   286,150 bytes   00:57:03.586
12              0:59:12.632     0:05:31.914     20,040 kbps     32,385 kbps     01:00:13.901    24,151 kbps     01:00:09.897    23,090 kbps     01:03:42.860    104,481 bytes   296,616 bytes   01:00:33.212
13              1:04:44.547     0:05:25.491     19,832 kbps     31,624 kbps     01:09:06.475    27,171 kbps     01:09:06.183    25,355 kbps     01:09:02.304    103,393 bytes   277,167 bytes   01:07:00.975
14              1:10:10.039     0:05:46.846     19,964 kbps     32,719 kbps     01:13:27.111    26,315 kbps     01:11:00.130    24,815 kbps     01:10:55.250    104,084 bytes   281,030 bytes   01:10:11.248
15              1:15:56.885     0:05:42.008     21,171 kbps     31,135 kbps     01:17:56.046    26,485 kbps     01:19:39.441    24,295 kbps     01:19:37.355    110,378 bytes   294,203 bytes   01:15:58.887
16              1:21:38.894     0:05:07.140     21,583 kbps     31,258 kbps     01:22:26.149    25,413 kbps     01:26:28.433    24,744 kbps     01:26:23.344    112,526 bytes   291,467 bytes   01:22:27.108
17              1:26:46.034     0:04:30.186     21,871 kbps     29,271 kbps     01:27:39.379    24,614 kbps     01:26:56.920    24,308 kbps     01:26:57.045    114,026 bytes   246,641 bytes   01:30:56.409
18              1:31:16.220     0:09:03.876     21,097 kbps     28,360 kbps     01:32:04.518    25,513 kbps     01:32:13.528    24,773 kbps     01:37:14.954    109,992 bytes   292,550 bytes   01:36:31.452
19              1:40:20.097     0:05:36.711     13,545 kbps     22,612 kbps     01:43:22.154    19,945 kbps     01:44:03.487    19,229 kbps     01:43:59.608    70,625 bytes    350,709 bytes   01:44:57.374
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6356.684                20,000                  15,891,494,249  86,456,429
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6356.684                1,675                   1,330,610,808   8,194,145
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6356.684                1,542                   1,225,592,968   7,628,172
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6356.684                79                      62,574,730      359,793
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6356.684                72                      57,167,438      328,905
post #1370 of 5099 Old 03-16-2010, 02:48 PM - Thread Starter
[US] The Fourth Kind (Additional Details)
Studio: Universal
UPC: 025192040566
Release Date: 2010-03-16
English DD 2.0 track is descriptive audio.
Code:
        Total   Video
[US] The Fourth Kind                                            VC-1    1:38:00 27,216,273,408  29,436,798,393  37.03   29.53   DTS-HD Master 5.1 3631Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FOURTH_KIND
Disc Size:      29,436,798,393 bytes
Protection:     AACS
BD-Java:        Yes
D-BOX Motion:   Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:38:00 (h:m:s)
Total Bitrate:          37.03 Mbps
VIDEO:
VC-1 Video              29529 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3631 kbps       5.1 / 48 kHz / 3631 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         43.722 kbps
Presentation Graphics           French          40.912 kbps
Presentation Graphics           French          3.967 kbps
Presentation Graphics           Spanish         38.721 kbps
Presentation Graphics           Spanish         1.919 kbps
FILES:
00010.M2TS      0:00:00.000     1:38:00.499     27,216,273,408  37,026
CHAPTERS:
1               0:00:00.000     0:01:42.227     22,239 kbps     47,554 kbps     00:00:50.216    35,984 kbps     00:01:14.407    34,899 kbps     00:01:15.575    117,719 bytes   699,175 bytes   00:00:51.051
2               0:01:42.227     0:06:34.477     30,563 kbps     44,504 kbps     00:06:49.575    36,799 kbps     00:06:03.988    35,759 kbps     00:02:20.473    159,712 bytes   730,361 bytes   00:06:50.201
3               0:08:16.704     0:05:36.502     31,444 kbps     41,996 kbps     00:09:50.923    35,317 kbps     00:09:46.961    34,482 kbps     00:11:22.139    163,933 bytes   540,894 bytes   00:09:56.679
4               0:13:53.207     0:06:01.569     31,953 kbps     42,357 kbps     00:19:21.034    37,491 kbps     00:19:20.951    36,385 kbps     00:19:20.701    166,589 bytes   529,643 bytes   00:15:31.138
5               0:19:54.776     0:04:30.520     29,650 kbps     49,232 kbps     00:22:31.141    37,000 kbps     00:23:23.568    35,416 kbps     00:23:18.522    154,582 bytes   662,257 bytes   00:22:47.949
6               0:24:25.297     0:04:07.664     29,433 kbps     45,153 kbps     00:28:04.307    35,657 kbps     00:24:53.742    34,094 kbps     00:24:48.778    153,450 bytes   694,909 bytes   00:25:36.660
7               0:28:32.961     0:05:04.512     31,779 kbps     51,304 kbps     00:28:37.924    38,002 kbps     00:29:35.482    35,404 kbps     00:33:06.609    165,682 bytes   750,652 bytes   00:28:37.966
8               0:33:37.473     0:03:19.282     32,393 kbps     42,684 kbps     00:36:10.126    37,328 kbps     00:34:23.895    35,082 kbps     00:34:23.895    168,884 bytes   608,344 bytes   00:34:24.937
9               0:36:56.756     0:06:06.741     30,747 kbps     42,658 kbps     00:39:24.737    36,472 kbps     00:41:17.808    34,874 kbps     00:41:13.137    160,593 bytes   769,472 bytes   00:39:25.237
10              0:43:03.497     0:04:26.182     32,360 kbps     41,111 kbps     00:46:14.271    36,101 kbps     00:45:18.424    34,562 kbps     00:46:07.431    168,711 bytes   527,574 bytes   00:43:11.505
11              0:47:29.680     0:05:12.895     30,502 kbps     45,367 kbps     00:47:33.308    35,514 kbps     00:47:42.401    33,840 kbps     00:49:46.942    159,022 bytes   859,766 bytes   00:52:42.576
12              0:52:42.576     0:04:02.867     31,536 kbps     50,007 kbps     00:55:23.778    34,809 kbps     00:55:13.184    33,623 kbps     00:54:17.254    164,415 bytes   637,210 bytes   00:52:42.701
13              0:56:45.443     0:04:15.338     29,890 kbps     42,151 kbps     01:00:13.318    34,548 kbps     00:57:35.493    33,959 kbps     00:57:30.947    156,524 bytes   761,438 bytes   01:01:00.782
14              1:01:00.782     0:04:15.672     32,064 kbps     46,662 kbps     01:02:19.110    36,586 kbps     01:02:15.356    34,451 kbps     01:04:56.684    167,167 bytes   605,559 bytes   01:01:00.823
15              1:05:16.454     0:04:31.896     30,523 kbps     47,265 kbps     01:07:47.271    35,914 kbps     01:05:49.278    35,087 kbps     01:08:46.539    159,133 bytes   701,453 bytes   01:09:48.350
16              1:09:48.350     0:04:26.891     31,390 kbps     41,292 kbps     01:11:52.641    35,183 kbps     01:12:33.932    34,414 kbps     01:12:33.932    163,654 bytes   637,717 bytes   01:09:48.392
17              1:14:15.242     0:06:23.132     28,320 kbps     46,703 kbps     01:17:39.071    35,110 kbps     01:14:40.851    33,525 kbps     01:14:21.957    148,164 bytes   694,393 bytes   01:17:39.112
18              1:20:38.375     0:06:52.161     32,018 kbps     41,276 kbps     01:20:38.458    35,354 kbps     01:20:38.375    34,528 kbps     01:20:38.375    166,926 bytes   441,048 bytes   01:21:31.177
19              1:27:30.536     0:04:50.832     29,473 kbps     41,846 kbps     01:28:23.423    36,014 kbps     01:30:26.421    35,741 kbps     01:30:26.421    153,656 bytes   501,159 bytes   01:32:03.935
20              1:32:21.369     0:05:39.130     10,377 kbps     21,536 kbps     01:37:53.492    16,659 kbps     01:35:50.786    16,373 kbps     01:35:49.243    54,182 bytes    383,763 bytes   01:37:57.454
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    5880.416                29,529                  21,705,532,184  118,050,114
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5880.416                3,631                   2,668,915,532   15,426,338
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           5880.416                768                     564,528,128     3,307,782
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            5880.416                768                     564,528,128     3,307,782
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5880.416                192                     141,132,288     918,830
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5880.416                44                      32,138,672      184,583
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5880.416                39                      28,462,036      162,777
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5880.416                41                      30,072,976      171,548
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5880.416                2                       1,410,348       8,093
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            5880.416                4                       2,916,254       16,543
post #1371 of 5099 Old 03-16-2010, 02:51 PM - Thread Starter
[US] Astro Boy (Additional Details)
Studio: Summit
UPC: 025192058493
Code:
        Total   Video
[US] Astro Boy                                                  AVC     1:33:48 25,403,062,272  33,359,045,665  36.11   29.59   DTS-HD Master 5.1 3957Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ASTRO_BOY
Disc Size:      33,359,045,665 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:33:48 (h:m:s)
Total Bitrate:          36.11 Mbps
VIDEO:
MPEG-4 AVC Video        29586 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3957 kbps       5.1 / 48 kHz / 3957 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         33.871 kbps
Presentation Graphics           Spanish         30.774 kbps
FILES:
00001.M2TS      0:00:00.000     1:33:48.623     25,403,062,272  36,106
CHAPTERS:
1               0:00:00.000     0:05:26.492     29,356 kbps     48,753 kbps     00:01:26.544    36,763 kbps     00:01:22.540    35,692 kbps     00:01:17.535    153,032 bytes   566,388 bytes   00:01:34.594
2               0:05:26.492     0:07:14.016     30,392 kbps     38,541 kbps     00:11:50.167    34,918 kbps     00:11:35.945    34,656 kbps     00:11:35.945    158,450 bytes   480,501 bytes   00:06:54.205
3               0:12:40.509     0:05:01.092     29,752 kbps     41,231 kbps     00:15:54.495    36,140 kbps     00:15:50.491    34,499 kbps     00:15:49.323    155,115 bytes   697,200 bytes   00:12:42.428
4               0:17:41.602     0:04:59.549     30,451 kbps     37,578 kbps     00:20:35.317    35,079 kbps     00:19:23.620    34,622 kbps     00:18:53.757    158,757 bytes   567,410 bytes   00:20:33.357
5               0:22:41.151     0:04:15.338     30,168 kbps     37,761 kbps     00:26:36.928    35,296 kbps     00:25:49.130    34,961 kbps     00:25:45.877    157,282 bytes   486,066 bytes   00:25:42.290
6               0:26:56.489     0:02:33.903     29,403 kbps     36,357 kbps     00:27:20.138    34,434 kbps     00:28:15.902    32,412 kbps     00:28:13.942    153,295 bytes   407,869 bytes   00:27:18.553
7               0:29:30.393     0:04:04.369     29,202 kbps     37,009 kbps     00:30:34.165    34,389 kbps     00:30:12.602    33,088 kbps     00:31:08.324    152,247 bytes   448,307 bytes   00:30:34.999
8               0:33:34.762     0:03:50.021     31,031 kbps     38,195 kbps     00:33:57.326    35,123 kbps     00:33:38.224    34,850 kbps     00:33:36.347    161,780 bytes   795,383 bytes   00:34:55.510
9               0:37:24.784     0:04:49.455     29,682 kbps     40,830 kbps     00:40:17.748    35,559 kbps     00:40:13.786    33,981 kbps     00:40:12.660    154,749 bytes   920,809 bytes   00:40:18.707
10              0:42:14.240     0:05:32.081     29,164 kbps     39,448 kbps     00:43:51.629    35,551 kbps     00:46:31.288    34,426 kbps     00:46:26.283    152,047 bytes   727,939 bytes   00:42:49.525
11              0:47:46.321     0:04:32.730     31,493 kbps     43,770 kbps     00:48:35.746    35,663 kbps     00:49:06.026    35,238 kbps     00:49:01.021    164,188 bytes   899,743 bytes   00:48:38.040
12              0:52:19.052     0:05:05.305     28,542 kbps     38,204 kbps     00:52:41.867    34,970 kbps     00:52:32.649    34,556 kbps     00:52:28.562    148,805 bytes   933,607 bytes   00:52:40.907
13              0:57:24.357     0:02:50.253     31,222 kbps     39,623 kbps     00:59:33.528    35,526 kbps     00:58:23.875    34,850 kbps     00:58:44.395    162,780 bytes   691,382 bytes   00:58:29.881
14              1:00:14.611     0:06:34.394     32,255 kbps     39,790 kbps     01:03:32.517    35,553 kbps     01:00:59.864    35,073 kbps     01:00:54.067    168,164 bytes   789,180 bytes   01:04:21.941
15              1:06:49.005     0:06:11.954     27,857 kbps     37,198 kbps     01:12:54.370    34,415 kbps     01:12:42.775    33,270 kbps     01:12:38.103    145,233 bytes   539,267 bytes   01:12:32.848
16              1:13:00.959     0:05:19.068     32,218 kbps     38,992 kbps     01:17:21.345    35,596 kbps     01:18:12.688    35,087 kbps     01:18:07.724    167,969 bytes   734,163 bytes   01:18:19.069
17              1:18:20.028     0:03:55.318     34,238 kbps     39,145 kbps     01:21:27.549    35,597 kbps     01:18:37.254    35,092 kbps     01:21:39.686    178,501 bytes   773,956 bytes   01:18:42.175
18              1:22:15.347     0:11:33.275     24,315 kbps     39,353 kbps     01:23:18.576    35,684 kbps     01:23:16.366    35,165 kbps     01:23:49.065    126,773 bytes   776,344 bytes   01:23:21.371
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     5628.456                29,587                  20,816,055,406  113,208,334
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5628.456                3,958                   2,784,378,464   16,008,620
00001.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           5628.456                640                     450,291,200     2,638,425
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5628.456                34                      23,830,917      138,854
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5628.456                31                      21,651,964      124,794
post #1372 of 5099 Old 03-17-2010, 06:18 PM
2012 - 2009 - Australian version
Distributed by Sony Pictures Home Entertainment Australia
Region free, confirmed with AnyDVD HD
This appears to be a Euro disc as well. Has an extensive package of subtitles which don't appear on the US disc.
One interesting aspect of this disc is that the two playlist files for the movie which are actually used have a different number of chapters in each. For regular playback there are 16 chapters, as is commonly used on Sony titles. For the BonusView PIP version there are 39 chapters. In this case, the 39 chapter marks are set so that they are just a couple of seconds ahead of the PIP window popping up. In other words, you can use these chapters to skip from PIP item to PIP item. I've shown both playlists below.
Normal playback:
Code:
        Total   Video
00001.MPLS                                                      AVC     2:37:49 35,770,650,624  47,465,509,671  30.22   21.98   DTS-HD Master 5.1 2155Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     2012
Disc Size:      47,465,509,671 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:37:49 (h:m:s)
Total Bitrate:          30.22 Mbps
VIDEO:
MPEG-4 AVC Video        21985 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
* MPEG-4 AVC Video      962 kbps            480p / 23.976 fps / 16:9 / High Profile 3.2
AUDIO:
DTS-HD Master Audio             English         2155 kbps       5.1 / 48 kHz / 2155 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          2110 kbps       5.1 / 48 kHz / 2110 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
* DTS Express                   English         192 kbps        2.0 / 48 kHz / 192 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         33.474 kbps
Presentation Graphics           English         26.587 kbps
Presentation Graphics           French          24.825 kbps
Presentation Graphics           Arabic          16.667 kbps
Presentation Graphics           Danish          27.893 kbps
Presentation Graphics           Dutch           31.081 kbps
Presentation Graphics           Finnish         26.482 kbps
Presentation Graphics           Hindi           30.308 kbps
Presentation Graphics           Norwegian       25.202 kbps
Presentation Graphics           Swedish         27.834 kbps
Presentation Graphics           English         53.563 kbps
Presentation Graphics           French          46.155 kbps
Presentation Graphics           Dutch           47.069 kbps
* Presentation Graphics         English         20.621 kbps
* Presentation Graphics         French          16.697 kbps
* Presentation Graphics         Dutch           35.083 kbps
FILES:
00740.M2TS      0:00:00.000     2:37:49.460     35,770,650,624  30,220
CHAPTERS:
1               0:00:00.000     0:11:54.672     20,313 kbps     33,735 kbps     00:07:11.722    31,946 kbps     00:01:18.036    29,989 kbps     00:02:39.701    105,896 bytes   370,513 bytes   00:07:22.316
2               0:11:54.672     0:10:03.561     24,830 kbps     36,441 kbps     00:21:43.385    33,494 kbps     00:21:39.298    32,871 kbps     00:11:57.508    129,451 bytes   569,377 bytes   00:21:44.011
3               0:21:58.233     0:06:49.367     24,365 kbps     34,431 kbps     00:22:08.744    32,987 kbps     00:23:24.027    32,646 kbps     00:23:18.355    127,030 bytes   520,160 bytes   00:22:15.292
4               0:28:47.600     0:05:50.475     22,670 kbps     34,460 kbps     00:33:21.082    32,731 kbps     00:32:38.122    31,756 kbps     00:32:33.117    118,189 bytes   375,806 bytes   00:33:22.083
5               0:34:38.076     0:10:10.067     24,775 kbps     34,460 kbps     00:35:49.981    33,026 kbps     00:35:23.204    32,829 kbps     00:35:30.753    129,165 bytes   410,610 bytes   00:35:21.077
6               0:44:48.143     0:10:38.512     27,499 kbps     34,932 kbps     00:51:52.484    33,189 kbps     00:51:48.647    32,995 kbps     00:51:49.397    143,367 bytes   424,876 bytes   00:55:07.053
7               0:55:26.656     0:09:42.748     26,488 kbps     34,823 kbps     00:57:06.881    33,050 kbps     00:58:32.217    32,066 kbps     00:56:41.648    138,098 bytes   463,195 bytes   00:57:06.005
8               1:05:09.405     0:11:15.883     22,041 kbps     34,235 kbps     01:06:58.389    31,837 kbps     01:06:41.497    29,625 kbps     01:06:56.470    114,914 bytes   370,038 bytes   01:14:26.545
9               1:16:25.289     0:08:37.225     19,934 kbps     31,157 kbps     01:20:47.592    29,681 kbps     01:20:43.964    27,965 kbps     01:20:45.966    103,925 bytes   368,909 bytes   01:20:48.593
10              1:25:02.514     0:11:32.817     21,655 kbps     34,203 kbps     01:33:19.302    32,646 kbps     01:28:46.612    31,584 kbps     01:28:41.983    112,901 bytes   367,824 bytes   01:33:20.052
11              1:36:35.331     0:10:11.902     18,670 kbps     33,390 kbps     01:37:17.456    30,314 kbps     01:37:03.234    29,757 kbps     01:36:58.312    97,337 bytes    338,047 bytes   01:37:18.457
12              1:46:47.234     0:10:02.560     20,537 kbps     33,946 kbps     01:52:17.605    32,785 kbps     01:52:14.602    28,462 kbps     01:53:30.762    107,068 bytes   333,891 bytes   01:52:16.646
13              1:56:49.794     0:08:03.357     21,343 kbps     32,759 kbps     02:01:10.388    29,986 kbps     02:04:22.913    27,425 kbps     02:04:17.825    111,273 bytes   303,310 bytes   01:57:17.697
14              2:04:53.152     0:11:46.831     23,543 kbps     33,660 kbps     02:12:59.179    32,642 kbps     02:12:24.311    31,715 kbps     02:12:20.015    122,743 bytes   360,102 bytes   02:13:47.519
15              2:16:39.983     0:06:41.609     24,632 kbps     35,248 kbps     02:17:23.693    31,753 kbps     02:20:52.777    31,159 kbps     02:17:14.809    128,422 bytes   341,561 bytes   02:17:36.623
16              2:23:21.593     0:14:27.867     13,588 kbps     33,957 kbps     02:28:01.330    33,058 kbps     02:28:07.211    32,958 kbps     02:28:07.211    70,843 bytes    472,887 bytes   02:28:10.006
PIP playback
Code:
        Total   Video
00632.MPLS                                                      AVC     2:37:49 35,770,650,624  47,465,509,671  30.22   21.98   DTS-HD Master 5.1 2155Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     2012
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
VIDEO:
AUDIO:
* Dolby Digital Audio           English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB
SUBTITLES:
* Presentation Graphics         English         33.474 kbps
* Presentation Graphics         English         26.587 kbps
* Presentation Graphics         French          24.825 kbps
* Presentation Graphics         Arabic          16.667 kbps
* Presentation Graphics         Danish          27.893 kbps
* Presentation Graphics         Dutch           31.081 kbps
* Presentation Graphics         Finnish         26.482 kbps
* Presentation Graphics         Hindi           30.308 kbps
* Presentation Graphics         Norwegian       25.202 kbps
* Presentation Graphics         Swedish         27.834 kbps
* Presentation Graphics         English         53.563 kbps
* Presentation Graphics         French          46.155 kbps
* Presentation Graphics         Dutch           47.069 kbps
FILES:
CHAPTERS:
1               0:00:00.000     0:01:17.994     10,594 kbps     31,068 kbps     00:01:11.237    24,641 kbps     00:01:10.528    22,839 kbps     00:01:07.984    55,202 bytes    228,632 bytes   00:01:17.077
2               0:01:17.994     0:00:51.342     26,977 kbps     33,526 kbps     00:01:45.146    31,946 kbps     00:01:18.036    29,355 kbps     00:01:17.994    140,644 bytes   326,607 bytes   00:01:34.719
3               0:02:09.337     0:00:59.142     23,553 kbps     33,295 kbps     00:02:40.702    30,951 kbps     00:02:39.075    29,989 kbps     00:02:39.701    122,794 bytes   269,568 bytes   00:02:12.715
4               0:03:08.479     0:01:48.942     21,586 kbps     33,602 kbps     00:04:35.775    30,102 kbps     00:04:42.573    28,605 kbps     00:04:39.195    112,540 bytes   277,998 bytes   00:03:14.402
5               0:04:57.422     0:00:49.758     20,176 kbps     24,303 kbps     00:05:34.751    22,778 kbps     00:05:02.677    22,404 kbps     00:05:02.802    105,187 bytes   274,944 bytes   00:05:03.845
6               0:05:47.180     0:01:38.014     19,992 kbps     33,735 kbps     00:07:11.722    28,022 kbps     00:07:11.722    27,349 kbps     00:07:14.350    104,227 bytes   370,513 bytes   00:07:22.316
7               0:07:25.194     0:03:18.156     21,489 kbps     33,136 kbps     00:09:29.610    30,246 kbps     00:09:28.192    29,208 kbps     00:09:20.351    112,032 bytes   352,096 bytes   00:08:59.789
8               0:10:43.351     0:01:58.409     21,453 kbps     33,669 kbps     00:12:04.306    32,964 kbps     00:12:02.638    32,871 kbps     00:11:57.508    111,846 bytes   323,493 bytes   00:11:53.671
9               0:12:41.761     0:01:44.687     24,304 kbps     34,476 kbps     00:14:06.804    32,973 kbps     00:13:54.834    32,453 kbps     00:13:49.912    126,710 bytes   479,284 bytes   00:13:51.872
10              0:14:26.448     0:03:52.231     24,918 kbps     34,685 kbps     00:15:31.305    33,084 kbps     00:15:32.181    32,138 kbps     00:15:27.801    129,913 bytes   429,427 bytes   00:15:26.008
11              0:18:18.680     0:07:20.398     25,542 kbps     36,441 kbps     00:21:43.385    33,494 kbps     00:21:39.298    32,646 kbps     00:23:18.355    133,166 bytes   569,377 bytes   00:21:44.011
12              0:25:39.079     0:05:10.393     21,572 kbps     33,658 kbps     00:28:04.265    32,742 kbps     00:28:02.055    30,743 kbps     00:27:58.093    112,469 bytes   401,897 bytes   00:27:23.058
13              0:30:49.472     0:05:21.029     25,367 kbps     34,460 kbps     00:33:21.082    33,026 kbps     00:35:23.204    32,829 kbps     00:35:30.753    132,250 bytes   410,610 bytes   00:35:21.077
14              0:36:10.501     0:02:43.204     24,698 kbps     34,274 kbps     00:36:20.219    32,694 kbps     00:36:20.303    31,962 kbps     00:36:15.423    128,764 bytes   406,856 bytes   00:36:30.479
15              0:38:53.706     0:03:25.288     22,944 kbps     31,874 kbps     00:39:24.445    29,649 kbps     00:42:11.904    28,423 kbps     00:42:08.984    119,621 bytes   393,728 bytes   00:41:44.752
16              0:42:18.994     0:02:25.019     24,659 kbps     33,110 kbps     00:43:43.495    30,577 kbps     00:44:08.771    29,865 kbps     00:44:32.795    128,561 bytes   361,317 bytes   00:43:27.604
17              0:44:44.014     0:04:24.055     28,065 kbps     34,227 kbps     00:44:58.570    32,876 kbps     00:44:48.727    32,202 kbps     00:47:19.503    146,318 bytes   365,437 bytes   00:46:59.066
18              0:49:08.070     0:03:09.022     29,170 kbps     34,932 kbps     00:51:52.484    33,189 kbps     00:51:48.647    32,995 kbps     00:51:49.397    152,078 bytes   410,364 bytes   00:51:54.402
19              0:52:17.092     0:04:33.815     25,362 kbps     34,292 kbps     00:55:37.709    32,832 kbps     00:55:06.011    31,931 kbps     00:56:40.897    132,228 bytes   452,127 bytes   00:55:38.668
20              0:56:50.907     0:01:10.195     25,594 kbps     34,823 kbps     00:57:06.881    32,679 kbps     00:57:04.963    30,203 kbps     00:57:03.420    133,436 bytes   463,195 bytes   00:57:06.005
21              0:58:01.102     0:02:08.586     24,887 kbps     33,861 kbps     01:00:01.139    33,050 kbps     00:58:32.217    31,218 kbps     00:58:27.754    129,749 bytes   386,767 bytes   00:59:07.001
22              1:00:09.689     0:03:21.701     27,537 kbps     34,559 kbps     01:01:26.683    32,979 kbps     01:01:47.078    31,950 kbps     01:01:42.198    143,564 bytes   446,563 bytes   01:01:31.396
23              1:03:31.390     0:03:45.850     25,045 kbps     34,235 kbps     01:06:58.389    31,837 kbps     01:06:41.497    30,286 kbps     01:04:16.978    130,575 bytes   357,955 bytes   01:06:59.348
24              1:07:17.241     0:02:50.962     23,271 kbps     30,483 kbps     01:08:18.344    27,516 kbps     01:09:11.021    27,410 kbps     01:09:17.820    121,324 bytes   275,228 bytes   01:10:07.995
25              1:10:08.204     0:03:39.886     21,420 kbps     32,466 kbps     01:10:48.702    29,659 kbps     01:10:09.622    28,422 kbps     01:10:28.390    111,672 bytes   281,240 bytes   01:10:11.624
26              1:13:48.090     0:10:31.339     20,258 kbps     32,163 kbps     01:15:14.510    29,681 kbps     01:20:43.964    27,965 kbps     01:20:45.966    105,618 bytes   370,038 bytes   01:14:26.545
27              1:24:19.429     0:04:50.873     20,723 kbps     33,578 kbps     01:29:04.464    32,646 kbps     01:28:46.612    31,584 kbps     01:28:41.983    108,039 bytes   273,145 bytes   01:26:52.248
28              1:29:10.303     0:02:57.510     22,504 kbps     33,016 kbps     01:31:17.805    30,014 kbps     01:31:17.805    27,821 kbps     01:31:12.925    117,327 bytes   301,557 bytes   01:31:09.755
29              1:32:07.813     0:01:30.381     25,638 kbps     34,203 kbps     01:33:19.302    30,997 kbps     01:33:17.091    30,442 kbps     01:33:11.544    133,665 bytes   367,824 bytes   01:33:20.052
30              1:33:38.195     0:09:10.049     18,763 kbps     33,439 kbps     01:34:28.454    31,885 kbps     01:34:26.952    29,757 kbps     01:36:58.312    97,823 bytes    338,047 bytes   01:37:18.457
31              1:42:48.245     0:05:22.071     18,389 kbps     29,250 kbps     01:44:51.535    25,779 kbps     01:44:08.283    24,171 kbps     01:43:53.977    95,870 bytes    234,194 bytes   01:48:06.480
32              1:48:10.317     0:08:31.427     21,052 kbps     33,946 kbps     01:52:17.605    32,785 kbps     01:52:14.602    28,462 kbps     01:53:30.762    109,753 bytes   333,891 bytes   01:52:16.646
33              1:56:41.744     0:02:58.303     19,920 kbps     29,228 kbps     01:57:16.863    25,879 kbps     01:58:54.043    24,008 kbps     01:58:48.246    103,856 bytes   303,310 bytes   01:57:17.697
34              1:59:40.047     0:07:10.638     21,858 kbps     33,415 kbps     02:05:20.387    30,321 kbps     02:05:17.218    27,425 kbps     02:04:17.825    113,957 bytes   272,026 bytes   01:59:41.465
35              2:06:50.686     0:02:22.225     23,302 kbps     32,625 kbps     02:07:40.903    31,993 kbps     02:07:14.710    30,662 kbps     02:07:13.751    121,487 bytes   326,160 bytes   02:06:57.234
36              2:09:12.911     0:00:35.368     24,940 kbps     32,880 kbps     02:09:41.315    32,098 kbps     02:09:40.689    29,693 kbps     02:09:38.270    130,027 bytes   289,408 bytes   02:09:44.693
37              2:09:48.280     0:03:34.088     23,859 kbps     33,660 kbps     02:12:59.179    32,642 kbps     02:12:24.311    31,715 kbps     02:12:20.015    124,390 bytes   306,075 bytes   02:10:20.896
38              2:13:22.369     0:10:02.935     24,518 kbps     35,248 kbps     02:17:23.693    31,773 kbps     02:14:33.690    31,159 kbps     02:17:14.809    127,827 bytes   360,102 bytes   02:13:47.519
39              2:23:25.305     0:14:24.154     13,625 kbps     33,957 kbps     02:28:01.330    33,058 kbps     02:28:07.211    32,958 kbps     02:28:07.211    71,036 bytes    472,887 bytes   02:28:10.006
Stephen Dawson
hifi-writer.com
post #1373 of 5099 Old 03-19-2010, 10:30 AM
This is the French transfer by Gaumont. I think its a bit too bright and you lose a lot of detail. Comparisons between four versions here: http://www.hd-compare.com/2009/05/fifth-element.html
Code:
        Total   Video
00001.MPLS                                                      AVC     2:06:22 31,480,498,176  33,359,906,138  33.21   28.99   DTS-HD Master 5.1 2430Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      33,359,906,138 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:06:22 (h:m:s)
Total Bitrate:          33.21 Mbps
VIDEO:
MPEG-4 AVC Video        28990 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2430 kbps       5.1 / 48 kHz / 2430 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           Danish          26.284 kbps
Presentation Graphics           Finnish         26.856 kbps
Presentation Graphics           Norwegian       26.631 kbps
Presentation Graphics           Swedish         26.552 kbps
FILES:
00000.M2TS      0:00:00.000     1:34:56.458     23,629,258,752  33,184
00001.M2TS      1:34:56.458     0:31:25.958     7,851,239,424   33,304
CHAPTERS:
1               0:00:00.000     0:06:51.000     28,013 kbps     34,655 kbps     00:05:12.916    33,229 kbps     00:05:09.333    33,019 kbps     00:06:29.083    145,885 bytes   398,695 bytes   00:05:13.791
2               0:06:51.000     0:09:54.000     31,133 kbps     37,047 kbps     00:11:44.333    33,391 kbps     00:11:36.916    33,085 kbps     00:14:46.041    162,153 bytes   394,700 bytes   00:12:00.791
3               0:16:45.000     0:07:26.625     26,882 kbps     34,674 kbps     00:18:46.333    32,933 kbps     00:17:07.791    31,973 kbps     00:17:23.458    140,013 bytes   328,269 bytes   00:17:01.458
4               0:24:11.625     0:07:00.750     29,290 kbps     34,351 kbps     00:30:45.750    33,031 kbps     00:25:51.916    32,865 kbps     00:25:49.041    152,550 bytes   379,766 bytes   00:26:34.541
5               0:31:12.375     0:08:46.041     29,481 kbps     35,489 kbps     00:38:02.458    33,328 kbps     00:37:11.708    32,880 kbps     00:31:13.041    153,545 bytes   378,909 bytes   00:38:32.083
6               0:39:58.416     0:08:11.041     28,448 kbps     33,813 kbps     00:40:22.750    33,013 kbps     00:40:35.333    32,598 kbps     00:40:22.750    148,165 bytes   372,001 bytes   00:40:43.541
7               0:48:09.458     0:09:44.083     27,724 kbps     34,093 kbps     00:57:18.250    33,104 kbps     00:57:11.875    32,907 kbps     00:57:09.791    144,394 bytes   353,727 bytes   00:49:30.250
8               0:57:53.541     0:09:15.000     28,146 kbps     34,360 kbps     01:05:01.875    32,991 kbps     00:58:26.708    31,287 kbps     00:58:23.250    146,594 bytes   368,400 bytes   00:59:17.416
9               1:07:08.541     0:07:44.750     31,348 kbps     34,951 kbps     01:11:23.541    33,084 kbps     01:07:10.833    32,892 kbps     01:10:39.041    163,272 bytes   330,257 bytes   01:11:31.416
10              1:14:53.291     0:07:38.000     28,620 kbps     35,466 kbps     01:16:40.458    33,205 kbps     01:22:12.708    32,989 kbps     01:22:07.541    149,064 bytes   422,623 bytes   01:21:26.708
11              1:22:31.291     0:04:47.625     28,961 kbps     34,102 kbps     01:22:43.958    33,015 kbps     01:26:51.416    32,783 kbps     01:26:47.916    150,837 bytes   380,184 bytes   01:23:49.583
12              1:27:18.916     0:10:29.750     30,324 kbps     34,587 kbps     01:36:24.000    33,172 kbps     01:35:03.166    33,006 kbps     01:34:58.250    157,939 bytes   379,704 bytes   01:30:45.250
13              1:37:48.666     0:06:29.125     32,525 kbps     36,742 kbps     01:41:47.958    33,433 kbps     01:41:43.958    32,999 kbps     01:40:23.583    169,402 bytes   367,132 bytes   01:41:47.041
14              1:44:17.791     0:07:57.375     32,195 kbps     39,228 kbps     01:52:04.083    33,718 kbps     01:52:00.125    33,229 kbps     01:47:42.041    167,684 bytes   374,534 bytes   01:47:51.958
15              1:52:15.166     0:09:12.666     32,323 kbps     36,480 kbps     01:54:19.375    33,624 kbps     01:54:15.541    33,034 kbps     01:54:10.500    168,351 bytes   394,368 bytes   01:59:52.250
16              2:01:27.833     0:04:54.583     10,853 kbps     16,897 kbps     02:04:56.208    15,290 kbps     02:04:53.875    14,854 kbps     02:01:54.208    56,536 bytes    248,439 bytes   02:04:56.250
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5696.333                28,988                  20,640,500,239  112,256,397
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5696.333                2,398                   1,707,654,960   10,167,988
00000.M2TS      4608 (0x1200)   0x90            PGS             swe (Swedish)           5696.333                28                      20,034,582      113,776
00000.M2TS      4609 (0x1201)   0x90            PGS             nor (Norwegian)         5696.333                28                      20,050,435      113,845
00000.M2TS      4610 (0x1202)   0x90            PGS             dan (Danish)            5696.333                28                      19,712,196      112,038
00000.M2TS      4611 (0x1203)   0x90            PGS             fin (Finnish)           5696.333                28                      20,111,919      114,150
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     1885.792                29,003                  6,836,754,151   37,182,589
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1885.792                2,527                   595,572,896     3,527,104
00001.M2TS      4608 (0x1200)   0x90            PGS             swe (Swedish)           1885.792                22                      5,131,256       29,287
00001.M2TS      4609 (0x1201)   0x90            PGS             nor (Norwegian)         1885.792                22                      5,190,199       29,616
00001.M2TS      4610 (0x1202)   0x90            PGS             dan (Danish)            1885.792                22                      5,199,990       29,659
00001.M2TS      4611 (0x1203)   0x90            PGS             fin (Finnish)           1885.792                23                      5,342,552       30,431
post #1374 of 5099 Old 03-19-2010, 10:50 AM
jd213's Avatar
There's also a Paramount Japan release. I might rent it someday to see how it compares although I don't currently have a way of taking screenshots: http://www.amazon.co.jp/dp/B002P3CNA...9017341&sr=8-3
jd213 is offline
post #1375 of 5099 Old 03-20-2010, 03:36 PM - Thread Starter
[US] Robocop (Additional Details)
Studio: MGM
UPC: 027616091635
Release Date: 2007-10-09
An old one that's already on the list, but I suppose it doesn't hurt to have the full report. This is being reissued next month as a Blu-ray + DVD combo pack, but presumably the BD will be the same disc.
The English DD 4.0 track is a mix of main feature audio.
Code:
        Total   Video
[US] Robocop                                                    MPEG-2  1:43:14 20,941,737,984  22,213,678,252  27.05   20.74   DTS-HD Master 5.1 3382Kbps (48kHz/24-bit) DD AC3 4.0 448Kbps
Code:
DISC INFO:
Disc Title:     ROBOCOP
Disc Size:      22,213,678,252 bytes
Protection:     BD+
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:43:14 (h:m:s)
Total Bitrate:          27.05 Mbps
VIDEO:
MPEG-2 Video            20742 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         3382 kbps       5.1 / 48 kHz / 3382 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps / DN -4dB
Dolby Digital Audio             English         448 kbps        4.0 / 48 kHz / 448 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           English         34.763 kbps
Presentation Graphics           Chinese         22.780 kbps
Presentation Graphics           French          1.425 kbps
Presentation Graphics           Korean          17.963 kbps
Presentation Graphics           Spanish         28.993 kbps
Presentation Graphics           Spanish         1.307 kbps
FILES:
00001.M2TS      0:00:00.000     1:43:14.605     20,941,737,984  27,045
CHAPTERS:
1               0:00:00.000     0:06:40.691     20,805 kbps     43,149 kbps     00:04:32.272    39,662 kbps     00:04:21.261    39,038 kbps     00:04:21.135    108,454 bytes   757,159 bytes   00:04:33.189
2               0:06:40.691     0:07:22.441     20,276 kbps     43,718 kbps     00:08:24.086    39,821 kbps     00:12:05.683    38,905 kbps     00:11:34.694    105,710 bytes   724,906 bytes   00:08:58.621
3               0:14:03.133     0:03:24.996     21,804 kbps     42,469 kbps     00:16:53.637    39,635 kbps     00:16:43.544    39,007 kbps     00:16:45.671    113,674 bytes   728,226 bytes   00:17:05.107
4               0:17:28.130     0:09:08.047     20,837 kbps     36,534 kbps     00:25:39.079    32,806 kbps     00:25:35.075    26,679 kbps     00:25:30.070    108,632 bytes   631,714 bytes   00:19:44.558
5               0:26:36.177     0:07:47.383     20,772 kbps     44,833 kbps     00:26:51.318    32,238 kbps     00:26:51.151    26,690 kbps     00:26:46.146    108,295 bytes   759,674 bytes   00:27:46.790
6               0:34:23.561     0:06:04.781     20,252 kbps     32,385 kbps     00:34:23.561    28,590 kbps     00:34:23.561    24,616 kbps     00:38:42.194    105,585 bytes   688,497 bytes   00:40:04.568
7               0:40:28.342     0:04:42.490     20,607 kbps     29,435 kbps     00:40:49.238    26,958 kbps     00:40:46.735    26,432 kbps     00:40:47.445    107,435 bytes   619,898 bytes   00:45:10.833
8               0:45:10.833     0:04:31.312     21,885 kbps     33,059 kbps     00:45:57.671    27,987 kbps     00:46:01.425    26,980 kbps     00:46:00.841    114,097 bytes   660,209 bytes   00:45:44.199
9               0:49:42.145     0:08:01.481     20,869 kbps     43,374 kbps     00:56:48.988    28,340 kbps     00:54:26.805    27,232 kbps     00:54:57.377    108,803 bytes   684,162 bytes   00:50:20.976
10              0:57:43.626     0:03:53.107     20,331 kbps     34,488 kbps     01:01:33.231    23,798 kbps     01:01:23.554    22,848 kbps     01:01:24.347    105,996 bytes   621,738 bytes   01:01:12.627
11              1:01:36.734     0:06:43.945     21,137 kbps     43,339 kbps     01:03:58.042    39,422 kbps     01:03:58.751    39,056 kbps     01:03:49.367    110,200 bytes   713,149 bytes   01:03:48.533
12              1:08:20.679     0:07:34.704     20,809 kbps     44,096 kbps     01:11:40.254    39,764 kbps     01:11:38.377    30,931 kbps     01:11:33.455    108,487 bytes   764,960 bytes   01:11:42.172
13              1:15:55.384     0:06:46.656     20,897 kbps     35,111 kbps     01:16:03.684    32,702 kbps     01:16:02.432    32,179 kbps     01:17:12.711    108,950 bytes   563,087 bytes   01:22:41.957
14              1:22:42.040     0:11:07.333     20,832 kbps     36,066 kbps     01:29:04.297    27,685 kbps     01:28:36.644    26,632 kbps     01:29:03.796    108,608 bytes   597,687 bytes   01:30:05.274
15              1:33:49.373     0:03:10.940     20,748 kbps     42,493 kbps     01:34:31.332    39,578 kbps     01:34:31.332    39,131 kbps     01:34:31.332    108,173 bytes   640,943 bytes   01:34:31.082
16              1:37:00.314     0:06:14.290     19,469 kbps     30,965 kbps     01:39:50.526    29,662 kbps     01:39:47.481    29,111 kbps     01:39:42.476    101,512 bytes   575,331 bytes   01:39:49.900
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6194.438                20,742                  16,060,892,180  87,373,792
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6194.438                3,382                   2,618,923,504   15,196,665
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6194.438                448                     346,898,944     1,935,820
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6194.438                448                     346,898,944     1,935,820
00001.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           6194.438                448                     346,898,944     1,935,820
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6194.438                35                      26,917,841      155,583
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6194.438                29                      22,449,904      130,237
00001.M2TS      4610 (0x1202)   0x90            PGS             zho (Chinese)           6194.438                23                      17,639,432      104,113
00001.M2TS      4611 (0x1203)   0x90            PGS             kor (Korean)            6194.438                18                      13,909,365      83,891
00001.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6194.438                1                       1,103,114       6,381
00001.M2TS      4613 (0x1205)   0x90            PGS             spa (Spanish)           6194.438                1                       1,012,320       5,886
post #1376 of 5099 Old 03-20-2010, 03:46 PM
Patsfan123's Avatar
Quoted: 106 Post(s)
Liked: 65
[US] Breaking Bad: Season 1: Disc 1 Eps 1-4
Code:
        Total   Video
USER.001                                                        AVC     3:22:47 44,322,889,728  45,913,748,788  29.14   24.00   DTS-HD Master 5.1 3518Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     BREAKINGBADS1
Disc Size:      45,913,748,788 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 3:22:47 (h:m:s)
Total Bitrate:          29.14 Mbps
VIDEO:
MPEG-4 AVC Video        23995 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3518 kbps       5.1 / 48 kHz / 3518 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         21.849 kbps
Presentation Graphics           French          24.953 kbps
FILES:
00262.M2TS      0:00:00.000     0:58:06.524     12,947,939,328  29,710
00274.M2TS      0:58:06.524     0:48:12.931     10,456,940,544  28,917
00275.M2TS      1:46:19.456     0:48:11.930     10,435,227,648  28,867
00276.M2TS      2:34:31.387     0:48:15.726     10,482,782,208  28,961
CHAPTERS:
1               0:00:00.000     0:58:06.524     23,997 kbps     38,497 kbps     00:39:53.057    37,093 kbps     00:01:03.563    36,926 kbps     00:52:38.488    125,110 bytes   408,022 bytes   00:49:20.415
2               0:58:06.524     0:48:12.931     23,999 kbps     38,373 kbps     01:00:00.555    37,100 kbps     01:00:00.680    36,816 kbps     00:59:58.219    125,119 bytes   447,388 bytes   01:12:23.547
3               1:46:19.456     0:48:11.930     23,993 kbps     38,979 kbps     02:26:34.243    37,040 kbps     02:02:10.281    36,884 kbps     02:02:10.823    125,090 bytes   428,191 bytes   02:29:54.777
4               2:34:31.387     0:48:15.726     23,990 kbps     38,319 kbps     02:49:13.643    36,997 kbps     02:35:36.660    36,718 kbps     02:36:23.373    125,075 bytes   401,393 bytes   03:14:33.119
STREAM DIAGNOSTICS:
00262.M2TS      4113 (0x1011)   0x1B            AVC                                     3486.358                23,999                  10,458,468,163  56,888,042
00262.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           3486.358                3,896                   1,698,010,224   9,771,514
00262.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           3486.358                192                     83,676,672      544,770
00262.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           3486.358                21                      9,212,611       54,972
00262.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            3486.358                24                      10,541,753      61,053
00274.M2TS      4113 (0x1011)   0x1B            AVC                                     2892.765                24,000                  8,678,361,382   47,205,426
00274.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2892.765                3,369                   1,218,381,004   7,070,848
00274.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2892.765                21                      7,609,692       45,282
00274.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2892.765                21                      7,721,092       44,709
00275.M2TS      4113 (0x1011)   0x1B            AVC                                     2891.764                23,995                  8,673,341,393   47,178,044
00275.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2891.764                3,324                   1,201,632,144   6,979,584
00275.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2891.764                20                      7,299,707       43,435
00275.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2891.764                25                      9,014,963       52,172
00276.M2TS      4113 (0x1011)   0x1B            AVC                                     2895.559                23,991                  8,683,579,847   47,233,759
00276.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2895.559                3,406                   1,232,772,912   7,151,727
00276.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2895.559                25                      9,108,234       53,923
00276.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2895.559                29                      10,673,507      61,376
Collection: Blu-ray
post #1377 of 5099 Old 03-20-2010, 03:49 PM - Thread Starter
Cinema Squid's Avatar
[US] The Twilight Saga: New Moon (Additional Details)
Studio: Summit
UPC: 025192058165
Release Date: 2010-03-20
Aspect Ratio: 2.40:1
The English DTS-HD Master and Dolby Surround 2.0 are main feature audio tracks, while the other English DD 2.0 track is a commentary.
There are supposedly at least a couple variants of this release, i.e. Target and Walmart exclusive editions that include different extra features. I got mine from Netflix, but it should presumably match the "standard" retail edition.
Code:
        Total   Video
[US] The Twilight Saga: New Moon                                AVC     2:10:38 33,679,202,304  45,320,012,019  34.37   27.40   DTS-HD Master 5.1 3883Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     NEW_MOON
Disc Size:      45,320,012,019 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 2:10:38 (h:m:s)
Total Bitrate:          34.37 Mbps
VIDEO:
MPEG-4 AVC Video        27403 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3883 kbps       5.1 / 48 kHz / 3883 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -2dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         31.819 kbps
Presentation Graphics           English         78.401 kbps
Presentation Graphics           Spanish         23.264 kbps
Presentation Graphics           Spanish         61.032 kbps
FILES:
00001.M2TS      0:00:00.000     2:10:38.831     33,679,202,304  34,372
CHAPTERS:
1               0:00:00.000     0:11:03.996     27,685 kbps     39,479 kbps     00:01:10.737    34,003 kbps     00:01:07.650    33,225 kbps     00:01:41.684    144,330 bytes   719,018 bytes   00:01:33.134
2               0:11:03.996     0:08:54.492     28,070 kbps     44,796 kbps     00:19:20.200    31,008 kbps     00:15:54.578    29,964 kbps     00:13:32.520    146,345 bytes   700,779 bytes   00:19:20.242
3               0:19:58.488     0:08:18.998     27,573 kbps     38,883 kbps     00:25:51.299    32,267 kbps     00:25:51.383    30,546 kbps     00:25:51.299    143,750 bytes   661,933 bytes   00:21:28.245
4               0:28:17.487     0:07:23.359     28,482 kbps     42,573 kbps     00:32:02.879    31,802 kbps     00:31:58.875    30,632 kbps     00:31:53.953    148,491 bytes   607,153 bytes   00:28:19.155
5               0:35:40.847     0:06:34.143     28,310 kbps     39,810 kbps     00:40:54.160    31,646 kbps     00:40:54.160    30,607 kbps     00:35:46.602    147,596 bytes   677,662 bytes   00:35:47.103
6               0:42:14.990     0:04:55.044     29,348 kbps     38,046 kbps     00:43:07.668    32,149 kbps     00:43:05.499    30,900 kbps     00:45:34.189    153,005 bytes   643,807 bytes   00:43:51.462
7               0:47:10.035     0:07:01.546     29,416 kbps     38,850 kbps     00:47:30.389    32,238 kbps     00:47:30.180    30,988 kbps     00:47:16.291    153,360 bytes   581,154 bytes   00:47:23.841
8               0:54:11.581     0:04:32.772     28,998 kbps     34,823 kbps     00:58:38.014    30,745 kbps     00:55:41.212    30,365 kbps     00:55:50.889    151,182 bytes   546,925 bytes   00:58:44.354
9               0:58:44.354     0:05:55.396     29,158 kbps     39,605 kbps     01:04:25.570    32,737 kbps     00:59:28.147    32,058 kbps     00:59:29.190    152,016 bytes   653,869 bytes   00:58:53.404
10              1:04:39.750     0:04:33.398     28,082 kbps     41,872 kbps     01:04:41.335    31,379 kbps     01:08:35.528    29,345 kbps     01:05:12.074    146,408 bytes   690,117 bytes   01:04:42.169
11              1:09:13.149     0:06:45.655     29,544 kbps     39,321 kbps     01:10:38.776    32,362 kbps     01:10:43.656    31,318 kbps     01:10:32.645    154,030 bytes   629,219 bytes   01:11:25.906
12              1:15:58.804     0:04:12.418     29,192 kbps     43,152 kbps     01:18:40.298    33,380 kbps     01:19:06.408    31,778 kbps     01:19:02.362    152,194 bytes   648,808 bytes   01:18:00.133
13              1:20:11.223     0:07:33.327     28,063 kbps     41,807 kbps     01:21:22.460    35,475 kbps     01:20:59.354    32,786 kbps     01:20:55.058    146,307 bytes   604,627 bytes   01:20:44.089
14              1:27:44.550     0:06:26.552     28,094 kbps     40,150 kbps     01:33:45.786    31,650 kbps     01:34:02.470    30,963 kbps     01:34:00.051    146,467 bytes   507,685 bytes   01:34:08.309
15              1:34:11.103     0:08:38.392     29,076 kbps     40,669 kbps     01:42:22.803    33,885 kbps     01:37:29.134    32,611 kbps     01:37:29.260    151,588 bytes   587,300 bytes   01:35:49.952
16              1:42:49.496     0:08:20.458     29,066 kbps     41,156 kbps     01:47:30.318    31,797 kbps     01:47:30.318    30,631 kbps     01:47:30.152    151,538 bytes   554,299 bytes   01:47:41.496
17              1:51:09.954     0:09:07.421     28,023 kbps     39,417 kbps     01:56:44.247    30,784 kbps     01:56:41.035    29,796 kbps     01:59:39.505    146,097 bytes   672,183 bytes   01:56:45.248
18              2:00:17.376     0:10:21.454     14,442 kbps     33,499 kbps     02:09:29.845    31,107 kbps     02:09:26.759    30,217 kbps     02:09:21.712    75,297 bytes    579,512 bytes   02:09:30.846
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     7838.748                27,403                  26,851,099,141  146,039,940
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7838.748                3,884                   3,805,245,784   21,900,312
00001.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7838.748                192                     188,132,352     1,224,820
00001.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7838.748                640                     627,107,840     3,674,460
00001.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7838.748                192                     188,132,352     1,224,820
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7838.748                32                      31,178,433      180,588
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7838.748                23                      22,795,579      132,468
00001.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           7838.748                78                      76,821,619      433,069
00001.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7838.748                61                      59,802,163      339,388
Cinema Squid is offline
post #1378 of 5099 Old 03-20-2010, 04:10 PM - Thread Starter
That is indeed interesting and actually a pretty good idea.
I took another look at my saved report of the US release - it also has a 00632.MPLS playlist with 39 chapter markers at exactly the same time locations. Incidentally, the per-chapter video bitrates seems to match up exactly as well, so this is likely an identical video encode.
post #1379 of 5099 Old 03-20-2010, 08:08 PM
Snowknight26's Avatar
Quoted: 26 Post(s)
Liked: 27
Memento
Nordic release
Region-free
Code:
        Total   Video
00013.MPLS                                                      AVC     1:53:19 22 274 709 504  23 681 139 992  26,21   21,98   DTS-HD Master 5.1 2040Kbps (48kHz/16-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:
Disc Size:      23 681 139 992 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:53:19 (h:m:s)
Size:                   22 274 709 504 bytes
Total Bitrate:          26,21 Mbps
VIDEO:
MPEG-4 AVC Video        21976 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2040 kbps       5.1 / 48 kHz / 2040 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit / DN -4dB)
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
SUBTITLES:
Presentation Graphics           Danish          27,522 kbps
Presentation Graphics           Finnish         27,613 kbps
Presentation Graphics           Norwegian       26,388 kbps
Presentation Graphics           Swedish         26,986 kbps
FILES:
00016.M2TS      0:00:00.000     1:53:19.000     22 274 697 216  26 209
00013.M2TS      1:53:19.000     0:00:00.416     12 288          236
CHAPTERS:
1               0:00:00.000     0:07:11.250     19 758 kbps     38 746 kbps     00:06:51.416    34 914 kbps     00:06:47.416    33 080 kbps     00:06:45.041    102 896 bytes   323 516 bytes   00:02:19.958
2               0:07:11.250     0:14:53.291     20 153 kbps     37 303 kbps     00:13:09.333    31 311 kbps     00:11:27.916    30 330 kbps     00:11:07.999    104 966 bytes   298 077 bytes   00:11:40.041
3               0:22:04.541     0:06:22.625     20 488 kbps     38 416 kbps     00:22:26.666    31 216 kbps     00:22:15.625    31 009 kbps     00:22:17.541    106 708 bytes   301 743 bytes   00:27:34.958
4               0:28:27.166     0:10:55.500     21 624 kbps     38 833 kbps     00:30:00.541    33 610 kbps     00:32:21.916    30 281 kbps     00:32:17.208    112 627 bytes   327 448 bytes   00:31:27.291
5               0:39:22.666     0:09:57.875     25 142 kbps     41 064 kbps     00:47:34.041    36 332 kbps     00:47:00.041    35 379 kbps     00:46:59.624    130 949 bytes   322 558 bytes   00:47:19.333
6               0:49:20.541     0:08:04.833     24 875 kbps     42 176 kbps     00:49:31.749    38 390 kbps     00:49:30.625    37 035 kbps     00:49:29.833    129 556 bytes   335 567 bytes   00:55:05.583
7               0:57:25.375     0:11:52.125     21 490 kbps     40 729 kbps     01:00:26.291    32 414 kbps     00:59:50.833    29 716 kbps     00:59:50.166    111 928 bytes   336 349 bytes   00:58:39.291
8               1:09:17.500     0:08:28.750     20 655 kbps     42 315 kbps     01:17:23.041    34 124 kbps     01:16:34.541    32 116 kbps     01:16:34.374    107 578 bytes   315 834 bytes   01:13:36.083
9               1:17:46.250     0:08:40.125     21 558 kbps     38 858 kbps     01:21:27.583    33 105 kbps     01:19:20.291    30 146 kbps     01:19:15.416    112 284 bytes   325 726 bytes   01:21:56.166
10              1:26:26.375     0:07:25.166     23 821 kbps     39 968 kbps     01:32:31.666    32 976 kbps     01:27:38.416    31 561 kbps     01:27:33.416    124 067 bytes   299 583 bytes   01:27:14.000
11              1:33:51.541     0:16:24.458     25 332 kbps     48 222 kbps     01:36:12.833    41 558 kbps     01:36:11.583    39 945 kbps     01:36:12.541    131 936 bytes   441 655 bytes   01:37:28.500
12              1:50:16.000     0:03:03.416     6 693 kbps      15 059 kbps     01:52:31.958    13 319 kbps     01:52:29.208    11 777 kbps     01:52:26.958    34 868 bytes    164 203 bytes   01:52:32.000
STREAM DIAGNOSTICS:
00016.M2TS      4113 (0x1011)   0x1B            AVC                                     6798,875                21 978                  18 678 038 627  101 606 394
00016.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6798,875                640                     543 920 640     3 187 035
00016.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           6798,875                2 041                   1 734 276 176   10 464 212
00016.M2TS      4608 (0x1200)   0x90            PGS             swe (Swedish)           6798,875                27                      22 936 161      131 510
00016.M2TS      4609 (0x1201)   0x90            PGS             dan (Danish)            6798,875                28                      23 391 752      133 977
00016.M2TS      4610 (0x1202)   0x90            PGS             nor (Norwegian)         6798,875                26                      22 427 514      128 725
00016.M2TS      4611 (0x1203)   0x90            PGS             fin (Finnish)           6798,875                28                      23 469 359      134 402
00013.M2TS      4113 (0x1011)   0x1B            AVC                                     0,250                   169                     5 290           32
Snowknight26 is offline
post #1380 of 5099 Old 03-21-2010, 10:21 PM
stumlad's Avatar
Note: The cover art back cover says TrueHD but these are both DTS-HD MA
Both movies are on a single disc. Sold as a "Comedy Double Feature"
Miss Congeniality (US)
Code:
        Total   Video
00100.MPLS                                                      VC-1    1:50:14 19,750,213,632  40,096,491,850  23.89   17.52   DTS-HD Master 5.1 4043Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:
Disc Size:      40,096,491,850 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:50:14 (h:m:s)
Total Bitrate:          23.89 Mbps
VIDEO:
VC-1 Video              17519 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4043 kbps       5.1 / 48 kHz / 4043 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps / DN -4dB
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         37.229 kbps
Presentation Graphics           French          30.377 kbps
Presentation Graphics           Spanish         34.635 kbps
FILES:
00027.M2TS      0:00:00.000     1:50:14.983     19,750,213,632  23,885
CHAPTERS:
1               0:00:00.000     0:02:10.171     13,220 kbps     24,740 kbps     00:00:06.089    19,219 kbps     00:00:03.962    17,431 kbps     00:01:26.086    69,638 bytes    232,206 bytes   00:01:02.520
2               0:02:10.171     0:04:51.749     17,896 kbps     28,142 kbps     00:04:34.148    23,939 kbps     00:04:30.478    23,036 kbps     00:06:28.930    93,304 bytes    208,294 bytes   00:04:49.080
3               0:07:01.921     0:04:07.372     14,349 kbps     20,692 kbps     00:08:42.605    18,921 kbps     00:10:22.204    17,505 kbps     00:10:21.662    74,808 bytes    209,073 bytes   00:11:09.251
4               0:11:09.293     0:04:10.625     19,800 kbps     28,941 kbps     00:12:44.180    28,288 kbps     00:12:43.012    26,707 kbps     00:12:41.051    103,230 bytes   274,001 bytes   00:12:43.512
5               0:15:19.919     0:04:43.866     21,782 kbps     33,938 kbps     00:15:19.919    28,849 kbps     00:19:51.106    26,422 kbps     00:19:46.685    113,560 bytes   340,648 bytes   00:17:47.357
6               0:20:03.785     0:02:25.395     19,261 kbps     24,657 kbps     00:20:03.994    22,162 kbps     00:20:43.951    21,515 kbps     00:20:40.948    100,418 bytes   184,519 bytes   00:21:20.904
7               0:22:29.181     0:02:39.325     18,694 kbps     25,704 kbps     00:23:29.825    22,705 kbps     00:23:40.085    22,134 kbps     00:23:36.081    97,460 bytes    237,524 bytes   00:23:41.128
8               0:25:08.507     0:04:58.923     15,706 kbps     22,101 kbps     00:26:29.379    19,968 kbps     00:26:27.377    19,306 kbps     00:26:45.020    81,883 bytes    201,214 bytes   00:29:46.242
9               0:30:07.430     0:04:14.712     18,835 kbps     26,123 kbps     00:34:15.261    23,597 kbps     00:34:14.427    22,849 kbps     00:33:42.687    98,195 bytes    228,118 bytes   00:34:20.767
10              0:34:22.143     0:02:38.950     17,070 kbps     27,120 kbps     00:36:55.296    21,984 kbps     00:35:41.013    20,120 kbps     00:35:36.008    88,994 bytes    311,049 bytes   00:35:33.089
11              0:37:01.093     0:03:09.856     15,982 kbps     22,924 kbps     00:38:39.608    21,526 kbps     00:38:38.024    20,244 kbps     00:39:11.057    83,320 bytes    269,695 bytes   00:38:38.065
12              0:40:10.950     0:02:17.220     17,290 kbps     27,794 kbps     00:41:06.881    24,947 kbps     00:41:06.046    22,789 kbps     00:42:16.242    90,144 bytes    298,623 bytes   00:41:06.922
13              0:42:28.170     0:04:14.003     18,513 kbps     29,709 kbps     00:43:03.664    26,397 kbps     00:43:03.080    25,339 kbps     00:42:43.727    96,517 bytes    262,796 bytes   00:42:49.942
14              0:46:42.174     0:02:14.300     16,406 kbps     22,278 kbps     00:48:01.753    20,601 kbps     00:47:51.326    20,248 kbps     00:47:52.953    85,531 bytes    214,931 bytes   00:47:31.390
15              0:48:56.475     0:02:42.245     16,826 kbps     23,818 kbps     00:51:26.374    22,950 kbps     00:51:22.370    21,550 kbps     00:50:29.026    87,723 bytes    247,565 bytes   00:51:38.720
16              0:51:38.720     0:02:54.173     16,469 kbps     26,257 kbps     00:52:12.045    21,541 kbps     00:54:23.218    19,663 kbps     00:52:30.564    85,863 bytes    334,666 bytes   00:52:13.046
17              0:54:32.894     0:02:24.561     16,954 kbps     23,330 kbps     00:54:35.021    21,654 kbps     00:55:41.713    20,280 kbps     00:55:41.713    88,392 bytes    226,814 bytes   00:55:37.917
18              0:56:57.455     0:04:39.028     18,443 kbps     40,241 kbps     00:59:28.940    33,915 kbps     00:59:32.485    32,224 kbps     00:59:28.856    96,155 bytes    338,597 bytes   00:59:23.434
19              1:01:36.484     0:03:08.396     18,352 kbps     25,317 kbps     01:01:53.376    22,791 kbps     01:01:36.484    21,857 kbps     01:01:36.484    95,680 bytes    284,760 bytes   01:04:02.880
20              1:04:44.881     0:02:18.096     15,657 kbps     24,037 kbps     01:05:43.648    21,536 kbps     01:05:14.827    19,107 kbps     01:05:43.648    81,627 bytes    193,854 bytes   01:05:08.696
21              1:07:02.977     0:05:02.051     17,120 kbps     25,126 kbps     01:08:45.037    22,947 kbps     01:08:26.936    22,402 kbps     01:08:23.516    89,256 bytes    260,199 bytes   01:08:26.644
22              1:12:05.029     0:03:27.415     17,773 kbps     22,861 kbps     01:12:05.029    19,919 kbps     01:12:38.228    19,505 kbps     01:12:59.208    92,658 bytes    183,645 bytes   01:13:15.140
23              1:15:32.444     0:03:46.225     16,281 kbps     21,774 kbps     01:18:45.345    20,470 kbps     01:18:45.053    19,181 kbps     01:18:10.352    84,883 bytes    228,707 bytes   01:17:28.185
24              1:19:18.670     0:03:52.815     22,019 kbps     42,947 kbps     01:21:24.129    33,657 kbps     01:22:52.592    30,562 kbps     01:22:50.674    114,798 bytes   349,284 bytes   01:21:25.130
25              1:23:11.486     0:01:59.244     21,346 kbps     27,773 kbps     01:23:27.335    25,515 kbps     01:23:26.835    24,402 kbps     01:24:07.000    111,287 bytes   286,785 bytes   01:23:26.876
26              1:25:10.730     0:03:21.659     18,563 kbps     28,601 kbps     01:27:22.528    26,527 kbps     01:26:53.750    25,694 kbps     01:27:48.137    96,779 bytes    250,682 bytes   01:27:38.628
27              1:28:32.390     0:03:18.072     19,506 kbps     30,208 kbps     01:30:38.433    25,580 kbps     01:30:35.138    23,496 kbps     01:30:34.637    101,695 bytes   289,230 bytes   01:31:17.472
28              1:31:50.463     0:02:17.011     19,681 kbps     28,336 kbps     01:33:23.889    26,228 kbps     01:33:19.969    25,732 kbps     01:33:21.929    102,606 bytes   264,696 bytes   01:32:13.319
29              1:34:07.475     0:01:57.408     16,632 kbps     21,781 kbps     01:34:12.063    19,780 kbps     01:34:12.021    18,681 kbps     01:35:29.557    86,713 bytes    267,554 bytes   01:34:13.064
30              1:36:04.884     0:04:31.062     20,631 kbps     44,058 kbps     01:39:30.798    35,287 kbps     01:39:28.337    29,638 kbps     01:39:25.834    107,561 bytes   301,068 bytes   01:39:31.799
31              1:40:35.946     0:02:21.808     19,260 kbps     33,315 kbps     01:40:42.619    28,306 kbps     01:40:41.243    27,310 kbps     01:40:41.535    100,414 bytes   333,433 bytes   01:40:47.916
32              1:42:57.754     0:02:38.283     24,187 kbps     38,225 kbps     01:44:14.706    36,135 kbps     01:44:11.036    33,443 kbps     01:45:17.686    126,098 bytes   382,154 bytes   01:43:22.154
33              1:45:36.038     0:04:38.945     1,861 kbps      9,974 kbps      01:50:08.101    6,928 kbps      01:50:08.018    3,815 kbps      01:50:02.887    9,738 bytes     137,408 bytes   01:50:11.313
STREAM DIAGNOSTICS:
00027.M2TS      4113 (0x1011)   0xEA            VC-1                                    6614.858                17,519                  14,486,104,094  78,824,536
00027.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6614.858                4,043                   3,342,931,652   19,198,501
00027.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6614.858                640                     529,200,640     3,100,785
00027.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6614.858                192                     158,760,192     1,033,595
00027.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6614.858                37                      30,783,309      177,542
00027.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6614.858                30                      25,118,177      146,049
00027.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6614.858                35                      28,638,412      163,052
Miss Congeniality 2 (US)
Code:
        Total   Video
00099.MPLS                                                      VC-1    1:55:20 20,267,839,488  40,096,491,850  23.43   17.50   DTS-HD Master 5.1 3601Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.3
PLAYLIST REPORT:
Length:                 1:55:20 (h:m:s)
Total Bitrate:          23.43 Mbps
VIDEO:
VC-1 Video              17505 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         3601 kbps       5.1 / 48 kHz / 3601 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         46.113 kbps
Presentation Graphics           French          31.887 kbps
Presentation Graphics           Spanish         41.715 kbps
FILES:
00063.M2TS      0:00:00.000     1:55:20.955     20,267,839,488  23,428
CHAPTERS:
1               0:00:00.000     0:03:22.869     16,933 kbps     34,402 kbps     00:00:04.713    26,361 kbps     00:00:03.086    25,722 kbps     00:02:13.007    89,031 bytes    250,964 bytes   00:02:17.428
2               0:03:22.869     0:02:30.567     16,129 kbps     22,511 kbps     00:05:26.117    21,504 kbps     00:05:24.449    20,308 kbps     00:05:19.402    84,090 bytes    223,224 bytes   00:05:24.490
3               0:05:53.436     0:02:03.832     16,590 kbps     23,237 kbps     00:06:17.001    22,444 kbps     00:06:08.534    22,198 kbps     00:06:08.493    86,492 bytes    192,016 bytes   00:06:17.502
4               0:07:57.268     0:03:58.279     18,529 kbps     26,604 kbps     00:08:24.337    23,647 kbps     00:08:23.377    22,944 kbps     00:08:23.377    96,602 bytes    187,596 bytes   00:10:45.811
5               0:11:55.548     0:03:55.610     16,677 kbps     29,281 kbps     00:14:22.319    27,791 kbps     00:14:21.360    27,121 kbps     00:14:19.775    86,948 bytes    233,948 bytes   00:12:01.554
6               0:15:51.158     0:02:12.090     14,305 kbps     20,477 kbps     00:18:00.579    18,758 kbps     00:17:58.243    17,107 kbps     00:17:53.238    74,582 bytes    202,306 bytes   00:15:53.160
7               0:18:03.248     0:04:51.833     20,179 kbps     34,174 kbps     00:22:42.235    32,518 kbps     00:22:40.734    31,500 kbps     00:22:37.356    105,206 bytes   322,932 bytes   00:22:37.397
8               0:22:55.082     0:03:36.966     18,862 kbps     31,304 kbps     00:23:52.097    28,233 kbps     00:25:48.797    26,653 kbps     00:25:47.963    98,340 bytes    232,110 bytes   00:26:04.771
9               0:26:32.048     0:02:54.507     15,390 kbps     19,597 kbps     00:27:25.769    18,370 kbps     00:26:47.022    17,671 kbps     00:26:42.601    80,235 bytes    197,677 bytes   00:29:26.556
10              0:29:26.556     0:03:17.322     15,935 kbps     20,823 kbps     00:29:46.576    19,432 kbps     00:29:45.825    19,101 kbps     00:29:41.613    83,080 bytes    215,126 bytes   00:31:01.776
11              0:32:43.878     0:03:17.655     19,536 kbps     31,017 kbps     00:32:50.885    30,321 kbps     00:33:04.774    29,689 kbps     00:32:43.878    101,850 bytes   272,888 bytes   00:34:23.811
12              0:36:01.534     0:02:29.899     18,078 kbps     30,715 kbps     00:38:25.720    29,802 kbps     00:38:24.343    26,936 kbps     00:38:21.424    94,249 bytes    308,622 bytes   00:36:08.541
13              0:38:31.434     0:06:12.705     18,004 kbps     28,296 kbps     00:38:48.034    27,085 kbps     00:38:44.280    26,174 kbps     00:38:40.985    93,866 bytes    272,104 bytes   00:38:32.435
14              0:44:44.139     0:04:58.673     18,157 kbps     34,550 kbps     00:45:54.042    29,966 kbps     00:45:50.539    28,414 kbps     00:45:45.492    94,664 bytes    261,107 bytes   00:45:54.877
15              0:49:42.813     0:04:59.007     17,841 kbps     29,492 kbps     00:51:09.274    28,360 kbps     00:51:12.235    28,190 kbps     00:51:07.939    93,016 bytes    261,886 bytes   00:54:38.358
16              0:54:41.820     0:04:06.537     16,113 kbps     22,997 kbps     00:58:47.357    20,880 kbps     00:56:12.327    20,267 kbps     00:56:12.327    84,005 bytes    214,327 bytes   00:58:48.107
17              0:58:48.358     0:03:10.648     15,777 kbps     27,588 kbps     01:01:58.005    24,910 kbps     01:01:54.001    20,400 kbps     01:01:48.996    82,256 bytes    229,621 bytes   01:01:58.798
18              1:01:59.006     0:02:09.796     19,934 kbps     29,396 kbps     01:02:13.729    27,815 kbps     01:02:10.017    27,414 kbps     01:02:08.141    103,928 bytes   322,893 bytes   01:02:17.024
19              1:04:08.803     0:04:06.579     16,519 kbps     30,321 kbps     01:04:16.143    28,680 kbps     01:04:16.143    26,941 kbps     01:04:16.143    86,120 bytes    238,483 bytes   01:04:16.185
20              1:08:15.382     0:03:05.310     16,560 kbps     20,787 kbps     01:08:17.009    19,394 kbps     01:08:54.630    18,449 kbps     01:08:15.382    86,334 bytes    202,942 bytes   01:09:32.293
21              1:11:20.693     0:04:10.541     20,716 kbps     29,907 kbps     01:14:44.938    28,070 kbps     01:14:44.313    26,690 kbps     01:14:44.271    108,004 bytes   262,332 bytes   01:12:13.329
22              1:15:31.235     0:03:42.347     18,171 kbps     25,843 kbps     01:15:53.757    23,615 kbps     01:16:06.895    22,728 kbps     01:16:01.890    94,736 bytes    350,249 bytes   01:19:13.582
23              1:19:13.582     0:02:39.409     19,480 kbps     35,329 kbps     01:20:42.546    33,357 kbps     01:20:40.585    30,418 kbps     01:20:36.206    101,559 bytes   339,608 bytes   01:19:14.583
24              1:21:52.991     0:05:54.354     20,233 kbps     32,565 kbps     01:24:37.030    27,939 kbps     01:27:07.972    26,996 kbps     01:27:05.803    105,486 bytes   357,411 bytes   01:25:13.316
25              1:27:47.345     0:02:55.550     19,695 kbps     32,080 kbps     01:29:39.874    26,964 kbps     01:29:38.623    25,876 kbps     01:29:39.624    102,680 bytes   381,953 bytes   01:29:39.916
26              1:30:42.895     0:03:49.646     19,730 kbps     36,655 kbps     01:32:48.980    32,796 kbps     01:32:48.354    31,321 kbps     01:32:40.513    102,864 bytes   331,705 bytes   01:32:41.138
27              1:34:32.541     0:02:37.365     22,529 kbps     44,619 kbps     01:36:36.874    36,072 kbps     01:34:49.058    31,008 kbps     01:34:46.013    117,454 bytes   312,128 bytes   01:34:49.100
28              1:37:09.907     0:01:57.408     22,447 kbps     39,698 kbps     01:37:33.389    34,113 kbps     01:37:36.475    32,900 kbps     01:37:31.470    117,028 bytes   255,098 bytes   01:37:33.514
29              1:39:07.316     0:04:42.115     16,674 kbps     39,883 kbps     01:43:48.347    31,680 kbps     01:43:44.426    24,567 kbps     01:41:23.368    86,931 bytes    291,753 bytes   01:43:48.805
30              1:43:49.431     0:03:42.347     16,522 kbps     33,148 kbps     01:44:50.367    26,655 kbps     01:44:47.114    22,580 kbps     01:44:42.025    86,139 bytes    323,823 bytes   01:44:51.243
31              1:47:31.778     0:07:49.177     9,343 kbps      21,820 kbps     01:49:13.004    18,831 kbps     01:49:10.335    17,523 kbps     01:50:14.399    48,868 bytes    287,130 bytes   01:49:11.878
STREAM DIAGNOSTICS:
00063.M2TS      4113 (0x1011)   0xEA            VC-1                                    6920.831                17,505                  15,143,540,561  82,401,921
00063.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6920.831                3,601                   3,115,495,860   18,010,449
00063.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6920.831                640                     553,676,800     3,244,200
00063.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6920.831                192                     166,103,040     1,081,400
00063.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6920.831                46                      39,892,891      227,241
00063.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6920.831                32                      27,585,856      158,729
00063.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6920.831                42                      36,088,064      205,832
stumlad is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
