NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
Old 07-24-2009, 08:43 PM - Thread Starter
Cinema Squid's Avatar
Originally Posted by Stephen Dawson View Post
Poltergeist error
There are two entries for this movie on the front page alphabetical list, one for US and one for DE. These appear to be identical except for two things. The second is the TrueHD audio bitrate, which for the DE one is listed as 16670kbps. That's actually impossible (the audio is 16/48 5.1, which comes to 4,608kbps in uncompressed PCM). So I suspect a typo there.
The first difference is in the total disc size for the two, and it's a small difference. I'm not sure that this is consistently reported by BDInfo 0.5.2. I've used two different BD drives and the figure it gives has been different.
I've just scanned Poltergeist -- the US 'book' version (barcode 0 12569 79849 6), and the figure reported is 22,126,444,468 bytes, which is the figure reported on the front page for the DE version. Perhaps the US scan used an earlier version of BDInfo. Anyway, it seems likely that the US and DE versions of this are the same (and likely the Australian version too, but I don't have a copy of this to scan).
Thanks, it looks like I pasted the video bitrate into the TrueHD bitrate field -oops!
BDInfo disc size is essentially calculated as a "dir /s" - all of the files on the disc are recursed and their sizes summed. As far as the differences in the disc size listing goes between the two Poltergeist entries, I mention somewhat obliquely in the notes sections on the first page that small variations in size due to "nuances" in the software stack are normal and ~10MB is within the boundaries of these normal differences. Assuming the US and DE editions are byte-for-byte identical, I imagine the DE disc size number is more correct as far as that goes. Sorry if I am being too intentionally vague, feel free to PM or email me if you want the "unrated" explanation...
Cinema Squid is offline
Old 07-24-2009, 10:40 PM
msgohan's Avatar
Originally Posted by CRT Dude View Post
Seamless branching with 24 audio on Watchmen? Did they find the closet they locked the Blade Runners guys in?
Except the branching is only for the PiP, not for including the Theatrical.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
Old 07-25-2009, 12:08 PM
Patsfan123's Avatar
Quoted: 107 Post(s)
Liked: 65
Code:
        Total   Video
Roadhouse                                                       MPEG-2  1:54:09 20,131,325,952  21,591,186,040  23.51   18.05   DTS-HD Master 5.1 3411Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     ROADHOUSE
Disc Size:      21,591,186,040 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:54:09 (h:m:s)
Total Bitrate:          23.51 Mbps
Description:
VIDEO:
MPEG-2 Video            18052 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         3411 kbps       5.1 / 48 kHz / 3411 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / Dolby Surround
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps / Dolby Surround
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         22.015 kbps
Presentation Graphics           Chinese         16.564 kbps
Presentation Graphics           French          0.239 kbps
Presentation Graphics           Korean          14.618 kbps
Presentation Graphics           Spanish         20.105 kbps
Presentation Graphics           Spanish         0.175 kbps
FILES:
00002.M2TS      0:00:00.000     1:54:09.926     20,131,325,952  23,511
CHAPTERS:
1               0:00:00.000     0:04:10.291     19,393 kbps     38,754 kbps     00:00:37.328    35,392 kbps     00:00:37.412    35,186 kbps     00:00:36.911    101,088 bytes   703,087 bytes   00:00:48.840
2               0:04:10.291     0:02:13.091     17,172 kbps     40,235 kbps     00:06:09.535    35,700 kbps     00:06:09.535    34,602 kbps     00:06:09.410    89,528 bytes    703,085 bytes   00:06:14.540
3               0:06:23.383     0:03:23.286     16,408 kbps     37,957 kbps     00:07:18.896    35,163 kbps     00:07:18.062    27,533 kbps     00:07:14.851    85,545 bytes    703,084 bytes   00:07:21.357
4               0:09:46.669     0:02:49.836     17,644 kbps     25,005 kbps     00:12:35.504    20,971 kbps     00:12:10.020    20,270 kbps     00:12:12.189    91,990 bytes    590,644 bytes   00:12:36.505
5               0:12:36.505     0:03:48.436     18,255 kbps     26,936 kbps     00:15:36.685    22,650 kbps     00:15:32.681    21,513 kbps     00:15:35.768    95,174 bytes    570,868 bytes   00:14:13.978
6               0:16:24.942     0:05:33.708     18,546 kbps     27,574 kbps     00:18:43.997    25,116 kbps     00:18:42.496    23,294 kbps     00:18:41.495    96,690 bytes    623,062 bytes   00:21:46.805
7               0:21:58.650     0:03:44.515     15,817 kbps     21,926 kbps     00:25:42.165    18,500 kbps     00:23:09.096    17,619 kbps     00:23:53.515    82,461 bytes    677,181 bytes   00:25:43.166
8               0:25:43.166     0:04:03.534     17,651 kbps     37,056 kbps     00:29:41.029    34,973 kbps     00:29:26.473    33,062 kbps     00:29:35.732    92,023 bytes    703,085 bytes   00:29:43.531
9               0:29:46.701     0:02:36.364     21,479 kbps     39,271 kbps     00:30:40.296    35,683 kbps     00:30:13.770    34,878 kbps     00:31:47.488    111,983 bytes   703,087 bytes   00:30:44.968
10              0:32:23.066     0:04:18.758     16,424 kbps     38,833 kbps     00:36:04.245    35,440 kbps     00:36:00.491    32,859 kbps     00:36:00.533    85,626 bytes    703,085 bytes   00:36:01.450
11              0:36:41.824     0:02:31.359     23,437 kbps     39,345 kbps     00:38:20.131    35,730 kbps     00:38:19.964    35,263 kbps     00:38:15.793    122,188 bytes   702,603 bytes   00:37:50.810
12              0:39:13.184     0:02:53.381     15,395 kbps     21,205 kbps     00:39:50.096    18,011 kbps     00:39:46.133    16,839 kbps     00:39:41.128    80,264 bytes    461,231 bytes   00:41:26.275
13              0:42:06.565     0:03:55.360     18,092 kbps     25,901 kbps     00:44:00.220    23,558 kbps     00:42:08.108    23,087 kbps     00:42:06.565    94,325 bytes    604,512 bytes   00:43:07.668
14              0:46:01.925     0:01:44.813     17,866 kbps     25,095 kbps     00:47:45.737    19,911 kbps     00:46:37.669    19,266 kbps     00:46:33.707    93,146 bytes    685,100 bytes   00:47:46.738
15              0:47:46.738     0:03:16.279     18,175 kbps     35,857 kbps     00:51:01.725    21,852 kbps     00:50:58.013    20,985 kbps     00:50:18.306    94,754 bytes    703,081 bytes   00:51:02.392
16              0:51:03.018     0:02:53.089     18,440 kbps     39,015 kbps     00:51:08.356    35,247 kbps     00:51:04.352    34,730 kbps     00:51:05.353    96,137 bytes    703,081 bytes   00:51:04.519
17              0:53:56.107     0:03:49.229     18,120 kbps     36,346 kbps     00:53:57.901    28,066 kbps     00:53:56.399    23,636 kbps     00:53:56.399    94,467 bytes    703,085 bytes   00:53:58.026
18              0:57:45.336     0:01:56.366     18,223 kbps     24,154 kbps     00:58:07.025    20,940 kbps     00:57:57.348    20,491 kbps     00:57:57.932    95,005 bytes    639,687 bytes   00:57:55.263
19              0:59:41.703     0:06:46.364     17,875 kbps     35,647 kbps     01:00:36.883    34,904 kbps     01:00:32.253    34,870 kbps     01:00:27.874    93,193 bytes    703,088 bytes   01:00:17.780
20              1:06:28.067     0:04:28.518     18,250 kbps     27,231 kbps     01:08:35.111    22,097 kbps     01:08:31.107    21,718 kbps     01:09:09.520    95,149 bytes    620,134 bytes   01:09:38.215
21              1:10:56.585     0:04:50.707     16,902 kbps     26,279 kbps     01:15:46.291    19,572 kbps     01:12:16.790    18,898 kbps     01:12:16.749    88,121 bytes    693,325 bytes   01:15:47.292
22              1:15:47.292     0:07:57.643     18,801 kbps     37,981 kbps     01:16:49.187    35,149 kbps     01:16:44.558    31,102 kbps     01:16:40.304    98,022 bytes    703,084 bytes   01:16:46.101
23              1:23:44.936     0:05:41.049     18,603 kbps     38,869 kbps     01:25:52.438    28,182 kbps     01:25:49.435    24,825 kbps     01:25:43.930    96,985 bytes    649,050 bytes   01:29:25.985
24              1:29:25.985     0:06:22.757     17,398 kbps     39,102 kbps     01:31:13.801    35,586 kbps     01:31:09.297    33,415 kbps     01:31:07.253    90,706 bytes    703,082 bytes   01:31:15.303
25              1:35:48.743     0:04:53.751     15,864 kbps     24,178 kbps     01:40:41.493    19,442 kbps     01:40:37.489    18,164 kbps     01:40:32.484    82,708 bytes    668,387 bytes   01:40:42.494
26              1:40:42.494     0:03:21.784     21,888 kbps     40,231 kbps     01:40:59.762    36,857 kbps     01:40:55.758    35,971 kbps     01:40:53.505    114,114 bytes   703,081 bytes   01:40:50.961
27              1:44:04.279     0:05:20.445     16,376 kbps     24,131 kbps     01:46:39.851    19,278 kbps     01:45:52.554    18,780 kbps     01:46:31.176    85,377 bytes    500,825 bytes   01:44:50.826
28              1:49:24.724     0:04:45.201     19,634 kbps     24,621 kbps     01:53:07.363    23,854 kbps     01:53:06.863    23,546 kbps     01:53:06.488    102,378 bytes   421,987 bytes   01:54:09.717
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6849.801                18,052                  15,456,905,276  84,100,442
00002.M2TS      4352 (0x1100)   0x81            AC3             fra (French)            6849.801                224                     191,798,656     1,070,305
00002.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           6849.801                224                     191,798,656     1,070,305
00002.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6849.801                224                     191,798,656     1,070,305
00002.M2TS      4355 (0x1103)   0x86            DTS-HD MA       eng (English)           6849.801                3,411                   2,920,644,584   16,940,308
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6849.801                22                      18,849,846      109,580
00002.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6849.801                20                      17,215,000      99,961
00002.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6849.801                0                       149,879         884
00002.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            6849.801                0                       204,681         1,195
00002.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            6849.801                15                      12,516,218      74,402
00002.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           6849.801                17                      14,182,711      83,466
Stephen, it will be interesting to see if the AU version gets the AVC/BD50 treatment.
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is offline
Old 07-25-2009, 01:07 PM - Thread Starter
Originally Posted by msgohan View Post
First Region BC disc? Does the cover actually say it's both or is it another Fox "slip-up" allowing more regions than they claim?
On a related note, I just ran into a Region AC disc: Confessions of a Shopaholic (marked as Region A).
Makes me wonder how many others are out there, since I imagine most people are just testing against Region A and B.
Old 07-25-2009, 07:01 PM
Stephen Dawson's Avatar
Hart's War - 2002 - Australian version
Distributed by Twentieth Century Fox Home Entertainment South Pacific Pty Ltd
Region A/B confirmed with AnyDVDHD
This is a pre-production test disc. It carries the same audio and extras as the final Australian release, and should be accurate as far as the encode goes. I would not trust it for region coding though. Also, it has two trailers on it -- Rocky and Windtalkers -- which are orphans. That is, there are no links to them from the menu. I don't know if they are there on the final Australian release.
Code:
        Total   Video
00001.MPLS                                                      MPEG-2  2:04:49 22,359,293,952  23,285,688,438  23.88   16.81   DTS-HD Master 5.1 3871Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      23,285,688,438 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:04:49 (h:m:s)
Total Bitrate:          23.88 Mbps
Description:
VIDEO:
MPEG-2 Video            16805 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-HD Master Audio             English         3871 kbps       5.1 / 48 kHz / 3871 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       German          768 kbps        5.1 / 48 kHz / 768 kbps / 16-bit
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         35.629 kbps
Presentation Graphics           French          31.255 kbps
Presentation Graphics           German          30.203 kbps
Presentation Graphics           German          0.140 kbps
Presentation Graphics           Swedish         27.970 kbps
Presentation Graphics           Danish          30.228 kbps
Presentation Graphics           Finnish         32.642 kbps
Presentation Graphics           Norwegian       30.607 kbps
Presentation Graphics           Dutch           23.183 kbps
Presentation Graphics           French          0.498 kbps
FILES:
00002.M2TS      0:00:00.000     2:04:49.982     22,359,293,952  23,882
CHAPTERS:
1               0:00:00.000     0:03:15.528     17,041 kbps     39,117 kbps     00:01:02.937    36,434 kbps     00:00:58.933    31,334 kbps     00:00:58.058    88,823 bytes    599,248 bytes   00:01:03.730
2               0:03:15.528     0:02:37.657     17,809 kbps     36,120 kbps     00:05:11.519    35,459 kbps     00:05:11.519    26,035 kbps     00:05:11.102    92,846 bytes    622,945 bytes   00:05:16.441
3               0:05:53.186     0:02:19.931     17,035 kbps     28,851 kbps     00:07:49.177    26,210 kbps     00:06:14.916    23,292 kbps     00:07:16.519    88,811 bytes    534,996 bytes   00:07:26.320
4               0:08:13.117     0:02:24.686     17,947 kbps     32,110 kbps     00:08:14.035    31,182 kbps     00:08:13.242    28,638 kbps     00:08:13.242    93,567 bytes    527,183 bytes   00:09:26.482
5               0:10:37.803     0:04:29.727     17,624 kbps     30,077 kbps     00:12:13.399    26,042 kbps     00:13:13.584    25,052 kbps     00:13:11.248    91,885 bytes    537,187 bytes   00:12:25.828
6               0:15:07.531     0:04:29.560     17,729 kbps     32,399 kbps     00:15:18.792    28,292 kbps     00:15:17.207    24,896 kbps     00:15:17.458    92,429 bytes    542,313 bytes   00:15:53.494
7               0:19:37.092     0:06:07.784     16,915 kbps     27,998 kbps     00:24:39.269    24,097 kbps     00:24:37.642    22,151 kbps     00:19:59.114    88,185 bytes    514,516 bytes   00:21:25.617
8               0:25:44.876     0:02:53.798     16,963 kbps     27,428 kbps     00:27:57.384    25,624 kbps     00:27:54.631    24,000 kbps     00:27:51.002    88,440 bytes    488,901 bytes   00:26:35.844
9               0:28:38.675     0:03:49.604     17,247 kbps     24,734 kbps     00:29:31.978    20,917 kbps     00:28:38.675    20,166 kbps     00:29:17.589    89,916 bytes    559,913 bytes   00:30:54.602
10              0:32:28.279     0:02:46.207     16,027 kbps     24,641 kbps     00:34:28.065    21,011 kbps     00:35:09.482    19,195 kbps     00:35:04.477    83,559 bytes    334,738 bytes   00:33:41.894
11              0:35:14.487     0:05:04.262     17,494 kbps     29,560 kbps     00:35:42.932    25,100 kbps     00:35:38.970    23,635 kbps     00:35:58.156    91,207 bytes    571,944 bytes   00:37:15.775
12              0:40:18.749     0:04:30.228     17,441 kbps     24,994 kbps     00:41:59.475    21,188 kbps     00:40:55.703    20,603 kbps     00:40:50.698    90,927 bytes    448,349 bytes   00:44:04.391
13              0:44:48.977     0:02:50.879     17,353 kbps     26,578 kbps     00:47:34.893    25,142 kbps     00:47:05.614    21,807 kbps     00:47:03.570    90,470 bytes    550,881 bytes   00:47:06.657
14              0:47:39.857     0:02:43.371     17,481 kbps     31,224 kbps     00:49:37.808    23,807 kbps     00:49:35.389    22,718 kbps     00:49:30.425    91,137 bytes    451,612 bytes   00:50:23.228
15              0:50:23.228     0:02:41.327     16,982 kbps     31,063 kbps     00:50:23.603    22,865 kbps     00:52:09.584    22,071 kbps     00:52:04.579    88,538 bytes    489,230 bytes   00:50:23.645
16              0:53:04.556     0:04:45.118     16,971 kbps     25,342 kbps     00:57:45.712    22,653 kbps     00:54:28.515    21,322 kbps     00:55:09.514    88,480 bytes    560,718 bytes   00:54:43.697
17              0:57:49.674     0:02:24.644     16,632 kbps     25,451 kbps     01:00:09.939    23,844 kbps     01:00:07.312    22,102 kbps     01:00:04.309    86,714 bytes    404,859 bytes   00:58:18.745
18              1:00:14.319     0:04:53.209     16,249 kbps     22,769 kbps     01:00:28.625    19,994 kbps     01:04:42.837    18,900 kbps     01:00:25.121    84,717 bytes    435,044 bytes   01:00:28.750
19              1:05:07.528     0:03:37.508     16,213 kbps     25,212 kbps     01:07:00.266    22,259 kbps     01:07:38.554    21,173 kbps     01:07:38.304    84,529 bytes    419,542 bytes   01:06:27.400
20              1:08:45.037     0:04:58.673     17,009 kbps     28,908 kbps     01:12:49.531    25,498 kbps     01:12:51.867    24,210 kbps     01:12:47.946    88,679 bytes    426,257 bytes   01:10:24.178
21              1:13:43.710     0:03:26.998     16,741 kbps     23,018 kbps     01:15:28.023    20,695 kbps     01:13:43.794    19,810 kbps     01:13:43.710    87,282 bytes    423,507 bytes   01:15:41.245
22              1:17:10.709     0:04:35.191     16,302 kbps     25,731 kbps     01:21:27.090    21,746 kbps     01:21:26.464    21,269 kbps     01:19:35.729    84,991 bytes    456,384 bytes   01:19:35.771
23              1:21:45.901     0:03:23.620     15,640 kbps     21,356 kbps     01:21:59.080    19,877 kbps     01:21:50.906    19,420 kbps     01:21:50.071    81,537 bytes    403,711 bytes   01:21:59.831
24              1:25:09.521     0:03:06.811     16,207 kbps     21,167 kbps     01:25:35.964    18,762 kbps     01:25:34.045    18,129 kbps     01:26:48.745    84,497 bytes    457,500 bytes   01:28:04.988
25              1:28:16.332     0:05:54.854     16,068 kbps     30,770 kbps     01:28:17.000    25,659 kbps     01:28:16.332    21,196 kbps     01:28:16.332    83,771 bytes    526,265 bytes   01:29:29.072
26              1:34:11.187     0:04:14.879     14,898 kbps     23,155 kbps     01:35:03.114    20,928 kbps     01:34:31.832    18,721 kbps     01:34:29.288    77,674 bytes    421,659 bytes   01:35:11.914
27              1:38:26.066     0:02:41.911     15,707 kbps     24,189 kbps     01:39:07.608    20,252 kbps     01:39:07.608    18,419 kbps     01:40:57.968    81,890 bytes    376,852 bytes   01:39:07.650
28              1:41:07.978     0:04:43.783     16,999 kbps     28,331 kbps     01:41:10.481    25,174 kbps     01:41:16.361    24,541 kbps     01:41:15.360    88,625 bytes    491,781 bytes   01:41:16.403
29              1:45:51.762     0:06:14.624     17,295 kbps     27,626 kbps     01:51:31.601    23,804 kbps     01:51:31.184    22,785 kbps     01:51:30.517    90,170 bytes    567,810 bytes   01:48:12.569
30              1:52:06.386     0:07:07.552     17,656 kbps     29,866 kbps     01:52:14.769    24,204 kbps     01:52:11.808    21,850 kbps     01:52:09.264    92,048 bytes    563,004 bytes   01:58:27.016
31              1:59:13.938     0:00:48.089     17,498 kbps     19,877 kbps     01:59:29.370    19,458 kbps     01:59:16.941    18,918 kbps     01:59:15.231    91,225 bytes    478,370 bytes   02:00:01.903
32              2:00:02.028     0:04:47.954     14,984 kbps     26,509 kbps     02:00:12.330    25,833 kbps     02:00:11.078    24,671 kbps     02:00:09.285    78,133 bytes    445,442 bytes   02:03:53.676
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x02            MPEG-2                                  7489.816                16,806                  15,734,050,376  85,615,921
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7489.816                3,871                   3,624,565,872   20,863,941
00002.M2TS      4353 (0x1101)   0x82            DTS             deu (German)            7489.816                755                     706,399,116     4,213,116
00002.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            7489.816                755                     706,399,116     4,213,116
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7489.816                36                      33,357,939      189,797
00002.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            7489.816                31                      29,262,125      167,032
00002.M2TS      4610 (0x1202)   0x90            PGS             deu (German)            7489.816                30                      28,277,786      161,464
00002.M2TS      4611 (0x1203)   0x90            PGS             deu (German)            7489.816                0                       131,233         754
00002.M2TS      4612 (0x1204)   0x90            PGS             swe (Swedish)           7489.816                28                      26,187,107      150,348
00002.M2TS      4613 (0x1205)   0x90            PGS             dan (Danish)            7489.816                30                      28,300,740      161,839
00002.M2TS      4614 (0x1206)   0x90            PGS             fin (Finnish)           7489.816                33                      30,560,800      174,130
00002.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         7489.816                31                      28,655,776      163,752
00002.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             7489.816                23                      21,705,376      125,836
00002.M2TS      4617 (0x1209)   0x90            PGS             fra (French)            7489.816                0                       466,259         2,678
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
Old 07-26-2009, 12:37 AM
Elf - 2003 - Australian Version
Distributed by Roadshow Entertainment
Locked to Region B, confirmed with AnyDVD HD
Unlike some distributed by Roadshow, this version seems to have been specifically developed for the company, commencing with the Roadshow logo at the start of the disc. It runs like a Warner disc.
It has a bunch of featurettes in 1080p24, all of which look to be (poorly) upconverted from 480i60. It also has something like 80 'Focus Points' through the movie, most less than a minute, some of which are fresh material ... brief statements by the wardrobe staff, etc. Some are links into the featurettes, which would explain why this SD material was converted to HD.
Code:
        Total   Video
00001.MPLS                                                      VC-1    1:36:43 19,880,251,392  39,106,335,472  27.41   21.95   DD AC3 5.1 640Kbps                        Dolby TrueHD 5.1 1512Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     ELF
Disc Size:      39,106,335,472 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:36:43 (h:m:s)
Total Bitrate:          27.41 Mbps
Description:
VIDEO:
VC-1 Video              21951 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby TrueHD Audio              English         1512 kbps       5.1 / 48 kHz / 1512 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Interactive Graphics            English         17.339 kbps
Presentation Graphics           English         37.929 kbps
Presentation Graphics           English         4.538 kbps
FILES:
00000.M2TS      0:00:00.000     1:36:43.172     19,880,251,392  27,406
CHAPTERS:
1               0:00:00.000     0:03:44.933     23,144 kbps     43,924 kbps     00:00:02.502    32,620 kbps     00:01:31.925    30,147 kbps     00:01:07.025    120,911 bytes   625,381 bytes   00:01:32.425
2               0:03:44.933     0:05:13.313     23,860 kbps     39,136 kbps     00:07:21.732    32,715 kbps     00:04:08.122    30,928 kbps     00:04:03.117    124,393 bytes   522,416 bytes   00:05:35.293
3               0:08:58.246     0:05:43.176     22,780 kbps     38,325 kbps     00:09:47.795    28,619 kbps     00:13:51.288    28,028 kbps     00:13:50.204    118,765 bytes   575,738 bytes   00:13:01.655
4               0:14:41.422     0:07:02.088     23,562 kbps     46,339 kbps     00:18:43.413    34,138 kbps     00:18:41.453    32,155 kbps     00:17:45.522    122,843 bytes   667,933 bytes   00:18:21.350
5               0:21:43.510     0:03:37.383     23,560 kbps     42,632 kbps     00:22:02.404    33,762 kbps     00:21:59.484    31,736 kbps     00:21:53.228    122,832 bytes   500,027 bytes   00:22:01.528
6               0:25:20.894     0:08:09.655     23,388 kbps     48,347 kbps     00:28:54.107    35,036 kbps     00:27:07.500    31,923 kbps     00:27:05.081    121,935 bytes   732,502 bytes   00:28:54.733
7               0:33:30.550     0:04:47.370     22,226 kbps     42,374 kbps     00:38:16.919    32,491 kbps     00:33:30.717    29,861 kbps     00:36:31.647    115,877 bytes   470,082 bytes   00:36:31.105
8               0:38:17.920     0:04:29.686     21,187 kbps     36,216 kbps     00:38:49.076    27,782 kbps     00:42:20.871    27,330 kbps     00:42:20.871    110,461 bytes   500,123 bytes   00:42:16.784
9               0:42:47.606     0:08:33.763     21,932 kbps     43,172 kbps     00:48:20.939    31,724 kbps     00:45:27.141    30,751 kbps     00:45:19.842    114,345 bytes   651,463 bytes   00:51:08.565
10              0:51:21.369     0:06:37.438     23,265 kbps     39,626 kbps     00:57:57.724    31,733 kbps     00:57:53.720    30,548 kbps     00:53:48.850    121,291 bytes   757,228 bytes   00:52:47.247
11              0:57:58.808     0:07:09.262     23,413 kbps     45,153 kbps     01:01:26.557    34,815 kbps     01:01:23.429    31,733 kbps     01:00:48.603    122,066 bytes   548,184 bytes   01:01:58.840
12              1:05:08.070     0:02:06.835     24,839 kbps     42,338 kbps     01:06:04.585    33,392 kbps     01:05:32.720    31,356 kbps     01:05:27.673    129,497 bytes   637,962 bytes   01:06:32.154
13              1:07:14.905     0:04:45.368     22,843 kbps     41,650 kbps     01:08:52.211    34,279 kbps     01:07:59.575    30,967 kbps     01:07:59.492    119,093 bytes   577,712 bytes   01:08:00.159
14              1:12:00.274     0:05:47.096     21,374 kbps     35,806 kbps     01:17:16.506    32,959 kbps     01:17:12.836    32,218 kbps     01:17:10.375    111,435 bytes   521,297 bytes   01:16:47.144
15              1:17:47.371     0:07:43.504     23,665 kbps     57,213 kbps     01:22:04.878    35,285 kbps     01:22:32.572    31,013 kbps     01:23:07.065    123,380 bytes   591,920 bytes   01:22:00.749
16              1:25:30.875     0:05:39.297     24,148 kbps     49,674 kbps     01:27:11.017    34,794 kbps     01:27:57.814    31,946 kbps     01:29:32.116    125,898 bytes   722,977 bytes   01:27:57.855
17              1:31:10.173     0:05:32.999     4,350 kbps      7,241 kbps      01:35:40.776    7,112 kbps      01:35:38.774    7,006 kbps      01:35:33.602    22,743 bytes    182,648 bytes   01:35:35.438
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    5803.047                21,951                  15,922,839,351  86,621,201
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5803.047                640                     464,256,000     2,720,250
00000.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           5803.047                2,152                   1,561,365,164   11,946,925
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5803.047                192                     139,276,800     906,750
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5803.047                192                     139,276,800     906,750
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5803.047                38                      27,513,641      158,363
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5803.047                5                       3,291,620       18,803
00000.M2TS      5120 (0x1400)   0x91            IGS             eng (English)           5803.047                17                      12,577,450      69,488
Stephen Dawson
hifi-writer.com
Old 07-26-2009, 03:58 AM
The Getaway - 1972 - Australian version
Distributed by Warner Bros Entertainment Australia Pty Ltd
Region A/B/C, confirmed with AnyDVD HD
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:02:49 17,265,420,288  22,114,740,816  18.74   16.02   DD AC3 1.0 192Kbps                        DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     VOLUME_ID
Disc Size:      22,114,740,816 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:02:49 (h:m:s)
Total Bitrate:          18.74 Mbps
Description:
VIDEO:
VC-1 Video              16017 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Italian         192 kbps        1.0 / 48 kHz / 192 kbps
Dolby Digital Audio             German          192 kbps        1.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         26.921 kbps
Presentation Graphics           English         32.032 kbps
Presentation Graphics           French          23.737 kbps
Presentation Graphics           Italian         13.631 kbps
Presentation Graphics           Italian         18.096 kbps
Presentation Graphics           German          14.965 kbps
Presentation Graphics           German          19.186 kbps
Presentation Graphics           Spanish         15.307 kbps
Presentation Graphics           Dutch           15.106 kbps
Presentation Graphics           Danish          13.405 kbps
Presentation Graphics           Finnish         14.870 kbps
Presentation Graphics           Norwegian       13.273 kbps
Presentation Graphics           Swedish         13.456 kbps
FILES:
00000.M2TS      0:00:00.000     2:02:49.153     17,265,420,288  18,743
CHAPTERS:
1               0:00:00.000     0:07:52.305     15,736 kbps     32,456 kbps     00:06:48.157    23,802 kbps     00:00:23.815    22,810 kbps     00:00:20.103    82,061 bytes    391,546 bytes   00:04:43.700
2               0:07:52.305     0:02:47.333     17,546 kbps     25,176 kbps     00:10:38.638    21,851 kbps     00:08:54.784    20,066 kbps     00:08:16.037    91,479 bytes    319,307 bytes   00:10:39.388
3               0:10:39.639     0:04:47.620     19,541 kbps     29,268 kbps     00:13:49.870    25,436 kbps     00:13:49.870    23,724 kbps     00:13:49.870    101,876 bytes   414,534 bytes   00:15:23.923
4               0:15:27.259     0:05:52.351     12,558 kbps     23,413 kbps     00:15:40.981    22,281 kbps     00:15:38.729    21,305 kbps     00:15:38.771    65,474 bytes    281,881 bytes   00:21:19.361
5               0:21:19.611     0:02:43.329     16,317 kbps     24,768 kbps     00:22:25.844    22,794 kbps     00:22:25.886    21,645 kbps     00:21:49.266    85,067 bytes    303,193 bytes   00:22:25.969
6               0:24:02.941     0:02:54.674     17,082 kbps     31,822 kbps     00:24:44.191    26,890 kbps     00:24:49.779    25,005 kbps     00:24:49.779    89,058 bytes    358,480 bytes   00:25:07.672
7               0:26:57.616     0:03:49.562     16,491 kbps     24,514 kbps     00:28:49.144    23,444 kbps     00:30:41.798    23,026 kbps     00:27:35.111    85,976 bytes    176,734 bytes   00:29:24.220
8               0:30:47.178     0:06:44.737     14,922 kbps     24,385 kbps     00:30:53.935    21,921 kbps     00:31:19.711    21,671 kbps     00:31:16.207    77,797 bytes    386,531 bytes   00:32:13.514
9               0:37:31.916     0:03:15.028     17,036 kbps     25,326 kbps     00:40:04.777    22,018 kbps     00:39:40.628    20,776 kbps     00:39:36.082    88,818 bytes    348,664 bytes   00:40:46.652
10              0:40:46.944     0:04:21.427     18,088 kbps     26,757 kbps     00:41:42.541    22,419 kbps     00:44:28.040    20,391 kbps     00:44:41.553    94,300 bytes    429,027 bytes   00:42:04.522
11              0:45:08.372     0:02:25.812     18,012 kbps     25,989 kbps     00:45:21.593    23,229 kbps     00:45:32.104    21,831 kbps     00:45:31.603    93,904 bytes    308,233 bytes   00:45:22.386
12              0:47:34.184     0:03:11.357     18,369 kbps     28,413 kbps     00:47:56.582    22,633 kbps     00:47:56.248    21,287 kbps     00:47:52.160    95,767 bytes    299,420 bytes   00:47:53.954
13              0:50:45.542     0:02:40.493     17,545 kbps     24,171 kbps     00:51:50.107    21,917 kbps     00:51:46.144    21,174 kbps     00:51:41.473    91,473 bytes    292,532 bytes   00:52:32.941
14              0:53:26.036     0:02:27.146     13,667 kbps     20,693 kbps     00:55:45.967    16,941 kbps     00:53:47.349    16,043 kbps     00:53:47.015    71,254 bytes    291,893 bytes   00:55:01.589
15              0:55:53.183     0:01:40.767     13,988 kbps     26,695 kbps     00:56:08.239    19,975 kbps     00:56:05.153    18,228 kbps     00:56:24.381    72,928 bytes    239,171 bytes   00:57:02.127
16              0:57:33.950     0:02:25.979     15,954 kbps     23,284 kbps     00:59:55.717    21,544 kbps     00:59:53.381    20,990 kbps     00:59:48.084    83,175 bytes    261,201 bytes   00:57:41.708
17              0:59:59.929     0:09:28.401     16,802 kbps     27,914 kbps     01:01:20.259    23,516 kbps     01:05:01.522    21,896 kbps     01:05:00.605    87,600 bytes    317,048 bytes   01:05:10.615
18              1:09:28.330     0:01:38.598     17,236 kbps     23,791 kbps     01:10:37.107    22,504 kbps     01:10:37.107    20,788 kbps     01:10:36.523    89,859 bytes    348,040 bytes   01:09:59.737
19              1:11:06.929     0:05:26.326     17,394 kbps     25,098 kbps     01:13:35.494    22,682 kbps     01:13:31.949    21,045 kbps     01:13:31.615    90,684 bytes    300,370 bytes   01:12:54.703
20              1:16:33.255     0:07:56.142     18,132 kbps     25,625 kbps     01:21:03.984    22,791 kbps     01:21:00.480    21,616 kbps     01:21:00.480    94,530 bytes    296,830 bytes   01:22:37.535
21              1:24:29.397     0:01:50.276     13,176 kbps     17,742 kbps     01:24:30.648    15,041 kbps     01:25:22.784    14,536 kbps     01:25:22.408    68,695 bytes    260,173 bytes   01:26:02.157
22              1:26:19.674     0:04:05.411     18,660 kbps     26,575 kbps     01:27:37.543    24,843 kbps     01:27:36.042    24,509 kbps     01:27:31.037    97,287 bytes    271,770 bytes   01:28:43.234
23              1:30:25.086     0:03:25.872     16,086 kbps     28,996 kbps     01:33:34.859    22,700 kbps     01:33:12.670    19,871 kbps     01:32:28.501    83,864 bytes    245,787 bytes   01:33:42.658
24              1:33:50.958     0:00:24.190     18,714 kbps     24,643 kbps     01:34:10.478    22,487 kbps     01:34:10.019    20,188 kbps     01:34:05.139    97,567 bytes    300,946 bytes   01:34:14.857
25              1:34:15.149     0:03:09.189     11,247 kbps     19,409 kbps     01:35:44.280    15,953 kbps     01:35:29.181    15,160 kbps     01:35:30.349    58,636 bytes    301,601 bytes   01:35:58.961
26              1:37:24.338     0:02:51.838     14,389 kbps     20,917 kbps     01:39:15.950    18,614 kbps     01:39:05.648    18,196 kbps     01:39:06.941    75,020 bytes    261,586 bytes   01:38:12.845
27              1:40:16.176     0:02:45.665     14,958 kbps     25,533 kbps     01:42:55.210    22,174 kbps     01:42:36.692    20,448 kbps     01:42:46.201    77,984 bytes    302,327 bytes   01:42:16.964
28              1:43:01.842     0:03:41.054     15,629 kbps     31,088 kbps     01:44:56.915    21,008 kbps     01:43:13.103    19,234 kbps     01:43:12.769    81,484 bytes    329,739 bytes   01:44:56.957
29              1:46:42.896     0:03:27.540     14,882 kbps     24,001 kbps     01:48:36.927    21,837 kbps     01:48:08.982    18,405 kbps     01:47:09.631    77,587 bytes    321,923 bytes   01:50:10.145
30              1:50:10.437     0:04:13.920     15,127 kbps     27,869 kbps     01:53:39.938    24,088 kbps     01:53:37.310    20,633 kbps     01:53:35.809    78,866 bytes    364,949 bytes   01:53:49.572
31              1:54:24.357     0:02:57.677     11,627 kbps     19,212 kbps     01:55:06.190    16,366 kbps     01:55:06.190    15,177 kbps     01:55:06.190    60,617 bytes    278,838 bytes   01:54:50.425
32              1:57:22.035     0:02:48.501     11,178 kbps     16,907 kbps     01:58:56.295    13,189 kbps     01:59:08.766    12,777 kbps     01:57:26.831    58,275 bytes    287,636 bytes   01:59:07.557
33              2:00:10.536     0:02:38.616     16,522 kbps     21,381 kbps     02:01:19.313    19,349 kbps     02:01:16.102    19,302 kbps     02:01:11.722    86,345 bytes    314,982 bytes   02:02:25.921
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7369.028                16,018                  14,754,298,263  80,292,279
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7369.028                192                     176,860,416     1,151,435
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            7369.028                192                     176,860,416     1,151,435
00000.M2TS      4354 (0x1102)   0x81            AC3             ita (Italian)           7369.028                192                     176,860,416     1,151,435
00000.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            7369.028                192                     176,860,416     1,151,435
00000.M2TS      4356 (0x1104)   0x81            AC3             spa (Spanish)           7369.028                192                     176,860,416     1,151,435
00000.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7369.028                192                     176,860,416     1,151,435
00000.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           7369.028                192                     176,860,416     1,151,435
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7369.028                27                      24,798,111      140,295
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7369.028                32                      29,505,846      166,638
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7369.028                24                      21,865,536      124,245
00000.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           7369.028                14                      12,555,769      73,799
00000.M2TS      4612 (0x1204)   0x90            PGS             ita (Italian)           7369.028                18                      16,668,577      97,300
00000.M2TS      4613 (0x1205)   0x90            PGS             deu (German)            7369.028                15                      13,784,634      80,524
00000.M2TS      4614 (0x1206)   0x90            PGS             deu (German)            7369.028                19                      17,673,528      102,618
00000.M2TS      4615 (0x1207)   0x90            PGS             spa (Spanish)           7369.028                15                      14,099,850      82,252
00000.M2TS      4616 (0x1208)   0x90            PGS             nld (Dutch)             7369.028                15                      13,914,635      81,212
00000.M2TS      4617 (0x1209)   0x90            PGS             dan (Danish)            7369.028                13                      12,348,111      72,666
00000.M2TS      4618 (0x120A)   0x90            PGS             fin (Finnish)           7369.028                15                      13,697,622      79,993
00000.M2TS      4619 (0x120B)   0x90            PGS             nor (Norwegian)         7369.028                13                      12,226,459      71,992
00000.M2TS      4620 (0x120C)   0x90            PGS             swe (Swedish)           7369.028                13                      12,394,803      72,923
Stephen Dawson
hifi-writer.com
Old 07-26-2009, 05:19 AM
Gods and Generals - 2003 - Australian version
Code:
        Total   Video
00000.MPLS                                                      VC-1    3:38:54 27,654,703,104  30,960,312,212  16.84   14.97   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     GODS_AND_GENERALS
Disc Size:      30,960,312,212 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 3:38:54 (h:m:s)
Total Bitrate:          16.84 Mbps
Description:
VIDEO:
VC-1 Video              14968 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
SUBTITLES:
Presentation Graphics           English         43.363 kbps
Presentation Graphics           English         44.995 kbps
Presentation Graphics           French          47.574 kbps
Presentation Graphics           Spanish         41.727 kbps
FILES:
00000.M2TS      0:00:00.000     2:07:13.125     15,498,485,760  16,243
00025.M2TS      2:07:13.125     1:31:41.329     12,156,168,192  17,677
00017.M2TS      3:38:54.454     0:00:00.500     49,152          786
CHAPTERS:
1               0:00:00.000     0:05:09.309     14,980 kbps     35,723 kbps     00:00:59.059    23,993 kbps     00:00:58.099    20,652 kbps     00:01:16.951    78,853 bytes    402,725 bytes   00:01:08.860
2               0:05:09.309     0:03:59.238     15,432 kbps     30,687 kbps     00:08:56.953    28,839 kbps     00:08:52.865    23,413 kbps     00:08:51.113    80,539 bytes    428,536 bytes   00:08:51.572
3               0:09:08.548     0:05:25.992     15,003 kbps     27,254 kbps     00:10:30.463    23,984 kbps     00:09:47.003    23,590 kbps     00:09:47.003    78,218 bytes    389,549 bytes   00:10:02.393
4               0:14:34.540     0:07:05.883     15,248 kbps     28,719 kbps     00:18:20.557    24,068 kbps     00:18:16.553    19,484 kbps     00:18:17.721    79,497 bytes    434,398 bytes   00:18:29.024
5               0:21:40.424     0:03:36.007     13,689 kbps     30,810 kbps     00:24:43.899    28,799 kbps     00:24:43.648    23,149 kbps     00:21:52.602    71,367 bytes    502,387 bytes   00:22:27.679
6               0:25:16.431     0:04:41.280     13,867 kbps     23,336 kbps     00:25:31.738    19,522 kbps     00:25:27.984    17,495 kbps     00:25:27.984    72,296 bytes    424,823 bytes   00:28:39.008
7               0:29:57.712     0:03:20.283     13,133 kbps     27,529 kbps     00:32:51.970    23,073 kbps     00:32:51.636    19,735 kbps     00:32:49.258    68,468 bytes    417,405 bytes   00:30:12.268
8               0:33:17.996     0:03:26.623     13,449 kbps     23,858 kbps     00:34:30.109    20,605 kbps     00:34:29.484    19,394 kbps     00:34:29.692    70,117 bytes    425,172 bytes   00:34:53.883
9               0:36:44.619     0:03:12.066     13,681 kbps     30,263 kbps     00:38:11.539    23,050 kbps     00:38:10.371    19,187 kbps     00:36:51.542    71,326 bytes    476,616 bytes   00:38:39.025
10              0:39:56.685     0:05:36.586     14,727 kbps     33,157 kbps     00:42:06.482    28,469 kbps     00:40:02.358    26,383 kbps     00:40:01.273    76,781 bytes    612,009 bytes   00:40:22.378
11              0:45:33.272     0:05:17.525     16,495 kbps     29,368 kbps     00:49:16.953    24,746 kbps     00:49:53.573    21,234 kbps     00:50:09.047    85,997 bytes    438,653 bytes   00:50:48.503
12              0:50:50.797     0:03:10.815     13,191 kbps     20,562 kbps     00:52:47.247    16,108 kbps     00:51:41.848    14,745 kbps     00:52:56.798    68,770 bytes    405,376 bytes   00:51:57.906
13              0:54:01.613     0:06:54.831     14,064 kbps     26,905 kbps     01:00:05.226    24,598 kbps     00:58:52.737    22,920 kbps     00:58:51.736    73,326 bytes    414,028 bytes   01:00:45.808
14              1:00:56.444     0:05:31.789     12,889 kbps     27,173 kbps     01:03:01.235    23,531 kbps     01:06:14.804    22,226 kbps     01:06:14.804    67,199 bytes    420,109 bytes   01:04:26.612
15              1:06:28.234     0:04:07.205     13,282 kbps     28,487 kbps     01:06:53.217    20,869 kbps     01:06:50.089    19,373 kbps     01:09:05.474    69,249 bytes    454,116 bytes   01:06:54.468
16              1:10:35.439     0:01:36.638     12,551 kbps     19,432 kbps     01:11:55.102    16,456 kbps     01:10:43.239    15,154 kbps     01:10:38.859    65,433 bytes    446,148 bytes   01:11:19.775
17              1:12:12.077     0:02:31.401     13,600 kbps     29,867 kbps     01:14:34.928    25,032 kbps     01:14:32.134    22,412 kbps     01:14:30.966    70,906 bytes    497,553 bytes   01:14:16.869
18              1:14:43.479     0:02:52.547     15,675 kbps     26,464 kbps     01:15:49.586    23,162 kbps     01:15:36.406    20,683 kbps     01:15:52.881    81,722 bytes    428,553 bytes   01:15:47.668
19              1:17:36.026     0:01:35.678     11,879 kbps     26,375 kbps     01:18:52.436    18,257 kbps     01:18:51.852    16,877 kbps     01:18:51.852    61,931 bytes    464,997 bytes   01:19:04.156
20              1:19:11.705     0:05:13.855     14,129 kbps     25,122 kbps     01:24:17.969    22,983 kbps     01:20:51.012    22,177 kbps     01:24:09.002    73,664 bytes    394,268 bytes   01:19:16.334
21              1:24:25.560     0:04:14.462     15,275 kbps     25,500 kbps     01:26:54.042    24,711 kbps     01:27:59.107    23,382 kbps     01:28:11.452    79,639 bytes    432,943 bytes   01:25:11.648
22              1:28:40.023     0:01:55.824     13,280 kbps     23,520 kbps     01:29:30.490    19,524 kbps     01:29:35.995    17,051 kbps     01:29:35.995    69,238 bytes    358,795 bytes   01:29:30.573
23              1:30:35.847     0:06:31.474     14,549 kbps     30,917 kbps     01:35:24.301    25,883 kbps     01:35:24.218    20,825 kbps     01:35:18.963    75,849 bytes    476,816 bytes   01:35:24.343
24              1:37:07.321     0:01:51.361     14,720 kbps     34,569 kbps     01:37:19.834    26,443 kbps     01:37:19.834    24,080 kbps     01:37:19.834    76,743 bytes    430,823 bytes   01:37:19.875
25              1:38:58.682     0:04:54.794     13,144 kbps     30,233 kbps     01:43:37.044    18,502 kbps     01:42:54.334    17,743 kbps     01:42:50.998    68,529 bytes    465,754 bytes   01:42:47.119
26              1:43:53.477     0:08:44.232     15,375 kbps     33,469 kbps     01:46:19.206    25,822 kbps     01:43:53.477    23,133 kbps     01:46:50.278    80,156 bytes    474,247 bytes   01:45:56.433
27              1:52:37.709     0:02:42.036     13,916 kbps     26,703 kbps     01:54:20.728    18,993 kbps     01:52:37.917    17,208 kbps     01:54:56.014    72,549 bytes    399,046 bytes   01:53:01.024
28              1:55:19.746     0:03:16.070     14,859 kbps     29,481 kbps     01:58:22.762    24,520 kbps     01:58:05.703    22,076 kbps     01:58:04.327    77,468 bytes    406,141 bytes   01:56:51.963
29              1:58:35.817     0:05:04.637     15,637 kbps     28,265 kbps     02:02:46.776    23,765 kbps     02:03:06.962    19,398 kbps     02:03:04.543    81,525 bytes    376,177 bytes   01:59:13.396
30              2:03:40.454     0:03:04.517     12,889 kbps     23,517 kbps     02:03:47.086    19,558 kbps     02:03:45.626    17,358 kbps     02:03:42.665    67,199 bytes    425,287 bytes   02:06:24.493
31              2:06:44.972     0:04:02.825     16,996 kbps     27,883 kbps     02:08:41.630    26,624 kbps     02:08:34.790    26,182 kbps     02:08:34.164    88,607 bytes    393,241 bytes   02:09:12.786
32              2:10:47.798     0:04:03.076     16,912 kbps     29,350 kbps     02:11:28.005    25,434 kbps     02:14:23.138    23,622 kbps     02:14:17.966    88,169 bytes    478,636 bytes   02:14:50.874
33              2:14:50.874     0:03:08.605     17,153 kbps     32,052 kbps     02:16:00.235    27,293 kbps     02:14:52.250    25,195 kbps     02:16:00.235    89,427 bytes    532,811 bytes   02:17:06.092
34              2:17:59.479     0:04:38.361     15,164 kbps     29,448 kbps     02:19:28.568    28,640 kbps     02:19:25.732    24,322 kbps     02:19:21.728    79,058 bytes    461,181 bytes   02:19:29.360
35              2:22:37.840     0:03:32.754     13,562 kbps     30,460 kbps     02:24:03.259    26,076 kbps     02:24:03.217    24,572 kbps     02:24:03.009    70,705 bytes    424,684 bytes   02:23:26.264
36              2:26:10.595     0:02:43.705     17,590 kbps     28,741 kbps     02:26:34.952    27,201 kbps     02:26:32.867    25,606 kbps     02:26:43.794    91,704 bytes    487,913 bytes   02:27:48.651
37              2:28:54.300     0:02:51.629     12,308 kbps     22,008 kbps     02:29:10.858    15,748 kbps     02:29:57.196    14,685 kbps     02:29:48.104    64,168 bytes    574,741 bytes   02:29:25.790
38              2:31:45.930     0:02:41.744     16,737 kbps     25,032 kbps     02:34:26.674    21,961 kbps     02:31:53.729    20,399 kbps     02:31:51.185    87,257 bytes    347,392 bytes   02:34:27.675
39              2:34:27.675     0:01:50.485     15,821 kbps     31,802 kbps     02:35:13.053    21,430 kbps     02:36:07.941    19,195 kbps     02:36:07.441    82,481 bytes    455,454 bytes   02:35:13.095
40              2:36:18.160     0:04:38.236     17,071 kbps     25,809 kbps     02:39:48.495    22,651 kbps     02:37:40.951    22,056 kbps     02:37:39.825    89,001 bytes    436,891 bytes   02:39:49.746
41              2:40:56.396     0:04:16.047     17,990 kbps     29,818 kbps     02:44:28.858    26,888 kbps     02:44:43.957    26,377 kbps     02:44:46.042    93,789 bytes    540,881 bytes   02:45:10.358
42              2:45:12.444     0:06:27.136     13,857 kbps     28,779 kbps     02:48:55.959    26,003 kbps     02:48:52.455    24,898 kbps     02:48:48.368    72,246 bytes    520,169 bytes   02:45:39.929
43              2:51:39.580     0:03:00.138     15,305 kbps     25,311 kbps     02:52:04.022    22,580 kbps     02:54:30.376    22,344 kbps     02:54:29.709    79,794 bytes    461,256 bytes   02:52:04.063
44              2:54:39.719     0:03:11.649     20,083 kbps     34,095 kbps     02:56:49.223    26,228 kbps     02:57:38.314    24,528 kbps     02:57:33.559    104,706 bytes   449,478 bytes   02:56:49.390
45              2:57:51.369     0:05:22.113     17,867 kbps     30,255 kbps     03:00:04.418    28,632 kbps     03:00:01.499    27,238 kbps     02:59:58.579    93,148 bytes    461,565 bytes   03:01:11.652
46              3:03:13.482     0:07:53.181     20,744 kbps     35,547 kbps     03:04:01.864    28,938 kbps     03:05:37.918    27,873 kbps     03:04:42.362    108,150 bytes   470,711 bytes   03:09:07.878
47              3:11:06.663     0:05:53.144     17,507 kbps     34,644 kbps     03:16:30.445    25,054 kbps     03:12:38.588    23,654 kbps     03:14:47.300    91,272 bytes    431,985 bytes   03:12:31.289
48              3:16:59.807     0:03:05.476     17,524 kbps     28,382 kbps     03:19:26.496    21,551 kbps     03:19:24.285    20,933 kbps     03:19:18.112    91,363 bytes    448,824 bytes   03:19:36.255
49              3:20:05.284     0:05:14.230     14,063 kbps     30,352 kbps     03:22:43.192    27,083 kbps     03:22:43.192    25,496 kbps     03:22:43.192    73,319 bytes    431,056 bytes   03:22:13.704
50              3:25:19.515     0:04:48.538     14,549 kbps     27,151 kbps     03:26:30.544    24,407 kbps     03:26:30.544    23,981 kbps     03:26:30.544    75,853 bytes    402,398 bytes   03:26:48.145
51              3:30:08.053     0:04:20.259     14,346 kbps     37,481 kbps     03:34:25.102    22,518 kbps     03:33:07.733    20,689 kbps     03:33:05.481    74,840 bytes    485,307 bytes   03:32:44.501
52              3:34:28.313     0:04:26.641     2,385 kbps      31,991 kbps     03:38:47.906    17,622 kbps     03:38:47.280    15,712 kbps     03:38:42.317    12,535 bytes    401,424 bytes   03:38:48.114
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    7633.000                14,372                  13,712,443,006  74,634,437
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           7633.000                640                     610,652,160     3,578,040
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           7633.000                192                     183,195,648     1,192,680
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7633.000                49                      46,540,078      260,344
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           7633.000                50                      48,146,695      269,442
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7633.000                53                      50,416,187      281,354
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7633.000                47                      44,515,315      249,253
00025.M2TS      4113 (0x1011)   0xEA            VC-1                                    5501.204                15,798                  10,863,256,159  59,118,826
00025.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5501.204                640                     440,107,520     2,578,755
00025.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5501.204                192                     132,032,256     859,585
00025.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5501.204                36                      24,656,789      138,175
00025.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5501.204                37                      25,728,475      144,227
00025.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5501.204                40                      27,693,653      154,876
00025.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5501.204                35                      23,994,413      134,643
00017.M2TS      4113 (0x1011)   0xEA            VC-1                                    0.375                   210                     9,871           62
00017.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           0.375                   262                     12,288          80
00017.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           0.375                   262                     12,288          80
00017.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           0.375                   0                       0               0
00017.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           0.375                   0                       0               0
00017.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            0.375                   0                       0               0
00017.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           0.375                   0                       0               0
Stephen Dawson
hifi-writer.com
Old 07-26-2009, 12:11 PM
Rieper's Avatar
Quoted: 154 Post(s)
Liked: 67
20th Century Fox | 2009 | 97 mins | Unrated | Jun 30, 2009
UPC: 024543588764
Region: A (Locked)*
Aspect Ratio: 2.35:1
BD Live 2.0: No
Subtitles: English SDH, French, Spanish
Disc Size: 50GB Dual Layer (BD50)
Note: 3-disc set includes Blu-ray + DVD + Digital copy
*Confirmed using WinDVD set to region B, would not let me play saying it was Region A disc.
Unrated Cut
Code:
        Total   Video
00314.MPLS                                                      AVC     1:37:22 24,628,242,432  34,388,623,567  33.72   27.64   DTS-HD Master 5.1 3990Kbps (48kHz/24-bit)
DISC INFO:
Disc Title:     LEGEND_OF_CHUN_LI
Disc Size:      34,388,623,567 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:37:22 (h:m:s)
Total Bitrate:          33.72 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        27640 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3990 kbps       5.1 / 48 kHz / 3990 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         33.075 kbps
Presentation Graphics           English         2.396 kbps
Presentation Graphics           French          30.780 kbps
Presentation Graphics           Spanish         30.369 kbps
FILES:
00300.M2TS      0:00:00.000     0:14:48.387     3,717,427,200   33,476
00370.M2TS      0:14:48.387     0:01:31.257     388,958,208     34,098
00371.M2TS      0:16:19.645     0:33:22.750     8,481,368,064   33,879
00302.M2TS      0:49:42.396     0:02:07.252     528,175,104     33,205
00303.M2TS      0:51:49.648     0:00:52.218     219,918,336     33,692
00305.M2TS      0:52:41.866     0:03:47.727     951,705,600     33,433
00306.M2TS      0:56:29.594     0:26:15.115     6,678,220,800   33,919
00308.M2TS      1:22:44.709     0:00:46.254     195,483,648     33,810
00309.M2TS      1:23:30.964     0:04:34.232     1,159,077,888   33,813
00311.M2TS      1:28:05.196     0:01:48.358     460,363,776     33,988
00312.M2TS      1:29:53.554     0:07:28.906     1,847,543,808   32,925
CHAPTERS:
1               0:00:00.000     0:04:20.134     27,337 kbps     47,812 kbps     00:02:15.802    34,240 kbps     00:01:48.024    32,337 kbps     00:02:15.593    142,501 bytes   763,430 bytes   00:02:16.010
2               0:04:20.134     0:03:37.842     27,916 kbps     39,317 kbps     00:04:51.374    30,776 kbps     00:04:41.572    29,722 kbps     00:04:42.156    145,542 bytes   555,121 bytes   00:04:20.927
3               0:07:57.977     0:01:42.602     27,340 kbps     35,603 kbps     00:08:47.860    29,942 kbps     00:08:47.360    29,231 kbps     00:08:39.143    142,536 bytes   485,102 bytes   00:08:57.703
4               0:09:40.580     0:02:53.798     27,677 kbps     39,960 kbps     00:11:16.425    34,918 kbps     00:11:07.500    34,680 kbps     00:11:02.620    144,293 bytes   576,633 bytes   00:11:02.662
5               0:12:34.378     0:03:41.971     27,724 kbps     42,052 kbps     00:14:50.014    34,414 kbps     00:14:50.055    33,073 kbps     00:14:48.137    144,538 bytes   566,159 bytes   00:15:20.127
6               0:16:16.350     0:02:27.981     27,055 kbps     36,032 kbps     00:16:21.271    30,084 kbps     00:17:54.740    29,332 kbps     00:17:50.986    141,050 bytes   572,471 bytes   00:16:21.480
7               0:18:44.331     0:03:04.601     27,317 kbps     42,324 kbps     00:21:37.087    33,342 kbps     00:18:47.251    32,066 kbps     00:18:59.221    142,420 bytes   625,258 bytes   00:18:51.463
8               0:21:48.932     0:01:13.740     28,136 kbps     34,592 kbps     00:21:53.020    30,899 kbps     00:21:49.099    29,423 kbps     00:21:49.683    146,687 bytes   552,079 bytes   00:21:49.725
9               0:23:02.672     0:05:39.505     28,578 kbps     42,710 kbps     00:24:48.820    34,893 kbps     00:24:39.853    33,840 kbps     00:24:39.811    148,991 bytes   636,159 bytes   00:24:21.626
10              0:28:42.178     0:04:12.126     27,339 kbps     37,179 kbps     00:30:40.338    34,562 kbps     00:32:09.844    33,204 kbps     00:32:10.053    142,533 bytes   611,647 bytes   00:30:38.878
11              0:32:54.305     0:02:32.360     27,604 kbps     41,248 kbps     00:34:27.064    34,042 kbps     00:34:53.674    33,070 kbps     00:34:51.214    143,914 bytes   644,098 bytes   00:34:28.065
12              0:35:26.666     0:05:24.198     28,502 kbps     42,841 kbps     00:40:10.699    35,461 kbps     00:40:22.962    34,194 kbps     00:40:19.542    148,595 bytes   634,081 bytes   00:37:29.372
13              0:40:50.865     0:02:16.052     29,048 kbps     40,734 kbps     00:41:56.680    32,961 kbps     00:43:01.912    31,091 kbps     00:42:43.644    151,442 bytes   624,715 bytes   00:42:50.234
14              0:43:06.917     0:07:57.310     26,715 kbps     42,436 kbps     00:47:20.712    36,001 kbps     00:48:39.333    33,409 kbps     00:48:37.497    139,279 bytes   626,352 bytes   00:50:06.670
15              0:51:04.227     0:01:37.639     28,348 kbps     40,659 kbps     00:51:51.274    34,630 kbps     00:51:48.980    32,614 kbps     00:51:44.768    147,793 bytes   595,569 bytes   00:52:11.211
16              0:52:41.866     0:03:37.258     27,554 kbps     49,843 kbps     00:53:24.993    34,648 kbps     00:53:24.659    33,734 kbps     00:53:24.826    143,655 bytes   626,873 bytes   00:53:50.560
17              0:56:19.125     0:03:01.180     27,300 kbps     38,494 kbps     00:57:30.154    32,776 kbps     00:58:41.809    31,339 kbps     00:58:16.367    142,330 bytes   533,005 bytes   00:57:51.050
18              0:59:20.306     0:03:53.483     27,480 kbps     38,831 kbps     01:00:00.555    31,846 kbps     01:01:40.905    31,181 kbps     01:01:36.692    143,270 bytes   608,414 bytes   01:01:45.118
19              1:03:13.789     0:04:32.814     27,060 kbps     38,065 kbps     01:03:42.235    29,991 kbps     01:04:00.336    28,929 kbps     01:04:00.336    141,076 bytes   588,116 bytes   01:03:42.902
20              1:07:46.604     0:02:40.577     29,888 kbps     42,104 kbps     01:10:21.925    34,029 kbps     01:10:21.925    32,521 kbps     01:10:17.171    155,822 bytes   579,163 bytes   01:09:57.276
21              1:10:27.181     0:02:22.600     29,193 kbps     41,078 kbps     01:11:01.965    35,064 kbps     01:11:01.382    34,181 kbps     01:11:01.256    152,198 bytes   637,378 bytes   01:11:23.570
22              1:12:49.782     0:02:19.222     28,469 kbps     40,989 kbps     01:14:36.138    34,200 kbps     01:14:32.009    31,892 kbps     01:14:27.212    148,423 bytes   547,988 bytes   01:14:19.121
23              1:15:09.004     0:02:30.441     27,299 kbps     45,821 kbps     01:16:07.896    34,099 kbps     01:15:44.247    31,018 kbps     01:15:44.331    142,326 bytes   539,305 bytes   01:16:08.772
24              1:17:39.446     0:02:23.351     26,765 kbps     40,657 kbps     01:19:50.243    31,296 kbps     01:19:52.495    30,273 kbps     01:19:50.243    139,540 bytes   549,092 bytes   01:18:45.595
25              1:20:02.797     0:02:12.048     27,184 kbps     38,684 kbps     01:20:05.050    31,927 kbps     01:20:04.049    30,648 kbps     01:20:03.423    141,723 bytes   612,014 bytes   01:20:25.987
26              1:22:14.846     0:02:26.646     27,367 kbps     43,828 kbps     01:23:21.830    33,050 kbps     01:23:21.830    31,804 kbps     01:23:21.830    142,681 bytes   540,162 bytes   01:23:22.664
27              1:24:41.492     0:05:12.061     27,516 kbps     46,397 kbps     01:26:20.883    33,832 kbps     01:26:12.750    32,729 kbps     01:26:12.750    143,458 bytes   562,677 bytes   01:28:14.539
28              1:29:53.554     0:07:28.906     26,949 kbps     46,728 kbps     01:32:13.736    34,215 kbps     01:32:09.482    33,098 kbps     01:31:24.729    140,513 bytes   780,575 bytes   01:34:08.934
STREAM DIAGNOSTICS:
00300.M2TS      4113 (0x1011)   0x1B            AVC                                     888.262                 27,601                  3,064,631,326   16,668,115
00300.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           888.262                 3,787                   420,528,708     2,423,444
00300.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           888.262                 224                     24,875,648      138,815
00300.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           888.262                 34                      3,775,193       21,512
00300.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            888.262                 34                      3,720,100       21,021
00300.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           888.262                 33                      3,645,295       20,616
00300.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           888.262                 5                       574,426         3,323
00370.M2TS      4113 (0x1011)   0x1B            AVC                                     91.174                  27,781                  316,619,339     1,722,048
00370.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           91.174                  4,193                   47,788,588      273,969
00370.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           91.174                  224                     2,555,392       14,260
00370.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           91.174                  46                      524,437         2,995
00370.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            91.174                  42                      473,607         2,694
00370.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           91.174                  44                      501,103         2,844
00370.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           91.174                  5                       60,628          352
00371.M2TS      4113 (0x1011)   0x1B            AVC                                     2002.667                27,744                  6,945,298,039   37,774,360
00371.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           2002.667                4,013                   1,004,477,752   5,771,380
00371.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           2002.667                224                     56,077,056      312,930
00371.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           2002.667                40                      9,936,537       56,308
00371.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            2002.667                39                      9,729,638       54,755
00371.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           2002.667                38                      9,496,065       53,478
00371.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           2002.667                3                       831,926         4,759
00302.M2TS      4113 (0x1011)   0x1B            AVC                                     127.127                 27,757                  441,076,758     2,398,953
00302.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           127.127                 3,353                   53,278,404      309,555
00302.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           127.127                 224                     3,563,392       19,885
00302.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           127.127                 48                      758,436         4,286
00302.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            127.127                 50                      795,586         4,466
00302.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           127.127                 50                      798,177         4,475
00302.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           127.127                 0                       70              7
00303.M2TS      4113 (0x1011)   0x1B            AVC                                     52.094                  27,835                  181,253,074     985,818
00303.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           52.094                  3,860                   25,137,160      144,711
00303.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           52.094                  225                     1,462,272       8,160
00303.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           52.094                  35                      224,735         1,303
00303.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            52.094                  19                      123,884         719
00303.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           52.094                  20                      129,528         749
00303.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           52.094                  3                       21,016          122
00305.M2TS      4113 (0x1011)   0x1B            AVC                                     227.602                 27,548                  783,754,724     4,262,728
00305.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           227.602                 3,784                   107,642,404     620,463
00305.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           227.602                 224                     6,376,832       35,585
00305.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           227.602                 42                      1,185,476       6,753
00305.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            227.602                 47                      1,337,651       7,524
00305.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           227.602                 45                      1,267,144       7,137
00305.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           227.602                 0                       70              7
00306.M2TS      4113 (0x1011)   0x1B            AVC                                     1575.032                27,758                  5,464,885,699   29,722,608
00306.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1575.032                4,083                   803,826,884     4,614,235
00306.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           1575.032                224                     44,103,808      246,115
00306.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1575.032                26                      5,130,248       29,503
00306.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            1575.032                24                      4,741,482       26,887
00306.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1575.032                24                      4,736,017       26,861
00306.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           1575.032                1                       261,575         1,508
00308.M2TS      4113 (0x1011)   0x1B            AVC                                     46.129                  27,761                  160,075,829     870,633
00308.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           46.129                  4,136                   23,846,416      136,799
00308.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           46.129                  225                     1,295,616       7,230
00308.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           46.129                  2                       11,514          69
00308.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            46.129                  0                       70              7
00308.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           46.129                  0                       70              7
00308.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           46.129                  0                       70              7
00309.M2TS      4113 (0x1011)   0x1B            AVC                                     274.149                 27,406                  939,161,392     5,108,042
00309.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           274.149                 4,379                   150,075,644     858,530
00309.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           274.149                 224                     7,678,720       42,850
00309.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           274.149                 15                      512,101         2,955
00309.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            274.149                 11                      388,597         2,207
00309.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           274.149                 12                      404,209         2,290
00309.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           274.149                 0                       70              7
00311.M2TS      4113 (0x1011)   0x1B            AVC                                     108.233                 27,790                  375,977,608     2,044,901
00311.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           108.233                 4,168                   56,396,024      323,334
00311.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           108.233                 224                     3,034,752       16,935
00311.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           108.233                 22                      298,296         1,725
00311.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            108.233                 19                      250,524         1,428
00311.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           108.233                 19                      262,363         1,493
00311.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           108.233                 0                       70              7
00312.M2TS      4113 (0x1011)   0x1B            AVC                                     448.823                 26,962                  1,512,650,983   8,227,247
00312.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           448.823                 3,943                   221,192,900     1,271,873
00312.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           448.823                 224                     12,569,984      70,145
00312.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           448.823                 32                      1,797,676       10,151
00312.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            448.823                 16                      917,714         5,189
00312.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           448.823                 17                      938,566         5,303
00312.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           448.823                 0                       70              7
Theatrical Cut (Rated PG-13)
Code:
        Total   Video
00313.MPLS                                                      AVC     1:36:35 24,434,110,464  34,388,623,567  33.73   27.64   DTS-HD Master 5.1 3995Kbps (48kHz/24-bit)
DISC INFO:
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:36:35 (h:m:s)
Total Bitrate:          33.73 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        27637 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3995 kbps       5.1 / 48 kHz / 3995 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         33.272 kbps
Presentation Graphics           English         2.416 kbps
Presentation Graphics           French          31.001 kbps
Presentation Graphics           Spanish         30.591 kbps
FILES:
00369.M2TS      0:14:48.387     0:01:31.257     388,724,736     34,077
00301.M2TS      0:49:42.396     0:01:38.014     408,416,256     33,335
00303.M2TS      0:51:20.410     0:00:52.218     219,918,336     33,692
00304.M2TS      0:52:12.629     0:03:30.293     877,805,568     33,394
00306.M2TS      0:55:42.922     0:26:15.115     6,678,220,800   33,919
00307.M2TS      1:21:58.038     0:00:46.254     195,428,352     33,801
00309.M2TS      1:22:44.292     0:04:34.232     1,159,077,888   33,813
00310.M2TS      1:27:18.524     0:01:48.358     460,179,456     33,975
00312.M2TS      1:29:06.883     0:07:28.906     1,847,543,808   32,925
CHAPTERS:
5               0:12:34.378     0:03:41.971     27,730 kbps     41,892 kbps     00:14:50.014    34,483 kbps     00:14:49.722    33,181 kbps     00:14:48.137    144,569 bytes   566,125 bytes   00:15:20.127
6               0:16:16.350     0:02:27.981     27,046 kbps     36,032 kbps     00:16:21.271    30,084 kbps     00:17:54.740    29,332 kbps     00:17:50.986    141,004 bytes   572,471 bytes   00:16:21.480
14              0:43:06.917     0:07:28.072     26,732 kbps     42,436 kbps     00:47:20.712    36,001 kbps     00:48:39.333    33,409 kbps     00:48:37.497    139,368 bytes   601,716 bytes   00:50:07.462
15              0:50:34.990     0:01:37.639     27,917 kbps     40,659 kbps     00:51:22.037    34,571 kbps     00:51:19.743    32,222 kbps     00:51:15.530    145,545 bytes   595,569 bytes   00:51:41.973
16              0:52:12.629     0:02:48.334     27,632 kbps     53,228 kbps     00:52:55.880    33,704 kbps     00:52:55.547    33,174 kbps     00:52:55.547    144,063 bytes   628,820 bytes   00:52:56.756
17              0:55:00.964     0:03:32.670     27,250 kbps     38,494 kbps     00:56:43.483    32,776 kbps     00:57:55.138    31,339 kbps     00:57:29.696    142,067 bytes   533,005 bytes   00:57:04.379
18              0:58:33.635     0:03:53.733     27,490 kbps     38,831 kbps     00:59:13.883    31,846 kbps     01:00:54.233    31,181 kbps     01:00:50.021    143,318 bytes   608,414 bytes   01:00:58.446
19              1:02:27.368     0:04:32.563     27,051 kbps     38,065 kbps     01:02:55.563    29,991 kbps     01:03:13.664    28,929 kbps     01:03:13.664    141,033 bytes   588,116 bytes   01:02:56.230
20              1:06:59.932     0:02:40.577     29,888 kbps     42,104 kbps     01:09:35.254    34,029 kbps     01:09:35.254    32,521 kbps     01:09:30.499    155,822 bytes   579,163 bytes   01:09:10.604
21              1:09:40.509     0:02:22.600     29,193 kbps     41,078 kbps     01:10:15.294    35,064 kbps     01:10:14.710    34,181 kbps     01:10:14.585    152,198 bytes   637,378 bytes   01:10:36.899
22              1:12:03.110     0:02:19.222     28,469 kbps     40,989 kbps     01:13:49.466    34,200 kbps     01:13:45.337    31,892 kbps     01:13:40.541    148,423 bytes   547,988 bytes   01:13:32.449
23              1:14:22.332     0:02:30.441     27,299 kbps     45,821 kbps     01:15:21.224    34,099 kbps     01:14:57.576    31,018 kbps     01:14:57.659    142,326 bytes   539,305 bytes   01:15:22.100
24              1:16:52.774     0:02:23.351     26,765 kbps     40,657 kbps     01:19:03.572    31,296 kbps     01:19:05.824    30,273 kbps     01:19:03.572    139,540 bytes   549,092 bytes   01:17:58.924
25              1:19:16.126     0:02:12.048     27,184 kbps     38,684 kbps     01:19:18.378    31,927 kbps     01:19:17.377    30,648 kbps     01:19:16.751    141,723 bytes   612,014 bytes   01:19:39.316
26              1:21:28.174     0:02:26.771     27,363 kbps     44,001 kbps     01:22:35.158    33,090 kbps     01:22:35.158    31,808 kbps     01:22:35.158    142,657 bytes   539,876 bytes   01:22:35.992
27              1:23:54.946     0:05:11.936     27,513 kbps     46,397 kbps     01:25:34.212    33,832 kbps     01:25:26.079    32,729 kbps     01:25:26.079    143,439 bytes   563,263 bytes   01:27:27.867
28              1:29:06.883     0:07:28.906     26,949 kbps     46,728 kbps     01:31:27.064    34,215 kbps     01:31:22.810    33,098 kbps     01:30:38.057    140,513 bytes   780,575 bytes   01:33:22.263
STREAM DIAGNOSTICS:
00369.M2TS      4113 (0x1011)   0x1B            AVC                                     91.174                  27,781                  316,618,840     1,722,047
00369.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           91.174                  4,175                   47,577,516      272,813
00369.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           91.174                  224                     2,555,392       14,260
00369.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           91.174                  45                      516,731         2,953
00369.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            91.174                  42                      473,607         2,694
00369.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           91.174                  44                      501,103         2,844
00369.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           91.174                  5                       60,628          352
00301.M2TS      4113 (0x1011)   0x1B            AVC                                     97.889                  27,716                  339,135,827     1,844,509
00301.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           97.889                  3,488                   42,679,692      247,275
00301.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           97.889                  224                     2,744,448       15,315
00301.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           97.889                  60                      738,264         4,163
00301.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            97.889                  63                      776,245         4,360
00301.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           97.889                  64                      782,136         4,388
00301.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           97.889                  0                       70              7
00304.M2TS      4113 (0x1011)   0x1B            AVC                                     210.168                 27,521                  723,015,269     3,932,424
00304.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           210.168                 3,764                   98,872,656      570,017
00304.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           210.168                 224                     5,888,512       32,860
00304.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           210.168                 44                      1,163,403       6,612
00304.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            210.168                 51                      1,337,651       7,524
00304.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           210.168                 48                      1,267,144       7,137
00304.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           210.168                 0                       70              7
00307.M2TS      4113 (0x1011)   0x1B            AVC                                     46.129                  27,751                  160,017,454     870,306
00307.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           46.129                  4,136                   23,849,588      136,842
00307.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           46.129                  225                     1,295,616       7,230
00307.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           46.129                  2                       11,514          69
00307.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            46.129                  0                       70              7
00307.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           46.129                  0                       70              7
00307.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           46.129                  0                       70              7
00310.M2TS      4113 (0x1011)   0x1B            AVC                                     108.233                 27,778                  375,810,482     2,044,012
00310.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           108.233                 4,168                   56,388,420      323,274
00310.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           108.233                 224                     3,034,752       16,935
00310.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           108.233                 22                      298,296         1,725
00310.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            108.233                 19                      250,524         1,428
00310.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           108.233                 19                      262,363         1,493
00310.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           108.233                 0                       70              7
Rieper is offline
Old 07-26-2009, 06:27 PM - Thread Starter
[US] Confessions of a Shopaholic (Additional Details)
Region Locked (AC) (confirmed w/ PowerDVD 8)
Studio: Disney
Release Date: 2009-06-23
UPC: 786936792751
Aspect Ratio: 2.40:1
Subs: English (SDH), Chinese (Simplified), Chinese (Traditional), Chinese (Unknown), French, French (Text), Indonesian, Korean, Malay, Portuguese, Portuguese (Text), Spanish, Spanish (Text), Thai, Thai (Text)
As mentioned several posts above, this release is Region AC locked. I'm not sure what the third set of Chinese subtitles is, but it's definitely different than the other two.
Code:
        Total   Video
Confessions of a Shopaholic                                     AVC     1:44:13 26,274,349,056  31,892,935,410  33.61   23.71   DTS-HD Master 5.1 3600Kbps (48kHz/24-bit) DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     SEW1NNE1
Disc Size:      31,892,935,410 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:44:13 (h:m:s)
Total Bitrate:          33.61 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23712 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3600 kbps       5.1 / 48 kHz / 3600 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Chinese         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Thai            640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         40.769 kbps
Presentation Graphics           Chinese         34.002 kbps
Presentation Graphics           Chinese         30.430 kbps
Presentation Graphics           Chinese         30.435 kbps
Presentation Graphics           French          38.874 kbps
Presentation Graphics           French          0.647 kbps
Presentation Graphics           Indonesian      38.953 kbps
Presentation Graphics           Korean          23.254 kbps
Presentation Graphics           Malay           43.288 kbps
Presentation Graphics           Portuguese      38.530 kbps
Presentation Graphics           Portuguese      0.850 kbps
Presentation Graphics           Spanish         34.073 kbps
Presentation Graphics           Spanish         0.620 kbps
Presentation Graphics           Thai            33.250 kbps
Presentation Graphics           Thai            0.076 kbps
FILES:
00125.M2TS      0:00:00.000     1:44:13.288     26,274,349,056  33,613
CHAPTERS:
1               0:00:00.000     0:04:21.552     22,290 kbps     36,284 kbps     00:03:52.148    35,398 kbps     00:03:47.936    30,492 kbps     00:03:45.975    116,192 bytes   387,278 bytes   00:00:41.124
2               0:04:21.552     0:04:53.001     23,884 kbps     36,122 kbps     00:04:32.355    35,378 kbps     00:04:28.601    31,106 kbps     00:08:01.814    124,518 bytes   339,963 bytes   00:04:28.643
3               0:09:14.554     0:05:32.874     30,203 kbps     43,656 kbps     00:13:27.306    37,126 kbps     00:13:23.344    35,443 kbps     00:12:20.406    157,465 bytes   365,058 bytes   00:13:27.932
4               0:14:47.428     0:06:30.848     28,485 kbps     37,555 kbps     00:20:49.623    35,823 kbps     00:20:45.369    35,459 kbps     00:20:43.742    148,509 bytes   333,503 bytes   00:20:42.658
5               0:21:18.277     0:04:37.485     30,984 kbps     37,382 kbps     00:22:53.080    35,651 kbps     00:24:41.855    35,457 kbps     00:22:26.511    161,538 bytes   342,295 bytes   00:24:46.026
6               0:25:55.762     0:04:13.211     21,235 kbps     36,555 kbps     00:29:46.785    35,394 kbps     00:29:57.921    33,344 kbps     00:29:54.918    110,711 bytes   293,099 bytes   00:27:44.162
7               0:30:08.973     0:06:20.213     26,472 kbps     42,030 kbps     00:31:37.937    35,680 kbps     00:34:19.766    35,500 kbps     00:34:14.677    138,012 bytes   332,328 bytes   00:31:38.479
8               0:36:29.187     0:04:23.429     23,129 kbps     39,263 kbps     00:37:41.968    34,056 kbps     00:40:46.986    28,711 kbps     00:38:26.887    120,584 bytes   567,437 bytes   00:37:42.760
9               0:40:52.616     0:05:18.318     21,180 kbps     34,630 kbps     00:40:53.617    30,832 kbps     00:40:53.117    28,554 kbps     00:40:53.284    110,425 bytes   284,701 bytes   00:44:37.216
10              0:46:10.934     0:06:50.326     24,760 kbps     36,831 kbps     00:51:08.356    35,486 kbps     00:49:38.266    35,404 kbps     00:49:37.015    129,087 bytes   295,085 bytes   00:53:01.261
11              0:53:01.261     0:05:57.273     23,620 kbps     41,594 kbps     00:53:02.596    33,076 kbps     00:58:14.115    31,897 kbps     00:58:08.485    123,144 bytes   367,768 bytes   00:53:03.263
12              0:58:58.535     0:05:31.914     25,823 kbps     35,897 kbps     01:00:01.931    34,453 kbps     00:59:57.927    33,378 kbps     00:59:53.590    134,629 bytes   336,925 bytes   01:01:28.851
13              1:04:30.449     0:02:55.592     25,388 kbps     36,312 kbps     01:06:05.211    32,117 kbps     01:06:00.998    31,041 kbps     01:06:01.999    132,361 bytes   410,529 bytes   01:06:01.082
14              1:07:26.042     0:05:04.721     26,611 kbps     39,500 kbps     01:11:57.062    36,008 kbps     01:11:53.017    35,431 kbps     01:12:05.738    138,736 bytes   336,033 bytes   01:11:48.679
15              1:12:30.763     0:05:15.898     20,794 kbps     30,825 kbps     01:13:24.608    29,004 kbps     01:13:21.605    25,653 kbps     01:12:35.225    108,412 bytes   311,657 bytes   01:14:56.450
16              1:17:46.662     0:05:45.219     20,667 kbps     33,109 kbps     01:18:34.751    30,072 kbps     01:23:02.018    29,359 kbps     01:23:02.018    107,749 bytes   353,071 bytes   01:19:56.750
17              1:23:31.881     0:06:11.662     22,855 kbps     31,968 kbps     01:27:30.411    28,057 kbps     01:27:29.535    26,605 kbps     01:25:36.589    119,158 bytes   337,945 bytes   01:29:43.544
18              1:29:43.544     0:04:25.098     23,162 kbps     36,121 kbps     01:30:13.699    31,275 kbps     01:30:13.616    29,458 kbps     01:30:37.807    120,758 bytes   328,473 bytes   01:30:13.741
19              1:34:08.643     0:05:11.269     23,529 kbps     36,344 kbps     01:39:10.319    35,467 kbps     01:37:05.069    35,339 kbps     01:37:05.611    122,670 bytes   352,981 bytes   01:35:42.611
20              1:39:19.912     0:04:53.376     6,773 kbps      35,965 kbps     01:39:22.414    25,604 kbps     01:39:21.163    19,209 kbps     01:40:01.203    35,317 bytes    277,099 bytes   01:40:09.211
STREAM DIAGNOSTICS:
00125.M2TS      4113 (0x1011)   0x1B            AVC                                     6253.122                23,712                  18,534,418,460  100,818,117
00125.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6253.122                3,600                   2,813,832,696   16,267,577
00125.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6253.122                640                     500,264,960     2,931,240
00125.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6253.122                640                     500,264,960     2,931,240
00125.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           6253.122                640                     500,264,960     2,931,240
00125.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        6253.122                640                     500,264,960     2,931,240
00125.M2TS      4357 (0x1105)   0x81            AC3             tha (Thai)              6253.122                640                     500,264,960     2,931,240
00125.M2TS      4358 (0x1106)   0x81            AC3             zho (Chinese)           6253.122                640                     500,264,960     2,931,240
00125.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6253.122                41                      31,867,312      184,156
00125.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6253.122                39                      30,386,188      174,685
00125.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6253.122                34                      26,633,269      154,183
00125.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        6253.122                39                      30,117,191      173,439
00125.M2TS      4612 (0x1204)   0x90            PGS             tha (Thai)              6253.122                33                      25,990,589      150,870
00125.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           6253.122                34                      26,577,716      154,418
00125.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           6253.122                30                      23,786,290      139,155
00125.M2TS      4615 (0x1207)   0x90            PGS             zho (Chinese)           6253.122                30                      23,786,290      139,155
00125.M2TS      4616 (0x1208)   0x90            PGS             ind (Indonesian)        6253.122                39                      30,447,729      175,298
00125.M2TS      4617 (0x1209)   0x90            PGS             msa (Malay)             6253.122                43                      33,836,590      193,883
00125.M2TS      4618 (0x120A)   0x90            PGS             kor (Korean)            6253.122                23                      18,176,997      108,066
00125.M2TS      4619 (0x120B)   0x90            PGS             fra (French)            6253.122                1                       506,028         2,921
00125.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           6253.122                1                       485,009         2,809
00125.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        6253.122                1                       664,418         3,831
00125.M2TS      4622 (0x120E)   0x90            PGS             tha (Thai)              6253.122                0                       59,197          356
00125.M2TS      4623 (0x120F)   0x90            PGS             zho (Chinese)           6253.122                30                      23,789,801      139,174
Cinema Squid is offline
Old 07-26-2009, 06:33 PM - Thread Starter
Cinema Squid's Avatar
[US] Frost/Nixon (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8)
Studio: Universal
Release Date: 2009-04-21
UPC: 025195053433
Subs: English (SDH), French, French (Text), Spanish, Spanish (Text)
There is a playlist on disc without the extra little 6 second M2TS tacked onto the end, but this is the one that seems to get launched when I play the movie.
Code:
        Total   Video
Frost/Nixon                                                     VC-1    2:01:57 31,655,497,728  42,240,681,075  34.61   24.94   DTS-HD Master 5.1 3237Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FROSTNIXON
Disc Size:      42,240,681,075 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:01:57 (h:m:s)
Total Bitrate:          34.61 Mbps
Description:
VIDEO:
VC-1 Video              24941 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
VC-1 Video              1990 kbps           480p / 23.976 fps / 16:9 / Advanced Profile 2
VC-1 Video              194 kbps            480p / 23.976 fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         3237 kbps       5.1 / 48 kHz / 3237 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 16-bit
DTS Express                     English         192 kbps        2.0 / 48 kHz / 192 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         57.361 kbps
Presentation Graphics           French          50.607 kbps
Presentation Graphics           French          0.579 kbps
Presentation Graphics           Spanish         41.615 kbps
Presentation Graphics           Spanish         0.470 kbps
FILES:
00010.M2TS      0:00:00.000     2:01:51.512     31,646,078,976  34,626
00083.M2TS      2:01:51.512     0:00:06.131     9,418,752       12,290
CHAPTERS:
1               0:00:00.000     0:05:40.048     19,892 kbps     47,115 kbps     00:04:48.037    36,893 kbps     00:05:06.055    34,668 kbps     00:05:00.800    103,989 bytes   674,337 bytes   00:03:01.306
2               0:05:40.048     0:06:14.665     24,058 kbps     48,910 kbps     00:11:17.885    37,261 kbps     00:11:17.635    36,148 kbps     00:06:24.634    125,425 bytes   507,371 bytes   00:07:19.021
3               0:11:54.714     0:05:05.930     24,439 kbps     43,808 kbps     00:13:10.790    35,763 kbps     00:15:38.812    34,434 kbps     00:15:33.807    127,416 bytes   529,451 bytes   00:13:12.833
4               0:17:00.644     0:06:05.698     23,034 kbps     46,254 kbps     00:22:08.702    35,949 kbps     00:22:04.698    33,210 kbps     00:22:02.446    120,089 bytes   478,840 bytes   00:18:41.203
5               0:23:06.343     0:06:04.739     22,661 kbps     42,166 kbps     00:23:18.980    36,893 kbps     00:27:56.383    32,544 kbps     00:23:16.645    118,143 bytes   666,192 bytes   00:24:22.502
6               0:29:11.082     0:05:26.159     25,620 kbps     38,321 kbps     00:31:37.103    34,700 kbps     00:31:35.435    33,219 kbps     00:34:22.060    133,573 bytes   531,790 bytes   00:31:17.417
7               0:34:37.241     0:03:47.518     29,539 kbps     42,034 kbps     00:37:52.687    37,655 kbps     00:37:52.019    36,186 kbps     00:37:50.768    154,004 bytes   457,369 bytes   00:37:53.229
8               0:38:24.760     0:09:19.392     24,495 kbps     47,816 kbps     00:39:12.016    36,273 kbps     00:39:08.012    33,433 kbps     00:39:05.968    127,706 bytes   483,727 bytes   00:43:09.545
9               0:47:44.152     0:06:47.407     26,292 kbps     45,491 kbps     00:49:44.481    35,747 kbps     00:49:40.519    33,999 kbps     00:49:35.681    137,075 bytes   555,155 bytes   00:48:12.598
10              0:54:31.559     0:04:35.900     24,667 kbps     36,302 kbps     00:56:48.029    33,720 kbps     00:56:34.474    33,648 kbps     00:56:34.474    128,600 bytes   445,920 bytes   00:56:27.092
11              0:59:07.460     0:05:58.691     27,220 kbps     47,340 kbps     00:59:08.127    36,620 kbps     01:03:12.955    35,481 kbps     01:03:07.784    141,911 bytes   490,541 bytes   01:01:41.781
12              1:05:06.152     0:07:13.391     30,851 kbps     47,198 kbps     01:10:36.023    36,568 kbps     01:06:04.710    35,309 kbps     01:06:20.726    160,842 bytes   519,224 bytes   01:10:35.731
13              1:12:19.543     0:07:27.029     24,471 kbps     45,469 kbps     01:12:38.270    37,015 kbps     01:18:39.589    34,557 kbps     01:18:36.503    127,583 bytes   469,472 bytes   01:14:47.566
14              1:19:46.573     0:06:35.269     25,212 kbps     35,656 kbps     01:19:49.284    31,946 kbps     01:24:14.507    31,480 kbps     01:24:09.836    131,442 bytes   432,956 bytes   01:21:19.249
15              1:26:21.843     0:05:27.827     26,883 kbps     44,134 kbps     01:31:05.251    36,678 kbps     01:31:14.677    32,302 kbps     01:31:39.660    140,157 bytes   508,837 bytes   01:27:18.942
16              1:31:49.670     0:06:50.660     28,655 kbps     39,471 kbps     01:34:34.710    37,491 kbps     01:34:30.706    36,263 kbps     01:36:33.871    149,395 bytes   480,323 bytes   01:31:54.675
17              1:38:40.331     0:03:39.260     29,646 kbps     43,481 kbps     01:41:53.607    37,417 kbps     01:42:03.242    35,138 kbps     01:42:02.991    154,560 bytes   510,725 bytes   01:41:54.066
18              1:42:19.591     0:08:43.814     29,615 kbps     46,860 kbps     01:51:02.364    36,212 kbps     01:48:51.441    34,752 kbps     01:48:46.144    154,399 bytes   647,142 bytes   01:50:20.155
19              1:51:03.406     0:05:32.248     22,846 kbps     44,716 kbps     01:55:33.593    37,534 kbps     01:55:54.656    33,897 kbps     01:55:24.959    120,714 bytes   529,093 bytes   01:55:23.583
20              1:56:35.655     0:05:21.988     6,361 kbps      12,877 kbps     02:01:51.595    9,173 kbps      02:00:18.920    9,028 kbps      01:58:52.750    33,254 bytes    751,488 bytes   02:01:51.637
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    7311.429                24,957                  22,809,001,390  124,067,947
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7311.429                3,237                   2,958,781,040   17,222,760
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           7311.429                768                     701,905,920     4,112,730
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            7311.429                768                     701,905,920     4,112,730
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           7311.429                192                     175,476,480     1,142,425
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7311.429                57                      52,468,711      299,459
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7311.429                42                      38,065,341      217,950
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7311.429                51                      46,290,132      263,102
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           7311.429                0                       429,776         2,447
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            7311.429                1                       529,562         3,032
00010.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           7311.429                192                     175,476,736     1,028,184
00010.M2TS      6657 (0x1A01)   0xA2            DTS Express     eng (English)           7311.429                192                     175,476,736     1,028,184
00010.M2TS      6912 (0x1B00)   0xEA            VC-1                                    7311.429                1,992                   1,820,527,364   9,999,714
00010.M2TS      6913 (0x1B01)   0xEA            VC-1                                    7311.429                194                     177,184,405     1,077,711
00083.M2TS      4113 (0x1011)   0xEA            VC-1                                    5.964                   6,523                   4,862,788       26,536
00083.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5.964                   2,718                   2,026,548       12,065
00083.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           5.964                   790                     588,800         3,450
00083.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            5.964                   790                     588,800         3,450
00083.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5.964                   198                     147,456         960
00083.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5.964                   0                       70              7
00083.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5.964                   0                       70              7
00083.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5.964                   0                       70              7
00083.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           5.964                   0                       70              7
00083.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            5.964                   0                       70              7
00083.M2TS      6656 (0x1A00)   0xA2            DTS Express     eng (English)           5.964                   198                     147,456         864
00083.M2TS      6657 (0x1A01)   0xA2            DTS Express     eng (English)           5.964                   198                     147,456         864
00083.M2TS      6912 (0x1B00)   0xEA            VC-1                                    5.964                   50                      37,357          300
00083.M2TS      6913 (0x1B01)   0xEA            VC-1                                    5.964                   50                      37,357          300
Old 07-26-2009, 06:37 PM
Stephen Dawson's Avatar
Good Luck Chuck - 2007 - Australian version
Distributed by Sony Pictures Home Entertainment Australia
Code:
        Total   Video
00000.MPLS                                                      AVC     1:41:18 32,505,452,544  46,685,200,717  42.78   32.00   Dolby TrueHD 5.1 1518Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     GOOD_LUCK_CHUCK
Disc Size:      46,685,200,717 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:41:18 (h:m:s)
Total Bitrate:          42.78 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        32000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1518 kbps       5.1 / 48 kHz / 1518 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             Czech           640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Hungarian       640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Turkish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Polish          640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         36.207 kbps
Presentation Graphics           English         36.212 kbps
Presentation Graphics           Spanish         36.981 kbps
Presentation Graphics           Portuguese      36.112 kbps
Presentation Graphics           Czech           31.392 kbps
Presentation Graphics           Hungarian       31.243 kbps
Presentation Graphics           Thai            36.130 kbps
Presentation Graphics           Turkish         35.064 kbps
Presentation Graphics           Polish          34.836 kbps
Presentation Graphics           Chinese         35.638 kbps
Presentation Graphics           Korean          27.811 kbps
Presentation Graphics           Arabic          20.347 kbps
Presentation Graphics           Bulgarian       34.509 kbps
Presentation Graphics           Croatian        31.824 kbps
Presentation Graphics           English         28.808 kbps
Presentation Graphics           English         28.812 kbps
Presentation Graphics           Hebrew          25.701 kbps
Presentation Graphics           Hindi           34.944 kbps
Presentation Graphics           Icelandic       37.147 kbps
Presentation Graphics           Romanian        34.787 kbps
Presentation Graphics           Serbian         32.527 kbps
Presentation Graphics           Slovak          32.339 kbps
Presentation Graphics           Slovenian       28.813 kbps
Presentation Graphics           English         48.663 kbps
Presentation Graphics           Korean          42.643 kbps
FILES:
00000.M2TS      0:00:00.000     1:41:18.113     32,505,452,544  42,784
CHAPTERS:
1               0:00:00.000     0:08:16.120     32,006 kbps     35,904 kbps     00:00:24.941    32,740 kbps     00:00:20.979    32,472 kbps     00:00:04.212    166,852 bytes   509,214 bytes   00:00:25.942
2               0:08:16.120     0:09:48.879     31,999 kbps     35,107 kbps     00:08:34.555    32,528 kbps     00:08:34.555    32,289 kbps     00:12:05.933    166,828 bytes   392,696 bytes   00:14:17.022
3               0:18:05.000     0:07:59.103     32,000 kbps     34,552 kbps     00:25:31.279    32,410 kbps     00:22:37.105    32,240 kbps     00:19:18.448    166,832 bytes   396,132 bytes   00:22:42.027
4               0:26:04.104     0:08:34.472     31,999 kbps     34,538 kbps     00:26:29.087    32,628 kbps     00:26:10.110    32,328 kbps     00:26:39.764    166,829 bytes   427,390 bytes   00:31:46.279
5               0:34:38.576     0:04:44.784     32,000 kbps     34,783 kbps     00:38:23.884    32,619 kbps     00:36:28.603    32,306 kbps     00:35:15.029    166,834 bytes   418,893 bytes   00:35:23.746
6               0:39:23.361     0:04:35.775     32,001 kbps     34,618 kbps     00:42:54.947    32,522 kbps     00:42:50.943    32,264 kbps     00:42:45.938    166,840 bytes   443,565 bytes   00:42:55.906
7               0:43:59.136     0:04:20.969     31,999 kbps     33,649 kbps     00:44:09.855    32,439 kbps     00:46:28.827    32,193 kbps     00:46:00.799    166,828 bytes   384,151 bytes   00:46:33.832
8               0:48:20.105     0:06:30.848     32,002 kbps     34,464 kbps     00:54:47.283    32,550 kbps     00:49:37.265    32,299 kbps     00:54:38.275    166,842 bytes   410,670 bytes   00:54:30.016
9               0:54:50.954     0:04:42.949     32,000 kbps     34,449 kbps     00:55:03.758    32,538 kbps     00:54:59.796    32,242 kbps     00:54:54.791    166,834 bytes   430,852 bytes   00:55:04.718
10              0:59:33.903     0:06:11.037     31,998 kbps     35,521 kbps     01:05:08.654    32,623 kbps     01:05:04.609    32,324 kbps     01:04:59.645    166,825 bytes   358,058 bytes   01:05:09.322
11              1:05:44.941     0:02:56.676     32,006 kbps     34,794 kbps     01:06:33.072    32,511 kbps     01:06:29.068    32,232 kbps     01:06:23.813    166,866 bytes   400,687 bytes   01:08:41.617
12              1:08:41.617     0:05:47.305     31,997 kbps     34,011 kbps     01:08:43.536    32,415 kbps     01:11:09.390    32,208 kbps     01:09:45.222    166,819 bytes   411,896 bytes   01:08:42.618
13              1:14:28.922     0:04:40.947     32,000 kbps     34,513 kbps     01:14:35.012    32,611 kbps     01:14:31.008    32,309 kbps     01:17:47.788    166,831 bytes   397,487 bytes   01:14:55.407
14              1:19:09.870     0:04:55.586     32,000 kbps     34,716 kbps     01:20:32.410    32,455 kbps     01:20:19.397    32,242 kbps     01:21:39.477    166,835 bytes   413,096 bytes   01:20:24.319
15              1:24:05.457     0:10:24.707     32,000 kbps     35,525 kbps     01:25:45.598    32,599 kbps     01:25:45.265    32,285 kbps     01:25:45.223    166,831 bytes   447,030 bytes   01:25:46.349
16              1:34:30.164     0:06:47.949     31,995 kbps     35,039 kbps     01:35:06.784    32,598 kbps     01:35:02.780    32,297 kbps     01:34:57.733    166,825 bytes   433,949 bytes   01:40:32.109
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6077.947                32,001                  24,312,455,325  132,217,445
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6077.947                2,158                   1,639,659,262   12,228,977
00000.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           6077.947                640                     486,251,520     2,849,130
00000.M2TS      4354 (0x1102)   0x81            AC3             por (Portuguese)        6077.947                640                     486,251,520     2,849,130
00000.M2TS      4355 (0x1103)   0x81            AC3             ces (Czech)             6077.947                640                     486,251,520     2,849,130
00000.M2TS      4356 (0x1104)   0x81            AC3             hun (Hungarian)         6077.947                640                     486,251,520     2,849,130
00000.M2TS      4357 (0x1105)   0x81            AC3             tha (Thai)              6077.947                640                     486,251,520     2,849,130
00000.M2TS      4358 (0x1106)   0x81            AC3             tur (Turkish)           6077.947                640                     486,251,520     2,849,130
00000.M2TS      4359 (0x1107)   0x81            AC3             pol (Polish)            6077.947                640                     486,251,520     2,849,130
00000.M2TS      4360 (0x1108)   0x81            AC3             eng (English)           6077.947                192                     145,875,456     949,710
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6077.947                36                      27,508,711      158,083
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6077.947                36                      27,512,690      158,104
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6077.947                37                      28,096,835      161,413
00000.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        6077.947                36                      27,436,657      157,856
00000.M2TS      4612 (0x1204)   0x90            PGS             ces (Czech)             6077.947                31                      23,850,589      138,345
00000.M2TS      4613 (0x1205)   0x90            PGS             hun (Hungarian)         6077.947                31                      23,737,152      137,745
00000.M2TS      4614 (0x1206)   0x90            PGS             tha (Thai)              6077.947                36                      27,450,230      157,924
00000.M2TS      4615 (0x1207)   0x90            PGS             tur (Turkish)           6077.947                35                      26,640,046      153,492
00000.M2TS      4616 (0x1208)   0x90            PGS             pol (Polish)            6077.947                35                      26,466,984      152,547
00000.M2TS      4617 (0x1209)   0x90            PGS             zho (Chinese)           6077.947                36                      27,076,723      155,900
00000.M2TS      4618 (0x120A)   0x90            PGS             kor (Korean)            6077.947                28                      21,129,598      123,579
00000.M2TS      4619 (0x120B)   0x90            PGS             ara (Arabic)            6077.947                20                      15,458,837      92,726
00000.M2TS      4620 (0x120C)   0x90            PGS             bul (Bulgarian)         6077.947                35                      26,218,960      151,244
00000.M2TS      4621 (0x120D)   0x90            PGS             hrv (Croatian)          6077.947                32                      24,178,389      140,105
00000.M2TS      4622 (0x120E)   0x90            PGS             eng (English)           6077.947                29                      21,887,217      128,923
00000.M2TS      4623 (0x120F)   0x90            PGS             eng (English)           6077.947                29                      21,890,251      128,937
00000.M2TS      4624 (0x1210)   0x90            PGS             heb (Hebrew)            6077.947                26                      19,526,802      114,867
00000.M2TS      4625 (0x1211)   0x90            PGS             hin (Hindi)             6077.947                35                      26,549,092      153,019
00000.M2TS      4626 (0x1212)   0x90            PGS             isl (Icelandic)         6077.947                37                      28,223,043      162,096
00000.M2TS      4627 (0x1213)   0x90            PGS             ron (Romanian)          6077.947                35                      26,430,070      152,393
00000.M2TS      4628 (0x1214)   0x90            PGS             srp (Serbian)           6077.947                33                      24,712,514      143,038
00000.M2TS      4629 (0x1215)   0x90            PGS             slk (Slovak)            6077.947                32                      24,570,214      142,243
00000.M2TS      4630 (0x1216)   0x90            PGS             slv (Slovenian)         6077.947                29                      21,891,320      127,679
00000.M2TS      4631 (0x1217)   0x90            PGS             eng (English)           6077.947                49                      36,972,247      210,516
00000.M2TS      4632 (0x1218)   0x90            PGS             kor (Korean)            6077.947                43                      32,398,275      188,089
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
Old 07-27-2009, 12:33 AM
The Jane Austen Book Club - 2007 - Australian Version
Code:
        Total   Video
00011.MPLS                                                      AVC     1:45:37 26,738,380,800  30,580,515,521  33.75   26.06   Dolby TrueHD 5.1 1359Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     JANE_AUSTEN_BOOK_CLUB
Disc Size:      30,580,515,521 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:45:37 (h:m:s)
Total Bitrate:          33.75 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        26059 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1359 kbps       5.1 / 48 kHz / 1359 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              Italian         1485 kbps       5.1 / 48 kHz / 1485 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         49.757 kbps
Presentation Graphics           English         44.807 kbps
Presentation Graphics           Italian         48.840 kbps
Presentation Graphics           Danish          46.477 kbps
Presentation Graphics           Finnish         48.001 kbps
Presentation Graphics           Norwegian       36.592 kbps
Presentation Graphics           Swedish         43.493 kbps
Presentation Graphics           English         91.074 kbps
Presentation Graphics           Italian         75.856 kbps
FILES:
00011.M2TS      0:00:00.000     1:45:37.331     26,738,380,800  33,753
CHAPTERS:
1               0:00:00.000     0:08:11.741     25,792 kbps     45,074 kbps     00:00:47.714    36,019 kbps     00:00:47.714    33,773 kbps     00:00:40.415    134,455 bytes   624,487 bytes   00:00:02.502
2               0:08:11.741     0:08:11.491     26,217 kbps     40,851 kbps     00:14:04.844    31,371 kbps     00:14:57.104    30,143 kbps     00:08:33.888    136,686 bytes   458,905 bytes   00:09:37.201
3               0:16:23.232     0:03:52.023     25,696 kbps     33,394 kbps     00:16:25.150    29,288 kbps     00:16:23.565    27,717 kbps     00:16:25.192    133,966 bytes   468,370 bytes   00:20:12.252
4               0:20:15.255     0:09:57.471     26,113 kbps     36,005 kbps     00:24:44.399    30,247 kbps     00:20:31.063    28,852 kbps     00:20:30.729    136,139 bytes   590,170 bytes   00:29:23.178
5               0:30:12.727     0:07:15.226     25,952 kbps     39,990 kbps     00:35:58.364    34,254 kbps     00:33:01.062    31,529 kbps     00:32:58.768    135,300 bytes   620,160 bytes   00:33:35.388
6               0:37:27.954     0:04:31.604     25,865 kbps     37,429 kbps     00:39:36.916    28,184 kbps     00:38:26.846    27,616 kbps     00:39:35.456    134,849 bytes   466,265 bytes   00:39:22.234
7               0:41:59.558     0:08:29.842     25,924 kbps     36,485 kbps     00:42:17.117    29,308 kbps     00:42:16.951    27,911 kbps     00:44:36.715    135,156 bytes   601,307 bytes   00:42:51.652
8               0:50:29.401     0:03:58.488     24,980 kbps     34,409 kbps     00:51:50.190    30,510 kbps     00:54:15.710    28,664 kbps     00:54:15.710    130,236 bytes   572,020 bytes   00:52:33.191
9               0:54:27.889     0:03:54.609     27,904 kbps     34,675 kbps     00:55:04.134    31,344 kbps     00:56:10.825    30,708 kbps     00:55:22.027    145,477 bytes   600,042 bytes   00:58:00.602
10              0:58:22.499     0:09:42.915     26,011 kbps     42,044 kbps     01:02:15.940    34,498 kbps     01:02:15.940    33,106 kbps     01:02:15.940    135,611 bytes   567,642 bytes   01:03:17.376
11              1:08:05.414     0:07:00.128     25,525 kbps     37,032 kbps     01:13:06.590    31,701 kbps     01:13:04.588    29,955 kbps     01:13:04.588    133,075 bytes   617,023 bytes   01:11:05.844
12              1:15:05.542     0:06:12.080     26,231 kbps     38,322 kbps     01:18:01.093    30,414 kbps     01:15:29.191    29,496 kbps     01:15:24.102    136,757 bytes   514,611 bytes   01:18:01.301
13              1:21:17.622     0:07:01.462     26,301 kbps     36,856 kbps     01:22:57.472    31,047 kbps     01:26:56.753    30,034 kbps     01:26:51.206    137,122 bytes   491,016 bytes   01:26:23.761
14              1:28:19.085     0:06:39.148     25,634 kbps     41,678 kbps     01:29:27.362    33,416 kbps     01:29:27.362    32,086 kbps     01:29:27.362    133,643 bytes   595,164 bytes   01:32:26.832
15              1:34:58.234     0:06:00.109     28,203 kbps     39,048 kbps     01:40:49.001    32,901 kbps     01:36:26.155    32,386 kbps     01:39:58.033    147,036 bytes   705,323 bytes   01:36:26.363
16              1:40:58.343     0:04:38.987     24,567 kbps     49,757 kbps     01:43:07.598    33,411 kbps     01:41:55.901    32,839 kbps     01:41:50.896    128,119 bytes   781,817 bytes   01:43:53.227
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6337.248                26,060                  20,643,236,217  112,280,959
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6337.248                1,999                   1,583,521,284   11,275,041
00011.M2TS      4353 (0x1101)   0x83            TrueHD          ita (Italian)           6337.248                2,125                   1,683,168,300   12,319,135
00011.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6337.248                192                     152,096,256     990,210
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6337.248                50                      39,415,737      223,820
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6337.248                45                      35,494,709      205,501
00011.M2TS      4610 (0x1202)   0x90            PGS             ita (Italian)           6337.248                49                      38,689,383      220,111
00011.M2TS      4611 (0x1203)   0x90            PGS             dan (Danish)            6337.248                46                      36,817,762      209,889
00011.M2TS      4612 (0x1204)   0x90            PGS             fin (Finnish)           6337.248                48                      38,024,990      216,557
00011.M2TS      4613 (0x1205)   0x90            PGS             nor (Norwegian)         6337.248                37                      28,987,184      167,031
00011.M2TS      4614 (0x1206)   0x90            PGS             swe (Swedish)           6337.248                43                      34,453,344      197,004
00011.M2TS      4615 (0x1207)   0x90            PGS             eng (English)           6337.248                91                      72,146,054      405,109
00011.M2TS      4616 (0x1208)   0x90            PGS             ita (Italian)           6337.248                76                      60,090,919      339,705
Stephen Dawson
hifi-writer.com
Old 07-27-2009, 05:00 AM
msgohan's Avatar
Memento - Sony - Spain - 26 May 2009
Region B locked (confirmed with PowerDVD set to all 3 regions)
Screenshots
Here's a weird one. They made a new AVC encode instead of the US MPEG-2, but limited the English audio to LPCM 2.0 for some reason. The Spanish sites list it with its announced features of being a region free BD25 with TrueHD 5.1 for both tracks. Maybe we'll get the nice AVC encode with a real audio track in a future UK or Aussie release.
Extras are two terrible quality trailers and the "Anatomy of a Scene" special, all in 16:9 SD PAL, in English with removable Spanish subs. Also included is a "Gallery" that's actually just a 1 min 25 sec HD slideshow of some screencaps set to music.
The "chronological cut" is available from the Extras menu as well, accomplished by a BD-J program that skips around to the appropriate scenes and keeps track of each scene's chronological number with a subtitle in the top-right letterbox bar. There's a warning screen explaining that it's "just for fun" and not a perfect rendition, and unfortunately the audio seems to dropout for a second at each jump. More importantly, it's not actually in chronological order...
The chronological version on the R2 DVD uses a separate encode on another disc in order to reverse the motion of the opening and end credits, which obviously isn't possible using this BD-J solution. But even ignoring that, the order used here is completely different and has no narrative structure. Instead of playing through all of the B&W scenes and transitioning to color with the developing photograph after Jimmy's murder, this starts with one B&W scene, then goes to Jimmy's murder and the final scene of the regular movie, then jumps to the chronologically first B&W scene, and just keeps going back and forth between color and monochrome. I only watched the first ten minutes and some spot checks of this version, but it seems totally disjointed.
Code:
        Total   Video
(ES) Memento (1080p24)                                          AVC     1:53:21 25,342,961,664  28,506,152,048  29.81   24.97   LPCM 2.0 1536Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     MEMENTO
Disc Size:      28,506,152,048 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:53:21 (h:m:s)
Total Bitrate:          29.81 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        24966 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
DTS Audio                       Spanish         1509 kbps       5.1 / 48 kHz / 1509 kbps / 16-bit
LPCM Audio                      English         1536 kbps       2.0 / 48 kHz / 1536 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         54.952 kbps
Presentation Graphics           Spanish         51.084 kbps
Presentation Graphics           Spanish         0.321 kbps
FILES:
00000.M2TS      0:00:00.000     1:53:21.041     25,342,961,664  29,811
CHAPTERS:
1               0:00:00.000     0:10:12.583     22,438 kbps     40,296 kbps     00:06:33.458    35,599 kbps     00:06:48.458    33,682 kbps     00:06:46.041    116,857 bytes   331,229 bytes   00:02:20.958
2               0:10:12.583     0:12:04.125     24,310 kbps     40,284 kbps     00:13:10.375    31,841 kbps     00:11:25.958    30,845 kbps     00:11:23.541    126,613 bytes   313,257 bytes   00:13:10.833
3               0:22:16.708     0:10:30.250     24,519 kbps     41,557 kbps     00:30:01.833    35,099 kbps     00:32:22.916    32,488 kbps     00:32:18.208    127,702 bytes   332,325 bytes   00:31:29.291
4               0:32:46.958     0:12:13.708     25,682 kbps     43,160 kbps     00:35:17.750    36,939 kbps     00:41:06.166    33,502 kbps     00:41:04.333    133,759 bytes   339,245 bytes   00:38:39.750
5               0:45:00.666     0:08:56.541     27,849 kbps     41,202 kbps     00:47:35.208    37,845 kbps     00:47:01.083    36,802 kbps     00:47:00.916    145,048 bytes   337,046 bytes   00:53:48.541
6               0:53:57.208     0:10:56.666     26,594 kbps     41,474 kbps     00:56:50.791    35,745 kbps     00:55:56.208    33,601 kbps     00:56:46.125    138,513 bytes   369,639 bytes   00:58:40.291
7               1:04:53.875     0:12:20.125     23,530 kbps     40,575 kbps     01:05:03.666    36,283 kbps     01:16:35.791    34,395 kbps     01:16:35.375    122,551 bytes   314,948 bytes   01:13:37.083
8               1:17:14.000     0:09:14.375     25,336 kbps     41,822 kbps     01:17:24.250    35,451 kbps     01:19:21.291    32,780 kbps     01:19:16.291    131,957 bytes   339,701 bytes   01:19:08.458
9               1:26:28.375     0:06:51.625     27,080 kbps     39,484 kbps     01:32:32.666    33,869 kbps     01:33:01.083    32,987 kbps     01:28:07.500    141,040 bytes   309,927 bytes   01:30:23.750
10              1:33:20.000     0:04:01.833     30,590 kbps     41,655 kbps     01:34:15.666    35,411 kbps     01:34:13.750    34,603 kbps     01:34:12.750    159,322 bytes   366,998 bytes   01:37:21.208
11              1:37:21.833     0:11:58.708     26,657 kbps     42,673 kbps     01:41:35.791    35,502 kbps     01:41:34.875    34,295 kbps     01:38:49.166    138,837 bytes   399,572 bytes   01:37:22.208
12              1:49:20.541     0:04:00.500     10,726 kbps     40,273 kbps     01:50:06.541    34,853 kbps     01:50:02.541    33,569 kbps     01:49:57.916    55,873 bytes    271,173 bytes   01:49:47.958
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6800.875                24,966                  21,224,143,177  115,443,869
00000.M2TS      4352 (0x1100)   0x82            DTS             spa (Spanish)           6800.875                1,509                   1,282,851,200   7,651,200
00000.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           6800.875                1,542                   1,311,241,476   8,161,254
00000.M2TS      4608 (0x1200)   0x90            PGS             spa (Spanish)           6800.875                51                      43,427,904      245,468
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6800.875                55                      46,715,998      263,383
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6800.875                0                       273,032         1,556
Oh, and DK Pulp Fiction is Region ABC by the way.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
Old 07-27-2009, 08:47 AM
How To Lose Friends & Alienate People - 2008 - Australian version
Judging by the disc title (HTLFAP_UK) this is also likely the British version as well.
Distributed by Paramount Home Entertainment (Australasia) Pty Ltd
Region A/B/C, confirmed with AnyDVD HD
Edit: I should add that there a few extras (deleted scenes, a gag reel, so-called 'Blog' items) and all these are in 576i50, MPEG2 format, so may not work on some US players.
Code:
        Total   Video
00070.MPLS                                                      AVC     1:49:45 37,467,598,848  40,701,165,507  45.52   37.28   Dolby TrueHD 5.1 3553Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     HTLFAP_UK
Disc Size:      40,701,165,507 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:49:45 (h:m:s)
Total Bitrate:          45.52 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        37276 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3553 kbps       5.1 / 48 kHz / 3553 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         41.648 kbps
Presentation Graphics           English         45.060 kbps
Presentation Graphics           English         80.570 kbps
Presentation Graphics           English         69.458 kbps
FILES:
00010.M2TS      0:00:00.000     1:49:45.287     37,467,598,848  45,517
CHAPTERS:
1               0:00:00.000     0:07:09.554     35,971 kbps     51,666 kbps     00:02:27.856    40,875 kbps     00:02:23.852    39,796 kbps     00:02:18.763    187,517 bytes   633,052 bytes   00:02:28.565
2               0:07:09.554     0:09:35.116     38,142 kbps     42,548 kbps     00:11:48.833    39,385 kbps     00:11:44.829    39,176 kbps     00:16:22.064    198,853 bytes   374,837 bytes   00:09:26.148
3               0:16:44.670     0:09:59.473     37,972 kbps     42,635 kbps     00:17:29.506    39,676 kbps     00:17:25.502    39,247 kbps     00:16:55.139    197,968 bytes   362,991 bytes   00:17:06.442
4               0:26:44.144     0:09:46.252     37,500 kbps     41,183 kbps     00:27:15.383    39,320 kbps     00:33:38.933    39,169 kbps     00:34:19.891    195,505 bytes   385,549 bytes   00:27:32.400
5               0:36:30.396     0:08:44.023     38,200 kbps     40,433 kbps     00:39:00.004    39,342 kbps     00:37:49.725    39,198 kbps     00:39:38.542    199,159 bytes   347,150 bytes   00:37:55.523
6               0:45:14.420     0:09:27.066     37,998 kbps     42,205 kbps     00:47:49.032    39,740 kbps     00:47:45.112    39,273 kbps     00:47:13.956    198,103 bytes   408,658 bytes   00:49:55.784
7               0:54:41.486     0:05:58.733     37,803 kbps     41,887 kbps     00:59:48.334    39,378 kbps     00:54:45.073    39,255 kbps     00:57:56.639    197,090 bytes   411,208 bytes   01:00:40.219
8               1:00:40.219     0:05:14.147     38,103 kbps     45,615 kbps     01:02:16.524    40,251 kbps     01:02:12.520    39,556 kbps     01:02:07.515    198,652 bytes   450,732 bytes   01:04:11.472
9               1:05:54.367     0:05:10.643     37,915 kbps     41,609 kbps     01:08:12.546    39,584 kbps     01:08:08.542    39,319 kbps     01:08:03.537    197,669 bytes   348,430 bytes   01:08:10.878
10              1:11:05.010     0:08:51.364     37,866 kbps     41,782 kbps     01:19:37.856    39,791 kbps     01:19:33.810    39,217 kbps     01:18:46.179    197,417 bytes   422,415 bytes   01:16:21.660
11              1:19:56.374     0:04:54.043     37,646 kbps     40,810 kbps     01:23:22.497    39,341 kbps     01:22:33.698    39,184 kbps     01:22:28.902    196,271 bytes   362,643 bytes   01:24:50.418
12              1:24:50.418     0:07:53.014     38,241 kbps     46,804 kbps     01:32:29.919    40,121 kbps     01:32:25.915    39,262 kbps     01:25:38.049    199,372 bytes   414,313 bytes   01:31:09.714
13              1:32:43.432     0:02:44.330     38,358 kbps     40,777 kbps     01:33:31.188    39,437 kbps     01:33:27.101    39,174 kbps     01:34:01.927    199,980 bytes   360,752 bytes   01:35:27.763
14              1:35:27.763     0:09:15.096     37,699 kbps     46,554 kbps     01:44:36.478    40,645 kbps     01:44:32.474    39,822 kbps     01:44:27.469    196,544 bytes   818,541 bytes   01:44:37.813
15              1:44:42.859     0:05:02.427     26,302 kbps     46,620 kbps     01:47:04.292    40,164 kbps     01:47:00.288    39,581 kbps     01:46:55.283    137,147 bytes   690,432 bytes   01:48:42.098
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0x1B            AVC                                     6585.204                37,276                  30,684,061,730  166,853,600
00010.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6585.204                4,193                   3,451,733,698   23,874,295
00010.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6585.204                224                     184,388,736     1,028,955
00010.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           6585.204                224                     184,388,736     1,028,955
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6585.204                224                     184,388,736     1,028,955
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6585.204                42                      34,282,974      195,767
00010.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6585.204                45                      37,091,279      212,070
00010.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6585.204                81                      66,322,291      376,688
00010.M2TS      4611 (0x1203)   0x90            PGS             eng (English)           6585.204                69                      57,175,182      323,823
Stephen Dawson
hifi-writer.com
Old 07-27-2009, 09:17 PM
Patsfan123's Avatar
Quoted: 107 Post(s)
Liked: 65
Code:
        Total   Video
Striking Distance                                               AVC     1:41:44 30,286,669,824  33,040,254,828  39.69   26.89   Dolby TrueHD 5.1 2491Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     STRIKING_DISTANCE
Disc Size:      33,040,254,828 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:41:44 (h:m:s)
Total Bitrate:          39.69 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        26895 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         2491 kbps       5.1 / 48 kHz / 2491 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              French          1580 kbps       5.1 / 48 kHz / 1580 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
Dolby TrueHD Audio              Portuguese      1656 kbps       5.1 / 48 kHz / 1656 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
SUBTITLES:
Presentation Graphics           English         28.043 kbps
Presentation Graphics           English         21.862 kbps
Presentation Graphics           French          19.336 kbps
Presentation Graphics           Portuguese      20.915 kbps
Presentation Graphics           Spanish         25.944 kbps
FILES:
00011.M2TS      0:00:00.000     1:41:44.098     30,286,669,824  39,694
CHAPTERS:
1               0:00:00.000     0:05:59.942     26,291 kbps     45,304 kbps     00:00:41.291    32,351 kbps     00:00:38.288    30,935 kbps     00:00:37.620    137,054 bytes   602,491 bytes   00:00:41.916
2               0:05:59.942     0:06:58.584     27,296 kbps     44,200 kbps     00:12:04.223    32,267 kbps     00:11:03.162    31,132 kbps     00:11:03.037    142,310 bytes   551,895 bytes   00:11:26.394
3               0:12:58.527     0:05:50.516     27,073 kbps     33,548 kbps     00:14:19.483    30,039 kbps     00:14:06.178    29,554 kbps     00:13:19.006    141,147 bytes   409,299 bytes   00:13:00.988
4               0:18:49.044     0:06:16.793     27,384 kbps     38,535 kbps     00:21:20.696    32,384 kbps     00:22:23.550    31,182 kbps     00:19:44.892    142,769 bytes   510,454 bytes   00:19:27.457
5               0:25:05.837     0:06:00.943     26,893 kbps     34,085 kbps     00:29:54.834    29,700 kbps     00:29:08.913    28,814 kbps     00:29:33.146    140,207 bytes   460,689 bytes   00:30:00.632
6               0:31:06.781     0:06:42.276     26,808 kbps     35,709 kbps     00:36:23.347    32,013 kbps     00:31:21.921    30,154 kbps     00:31:15.957    139,765 bytes   451,613 bytes   00:32:29.405
7               0:37:49.058     0:05:55.354     27,157 kbps     35,838 kbps     00:38:02.363    31,250 kbps     00:37:58.484    30,642 kbps     00:37:53.479    141,585 bytes   404,733 bytes   00:40:06.153
8               0:43:44.413     0:02:31.025     26,090 kbps     31,897 kbps     00:43:58.344    28,630 kbps     00:45:29.351    28,067 kbps     00:45:24.221    136,023 bytes   385,427 bytes   00:44:17.696
9               0:46:15.439     0:07:33.286     26,961 kbps     32,929 kbps     00:47:06.615    30,472 kbps     00:47:03.487    29,567 kbps     00:47:25.050    140,563 bytes   472,447 bytes   00:53:46.056
10              0:53:48.725     0:06:34.393     27,750 kbps     36,330 kbps     00:54:59.671    32,540 kbps     00:55:00.547    31,537 kbps     00:54:26.930    144,673 bytes   413,685 bytes   00:56:44.943
11              1:00:23.119     0:07:46.215     26,840 kbps     39,726 kbps     01:05:49.820    33,364 kbps     01:05:48.319    31,662 kbps     01:05:45.316    139,933 bytes   470,685 bytes   01:06:52.008
12              1:08:09.335     0:04:37.610     26,889 kbps     37,952 kbps     01:11:14.103    31,718 kbps     01:10:17.129    30,533 kbps     01:11:14.103    140,185 bytes   470,303 bytes   01:11:21.110
13              1:12:46.945     0:08:08.446     26,556 kbps     40,854 kbps     01:18:32.624    30,857 kbps     01:16:20.617    29,611 kbps     01:12:49.281    138,449 bytes   447,389 bytes   01:16:20.701
14              1:20:55.392     0:10:22.246     26,745 kbps     44,554 kbps     01:22:06.338    31,744 kbps     01:22:06.212    29,521 kbps     01:22:31.571    139,435 bytes   519,542 bytes   01:22:06.421
15              1:31:17.638     0:02:34.445     28,019 kbps     38,473 kbps     01:32:59.198    32,442 kbps     01:31:22.185    31,402 kbps     01:31:17.638    146,076 bytes   378,646 bytes   01:32:22.620
16              1:33:52.084     0:07:52.013     26,074 kbps     39,988 kbps     01:35:21.757    32,029 kbps     01:35:44.488    30,993 kbps     01:35:48.284    135,961 bytes   676,324 bytes   01:38:19.894
STREAM DIAGNOSTICS:
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     6104.015                26,895                  20,521,182,886  111,614,047
00011.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6104.015                3,131                   2,388,907,734   17,848,496
00011.M2TS      4353 (0x1101)   0x83            TrueHD          fra (French)            6104.015                2,028                   1,547,608,120   11,986,375
00011.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6104.015                640                     488,330,240     2,861,310
00011.M2TS      4355 (0x1103)   0x83            TrueHD          por (Portuguese)        6104.015                2,104                   1,605,172,218   12,716,787
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6104.015                28                      21,397,521      122,736
00011.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6104.015                22                      16,681,183      97,690
00011.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6104.015                19                      14,753,777      84,295
00011.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6104.015                26                      19,795,721      113,770
00011.M2TS      4612 (0x1204)   0x90            PGS             por (Portuguese)        6104.015                21                      15,958,368      93,048
Code:
a03 Extracting audio track number 3...
a03 Extracting TrueHD stream...
a03 Decoding with libav/ffmpeg...
a03 The original audio track has a constant bit depth of 20 bits.
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is offline
Old 07-28-2009, 12:34 AM
Rio Bravo - 1959 - Australian version
... but seems to the same as the US version
Distributed by Warner Bros Entertainment Australia Pty Ltd
Region A/B/C confirmed with AnyDVD HD.
Code:
        Total   Video
00000.MPLS                                                      VC-1    2:21:03 22,718,208,000  27,224,120,216  21.47   19.62   DD AC3 1.0 192Kbps
Code:
DISC INFO:
Disc Title:     RIO_BRAVO
Disc Size:      27,224,120,216 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:21:03 (h:m:s)
Total Bitrate:          21.47 Mbps
Description:
VIDEO:
VC-1 Video              19617 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps
Dolby Digital Audio             French          192 kbps        1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         40.681 kbps
Presentation Graphics           English         42.598 kbps
Presentation Graphics           French          48.346 kbps
Presentation Graphics           Spanish         59.978 kbps
FILES:
00000.M2TS      0:00:00.000     2:21:03.496     22,718,140,416  21,474
00017.M2TS      2:21:03.496     0:00:00.500     67,584          1,080
CHAPTERS:
1               0:00:00.000     0:01:25.084     25,224 kbps     34,220 kbps     00:00:33.783    28,572 kbps     00:00:57.640    27,629 kbps     00:00:53.053    132,155 bytes   407,338 bytes   00:01:17.035
2               0:01:25.084     0:02:34.654     16,791 kbps     26,966 kbps     00:03:46.226    21,700 kbps     00:03:14.861    19,038 kbps     00:03:10.231    87,539 bytes    345,297 bytes   00:02:41.578
3               0:03:59.739     0:01:23.249     17,001 kbps     25,028 kbps     00:04:54.919    20,274 kbps     00:04:06.996    19,242 kbps     00:04:01.991    88,813 bytes    348,284 bytes   00:04:48.162
4               0:05:22.989     0:04:30.144     23,097 kbps     35,169 kbps     00:08:26.923    28,199 kbps     00:07:13.433    27,364 kbps     00:07:00.002    120,415 bytes   497,771 bytes   00:08:17.788
5               0:09:53.134     0:02:12.799     21,944 kbps     35,154 kbps     00:11:43.327    26,713 kbps     00:10:09.567    25,326 kbps     00:10:03.728    114,405 bytes   519,533 bytes   00:11:53.087
6               0:12:05.933     0:02:35.738     16,973 kbps     30,888 kbps     00:14:15.980    22,245 kbps     00:14:30.744    20,548 kbps     00:14:31.662    88,487 bytes    400,238 bytes   00:12:27.747
7               0:14:41.672     0:03:18.406     18,916 kbps     32,015 kbps     00:15:10.868    27,130 kbps     00:14:59.607    25,647 kbps     00:15:02.192    98,621 bytes    370,653 bytes   00:14:50.431
8               0:18:00.079     0:05:19.318     19,675 kbps     40,042 kbps     00:20:43.325    28,368 kbps     00:20:58.256    26,206 kbps     00:18:07.753    102,576 bytes   466,073 bytes   00:20:43.367
9               0:23:19.398     0:03:35.924     20,478 kbps     35,390 kbps     00:23:34.079    28,980 kbps     00:25:48.964    25,755 kbps     00:25:48.421    106,763 bytes   445,858 bytes   00:23:34.121
10              0:26:55.322     0:01:47.023     20,079 kbps     32,208 kbps     00:28:12.065    27,539 kbps     00:28:10.105    22,996 kbps     00:28:05.100    104,685 bytes   561,585 bytes   00:28:12.315
11              0:28:42.345     0:03:54.609     21,144 kbps     34,724 kbps     00:29:39.986    28,257 kbps     00:30:29.577    25,180 kbps     00:30:29.536    110,234 bytes   482,908 bytes   00:31:17.792
12              0:32:36.955     0:02:20.932     20,530 kbps     31,295 kbps     00:33:25.294    28,781 kbps     00:33:24.919    26,745 kbps     00:33:24.919    107,036 bytes   486,471 bytes   00:32:55.181
13              0:34:57.887     0:01:34.803     18,001 kbps     31,618 kbps     00:36:24.724    23,132 kbps     00:36:24.098    20,461 kbps     00:35:29.460    93,847 bytes    523,607 bytes   00:35:24.872
14              0:36:32.690     0:03:03.808     16,693 kbps     37,245 kbps     00:37:39.757    27,721 kbps     00:39:09.346    24,693 kbps     00:39:09.347    87,028 bytes    451,368 bytes   00:37:39.966
15              0:39:36.499     0:05:54.354     17,694 kbps     34,287 kbps     00:41:57.598    27,076 kbps     00:42:57.157    24,447 kbps     00:41:52.635    92,250 bytes    481,794 bytes   00:41:36.327
16              0:45:30.853     0:03:03.057     18,893 kbps     38,124 kbps     00:46:54.770    28,737 kbps     00:45:40.112    26,090 kbps     00:46:37.461    98,502 bytes    487,857 bytes   00:46:55.062
17              0:48:33.911     0:04:20.051     18,567 kbps     34,065 kbps     00:51:23.246    27,866 kbps     00:51:51.358    26,636 kbps     00:51:22.746    96,802 bytes    407,725 bytes   00:51:54.903
18              0:52:53.962     0:03:32.503     17,601 kbps     29,215 kbps     00:56:24.672    23,545 kbps     00:54:45.907    21,325 kbps     00:56:07.322    91,765 bytes    377,879 bytes   00:55:33.913
19              0:56:26.466     0:04:01.449     21,700 kbps     34,681 kbps     00:58:49.609    27,929 kbps     00:56:58.498    25,800 kbps     00:57:18.476    113,132 bytes   594,107 bytes   00:59:01.496
20              1:00:27.915     0:04:40.613     17,795 kbps     27,511 kbps     01:01:32.230    25,642 kbps     01:03:12.663    22,063 kbps     01:03:07.992    92,775 bytes    477,887 bytes   01:01:32.271
21              1:05:08.529     0:04:02.867     19,111 kbps     28,910 kbps     01:07:35.176    26,627 kbps     01:06:59.473    23,944 kbps     01:06:57.430    99,635 bytes    418,895 bytes   01:06:47.503
22              1:09:11.397     0:03:16.487     17,004 kbps     27,690 kbps     01:11:07.596    22,435 kbps     01:10:46.659    20,276 kbps     01:10:43.155    88,652 bytes    407,496 bytes   01:11:21.151
23              1:12:27.885     0:04:42.699     19,827 kbps     32,467 kbps     01:14:46.023    29,429 kbps     01:16:09.648    25,514 kbps     01:16:08.480    103,368 bytes   434,833 bytes   01:12:42.399
24              1:17:10.584     0:05:50.224     18,057 kbps     30,745 kbps     01:17:26.850    23,954 kbps     01:18:34.751    22,086 kbps     01:18:59.860    94,143 bytes    375,062 bytes   01:20:14.559
25              1:23:00.809     0:02:30.775     15,042 kbps     23,839 kbps     01:24:38.907    19,869 kbps     01:23:19.494    17,609 kbps     01:23:03.770    78,424 bytes    347,181 bytes   01:24:39.032
26              1:25:31.584     0:03:45.600     19,040 kbps     34,264 kbps     01:27:05.929    27,691 kbps     01:26:06.327    26,374 kbps     01:26:07.745    99,265 bytes    663,450 bytes   01:26:56.294
27              1:29:17.185     0:03:25.455     21,202 kbps     32,926 kbps     01:32:31.712    28,253 kbps     01:32:15.821    26,058 kbps     01:32:15.321    110,539 bytes   500,806 bytes   01:29:27.904
28              1:32:42.640     0:02:52.797     20,458 kbps     35,429 kbps     01:34:50.017    27,535 kbps     01:34:27.536    26,257 kbps     01:34:49.975    106,659 bytes   494,044 bytes   01:35:06.075
29              1:35:35.438     0:03:16.654     19,531 kbps     32,475 kbps     01:35:42.862    25,486 kbps     01:38:27.192    23,687 kbps     01:35:47.783    101,825 bytes   440,237 bytes   01:35:54.248
30              1:38:52.092     0:02:11.422     16,931 kbps     25,898 kbps     01:39:51.568    21,871 kbps     01:40:48.292    21,234 kbps     01:40:46.874    88,268 bytes    370,564 bytes   01:39:12.655
31              1:41:03.515     0:03:47.268     16,939 kbps     27,152 kbps     01:41:43.055    21,610 kbps     01:42:11.834    20,082 kbps     01:41:06.518    88,314 bytes    396,742 bytes   01:44:49.032
32              1:44:50.784     0:02:14.092     19,371 kbps     31,364 kbps     01:46:36.473    23,651 kbps     01:46:34.596    22,264 kbps     01:46:29.549    100,990 bytes   551,090 bytes   01:46:36.598
33              1:47:04.876     0:02:35.154     19,843 kbps     27,861 kbps     01:48:24.289    24,140 kbps     01:48:38.720    23,542 kbps     01:48:33.715    103,454 bytes   386,150 bytes   01:48:24.414
34              1:49:40.031     0:03:53.733     21,275 kbps     31,195 kbps     01:53:06.070    25,951 kbps     01:50:01.636    24,947 kbps     01:51:05.367    110,920 bytes   462,081 bytes   01:53:16.790
35              1:53:33.765     0:03:52.190     20,453 kbps     36,683 kbps     01:54:14.556    28,932 kbps     01:55:16.451    25,385 kbps     01:54:31.489    106,631 bytes   537,137 bytes   01:53:54.744
36              1:57:25.955     0:04:23.304     20,720 kbps     37,377 kbps     02:01:47.633    24,967 kbps     01:58:48.704    23,624 kbps     01:57:30.668    108,024 bytes   577,076 bytes   02:00:52.787
37              2:01:49.260     0:03:01.014     21,364 kbps     35,288 kbps     02:04:33.674    28,738 kbps     02:04:33.841    27,948 kbps     02:03:50.756    111,384 bytes   579,803 bytes   02:02:56.535
38              2:04:50.274     0:04:17.090     23,510 kbps     36,957 kbps     02:07:54.541    29,266 kbps     02:08:46.093    27,913 kbps     02:07:18.088    122,570 bytes   604,177 bytes   02:07:01.238
39              2:09:07.364     0:03:45.016     23,896 kbps     37,252 kbps     02:12:48.168    29,156 kbps     02:10:12.596    28,030 kbps     02:09:18.959    124,580 bytes   550,036 bytes   02:12:09.338
40              2:12:52.381     0:03:32.086     19,499 kbps     33,230 kbps     02:16:19.045    26,522 kbps     02:13:06.853    22,449 kbps     02:13:06.353    101,659 bytes   537,442 bytes   02:12:59.388
41              2:16:24.467     0:04:39.529     20,603 kbps     34,182 kbps     02:17:34.829    27,363 kbps     02:18:06.653    26,098 kbps     02:18:09.030    107,770 bytes   450,382 bytes   02:17:06.218
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    8463.372                19,619                  20,754,889,973  112,920,614
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           8463.372                192                     203,124,480     1,322,425
00000.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            8463.372                192                     203,124,480     1,322,425
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           8463.372                192                     203,124,480     1,322,425
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           8463.372                41                      43,040,765      246,709
00000.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           8463.372                43                      45,068,673      258,543
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            8463.372                48                      51,149,910      289,166
00000.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           8463.372                60                      63,456,277      357,798
00017.M2TS      4113 (0x1011)   0xEA            VC-1                                    0.375                   210                     9,871           62
00017.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           0.375                   262                     12,288          80
00017.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            0.375                   262                     12,288          80
00017.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           0.375                   262                     12,288          80
00017.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           0.375                   0                       0               0
00017.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           0.375                   0                       0               0
00017.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            0.375                   0                       0               0
00017.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           0.375                   0                       0               0
Stephen Dawson
hifi-writer.com
Old 07-28-2009, 01:25 AM
RV - 2006 - Australian version
Locked to Region B, confirmed with AnyDVD HD.
Code:
        Total   Video
00001.MPLS                                                      MPEG-2  1:38:47 22,025,410,560  23,311,405,676  29.72   17.22   DD AC3 5.1 448Kbps                        LPCM 5.1 4608Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID
Disc Size:      23,311,405,676 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:38:47 (h:m:s)
Total Bitrate:          29.72 Mbps
Description:
VIDEO:
MPEG-2 Video            17218 kbps          1080p / 23.976 fps / 16:9
AUDIO:
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
LPCM Audio                      English         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
LPCM Audio                      French          4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
SUBTITLES:
Presentation Graphics           English         60.404 kbps
Presentation Graphics           English         45.566 kbps
Presentation Graphics           French          57.017 kbps
Presentation Graphics           Dutch           47.523 kbps
Presentation Graphics           Arabic          30.527 kbps
Presentation Graphics           Czech           51.982 kbps
Presentation Graphics           Danish          46.623 kbps
Presentation Graphics           Finnish         55.085 kbps
Presentation Graphics           Greek, Ancient (to 1453)59.046 kbps
Presentation Graphics           Hebrew          41.070 kbps
Presentation Graphics           Hindi           50.482 kbps
Presentation Graphics           Hungarian       49.515 kbps
Presentation Graphics           Norwegian       55.611 kbps
Presentation Graphics           Polish          57.459 kbps
Presentation Graphics           Swedish         45.110 kbps
Presentation Graphics           Turkish         57.271 kbps
FILES:
00002.M2TS      0:00:00.000     1:38:47.922     22,025,410,560  29,724
CHAPTERS:
1               0:00:00.000     0:05:44.761     16,237 kbps     29,114 kbps     00:03:28.833    26,271 kbps     00:03:24.954    23,342 kbps     00:03:24.287    84,640 bytes    581,886 bytes   00:04:59.090
2               0:05:44.761     0:09:01.874     17,394 kbps     25,405 kbps     00:09:11.926    22,705 kbps     00:11:50.584    21,989 kbps     00:14:33.247    90,684 bytes    555,906 bytes   00:07:49.260
3               0:14:46.635     0:03:57.028     19,024 kbps     30,645 kbps     00:15:20.085    25,502 kbps     00:16:15.182    24,834 kbps     00:16:11.470    99,183 bytes    538,019 bytes   00:14:49.680
4               0:18:43.664     0:09:09.799     17,765 kbps     31,058 kbps     00:27:02.537    27,277 kbps     00:26:59.284    23,381 kbps     00:26:58.658    92,620 bytes    541,676 bytes   00:20:00.866
5               0:27:53.463     0:07:51.512     17,155 kbps     23,410 kbps     00:28:03.181    20,209 kbps     00:28:23.743    19,487 kbps     00:28:18.655    89,439 bytes    528,588 bytes   00:28:23.993
6               0:35:44.976     0:02:41.870     17,186 kbps     29,177 kbps     00:37:49.684    24,060 kbps     00:37:46.681    21,452 kbps     00:37:41.676    89,602 bytes    503,446 bytes   00:36:16.799
7               0:38:26.846     0:05:28.244     16,578 kbps     30,619 kbps     00:39:49.470    21,639 kbps     00:39:47.968    20,266 kbps     00:39:47.635    86,429 bytes    505,095 bytes   00:40:24.171
8               0:43:55.090     0:05:08.016     17,382 kbps     23,525 kbps     00:44:02.848    21,022 kbps     00:44:03.140    19,745 kbps     00:44:02.848    90,624 bytes    551,571 bytes   00:46:31.663
9               0:49:03.106     0:04:29.310     19,639 kbps     29,607 kbps     00:51:02.309    27,898 kbps     00:50:58.305    27,690 kbps     00:50:53.300    102,387 bytes   508,209 bytes   00:52:39.406
10              0:53:32.417     0:08:08.905     16,881 kbps     29,488 kbps     00:54:41.361    26,140 kbps     00:54:41.319    24,402 kbps     00:54:37.691    88,010 bytes    546,242 bytes   00:59:46.583
11              1:01:41.322     0:05:35.835     16,128 kbps     23,719 kbps     01:04:25.194    21,447 kbps     01:04:09.762    20,255 kbps     01:04:08.511    84,082 bytes    566,169 bytes   01:02:17.734
12              1:07:17.158     0:05:31.831     18,182 kbps     29,413 kbps     01:12:10.451    25,802 kbps     01:12:10.451    22,930 kbps     01:12:29.303    94,794 bytes    512,631 bytes   01:11:05.552
13              1:12:48.989     0:05:46.262     19,067 kbps     31,064 kbps     01:16:03.016    26,065 kbps     01:16:01.181    25,018 kbps     01:15:54.007    99,406 bytes    539,978 bytes   01:17:29.561
14              1:18:35.252     0:06:15.541     17,466 kbps     27,450 kbps     01:21:41.897    25,801 kbps     01:21:38.894    23,548 kbps     01:21:38.852    91,061 bytes    514,250 bytes   01:19:44.070
15              1:24:50.794     0:05:01.175     18,095 kbps     26,529 kbps     01:29:28.237    23,259 kbps     01:29:26.652    22,132 kbps     01:26:42.488    94,340 bytes    525,680 bytes   01:28:49.240
16              1:29:51.969     0:08:55.952     13,988 kbps     24,208 kbps     01:31:08.212    21,107 kbps     01:37:38.018    20,977 kbps     01:37:34.056    72,933 bytes    477,230 bytes   01:31:30.026
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x02            MPEG-2                                  5927.797                17,218                  12,758,271,883  69,421,348
00002.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5927.797                448                     331,964,416     1,852,480
00002.M2TS      4353 (0x1101)   0x80            LPCM            eng (English)           5927.797                4,614                   3,419,227,140   18,969,360
00002.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5927.797                448                     331,964,416     1,852,480
00002.M2TS      4355 (0x1103)   0x80            LPCM            fra (French)            5927.797                4,614                   3,419,227,140   18,969,360
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5927.797                60                      44,759,011      251,381
00002.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           5927.797                46                      33,763,634      193,653
00002.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            5927.797                57                      42,248,768      237,520
00002.M2TS      4611 (0x1203)   0x90            PGS             nld (Dutch)             5927.797                48                      35,214,229      197,113
00002.M2TS      4612 (0x1204)   0x90            PGS             ara (Arabic)            5927.797                31                      22,619,910      131,234
00002.M2TS      4613 (0x1205)   0x90            PGS             ces (Czech)             5927.797                52                      38,518,386      217,627
00002.M2TS      4614 (0x1206)   0x90            PGS             dan (Danish)            5927.797                47                      34,547,253      194,458
00002.M2TS      4615 (0x1207)   0x90            PGS             fin (Finnish)           5927.797                55                      40,817,727      229,126
00002.M2TS      4616 (0x1208)   0x90            PGS             grc (Greek, Ancient (to 1453))5927.797                59                      43,752,758      246,073
00002.M2TS      4617 (0x1209)   0x90            PGS             heb (Hebrew)            5927.797                41                      30,432,340      173,618
00002.M2TS      4618 (0x120A)   0x90            PGS             hin (Hindi)             5927.797                50                      37,406,442      211,507
00002.M2TS      4619 (0x120B)   0x90            PGS             hun (Hungarian)         5927.797                50                      36,690,354      207,681
00002.M2TS      4620 (0x120C)   0x90            PGS             nor (Norwegian)         5927.797                56                      41,207,368      232,156
00002.M2TS      4621 (0x120D)   0x90            PGS             pol (Polish)            5927.797                57                      42,576,570      239,695
00002.M2TS      4622 (0x120E)   0x90            PGS             swe (Swedish)           5927.797                45                      33,426,153      187,187
00002.M2TS      4623 (0x120F)   0x90            PGS             tur (Turkish)           5927.797                57                      42,437,434      238,945
Stephen Dawson
hifi-writer.com
Old 07-28-2009, 11:51 AM
eric.exe's Avatar
Quoted: 16 Post(s)
Code:
        Total   Video
Initial D                                                       AVC     1:48:52 19,947,073,536  24,996,490,802  24.43   16.49   LPCM 5.1 4608Kbps (48kHz/16-bit)          DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     INITIALD
Disc Size:      24,996,490,802 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:48:52 (h:m:s)
Total Bitrate:          24.43 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        16495 kbps          1080p / 24 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      Chinese         4608 kbps       5.1 / 48 kHz / 4608 kbps / 16-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         21.906 kbps
Presentation Graphics           Chinese         19.569 kbps
Presentation Graphics           Chinese         18.831 kbps
FILES:
00000.M2TS      0:00:00.000     1:48:52.666     19,947,073,536  24,427
CHAPTERS:
1               0:00:00.000     0:04:50.333     15,414 kbps     27,650 kbps     00:01:02.458    23,659 kbps     00:01:01.416    22,683 kbps     00:02:02.250    80,269 bytes    304,931 bytes   00:02:00.916
2               0:04:50.333     0:02:38.958     15,372 kbps     23,717 kbps     00:05:13.625    21,832 kbps     00:05:12.083    19,074 kbps     00:05:21.416    80,063 bytes    361,464 bytes   00:05:19.666
3               0:07:29.291     0:04:23.708     18,145 kbps     25,012 kbps     00:09:10.375    22,290 kbps     00:11:38.583    21,448 kbps     00:11:33.750    94,508 bytes    276,120 bytes   00:07:57.083
4               0:11:53.000     0:05:01.833     15,449 kbps     29,232 kbps     00:13:33.000    27,246 kbps     00:13:30.791    25,241 kbps     00:13:29.166    80,465 bytes    345,760 bytes   00:12:26.083
5               0:16:54.833     0:05:29.583     17,558 kbps     30,504 kbps     00:18:58.583    28,824 kbps     00:21:39.500    24,095 kbps     00:21:34.458    91,449 bytes    295,426 bytes   00:18:59.458
6               0:22:24.416     0:04:31.583     16,198 kbps     25,329 kbps     00:24:21.875    24,402 kbps     00:24:26.875    24,289 kbps     00:24:21.875    84,363 bytes    261,406 bytes   00:24:18.125
7               0:26:56.000     0:05:16.416     13,939 kbps     24,423 kbps     00:30:10.000    19,602 kbps     00:31:35.250    17,635 kbps     00:31:34.916    72,601 bytes    228,715 bytes   00:31:35.291
8               0:32:12.416     0:06:21.500     15,456 kbps     31,581 kbps     00:38:28.666    28,545 kbps     00:37:11.666    23,675 kbps     00:37:07.000    80,502 bytes    300,459 bytes   00:37:11.708
9               0:38:33.916     0:06:29.500     17,869 kbps     30,541 kbps     00:41:51.458    27,910 kbps     00:40:41.000    27,671 kbps     00:40:39.416    93,069 bytes    267,024 bytes   00:43:21.750
10              0:45:03.416     0:04:50.000     19,638 kbps     30,430 kbps     00:45:41.416    29,579 kbps     00:45:30.375    28,968 kbps     00:45:29.916    102,280 bytes   264,313 bytes   00:49:45.833
11              0:49:53.416     0:05:41.166     16,584 kbps     32,087 kbps     00:50:56.708    28,397 kbps     00:49:58.166    25,699 kbps     00:49:54.208    86,377 bytes    357,439 bytes   00:52:35.333
12              0:55:34.583     0:03:06.375     17,265 kbps     29,975 kbps     00:57:37.958    28,650 kbps     00:57:35.833    28,311 kbps     00:57:30.958    89,920 bytes    311,407 bytes   00:55:35.375
13              0:58:40.958     0:04:23.458     20,096 kbps     32,336 kbps     01:00:39.375    29,433 kbps     01:00:43.166    27,735 kbps     01:00:31.791    104,665 bytes   443,749 bytes   01:00:30.583
14              1:03:04.416     0:04:47.000     19,409 kbps     30,404 kbps     01:04:14.791    29,413 kbps     01:04:52.000    27,103 kbps     01:04:48.416    101,087 bytes   365,745 bytes   01:03:18.833
15              1:07:51.416     0:04:52.416     16,516 kbps     30,232 kbps     01:08:26.375    29,683 kbps     01:08:22.416    28,150 kbps     01:08:21.250    86,020 bytes    293,816 bytes   01:08:53.166
16              1:12:43.833     0:05:24.833     16,434 kbps     29,471 kbps     01:14:24.750    26,598 kbps     01:15:28.583    25,317 kbps     01:15:29.791    85,593 bytes    258,340 bytes   01:16:05.708
17              1:18:08.666     0:06:11.541     16,137 kbps     30,571 kbps     01:22:12.500    29,569 kbps     01:22:09.291    25,441 kbps     01:22:08.500    84,048 bytes    301,076 bytes   01:22:52.833
18              1:24:20.208     0:09:17.791     16,963 kbps     33,703 kbps     01:30:01.708    27,714 kbps     01:28:16.750    24,957 kbps     01:28:15.208    88,347 bytes    300,352 bytes   01:24:21.333
19              1:33:38.000     0:05:28.916     18,967 kbps     30,175 kbps     01:37:25.083    29,528 kbps     01:34:14.166    29,033 kbps     01:34:12.458    98,786 bytes    254,287 bytes   01:36:19.833
20              1:39:06.916     0:09:45.750     11,327 kbps     22,399 kbps     01:40:14.583    21,165 kbps     01:42:41.625    19,472 kbps     01:42:37.125    58,997 bytes    309,411 bytes   01:41:47.125
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6532.500                16,495                  13,469,231,908  73,294,202
00000.M2TS      4352 (0x1100)   0x80            LPCM            zho (Chinese)           6532.500                4,615                   3,768,044,056   20,904,544
00000.M2TS      4353 (0x1101)   0x81            AC3             zho (Chinese)           6532.500                640                     522,613,760     3,062,190
00000.M2TS      4354 (0x1102)   0x81            AC3             zho (Chinese)           6532.500                640                     522,613,760     3,062,190
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6532.500                640                     522,613,760     3,062,190
00000.M2TS      4608 (0x1200)   0x90            PGS             zho (Chinese)           6532.500                20                      15,979,977      93,237
00000.M2TS      4609 (0x1201)   0x90            PGS             zho (Chinese)           6532.500                19                      15,376,896      89,962
00000.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6532.500                22                      17,887,690      103,626
eric.exe is offline
Old 07-28-2009, 12:35 PM
Snowknight26's Avatar
Quoted: 26 Post(s)
Liked: 27
Black Christmas (1974)
US Release
Code:
        Total   Video
00000.MPLS                                                      AVC     1:37:49 12,241,815,552  23,730,255,348  16.69   15.00   DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     BLACK_CHRISTMAS
Disc Size:      23,730,255,348 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:37:49 (h:m:s)
Total Bitrate:          16.69 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        15000 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             French          224 kbps        2.0 / 48 kHz / 224 kbps
FILES:
00000.M2TS      0:00:00.000     1:37:49.405     12,241,815,552  16,686
CHAPTERS:
1               0:00:00.000     0:03:46.100     15,041 kbps     30,662 kbps     00:00:01.251    19,484 kbps     00:00:00.875    16,515 kbps     00:00:00.709    78,400 bytes    345,433 bytes   00:00:01.501
2               0:03:46.100     0:02:51.296     14,995 kbps     16,710 kbps     00:04:56.546    15,552 kbps     00:04:24.764    15,292 kbps     00:04:51.958    78,179 bytes    159,351 bytes   00:04:57.422
3               0:06:37.397     0:03:41.220     15,005 kbps     17,150 kbps     00:09:00.706    15,645 kbps     00:10:03.602    15,392 kbps     00:10:01.892    78,229 bytes    165,296 bytes   00:08:11.365
4               0:10:18.617     0:03:53.566     14,988 kbps     17,284 kbps     00:10:50.650    15,686 kbps     00:11:42.243    15,525 kbps     00:10:20.620    78,142 bytes    176,360 bytes   00:10:21.621
5               0:14:12.184     0:02:13.132     14,991 kbps     16,604 kbps     00:14:28.200    15,520 kbps     00:15:53.535    15,276 kbps     00:15:52.034    78,159 bytes    149,981 bytes   00:14:26.198
6               0:16:25.317     0:04:33.147     15,007 kbps     17,043 kbps     00:16:27.277    15,846 kbps     00:19:16.947    15,383 kbps     00:19:11.692    78,242 bytes    183,413 bytes   00:19:07.980
7               0:20:58.465     0:01:50.902     15,001 kbps     17,032 kbps     00:22:43.862    15,794 kbps     00:22:44.071    15,451 kbps     00:22:39.066    78,207 bytes    184,767 bytes   00:22:40.901
8               0:22:49.368     0:02:23.560     15,003 kbps     17,279 kbps     00:24:40.854    15,612 kbps     00:24:41.146    15,376 kbps     00:24:01.648    78,220 bytes    177,606 bytes   00:24:41.646
9               0:25:12.928     0:02:40.159     15,013 kbps     18,139 kbps     00:26:15.949    16,107 kbps     00:26:15.532    15,507 kbps     00:26:13.488    78,273 bytes    200,653 bytes   00:27:07.792
10              0:27:53.088     0:01:51.528     14,965 kbps     17,369 kbps     00:28:51.604    15,500 kbps     00:29:14.127    15,260 kbps     00:29:14.127    78,020 bytes    173,246 bytes   00:28:30.625
11              0:29:44.616     0:02:34.112     14,995 kbps     18,432 kbps     00:30:07.347    16,082 kbps     00:30:12.894    15,444 kbps     00:30:07.347    78,179 bytes    209,434 bytes   00:29:59.130
12              0:32:18.728     0:03:04.392     15,008 kbps     17,553 kbps     00:32:28.237    15,820 kbps     00:32:54.263    15,454 kbps     00:32:49.258    78,244 bytes    193,314 bytes   00:32:19.437
13              0:35:23.121     0:01:27.086     15,020 kbps     20,893 kbps     00:35:23.621    16,008 kbps     00:35:25.873    15,517 kbps     00:35:25.873    78,310 bytes    287,587 bytes   00:35:24.622
14              0:36:50.208     0:01:36.888     15,035 kbps     19,311 kbps     00:38:08.953    16,943 kbps     00:38:08.703    16,109 kbps     00:38:08.244    78,385 bytes    258,214 bytes   00:38:12.957
15              0:38:27.096     0:04:08.498     14,993 kbps     20,161 kbps     00:39:02.131    16,795 kbps     00:39:00.421    15,853 kbps     00:38:56.876    78,168 bytes    249,138 bytes   00:39:18.147
16              0:42:35.594     0:01:21.289     14,971 kbps     20,668 kbps     00:42:35.678    17,062 kbps     00:42:35.594    15,915 kbps     00:42:35.678    78,052 bytes    253,495 bytes   00:42:35.928
17              0:43:56.884     0:03:53.983     14,993 kbps     18,808 kbps     00:45:19.716    16,502 kbps     00:45:18.757    15,803 kbps     00:45:14.503    78,168 bytes    207,658 bytes   00:45:21.468
18              0:47:50.868     0:02:49.002     14,996 kbps     16,692 kbps     00:48:50.302    15,438 kbps     00:48:46.757    15,199 kbps     00:48:43.545    78,182 bytes    157,565 bytes   00:50:11.633
19              0:50:39.870     0:01:40.225     15,012 kbps     17,350 kbps     00:52:02.202    15,720 kbps     00:52:00.492    15,334 kbps     00:51:53.235    78,267 bytes    193,671 bytes   00:52:05.455
20              0:52:20.095     0:02:14.175     14,983 kbps     17,608 kbps     00:52:57.132    15,770 kbps     00:53:36.713    15,350 kbps     00:53:30.957    78,112 bytes    179,255 bytes   00:53:46.181
21              0:54:34.271     0:02:50.753     15,012 kbps     16,709 kbps     00:56:14.996    15,472 kbps     00:55:25.739    15,292 kbps     00:57:05.839    78,265 bytes    171,237 bytes   00:56:18.041
22              0:57:25.024     0:02:10.547     14,990 kbps     16,399 kbps     00:58:58.910    15,275 kbps     00:57:36.744    15,154 kbps     00:58:16.117    78,152 bytes    168,522 bytes   00:59:12.465
23              0:59:35.572     0:03:09.814     14,999 kbps     17,664 kbps     01:01:08.039    15,988 kbps     01:02:00.508    15,489 kbps     01:01:55.378    78,200 bytes    199,961 bytes   00:59:36.698
24              1:02:45.386     0:03:14.527     14,996 kbps     19,559 kbps     01:03:51.285    16,305 kbps     01:03:47.990    15,543 kbps     01:03:59.502    78,180 bytes    223,915 bytes   01:04:08.010
25              1:05:59.914     0:02:48.877     15,010 kbps     17,467 kbps     01:08:01.869    15,662 kbps     01:07:08.024    15,354 kbps     01:07:01.809    78,254 bytes    184,373 bytes   01:08:05.873
26              1:08:48.791     0:02:45.832     14,991 kbps     17,044 kbps     01:09:50.644    15,706 kbps     01:09:48.893    15,381 kbps     01:09:49.143    78,156 bytes    185,948 bytes   01:11:28.492
27              1:11:34.623     0:04:19.842     15,004 kbps     17,522 kbps     01:13:14.056    15,750 kbps     01:13:14.056    15,328 kbps     01:13:13.597    78,224 bytes    195,906 bytes   01:14:03.355
28              1:15:54.466     0:01:24.501     15,000 kbps     16,676 kbps     01:17:15.505    15,560 kbps     01:15:59.388    15,298 kbps     01:16:17.531    78,204 bytes    188,351 bytes   01:16:18.532
29              1:17:18.967     0:02:21.558     14,998 kbps     17,771 kbps     01:18:54.980    15,859 kbps     01:18:51.351    15,504 kbps     01:18:54.980    78,192 bytes    215,539 bytes   01:19:08.702
30              1:19:40.525     0:01:06.816     14,998 kbps     16,796 kbps     01:20:08.970    15,658 kbps     01:20:07.761    15,282 kbps     01:20:05.008    78,193 bytes    170,801 bytes   01:19:42.736
31              1:20:47.342     0:02:13.424     15,009 kbps     17,153 kbps     01:20:59.938    15,754 kbps     01:20:59.938    15,432 kbps     01:20:53.932    78,252 bytes    207,281 bytes   01:22:43.041
32              1:23:00.767     0:02:14.926     15,007 kbps     17,979 kbps     01:24:44.621    15,843 kbps     01:23:33.800    15,402 kbps     01:24:43.912    78,240 bytes    216,019 bytes   01:24:53.880
33              1:25:15.693     0:04:37.110     15,008 kbps     24,866 kbps     01:27:24.030    17,902 kbps     01:27:20.735    16,097 kbps     01:27:29.410    78,246 bytes    313,835 bytes   01:27:24.238
34              1:29:52.804     0:01:23.666     14,979 kbps     17,821 kbps     01:30:50.278    15,725 kbps     01:30:23.709    15,400 kbps     01:30:32.969    78,095 bytes    220,883 bytes   01:30:25.711
35              1:31:16.470     0:05:09.309     14,994 kbps     19,454 kbps     01:33:51.626    16,620 kbps     01:33:49.165    15,834 kbps     01:33:44.118    78,174 bytes    253,431 bytes   01:33:19.594
36              1:36:25.780     0:01:23.625     14,953 kbps     19,029 kbps     01:37:46.610    16,235 kbps     01:37:42.648    15,680 kbps     01:37:37.643    77,998 bytes    233,174 bytes   01:37:46.861
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     5869.238                15,001                  11,005,454,934  59,894,530
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5869.238                448                     328,677,888     1,834,140
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           5869.238                224                     164,338,944     917,070
00000.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            5869.238                224                     164,340,736     917,080
Snowknight26 is offline
Old 07-28-2009, 04:51 PM - Thread Starter
[US] Fast & Furious (Additional Details)
Studio: Universal
Release Date: 2009-07-28
UPC: 025195052108
Aspect Ratio: 2.40:1
The implementation of the U-Control "Take Control" feature on this disc is a little curious as you will note the lack of a secondary PiP video/audio tracks in the report below. Instead, this mode branches in other playlists throughout the course of the movie. However, there is not a separate playlist that shows all these branch points (presumably controlled by BD-Java instead) so I am not able to easily determine the length or put together stats on this mode. One unfortunate decision by Universal is that at least some of these branches are 1080i60 - which could be jarring depending on how well your display handles resolution changes.
Code:
        Total   Video
Fast and Furious                                                VC-1    1:46:52 28,222,285,824  48,681,009,621  35.21   27.31   DTS-HD Master 5.1 4171Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     FAST_AND_FURIOUS
Disc Size:      48,681,009,621 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:46:52 (h:m:s)
Total Bitrate:          35.21 Mbps
Description:
VIDEO:
VC-1 Video              27314 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4171 kbps       5.1 / 48 kHz / 4171 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         25.484 kbps
Presentation Graphics           French          22.109 kbps
Presentation Graphics           French          1.275 kbps
Presentation Graphics           Spanish         17.994 kbps
Presentation Graphics           Spanish         0.337 kbps
FILES:
00010.M2TS      0:00:00.000     1:46:52.406     28,222,285,824  35,210
CHAPTERS:
1               0:00:00.000     0:07:26.529     30,426 kbps     52,759 kbps     00:00:35.744    37,310 kbps     00:00:35.577    35,005 kbps     00:00:35.827    158,612 bytes   520,172 bytes   00:03:45.183
2               0:07:26.529     0:04:20.426     28,483 kbps     43,121 kbps     00:07:40.168    36,630 kbps     00:08:17.830    34,705 kbps     00:07:36.664    148,496 bytes   443,880 bytes   00:07:45.006
3               0:11:46.956     0:04:59.799     30,304 kbps     44,871 kbps     00:12:08.394    37,949 kbps     00:14:55.519    35,421 kbps     00:14:55.519    157,990 bytes   525,354 bytes   00:15:49.281
4               0:16:46.755     0:07:37.331     25,661 kbps     49,897 kbps     00:21:13.105    35,857 kbps     00:21:15.649    34,419 kbps     00:21:13.021    133,784 bytes   636,831 bytes   00:21:13.230
5               0:24:24.087     0:04:41.364     26,402 kbps     41,563 kbps     00:25:15.430    35,444 kbps     00:25:11.426    34,161 kbps     00:25:06.421    137,646 bytes   448,303 bytes   00:25:07.130
6               0:29:05.452     0:04:59.841     29,814 kbps     49,177 kbps     00:30:08.389    38,333 kbps     00:29:19.299    35,536 kbps     00:29:05.702    155,439 bytes   551,787 bytes   00:30:41.214
7               0:34:05.293     0:03:25.496     27,770 kbps     51,751 kbps     00:34:08.588    34,700 kbps     00:34:16.262    32,755 kbps     00:34:11.591    144,780 bytes   735,579 bytes   00:34:08.629
8               0:37:30.790     0:08:36.557     28,850 kbps     49,528 kbps     00:43:54.048    36,496 kbps     00:39:55.601    34,614 kbps     00:43:47.625    150,409 bytes   941,246 bytes   00:37:34.252
9               0:46:07.347     0:07:30.032     28,190 kbps     46,520 kbps     00:50:41.955    35,425 kbps     00:50:37.909    33,173 kbps     00:53:12.272    146,971 bytes   470,066 bytes   00:50:47.335
10              0:53:37.380     0:04:37.777     25,783 kbps     47,985 kbps     00:54:21.508    34,605 kbps     00:55:57.020    33,224 kbps     00:54:21.925    134,422 bytes   443,785 bytes   00:54:16.920
11              0:58:15.158     0:06:34.060     26,290 kbps     50,804 kbps     00:59:22.308    37,635 kbps     01:00:49.812    33,231 kbps     01:03:57.792    137,065 bytes   895,365 bytes   01:03:11.537
12              1:04:49.218     0:02:40.660     26,850 kbps     41,254 kbps     01:05:01.397    34,699 kbps     01:04:58.519    31,667 kbps     01:07:09.608    139,986 bytes   435,439 bytes   01:05:01.731
13              1:07:29.879     0:04:31.980     25,613 kbps     40,321 kbps     01:10:57.294    33,984 kbps     01:10:54.416    32,816 kbps     01:10:50.204    133,533 bytes   406,531 bytes   01:10:57.836
14              1:12:01.859     0:02:44.664     27,155 kbps     37,392 kbps     01:12:06.780    35,125 kbps     01:12:06.697    33,599 kbps     01:12:04.320    141,574 bytes   424,448 bytes   01:12:14.288
15              1:14:46.523     0:05:49.640     26,923 kbps     41,278 kbps     01:18:02.177    35,073 kbps     01:17:59.466    34,279 kbps     01:20:26.154    140,367 bytes   417,451 bytes   01:19:03.989
16              1:20:36.164     0:04:27.100     27,290 kbps     39,050 kbps     01:22:46.836    36,008 kbps     01:23:19.202    33,916 kbps     01:23:15.281    142,276 bytes   449,979 bytes   01:23:37.387
17              1:25:03.264     0:04:06.120     25,359 kbps     43,298 kbps     01:29:00.043    35,903 kbps     01:25:35.630    33,616 kbps     01:28:40.606    132,209 bytes   495,759 bytes   01:25:10.146
18              1:29:09.385     0:06:45.613     29,308 kbps     49,997 kbps     01:35:03.531    35,833 kbps     01:30:24.961    34,025 kbps     01:30:35.888    152,798 bytes   701,603 bytes   01:29:38.664
19              1:35:54.999     0:03:29.959     31,344 kbps     51,228 kbps     01:36:25.780    37,845 kbps     01:38:44.752    35,253 kbps     01:38:19.059    163,413 bytes   463,014 bytes   01:36:26.155
20              1:39:24.959     0:07:27.447     20,055 kbps     49,267 kbps     01:40:02.871    35,316 kbps     01:40:02.579    29,909 kbps     01:39:41.684    104,566 bytes   558,617 bytes   01:45:49.468
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0xEA            VC-1                                    6412.281                27,314                  21,893,461,775  119,078,692
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6412.281                4,171                   3,343,521,032   19,170,490
00010.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           6412.281                768                     615,591,936     3,606,984
00010.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            6412.281                768                     615,591,936     3,606,984
00010.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6412.281                192                     153,897,984     1,001,940
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6412.281                25                      20,426,879      118,035
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6412.281                18                      14,423,305      83,702
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            6412.281                22                      17,721,624      101,987
00010.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6412.281                0                       270,278         1,547
00010.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6412.281                1                       1,021,980       5,849
Cinema Squid is offline
Old 07-28-2009, 05:07 PM
eric.exe's Avatar
Quoted: 16 Post(s)
Code:
        Total   Video
12 Monkeys                                                      VC-1    2:09:34 38,565,728,256  42,457,295,442  39.68   28.66   DTS-HD Master 5.1 4192Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     12_MONKEYS_G51_GLO
Disc Size:      42,457,295,442 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:09:34 (h:m:s)
Total Bitrate:          39.68 Mbps
Description:
VIDEO:
VC-1 Video              28656 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4192 kbps       5.1 / 48 kHz / 4192 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       Italian         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
DTS Audio                       Spanish         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         640 kbps        2.0 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         49.326 kbps
Presentation Graphics           English         89.697 kbps
Presentation Graphics           Chinese         34.989 kbps
Presentation Graphics           Danish          42.870 kbps
Presentation Graphics           Dutch           42.355 kbps
Presentation Graphics           Finnish         41.632 kbps
Presentation Graphics           French          44.002 kbps
Presentation Graphics           French          0.778 kbps
Presentation Graphics           Greek           44.780 kbps
Presentation Graphics           Italian         41.275 kbps
Presentation Graphics           Italian         80.707 kbps
Presentation Graphics           Italian         0.804 kbps
Presentation Graphics           Korean          29.391 kbps
Presentation Graphics           Norwegian       40.751 kbps
Presentation Graphics           Portuguese      40.855 kbps
Presentation Graphics           Spanish         36.253 kbps
Presentation Graphics           Spanish         43.396 kbps
Presentation Graphics           Spanish         76.207 kbps
Presentation Graphics           Spanish         0.404 kbps
Presentation Graphics           Spanish         0.882 kbps
Presentation Graphics           Swedish         39.651 kbps
FILES:
00009.M2TS      0:00:00.000     2:09:34.767     38,565,728,256  39,683
CHAPTERS:
1               0:00:00.000     0:08:34.889     25,689 kbps     42,535 kbps     00:02:09.921    36,678 kbps     00:02:06.835    34,814 kbps     00:02:01.746    134,259 bytes   624,077 bytes   00:03:41.763
2               0:08:34.889     0:02:23.476     27,633 kbps     47,218 kbps     00:09:37.702    37,869 kbps     00:09:37.118    34,521 kbps     00:08:44.857    144,068 bytes   580,549 bytes   00:08:54.867
3               0:10:58.366     0:05:40.965     30,407 kbps     41,844 kbps     00:11:25.393    37,122 kbps     00:15:56.455    35,714 kbps     00:15:55.371    158,528 bytes   604,903 bytes   00:14:30.870
4               0:16:39.331     0:04:50.540     32,955 kbps     44,313 kbps     00:16:49.591    37,407 kbps     00:16:47.923    36,262 kbps     00:16:49.341    171,814 bytes   554,442 bytes   00:16:50.384
5               0:21:29.871     0:03:54.025     32,480 kbps     47,296 kbps     00:22:43.945    36,951 kbps     00:22:41.735    35,054 kbps     00:21:48.181    169,337 bytes   580,280 bytes   00:24:35.849
6               0:25:23.897     0:04:03.368     30,236 kbps     39,441 kbps     00:25:46.419    34,307 kbps     00:26:15.282    33,834 kbps     00:25:39.246    157,638 bytes   557,827 bytes   00:28:57.193
7               0:29:27.265     0:03:18.823     33,009 kbps     42,852 kbps     00:32:26.694    36,722 kbps     00:32:41.084    35,199 kbps     00:32:07.842    172,095 bytes   601,511 bytes   00:29:31.978
8               0:32:46.089     0:03:44.182     32,534 kbps     44,055 kbps     00:33:47.567    38,434 kbps     00:33:10.071    36,591 kbps     00:33:08.861    169,617 bytes   637,051 bytes   00:34:36.657
9               0:36:30.271     0:01:25.502     32,571 kbps     39,247 kbps     00:36:30.521    35,633 kbps     00:36:42.658    34,773 kbps     00:36:36.235    169,813 bytes   593,601 bytes   00:36:36.277
10              0:37:55.773     0:02:04.833     32,228 kbps     39,435 kbps     00:38:11.831    34,523 kbps     00:39:11.974    34,170 kbps     00:39:11.932    168,020 bytes   521,086 bytes   00:38:37.023
11              0:40:00.606     0:02:05.625     30,487 kbps     37,209 kbps     00:40:53.200    33,141 kbps     00:40:23.379    32,700 kbps     00:40:23.170    158,943 bytes   525,482 bytes   00:41:26.692
12              0:42:06.232     0:02:38.908     27,557 kbps     44,944 kbps     00:44:01.221    34,591 kbps     00:44:01.138    32,661 kbps     00:44:33.921    143,668 bytes   544,272 bytes   00:44:33.962
13              0:44:45.140     0:03:01.264     25,134 kbps     42,989 kbps     00:46:31.914    40,207 kbps     00:46:27.910    38,377 kbps     00:46:22.905    131,038 bytes   467,091 bytes   00:45:38.235
14              0:47:46.405     0:06:01.444     21,891 kbps     42,389 kbps     00:49:02.022    33,967 kbps     00:53:16.860    33,526 kbps     00:53:14.900    114,128 bytes   483,709 bytes   00:53:35.921
15              0:53:47.849     0:03:25.622     29,118 kbps     38,924 kbps     00:54:15.877    35,125 kbps     00:54:11.790    33,695 kbps     00:54:07.244    151,806 bytes   560,677 bytes   00:53:49.851
16              0:57:13.471     0:01:36.679     32,736 kbps     41,739 kbps     00:58:40.683    36,933 kbps     00:58:40.016    36,293 kbps     00:58:40.141    170,671 bytes   410,953 bytes   00:58:16.159
17              0:58:50.151     0:02:30.525     30,025 kbps     40,961 kbps     01:00:28.416    35,409 kbps     01:01:10.666    33,573 kbps     01:01:10.667    156,536 bytes   591,998 bytes   01:00:03.433
18              1:01:20.677     0:02:03.790     28,662 kbps     40,099 kbps     01:01:42.323    32,197 kbps     01:01:34.357    31,880 kbps     01:01:29.352    149,430 bytes   490,180 bytes   01:03:08.618
19              1:03:24.467     0:03:08.563     29,399 kbps     38,890 kbps     01:03:25.218    33,274 kbps     01:03:25.134    31,860 kbps     01:03:39.774    153,275 bytes   520,782 bytes   01:03:37.522
20              1:06:33.030     0:03:33.713     29,478 kbps     42,537 kbps     01:08:52.753    37,243 kbps     01:08:48.666    34,691 kbps     01:06:34.407    153,684 bytes   603,469 bytes   01:08:51.210
21              1:10:06.744     0:05:44.052     29,002 kbps     40,552 kbps     01:15:44.289    35,082 kbps     01:14:51.195    33,471 kbps     01:14:51.195    151,205 bytes   533,210 bytes   01:14:03.105
22              1:15:50.796     0:02:37.198     28,436 kbps     37,342 kbps     01:16:00.597    35,065 kbps     01:15:58.929    33,516 kbps     01:15:53.840    148,252 bytes   554,741 bytes   01:18:08.016
23              1:18:27.994     0:02:37.240     30,232 kbps     39,046 kbps     01:19:32.684    34,261 kbps     01:19:52.579    33,908 kbps     01:19:49.201    157,618 bytes   501,368 bytes   01:20:00.045
24              1:21:05.235     0:02:37.740     30,701 kbps     41,302 kbps     01:21:40.812    34,701 kbps     01:21:51.323    33,497 kbps     01:21:46.109    160,059 bytes   620,354 bytes   01:22:33.531
25              1:23:42.976     0:01:31.299     25,348 kbps     34,678 kbps     01:24:06.708    32,842 kbps     01:24:05.081    30,815 kbps     01:24:23.725    132,154 bytes   475,169 bytes   01:24:17.761
26              1:25:14.275     0:01:23.082     29,677 kbps     41,344 kbps     01:26:10.915    34,853 kbps     01:26:24.721    34,173 kbps     01:26:24.721    154,721 bytes   478,358 bytes   01:26:14.294
27              1:26:37.358     0:02:27.188     28,281 kbps     38,779 kbps     01:28:24.632    35,656 kbps     01:28:24.299    33,972 kbps     01:28:22.213    147,443 bytes   605,624 bytes   01:28:16.249
28              1:29:04.547     0:02:28.731     31,261 kbps     38,833 kbps     01:31:32.028    35,729 kbps     01:29:45.505    34,605 kbps     01:31:23.019    162,981 bytes   575,058 bytes   01:30:46.023
29              1:31:33.279     0:01:05.982     32,936 kbps     39,290 kbps     01:32:23.412    36,127 kbps     01:31:44.582    34,744 kbps     01:31:39.243    171,715 bytes   389,182 bytes   01:32:29.043
30              1:32:39.262     0:02:25.311     31,176 kbps     44,092 kbps     01:34:38.047    35,634 kbps     01:32:42.431    34,430 kbps     01:32:39.345    162,538 bytes   639,348 bytes   01:34:58.109
31              1:35:04.573     0:04:20.218     30,147 kbps     39,240 kbps     01:35:04.657    34,360 kbps     01:38:41.916    32,968 kbps     01:35:09.453    157,170 bytes   553,733 bytes   01:36:13.267
32              1:39:24.792     0:02:15.718     29,776 kbps     41,027 kbps     01:40:33.569    33,409 kbps     01:39:26.752    32,285 kbps     01:40:03.914    155,239 bytes   475,708 bytes   01:40:27.187
33              1:41:40.511     0:02:52.881     30,599 kbps     42,970 kbps     01:41:40.677    34,107 kbps     01:42:29.726    32,996 kbps     01:42:46.243    159,528 bytes   537,782 bytes   01:41:59.071
34              1:44:33.392     0:02:00.286     25,494 kbps     32,790 kbps     01:45:23.442    28,606 kbps     01:45:23.525    27,676 kbps     01:45:23.525    132,912 bytes   385,465 bytes   01:45:10.929
35              1:46:33.678     0:02:46.749     22,309 kbps     36,512 kbps     01:49:12.379    30,517 kbps     01:49:09.751    27,543 kbps     01:49:03.370    116,310 bytes   421,415 bytes   01:48:58.406
36              1:49:20.428     0:01:37.639     28,480 kbps     38,931 kbps     01:49:23.807    32,901 kbps     01:49:20.637    30,911 kbps     01:49:47.455    148,481 bytes   600,552 bytes   01:49:24.015
37              1:50:58.068     0:01:50.819     27,849 kbps     40,563 kbps     01:51:08.745    34,696 kbps     01:51:09.120    32,681 kbps     01:51:08.161    145,193 bytes   517,356 bytes   01:51:09.245
38              1:52:48.887     0:01:42.477     29,730 kbps     42,363 kbps     01:53:19.584    33,500 kbps     01:53:42.899    33,018 kbps     01:53:37.977    154,996 bytes   483,410 bytes   01:53:13.703
39              1:54:31.364     0:02:01.996     27,345 kbps     39,178 kbps     01:55:00.894    33,303 kbps     01:55:00.143    31,978 kbps     01:55:00.143    142,566 bytes   493,672 bytes   01:54:52.510
40              1:56:33.361     0:02:33.653     29,193 kbps     39,612 kbps     01:57:21.659    34,167 kbps     01:58:24.388    32,814 kbps     01:58:39.112    152,199 bytes   505,029 bytes   01:57:54.776
41              1:59:07.014     0:02:14.551     28,828 kbps     39,094 kbps     02:00:18.628    33,376 kbps     02:00:18.628    31,736 kbps     01:59:13.980    150,294 bytes   430,618 bytes   02:00:25.968
42              2:01:21.565     0:02:51.671     29,350 kbps     43,224 kbps     02:01:42.336    36,499 kbps     02:02:32.136    33,994 kbps     02:04:03.018    153,020 bytes   556,133 bytes   02:03:13.844
43              2:04:13.237     0:01:19.370     26,255 kbps     43,080 kbps     02:04:51.734    32,112 kbps     02:04:51.233    30,424 kbps     02:05:22.515    136,883 bytes   595,516 bytes   02:04:52.568
44              2:05:32.608     0:04:02.158     17,581 kbps     41,415 kbps     02:09:32.473    33,959 kbps     02:09:28.469    27,095 kbps     02:08:44.341    91,881 bytes    518,102 bytes   02:09:31.847
STREAM DIAGNOSTICS:
00009.M2TS      4113 (0x1011)   0xEA            VC-1                                    7774.642                28,657                  27,849,486,400  151,468,300
00009.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           7774.642                4,192                   4,073,821,408   23,352,787
00009.M2TS      4353 (0x1101)   0x82            DTS             spa (Spanish)           7774.642                768                     746,378,240     4,373,310
00009.M2TS      4354 (0x1102)   0x82            DTS             fra (French)            7774.642                768                     746,378,240     4,373,310
00009.M2TS      4355 (0x1103)   0x82            DTS             ita (Italian)           7774.642                768                     746,378,240     4,373,310
00009.M2TS      4356 (0x1104)   0x82            DTS             spa (Spanish)           7774.642                768                     746,378,240     4,373,310
00009.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           7774.642                640                     621,982,720     3,644,430
00009.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7774.642                49                      47,936,988      274,276
00009.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           7774.642                36                      35,231,932      203,884
00009.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            7774.642                44                      42,762,795      245,073
00009.M2TS      4611 (0x1203)   0x90            PGS             ita (Italian)           7774.642                41                      40,112,960      230,535
00009.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           7774.642                43                      42,174,422      241,715
00009.M2TS      4613 (0x1205)   0x90            PGS             nld (Dutch)             7774.642                42                      41,162,648      236,218
00009.M2TS      4614 (0x1206)   0x90            PGS             por (Portuguese)        7774.642                41                      39,704,673      228,294
00009.M2TS      4615 (0x1207)   0x90            PGS             dan (Danish)            7774.642                43                      41,663,211      238,934
00009.M2TS      4616 (0x1208)   0x90            PGS             nor (Norwegian)         7774.642                41                      39,603,857      227,780
00009.M2TS      4617 (0x1209)   0x90            PGS             fin (Finnish)           7774.642                42                      40,459,478      232,405
00009.M2TS      4618 (0x120A)   0x90            PGS             swe (Swedish)           7774.642                40                      38,534,341      221,925
00009.M2TS      4619 (0x120B)   0x90            PGS             ell (Greek)             7774.642                45                      43,519,699      249,251
00009.M2TS      4620 (0x120C)   0x90            PGS             kor (Korean)            7774.642                29                      28,563,105      167,840
00009.M2TS      4621 (0x120D)   0x90            PGS             zho (Chinese)           7774.642                35                      34,003,805      197,427
00009.M2TS      4622 (0x120E)   0x90            PGS             eng (English)           7774.642                90                      87,171,984      489,417
00009.M2TS      4623 (0x120F)   0x90            PGS             ita (Italian)           7774.642                81                      78,435,107      442,062
00009.M2TS      4624 (0x1210)   0x90            PGS             spa (Spanish)           7774.642                76                      74,061,680      418,315
00009.M2TS      4625 (0x1211)   0x90            PGS             spa (Spanish)           7774.642                0                       392,450         2,244
00009.M2TS      4626 (0x1212)   0x90            PGS             fra (French)            7774.642                1                       756,131         4,296
00009.M2TS      4627 (0x1213)   0x90            PGS             ita (Italian)           7774.642                1                       781,537         4,459
00009.M2TS      4628 (0x1214)   0x90            PGS             spa (Spanish)           7774.642                1                       856,926         4,859
eric.exe is offline
Old 07-28-2009, 06:30 PM
eric.exe's Avatar
Quoted: 16 Post(s)
TF1 France release, locked to Region B.
Code:
        Total   Video
Casino                                                          AVC     2:58:12 37,210,183,680  42,716,456,892  27.84   21.52   DTS-HD Master 5.1 2246Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     CASINO
Disc Size:      42,716,456,892 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:58:12 (h:m:s)
Total Bitrate:          27.84 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        21522 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         2246 kbps       5.1 / 48 kHz / 2246 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
DTS-HD Master Audio             French          2274 kbps       5.1 / 48 kHz / 2274 kbps / 16-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 16-bit)
SUBTITLES:
Presentation Graphics           French          0.026 kbps
Presentation Graphics           French          47.435 kbps
Presentation Graphics           French          54.966 kbps
FILES:
00002.M2TS      0:00:00.000     2:58:12.223     37,210,183,680  27,841
CHAPTERS:
1               0:00:00.000     0:04:09.916     22,569 kbps     31,624 kbps     00:00:58.099    30,538 kbps     00:01:11.905    29,834 kbps     00:01:11.863    117,646 bytes   361,220 bytes   00:00:42.876
2               0:04:09.916     0:06:36.395     23,742 kbps     33,539 kbps     00:04:26.933    29,801 kbps     00:04:27.058    29,548 kbps     00:04:27.058    123,781 bytes   359,565 bytes   00:04:56.421
3               0:10:46.312     0:18:55.300     22,245 kbps     38,545 kbps     00:22:18.211    30,013 kbps     00:22:18.211    29,220 kbps     00:20:20.385    115,975 bytes   372,704 bytes   00:24:52.699
4               0:29:41.613     0:09:14.804     21,396 kbps     33,069 kbps     00:36:26.559    27,425 kbps     00:32:32.492    26,223 kbps     00:32:31.574    111,551 bytes   343,683 bytes   00:32:28.696
5               0:38:56.417     0:09:54.510     22,860 kbps     35,344 kbps     00:42:44.478    29,582 kbps     00:42:44.478    28,455 kbps     00:42:42.726    119,182 bytes   413,321 bytes   00:42:44.520
6               0:48:50.928     0:09:32.154     22,916 kbps     32,619 kbps     00:57:23.690    28,814 kbps     00:58:12.739    28,229 kbps     00:53:01.261    119,471 bytes   359,089 bytes   00:53:59.903
7               0:58:23.082     0:13:09.663     18,937 kbps     30,988 kbps     01:01:44.826    25,187 kbps     01:07:19.201    23,309 kbps     00:58:23.082    98,730 bytes    311,041 bytes   01:09:05.933
8               1:11:32.746     0:12:17.069     19,655 kbps     30,466 kbps     01:16:50.314    27,209 kbps     01:13:48.674    25,265 kbps     01:13:48.090    102,471 bytes   357,937 bytes   01:13:49.675
9               1:23:49.816     0:07:58.811     19,216 kbps     26,146 kbps     01:26:37.358    24,233 kbps     01:30:18.496    23,003 kbps     01:29:01.085    100,185 bytes   334,762 bytes   01:30:33.469
10              1:31:48.628     0:10:00.891     22,089 kbps     34,425 kbps     01:41:46.475    28,763 kbps     01:41:06.143    27,866 kbps     01:41:16.779    115,162 bytes   365,246 bytes   01:41:47.476
11              1:41:49.520     0:09:34.490     23,027 kbps     36,554 kbps     01:45:51.887    30,305 kbps     01:44:07.783    29,654 kbps     01:44:07.366    120,052 bytes   312,598 bytes   01:44:14.915
12              1:51:24.010     0:07:27.947     21,596 kbps     29,436 kbps     01:51:58.420    27,504 kbps     01:52:41.463    26,299 kbps     01:52:36.458    112,592 bytes   390,021 bytes   01:55:14.657
13              1:58:51.958     0:07:49.010     21,002 kbps     30,646 kbps     02:00:38.731    27,864 kbps     02:00:29.180    27,051 kbps     02:00:07.825    109,493 bytes   395,079 bytes   02:01:10.096
14              2:06:40.968     0:07:28.448     20,743 kbps     30,397 kbps     02:13:27.541    26,668 kbps     02:11:51.820    26,391 kbps     02:11:52.571    108,144 bytes   398,986 bytes   02:14:09.249
15              2:14:09.416     0:03:52.065     22,209 kbps     29,400 kbps     02:17:59.562    25,139 kbps     02:17:08.053    24,514 kbps     02:17:05.592    115,790 bytes   409,764 bytes   02:17:46.049
16              2:18:01.481     0:15:40.064     22,086 kbps     35,992 kbps     02:27:33.803    29,792 kbps     02:24:38.503    28,883 kbps     02:24:33.247    115,146 bytes   449,393 bytes   02:33:40.544
17              2:33:41.545     0:05:58.733     24,555 kbps     38,182 kbps     02:38:04.475    30,300 kbps     02:38:01.013    28,244 kbps     02:37:56.091    128,017 bytes   448,065 bytes   02:34:39.395
18              2:39:40.279     0:02:13.424     21,719 kbps     30,941 kbps     02:40:39.171    25,830 kbps     02:40:39.171    24,219 kbps     02:40:43.175    113,233 bytes   366,882 bytes   02:39:44.241
19              2:41:53.704     0:07:32.034     24,134 kbps     38,659 kbps     02:47:37.797    32,628 kbps     02:47:48.600    30,828 kbps     02:47:33.585    125,825 bytes   454,391 bytes   02:47:06.141
20              2:49:25.738     0:02:39.075     23,837 kbps     38,079 kbps     02:49:31.744    33,986 kbps     02:49:30.201    31,617 kbps     02:49:27.407    124,276 bytes   413,017 bytes   02:51:35.368
21              2:52:04.814     0:06:07.408     13,464 kbps     25,283 kbps     02:56:09.100    16,788 kbps     02:56:35.126    15,655 kbps     02:56:38.629    70,203 bytes    310,938 bytes   02:57:52.119
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     10692.140               21,522                  28,764,986,968  156,481,888
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       fra (French)            10692.140               2,274                   3,038,895,812   18,190,815
00002.M2TS      4353 (0x1101)   0x86            DTS-HD MA       eng (English)           10692.140               2,246                   3,002,289,604   17,990,963
00002.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            10692.140               0                       35,233          206
00002.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            10692.140               47                      63,398,572      362,395
00002.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            10692.140               55                      73,464,057      418,551
eric.exe is offline
Old 07-28-2009, 09:39 PM
Thunderbolt8's Avatar
^^does it look better than the other VC-1 version?
Thunderbolt8 is offline
Old 07-29-2009, 08:33 AM
Quoted: 26 Post(s)
Liked: 27
Sublime
US Release
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:53:09 18,433,701,888  19,423,560,968  21.72   19.74   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     RAW_FEED_SUBLIME_NA
Disc Size:      19,423,560,968 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:53:09 (h:m:s)
Total Bitrate:          21.72 Mbps
Description:
VIDEO:
VC-1 Video              19739 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         30.109 kbps
Presentation Graphics           French          22.426 kbps
Presentation Graphics           Spanish         29.176 kbps
FILES:
00000.M2TS      0:00:00.000     1:53:09.115     18,433,701,888  21,721
CHAPTERS:
1               0:00:00.000     0:04:00.573     14,604 kbps     25,156 kbps     00:02:53.423    20,778 kbps     00:02:07.794    18,314 kbps     00:03:24.829    77,225 bytes    245,835 bytes   00:00:24.274
2               0:04:00.573     0:03:41.221     18,214 kbps     27,042 kbps     00:04:07.413    24,642 kbps     00:04:30.311    24,327 kbps     00:04:26.307    94,959 bytes    248,985 bytes   00:04:15.880
3               0:07:41.794     0:04:07.747     22,920 kbps     32,884 kbps     00:09:25.606    27,456 kbps     00:09:05.836    26,139 kbps     00:09:00.915    119,555 bytes   313,621 bytes   00:08:58.287
4               0:11:49.542     0:04:10.416     15,209 kbps     23,203 kbps     00:12:16.318    21,691 kbps     00:12:14.525    19,202 kbps     00:12:22.825    79,293 bytes    212,463 bytes   00:12:27.413
5               0:15:59.959     0:04:10.083     17,959 kbps     25,325 kbps     00:18:20.974    22,827 kbps     00:18:20.808    22,525 kbps     00:18:21.016    93,631 bytes    207,577 bytes   00:19:57.696
6               0:20:10.042     0:03:42.889     17,943 kbps     28,230 kbps     00:20:57.339    24,222 kbps     00:21:10.435    22,778 kbps     00:21:05.722    93,545 bytes    241,409 bytes   00:20:57.965
7               0:23:52.931     0:03:09.856     15,223 kbps     23,948 kbps     00:25:56.680    22,055 kbps     00:25:52.884    20,654 kbps     00:25:49.673    79,368 bytes    242,468 bytes   00:25:56.721
8               0:27:02.787     0:05:22.655     20,904 kbps     32,161 kbps     00:28:12.315    26,561 kbps     00:28:08.478    25,514 kbps     00:28:25.370    108,986 bytes   284,014 bytes   00:30:48.972
9               0:32:25.443     0:03:33.880     18,753 kbps     31,835 kbps     00:32:52.220    27,362 kbps     00:32:49.550    25,848 kbps     00:32:44.671    97,769 bytes    276,216 bytes   00:33:00.186
10              0:35:59.323     0:03:48.228     17,436 kbps     28,326 kbps     00:38:57.293    24,903 kbps     00:37:42.218    21,816 kbps     00:37:38.047    90,904 bytes    232,290 bytes   00:37:46.430
11              0:39:47.551     0:06:15.375     22,518 kbps     35,084 kbps     00:42:22.540    27,054 kbps     00:44:17.780    26,205 kbps     00:43:03.330    117,397 bytes   325,694 bytes   00:42:22.581
12              0:46:02.926     0:04:48.121     22,958 kbps     31,454 kbps     00:49:59.830    26,691 kbps     00:49:57.119    26,122 kbps     00:50:13.760    119,693 bytes   290,336 bytes   00:50:10.006
13              0:50:51.047     0:03:51.731     21,753 kbps     33,356 kbps     00:54:41.736    26,812 kbps     00:54:37.774    25,554 kbps     00:54:32.769    113,409 bytes   334,264 bytes   00:51:30.754
14              0:54:42.779     0:05:02.301     22,911 kbps     31,650 kbps     00:59:07.669    27,414 kbps     00:58:50.485    25,468 kbps     00:56:52.992    119,450 bytes   344,213 bytes   00:58:33.593
15              0:59:45.081     0:04:11.918     21,840 kbps     34,488 kbps     00:59:45.248    27,085 kbps     01:03:40.900    26,141 kbps     01:03:38.397    113,866 bytes   267,666 bytes   01:03:43.569
16              1:03:56.999     0:06:12.205     19,772 kbps     28,412 kbps     01:05:12.825    26,482 kbps     01:09:09.019    25,255 kbps     01:05:20.333    103,082 bytes   226,793 bytes   01:06:00.498
17              1:10:09.205     0:04:32.271     21,703 kbps     33,894 kbps     01:12:53.494    27,530 kbps     01:12:49.490    26,444 kbps     01:13:35.244    113,148 bytes   281,123 bytes   01:11:55.311
18              1:14:41.477     0:03:06.686     21,896 kbps     32,702 kbps     01:17:09.499    27,288 kbps     01:15:34.363    26,090 kbps     01:15:17.846    114,158 bytes   326,897 bytes   01:17:45.619
19              1:17:48.163     0:03:36.382     21,882 kbps     31,184 kbps     01:20:20.023    26,997 kbps     01:21:19.416    25,809 kbps     01:21:14.411    114,083 bytes   316,685 bytes   01:21:12.409
20              1:21:24.546     0:04:41.614     23,238 kbps     29,778 kbps     01:21:32.345    27,384 kbps     01:23:04.312    26,365 kbps     01:22:59.265    121,151 bytes   293,306 bytes   01:22:18.808
21              1:26:06.161     0:04:24.764     21,821 kbps     30,775 kbps     01:27:48.846    26,872 kbps     01:26:40.486    25,448 kbps     01:26:35.440    113,765 bytes   298,687 bytes   01:30:15.743
22              1:30:30.925     0:05:44.510     21,051 kbps     33,799 kbps     01:32:37.969    27,249 kbps     01:33:07.373    25,018 kbps     01:32:42.515    109,752 bytes   326,742 bytes   01:30:38.182
23              1:36:15.436     0:06:44.403     22,474 kbps     31,506 kbps     01:38:19.351    27,357 kbps     01:41:10.773    26,055 kbps     01:39:44.478    117,169 bytes   313,880 bytes   01:42:18.298
24              1:42:59.840     0:05:20.653     21,882 kbps     32,662 kbps     01:44:12.204    26,925 kbps     01:47:13.593    25,734 kbps     01:47:08.630    114,259 bytes   330,594 bytes   01:46:25.545
25              1:48:20.494     0:04:48.621     1,937 kbps      5,043 kbps      01:52:59.773    4,126 kbps      01:50:52.854    4,003 kbps      01:50:52.228    10,303 bytes    119,738 bytes   01:53:01.357
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    6789.032                19,739                  16,751,352,806  91,137,282
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           6789.032                640                     543,129,600     3,182,400
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6789.032                192                     162,938,880     1,060,800
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6789.032                30                      25,551,294      147,587
00000.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            6789.032                22                      19,031,826      111,054
00000.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           6789.032                29                      24,759,482      142,285
Old 07-29-2009, 05:21 PM
Patsfan123's Avatar
Quoted: 107 Post(s)
Liked: 65
I think they set this one on autopilot and left for the day..
Code:
        Total   Video
Miss March (Unrated)                                            AVC     1:33:33 30,455,783,424  40,106,589,218  43.40   36.76   DTS-HD Master 5.1 3819Kbps (48kHz/24-bit)
Miss March (Rated)                                              AVC     1:29:58 29,256,486,912  40,106,589,218  43.36   36.73   DTS-HD Master 5.1 3812Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MISS_MARCH
Disc Size:      40,106,589,218 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:33:33 (h:m:s)
Total Bitrate:          43.40 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        36761 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3819 kbps       5.1 / 48 kHz / 3819 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         72.569 kbps
Presentation Graphics           French          3.316 kbps
Presentation Graphics           Portuguese      54.623 kbps
Presentation Graphics           Spanish         57.039 kbps
FILES:
00057.M2TS      0:00:00.000     0:09:21.227     3,142,920,192   44,801
00059.M2TS      0:09:21.227     0:04:08.373     1,391,806,464   44,830
00060.M2TS      0:13:29.600     0:03:54.442     1,289,011,200   43,986
00062.M2TS      0:17:24.042     0:03:02.640     1,016,352,768   44,518
00063.M2TS      0:20:26.683     0:11:07.416     3,701,772,288   44,371
00065.M2TS      0:31:34.100     0:01:33.384     520,187,904     44,563
00066.M2TS      0:33:07.485     0:12:41.260     4,208,381,952   44,225
00068.M2TS      0:45:48.745     0:03:03.141     1,020,954,624   44,597
00069.M2TS      0:48:51.887     0:09:49.171     3,281,098,752   44,552
00071.M2TS      0:58:41.059     0:02:12.048     742,066,176     44,957
00072.M2TS      1:00:53.107     0:02:18.638     781,406,208     45,090
00074.M2TS      1:03:11.746     0:07:54.307     2,647,099,392   44,648
00075.M2TS      1:11:06.053     0:17:18.203     5,807,388,672   44,750
00078.M2TS      1:28:24.257     0:05:09.559     905,336,832     23,397
CHAPTERS:
1               0:00:00.000     0:04:39.737     37,551 kbps     44,708 kbps     00:02:10.797    40,186 kbps     00:02:46.416    39,401 kbps     00:03:07.645    195,745 bytes   739,004 bytes   00:02:15.176
2               0:04:39.737     0:04:41.489     38,715 kbps     43,565 kbps     00:05:06.014    39,906 kbps     00:05:01.968    39,654 kbps     00:04:56.963    201,843 bytes   550,663 bytes   00:09:21.227
3               0:09:21.227     0:03:57.278     37,954 kbps     42,947 kbps     00:13:17.254    39,891 kbps     00:12:57.193    39,451 kbps     00:12:46.390    197,875 bytes   575,189 bytes   00:09:22.228
4               0:13:18.506     0:03:03.892     38,796 kbps     47,439 kbps     00:16:19.269    40,938 kbps     00:16:15.307    40,050 kbps     00:16:10.302    202,264 bytes   441,490 bytes   00:16:20.938
5               0:16:22.398     0:04:04.285     36,627 kbps     42,754 kbps     00:17:18.704    39,813 kbps     00:17:14.700    39,419 kbps     00:16:40.916    190,955 bytes   391,699 bytes   00:17:24.042
6               0:20:26.683     0:04:41.489     38,350 kbps     50,155 kbps     00:21:29.663    41,318 kbps     00:21:25.659    40,107 kbps     00:21:20.612    199,939 bytes   920,071 bytes   00:21:30.247
7               0:25:08.173     0:01:44.395     35,438 kbps     46,213 kbps     00:26:48.773    38,188 kbps     00:26:44.811    37,176 kbps     00:26:39.764    184,758 bytes   421,971 bytes   00:26:49.316
8               0:26:52.569     0:05:04.971     38,218 kbps     43,178 kbps     00:27:30.982    39,410 kbps     00:27:36.112    39,256 kbps     00:27:31.024    199,251 bytes   507,575 bytes   00:28:34.879
9               0:31:57.540     0:03:16.154     37,017 kbps     40,724 kbps     00:32:31.324    39,192 kbps     00:33:12.073    39,124 kbps     00:33:07.693    192,989 bytes   299,984 bytes   00:32:47.423
10              0:35:13.694     0:04:19.717     37,247 kbps     41,194 kbps     00:37:18.194    39,273 kbps     00:36:06.372    39,132 kbps     00:35:13.903    194,187 bytes   441,312 bytes   00:36:13.462
11              0:39:33.412     0:05:11.269     38,635 kbps     40,946 kbps     00:44:34.421    39,500 kbps     00:43:50.794    39,323 kbps     00:43:45.748    201,427 bytes   414,221 bytes   00:41:00.457
12              0:44:44.681     0:05:00.258     37,975 kbps     41,319 kbps     00:48:04.464    39,635 kbps     00:45:41.488    39,269 kbps     00:49:33.887    197,985 bytes   415,185 bytes   00:45:45.826
13              0:49:44.940     0:05:49.474     38,285 kbps     43,230 kbps     00:51:10.901    39,862 kbps     00:51:06.980    39,367 kbps     00:49:46.483    199,599 bytes   408,418 bytes   00:51:11.735
14              0:55:34.414     0:04:52.709     37,372 kbps     42,480 kbps     00:58:53.446    39,768 kbps     00:58:49.400    39,444 kbps     00:58:44.395    194,841 bytes   376,686 bytes   00:59:30.692
15              1:00:27.123     0:03:51.064     38,307 kbps     41,088 kbps     01:02:17.483    39,428 kbps     01:03:38.856    39,299 kbps     01:03:37.396    199,717 bytes   467,696 bytes   01:00:31.377
16              1:04:18.187     0:04:11.292     36,879 kbps     40,363 kbps     01:04:20.439    39,109 kbps     01:05:03.649    38,744 kbps     01:04:24.735    192,270 bytes   444,146 bytes   01:07:05.729
17              1:08:29.480     0:04:58.715     38,769 kbps     43,215 kbps     01:12:59.625    39,747 kbps     01:10:34.104    39,275 kbps     01:13:16.975    202,126 bytes   374,888 bytes   01:09:01.512
18              1:13:28.195     0:01:18.745     38,243 kbps     40,944 kbps     01:14:45.939    39,268 kbps     01:13:48.966    39,191 kbps     01:13:48.966    199,379 bytes   445,749 bytes   01:14:46.940
19              1:14:46.940     0:01:34.260     36,912 kbps     40,989 kbps     01:15:14.760    39,146 kbps     01:15:11.048    38,114 kbps     01:15:11.048    192,440 bytes   427,836 bytes   01:16:08.313
20              1:16:21.201     0:02:35.280     38,022 kbps     40,316 kbps     01:18:11.561    39,372 kbps     01:18:07.641    39,231 kbps     01:17:41.072    198,229 bytes   419,007 bytes   01:18:56.481
21              1:18:56.481     0:02:14.342     37,112 kbps     49,194 kbps     01:21:00.271    41,098 kbps     01:20:56.267    40,105 kbps     01:20:51.262    193,487 bytes   457,813 bytes   01:21:01.022
22              1:21:10.824     0:05:55.813     38,485 kbps     41,809 kbps     01:22:17.515    39,652 kbps     01:22:13.595    39,349 kbps     01:22:08.590    200,643 bytes   431,997 bytes   01:23:46.312
23              1:27:06.637     0:01:52.195     37,635 kbps     45,321 kbps     01:28:57.498    40,194 kbps     01:28:53.494    39,671 kbps     01:28:48.489    196,210 bytes   394,979 bytes   01:27:14.520
24              1:28:58.833     0:04:34.983     14,730 kbps     41,330 kbps     01:29:40.333    39,524 kbps     01:29:53.638    39,341 kbps     01:29:31.449    76,809 bytes    572,080 bytes   01:32:26.248
STREAM DIAGNOSTICS:
00057.M2TS      4113 (0x1011)   0x1B            AVC                                     561.102                 38,136                  2,674,747,774   14,544,600
00057.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           561.102                 3,784                   265,395,432     1,529,536
00057.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            561.102                 448                     31,429,888      175,390
00057.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           561.102                 75                      5,287,439       29,817
00057.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           561.102                 61                      4,271,690       24,187
00057.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        561.102                 61                      4,288,170       24,268
00057.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            561.102                 2                       111,605         637
00059.M2TS      4113 (0x1011)   0x1B            AVC                                     248.248                 38,002                  1,179,252,739   6,412,455
00059.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           248.248                 3,936                   122,122,584     702,504
00059.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            248.248                 448                     13,909,504      77,620
00059.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           248.248                 90                      2,807,367       15,786
00059.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           248.248                 65                      2,006,721       11,367
00059.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        248.248                 61                      1,903,331       10,809
00059.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            248.248                 2                       62,522          367
00060.M2TS      4113 (0x1011)   0x1B            AVC                                     234.359                 37,195                  1,089,636,733   5,925,179
00060.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           234.359                 3,950                   115,728,016     665,569
00060.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            234.359                 448                     13,129,984      73,270
00060.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           234.359                 76                      2,231,627       12,550
00060.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           234.359                 61                      1,775,113       10,051
00060.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        234.359                 60                      1,748,797       9,908
00060.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            234.359                 0                       70              7
00062.M2TS      4113 (0x1011)   0x1B            AVC                                     182.516                 38,011                  867,209,459     4,715,654
00062.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           182.516                 3,611                   82,393,292      476,250
00062.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            182.516                 448                     10,228,736      57,080
00062.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           182.516                 88                      2,007,597       11,307
00062.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           182.516                 76                      1,740,377       9,847
00062.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        182.516                 73                      1,672,270       9,471
00062.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            182.516                 5                       105,661         602
00063.M2TS      4113 (0x1011)   0x1B            AVC                                     667.292                 37,839                  3,156,198,584   17,162,698
00063.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           667.292                 3,671                   306,163,572     1,767,887
00063.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            667.292                 448                     37,375,744      208,570
00063.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           667.292                 75                      6,288,007       35,504
00063.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           667.292                 62                      5,132,992       29,126
00063.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        667.292                 58                      4,831,630       27,482
00063.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            667.292                 0                       35,495          200
00065.M2TS      4113 (0x1011)   0x1B            AVC                                     93.260                  38,019                  443,205,687     2,410,075
00065.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           93.260                  3,786                   44,132,436      254,417
00065.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            93.260                  449                     5,230,848       29,190
00065.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           93.260                  58                      671,765         3,787
00065.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           93.260                  37                      436,627         2,480
00065.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        93.260                  39                      449,009         2,551
00065.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            93.260                  0                       70              7
00066.M2TS      4113 (0x1011)   0x1B            AVC                                     761.135                 37,820                  3,598,295,474   19,566,753
00066.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           761.135                 3,576                   340,191,964     1,967,457
00066.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            761.135                 448                     42,631,680      237,900
00066.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           761.135                 63                      5,947,128       33,607
00066.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           761.135                 54                      5,119,055       28,989
00066.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        761.135                 51                      4,821,365       27,377
00066.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            761.135                 2                       204,540         1,153
00068.M2TS      4113 (0x1011)   0x1B            AVC                                     183.016                 37,495                  857,774,537     4,664,403
00068.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           183.016                 4,191                   95,883,068      549,638
00068.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            183.016                 448                     10,257,408      57,240
00068.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           183.016                 83                      1,902,665       10,700
00068.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           183.016                 72                      1,635,826       9,210
00068.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        183.016                 66                      1,508,155       8,507
00068.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            183.016                 34                      786,997         4,427
00069.M2TS      4113 (0x1011)   0x1B            AVC                                     589.047                 37,978                  2,796,362,995   15,205,971
00069.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           589.047                 3,731                   274,704,172     1,584,283
00069.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            589.047                 448                     32,994,304      184,120
00069.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           589.047                 68                      4,977,946       28,190
00069.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           589.047                 54                      3,959,875       22,458
00069.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        589.047                 50                      3,716,162       21,133
00069.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            589.047                 0                       70              7
00071.M2TS      4113 (0x1011)   0x1B            AVC                                     131.965                 37,984                  626,563,736     3,407,106
00071.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           131.965                 4,135                   68,208,944      391,163
00071.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            131.965                 448                     7,395,584       41,270
00071.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           131.965                 60                      985,449         5,567
00071.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           131.965                 51                      843,292         4,775
00071.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        131.965                 47                      777,477         4,414
00071.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            131.965                 11                      178,721         1,012
00072.M2TS      4113 (0x1011)   0x1B            AVC                                     138.513                 38,010                  658,110,465     3,578,663
00072.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           138.513                 4,260                   73,759,464      422,378
00072.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            138.513                 448                     7,764,736       43,330
00072.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           138.513                 67                      1,158,067       6,538
00072.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           138.513                 47                      812,555         4,600
00072.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        138.513                 42                      719,123         4,093
00072.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            138.513                 1                       20,300          117
00074.M2TS      4113 (0x1011)   0x1B            AVC                                     474.182                 37,834                  2,242,541,044   12,194,432
00074.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           474.182                 3,938                   233,442,256     1,342,686
00074.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            474.182                 448                     26,562,816      148,230
00074.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           474.182                 71                      4,209,944       23,799
00074.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           474.182                 60                      3,526,887       20,047
00074.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        474.182                 59                      3,483,268       19,821
00074.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            474.182                 10                      602,654         3,406
00075.M2TS      4113 (0x1011)   0x1B            AVC                                     1038.079                38,000                  4,930,848,891   26,812,762
00075.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1038.079                3,866                   501,608,824     2,888,223
00075.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1038.079                448                     58,139,648      324,440
00075.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1038.079                73                      9,413,299       53,222
00075.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1038.079                64                      8,312,503       47,097
00075.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        1038.079                62                      7,990,801       45,351
00075.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            1038.079                0                       21,595          124
00078.M2TS      4113 (0x1011)   0x1B            AVC                                     309.434                 17,459                  675,291,959     3,675,851
00078.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           309.434                 4,038                   156,204,144     896,939
00078.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            309.434                 448                     17,335,808      96,740
00078.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           309.434                 78                      3,035,654       17,090
00078.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           309.434                 12                      452,310         2,581
00078.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        309.434                 11                      421,022         2,411
00078.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            309.434                 5                       196,573         1,131
Code:
DISC INFO:
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:29:58 (h:m:s)
Total Bitrate:          43.36 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        36728 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3812 kbps       5.1 / 48 kHz / 3812 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         73.110 kbps
Presentation Graphics           French          1.427 kbps
Presentation Graphics           Portuguese      55.113 kbps
Presentation Graphics           Spanish         57.500 kbps
FILES:
00058.M2TS      0:09:21.227     0:03:53.399     1,306,005,504   44,765
00060.M2TS      0:13:14.627     0:03:54.442     1,289,011,200   43,986
00061.M2TS      0:17:09.069     0:02:52.005     957,474,816     44,532
00063.M2TS      0:20:01.074     0:11:07.416     3,701,772,288   44,371
00064.M2TS      0:31:08.491     0:01:32.217     513,613,824     44,557
00066.M2TS      0:32:40.708     0:12:41.260     4,208,381,952   44,225
00067.M2TS      0:45:21.969     0:02:15.176     754,636,800     44,661
00069.M2TS      0:47:37.145     0:09:49.171     3,281,098,752   44,552
00070.M2TS      0:57:26.317     0:01:52.445     631,025,664     44,895
00072.M2TS      0:59:18.763     0:02:18.638     781,406,208     45,090
00073.M2TS      1:01:37.401     0:06:23.132     2,138,222,592   44,647
00075.M2TS      1:08:00.534     0:17:18.203     5,807,388,672   44,750
00077.M2TS      1:25:18.738     0:04:39.320     743,528,448     21,295
CHAPTERS:
2               0:04:39.737     0:04:41.489     38,715 kbps     43,565 kbps     00:05:06.014    39,906 kbps     00:05:01.968    39,654 kbps     00:04:56.963    201,843 bytes   548,707 bytes   00:09:21.227
3               0:09:21.227     0:03:42.263     37,942 kbps     43,527 kbps     00:12:57.318    39,845 kbps     00:12:57.067    39,464 kbps     00:12:42.595    197,813 bytes   585,362 bytes   00:12:52.396
4               0:13:03.491     0:03:03.933     38,784 kbps     47,439 kbps     00:16:04.296    40,938 kbps     00:16:00.334    40,050 kbps     00:15:55.329    202,200 bytes   441,490 bytes   00:16:05.964
5               0:16:07.424     0:03:53.650     36,567 kbps     42,754 kbps     00:17:03.731    39,813 kbps     00:16:59.727    39,419 kbps     00:16:25.943    190,645 bytes   392,447 bytes   00:17:09.069
6               0:20:01.074     0:04:41.489     38,350 kbps     50,155 kbps     00:21:04.054    41,318 kbps     00:21:00.050    40,107 kbps     00:20:55.003    199,939 bytes   920,071 bytes   00:21:04.638
7               0:24:42.564     0:01:44.395     35,438 kbps     46,213 kbps     00:26:23.164    38,188 kbps     00:26:19.202    37,176 kbps     00:26:14.155    184,758 bytes   421,971 bytes   00:26:23.707
8               0:26:26.960     0:05:03.803     38,212 kbps     43,178 kbps     00:27:05.373    39,410 kbps     00:27:10.503    39,256 kbps     00:27:05.415    199,222 bytes   507,575 bytes   00:28:09.270
9               0:31:30.763     0:03:16.154     37,024 kbps     40,742 kbps     00:32:04.380    39,192 kbps     00:32:45.296    39,124 kbps     00:32:40.917    193,024 bytes   302,014 bytes   00:32:20.646
10              0:34:46.918     0:04:19.717     37,247 kbps     41,194 kbps     00:36:51.417    39,273 kbps     00:35:39.595    39,132 kbps     00:34:47.126    194,187 bytes   441,312 bytes   00:35:46.686
11              0:39:06.635     0:05:11.269     38,635 kbps     40,946 kbps     00:44:07.644    39,500 kbps     00:43:24.018    39,323 kbps     00:43:18.971    201,427 bytes   414,221 bytes   00:40:33.681
12              0:44:17.905     0:04:12.293     38,085 kbps     44,445 kbps     00:46:54.353    40,096 kbps     00:46:50.307    39,450 kbps     00:46:45.302    198,558 bytes   415,185 bytes   00:45:19.049
13              0:48:30.198     0:05:49.474     38,285 kbps     43,230 kbps     00:49:56.159    39,862 kbps     00:49:52.239    39,367 kbps     00:48:31.742    199,599 bytes   408,418 bytes   00:49:56.993
14              0:54:19.672     0:04:33.106     37,320 kbps     40,699 kbps     00:56:44.776    39,462 kbps     00:57:05.255    39,210 kbps     00:57:00.291    194,571 bytes   377,491 bytes   00:58:03.896
15              0:58:52.779     0:03:16.321     38,185 kbps     41,088 kbps     01:00:43.139    39,398 kbps     01:00:04.851    39,215 kbps     01:01:56.671    199,078 bytes   442,684 bytes   00:58:57.033
16              1:02:09.100     0:03:43.890     37,026 kbps     40,334 kbps     01:02:11.352    39,118 kbps     01:02:22.280    38,940 kbps     01:02:10.309    193,035 bytes   453,596 bytes   01:04:29.240
17              1:05:52.990     0:04:29.686     38,814 kbps     43,215 kbps     01:09:54.106    39,848 kbps     01:07:28.794    39,494 kbps     01:07:23.747    202,360 bytes   381,009 bytes   01:07:33.382
18              1:10:22.676     0:01:18.745     38,243 kbps     40,944 kbps     01:11:40.420    39,268 kbps     01:10:43.447    39,191 kbps     01:10:43.447    199,379 bytes   445,749 bytes   01:11:41.421
19              1:11:41.421     0:01:34.260     36,912 kbps     40,989 kbps     01:12:09.241    39,146 kbps     01:12:05.529    38,114 kbps     01:12:05.529    192,440 bytes   427,836 bytes   01:13:02.794
20              1:13:15.682     0:02:35.280     38,022 kbps     40,316 kbps     01:15:06.043    39,372 kbps     01:15:02.122    39,231 kbps     01:14:35.554    198,229 bytes   419,007 bytes   01:15:50.962
21              1:15:50.962     0:02:14.342     37,112 kbps     49,194 kbps     01:17:54.753    41,098 kbps     01:17:50.749    40,105 kbps     01:17:45.744    193,487 bytes   457,813 bytes   01:17:55.504
22              1:18:05.305     0:05:55.813     38,485 kbps     41,809 kbps     01:19:11.997    39,652 kbps     01:19:08.076    39,349 kbps     01:19:03.071    200,643 bytes   431,997 bytes   01:20:40.794
23              1:24:01.119     0:01:24.667     37,163 kbps     40,648 kbps     01:25:20.365    39,214 kbps     01:25:19.364    38,202 kbps     01:25:15.735    193,750 bytes   394,979 bytes   01:24:09.002
24              1:25:25.787     0:04:32.271     14,783 kbps     40,772 kbps     01:26:11.290    39,423 kbps     01:26:20.133    39,238 kbps     01:26:11.290    77,086 bytes    572,074 bytes   01:28:52.952
STREAM DIAGNOSTICS:
00058.M2TS      4113 (0x1011)   0x1B            AVC                                     233.275                 37,985                  1,107,607,379   6,022,869
00058.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           233.275                 3,887                   113,335,132     652,446
00058.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            233.275                 448                     13,070,848      72,940
00058.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           233.275                 92                      2,680,945       15,072
00058.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           233.275                 67                      1,965,612       11,122
00058.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        233.275                 64                      1,861,539       10,561
00058.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            233.275                 1                       18,386          107
00061.M2TS      4113 (0x1011)   0x1B            AVC                                     171.880                 38,016                  816,780,425     4,441,498
00061.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           171.880                 3,620                   77,772,080      449,551
00061.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            171.880                 448                     9,633,792       53,760
00061.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           171.880                 90                      1,934,533       10,883
00061.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           171.880                 78                      1,682,337       9,511
00061.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        171.880                 75                      1,609,785       9,111
00061.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            171.880                 0                       70              7
00064.M2TS      4113 (0x1011)   0x1B            AVC                                     92.092                  38,012                  437,575,844     2,379,434
00064.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           92.092                  3,787                   43,588,444      251,285
00064.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            92.092                  449                     5,164,544       28,820
00064.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           92.092                  58                      671,765         3,787
00064.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           92.092                  38                      436,627         2,480
00064.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        92.092                  39                      449,009         2,551
00064.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            92.092                  0                       70              7
00067.M2TS      4113 (0x1011)   0x1B            AVC                                     135.052                 37,530                  633,557,745     3,445,182
00067.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           135.052                 4,204                   70,968,024      406,824
00067.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            135.052                 448                     7,571,200       42,250
00067.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           135.052                 95                      1,600,644       8,996
00067.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           135.052                 79                      1,338,293       7,537
00067.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        135.052                 73                      1,233,150       6,959
00067.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            135.052                 29                      497,338         2,799
00070.M2TS      4113 (0x1011)   0x1B            AVC                                     112.362                 37,963                  533,196,914     2,899,416
00070.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           112.362                 4,098                   57,563,668      330,343
00070.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            112.362                 448                     6,297,088       35,140
00070.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           112.362                 61                      861,555         4,867
00070.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           112.362                 54                      762,770         4,317
00070.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        112.362                 51                      709,542         4,024
00070.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            112.362                 4                       53,267          303
00073.M2TS      4113 (0x1011)   0x1B            AVC                                     383.008                 37,844                  1,811,811,686   9,852,194
00073.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           383.008                 3,933                   188,314,984     1,082,886
00073.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            383.008                 448                     21,455,616      119,730
00073.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           383.008                 75                      3,569,427       20,165
00073.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           383.008                 62                      2,964,397       16,859
00073.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        383.008                 62                      2,957,076       16,827
00073.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            383.008                 0                       70              7
00077.M2TS      4113 (0x1011)   0x1B            AVC                                     279.196                 15,405                  537,615,259     2,927,255
00077.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           279.196                 4,092                   142,795,356     819,472
00077.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            279.196                 448                     15,642,368      87,290
00077.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           279.196                 78                      2,709,234       15,238
00077.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           279.196                 8                       264,642         1,500
00077.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        279.196                 7                       251,630         1,429
00077.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            279.196                 0                       70              7
Unrated graph:
LG 65C6P | Onkyo TX-NR646 5.1.2 | Polk Audio Monitor70 Series II Floorstanding Fronts | CS2 Series Center | Monitor40 Series II Bookshelf Rears | Onkyo SKH-410 | eD A2-300
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D
Collection: Blu-ray
Patsfan123 is offline
Old 07-29-2009, 08:02 PM - Thread Starter
Cinema Squid's Avatar
[US] Final Fantasy VII: Advent Children (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8)
Studio: Sony
Release Date: 2009-06-02
UPC: 043396225916
Aspect Ratio: 1.78:1
Subs: English (SDH), Arabic, Chinese (Simplified), Chinese (Traditional), Dutch, English, French, Korean, Portuguese, Spanish, Thai
This appears to be a different encode from the JP edition in the catchup titles list. I don't know what's up with the multiple angles for the last eleven minutes - as far as I can tell they look to be the same content (English end credits sequence) encoded three different times and I didn't see anything in the menus to "activate" them so to speak.
Code:
        Total   Video
Final Fantasy VII: Advent Children                              AVC     2:06:33 32,433,213,696  48,284,272,773  34.17   20.14   Dolby TrueHD 5.1 1821Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Title:     VOLUME_ID
Disc Size:      48,284,272,773 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:06:33 (h:m:s)
Total Bitrate:          34.17 Mbps
Size (w/ Angles):       37,667,305,728 (h:m:s)
Length (w/ Angles):     2:29:13 (h:m:s)
Bitrate (w/ Angles):    33.65 (h:m:s)
Description:
VIDEO:
MPEG-4 AVC Video        20145 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video (1)    1682 (18781) kbps   1080p / 23.976 fps / 16:9 / High Profile 4.1
MPEG-4 AVC Video (2)    1680 (18762) kbps   1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1821 kbps       5.1 / 48 kHz / 1821 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby TrueHD Audio              French          1869 kbps       5.1 / 48 kHz / 1869 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
Dolby TrueHD Audio              Japanese        3612 kbps       5.1 / 48 kHz / 3612 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
SUBTITLES:
Presentation Graphics           English         14.280 kbps
Presentation Graphics           English         12.081 kbps
Presentation Graphics           English         14.286 kbps
Presentation Graphics           Arabic          7.687 kbps
Presentation Graphics           Chinese         13.693 kbps
Presentation Graphics           Chinese         14.306 kbps
Presentation Graphics           Dutch           13.950 kbps
Presentation Graphics           French          14.152 kbps
Presentation Graphics           Korean          10.414 kbps
Presentation Graphics           Portuguese      14.155 kbps
Presentation Graphics           Spanish         14.214 kbps
Presentation Graphics           Thai            14.288 kbps
FILES:
00217.M2TS      0:00:00.000     1:55:13.406     29,804,583,168  34,489
00218.M2TS      1:55:13.406     0:11:20.179     2,628,630,528   30,917
00219.M2TS (1)  1:55:13.406     0:11:20.179     2,617,884,672   30,791
00220.M2TS (2)  1:55:13.406     0:11:20.179     2,616,207,360   30,771
CHAPTERS:
1               0:00:00.000     0:01:29.714     19,934 kbps     49,909 kbps     00:00:16.433    31,885 kbps     00:00:16.433    30,833 kbps     00:00:16.433    103,877 bytes   750,063 bytes   00:01:20.622
2               0:01:29.714     0:01:21.581     19,095 kbps     40,709 kbps     00:02:39.450    30,637 kbps     00:02:39.450    30,092 kbps     00:02:39.450    99,552 bytes    715,533 bytes   00:02:39.492
3               0:02:51.296     0:01:36.179     28,494 kbps     38,517 kbps     00:02:58.344    31,063 kbps     00:04:14.212    29,940 kbps     00:04:09.207    148,553 bytes   400,782 bytes   00:04:27.475
4               0:04:27.475     0:02:45.081     23,784 kbps     47,426 kbps     00:04:29.102    32,105 kbps     00:04:29.185    30,952 kbps     00:04:29.102    124,000 bytes   624,938 bytes   00:07:12.557
5               0:07:12.557     0:03:05.310     20,218 kbps     38,229 kbps     00:09:23.187    26,169 kbps     00:07:31.909    23,975 kbps     00:07:28.322    105,405 bytes   656,507 bytes   00:07:36.831
6               0:10:17.867     0:02:16.803     19,531 kbps     26,230 kbps     00:11:02.244    21,721 kbps     00:10:22.413    20,474 kbps     00:11:44.036    101,859 bytes   445,258 bytes   00:10:29.962
7               0:12:34.670     0:02:33.528     20,045 kbps     29,958 kbps     00:13:54.416    22,423 kbps     00:13:50.412    21,073 kbps     00:14:05.219    104,505 bytes   506,176 bytes   00:13:55.376
8               0:15:08.198     0:06:23.257     20,031 kbps     41,977 kbps     00:19:45.726    31,482 kbps     00:19:41.889    29,893 kbps     00:19:40.137    104,432 bytes   659,334 bytes   00:19:21.952
9               0:21:31.456     0:01:48.566     19,771 kbps     28,910 kbps     00:21:48.432    22,464 kbps     00:21:37.504    21,160 kbps     00:21:39.423    103,077 bytes   433,969 bytes   00:23:20.023
10              0:23:20.023     0:01:30.340     17,508 kbps     30,386 kbps     00:24:24.963    21,040 kbps     00:24:21.501    19,902 kbps     00:24:17.289    91,277 bytes    635,504 bytes   00:24:50.322
11              0:24:50.363     0:04:25.139     20,792 kbps     47,060 kbps     00:26:44.269    29,295 kbps     00:25:48.046    24,866 kbps     00:25:48.004    108,399 bytes   750,218 bytes   00:26:54.487
12              0:29:15.503     0:04:45.368     20,322 kbps     36,997 kbps     00:31:27.468    26,199 kbps     00:31:23.548    24,717 kbps     00:31:25.425    105,949 bytes   549,767 bytes   00:32:00.752
13              0:34:00.872     0:04:14.754     20,946 kbps     35,469 kbps     00:37:22.990    25,632 kbps     00:35:34.298    24,765 kbps     00:35:27.583    109,201 bytes   470,098 bytes   00:37:23.074
14              0:38:15.626     0:01:22.749     17,765 kbps     25,061 kbps     00:38:44.071    20,567 kbps     00:38:32.476    19,607 kbps     00:38:57.001    92,621 bytes    449,330 bytes   00:38:34.145
15              0:39:38.376     0:02:34.445     18,695 kbps     48,874 kbps     00:40:36.809    31,466 kbps     00:40:33.305    26,456 kbps     00:40:28.342    97,468 bytes    490,024 bytes   00:40:37.643
16              0:42:12.821     0:01:13.782     21,143 kbps     43,878 kbps     00:42:51.986    30,548 kbps     00:42:49.984    26,057 kbps     00:42:49.984    110,230 bytes   537,360 bytes   00:42:52.611
17              0:43:26.604     0:01:24.292     21,344 kbps     46,931 kbps     00:43:27.146    31,161 kbps     00:44:42.805    29,419 kbps     00:44:35.964    111,277 bytes   534,257 bytes   00:44:00.804
18              0:44:50.896     0:01:39.557     15,107 kbps     41,739 kbps     00:44:51.188    22,049 kbps     00:45:10.165    18,878 kbps     00:45:11.875    78,759 bytes    469,113 bytes   00:44:51.730
19              0:46:30.454     0:02:44.914     19,696 kbps     36,523 kbps     00:49:13.116    27,431 kbps     00:49:10.364    23,947 kbps     00:47:37.187    102,684 bytes   565,877 bytes   00:49:13.241
20              0:49:15.369     0:01:03.897     18,175 kbps     37,741 kbps     00:49:23.710    28,260 kbps     00:49:23.210    26,091 kbps     00:49:21.541    94,759 bytes    513,037 bytes   00:49:24.127
21              0:50:19.266     0:03:22.285     24,009 kbps     42,342 kbps     00:52:15.006    32,324 kbps     00:52:40.657    31,154 kbps     00:52:06.915    125,174 bytes   505,048 bytes   00:53:41.551
22              0:53:41.551     0:04:26.933     18,506 kbps     33,044 kbps     00:55:18.231    29,057 kbps     00:58:00.685    24,964 kbps     00:57:56.723    96,481 bytes    515,019 bytes   00:54:02.989
23              0:58:08.485     0:01:16.159     25,681 kbps     47,977 kbps     00:58:09.152    32,379 kbps     00:58:09.235    31,149 kbps     00:58:09.235    133,886 bytes   439,310 bytes   00:58:18.453
24              0:59:24.644     0:02:26.604     22,324 kbps     34,084 kbps     01:00:05.518    29,372 kbps     01:00:04.017    26,262 kbps     01:00:03.558    116,386 bytes   502,939 bytes   00:59:35.196
25              1:01:51.249     0:01:41.267     18,643 kbps     26,384 kbps     01:02:12.103    23,814 kbps     01:02:09.726    22,322 kbps     01:02:05.346    97,195 bytes    482,582 bytes   01:02:13.104
26              1:03:32.517     0:02:20.974     19,242 kbps     27,680 kbps     01:04:08.010    22,259 kbps     01:04:01.462    21,386 kbps     01:04:01.712    100,321 bytes   421,466 bytes   01:04:08.845
27              1:05:53.491     0:03:04.475     21,165 kbps     36,627 kbps     01:06:46.168    31,715 kbps     01:06:42.081    30,145 kbps     01:06:37.284    110,346 bytes   489,231 bytes   01:06:49.547
28              1:08:57.967     0:02:15.802     19,291 kbps     26,585 kbps     01:09:24.702    22,832 kbps     01:09:20.698    22,020 kbps     01:09:15.776    100,575 bytes   372,490 bytes   01:09:07.101
29              1:11:13.769     0:02:04.791     20,378 kbps     32,362 kbps     01:12:13.996    23,955 kbps     01:12:13.996    23,048 kbps     01:12:17.499    106,240 bytes   340,417 bytes   01:13:18.560
30              1:13:18.560     0:03:06.144     18,916 kbps     33,696 kbps     01:16:22.119    28,906 kbps     01:13:39.415    25,640 kbps     01:13:37.412    98,621 bytes    530,907 bytes   01:15:40.118
31              1:16:24.705     0:02:47.000     21,903 kbps     40,835 kbps     01:17:53.752    29,160 kbps     01:17:54.127    27,237 kbps     01:17:52.167    114,192 bytes   475,734 bytes   01:19:00.819
32              1:19:11.705     0:00:27.485     20,287 kbps     43,570 kbps     01:19:37.481    27,912 kbps     01:19:33.810    23,285 kbps     01:19:28.680    105,767 bytes   548,828 bytes   01:19:23.216
33              1:19:39.191     0:02:16.594     19,147 kbps     35,000 kbps     01:21:31.636    25,524 kbps     01:20:47.384    24,112 kbps     01:21:36.349    99,825 bytes    437,646 bytes   01:21:32.012
34              1:21:55.785     0:01:01.603     19,796 kbps     36,482 kbps     01:22:05.378    26,589 kbps     01:22:05.378    24,070 kbps     01:22:01.917    103,209 bytes   469,291 bytes   01:22:05.420
35              1:22:57.389     0:07:01.295     20,382 kbps     38,462 kbps     01:25:10.021    31,913 kbps     01:25:10.021    28,842 kbps     01:25:07.685    106,264 bytes   619,191 bytes   01:28:55.872
36              1:29:58.684     0:02:18.638     19,707 kbps     40,302 kbps     01:31:34.697    29,190 kbps     01:31:32.445    27,465 kbps     01:31:32.195    102,743 bytes   476,739 bytes   01:31:25.897
37              1:32:17.323     0:03:13.484     19,065 kbps     37,799 kbps     01:33:32.815    26,351 kbps     01:33:32.773    23,905 kbps     01:33:32.690    99,397 bytes    539,600 bytes   01:33:32.857
38              1:35:30.808     0:07:56.976     19,702 kbps     39,806 kbps     01:37:42.857    27,128 kbps     01:38:28.944    25,571 kbps     01:42:27.850    102,718 bytes   690,751 bytes   01:36:22.401
39              1:43:27.784     0:01:36.513     21,431 kbps     44,596 kbps     01:44:08.325    29,537 kbps     01:44:04.988    27,442 kbps     01:44:03.820    111,732 bytes   394,783 bytes   01:44:11.203
40              1:45:04.298     0:04:03.284     20,747 kbps     29,471 kbps     01:45:05.924    24,682 kbps     01:45:04.298    23,378 kbps     01:46:02.814    108,166 bytes   471,811 bytes   01:48:59.032
41              1:49:07.582     0:01:10.028     20,710 kbps     28,904 kbps     01:49:09.751    23,501 kbps     01:49:59.801    22,262 kbps     01:49:54.754    107,972 bytes   574,344 bytes   01:50:12.897
42              1:50:17.611     0:01:16.159     16,383 kbps     30,714 kbps     01:51:23.802    23,593 kbps     01:51:23.802    22,890 kbps     01:51:23.760    85,415 bytes    444,828 bytes   01:51:28.765
43              1:51:33.770     0:03:40.136     20,170 kbps     32,255 kbps     01:51:49.703    25,646 kbps     01:51:49.369    24,733 kbps     01:51:46.908    105,176 bytes   607,840 bytes   01:54:55.179
44              1:55:13.906     0:05:28.328     14,853 kbps     52,911 kbps     01:59:18.776    22,553 kbps     01:59:16.107    21,243 kbps     01:59:11.769    77,435 bytes    457,988 bytes   01:58:35.024
45              2:00:42.234     0:05:51.350     22,711 kbps     46,450 kbps     02:05:24.433    29,090 kbps     02:00:42.902    27,559 kbps     02:00:42.818    118,431 bytes   665,656 bytes   02:02:11.782
STREAM DIAGNOSTICS:
00217.M2TS      4113 (0x1011)   0x1B            AVC                                     6913.323                20,268                  17,514,473,412  95,285,115
00217.M2TS      4352 (0x1100)   0x83            TrueHD          jpn (Japanese)          6913.323                4,329                   3,741,202,252   25,337,062
00217.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           6913.323                2,489                   2,151,054,807   17,136,970
00217.M2TS      4354 (0x1102)   0x83            TrueHD          fra (French)            6913.323                2,350                   2,031,127,020   16,371,866
00217.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6913.323                16                      13,512,684      78,238
00217.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           6913.323                13                      11,428,210      68,540
00217.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6913.323                16                      13,517,988      78,266
00217.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            6913.323                15                      13,366,860      77,444
00217.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           6913.323                16                      13,451,496      77,971
00217.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        6913.323                15                      13,388,821      77,612
00217.M2TS      4614 (0x1206)   0x90            PGS             ara (Arabic)            6913.323                8                       7,279,557       44,405
00217.M2TS      4615 (0x1207)   0x90            PGS             zho (Chinese)           6913.323                15                      12,960,178      75,289
00217.M2TS      4616 (0x1208)   0x90            PGS             zho (Chinese)           6913.323                16                      13,540,830      78,431
00217.M2TS      4617 (0x1209)   0x90            PGS             nld (Dutch)             6913.323                15                      13,205,772      76,546
00217.M2TS      4618 (0x120A)   0x90            PGS             kor (Korean)            6913.323                11                      9,847,782       58,388
00217.M2TS      4619 (0x120B)   0x90            PGS             tha (Thai)              6913.323                16                      13,502,549      78,250
00218.M2TS      4113 (0x1011)   0x1B            AVC                                     680.096                 18,903                  1,606,992,795   8,743,227
00218.M2TS      4352 (0x1100)   0x83            TrueHD          jpn (Japanese)          680.096                 3,469                   294,872,360     2,246,903
00218.M2TS      4353 (0x1101)   0x83            TrueHD          eng (English)           680.096                 2,172                   184,613,686     1,392,017
00218.M2TS      4354 (0x1102)   0x83            TrueHD          fra (French)            680.096                 1,977                   168,039,822     1,282,793
00218.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00218.M2TS      4609 (0x1201)   0x90            PGS             eng (English)           680.096                 0                       39,050          245
00218.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00218.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            680.096                 1                       65,812          390
00218.M2TS      4612 (0x1204)   0x90            PGS             spa (Spanish)           680.096                 0                       40,811          248
00218.M2TS      4613 (0x1205)   0x90            PGS             por (Portuguese)        680.096                 1                       46,991          283
00218.M2TS      4614 (0x1206)   0x90            PGS             ara (Arabic)            680.096                 0                       16,784          117
00218.M2TS      4615 (0x1207)   0x90            PGS             zho (Chinese)           680.096                 0                       36,982          228
00218.M2TS      4616 (0x1208)   0x90            PGS             zho (Chinese)           680.096                 0                       38,566          237
00218.M2TS      4617 (0x1209)   0x90            PGS             nld (Dutch)             680.096                 0                       35,552          221
00218.M2TS      4618 (0x120A)   0x90            PGS             kor (Korean)            680.096                 0                       36,915          227
00218.M2TS      4619 (0x120B)   0x90            PGS             tha (Thai)              680.096                 1                       59,474          350
00219.M2TS (1)  4113 (0x1011)   0x1B            AVC                                     680.096                 18,782                  1,596,705,580   8,687,262
00219.M2TS (1)  4352 (0x1100)   0x83            TrueHD          jpn (Japanese)          680.096                 3,469                   294,872,360     2,246,903
00219.M2TS (1)  4353 (0x1101)   0x83            TrueHD          eng (English)           680.096                 2,172                   184,613,686     1,392,017
00219.M2TS (1)  4354 (0x1102)   0x83            TrueHD          fra (French)            680.096                 1,977                   168,039,822     1,282,793
00219.M2TS (1)  4608 (0x1200)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00219.M2TS (1)  4609 (0x1201)   0x90            PGS             eng (English)           680.096                 0                       39,050          245
00219.M2TS (1)  4610 (0x1202)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00219.M2TS (1)  4611 (0x1203)   0x90            PGS             fra (French)            680.096                 1                       65,812          390
00219.M2TS (1)  4612 (0x1204)   0x90            PGS             spa (Spanish)           680.096                 0                       40,811          248
00219.M2TS (1)  4613 (0x1205)   0x90            PGS             por (Portuguese)        680.096                 1                       46,991          283
00219.M2TS (1)  4614 (0x1206)   0x90            PGS             ara (Arabic)            680.096                 0                       16,784          117
00219.M2TS (1)  4615 (0x1207)   0x90            PGS             zho (Chinese)           680.096                 0                       36,982          228
00219.M2TS (1)  4616 (0x1208)   0x90            PGS             zho (Chinese)           680.096                 0                       38,566          237
00219.M2TS (1)  4617 (0x1209)   0x90            PGS             nld (Dutch)             680.096                 0                       35,552          221
00219.M2TS (1)  4618 (0x120A)   0x90            PGS             kor (Korean)            680.096                 0                       36,915          227
00219.M2TS (1)  4619 (0x120B)   0x90            PGS             tha (Thai)              680.096                 1                       59,474          350
00220.M2TS (2)  4113 (0x1011)   0x1B            AVC                                     680.096                 18,763                  1,595,090,574   8,678,529
00220.M2TS (2)  4352 (0x1100)   0x83            TrueHD          jpn (Japanese)          680.096                 3,469                   294,872,360     2,246,903
00220.M2TS (2)  4353 (0x1101)   0x83            TrueHD          eng (English)           680.096                 2,172                   184,613,686     1,392,017
00220.M2TS (2)  4354 (0x1102)   0x83            TrueHD          fra (French)            680.096                 1,977                   168,039,822     1,282,793
00220.M2TS (2)  4608 (0x1200)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00220.M2TS (2)  4609 (0x1201)   0x90            PGS             eng (English)           680.096                 0                       39,050          245
00220.M2TS (2)  4610 (0x1202)   0x90            PGS             eng (English)           680.096                 0                       42,146          255
00220.M2TS (2)  4611 (0x1203)   0x90            PGS             fra (French)            680.096                 1                       65,812          390
00220.M2TS (2)  4612 (0x1204)   0x90            PGS             spa (Spanish)           680.096                 0                       40,811          248
00220.M2TS (2)  4613 (0x1205)   0x90            PGS             por (Portuguese)        680.096                 1                       46,991          283
00220.M2TS (2)  4614 (0x1206)   0x90            PGS             ara (Arabic)            680.096                 0                       16,784          117
00220.M2TS (2)  4615 (0x1207)   0x90            PGS             zho (Chinese)           680.096                 0                       36,982          228
00220.M2TS (2)  4616 (0x1208)   0x90            PGS             zho (Chinese)           680.096                 0                       38,566          237
00220.M2TS (2)  4617 (0x1209)   0x90            PGS             nld (Dutch)             680.096                 0                       35,552          221
00220.M2TS (2)  4618 (0x120A)   0x90            PGS             kor (Korean)            680.096                 0                       36,915          227
00220.M2TS (2)  4619 (0x120B)   0x90            PGS             tha (Thai)              680.096                 1                       59,474          350
Old 07-29-2009, 08:09 PM - Thread Starter
[US] 12 Rounds (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8)
Studio: Fox
Release Date: 2009-06-30
UPC: 024543589013
Aspect Ratio: 2.40:1
Subs: English (SDH), Chinese (Cantonese), Chinese (Traditional), French (Text), Korean, Portuguese, Spanish
The two DD 2.0 tracks are commentaries and are only accessible from the Unrated cut.
Code:
        Total   Video
12 Rounds: Unrated                                              AVC     1:49:39 27,758,923,776  41,115,140,365  33.75   25.63   DTS-HD Master 5.1 4179Kbps (48kHz/24-bit)
           Theatrical                                           AVC     1:47:56 27,330,969,600  41,115,140,365  33.76   25.63   DTS-HD Master 5.1 4175Kbps (48kHz/24-bit)
Unrated
Code:
DISC INFO:
Disc Title:     TWELVE_ROUNDS
Disc Size:      41,115,140,365 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:49:39 (h:m:s)
Total Bitrate:          33.75 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25627 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4179 kbps       5.1 / 48 kHz / 4179 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Portuguese      448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         57.948 kbps
Presentation Graphics           Chinese         64.390 kbps
Presentation Graphics           Chinese         65.485 kbps
Presentation Graphics           French          1.184 kbps
Presentation Graphics           Korean          49.159 kbps
Presentation Graphics           Portuguese      43.204 kbps
Presentation Graphics           Spanish         49.646 kbps
FILES:
00328.M2TS      0:00:00.000     0:11:53.796     3,019,517,952   33,842
00343.M2TS      0:11:53.796     0:01:19.162     335,155,200     33,870
00330.M2TS      0:13:12.958     0:05:32.498     1,392,936,960   33,514
00344.M2TS      0:18:45.457     0:03:41.721     929,132,544     33,524
00331.M2TS      0:22:27.179     0:02:33.486     634,570,752     33,075
00345.M2TS      0:25:00.665     0:00:30.655     125,730,816     32,811
00334.M2TS      0:25:31.321     0:22:26.595     5,685,645,312   33,778
00346.M2TS      0:47:57.916     0:02:37.282     665,499,648     33,850
00336.M2TS      0:50:35.198     0:19:17.406     4,879,982,592   33,730
00347.M2TS      1:09:52.604     0:00:55.346     235,014,144     33,970
00337.M2TS      1:10:47.951     0:15:07.865     3,853,080,576   33,953
00348.M2TS      1:25:55.817     0:01:36.096     401,891,328     33,457
00340.M2TS      1:27:31.913     0:14:37.877     3,718,692,864   33,888
00349.M2TS      1:42:09.790     0:02:07.627     548,665,344     34,392
00342.M2TS      1:44:17.417     0:05:21.904     1,333,407,744   33,138
CHAPTERS:
1               0:00:00.000     0:02:44.581     25,176 kbps     51,919 kbps     00:00:44.419    31,100 kbps     00:01:48.483    28,988 kbps     00:01:41.017    131,224 bytes   743,587 bytes   00:01:33.259
2               0:02:44.581     0:01:43.686     25,978 kbps     34,032 kbps     00:02:57.093    28,882 kbps     00:03:25.705    27,963 kbps     00:03:20.366    135,435 bytes   489,505 bytes   00:02:49.586
3               0:04:28.267     0:03:07.854     25,625 kbps     36,424 kbps     00:06:43.778    28,545 kbps     00:05:50.099    27,685 kbps     00:05:49.474    133,597 bytes   474,090 bytes   00:05:18.401
4               0:07:36.122     0:04:20.927     25,802 kbps     36,556 kbps     00:09:06.963    31,024 kbps     00:09:21.185    29,606 kbps     00:09:18.724    134,522 bytes   718,505 bytes   00:09:35.199
5               0:11:57.049     0:02:29.065     24,614 kbps     36,616 kbps     00:12:40.134    32,826 kbps     00:12:36.172    31,733 kbps     00:12:31.917    128,324 bytes   549,072 bytes   00:14:11.225
6               0:14:26.115     0:03:07.687     26,022 kbps     46,505 kbps     00:15:58.457    32,806 kbps     00:15:46.612    31,691 kbps     00:17:13.532    135,669 bytes   519,224 bytes   00:16:26.276
7               0:17:33.802     0:02:52.797     25,245 kbps     41,993 kbps     00:17:48.609    31,584 kbps     00:17:45.731    29,392 kbps     00:17:44.855    131,615 bytes   557,493 bytes   00:20:06.788
8               0:20:26.600     0:01:58.743     26,229 kbps     39,860 kbps     00:22:02.738    34,650 kbps     00:21:27.077    32,666 kbps     00:21:28.662    136,746 bytes   521,887 bytes   00:22:17.753
9               0:22:25.343     0:01:45.980     24,294 kbps     36,607 kbps     00:23:07.928    29,103 kbps     00:23:04.341    28,089 kbps     00:22:59.336    126,658 bytes   425,989 bytes   00:23:07.969
10              0:24:11.324     0:02:32.026     24,696 kbps     34,495 kbps     00:24:58.330    30,586 kbps     00:24:56.953    29,368 kbps     00:24:41.855    128,751 bytes   452,201 bytes   00:24:58.455
11              0:26:43.351     0:01:57.242     25,431 kbps     37,965 kbps     00:28:17.237    32,246 kbps     00:27:55.590    31,129 kbps     00:28:16.986    132,588 bytes   533,155 bytes   00:28:17.278
12              0:28:40.593     0:05:12.895     26,827 kbps     44,329 kbps     00:31:58.291    33,380 kbps     00:28:51.146    31,979 kbps     00:28:51.980    139,864 bytes   549,784 bytes   00:32:29.197
13              0:33:53.489     0:01:06.024     23,183 kbps     32,030 kbps     00:34:05.877    26,925 kbps     00:34:36.365    26,071 kbps     00:34:34.864    120,867 bytes   425,588 bytes   00:34:11.674
14              0:34:59.514     0:03:24.162     26,997 kbps     41,389 kbps     00:37:15.232    33,733 kbps     00:37:45.930    31,823 kbps     00:35:22.119    140,750 bytes   576,228 bytes   00:35:20.076
15              0:38:23.676     0:05:57.440     24,830 kbps     48,010 kbps     00:41:26.025    34,927 kbps     00:38:53.205    32,446 kbps     00:41:55.763    129,453 bytes   597,076 bytes   00:38:36.355
16              0:44:21.116     0:06:33.684     26,070 kbps     45,893 kbps     00:46:09.766    33,603 kbps     00:46:06.805    30,374 kbps     00:46:01.008    135,917 bytes   582,782 bytes   00:46:10.601
17              0:50:54.801     0:05:10.601     25,888 kbps     38,087 kbps     00:51:19.784    32,118 kbps     00:51:38.929    30,587 kbps     00:51:38.887    134,967 bytes   538,474 bytes   00:51:11.860
18              0:56:05.403     0:04:25.348     25,452 kbps     39,310 kbps     00:57:05.255    34,397 kbps     00:57:05.255    31,293 kbps     00:57:04.420    132,695 bytes   607,189 bytes   00:57:42.417
19              1:00:30.752     0:02:58.011     25,323 kbps     39,216 kbps     01:02:27.368    29,660 kbps     01:02:47.763    27,568 kbps     01:02:47.763    132,023 bytes   502,274 bytes   01:01:59.006
20              1:03:28.763     0:02:59.345     26,498 kbps     43,605 kbps     01:05:25.755    36,203 kbps     01:05:36.599    33,325 kbps     01:05:37.016    138,149 bytes   583,382 bytes   01:05:39.101
21              1:06:28.109     0:07:36.497     26,271 kbps     47,636 kbps     01:13:47.839    34,559 kbps     01:13:50.801    33,793 kbps     01:13:46.004    136,966 bytes   573,318 bytes   01:09:47.516
22              1:14:04.606     0:01:33.426     24,987 kbps     34,945 kbps     01:15:20.974    29,618 kbps     01:14:52.863    28,127 kbps     01:14:47.733    130,270 bytes   463,505 bytes   01:14:09.903
23              1:15:38.033     0:01:24.793     26,352 kbps     44,310 kbps     01:16:44.015    32,857 kbps     01:16:26.623    30,546 kbps     01:16:26.373    137,386 bytes   529,807 bytes   01:16:43.348
24              1:17:02.826     0:08:22.752     25,038 kbps     47,224 kbps     01:18:35.961    35,321 kbps     01:18:32.165    33,003 kbps     01:18:26.993    130,537 bytes   623,476 bytes   01:24:27.729
25              1:25:25.578     0:03:47.352     25,160 kbps     47,197 kbps     01:26:52.373    34,287 kbps     01:26:48.619    31,307 kbps     01:26:48.494    131,175 bytes   663,043 bytes   01:26:52.915
26              1:29:12.930     0:01:53.780     25,618 kbps     48,340 kbps     01:30:44.355    33,014 kbps     01:30:43.688    29,822 kbps     01:30:38.516    133,558 bytes   500,460 bytes   01:30:44.397
27              1:31:06.711     0:04:25.056     25,631 kbps     46,728 kbps     01:34:38.631    32,310 kbps     01:34:34.585    30,358 kbps     01:34:30.080    133,630 bytes   544,670 bytes   01:34:38.881
28              1:35:31.767     0:01:26.169     26,986 kbps     42,273 kbps     01:35:41.360    33,695 kbps     01:35:41.235    29,974 kbps     01:35:56.834    140,693 bytes   604,825 bytes   01:35:49.702
29              1:36:57.937     0:03:08.271     26,014 kbps     42,195 kbps     01:38:08.716    33,796 kbps     01:37:56.704    32,569 kbps     01:37:56.120    135,624 bytes   522,756 bytes   01:37:49.822
30              1:40:06.208     0:02:38.867     24,974 kbps     41,297 kbps     01:42:17.714    30,323 kbps     01:42:15.420    29,292 kbps     01:42:09.748    130,205 bytes   496,688 bytes   01:42:18.382
31              1:42:45.075     0:02:47.375     25,495 kbps     48,746 kbps     01:43:33.790    32,608 kbps     01:44:06.490    29,748 kbps     01:43:33.790    132,919 bytes   442,818 bytes   01:45:32.451
32              1:45:32.451     0:04:06.871     25,178 kbps     39,231 kbps     01:46:04.900    29,274 kbps     01:46:04.774    27,801 kbps     01:46:04.774    131,291 bytes   549,056 bytes   01:46:22.584
STREAM DIAGNOSTICS:
00328.M2TS      4113 (0x1011)   0x1B            AVC                                     713.713                 25,624                  2,285,981,158   12,433,840
00328.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           713.713                 4,163                   371,416,920     2,129,919
00328.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            713.713                 448                     39,974,144      223,070
00328.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           713.713                 448                     39,974,144      223,070
00328.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        713.713                 448                     39,974,144      223,070
00328.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           713.713                 224                     19,987,072      111,535
00328.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           713.713                 224                     19,987,072      111,535
00328.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           713.713                 71                      6,296,236       35,424
00328.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           713.713                 64                      5,752,790       32,406
00328.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        713.713                 58                      5,170,496       29,253
00328.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           713.713                 85                      7,574,253       42,459
00328.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            713.713                 67                      5,965,771       33,671
00328.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           713.713                 88                      7,815,076       43,760
00328.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            713.713                 3                       286,547         1,619
00343.M2TS      4113 (0x1011)   0x1B            AVC                                     79.079                  25,868                  255,706,532     1,390,840
00343.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           79.079                  4,040                   39,931,260      229,354
00343.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            79.079                  449                     4,433,408       24,740
00343.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           79.079                  449                     4,433,408       24,740
00343.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        79.079                  449                     4,433,408       24,740
00343.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           79.079                  224                     2,216,704       12,370
00343.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           79.079                  224                     2,216,704       12,370
00343.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           79.079                  68                      674,897         3,786
00343.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           79.079                  53                      527,935         2,972
00343.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        79.079                  49                      483,960         2,725
00343.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           79.079                  76                      751,554         4,190
00343.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            79.079                  48                      474,723         2,679
00343.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           79.079                  78                      775,426         4,317
00343.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            79.079                  0                       70              7
00330.M2TS      4113 (0x1011)   0x1B            AVC                                     332.415                 25,530                  1,060,817,468   5,770,051
00330.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           332.415                 4,111                   170,835,768     980,220
00330.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            332.415                 448                     18,620,672      103,910
00330.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           332.415                 448                     18,620,672      103,910
00330.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        332.415                 448                     18,620,672      103,910
00330.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           332.415                 224                     9,310,336       51,955
00330.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           332.415                 224                     9,310,336       51,955
00330.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           332.415                 47                      1,960,993       11,092
00330.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           332.415                 42                      1,765,367       9,988
00330.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        332.415                 36                      1,477,788       8,415
00330.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           332.415                 52                      2,166,265       12,207
00330.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            332.415                 42                      1,757,605       9,974
00330.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           332.415                 55                      2,292,795       12,898
00330.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            332.415                 1                       31,284          177
00344.M2TS      4113 (0x1011)   0x1B            AVC                                     221.638                 25,382                  703,189,905     3,824,789
00344.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           221.638                 4,444                   123,108,316     703,584
00344.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            221.638                 448                     12,416,768      69,290
00344.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           221.638                 448                     12,416,768      69,290
00344.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        221.638                 448                     12,416,768      69,290
00344.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           221.638                 224                     6,208,384       34,645
00344.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           221.638                 224                     6,208,384       34,645
00344.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           221.638                 22                      607,096         3,502
00344.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           221.638                 16                      439,759         2,544
00344.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        221.638                 13                      358,733         2,102
00344.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           221.638                 21                      570,237         3,264
00344.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            221.638                 16                      430,620         2,503
00344.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           221.638                 22                      603,933         3,450
00344.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            221.638                 1                       33,008          191
00331.M2TS      4113 (0x1011)   0x1B            AVC                                     153.362                 25,426                  487,416,972     2,651,143
00331.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           153.362                 3,591                   68,847,960      398,212
00331.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            153.362                 448                     8,596,224       47,970
00331.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           153.362                 448                     8,596,224       47,970
00331.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        153.362                 448                     8,596,224       47,970
00331.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           153.362                 224                     4,298,112       23,985
00331.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           153.362                 224                     4,298,112       23,985
00331.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           153.362                 90                      1,721,612       9,673
00331.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           153.362                 72                      1,380,655       7,756
00331.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        153.362                 64                      1,235,131       6,984
00331.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           153.362                 96                      1,831,298       10,251
00331.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            153.362                 68                      1,307,550       7,397
00331.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           153.362                 99                      1,888,637       10,560
00331.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            153.362                 0                       70              7
00345.M2TS      4113 (0x1011)   0x1B            AVC                                     30.572                  25,893                  98,950,151      538,189
00345.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30.572                  2,951                   11,275,540      66,035
00345.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            30.572                  449                     1,716,736       9,580
00345.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           30.572                  449                     1,716,736       9,580
00345.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        30.572                  449                     1,716,736       9,580
00345.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           30.572                  225                     858,368         4,790
00345.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           30.572                  225                     858,368         4,790
00345.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30.572                  78                      296,478         1,659
00345.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           30.572                  69                      262,048         1,472
00345.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        30.572                  66                      250,883         1,413
00345.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           30.572                  90                      344,211         1,932
00345.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            30.572                  68                      260,220         1,472
00345.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           30.572                  99                      377,114         2,110
00345.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            30.572                  0                       70              7
00334.M2TS      4113 (0x1011)   0x1B            AVC                                     1346.512                25,724                  4,329,643,073   23,549,676
00334.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1346.512                4,086                   687,707,144     3,947,574
00334.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1346.512                448                     75,410,944      420,820
00334.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           1346.512                448                     75,410,944      420,820
00334.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        1346.512                448                     75,410,944      420,820
00334.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           1346.512                224                     37,705,472      210,410
00334.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1346.512                224                     37,705,472      210,410
00334.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1346.512                63                      10,542,451      59,439
00334.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1346.512                52                      8,794,643       49,635
00334.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        1346.512                46                      7,818,315       44,362
00334.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           1346.512                69                      11,639,046      65,296
00334.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            1346.512                51                      8,571,991       48,559
00334.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           1346.512                70                      11,746,349      65,871
00334.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            1346.512                1                       174,742         983
00346.M2TS      4113 (0x1011)   0x1B            AVC                                     157.199                 25,436                  499,807,048     2,718,581
00346.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           157.199                 4,766                   93,644,756      533,485
00346.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            157.199                 448                     8,809,472       49,160
00346.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           157.199                 448                     8,809,472       49,160
00346.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        157.199                 448                     8,809,472       49,160
00346.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           157.199                 224                     4,404,736       24,580
00346.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           157.199                 224                     4,404,736       24,580
00346.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           157.199                 15                      297,917         1,707
00346.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           157.199                 8                       148,003         846
00346.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        157.199                 6                       114,946         659
00346.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           157.199                 8                       165,456         947
00346.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            157.199                 7                       140,434         809
00346.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           157.199                 8                       150,993         869
00346.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            157.199                 1                       23,128          133
00336.M2TS      4113 (0x1011)   0x1B            AVC                                     1157.323                25,709                  3,719,175,639   20,229,299
00336.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1157.323                4,036                   583,888,864     3,354,061
00336.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            1157.323                448                     64,814,848      361,690
00336.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           1157.323                448                     64,814,848      361,690
00336.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        1157.323                448                     64,814,848      361,690
00336.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           1157.323                224                     32,407,424      180,845
00336.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           1157.323                224                     32,407,424      180,845
00336.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1157.323                62                      8,949,273       50,403
00336.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1157.323                57                      8,303,847       46,731
00336.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        1157.323                49                      7,020,650       39,754
00336.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           1157.323                72                      10,482,973      58,716
00336.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            1157.323                56                      8,137,634       45,908
00336.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           1157.323                74                      10,661,915      59,683
00336.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            1157.323                1                       167,646         978
00347.M2TS      4113 (0x1011)   0x1B            AVC                                     55.264                  25,854                  178,600,810     971,440
00347.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           55.264                  4,074                   28,142,248      161,563
00347.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            55.264                  449                     3,100,160       17,300
00347.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           55.264                  449                     3,100,160       17,300
00347.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        55.264                  449                     3,100,160       17,300
00347.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           55.264                  224                     1,550,080       8,650
00347.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           55.264                  224                     1,550,080       8,650
00347.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           55.264                  73                      504,708         2,859
00347.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           55.264                  67                      461,313         2,610
00347.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        55.264                  58                      398,761         2,261
00347.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           55.264                  91                      631,176         3,539
00347.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            55.264                  72                      494,915         2,797
00347.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           55.264                  96                      662,217         3,707
00347.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            55.264                  0                       70              7
00337.M2TS      4113 (0x1011)   0x1B            AVC                                     907.740                 25,657                  2,911,286,026   15,835,005
00337.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           907.740                 4,364                   495,180,432     2,832,864
00337.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            907.740                 448                     50,840,832      283,710
00337.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           907.740                 448                     50,840,832      283,710
00337.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        907.740                 448                     50,840,832      283,710
00337.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           907.740                 224                     25,420,416      141,855
00337.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           907.740                 224                     25,420,416      141,855
00337.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           907.740                 58                      6,606,244       37,227
00337.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           907.740                 47                      5,346,392       30,115
00337.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        907.740                 41                      4,602,186       26,081
00337.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           907.740                 59                      6,747,137       37,874
00337.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            907.740                 45                      5,124,707       29,025
00337.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           907.740                 61                      6,908,063       38,747
00337.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            907.740                 0                       42,945          247
00348.M2TS      4113 (0x1011)   0x1B            AVC                                     96.013                  25,637                  307,685,852     1,673,556
00348.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           96.013                  3,823                   45,880,812      264,336
00348.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            96.013                  448                     5,381,376       30,030
00348.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           96.013                  448                     5,381,376       30,030
00348.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        96.013                  448                     5,381,376       30,030
00348.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           96.013                  224                     2,690,688       15,015
00348.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           96.013                  224                     2,690,688       15,015
00348.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           96.013                  74                      891,562         5,043
00348.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           96.013                  64                      767,276         4,334
00348.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        96.013                  54                      650,556         3,700
00348.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           96.013                  79                      947,494         5,314
00348.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            96.013                  59                      713,789         4,042
00348.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           96.013                  80                      961,949         5,392
00348.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            96.013                  5                       58,664          332
00340.M2TS      4113 (0x1011)   0x1B            AVC                                     877.794                 25,617                  2,810,852,030   15,288,787
00340.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           877.794                 4,276                   469,173,552     2,686,550
00340.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            877.794                 448                     49,161,728      274,340
00340.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           877.794                 448                     49,161,728      274,340
00340.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        877.794                 448                     49,161,728      274,340
00340.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           877.794                 224                     24,580,864      137,170
00340.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           877.794                 224                     24,580,864      137,170
00340.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           877.794                 63                      6,941,209       39,097
00340.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           877.794                 57                      6,220,410       34,911
00340.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        877.794                 49                      5,345,253       30,178
00340.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           877.794                 75                      8,216,416       45,853
00340.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            877.794                 57                      6,295,918       35,364
00340.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           877.794                 74                      8,109,847       45,266
00340.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            877.794                 1                       155,098         891
00349.M2TS      4113 (0x1011)   0x1B            AVC                                     127.544                 25,670                  409,260,738     2,226,059
00349.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           127.544                 4,863                   77,529,128      441,176
00349.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            127.544                 448                     7,148,288       39,890
00349.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           127.544                 448                     7,148,288       39,890
00349.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        127.544                 448                     7,148,288       39,890
00349.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           127.544                 224                     3,574,144       19,945
00349.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           127.544                 224                     3,574,144       19,945
00349.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           127.544                 44                      703,586         4,023
00349.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           127.544                 35                      551,086         3,152
00349.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        127.544                 31                      491,963         2,831
00349.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           127.544                 45                      714,672         4,061
00349.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            127.544                 37                      593,552         3,398
00349.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           127.544                 45                      712,559         4,051
00349.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            127.544                 0                       70              7
00342.M2TS      4113 (0x1011)   0x1B            AVC                                     321.780                 25,293                  1,017,349,775   5,533,541
00342.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           321.780                 4,241                   170,594,540     977,358
00342.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            321.780                 448                     18,027,520      100,600
00342.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           321.780                 448                     18,027,520      100,600
00342.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        321.780                 448                     18,027,520      100,600
00342.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           321.780                 224                     9,013,760       50,300
00342.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           321.780                 224                     9,013,760       50,300
00342.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           321.780                 16                      663,111         3,811
00342.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           321.780                 3                       108,373         635
00342.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        321.780                 3                       111,972         656
00342.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           321.780                 4                       173,092         988
00342.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            321.780                 4                       159,467         913
00342.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           321.780                 5                       189,124         1,075
00342.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            321.780                 0                       70              7
Theatrical
Code:
DISC INFO:
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:47:56 (h:m:s)
Total Bitrate:          33.76 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        25635 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4175 kbps       5.1 / 48 kHz / 4175 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         58.391 kbps
Presentation Graphics           Chinese         65.005 kbps
Presentation Graphics           Chinese         66.086 kbps
Presentation Graphics           French          1.202 kbps
Presentation Graphics           Korean          49.612 kbps
Presentation Graphics           Portuguese      43.604 kbps
Presentation Graphics           Spanish         50.085 kbps
FILES:
00329.M2TS      0:11:53.796     0:01:18.411     332,507,136     33,924
00330.M2TS      0:13:12.208     0:05:32.498     1,392,936,960   33,514
00332.M2TS      0:18:44.706     0:02:59.429     752,670,720     33,558
00331.M2TS      0:21:44.136     0:02:33.486     634,570,752     33,075
00333.M2TS      0:24:17.622     0:00:30.655     126,818,304     33,095
00334.M2TS      0:24:48.278     0:22:26.595     5,685,645,312   33,778
00335.M2TS      0:47:14.873     0:02:12.048     560,836,608     33,978
00336.M2TS      0:49:26.922     0:19:17.406     4,879,982,592   33,730
00338.M2TS      1:08:44.328     0:00:34.743     147,959,808     34,070
00337.M2TS      1:09:19.071     0:15:07.865     3,853,080,576   33,953
00339.M2TS      1:24:26.936     0:01:33.009     390,266,880     33,568
00340.M2TS      1:25:59.946     0:14:37.877     3,718,692,864   33,888
00341.M2TS      1:40:37.823     0:01:56.741     502,075,392     34,406
00342.M2TS      1:42:34.564     0:05:21.904     1,333,407,744   33,138
CHAPTERS:
4               0:07:36.122     0:04:20.927     25,803 kbps     36,556 kbps     00:09:06.963    31,024 kbps     00:09:21.185    29,606 kbps     00:09:18.724    134,523 bytes   718,505 bytes   00:09:35.199
5               0:11:57.049     0:02:28.314     24,619 kbps     36,698 kbps     00:12:40.217    32,996 kbps     00:12:36.922    31,841 kbps     00:12:31.959    128,352 bytes   549,072 bytes   00:14:10.474
6               0:14:25.364     0:03:07.687     26,022 kbps     46,505 kbps     00:15:57.706    32,806 kbps     00:15:45.861    31,691 kbps     00:17:12.781    135,669 bytes   519,224 bytes   00:16:25.526
7               0:17:33.051     0:02:11.923     25,734 kbps     41,993 kbps     00:17:47.858    31,584 kbps     00:17:44.980    29,392 kbps     00:17:44.104    134,163 bytes   598,325 bytes   00:19:25.163
8               0:19:44.975     0:01:57.367     25,771 kbps     39,707 kbps     00:20:52.960    34,249 kbps     00:20:45.452    33,320 kbps     00:20:47.037    134,356 bytes   501,501 bytes   00:21:40.132
9               0:21:42.342     0:01:45.939     24,292 kbps     36,607 kbps     00:22:24.885    29,103 kbps     00:22:21.298    28,089 kbps     00:22:16.293    126,646 bytes   425,989 bytes   00:22:24.926
10              0:23:28.281     0:02:32.026     24,695 kbps     34,495 kbps     00:24:15.287    30,547 kbps     00:24:13.910    29,368 kbps     00:23:58.812    128,749 bytes   452,201 bytes   00:24:15.412
11              0:26:00.308     0:01:57.242     25,431 kbps     37,965 kbps     00:27:34.194    32,246 kbps     00:27:12.547    31,129 kbps     00:27:33.943    132,588 bytes   533,155 bytes   00:27:34.235
12              0:27:57.550     0:05:12.895     26,827 kbps     44,329 kbps     00:31:15.248    33,380 kbps     00:28:08.103    31,979 kbps     00:28:08.937    139,864 bytes   549,784 bytes   00:31:46.154
13              0:33:10.446     0:01:05.899     23,148 kbps     32,030 kbps     00:33:22.834    26,925 kbps     00:33:53.322    26,071 kbps     00:33:51.821    120,682 bytes   425,588 bytes   00:33:28.631
14              0:34:16.345     0:03:24.287     27,006 kbps     41,389 kbps     00:36:32.189    33,733 kbps     00:37:02.887    31,823 kbps     00:34:39.076    140,798 bytes   576,228 bytes   00:34:37.033
15              0:37:40.633     0:05:57.440     24,830 kbps     48,010 kbps     00:40:42.982    34,927 kbps     00:38:10.162    32,446 kbps     00:41:12.720    129,453 bytes   597,076 bytes   00:37:53.312
16              0:43:38.073     0:06:08.451     26,162 kbps     45,893 kbps     00:45:26.723    33,603 kbps     00:45:23.762    30,374 kbps     00:45:17.965    136,396 bytes   582,782 bytes   00:45:27.558
17              0:49:46.525     0:05:10.601     25,888 kbps     38,087 kbps     00:50:11.508    32,118 kbps     00:50:30.652    30,587 kbps     00:50:30.610    134,967 bytes   538,474 bytes   00:50:03.583
18              0:54:57.127     0:04:25.348     25,452 kbps     39,310 kbps     00:55:56.978    34,397 kbps     00:55:56.978    31,293 kbps     00:55:56.144    132,695 bytes   607,189 bytes   00:56:34.140
19              0:59:22.475     0:02:58.011     25,323 kbps     39,216 kbps     01:01:19.092    29,660 kbps     01:01:39.487    27,568 kbps     01:01:39.487    132,023 bytes   502,274 bytes   01:00:50.730
20              1:02:20.486     0:02:59.345     26,498 kbps     43,605 kbps     01:04:17.478    36,203 kbps     01:04:28.322    33,325 kbps     01:04:28.739    138,149 bytes   583,382 bytes   01:04:30.825
21              1:05:19.832     0:07:15.893     26,293 kbps     47,636 kbps     01:12:18.959    34,559 kbps     01:12:21.920    33,793 kbps     01:12:17.124    137,079 bytes   573,318 bytes   01:08:39.240
22              1:12:35.726     0:01:33.426     24,987 kbps     34,945 kbps     01:13:52.094    29,618 kbps     01:13:23.982    28,127 kbps     01:13:18.852    130,270 bytes   463,505 bytes   01:12:41.023
23              1:14:09.152     0:01:24.793     26,352 kbps     44,310 kbps     01:15:15.135    32,857 kbps     01:14:57.743    30,546 kbps     01:14:57.492    137,386 bytes   529,807 bytes   01:15:14.468
24              1:15:33.945     0:08:22.752     25,038 kbps     47,224 kbps     01:17:07.080    35,321 kbps     01:17:03.285    33,003 kbps     01:16:58.113    130,537 bytes   623,476 bytes   01:22:58.848
25              1:23:56.698     0:03:44.265     25,192 kbps     51,609 kbps     01:25:32.126    33,925 kbps     01:25:20.073    31,972 kbps     01:25:15.985    131,341 bytes   614,246 bytes   01:25:20.949
26              1:27:40.963     0:01:53.780     25,618 kbps     48,340 kbps     01:29:12.388    33,014 kbps     01:29:11.721    29,822 kbps     01:29:06.549    133,558 bytes   500,460 bytes   01:29:12.430
27              1:29:34.744     0:04:25.056     25,631 kbps     46,728 kbps     01:33:06.664    32,310 kbps     01:33:02.618    30,358 kbps     01:32:58.114    133,630 bytes   544,670 bytes   01:33:06.914
28              1:33:59.800     0:01:26.169     26,986 kbps     42,273 kbps     01:34:09.393    33,695 kbps     01:34:09.268    29,974 kbps     01:34:24.867    140,693 bytes   604,825 bytes   01:34:17.735
29              1:35:25.970     0:03:08.271     26,014 kbps     42,195 kbps     01:36:36.749    33,796 kbps     01:36:24.737    32,569 kbps     01:36:24.153    135,624 bytes   522,756 bytes   01:36:17.855
30              1:38:34.241     0:02:27.981     25,033 kbps     41,324 kbps     01:40:43.537    32,008 kbps     01:40:39.449    29,156 kbps     01:40:39.324    130,511 bytes   471,845 bytes   01:38:40.748
31              1:41:02.222     0:02:47.375     25,384 kbps     45,247 kbps     01:42:24.721    32,949 kbps     01:42:23.637    29,102 kbps     01:41:47.601    132,342 bytes   463,199 bytes   01:42:24.096
32              1:43:49.598     0:04:06.871     25,178 kbps     39,231 kbps     01:44:22.047    29,274 kbps     01:44:21.922    27,801 kbps     01:44:21.922    131,291 bytes   549,056 bytes   01:44:39.731
STREAM DIAGNOSTICS:
00329.M2TS      4113 (0x1011)   0x1B            AVC                                     78.328                  25,892                  253,505,269     1,378,839
00329.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           78.328                  4,065                   39,797,924      228,551
00329.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            78.328                  449                     4,392,192       24,510
00329.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           78.328                  449                     4,392,192       24,510
00329.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        78.328                  449                     4,392,192       24,510
00329.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           78.328                  224                     2,196,096       12,255
00329.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           78.328                  224                     2,196,096       12,255
00329.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           78.328                  69                      674,911         3,786
00329.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           78.328                  54                      527,935         2,972
00329.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        78.328                  49                      483,960         2,725
00329.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           78.328                  77                      751,554         4,190
00329.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            78.328                  48                      474,723         2,679
00329.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           78.328                  79                      775,426         4,317
00329.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            78.328                  0                       70              7
00332.M2TS      4113 (0x1011)   0x1B            AVC                                     179.346                 25,465                  570,877,790     3,105,128
00332.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           179.346                 4,389                   98,391,508      562,754
00332.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            179.346                 448                     10,049,536      56,080
00332.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           179.346                 448                     10,049,536      56,080
00332.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        179.346                 448                     10,049,536      56,080
00332.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           179.346                 224                     5,024,768       28,040
00332.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           179.346                 224                     5,024,768       28,040
00332.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           179.346                 23                      522,169         3,013
00332.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           179.346                 17                      381,407         2,206
00332.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        179.346                 13                      300,787         1,767
00332.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           179.346                 21                      471,352         2,707
00332.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            179.346                 17                      371,993         2,165
00332.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           179.346                 22                      492,818         2,826
00332.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            179.346                 1                       33,008          191
00333.M2TS      4113 (0x1011)   0x1B            AVC                                     30.572                  25,890                  98,940,385      538,150
00333.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           30.572                  3,225                   12,325,620      71,753
00333.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            30.572                  449                     1,716,736       9,580
00333.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           30.572                  449                     1,716,736       9,580
00333.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        30.572                  449                     1,716,736       9,580
00333.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           30.572                  225                     858,368         4,790
00333.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           30.572                  225                     858,368         4,790
00333.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           30.572                  78                      296,862         1,661
00333.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           30.572                  67                      257,557         1,448
00333.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        30.572                  66                      250,883         1,413
00333.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           30.572                  90                      344,211         1,932
00333.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            30.572                  68                      260,220         1,472
00333.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           30.572                  99                      377,114         2,110
00333.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            30.572                  0                       70              7
00335.M2TS      4113 (0x1011)   0x1B            AVC                                     131.965                 25,571                  421,806,822     2,294,336
00335.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           131.965                 4,747                   78,310,488      446,252
00335.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            131.965                 448                     7,395,584       41,270
00335.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           131.965                 448                     7,395,584       41,270
00335.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        131.965                 448                     7,395,584       41,270
00335.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           131.965                 224                     3,697,792       20,635
00335.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           131.965                 224                     3,697,792       20,635
00335.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           131.965                 16                      258,178         1,477
00335.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           131.965                 9                       148,003         846
00335.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        131.965                 7                       114,946         659
00335.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           131.965                 10                      165,456         947
00335.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            131.965                 9                       140,434         809
00335.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           131.965                 9                       150,993         869
00335.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            131.965                 1                       23,128          133
00338.M2TS      4113 (0x1011)   0x1B            AVC                                     34.660                  25,880                  112,122,159     609,859
00338.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           34.660                  4,150                   17,978,100      103,112
00338.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            34.660                  449                     1,946,112       10,860
00338.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           34.660                  449                     1,946,112       10,860
00338.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        34.660                  449                     1,946,112       10,860
00338.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           34.660                  225                     973,056         5,430
00338.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           34.660                  225                     973,056         5,430
00338.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           34.660                  76                      331,102         1,874
00338.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           34.660                  63                      274,476         1,553
00338.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        34.660                  58                      252,357         1,432
00338.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           34.660                  101                     435,834         2,443
00338.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            34.660                  74                      319,805         1,811
00338.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           34.660                  105                     456,918         2,556
00338.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            34.660                  0                       70              7
00339.M2TS      4113 (0x1011)   0x1B            AVC                                     92.926                  25,730                  298,874,084     1,625,616
00339.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           92.926                  3,839                   44,589,256      256,888
00339.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            92.926                  448                     5,209,344       29,070
00339.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           92.926                  448                     5,209,344       29,070
00339.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        92.926                  448                     5,209,344       29,070
00339.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           92.926                  224                     2,604,672       14,535
00339.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           92.926                  224                     2,604,672       14,535
00339.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           92.926                  74                      863,998         4,886
00339.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           92.926                  63                      733,902         4,146
00339.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        92.926                  54                      623,298         3,545
00339.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           92.926                  79                      912,158         5,115
00339.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            92.926                  59                      682,131         3,863
00339.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           92.926                  79                      923,123         5,174
00339.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            92.926                  5                       58,664          332
00341.M2TS      4113 (0x1011)   0x1B            AVC                                     116.658                 25,651                  374,047,766     2,034,537
00341.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           116.658                 4,878                   71,128,656      404,793
00341.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            116.658                 448                     6,539,008       36,490
00341.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           116.658                 448                     6,539,008       36,490
00341.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        116.658                 448                     6,539,008       36,490
00341.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           116.658                 224                     3,269,504       18,245
00341.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           116.658                 224                     3,269,504       18,245
00341.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           116.658                 44                      642,768         3,671
00341.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           116.658                 38                      551,086         3,152
00341.M2TS      4610 (0x1202)   0x90            PGS             por (Portuguese)        116.658                 34                      491,963         2,831
00341.M2TS      4611 (0x1203)   0x90            PGS             zho (Chinese)           116.658                 49                      714,672         4,061
00341.M2TS      4612 (0x1204)   0x90            PGS             kor (Korean)            116.658                 41                      593,552         3,398
00341.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           116.658                 49                      712,559         4,051
00341.M2TS      4614 (0x1206)   0x90            PGS             fra (French)            116.658                 0                       70              7
Cinema Squid is offline
Old 07-29-2009, 08:27 PM - Thread Starter
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [US] 1995   12 Monkeys                                                       VC-1    1080p24 1.85:1  28.66   2:09:34 38,565,728,256  42,457,295,442  39.69   DTS-MA  5.1    48/24  4192
 A  [US] 2009   12 Rounds: Unrated (seamless)                                    AVC     1080p24 2.40:1  25.63   1:49:39 27,758,923,776  41,115,140,365  33.75   DTS-MA  5.1    48/24  4179
                           Theatrical (seamless)                         AVC     1080p24 2.40:1  25.64   1:47:56 27,330,969,600                  33.76   DTS-MA  5.1    48/24  4175
ABC [UK] 1993   Bad Boy Bubby                                                   AVC     1080p24 2.35:1  30.06   1:53:51 32,717,998,080  34,378,029,372  38.32   DTS-MA  5.1    48/16  2043  / TrueHD  5.1    48/16  1382  / AC3     2.0    48     640
ABC [US] 1986   Big Trouble in Little China                                     AVC     1080p24 2.35:1  27.81   1:39:47 30,816,215,040  36,687,269,933  41.18   DTS-MA  5.1    48/24  3848  / DTS-MA  5.1    48/24  3699  / AC3     2.0    48     224
ABC [US] 1974   Black Christmas                                                  AVC     1080p24 1.85:1  15.00   1:37:49 12,241,815,552  23,730,255,348  16.69   AC3     5.1    48     448   / AC3     2.0    48     224
ABC [AU] 1999   The Bone Collector                                               AVC     1080p24 2.40:1  26.92   1:57:57 35,867,842,560  37,673,034,143  40.55   TrueHD  5.1    48/16  1429
 B  [FR] 1995   Casino                                                           AVC     1080p24 2.40:1  21.52   2:58:12 37,210,183,680  42,716,456,892  27.84   DTS-MA  5.1    48/16  2246
A C [US] 2009   Confessions of a Shopaholic                                      AVC     1080p24 2.40:1  23.71   1:44:13 26,274,349,056  31,892,935,410  33.62   DTS-MA  5.1    48/24  3600  / AC3     5.1    48     640
 B  [AU] 2003   Elf                                                              VC-1    1080p24 1.85:1  21.95   1:36:43 19,880,251,392  39,106,335,472  27.41   TrueHD  5.1    48/16  1512  / AC3     5.1    48     640
ABC [US] 2009   Fast and Furious                                         VC-1    1080p24 2.40:1  27.31   1:46:52 28,222,285,824  48,681,009,621  35.21   DTS-MA  5.1    48/24  4171
ABC [US] 2005   Final Fantasy VII: Advent Children                               AVC     1080p24 1.78:1  20.15   2:06:33 32,433,213,696  48,284,272,773  34.17   TrueHD  5.1    48/24  3612
ABC [US] 2008   Frost/Nixon                                                      VC-1    1080p24 2.35:1  24.94   2:01:57 31,655,497,728  42,240,681,075  34.61   DTS-MA  5.1    48/24  3237
ABC [AU] 1972   The Getaway                                                      VC-1    1080p24 2.35:1  16.02   2:02:49 17,265,420,288  22,114,740,816  18.74   AC3     1.0    48     192
    [JP] 2006   The Girl Who Leapt Through Time                                  AVC     1080p24 1.85:1  36.07   1:38:19 34,024,267,776  36,985,030,068  46.14   DTS-MA  5.1    48/16  1957  / TrueHD  5.1    48/16  1970  / LPCM    2.0    48/16  1536
ABC [AU] 2003   Gods and Generals                                                VC-1    1080p24 2.40:1  14.97   3:38:54 27,654,703,104  30,960,312,212  16.84   AC3     5.1    48     640
ABC [AU] 2007   Good Luck Chuck                                                  AVC     1080p24 1.85:1  32.00   1:41:18 32,505,452,544  46,685,200,717  42.78   TrueHD  5.1    48/16  1518
AB  [AU] 2002   Hart's War                                                       MPEG-2  1080p24 2.35:1  16.81   2:04:49 22,359,293,952  23,285,688,438  23.88   DTS-MA  5.1    48/24  3871
 A  [US] 2009   The Haunting in Connecticut: Unrated (seamless)                  AVC     1080p24 2.35:1  27.42   1:42:50 27,141,064,704  44,887,312,638  35.19   DTS-MA  7.1    48/24  4784
                                             Theatrical                          AVC     1080p24 2.35:1  27.42   1:42:29 27,041,906,688                  35.18   DTS-MA  7.1    48/24  4784
ABC [AU] 2008   How to Lose Friends and Alienate People                          AVC     1080p24 1.78:1  37.28   1:49:45 37,467,598,848  40,701,165,507  45.52   TrueHD  5.1    48/24  3553
ABC [US] 2005   Initial D                                                        AVC     1080p24 2.35:1  16.50   1:48:52 19,947,073,536  24,996,490,802  24.43   LPCM    5.1    48/16  4608  / AC3     5.1    48     640
ABC [AU] 2007   The Jane Austen Book Club                                        AVC     1080p24 1.78:1  26.06   1:45:37 26,738,380,800  30,580,515,521  33.76   TrueHD  5.1    48/16  1359
ABC [FR] 1976   King Kong                                                       VC-1    1080p24 2.35:1  20.12   2:14:28 28,180,180,992  32,023,212,418  27.94   DTS-MA  5.1    48/16  2204
    [US] 2008   Kit Kittredge: An American Girl                                  VC-1    1080p24 1.85:1  22.28   1:40:21 18,127,300,608  18,284,680,213  24.09   AC3     5.1    48     640
 B  [ES] 2000   Memento                                                          AVC     1080p24*2.35:1  24.97   1:53:21 25,342,961,664  28,506,152,048  29.81   LPCM    2.0    48/16  1536
    [US] 2009   Miss March: Unrated (seamless)                                   AVC     1080p24 1.85:1  36.76   1:33:33 30,455,783,424  40,106,589,218  43.41   DTS-MA  5.1    48/24  3819
                            Theatrical (seamless)                                AVC     1080p24 1.85:1  36.73   1:29:58 29,256,486,912                  43.36   DTS-MA  5.1    48/24  3812
ABC [US] 1992   My Cousin Vinny                                                 AVC     1080p24 1.85:1  18.99   1:59:18 22,811,022,199  22,811,022,199  25.49   DTS-MA  5.1    48/24  3540  / AC3     2.0    48     224
ABC [US] 1999   The Ninth Gate                                                  AVC     1080p24 2.35:1  34.82   2:13:14 41,907,210,240  43,139,241,001  41.94   DTS-MA  7.1    48/24  4766
ABC [AU] 1959   Rio Bravo                                                        VC-1    1080p24 1.85:1  19.62   2:21:03 22,718,208,000  27,224,120,216  21.48   AC3     1.0    48     192
 A  [US] 1989   Road House                                                       MPEG-2  1080p24 2.40:1  18.05   1:54:09 20,131,325,952  21,591,186,040  23.51   DTS-MA  5.1    48/24  3411  / AC3     2.0    48     224
 B  [AU] 2006   RV                                                               MPEG-2  1080p24 2.40:1  17.22   1:38:47 22,025,410,560  23,311,405,676  29.73   LPCM    5.1    48/16  4608  / AC3     5.1    48     448
 BC [AU] 1998   The Siege                                                        AVC     1080p24 2.35:1  34.12   1:56:05 38,327,445,504  41,957,622,852  44.02   DTS-MA  5.1    48/24  4312
ABC [US] 2009   The Soloist                                                     AVC     1080p24 2.35:1  30.54   1:57:02 33,866,065,920  42,833,088,536  38.58   TrueHD  5.1    48/24  3100
 A  [US] 2009   Street Fighter: The Legend of Chun-Li: Unrated (seamless)        AVC     1080p24 2.35:1  27.64   1:37:22 24,628,242,432  34,388,623,567  33.73   DTS-MA  5.1    48/24  3990
                                                       Theatrical (seamless)     AVC     1080p24 2.35:1  27.64   1:36:35 24,434,110,464                  33.73   DTS-MA  5.1    48/24  3995
    [US] 1993   Striking Distance                                                AVC     1080p24 1.85:1  26.90   1:41:44 30,286,669,824  33,040,254,828  39.69   TrueHD  5.1    48/20  2491
ABC [US] 2007   Sublime                                                          VC-1    1080p24 2.40:1  19.74   1:53:09 18,433,701,888  19,423,560,968  21.72   AC3     5.1    48     640
NOTE: I changed the format of the listings to use tabs instead of spaces to layout the columns. This shrunk the post sizes by over 20% which will be helpful. Hopefully this looks OK for everyone - seems to look fine in FF 3.5, IE 8 and Safari 4 on my computer at least.
Old 07-29-2009, 09:12 PM
msgohan's Avatar
Just gotta say, I never thought there would be a Region AC title.
Everything seems to be displaying fine in my good old Firefox 1.5, except - is it by design that the single-region titles have their code centered and the others are lined up by "column"?
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
