NEW Unofficial Blu-ray Audio and Video Specifications Thread - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #211 of 5099 Old 07-29-2009, 10:15 PM
Stephen Dawson's Avatar
Originally Posted by msgohan View Post
Just gotta say, I never thought there would be a Region AC title.
Everything seems to be displaying fine in my good old Firefox 1.5, except - is it by design that the single-region titles have their code centered and the others are lined up by "column"?
Looks fine as well on mine, using IE7. Region codes are formatted using spaces, so it all depends how they're typed.
Stephen Dawson
hifi-writer.com
Stephen Dawson is offline
post #212 of 5099 Old 07-29-2009, 11:26 PM - Thread Starter
Cinema Squid's Avatar
Good catch, I meant to have the region A on the left so that A, B, and C would be in their own little one character columns, like so:
Code:
A
 B
  C
AB
A C
 BC
ABC
I thought that would perhaps be slightly easier to visually scan.
Cinema Squid is offline
post #213 of 5099 Old 07-30-2009, 12:08 AM
I like seeing the region codes organised that way. Unusual ones tend to jump out at the eye.
Speaking of unusual ones: we now appear to have every combination of region code except one: Region C locked. I downloaded the .txt version of the list from the front page, but there appeared to be no 'C' only.
I wonder if we will ever see one.
Stephen Dawson
hifi-writer.com
post #214 of 5099 Old 07-30-2009, 06:24 AM
DigitalfreakNYC's Avatar
Quoted: 52 Post(s)
Any idea when the catch-up titles will be added?
"I have never seen it, but by all accounts it is terrible. However, I have seen the house that it built, and it is terrific." - Michael Caine, on Jaws the Revenge
DigitalfreakNYC is offline
post #215 of 5099 Old 07-30-2009, 08:38 AM
Phloyd's Avatar
I set my player to 'C' to find 'region coded' titles. I certainly missed that one.
Looks like I can't make any assumptions now...
Phloyd is offline
post #216 of 5099 Old 07-30-2009, 09:24 AM
sschen's Avatar
Quoted: 13 Post(s)
China release of Red Cliff I is Region C locked, from a thread on blu-ray.com forum.
sschen is online now
post #217 of 5099 Old 07-30-2009, 02:20 PM - Thread Starter
I did add one this go around (The Girl Who Leapt Through Time). At that rate, I'm confident the catch-up list will be cleared out somewhere between 6-8 years from now.
Seriously speaking, I was concentrating first on those that had postings in the previous thread and there aren't very many of those left. I do hope to pick up the pace on moving the rest in.
post #218 of 5099 Old 07-30-2009, 03:29 PM
Quoted: 52 Post(s)
I'm confused. I posted several of those in the previous thread, I believe.
post #219 of 5099 Old 07-30-2009, 04:02 PM
msgohan's Avatar
Well here's one from the catch-up list I figured I may as well scan while I've got it in the drive... Not sure whether this actually helps you or makes more work for you, but I couldn't find it in a search so I think it's the first full posting of the BEST RELEASE EVAR of Pan's Labyrinth.
Pan's Labyrinth - United Kingdom - Optimum Home Entertainment
Region ABC (confirmed with PowerDVD set to all 3 regions)
Release: 2007-11-19
Extras are all PAL 576i, and though the pre-menu logo looks like crappy SD, it's actually 1080p23.976 so it should play fine in the PS3 with latest firmware still (my PS3 is broken so I can't check).
Ironically, they incorrectly flagged the English-language commentary track as Spanish - the opposite problem is on their HD DVD, with the main Spanish track flagged as English.
There's a playlist that's 5-seconds shorter without the Optimum logo M2TS; this is the one that plays from the menu.
Code:
        Total   Video
00002.MPLS                                                      VC-1    1:58:56 28,573,224,960  36,599,330,132  32.03   29.45   DD AC3 5.1 640Kbps                        DD AC3 2.0 224Kbps
Code:
DISC INFO:
Disc Title:     PANS_LABYRINTH
Disc Size:      36,599,330,132 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:58:56 (h:m:s)
Total Bitrate:          32.03 Mbps
Description:
VIDEO:
VC-1 Video              29451 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Spanish         224 kbps        2.0 / 48 kHz / 224 kbps
Dolby Digital Audio             Spanish**       224 kbps        2.0 / 48 kHz / 224 kbps
SUBTITLES:
Presentation Graphics           English         22.157 kbps
FILES:
00005.M2TS      0:00:00.000     0:00:05.630     2,064,384       2,933
00006.M2TS      0:00:05.630     1:58:51.124     28,571,160,576  32,052
CHAPTERS:
1               0:00:00.000     0:11:19.595     28,698 kbps     54,657 kbps     00:07:45.047    39,501 kbps     00:05:47.055    37,197 kbps     00:05:46.679    149,813 bytes   984,673 bytes   00:09:02.792
2               0:11:19.595     0:06:39.982     28,398 kbps     54,444 kbps     00:13:29.141    38,797 kbps     00:13:29.308    36,363 kbps     00:13:29.016    148,055 bytes   615,588 bytes   00:14:05.511
3               0:17:59.578     0:06:42.068     28,205 kbps     54,001 kbps     00:18:20.599    39,234 kbps     00:24:19.958    35,801 kbps     00:19:20.784    147,050 bytes   704,912 bytes   00:23:29.533
4               0:24:41.646     0:07:05.716     33,176 kbps     53,710 kbps     00:24:43.940    38,914 kbps     00:26:23.248    36,988 kbps     00:28:00.845    172,966 bytes   866,296 bytes   00:29:22.677
5               0:31:47.363     0:06:36.020     32,659 kbps     55,018 kbps     00:33:05.733    39,604 kbps     00:34:15.803    37,211 kbps     00:33:05.733    170,269 bytes   966,007 bytes   00:32:01.711
6               0:38:23.384     0:05:17.775     31,602 kbps     52,123 kbps     00:41:35.367    38,189 kbps     00:42:41.809    36,730 kbps     00:38:30.016    164,759 bytes   812,609 bytes   00:40:41.689
7               0:43:41.160     0:06:45.863     30,865 kbps     52,705 kbps     00:46:12.644    39,045 kbps     00:46:11.685    36,972 kbps     00:46:11.310    160,917 bytes   809,671 bytes   00:46:14.605
8               0:50:27.023     0:05:00.341     28,226 kbps     48,932 kbps     00:53:25.368    36,029 kbps     00:53:27.787    33,761 kbps     00:53:22.782    147,155 bytes   666,491 bytes   00:53:10.061
9               0:55:27.365     0:06:58.417     30,721 kbps     57,925 kbps     00:55:46.926    38,528 kbps     00:55:46.926    36,572 kbps     01:00:59.197    160,164 bytes   932,675 bytes   00:55:47.802
10              1:02:25.783     0:09:27.858     32,396 kbps     51,080 kbps     01:04:14.016    38,158 kbps     01:06:42.623    36,894 kbps     01:11:22.403    168,898 bytes   885,113 bytes   01:02:25.825
11              1:11:53.642     0:11:41.075     29,574 kbps     55,873 kbps     01:18:50.851    39,100 kbps     01:18:08.850    36,904 kbps     01:18:08.850    154,183 bytes   799,831 bytes   01:18:08.892
12              1:23:34.718     0:07:43.171     29,947 kbps     51,341 kbps     01:26:47.619    39,082 kbps     01:24:29.689    36,910 kbps     01:26:47.619    156,130 bytes   757,225 bytes   01:25:01.012
13              1:31:17.889     0:10:21.537     31,659 kbps     53,309 kbps     01:41:37.966    39,079 kbps     01:33:41.532    37,108 kbps     01:34:12.313    165,055 bytes   1,023,267 bytes 01:37:31.971
14              1:41:39.426     0:10:30.212     34,215 kbps     52,955 kbps     01:49:00.992    38,611 kbps     01:42:29.726    36,959 kbps     01:43:07.222    178,383 bytes   820,700 bytes   01:50:30.832
15              1:52:09.639     0:06:47.115     6,836 kbps      18,495 kbps     01:58:23.679    16,354 kbps     01:58:20.635    15,397 kbps     01:58:16.964    35,737 bytes    359,370 bytes   01:58:23.721
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0xEA            VC-1                                    5.506                   1,614                   1,110,467       6,116
00005.M2TS      4352 (0x1100)   0x81            AC3             spa (Spanish)           5.506                   229                     157,696         880
00005.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           5.506                   655                     450,560         2,640
00005.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           5.506                   229                     157,696         880
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5.506                   0                       70              7
00006.M2TS      4113 (0x1011)   0xEA            VC-1                                    7130.999                29,473                  26,271,879,242  142,885,064
00006.M2TS      4352 (0x1100)   0x81            AC3             spa (Spanish)           7130.999                224                     199,671,808     1,114,240
00006.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           7130.999                640                     570,490,880     3,342,720
00006.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           7130.999                224                     199,671,808     1,114,240
00006.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           7130.999                22                      19,766,470      112,944
**NOTE: The third audio track is flagged as Spanish, but it's really the English commentary track.
Where did the info about the US "The Siege" being AVC come from? Because it's actually one of Fox's single-layer barebones MPEG-2 holdovers that they were previewing forever ago. That's why the overseas disc is different: they bothered to make a new one. (The Czech disc label is apparently THESIEGEF4, vs SEIGE_F1 for Aussie. Wonder what the numbers mean)
By the way, Cinema Squid, you've seen http://www.dvduell.de/blu-ray-info/ right? It has full BDInfo and bitrate charts for some German discs.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #220 of 5099 Old 07-30-2009, 11:25 PM
kennerado's Avatar
FIFA World Cup 2006: All The Goals (UK release, marked region ABC)
Code:
        Total   Video
00001.MPLS                                                      MPEG-2  2:00:14 38,923,431,936  42,615,439,158  43.16   39.66   DD AC3 2.0 192Kbps
Code:
DISC INFO:
Disc Title:     ALL_THE_GOALS
Disc Size:      42,615,439,158 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:00:14 (h:m:s)
Total Bitrate:          43.16 Mbps
Description:
VIDEO:
MPEG-2 Video            39660 kbps          1080i / 25 fps / 16:9
AUDIO:
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Dutch           192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             French          192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Greek           192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Italian         192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Portuguese      192 kbps        2.0 / 48 kHz / 192 kbps
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           Danish          4.773 kbps
Presentation Graphics           Finnish         4.916 kbps
Presentation Graphics           Norwegian       4.553 kbps
Presentation Graphics           Swedish         4.820 kbps
FILES:
00003.M2TS      0:00:00.000     1:14:15.000     24,023,119,872  43,139
00004.M2TS      1:14:15.000     0:45:59.960     14,900,312,064  43,190
CHAPTERS:
1               0:00:00.000     0:01:18.440     38,708 kbps     43,588 kbps     00:00:03.240    40,523 kbps     00:00:38.039    40,029 kbps     00:00:42.480    193,441 bytes   695,757 bytes   00:00:00.280
2               0:01:18.440     0:11:45.280     39,639 kbps     44,744 kbps     00:05:30.240    40,817 kbps     00:05:26.240    40,323 kbps     00:11:19.800    198,196 bytes   714,789 bytes   00:10:18.880
3               0:13:03.720     0:00:28.000     38,962 kbps     42,642 kbps     00:13:30.720    40,420 kbps     00:13:26.720    40,134 kbps     00:13:21.680    194,811 bytes   695,612 bytes   00:13:08.920
4               0:13:31.720     0:05:15.399     39,739 kbps     44,126 kbps     00:13:47.240    40,535 kbps     00:18:08.640    40,192 kbps     00:13:46.560    198,697 bytes   709,038 bytes   00:15:46.240
5               0:18:47.119     0:00:28.000     38,781 kbps     43,580 kbps     00:18:58.680    40,555 kbps     00:18:58.680    40,234 kbps     00:18:58.680    193,907 bytes   695,713 bytes   00:18:52.359
6               0:19:15.119     0:12:13.080     39,679 kbps     44,100 kbps     00:28:31.200    40,665 kbps     00:28:27.200    40,340 kbps     00:21:59.880    198,397 bytes   730,334 bytes   00:19:38.240
7               0:31:28.200     0:00:28.480     38,827 kbps     42,284 kbps     00:31:39.720    40,272 kbps     00:31:47.160    40,036 kbps     00:31:46.640    194,137 bytes   695,713 bytes   00:31:36.640
8               0:31:56.680     0:07:05.759     39,797 kbps     43,724 kbps     00:31:57.680    40,637 kbps     00:35:26.399    40,244 kbps     00:36:04.200    198,986 bytes   680,730 bytes   00:32:01.120
9               0:39:02.439     0:00:28.039     39,045 kbps     44,010 kbps     00:39:29.479    40,668 kbps     00:39:25.479    40,269 kbps     00:39:20.439    195,226 bytes   695,629 bytes   00:39:07.960
10              0:39:30.479     0:08:28.400     39,668 kbps     44,217 kbps     00:47:45.960    40,593 kbps     00:41:13.279    40,258 kbps     00:44:09.359    198,340 bytes   695,757 bytes   00:43:53.560
11              0:47:58.880     0:00:28.000     38,263 kbps     42,229 kbps     00:48:10.439    39,495 kbps     00:48:17.520    39,162 kbps     00:48:10.439    191,316 bytes   695,713 bytes   00:48:04.120
12              0:48:26.880     0:07:54.599     39,727 kbps     43,508 kbps     00:48:58.200    40,585 kbps     00:49:22.479    40,266 kbps     00:54:37.800    198,634 bytes   695,757 bytes   00:56:16.960
13              0:56:21.479     0:00:28.000     38,961 kbps     42,836 kbps     00:56:45.239    40,271 kbps     00:56:41.239    40,116 kbps     00:56:36.840    194,804 bytes   695,627 bytes   00:56:28.840
14              0:56:49.479     0:05:33.280     39,670 kbps     43,204 kbps     01:01:25.320    40,753 kbps     01:02:17.760    40,221 kbps     01:00:25.680    198,350 bytes   695,757 bytes   00:58:34.000
15              1:02:22.760     0:09:52.279     39,753 kbps     44,711 kbps     01:02:34.320    40,696 kbps     01:02:34.280    40,300 kbps     01:06:12.000    198,767 bytes   721,256 bytes   01:02:37.720
16              1:12:15.040     0:00:28.000     38,667 kbps     42,278 kbps     01:12:42.040    40,663 kbps     01:12:38.040    40,271 kbps     01:12:33.000    193,334 bytes   695,494 bytes   01:12:25.840
17              1:12:43.040     0:15:59.760     39,734 kbps     45,577 kbps     01:18:25.920    40,842 kbps     01:26:20.760    40,335 kbps     01:18:25.920    198,669 bytes   750,144 bytes   01:22:41.320
18              1:28:42.800     0:09:35.319     39,661 kbps     45,209 kbps     01:31:13.640    40,889 kbps     01:31:16.559    40,425 kbps     01:35:31.040    198,304 bytes   703,289 bytes   01:37:00.280
19              1:38:18.120     0:11:13.079     39,781 kbps     44,590 kbps     01:39:04.640    40,781 kbps     01:39:00.640    40,359 kbps     01:38:55.600    198,903 bytes   695,757 bytes   01:38:25.840
20              1:49:31.200     0:10:43.760     39,528 kbps     44,337 kbps     01:56:25.400    40,794 kbps     01:58:25.920    40,327 kbps     01:58:22.560    197,650 bytes   708,181 bytes   01:58:16.840
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x02            MPEG-2                                  4454.880                39,641                  22,074,516,220  120,034,975
00003.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           4454.880                192                     106,920,192     696,095
00003.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            4454.880                192                     106,920,192     696,095
00003.M2TS      4354 (0x1102)   0x81            AC3             ita (Italian)           4454.880                192                     106,920,192     696,095
00003.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           4454.880                192                     106,920,192     696,095
00003.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        4454.880                192                     106,920,192     696,095
00003.M2TS      4357 (0x1105)   0x81            AC3             ell (Greek)             4454.880                192                     106,920,192     696,095
00003.M2TS      4358 (0x1106)   0x81            AC3             nld (Dutch)             4454.880                192                     106,920,192     696,095
00003.M2TS      4608 (0x1200)   0x90            PGS             swe (Swedish)           4454.880                5                       2,806,981       15,926
00003.M2TS      4609 (0x1201)   0x90            PGS             nor (Norwegian)         4454.880                5                       2,697,223       15,273
00003.M2TS      4610 (0x1202)   0x90            PGS             fin (Finnish)           4454.880                5                       2,893,691       16,396
00003.M2TS      4611 (0x1203)   0x90            PGS             dan (Danish)            4454.880                5                       2,802,050       15,903
00004.M2TS      4113 (0x1011)   0x02            MPEG-2                                  2759.880                39,693                  13,693,420,306  74,460,812
00004.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           2759.880                192                     66,239,232      431,245
00004.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            2759.880                192                     66,239,232      431,245
00004.M2TS      4354 (0x1102)   0x81            AC3             ita (Italian)           2759.880                192                     66,239,232      431,245
00004.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           2759.880                192                     66,239,232      431,245
00004.M2TS      4356 (0x1104)   0x81            AC3             por (Portuguese)        2759.880                192                     66,239,232      431,245
00004.M2TS      4357 (0x1105)   0x81            AC3             ell (Greek)             2759.880                192                     66,239,232      431,245
00004.M2TS      4358 (0x1106)   0x81            AC3             nld (Dutch)             2759.880                192                     66,239,232      431,245
00004.M2TS      4608 (0x1200)   0x90            PGS             swe (Swedish)           2759.880                4                       1,539,814       8,689
00004.M2TS      4609 (0x1201)   0x90            PGS             nor (Norwegian)         2759.880                4                       1,408,683       7,960
00004.M2TS      4610 (0x1202)   0x90            PGS             fin (Finnish)           2759.880                4                       1,539,901       8,687
00004.M2TS      4611 (0x1203)   0x90            PGS             dan (Danish)            2759.880                4                       1,502,690       8,483
kennerado is offline
post #221 of 5099 Old 07-31-2009, 04:50 AM
The Truman Show - 1998 - Australian version
From disc label -- THE_TRUMAN_SHOW_EU -- is probably also European version
Distributed by Paramount Home Entertainment (Australasia) Pty Ltd
Region A/B/C, confirmed with AnyDVD HD.
Has a slightly different video bitrate to the one listed on the front page, although the TrueHD audio bitrate is identical.
Code:
        Total   Video
00001.MPLS                                                      AVC     1:42:56 36,109,633,536  40,804,594,163  46.77   35.82   Dolby TrueHD 5.1 3672Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     THE_TRUMAN_SHOW_EU
Disc Size:      40,804,594,163 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:42:56 (h:m:s)
Total Bitrate:          46.77 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        35825 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         3672 kbps       5.1 / 48 kHz / 3672 kbps / 24-bit (AC3 Core: 5.1 / 48 kHz / 640 kbps)
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             German          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Italian         640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           Danish          29.212 kbps
Presentation Graphics           German          31.020 kbps
Presentation Graphics           English         32.060 kbps
Presentation Graphics           Spanish         30.986 kbps
Presentation Graphics           French          25.743 kbps
Presentation Graphics           Italian         30.002 kbps
Presentation Graphics           Dutch           26.461 kbps
Presentation Graphics           Norwegian       28.197 kbps
Presentation Graphics           Finnish         28.436 kbps
Presentation Graphics           Swedish         27.315 kbps
Presentation Graphics           English         35.840 kbps
Presentation Graphics           German          0.071 kbps
Presentation Graphics           Spanish         0.140 kbps
Presentation Graphics           French          0.125 kbps
Presentation Graphics           Italian         0.119 kbps
FILES:
00002.M2TS      0:00:00.000     1:42:56.920     36,109,633,536  46,767
CHAPTERS:
1               0:00:00.000     0:02:42.537     33,131 kbps     52,365 kbps     00:00:16.349    39,834 kbps     00:00:12.345    38,422 kbps     00:00:07.340    172,686 bytes   540,419 bytes   00:00:17.017
2               0:02:42.537     0:04:06.746     36,326 kbps     39,654 kbps     00:03:46.476    37,570 kbps     00:03:10.315    37,176 kbps     00:03:28.666    189,387 bytes   521,071 bytes   00:03:52.982
3               0:06:49.283     0:02:17.428     36,799 kbps     39,102 kbps     00:06:57.250    37,255 kbps     00:07:37.874    37,081 kbps     00:07:07.593    191,856 bytes   423,834 bytes   00:09:06.712
4               0:09:06.712     0:00:36.745     36,813 kbps     40,157 kbps     00:09:35.950    37,516 kbps     00:09:10.550    37,154 kbps     00:09:08.673    191,927 bytes   581,966 bytes   00:09:15.513
5               0:09:43.457     0:01:47.899     36,406 kbps     39,397 kbps     00:11:19.553    37,413 kbps     00:11:21.972    37,066 kbps     00:11:19.970    189,803 bytes   445,820 bytes   00:11:28.979
6               0:11:31.357     0:05:43.343     36,590 kbps     41,340 kbps     00:12:42.386    37,425 kbps     00:15:28.010    37,145 kbps     00:15:22.963    190,762 bytes   404,414 bytes   00:14:26.949
7               0:17:14.700     0:12:14.525     36,517 kbps     41,313 kbps     00:25:50.423    37,499 kbps     00:25:46.503    37,215 kbps     00:25:41.498    190,381 bytes   388,752 bytes   00:28:27.414
8               0:29:29.225     0:07:28.990     36,413 kbps     41,614 kbps     00:32:56.516    37,331 kbps     00:35:57.613    37,111 kbps     00:31:34.893    189,840 bytes   900,766 bytes   00:29:52.540
9               0:36:58.216     0:05:35.710     36,551 kbps     39,817 kbps     00:39:35.623    37,346 kbps     00:40:38.853    37,101 kbps     00:39:45.549    190,559 bytes   477,069 bytes   00:40:43.023
10              0:42:33.926     0:03:07.186     36,689 kbps     39,626 kbps     00:43:02.830    37,248 kbps     00:43:44.580    37,073 kbps     00:43:49.460    191,281 bytes   385,308 bytes   00:44:27.247
11              0:45:41.113     0:02:02.705     36,713 kbps     39,270 kbps     00:46:51.809    37,338 kbps     00:47:15.749    37,204 kbps     00:47:10.619    191,407 bytes   488,625 bytes   00:45:53.417
12              0:47:43.819     0:03:28.625     36,624 kbps     41,038 kbps     00:50:03.458    37,752 kbps     00:49:59.621    37,383 kbps     00:49:54.616    190,940 bytes   552,773 bytes   00:48:17.352
13              0:51:12.444     0:01:44.187     36,521 kbps     40,332 kbps     00:52:51.042    37,744 kbps     00:52:47.038    37,046 kbps     00:52:44.786    190,402 bytes   389,837 bytes   00:52:09.543
14              0:52:56.631     0:02:26.396     36,615 kbps     39,253 kbps     00:54:07.494    37,329 kbps     00:54:06.618    37,042 kbps     00:53:33.335    190,896 bytes   365,180 bytes   00:53:33.418
15              0:55:23.028     0:05:45.011     36,662 kbps     39,642 kbps     01:00:06.519    37,439 kbps     00:59:20.765    37,087 kbps     01:00:58.029    191,139 bytes   476,623 bytes   00:59:23.893
16              1:01:08.039     0:08:49.946     36,562 kbps     46,748 kbps     01:01:27.725    38,750 kbps     01:01:23.721    37,488 kbps     01:04:31.492    190,617 bytes   480,030 bytes   01:03:53.371
17              1:09:57.985     0:03:22.911     36,700 kbps     41,403 kbps     01:12:29.636    37,738 kbps     01:12:25.591    37,236 kbps     01:12:20.586    191,339 bytes   536,943 bytes   01:13:18.268
18              1:13:20.896     0:07:40.460     36,499 kbps     42,946 kbps     01:19:54.164    37,823 kbps     01:19:50.202    37,365 kbps     01:19:45.113    190,292 bytes   448,846 bytes   01:19:50.827
19              1:21:01.356     0:02:21.391     36,608 kbps     43,148 kbps     01:21:36.224    37,941 kbps     01:21:32.220    37,388 kbps     01:21:27.257    190,859 bytes   388,798 bytes   01:22:05.170
20              1:23:22.747     0:04:21.344     36,210 kbps     40,960 kbps     01:25:38.258    37,597 kbps     01:25:34.254    37,327 kbps     01:25:29.249    188,782 bytes   434,896 bytes   01:27:21.527
21              1:27:44.092     0:04:07.121     36,698 kbps     40,621 kbps     01:27:55.144    37,432 kbps     01:28:54.120    37,197 kbps     01:28:54.495    191,327 bytes   414,203 bytes   01:31:16.512
22              1:31:51.214     0:02:58.094     36,740 kbps     39,247 kbps     01:34:33.501    37,345 kbps     01:34:30.456    37,135 kbps     01:34:28.329    191,544 bytes   419,174 bytes   01:34:34.460
23              1:34:49.308     0:01:11.446     36,318 kbps     38,663 kbps     01:35:42.945    37,218 kbps     01:35:24.135    36,981 kbps     01:35:07.535    189,344 bytes   332,010 bytes   01:35:39.692
24              1:36:00.755     0:06:56.165     27,134 kbps     43,552 kbps     01:42:52.749    37,446 kbps     01:41:35.380    37,171 kbps     01:41:30.375    141,479 bytes   438,460 bytes   01:42:53.500
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     6176.754                35,826                  27,660,819,710  150,417,368
00002.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6176.754                4,312                   3,329,277,000   24,344,024
00002.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            6176.754                640                     494,154,240     2,895,435
00002.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           6176.754                640                     494,154,240     2,895,435
00002.M2TS      4355 (0x1103)   0x81            AC3             deu (German)            6176.754                640                     494,154,240     2,895,435
00002.M2TS      4356 (0x1104)   0x81            AC3             ita (Italian)           6176.754                640                     494,154,240     2,895,435
00002.M2TS      4608 (0x1200)   0x90            PGS             dan (Danish)            6176.754                29                      22,554,854      130,540
00002.M2TS      4609 (0x1201)   0x90            PGS             deu (German)            6176.754                31                      23,951,171      138,152
00002.M2TS      4610 (0x1202)   0x90            PGS             eng (English)           6176.754                32                      24,754,045      142,188
00002.M2TS      4611 (0x1203)   0x90            PGS             spa (Spanish)           6176.754                31                      23,925,059      137,984
00002.M2TS      4612 (0x1204)   0x90            PGS             fra (French)            6176.754                26                      19,876,364      116,004
00002.M2TS      4613 (0x1205)   0x90            PGS             ita (Italian)           6176.754                30                      23,165,345      133,847
00002.M2TS      4614 (0x1206)   0x90            PGS             nld (Dutch)             6176.754                26                      20,430,663      119,006
00002.M2TS      4615 (0x1207)   0x90            PGS             nor (Norwegian)         6176.754                28                      21,771,361      126,299
00002.M2TS      4616 (0x1208)   0x90            PGS             fin (Finnish)           6176.754                28                      21,955,888      127,294
00002.M2TS      4617 (0x1209)   0x90            PGS             swe (Swedish)           6176.754                27                      21,090,419      122,606
00002.M2TS      4618 (0x120A)   0x90            PGS             eng (English)           6176.754                36                      27,672,372      159,209
00002.M2TS      4619 (0x120B)   0x90            PGS             deu (German)            6176.754                0                       54,790          327
00002.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           6176.754                0                       108,038         627
00002.M2TS      4621 (0x120D)   0x90            PGS             fra (French)            6176.754                0                       96,340          559
00002.M2TS      4622 (0x120E)   0x90            PGS             ita (Italian)           6176.754                0                       92,152          537
Stephen Dawson
hifi-writer.com
post #222 of 5099 Old 07-31-2009, 07:09 AM
Quoted: 52 Post(s)
Release: 2007-11-19
Code:
        Total   Video
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Description:
VIDEO:
AUDIO:
SUBTITLES:
FILES:
CHAPTERS:
STREAM DIAGNOSTICS:
Weird. So the video is better but the audio isn't lossless.
post #223 of 5099 Old 07-31-2009, 10:01 AM - Thread Starter
That is possible. There are three general classes of entries that I skipped over when I did my first pass through them:
  1. Entries marked as (EU). I'd prefer to have these mapped to specific a specific country or countries if possible, so if anyone knows what countries those entries are applicable to that would be appreciated.
  2. Partial television show entries - usually just the first episode or first disc posted. I was going to leave these out, but I think now perhaps it would be better to put them in after all.
  3. Some Japanese titles - sheer laziness on my part, but I've been going back through and putting them in.
I also just realized that some of the reports might be missing due to the "Great AVS Database Crash of 2008".
Yes, I did find that from a link posted I believe sometime in the last thread. Most of those should be in the list already, although I don't see an easy way to tell when new things get added to that page so there might be some missing.
post #224 of 5099 Old 07-31-2009, 11:54 AM
Quoted: 52 Post(s)
A lot of the ones I'm looking at are not EU titles. I guess I'm just being anal. I primarily use this list to compare/contrast different versions from different regions and it's invaluable to me for that purpose. However, it seems like a lot of titles are missing still because of the update. Don't want to hound you and definitely dont' want to seem unappreciative. Whenever you can get to it would be great.
post #225 of 5099 Old 07-31-2009, 12:29 PM
msgohan's Avatar
Yeah, and they put a 1536kbps DD+ track on their HD DVD. But I guess this is the best they could put on the Blu-ray if they wanted to stay away from TrueHD and DTS for some reason.
That is possible. There are three general classes of entries that I skipped over when I did my first pass through them:[list=1][*]Entries marked as (EU). I'd prefer to have these mapped to specific a specific country or countries if possible, so if anyone knows what countries those entries are applicable to that would be appreciated.[*]Partial television show entries - usually just the first episode or first disc posted. I was going to leave these out, but I think now perhaps it would be better to put them in after all.
I'm pretty sure "(EU)" ones like Air Force One and Con Air refer to the UK discs.
I think I might be able to rent 24 Season 7 if no one else can add the full specs.
PS3, WD TV Live
msgohan is offline
post #226 of 5099 Old 07-31-2009, 04:47 PM
Snowknight26's Avatar
Quoted: 26 Post(s)
Liked: 27
The Moguls (The Amateurs)
US Release
Code:
        Total   Video
00018.MPLS                                                      VC-1    1:38:21 13,276,342,272  20,790,383,032  18.00   14.99   DTS 5.1 768Kbps (48kHz/24-bit)            DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Title:     BDROM
Disc Size:      20,790,383,032 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:38:21 (h:m:s)
Total Bitrate:          18.00 Mbps
Description:
VIDEO:
VC-1 Video              14991 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS Audio                       English         768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         109.752 kbps
Presentation Graphics           Spanish         93.778 kbps
FILES:
00024.M2TS      0:00:00.000     1:38:20.895     13,276,323,840  17,999
00009.M2TS      1:38:20.895     0:00:00.625     18,432          236
CHAPTERS:
1               0:00:00.000     0:14:11.016     12,173 kbps     25,009 kbps     00:00:49.966    20,528 kbps     00:00:47.922    19,586 kbps     00:00:41.374    63,459 bytes    299,174 bytes   00:00:40.248
2               0:14:11.016     0:05:43.134     17,206 kbps     32,210 kbps     00:14:34.290    20,804 kbps     00:17:50.319    20,082 kbps     00:18:41.703    89,704 bytes    652,043 bytes   00:14:19.733
3               0:19:54.151     0:06:53.746     18,986 kbps     32,209 kbps     00:25:03.877    23,971 kbps     00:25:07.923    22,779 kbps     00:25:08.215    98,985 bytes    361,085 bytes   00:26:20.662
4               0:26:47.897     0:08:29.926     13,532 kbps     24,264 kbps     00:26:51.318    17,645 kbps     00:34:16.137    16,479 kbps     00:31:35.059    70,547 bytes    268,971 bytes   00:27:55.006
5               0:35:17.824     0:04:46.619     15,724 kbps     25,544 kbps     00:37:41.676    19,741 kbps     00:37:39.257    18,031 kbps     00:37:34.168    81,975 bytes    289,960 bytes   00:36:05.496
6               0:40:04.443     0:04:03.159     16,411 kbps     28,724 kbps     00:40:04.568    22,301 kbps     00:40:13.119    20,372 kbps     00:40:47.570    85,561 bytes    319,192 bytes   00:40:54.618
7               0:44:07.603     0:06:48.449     15,478 kbps     30,985 kbps     00:48:08.510    23,217 kbps     00:48:08.510    22,846 kbps     00:48:08.510    80,695 bytes    435,805 bytes   00:48:08.552
8               0:50:56.053     0:08:27.882     15,742 kbps     22,945 kbps     00:53:27.787    18,672 kbps     00:58:12.155    17,864 kbps     00:50:58.638    82,070 bytes    279,198 bytes   00:51:06.521
9               0:59:23.935     0:18:40.911     14,658 kbps     28,383 kbps     01:00:37.925    21,792 kbps     01:07:11.402    20,048 kbps     01:04:57.268    76,423 bytes    343,172 bytes   01:01:25.348
10              1:18:04.846     0:05:26.326     17,333 kbps     24,542 kbps     01:22:48.838    21,099 kbps     01:19:19.796    20,405 kbps     01:18:12.938    90,365 bytes    256,649 bytes   01:19:53.997
11              1:23:31.172     0:09:54.427     15,470 kbps     28,104 kbps     01:24:24.142    23,333 kbps     01:24:58.593    22,110 kbps     01:24:58.051    80,655 bytes    373,370 bytes   01:27:04.886
12              1:33:25.600     0:04:55.920     11,329 kbps     31,920 kbps     01:33:56.464    24,164 kbps     01:33:56.297    23,082 kbps     01:33:56.464    59,083 bytes    1,009,749 bytes 01:33:53.669
STREAM DIAGNOSTICS:
00024.M2TS      4113 (0x1011)   0xEA            VC-1                                    5900.770                14,993                  11,058,508,432  60,185,909
00024.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           5900.770                640                     472,153,600     2,766,525
00024.M2TS      4353 (0x1101)   0x82            DTS             eng (English)           5900.770                768                     566,591,488     3,319,872
00024.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5900.770                192                     141,646,080     922,175
00024.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           5900.770                192                     141,646,080     922,175
00024.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5900.770                110                     80,963,001      449,079
00024.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5900.770                94                      69,179,312      384,024
00009.M2TS      4113 (0x1011)   0xEA            VC-1                                    0.501                   161                     10,044          65
Snowknight26 is offline
post #227 of 5099 Old 07-31-2009, 04:55 PM
Quoted: 26 Post(s)
Liked: 27
An American Carol
US Release
Code:
        Total   Video
00021.MPLS                                                      AVC     1:22:27 15,893,200,896  19,345,519,028  25.70   23.40   DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     AMERICAN CAROL
Disc Size:      19,345,519,028 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:22:27 (h:m:s)
Total Bitrate:          25.70 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        23398 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             English         384 kbps        2.0 / 48 kHz / 384 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         51.499 kbps
FILES:
00000.M2TS      0:00:00.000     1:22:22.938     15,892,586,496  25,722
00025.M2TS      1:22:22.938     0:00:05.004     614,400         982
CHAPTERS:
1               0:00:00.000     0:06:33.893     25,190 kbps     50,535 kbps     00:00:58.058    38,734 kbps     00:00:54.554    35,638 kbps     00:05:33.666    131,317 bytes   511,274 bytes   00:03:52.982
2               0:06:33.893     0:06:49.826     24,685 kbps     42,294 kbps     00:09:46.294    33,230 kbps     00:08:21.918    31,886 kbps     00:08:09.864    128,698 bytes   499,296 bytes   00:13:14.251
3               0:13:23.719     0:07:11.222     25,662 kbps     39,086 kbps     00:13:54.708    33,300 kbps     00:17:57.451    30,480 kbps     00:17:57.451    133,791 bytes   528,053 bytes   00:15:40.939
4               0:20:34.942     0:05:33.833     24,773 kbps     42,897 kbps     00:22:59.628    32,661 kbps     00:22:55.624    29,726 kbps     00:24:59.331    129,153 bytes   592,928 bytes   00:23:00.462
5               0:26:08.775     0:07:03.965     25,246 kbps     45,534 kbps     00:26:56.156    37,870 kbps     00:26:56.197    33,894 kbps     00:26:56.197    131,623 bytes   512,760 bytes   00:26:56.239
6               0:33:12.740     0:05:34.834     26,037 kbps     50,817 kbps     00:34:52.173    36,448 kbps     00:35:35.258    33,324 kbps     00:35:10.858    135,744 bytes   510,226 bytes   00:34:52.215
7               0:38:47.575     0:08:57.703     24,519 kbps     44,059 kbps     00:45:11.917    35,423 kbps     00:45:23.720    33,767 kbps     00:45:19.258    127,832 bytes   492,497 bytes   00:45:20.801
8               0:47:45.279     0:06:32.058     24,636 kbps     39,374 kbps     00:54:01.655    32,115 kbps     00:47:52.661    29,751 kbps     00:47:52.578    128,443 bytes   481,380 bytes   00:53:15.442
9               0:54:17.337     0:06:35.561     22,802 kbps     42,087 kbps     00:54:26.221    33,516 kbps     00:54:22.217    30,446 kbps     00:54:19.256    118,880 bytes   510,507 bytes   00:54:26.263
10              1:00:52.899     0:07:08.177     25,656 kbps     41,119 kbps     01:02:35.626    34,467 kbps     01:03:50.535    32,547 kbps     01:03:45.822    133,761 bytes   536,982 bytes   01:04:01.546
11              1:08:01.076     0:07:56.058     25,088 kbps     41,562 kbps     01:10:36.565    32,997 kbps     01:12:26.467    31,332 kbps     01:12:24.089    130,796 bytes   525,379 bytes   01:12:00.816
12              1:15:57.135     0:06:25.760     5,651 kbps      37,178 kbps     01:16:29.251    28,922 kbps     01:16:26.707    28,108 kbps     01:16:22.452    29,464 bytes    457,053 bytes   01:16:29.293
13              1:22:22.896     0:00:05.046     864 kbps        1,241 kbps      01:22:24.939    871 kbps        01:22:22.896    0 kbps          00:00:00.000    4,542 bytes     74,208 bytes    01:22:25.190
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     4942.855                23,421                  14,471,014,765  78,716,615
00000.M2TS      4352 (0x1100)   0x81            AC3             eng (English)           4942.855                448                     276,804,864     1,544,670
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4942.855                384                     237,261,312     1,390,203
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           4942.855                192                     118,630,656     772,335
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4942.855                52                      31,851,872      184,454
00025.M2TS      4113 (0x1011)   0x1B            AVC                                     4.880                   894                     545,098         3,003
post #228 of 5099 Old 07-31-2009, 07:20 PM
Rieper's Avatar
Quoted: 154 Post(s)
Liked: 67
Criterion | 1965 | 105 mins | Unrated | Jul 28, 2009 (New Release)
UPC: 715515047814
Region: A (Locked)*
Aspect Ratio: 1.66:1
Audio: English (1.0 Mono)
Subtitles: English HOH, None
Disc Size: 50GB Dual Layer (BD50)
*confirmed using AnyDVD HD set to Region B & C (gave 'Region incompatible' error message).
Special Note:
DIRECTOR-APPROVED SPECIAL EDITION
•New, restored high-definition digital transfer, approved by director Roman Polanski (with an uncompressed monaural soundtrack on the Blu-ray edition)
•Audio commentary featuring Polanski and actress Catherine Deneuve
•A British Horror Film (2003), a documentary on the making of Repulsion, featuring interviews with Polanski, producer Gene Gutowski, and cinematographer Gil Taylor, among others
•A 1964 television documentary filmed on the set of Repulsion, with rare footage of Polanski and Deneuve at work
•Original theatrical trailers
•PLUS: A booklet featuring an essay by film scholar and curator Bill Horrigan
Code:
        Total   Video
00001.MPLS                                                      AVC     1:45:16 30,681,366,528  44,993,411,114  38.86   34.56   LPCM 1.0 1152Kbps (48kHz/24-bit)          DD AC3 1.0 192Kbps
DISC INFO:
Disc Title:     REPULSION
Disc Size:      44,993,411,114 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:45:16 (h:m:s)
Total Bitrate:          38.86 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        34555 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      English         1152 kbps       1.0 / 48 kHz / 1152 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        1.0 / 48 kHz / 192 kbps
SUBTITLES:
Presentation Graphics           English         26.966 kbps
FILES:
00257.M2TS      0:00:00.000     1:45:16.643     30,681,366,528  38,858
CHAPTERS:
1               0:00:00.000     0:02:19.639     31,608 kbps     36,941 kbps     00:00:07.340    36,339 kbps     00:00:03.336    36,292 kbps     00:00:02.335    164,738 bytes   212,686 bytes   00:01:28.004
2               0:02:19.639     0:06:18.836     36,064 kbps     38,515 kbps     00:04:34.607    36,704 kbps     00:04:30.603    36,368 kbps     00:04:25.598    188,022 bytes   253,282 bytes   00:08:37.725
3               0:08:38.476     0:10:57.782     35,354 kbps     40,271 kbps     00:14:13.394    37,058 kbps     00:14:09.390    36,658 kbps     00:14:04.385    184,320 bytes   247,667 bytes   00:14:13.936
4               0:19:36.258     0:07:26.904     35,926 kbps     39,158 kbps     00:24:07.070    36,721 kbps     00:24:03.024    36,350 kbps     00:23:58.061    187,300 bytes   227,132 bytes   00:24:07.737
5               0:27:03.163     0:09:04.794     35,588 kbps     38,837 kbps     00:34:24.437    36,776 kbps     00:34:20.433    36,486 kbps     00:34:15.428    185,537 bytes   243,668 bytes   00:34:25.146
6               0:36:07.957     0:06:22.840     33,322 kbps     37,022 kbps     00:41:52.885    36,419 kbps     00:41:48.797    36,338 kbps     00:41:43.792    173,728 bytes   209,451 bytes   00:41:45.836
7               0:42:30.798     0:12:03.305     32,674 kbps     38,084 kbps     00:47:08.784    36,663 kbps     00:47:04.863    36,413 kbps     00:46:59.817    170,346 bytes   243,710 bytes   00:47:09.493
8               0:54:34.104     0:09:14.679     36,097 kbps     37,880 kbps     01:00:14.402    36,518 kbps     00:55:50.472    36,369 kbps     00:57:55.555    188,193 bytes   231,863 bytes   00:58:05.231
9               1:03:48.783     0:08:45.066     35,693 kbps     38,121 kbps     01:12:09.616    36,443 kbps     01:07:14.238    36,329 kbps     01:04:20.731    186,088 bytes   228,077 bytes   01:12:10.075
10              1:12:33.849     0:05:03.011     35,559 kbps     38,101 kbps     01:13:59.852    36,487 kbps     01:16:35.173    36,340 kbps     01:16:30.168    185,390 bytes   229,489 bytes   01:15:56.426
11              1:17:36.860     0:12:19.864     33,875 kbps     38,402 kbps     01:22:20.769    36,663 kbps     01:22:16.765    36,449 kbps     01:22:11.801    176,610 bytes   261,111 bytes   01:22:13.428
12              1:29:56.724     0:05:23.531     34,847 kbps     39,417 kbps     01:33:23.014    36,587 kbps     01:34:57.233    36,384 kbps     01:34:52.228    181,676 bytes   244,758 bytes   01:33:23.514
13              1:35:20.256     0:09:13.344     34,337 kbps     37,987 kbps     01:35:25.970    36,574 kbps     01:35:42.737    36,365 kbps     01:37:45.568    179,018 bytes   228,009 bytes   01:37:37.768
14              1:44:33.600     0:00:43.042     5,393 kbps      10,792 kbps     01:44:51.201    10,153 kbps     01:44:48.490    9,224 kbps      01:44:46.738    28,144 bytes    109,006 bytes   01:44:50.617
STREAM DIAGNOSTICS:
00257.M2TS      4113 (0x1011)   0x1B            AVC                                     6316.477                34,556                  27,284,101,050  148,371,906
00257.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           6316.477                2,310                   1,824,247,076   10,106,632
00257.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6316.477                192                     151,600,128     986,980
00257.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6316.477                27                      21,291,442      121,643
Rieper is offline
post #229 of 5099 Old 07-31-2009, 08:28 PM
Rieper's Avatar
Quoted: 154 Post(s)
Liked: 67
Criterion | 1961 | 94 mins | Unrated | Jun 23, 2009
UPC: 715515046312
Region: A (Locked)*
Aspect Ratio: 2.35:1
Audio: French (1.0 Mono)
Subtitles: English, None
*confirmed using AnyDVD HD set to Region B & C (gave me 'Region mismatch' error message).
Special Note:
New, restored high-definition digital transfer, supervised and approved by director Alain Resnais (with uncompressed monaural soundtrack on the Blu-ray edition)
New audio interview with Resnais, recorded exclusively for this release
New documentary on the making of Last Year at Marienbad, featuring interviews with many of Resnais' collaborators
New video interview with film scholar Ginette Vincendeau on the history of the film and its many mysteries
Two short documentaries by Resnais: Toute la mémoire du monde (1956) and Le chant du styrène (1958)
Original theatrical trailer and Rialto's rerelease trailer
New and improved English subtitle translation
PLUS: A booklet featuring an essay by critic Mark Polizzotti and a section on Alain Robbe-Grillet's evolving attitude toward the film, including the author's introduction to the published screenplay and comments by film scholar François Thomas
Code:
        Total   Video
00001.MPLS                                                      AVC     1:34:43 29,234,737,152  49,237,323,332  41.15   34.62   LPCM 1.0 1152Kbps (48kHz/24-bit)          LPCM 1.0 1152Kbps (48kHz/24-bit)
DISC INFO:
Disc Title:     MARIENBAD
Disc Size:      49,237,323,332 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:34:43 (h:m:s)
Total Bitrate:          41.15 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        34618 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
LPCM Audio                      French          1152 kbps       1.0 / 48 kHz / 1152 kbps / 24-bit
SUBTITLES:
Presentation Graphics           English         35.354 kbps
FILES:
00237.M2TS      0:00:00.000     1:34:43.511     29,234,737,152  41,150
CHAPTERS:
1               0:00:00.000     0:08:38.184     33,361 kbps     39,499 kbps     00:00:31.031    36,608 kbps     00:03:32.170    36,403 kbps     00:03:27.165    173,914 bytes   302,999 bytes   00:00:31.656
2               0:08:38.184     0:03:39.969     35,069 kbps     36,984 kbps     00:11:16.592    36,388 kbps     00:12:03.764    36,289 kbps     00:10:30.379    182,833 bytes   253,822 bytes   00:12:08.519
3               0:12:18.154     0:02:29.607     36,072 kbps     40,092 kbps     00:14:32.580    36,863 kbps     00:14:28.534    36,410 kbps     00:14:23.529    188,061 bytes   707,153 bytes   00:14:33.539
4               0:14:47.761     0:02:49.961     36,159 kbps     39,326 kbps     00:17:32.676    36,865 kbps     00:17:28.672    36,536 kbps     00:17:23.667    188,517 bytes   583,425 bytes   00:17:33.677
5               0:17:37.723     0:02:37.198     36,179 kbps     37,368 kbps     00:18:24.061    36,437 kbps     00:19:58.488    36,334 kbps     00:19:53.442    188,619 bytes   271,187 bytes   00:18:27.815
6               0:20:14.922     0:05:39.172     32,348 kbps     37,195 kbps     00:24:54.534    36,424 kbps     00:23:24.111    36,312 kbps     00:22:32.476    168,650 bytes   258,204 bytes   00:22:46.823
7               0:25:54.094     0:03:24.996     36,198 kbps     37,885 kbps     00:28:36.673    36,583 kbps     00:28:32.669    36,420 kbps     00:28:27.664    188,721 bytes   325,286 bytes   00:28:37.424
8               0:29:19.090     0:03:15.361     36,219 kbps     37,395 kbps     00:32:13.014    36,496 kbps     00:32:09.052    36,358 kbps     00:32:04.047    188,831 bytes   284,533 bytes   00:29:53.708
9               0:32:34.452     0:04:35.817     33,928 kbps     37,496 kbps     00:34:50.630    36,422 kbps     00:34:46.626    36,328 kbps     00:34:41.621    176,885 bytes   426,025 bytes   00:35:17.907
10              0:37:10.269     0:05:19.777     32,415 kbps     38,551 kbps     00:38:20.464    36,495 kbps     00:40:03.025    36,378 kbps     00:39:58.020    168,995 bytes   277,953 bytes   00:38:25.761
11              0:42:30.047     0:04:21.970     36,131 kbps     37,029 kbps     00:46:34.666    36,440 kbps     00:45:49.955    36,354 kbps     00:45:44.950    188,372 bytes   269,124 bytes   00:46:36.627
12              0:46:52.017     0:04:29.394     36,219 kbps     37,365 kbps     00:48:26.028    36,432 kbps     00:48:22.024    36,305 kbps     00:48:17.019    188,827 bytes   272,540 bytes   00:48:40.834
13              0:51:21.411     0:04:56.713     36,223 kbps     36,762 kbps     00:56:09.157    36,329 kbps     00:51:35.550    36,291 kbps     00:52:59.885    188,849 bytes   252,540 bytes   00:51:22.412
14              0:56:18.124     0:04:28.685     35,563 kbps     40,343 kbps     00:56:55.078    37,003 kbps     00:56:51.074    36,614 kbps     00:56:46.069    185,412 bytes   690,085 bytes   00:56:56.079
15              1:00:46.809     0:04:25.974     35,273 kbps     38,092 kbps     01:05:07.111    36,512 kbps     01:05:02.982    36,353 kbps     01:04:08.845    183,899 bytes   286,632 bytes   01:02:25.074
16              1:05:12.783     0:04:33.022     36,192 kbps     37,462 kbps     01:08:53.295    36,468 kbps     01:08:49.291    36,356 kbps     01:08:37.446    188,687 bytes   287,198 bytes   01:07:51.567
17              1:09:45.806     0:04:00.698     36,203 kbps     39,172 kbps     01:09:59.403    36,584 kbps     01:09:55.399    36,369 kbps     01:10:09.205    188,747 bytes   538,487 bytes   01:10:00.404
18              1:13:46.505     0:04:01.324     35,887 kbps     39,253 kbps     01:14:42.352    36,694 kbps     01:14:38.348    36,479 kbps     01:14:33.343    187,096 bytes   605,117 bytes   01:14:43.353
19              1:17:47.829     0:04:06.120     36,039 kbps     37,787 kbps     01:21:49.946    36,463 kbps     01:21:45.775    36,350 kbps     01:20:48.134    187,890 bytes   239,999 bytes   01:21:40.812
20              1:21:53.950     0:05:31.164     33,628 kbps     38,319 kbps     01:27:00.298    36,639 kbps     01:26:56.252    36,450 kbps     01:26:51.247    175,320 bytes   526,359 bytes   01:27:01.257
21              1:27:25.114     0:07:18.396     30,018 kbps     37,432 kbps     01:28:47.447    36,412 kbps     01:28:43.443    36,322 kbps     01:32:54.902    156,517 bytes   315,192 bytes   01:33:19.010
STREAM DIAGNOSTICS:
00237.M2TS      4113 (0x1011)   0x1B            AVC                                     5683.344                34,619                  24,593,912,613  133,742,629
00237.M2TS      4352 (0x1100)   0x80            LPCM            fra (French)            5683.344                2,310                   1,641,399,132   9,093,624
00237.M2TS      4353 (0x1101)   0x80            LPCM            fra (French)            5683.344                2,310                   1,641,399,132   9,093,624
00237.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5683.344                35                      25,116,790      143,976
Rieper is offline
post #230 of 5099 Old 08-02-2009, 11:23 AM - Thread Starter
[US] The Towering Inferno (Additional Details)
Region Locked (A) (confirmed w/ PowerDVD 8)
Studio: Fox
Release Date: 2009-07-14
UPC: 024543600008
Subs: English (SDH), French, Spanish
English DTS-HD Master 5.1, Dolby Digital 4.0, Dolby Digital 2.0 original audio tracks w/ 3 commentary tracks.
Code:
        Total   Video
The Towering Inferno                                            AVC     2:44:53 39,291,930,624  48,243,804,187  31.77   24.82   DTS-HD Master 5.1 3555Kbps (48kHz/24-bit) DD AC3 4.0 448Kbps / DD AC3 2.0 224Kbps
Code:
DISC INFO:
Disc Title:     TOWERING_INFERNO
Disc Size:      48,243,804,187 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 2:44:53 (h:m:s)
Total Bitrate:          31.77 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        24817 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3555 kbps       5.1 / 48 kHz / 3555 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        4.0 / 48 kHz / 448 kbps
Dolby Digital Audio             English         224 kbps        2.0 / 48 kHz / 224 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         38.058 kbps
Presentation Graphics           French          33.961 kbps
Presentation Graphics           Spanish         30.808 kbps
FILES:
00002.M2TS      0:00:00.000     2:44:53.884     39,291,930,624  31,771
CHAPTERS:
1               0:00:00.000     0:03:35.215     30,889 kbps     48,277 kbps     00:00:02.419    34,609 kbps     00:00:30.989    32,982 kbps     00:00:19.853    161,012 bytes   514,847 bytes   00:03:25.246
2               0:03:35.215     0:05:28.703     24,490 kbps     42,529 kbps     00:04:03.993    32,676 kbps     00:04:03.993    31,816 kbps     00:04:03.993    127,681 bytes   590,701 bytes   00:04:04.035
3               0:09:03.918     0:02:24.894     23,931 kbps     34,991 kbps     00:10:06.689    31,524 kbps     00:10:08.649    28,023 kbps     00:10:03.644    124,766 bytes   525,867 bytes   00:11:13.381
4               0:11:28.813     0:02:20.014     23,902 kbps     31,829 kbps     00:11:52.920    29,225 kbps     00:12:34.211    27,339 kbps     00:11:46.122    124,615 bytes   509,746 bytes   00:11:53.921
5               0:13:48.828     0:04:56.004     24,837 kbps     41,200 kbps     00:18:21.225    33,004 kbps     00:18:21.225    31,913 kbps     00:18:21.225    129,491 bytes   599,235 bytes   00:18:21.266
6               0:18:44.832     0:04:09.958     24,095 kbps     34,994 kbps     00:21:07.766    28,864 kbps     00:22:24.259    26,975 kbps     00:20:51.458    125,623 bytes   513,978 bytes   00:20:52.876
7               0:22:54.790     0:05:49.098     24,722 kbps     38,764 kbps     00:28:18.488    33,564 kbps     00:24:45.984    32,271 kbps     00:24:46.276    128,890 bytes   589,400 bytes   00:28:16.069
8               0:28:43.888     0:03:08.938     26,114 kbps     37,280 kbps     00:30:16.022    33,939 kbps     00:30:12.560    31,815 kbps     00:29:05.952    136,148 bytes   501,927 bytes   00:29:14.753
9               0:31:52.827     0:03:51.773     24,609 kbps     32,323 kbps     00:34:03.374    28,033 kbps     00:32:08.468    27,242 kbps     00:33:01.396    128,302 bytes   492,646 bytes   00:32:26.903
10              0:35:44.600     0:05:55.271     24,365 kbps     44,012 kbps     00:40:59.623    34,298 kbps     00:39:25.071    31,461 kbps     00:38:32.727    127,029 bytes   649,462 bytes   00:37:43.928
11              0:41:39.872     0:05:05.179     23,520 kbps     46,361 kbps     00:44:40.427    33,781 kbps     00:44:40.386    32,827 kbps     00:44:40.427    122,623 bytes   683,604 bytes   00:45:05.035
12              0:46:45.052     0:05:22.363     26,007 kbps     42,274 kbps     00:47:44.987    33,870 kbps     00:47:43.610    33,122 kbps     00:47:43.277    135,588 bytes   593,486 bytes   00:50:57.012
13              0:52:07.415     0:03:23.828     24,406 kbps     35,847 kbps     00:54:11.581    29,140 kbps     00:55:14.894    28,131 kbps     00:54:43.238    127,241 bytes   512,820 bytes   00:54:54.040
14              0:55:31.244     0:02:34.445     24,113 kbps     48,990 kbps     00:56:20.794    30,096 kbps     00:56:39.270    28,163 kbps     00:57:16.141    125,715 bytes   543,612 bytes   00:58:05.690
15              0:58:05.690     0:08:26.506     25,914 kbps     43,706 kbps     01:04:35.997    35,103 kbps     01:06:14.887    34,439 kbps     01:06:14.971    135,101 bytes   534,799 bytes   01:06:13.177
16              1:06:32.196     0:03:40.553     29,011 kbps     41,307 kbps     01:08:42.618    34,352 kbps     01:09:36.172    33,529 kbps     01:09:37.423    151,248 bytes   632,865 bytes   01:08:42.660
17              1:10:12.750     0:03:54.943     24,055 kbps     37,635 kbps     01:11:34.999    31,684 kbps     01:11:31.036    30,254 kbps     01:11:29.535    125,411 bytes   483,849 bytes   01:11:41.714
18              1:14:07.693     0:09:25.648     22,983 kbps     32,508 kbps     01:14:56.742    28,447 kbps     01:17:58.757    27,354 kbps     01:20:53.598    119,824 bytes   494,522 bytes   01:18:02.094
19              1:23:33.341     0:04:42.615     22,412 kbps     43,519 kbps     01:23:55.947    27,590 kbps     01:24:16.634    25,791 kbps     01:24:11.796    116,848 bytes   463,494 bytes   01:24:28.730
20              1:28:15.957     0:05:52.351     23,444 kbps     35,966 kbps     01:29:16.851    31,145 kbps     01:33:37.570    29,686 kbps     01:33:40.281    122,224 bytes   605,827 bytes   01:29:17.060
21              1:34:08.309     0:08:58.120     24,323 kbps     38,958 kbps     01:39:09.735    31,844 kbps     01:39:05.731    30,412 kbps     01:42:48.036    126,810 bytes   502,127 bytes   01:34:45.930
22              1:43:06.430     0:03:24.829     26,404 kbps     38,145 kbps     01:45:05.257    31,461 kbps     01:45:01.878    29,365 kbps     01:44:58.417    137,657 bytes   515,731 bytes   01:45:06.091
23              1:46:31.259     0:02:34.445     24,358 kbps     32,989 kbps     01:46:42.854    27,692 kbps     01:46:40.894    27,039 kbps     01:47:43.748    126,990 bytes   499,280 bytes   01:48:03.226
24              1:49:05.705     0:08:51.656     25,700 kbps     49,863 kbps     01:54:58.933    33,096 kbps     01:50:42.927    32,357 kbps     01:56:08.169    133,991 bytes   638,619 bytes   01:54:59.058
25              1:57:57.361     0:02:49.460     24,195 kbps     35,088 kbps     01:58:30.978    27,339 kbps     02:00:22.924    26,831 kbps     02:00:16.000    126,141 bytes   430,331 bytes   01:58:34.649
26              2:00:46.822     0:06:22.632     24,728 kbps     40,555 kbps     02:05:14.882    32,568 kbps     02:05:53.379    31,695 kbps     02:06:30.457    128,921 bytes   574,465 bytes   02:05:53.754
27              2:07:09.455     0:07:25.236     23,007 kbps     43,703 kbps     02:07:37.900    33,574 kbps     02:07:37.900    30,614 kbps     02:08:01.090    119,951 bytes   582,697 bytes   02:07:37.941
28              2:14:34.691     0:07:13.266     23,437 kbps     34,741 kbps     02:21:31.316    31,905 kbps     02:21:27.312    31,515 kbps     02:21:37.947    122,188 bytes   487,517 bytes   02:21:26.352
29              2:21:47.957     0:08:50.363     25,853 kbps     48,386 kbps     02:23:12.333    35,902 kbps     02:23:00.738    33,176 kbps     02:23:00.780    134,787 bytes   597,558 bytes   02:30:38.320
30              2:30:38.320     0:06:11.704     26,723 kbps     45,457 kbps     02:36:44.561    33,514 kbps     02:36:44.603    31,675 kbps     02:34:29.885    139,323 bytes   738,561 bytes   02:36:44.645
31              2:36:50.025     0:04:35.274     26,466 kbps     40,692 kbps     02:37:39.867    33,671 kbps     02:37:35.904    32,409 kbps     02:37:30.941    137,984 bytes   571,440 bytes   02:39:20.217
32              2:41:25.300     0:03:28.583     23,400 kbps     37,011 kbps     02:44:47.711    28,327 kbps     02:41:26.301    27,052 kbps     02:41:26.009    122,048 bytes   502,631 bytes   02:41:29.680
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     9893.801                24,817                  30,692,009,973  166,944,181
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9893.801                3,555                   4,396,816,048   25,438,108
00002.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           9893.801                448                     554,057,728     3,091,840
00002.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9893.801                224                     277,028,864     1,545,920
00002.M2TS      4355 (0x1103)   0x81            AC3             spa (Spanish)           9893.801                224                     277,028,864     1,545,920
00002.M2TS      4356 (0x1104)   0x81            AC3             eng (English)           9893.801                224                     277,028,864     1,545,920
00002.M2TS      4357 (0x1105)   0x81            AC3             eng (English)           9893.801                224                     277,028,864     1,545,920
00002.M2TS      4358 (0x1106)   0x81            AC3             eng (English)           9893.801                224                     277,028,864     1,545,920
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9893.801                38                      47,068,025      266,927
00002.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            9893.801                34                      42,001,051      237,833
00002.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           9893.801                31                      38,101,819      216,592
post #231 of 5099 Old 08-02-2009, 11:28 AM - Thread Starter
[US] This Is Spinal Tap (Additional Details)
Studio: MGM
Release Date: 2009-07-28
UPC: 883904132585
Aspect Ratio: 1.85:1
English DTS-HD Master 5.1 and Dolby Digital 2.0 original audio tracks w/ one commentary (by Spinal Tap in-character).
Code:
        Total   Video
This Is Spinal Tap                                              AVC     1:22:50 24,071,086,080  35,143,834,301  38.74   32.98   DTS-HD Master 5.1 3129Kbps (48kHz/24-bit) DD AC3 2.0 224Kbps
Code:
DISC INFO:
Disc Title:     THIS_IS_SPINAL_TAP
Disc Size:      35,143,834,301 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:22:50 (h:m:s)
Total Bitrate:          38.74 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        32983 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3129 kbps       5.1 / 48 kHz / 3129 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         71.853 kbps
Presentation Graphics           French          57.495 kbps
Presentation Graphics           Spanish         57.948 kbps
FILES:
00000.M2TS      0:00:00.000     1:22:50.966     24,071,086,080  38,739
CHAPTERS:
1               0:00:00.000     0:01:54.447     29,415 kbps     35,560 kbps     00:00:40.498    34,800 kbps     00:01:36.387    34,738 kbps     00:01:36.304    153,299 bytes   260,149 bytes   00:01:32.675
2               0:01:54.447     0:02:16.261     33,185 kbps     38,381 kbps     00:03:53.608    34,824 kbps     00:03:53.733    34,699 kbps     00:03:53.816    173,009 bytes   356,436 bytes   00:03:51.814
3               0:04:10.708     0:02:18.680     34,394 kbps     35,985 kbps     00:05:03.177    34,880 kbps     00:04:12.460    34,787 kbps     00:05:34.834    179,317 bytes   290,896 bytes   00:04:15.713
4               0:06:29.389     0:01:52.612     34,367 kbps     36,688 kbps     00:07:40.585    35,128 kbps     00:07:36.581    34,885 kbps     00:07:31.576    179,175 bytes   377,017 bytes   00:07:41.544
5               0:08:22.001     0:01:42.936     33,378 kbps     36,567 kbps     00:08:45.525    34,743 kbps     00:08:34.555    34,596 kbps     00:08:29.592    174,017 bytes   240,524 bytes   00:09:18.808
6               0:10:04.937     0:02:00.411     30,740 kbps     38,053 kbps     00:11:43.119    33,986 kbps     00:11:43.035    33,041 kbps     00:11:37.655    160,263 bytes   276,405 bytes   00:11:05.498
7               0:12:05.349     0:00:48.173     33,290 kbps     36,006 kbps     00:12:08.811    34,901 kbps     00:12:09.603    34,441 kbps     00:12:07.309    173,557 bytes   327,593 bytes   00:12:25.911
8               0:12:53.522     0:03:59.572     33,268 kbps     37,225 kbps     00:13:03.783    35,171 kbps     00:12:59.737    34,740 kbps     00:14:07.054    173,442 bytes   306,279 bytes   00:13:04.533
9               0:16:53.095     0:01:53.071     33,033 kbps     34,845 kbps     00:17:19.204    34,107 kbps     00:17:16.368    33,876 kbps     00:17:14.491    172,220 bytes   292,357 bytes   00:18:46.166
10              0:18:46.166     0:01:41.643     34,462 kbps     36,475 kbps     00:20:08.498    34,823 kbps     00:19:09.982    34,728 kbps     00:19:41.180    179,671 bytes   270,716 bytes   00:18:47.167
11              0:20:27.809     0:03:26.289     33,561 kbps     36,689 kbps     00:20:47.537    34,864 kbps     00:22:41.651    34,774 kbps     00:22:36.938    174,970 bytes   282,642 bytes   00:21:44.303
12              0:23:54.099     0:03:01.306     32,131 kbps     35,644 kbps     00:25:39.955    34,506 kbps     00:25:36.076    33,577 kbps     00:24:46.526    167,518 bytes   298,459 bytes   00:24:52.741
13              0:26:55.405     0:00:59.225     32,907 kbps     34,951 kbps     00:27:46.289    34,059 kbps     00:27:46.039    33,483 kbps     00:27:44.621    171,564 bytes   266,556 bytes   00:27:51.044
14              0:27:54.631     0:02:08.545     33,370 kbps     35,754 kbps     00:29:44.866    34,815 kbps     00:29:40.862    34,712 kbps     00:29:17.881    173,976 bytes   286,206 bytes   00:30:03.176
15              0:30:03.176     0:01:19.621     33,446 kbps     35,749 kbps     00:30:44.133    34,833 kbps     00:31:07.031    34,749 kbps     00:31:02.151    174,370 bytes   286,360 bytes   00:30:17.649
16              0:31:22.797     0:02:01.204     34,445 kbps     36,259 kbps     00:32:28.196    34,962 kbps     00:32:24.275    34,772 kbps     00:31:33.182    179,580 bytes   277,940 bytes   00:32:38.373
17              0:33:24.002     0:06:11.204     32,350 kbps     36,233 kbps     00:34:17.513    34,928 kbps     00:34:13.509    34,769 kbps     00:33:50.945    168,656 bytes   264,761 bytes   00:34:54.675
18              0:39:35.206     0:01:57.951     32,987 kbps     35,730 kbps     00:39:36.832    34,780 kbps     00:39:51.430    34,716 kbps     00:39:49.678    171,979 bytes   281,894 bytes   00:41:12.011
19              0:41:33.157     0:01:07.067     34,216 kbps     35,440 kbps     00:42:24.625    34,796 kbps     00:42:24.667    34,649 kbps     00:42:24.667    178,389 bytes   260,709 bytes   00:42:19.245
20              0:42:40.224     0:02:43.705     33,290 kbps     36,578 kbps     00:44:57.653    34,780 kbps     00:42:40.849    34,721 kbps     00:42:40.808    173,558 bytes   325,779 bytes   00:44:31.126
21              0:45:23.929     0:02:15.510     33,681 kbps     35,620 kbps     00:47:31.348    34,828 kbps     00:45:28.600    34,669 kbps     00:46:45.594    175,596 bytes   278,973 bytes   00:46:44.510
22              0:47:39.439     0:02:09.546     31,338 kbps     36,799 kbps     00:49:45.816    34,397 kbps     00:47:54.913    33,839 kbps     00:49:17.120    163,382 bytes   266,142 bytes   00:47:46.029
23              0:49:48.986     0:03:03.725     33,578 kbps     36,414 kbps     00:52:39.364    35,010 kbps     00:52:35.360    34,762 kbps     00:52:42.450    175,062 bytes   268,393 bytes   00:52:10.001
24              0:52:52.711     0:00:59.059     29,706 kbps     35,353 kbps     00:53:01.052    34,805 kbps     00:52:57.090    34,680 kbps     00:52:55.589    154,871 bytes   282,189 bytes   00:53:51.770
25              0:53:51.770     0:03:44.182     32,812 kbps     36,519 kbps     00:56:29.385    35,033 kbps     00:56:12.702    34,677 kbps     00:53:52.896    171,067 bytes   285,576 bytes   00:57:31.531
26              0:57:35.952     0:04:33.189     33,581 kbps     35,686 kbps     01:02:00.675    34,855 kbps     01:00:43.306    34,754 kbps     01:00:38.134    175,076 bytes   258,631 bytes   00:57:49.132
27              1:02:09.142     0:01:52.779     32,689 kbps     35,245 kbps     01:03:30.348    34,770 kbps     01:03:30.348    34,218 kbps     01:03:29.222    170,425 bytes   258,555 bytes   01:02:12.520
28              1:04:01.921     0:04:27.266     32,930 kbps     35,641 kbps     01:06:20.643    34,823 kbps     01:04:33.327    34,592 kbps     01:07:14.530    171,681 bytes   284,214 bytes   01:06:05.795
29              1:08:29.188     0:01:48.358     32,959 kbps     35,599 kbps     01:08:39.990    34,816 kbps     01:08:31.482    34,759 kbps     01:08:30.898    171,834 bytes   293,194 bytes   01:09:43.429
30              1:10:17.546     0:01:52.862     33,287 kbps     35,635 kbps     01:11:50.681    34,741 kbps     01:10:20.799    34,661 kbps     01:10:20.799    173,545 bytes   271,305 bytes   01:12:10.409
31              1:12:10.409     0:05:24.532     32,939 kbps     37,683 kbps     01:17:20.886    34,839 kbps     01:12:15.539    34,689 kbps     01:13:18.769    171,731 bytes   287,030 bytes   01:17:16.923
32              1:17:34.941     0:05:16.024     32,991 kbps     36,216 kbps     01:20:09.638    34,900 kbps     01:20:55.517    34,842 kbps     01:20:00.545    172,025 bytes   347,035 bytes   01:21:58.204
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     4970.841                32,983                  20,494,398,643  111,452,635
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           4970.841                3,130                   1,944,549,820   11,336,086
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           4970.841                224                     139,187,328     776,715
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           4970.841                224                     139,187,328     776,715
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           4970.841                72                      44,647,218      255,289
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           4970.841                58                      36,006,997      206,145
00000.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            4970.841                57                      35,725,619      204,666
post #232 of 5099 Old 08-03-2009, 07:09 PM
msgohan's Avatar
Could've sworn someone scanned this when it was released but I guess maybe it was lost in the database crash.
Jingle All the Way - United States - 20th Century Fox
Region A locked (confirmed w/PowerDVD set to all 3 regions)
Release: 2008-12-02
Code:
        Total   Video
Jingle All the Way: Extended Director's Cut (seamless)          AVC     1:33:44 25,126,115,328  45,176,078,817  35.74   28.21   DTS-HD Master 5.1 4450Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     JINGLE_ALL_THE_WAY_US
Disc Size:      45,176,078,817 bytes
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:33:44 (h:m:s)
Total Bitrate:          35.74 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        28209 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4450 kbps       5.1 / 48 kHz / 4450 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             French          448 kbps        5.1 / 48 kHz / 448 kbps
Dolby Digital Audio             Spanish         448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           English         67.057 kbps
Presentation Graphics           Chinese         44.666 kbps
Presentation Graphics           Chinese         47.136 kbps
Presentation Graphics           French          5.074 kbps
Presentation Graphics           Korean          38.356 kbps
Presentation Graphics           Spanish         47.441 kbps
Presentation Graphics           Spanish         4.138 kbps
Presentation Graphics           Thai            38.784 kbps
FILES:
00001.M2TS      0:00:00.000     0:19:56.612     5,345,163,264   35,735
00011.M2TS      0:19:56.612     0:07:43.838     2,117,695,488   36,525
00003.M2TS      0:27:40.450     0:05:27.994     1,639,409,664   39,986
00012.M2TS      0:33:08.444     0:09:09.632     2,701,363,200   39,319
00005.M2TS      0:42:18.077     0:03:04.642     754,225,152     32,678
00013.M2TS      0:45:22.719     0:05:03.845     1,489,618,944   39,220
00007.M2TS      0:50:26.565     0:05:38.546     1,499,547,648   35,435
00014.M2TS      0:56:05.111     0:01:23.416     386,273,280     37,045
00009.M2TS      0:57:28.528     0:23:58.645     6,606,323,712   36,736
00015.M2TS      1:21:27.173     0:12:17.445     2,586,494,976   28,059
CHAPTERS:
1               0:00:00.000     0:07:57.143     29,081 kbps     51,026 kbps     00:00:01.876    38,477 kbps     00:00:26.234    35,723 kbps     00:04:34.732    151,600 bytes   639,077 bytes   00:00:20.937
2               0:07:57.143     0:05:48.097     28,614 kbps     44,067 kbps     00:09:19.433    38,008 kbps     00:09:18.099    35,876 kbps     00:09:31.946    149,183 bytes   512,205 bytes   00:08:21.417
3               0:13:45.241     0:02:35.613     26,956 kbps     41,661 kbps     00:14:55.644    33,849 kbps     00:14:45.551    32,147 kbps     00:13:45.241    140,535 bytes   664,937 bytes   00:14:47.177
4               0:16:20.854     0:02:14.884     24,630 kbps     38,522 kbps     00:16:23.232    34,954 kbps     00:16:21.063    32,442 kbps     00:16:20.854    128,411 bytes   563,184 bytes   00:16:24.149
5               0:18:35.739     0:05:20.403     29,632 kbps     45,767 kbps     00:20:45.702    38,276 kbps     00:18:48.043    35,656 kbps     00:23:16.561    154,487 bytes   576,543 bytes   00:20:46.286
6               0:23:56.143     0:02:08.253     30,345 kbps     41,041 kbps     00:24:55.785    36,757 kbps     00:23:58.520    35,895 kbps     00:23:58.520    158,154 bytes   484,251 bytes   00:24:57.746
7               0:26:04.396     0:02:03.456     27,002 kbps     42,270 kbps     00:27:29.689    31,493 kbps     00:27:17.093    30,053 kbps     00:27:13.965    140,775 bytes   551,990 bytes   00:27:45.747
8               0:28:07.852     0:02:22.058     33,010 kbps     45,811 kbps     00:29:26.973    37,958 kbps     00:29:44.532    36,390 kbps     00:30:16.272    172,148 bytes   493,011 bytes   00:30:21.528
9               0:30:29.911     0:02:15.593     33,326 kbps     43,081 kbps     00:32:01.711    36,893 kbps     00:32:26.611    36,097 kbps     00:32:27.362    173,746 bytes   518,123 bytes   00:31:12.287
10              0:32:45.505     0:06:09.619     31,138 kbps     44,200 kbps     00:35:54.277    38,572 kbps     00:35:50.857    35,116 kbps     00:35:47.770    162,337 bytes   681,228 bytes   00:35:07.980
11              0:38:55.124     0:03:22.952     31,879 kbps     46,180 kbps     00:40:12.368    38,583 kbps     00:40:09.156    36,215 kbps     00:39:48.803    166,203 bytes   584,370 bytes   00:40:13.327
12              0:42:18.077     0:03:04.642     25,660 kbps     41,601 kbps     00:42:33.425    34,760 kbps     00:42:33.425    31,216 kbps     00:42:30.839    133,779 bytes   515,088 bytes   00:42:33.467
13              0:45:22.719     0:03:40.178     31,848 kbps     43,503 kbps     00:47:05.614    37,380 kbps     00:46:28.243    35,794 kbps     00:46:54.478    166,040 bytes   529,773 bytes   00:45:46.869
14              0:49:02.898     0:07:56.726     28,591 kbps     47,931 kbps     00:54:03.531    38,194 kbps     00:54:02.822    34,688 kbps     00:50:03.792    149,061 bytes   593,148 bytes   00:56:59.624
15              0:56:59.624     0:06:44.779     27,515 kbps     50,470 kbps     01:00:27.832    38,720 kbps     01:00:45.850    35,626 kbps     01:00:06.102    143,452 bytes   671,554 bytes   00:57:13.137
16              1:03:44.403     0:02:18.638     29,287 kbps     44,878 kbps     01:04:39.208    38,410 kbps     01:03:53.287    35,137 kbps     01:04:45.881    152,688 bytes   568,844 bytes   01:05:29.925
17              1:06:03.042     0:02:44.247     31,340 kbps     49,262 kbps     01:07:32.923    37,604 kbps     01:07:52.443    36,243 kbps     01:07:55.029    163,391 bytes   602,505 bytes   01:07:33.883
18              1:08:47.289     0:04:19.676     30,035 kbps     49,485 kbps     01:10:46.075    38,352 kbps     01:12:44.735    36,076 kbps     01:10:25.429    156,590 bytes   622,682 bytes   01:11:26.448
19              1:13:06.965     0:01:40.517     26,328 kbps     43,367 kbps     01:14:23.834    33,105 kbps     01:13:19.269    30,202 kbps     01:13:19.269    137,261 bytes   594,243 bytes   01:14:23.876
20              1:14:47.482     0:03:34.547     29,209 kbps     47,372 kbps     01:17:13.670    38,263 kbps     01:17:12.377    35,831 kbps     01:17:10.041    152,284 bytes   597,593 bytes   01:15:25.520
21              1:18:22.030     0:04:11.668     30,654 kbps     46,591 kbps     01:22:10.008    38,893 kbps     01:20:04.716    36,225 kbps     01:22:01.458    159,818 bytes   710,843 bytes   01:22:10.050
22              1:22:33.698     0:02:54.173     26,066 kbps     47,959 kbps     01:25:03.181    38,274 kbps     01:25:03.181    35,576 kbps     01:23:35.093    135,898 bytes   548,293 bytes   01:25:03.890
23              1:25:27.872     0:00:47.130     29,874 kbps     50,128 kbps     01:26:10.999    38,178 kbps     01:25:40.843    34,672 kbps     01:25:40.093    155,748 bytes   473,847 bytes   01:26:11.040
24              1:26:15.003     0:07:28.614     16,286 kbps     37,695 kbps     01:32:45.935    35,967 kbps     01:32:41.889    35,040 kbps     01:32:37.927    84,906 bytes    732,789 bytes   01:32:41.972
25              1:33:43.617     0:00:01.001     103 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    561 bytes       785 bytes       01:33:43.909
STREAM DIAGNOSTICS:
00001.M2TS      4113 (0x1011)   0x1B            AVC                                     1196.487                28,351                  4,240,236,125   23,061,481
00001.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1196.487                4,259                   636,988,008     3,648,322
00001.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           1196.487                448                     67,011,840      373,950
00001.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            1196.487                448                     67,011,840      373,950
00001.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1196.487                74                      11,026,586      62,442
00001.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1196.487                60                      8,904,358       50,673
00001.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1196.487                1                       100,275         585
00001.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            1196.487                2                       328,050         1,883
00001.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           1196.487                54                      8,082,920       46,318
00001.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           1196.487                58                      8,630,899       49,487
00001.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            1196.487                46                      6,834,367       39,542
00001.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              1196.487                48                      7,169,620       41,338
00011.M2TS      4113 (0x1011)   0x1B            AVC                                     463.755                 29,097                  1,686,742,934   9,173,539
00011.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           463.755                 4,266                   247,296,692     1,416,828
00011.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           463.755                 448                     25,976,832      144,960
00011.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            463.755                 448                     25,976,832      144,960
00011.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           463.755                 73                      4,246,270       24,122
00011.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           463.755                 53                      3,093,245       17,628
00011.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           463.755                 11                      665,525         3,857
00011.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            463.755                 13                      770,690         4,429
00011.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           463.755                 51                      2,962,027       17,054
00011.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           463.755                 53                      3,085,218       17,768
00011.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            463.755                 45                      2,592,684       15,024
00011.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              463.755                 44                      2,560,620       14,845
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     327.869                 32,282                  1,323,014,283   7,194,877
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           327.869                 4,539                   186,030,576     1,062,283
00003.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           327.869                 448                     18,369,792      102,510
00003.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            327.869                 448                     18,369,792      102,510
00003.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           327.869                 54                      2,232,533       12,685
00003.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           327.869                 37                      1,495,956       8,534
00003.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           327.869                 0                       10,286          64
00003.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            327.869                 1                       59,686          350
00003.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           327.869                 33                      1,335,027       7,748
00003.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           327.869                 37                      1,506,328       8,663
00003.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            327.869                 31                      1,251,011       7,266
00003.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              327.869                 28                      1,136,706       6,599
00012.M2TS      4113 (0x1011)   0x1B            AVC                                     549.549                 31,402                  2,157,101,471   11,731,010
00012.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           549.549                 4,642                   318,851,080     1,818,979
00012.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           549.549                 448                     30,781,184      171,770
00012.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            549.549                 448                     30,781,184      171,770
00012.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           549.549                 69                      4,763,544       27,027
00012.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           549.549                 52                      3,572,236       20,372
00012.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           549.549                 17                      1,141,336       6,567
00012.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            549.549                 18                      1,245,196       7,130
00012.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           549.549                 50                      3,413,459       19,618
00012.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           549.549                 51                      3,520,943       20,224
00012.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            549.549                 43                      2,926,459       16,952
00012.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              549.549                 43                      2,958,200       17,127
00005.M2TS      4113 (0x1011)   0x1B            AVC                                     184.476                 25,681                  592,193,921     3,221,012
00005.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           184.476                 4,009                   92,454,904      531,193
00005.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           184.476                 448                     10,341,632      57,710
00005.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            184.476                 448                     10,341,632      57,710
00005.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           184.476                 73                      1,676,913       9,518
00005.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           184.476                 64                      1,467,595       8,347
00005.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           184.476                 0                       8,875           56
00005.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            184.476                 4                       92,702          520
00005.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           184.476                 55                      1,265,068       7,266
00005.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           184.476                 60                      1,375,219       7,896
00005.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            184.476                 48                      1,107,154       6,390
00005.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              184.476                 52                      1,195,240       6,839
00013.M2TS      4113 (0x1011)   0x1B            AVC                                     303.678                 31,655                  1,201,601,360   6,534,688
00013.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           303.678                 4,244                   161,111,020     922,752
00013.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           303.678                 448                     17,016,832      94,960
00013.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            303.678                 448                     17,016,832      94,960
00013.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           303.678                 87                      3,294,386       18,723
00013.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           303.678                 64                      2,433,704       13,923
00013.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           303.678                 5                       201,591         1,156
00013.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            303.678                 6                       236,536         1,343
00013.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           303.678                 67                      2,547,806       14,693
00013.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           303.678                 68                      2,590,169       14,903
00013.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            303.678                 53                      2,007,607       11,684
00013.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              303.678                 54                      2,060,849       11,958
00007.M2TS      4113 (0x1011)   0x1B            AVC                                     338.380                 28,104                  1,188,743,618   6,465,293
00007.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           338.380                 4,175                   176,587,424     1,012,505
00007.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           338.380                 448                     18,961,152      105,810
00007.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            338.380                 448                     18,961,152      105,810
00007.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           338.380                 94                      3,976,420       22,459
00007.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           338.380                 66                      2,788,661       15,822
00007.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           338.380                 0                       0               0
00007.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            338.380                 0                       0               0
00007.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           338.380                 63                      2,658,127       15,246
00007.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           338.380                 68                      2,856,749       16,372
00007.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            338.380                 53                      2,222,663       12,846
00007.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              338.380                 52                      2,191,771       12,688
00014.M2TS      4113 (0x1011)   0x1B            AVC                                     83.333                  29,556                  307,877,414     1,674,422
00014.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           83.333                  4,336                   45,166,748      258,270
00014.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           83.333                  448                     4,671,744       26,070
00014.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            83.333                  448                     4,671,744       26,070
00014.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           83.333                  60                      622,939         3,527
00014.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           83.333                  58                      608,838         3,459
00014.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           83.333                  35                      362,474         2,062
00014.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            83.333                  41                      430,463         2,439
00014.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           83.333                  44                      454,398         2,585
00014.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           83.333                  44                      456,543         2,597
00014.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            83.333                  37                      387,344         2,220
00014.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              83.333                  31                      328,026         1,882
00009.M2TS      4113 (0x1011)   0x1B            AVC                                     1438.562                29,028                  5,219,886,614   28,389,123
00009.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           1438.562                4,640                   834,278,904     4,758,334
00009.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           1438.562                448                     80,566,528      449,590
00009.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            1438.562                448                     80,566,528      449,590
00009.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           1438.562                59                      10,620,613      60,500
00009.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           1438.562                40                      7,165,137       40,870
00009.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           1438.562                1                       165,336         940
00009.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            1438.562                1                       135,674         770
00009.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           1438.562                38                      6,888,704       39,645
00009.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           1438.562                40                      7,204,806       41,578
00009.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            1438.562                33                      5,998,245       34,787
00009.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              1438.562                33                      6,006,165       34,794
00015.M2TS      4113 (0x1011)   0x1B            AVC                                     737.320                 20,789                  1,915,977,446   10,423,176
00015.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           737.320                 4,665                   429,929,780     2,451,459
00015.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           737.320                 448                     41,298,432      230,460
00015.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            737.320                 448                     41,298,432      230,460
00015.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           737.320                 51                      4,686,059       26,686
00015.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           737.320                 20                      1,825,180       10,463
00015.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           737.320                 3                       253,560         1,452
00015.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            737.320                 3                       268,638         1,534
00015.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           737.320                 19                      1,796,326       10,388
00015.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           737.320                 21                      1,913,597       11,009
00015.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            737.320                 18                      1,639,767       9,523
00015.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              737.320                 18                      1,660,958       9,646
Code:
        Total   Video
Jingle All the Way: Theatrical Cut (seamless)                   AVC     1:29:31 23,848,200,192  45,176,078,817  35.52   28.04   DTS-HD Master 5.1 4423Kbps (48kHz/24-bit)
Code:
DISC INFO:
Protection:     BD+
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:29:31 (h:m:s)
Total Bitrate:          35.52 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        28039 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4423 kbps       5.1 / 48 kHz / 4423 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         67.502 kbps
Presentation Graphics           Chinese         44.007 kbps
Presentation Graphics           Chinese         46.621 kbps
Presentation Graphics           French          1.228 kbps
Presentation Graphics           Korean          37.737 kbps
Presentation Graphics           Spanish         47.003 kbps
Presentation Graphics           Spanish         0.685 kbps
Presentation Graphics           Thai            38.208 kbps
FILES:
00002.M2TS      0:19:56.612     0:06:26.928     1,794,619,392   37,105
00003.M2TS      0:26:23.540     0:05:27.994     1,639,409,664   39,986
00004.M2TS      0:31:51.534     0:07:18.187     2,147,887,104   39,214
00005.M2TS      0:39:09.722     0:03:04.642     754,225,152     32,678
00006.M2TS      0:42:14.365     0:04:42.490     1,322,385,408   37,449
00007.M2TS      0:46:56.855     0:05:38.546     1,499,547,648   35,435
00008.M2TS      0:52:35.402     0:00:45.211     189,628,416     33,554
00009.M2TS      0:53:20.613     0:23:58.645     6,606,323,712   36,736
00010.M2TS      1:17:19.259     0:12:11.856     2,549,010,432   27,864
CHAPTERS:
5               0:18:35.739     0:04:03.368     30,340 kbps     43,670 kbps     00:20:45.702    38,276 kbps     00:18:48.043    35,573 kbps     00:20:49.289    158,180 bytes   562,801 bytes   00:20:46.286
6               0:22:39.107     0:02:08.378     30,119 kbps     39,929 kbps     00:23:38.750    36,338 kbps     00:22:41.485    35,237 kbps     00:22:41.485    157,026 bytes   513,560 bytes   00:22:40.776
7               0:24:47.485     0:02:03.456     27,616 kbps     41,068 kbps     00:26:12.779    32,596 kbps     00:25:05.629    32,138 kbps     00:25:00.749    143,929 bytes   551,990 bytes   00:26:28.837
8               0:26:50.942     0:02:22.058     33,010 kbps     45,811 kbps     00:28:10.063    37,958 kbps     00:28:27.622    36,390 kbps     00:28:59.362    172,148 bytes   493,011 bytes   00:29:04.617
9               0:29:13.001     0:02:15.593     33,326 kbps     43,081 kbps     00:30:44.801    36,893 kbps     00:31:09.701    36,097 kbps     00:31:10.451    173,746 bytes   518,123 bytes   00:29:55.376
10              0:31:28.595     0:04:30.395     31,647 kbps     43,611 kbps     00:34:09.714    38,034 kbps     00:34:06.294    35,302 kbps     00:34:01.330    164,994 bytes   654,734 bytes   00:33:23.418
11              0:35:58.990     0:03:10.732     31,442 kbps     45,170 kbps     00:38:10.579    37,586 kbps     00:36:56.881    36,132 kbps     00:36:52.668    163,925 bytes   549,013 bytes   00:37:17.193
12              0:39:09.722     0:03:04.642     25,660 kbps     41,601 kbps     00:39:25.070    34,760 kbps     00:39:25.071    31,216 kbps     00:39:22.485    133,778 bytes   515,088 bytes   00:39:25.112
13              0:42:14.365     0:03:18.823     29,875 kbps     42,910 kbps     00:42:36.679    36,726 kbps     00:42:35.844    35,618 kbps     00:43:30.649    155,756 bytes   543,930 bytes   00:43:27.771
14              0:45:33.188     0:07:18.271     28,314 kbps     47,931 kbps     00:50:33.822    38,194 kbps     00:50:33.113    34,537 kbps     00:46:35.626    147,603 bytes   553,383 bytes   00:52:51.459
15              0:52:51.459     0:06:45.029     27,329 kbps     50,470 kbps     00:56:19.918    38,720 kbps     00:56:37.936    35,626 kbps     00:55:58.188    142,498 bytes   620,037 bytes   00:55:10.765
16              0:59:36.489     0:02:18.638     29,287 kbps     44,878 kbps     01:00:31.294    38,410 kbps     00:59:45.373    35,137 kbps     01:00:37.967    152,688 bytes   568,844 bytes   01:01:22.011
17              1:01:55.127     0:02:44.247     31,340 kbps     49,262 kbps     01:03:25.009    37,604 kbps     01:03:44.528    36,243 kbps     01:03:47.114    163,391 bytes   602,505 bytes   01:03:25.968
18              1:04:39.375     0:04:19.676     30,035 kbps     49,485 kbps     01:06:38.160    38,352 kbps     01:08:36.820    36,076 kbps     01:06:17.515    156,590 bytes   622,682 bytes   01:07:18.534
19              1:08:59.051     0:01:40.517     26,328 kbps     43,367 kbps     01:10:15.919    33,105 kbps     01:09:11.355    30,202 kbps     01:09:11.355    137,261 bytes   594,243 bytes   01:10:15.961
20              1:10:39.568     0:03:34.547     29,209 kbps     47,372 kbps     01:13:05.756    38,263 kbps     01:13:04.463    35,831 kbps     01:13:02.127    152,284 bytes   597,593 bytes   01:11:17.606
21              1:14:14.116     0:04:11.668     30,501 kbps     52,104 kbps     01:18:02.093    38,893 kbps     01:15:56.802    36,314 kbps     01:17:53.543    158,994 bytes   776,410 bytes   01:18:02.135
22              1:18:25.784     0:02:54.465     24,910 kbps     48,190 kbps     01:20:55.266    38,319 kbps     01:20:55.266    34,857 kbps     01:20:55.266    129,869 bytes   547,109 bytes   01:20:55.976
23              1:21:20.250     0:07:25.111     16,371 kbps     37,657 kbps     01:27:51.182    35,768 kbps     01:27:47.136    34,857 kbps     01:27:43.174    85,352 bytes    726,263 bytes   01:27:47.220
24              1:28:45.361     0:00:44.753     32,160 kbps     52,874 kbps     01:29:25.902    39,263 kbps     01:28:54.871    36,655 kbps     01:28:53.995    167,670 bytes   456,914 bytes   01:29:25.943
25              1:29:30.114     0:00:01.000     102 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    579 bytes       788 bytes       01:29:30.406
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            AVC                                     386.845                 29,558                  1,429,273,667   7,773,219
00002.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           386.845                 4,375                   211,540,644     1,210,230
00002.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           386.845                 448                     21,668,864      120,920
00002.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            386.845                 448                     21,668,864      120,920
00002.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           386.845                 82                      3,974,273       22,584
00002.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           386.845                 55                      2,659,819       15,124
00002.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           386.845                 3                       139,453         808
00002.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            386.845                 3                       151,980         875
00002.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           386.845                 50                      2,435,884       14,022
00002.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           386.845                 53                      2,566,880       14,780
00002.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            386.845                 44                      2,151,212       12,452
00002.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              386.845                 43                      2,092,684       12,136
00004.M2TS      4113 (0x1011)   0x1B            AVC                                     438.104                 31,572                  1,729,005,805   9,402,938
00004.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           438.104                 4,416                   241,826,572     1,382,605
00004.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           438.104                 448                     24,541,440      136,950
00004.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            438.104                 448                     24,541,440      136,950
00004.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           438.104                 71                      3,886,397       22,044
00004.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           438.104                 50                      2,736,658       15,591
00004.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           438.104                 0                       0               0
00004.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            438.104                 0                       0               0
00004.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           438.104                 48                      2,636,661       15,189
00004.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           438.104                 50                      2,751,943       15,845
00004.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            438.104                 40                      2,175,893       12,669
00004.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              438.104                 42                      2,311,444       13,405
00006.M2TS      4113 (0x1011)   0x1B            AVC                                     282.324                 30,155                  1,064,196,153   5,787,668
00006.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           282.324                 4,066                   143,495,224     824,008
00006.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           282.324                 448                     15,821,568      88,290
00006.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            282.324                 448                     15,821,568      88,290
00006.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           282.324                 84                      2,955,037       16,804
00006.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           282.324                 63                      2,232,113       12,767
00006.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           282.324                 0                       0               0
00006.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            282.324                 0                       0               0
00006.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           282.324                 66                      2,329,758       13,442
00006.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           282.324                 67                      2,377,117       13,687
00006.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            282.324                 52                      1,847,648       10,757
00006.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              282.324                 52                      1,828,743       10,621
00008.M2TS      4113 (0x1011)   0x1B            AVC                                     45.128                  26,606                  150,085,088     816,317
00008.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           45.128                  4,123                   23,258,164      133,564
00008.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           45.128                  449                     2,533,888       14,140
00008.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            45.128                  449                     2,533,888       14,140
00008.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           45.128                  50                      283,951         1,610
00008.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           45.128                  50                      281,926         1,599
00008.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           45.128                  6                       35,562          202
00008.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            45.128                  10                      56,670          325
00008.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           45.128                  21                      117,283         679
00008.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           45.128                  21                      117,497         680
00008.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            45.128                  19                      108,477         631
00008.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              45.128                  12                      64,962          378
00010.M2TS      4113 (0x1011)   0x1B            AVC                                     731.731                 20,646                  1,888,438,665   10,273,427
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           731.731                 4,625                   422,992,196     2,412,869
00010.M2TS      4353 (0x1101)   0x81            AC3             spa (Spanish)           731.731                 448                     40,986,624      228,720
00010.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            731.731                 448                     40,986,624      228,720
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           731.731                 51                      4,687,360       26,694
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           731.731                 20                      1,825,180       10,463
00010.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           731.731                 0                       0               0
00010.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            731.731                 0                       0               0
00010.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           731.731                 20                      1,796,326       10,388
00010.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           731.731                 21                      1,913,597       11,009
00010.M2TS      4614 (0x1206)   0x90            PGS             kor (Korean)            731.731                 18                      1,639,767       9,523
00010.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              731.731                 18                      1,654,856       9,613
Extended Cut bitrate graph:
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #233 of 5099 Old 08-03-2009, 07:17 PM
msgohan's Avatar
This is on the catchup list; I originally posted it way back with BDInfo v0.2 when there was no extended info.
Eternal Sunshine of the Spotless Mind - Japan - GAGA Communications
Region ABC (confirmed w/PowerDVD set to all 3 regions)
Release: 2008-03-21
Code: GABLY-1276
Code:
        Total   Video
(JP) Eternal Sunshine of the Spotless Mind                      AVC     1:47:41 34,929,045,504  38,730,906,428  43.25   37.57   Dolby TrueHD 5.1 1163Kbps (48kHz/16-bit)  DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     BDROM
Disc Size:      38,730,906,428 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:47:41 (h:m:s)
Total Bitrate:          43.25 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        37567 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1163 kbps       5.1 / 48 kHz / 1163 kbps / 16-bit (AC3 Core: 5.1 / 48 kHz / 448 kbps)
Dolby Digital Audio             Japanese        448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           Japanese        118.504 kbps
Presentation Graphics           Japanese        1.876 kbps
Presentation Graphics           Japanese        234.866 kbps
FILES:
00000.M2TS      0:00:00.000     1:47:41.455     34,929,045,504  43,246
CHAPTERS:
1               0:00:00.000     0:03:42.722     37,911 kbps     43,915 kbps     00:02:08.378    40,311 kbps     00:02:04.415    39,742 kbps     00:01:03.563    197,615 bytes   381,148 bytes   00:02:19.931
2               0:03:42.722     0:06:48.032     39,316 kbps     41,531 kbps     00:09:41.539    39,781 kbps     00:09:22.436    39,670 kbps     00:06:16.626    204,977 bytes   319,027 bytes   00:07:54.098
3               0:10:30.755     0:02:54.090     38,795 kbps     43,063 kbps     00:11:11.212    39,863 kbps     00:11:07.124    39,590 kbps     00:12:24.535    202,259 bytes   297,079 bytes   00:11:11.712
4               0:13:24.845     0:04:12.543     38,761 kbps     42,913 kbps     00:17:34.344    40,174 kbps     00:16:38.831    39,660 kbps     00:16:33.909    202,081 bytes   331,578 bytes   00:16:43.585
5               0:17:37.389     0:01:57.450     38,230 kbps     41,657 kbps     00:18:14.259    39,605 kbps     00:19:17.072    39,582 kbps     00:19:12.192    199,316 bytes   283,167 bytes   00:19:13.110
6               0:19:34.840     0:05:36.461     38,605 kbps     43,831 kbps     00:23:25.987    40,236 kbps     00:20:04.828    39,716 kbps     00:23:16.978    201,268 bytes   365,694 bytes   00:21:02.344
7               0:25:11.301     0:02:49.002     39,176 kbps     43,822 kbps     00:26:24.332    40,190 kbps     00:26:16.449    39,896 kbps     00:26:11.361    204,245 bytes   321,166 bytes   00:26:25.000
8               0:28:00.303     0:07:07.760     39,223 kbps     46,410 kbps     00:29:13.793    40,164 kbps     00:29:01.072    39,729 kbps     00:29:45.283    204,490 bytes   359,285 bytes   00:34:30.485
9               0:35:08.064     0:07:58.019     38,321 kbps     44,415 kbps     00:37:35.503    40,420 kbps     00:37:31.499    39,871 kbps     00:37:26.452    199,788 bytes   309,086 bytes   00:37:00.468
10              0:43:06.083     0:06:22.507     38,328 kbps     41,494 kbps     00:43:15.217    39,729 kbps     00:49:11.657    39,648 kbps     00:49:06.652    199,822 bytes   321,025 bytes   00:47:18.293
11              0:49:28.590     0:02:44.622     38,920 kbps     41,521 kbps     00:49:47.025    39,750 kbps     00:51:23.371    39,608 kbps     00:50:25.022    202,909 bytes   288,275 bytes   00:51:17.157
12              0:52:13.213     0:07:10.763     37,639 kbps     43,460 kbps     00:57:50.300    40,065 kbps     00:57:46.379    39,698 kbps     00:58:10.278    196,234 bytes   459,901 bytes   00:57:50.967
13              0:59:23.977     0:03:28.750     39,317 kbps     43,449 kbps     01:02:23.072    39,974 kbps     01:02:19.068    39,748 kbps     01:02:14.063    204,980 bytes   329,689 bytes   01:02:50.099
14              1:02:52.727     0:12:57.193     38,603 kbps     43,058 kbps     01:05:25.296    40,348 kbps     01:05:21.250    39,791 kbps     01:08:31.190    201,258 bytes   400,428 bytes   01:09:46.682
15              1:15:49.920     0:05:37.879     38,606 kbps     42,780 kbps     01:21:00.522    40,083 kbps     01:18:28.745    39,809 kbps     01:18:23.824    201,276 bytes   291,321 bytes   01:19:39.399
16              1:21:27.799     0:02:54.382     38,312 kbps     41,057 kbps     01:22:22.228    39,714 kbps     01:21:52.574    39,513 kbps     01:22:45.502    199,743 bytes   313,824 bytes   01:23:13.029
17              1:24:22.182     0:07:22.483     37,227 kbps     47,208 kbps     01:31:19.599    40,201 kbps     01:27:44.676    39,716 kbps     01:27:39.796    194,084 bytes   331,873 bytes   01:31:20.433
18              1:31:44.665     0:04:07.080     38,995 kbps     41,640 kbps     01:33:43.284    39,901 kbps     01:33:46.662    39,674 kbps     01:33:22.555    203,304 bytes   307,024 bytes   01:34:22.323
19              1:35:51.746     0:08:13.534     38,743 kbps     44,239 kbps     01:36:35.956    40,358 kbps     01:36:31.952    39,818 kbps     01:40:50.210    201,986 bytes   331,557 bytes   01:38:51.342
20              1:44:05.280     0:03:33.504     9,686 kbps      18,799 kbps     01:46:44.773    17,768 kbps     01:46:43.772    16,561 kbps     01:46:41.019    50,497 bytes    274,312 bytes   01:46:45.440
21              1:47:38.785     0:00:02.669     393 kbps        413 kbps        01:47:39.619    0 kbps          00:00:00.000    0 kbps          00:00:00.000    2,083 bytes     3,413 bytes     01:47:39.786
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            AVC                                     6461.288                37,568                  30,342,239,120  164,994,031
00000.M2TS      4352 (0x1100)   0x83            TrueHD          eng (English)           6461.288                1,611                   1,301,428,872   10,048,516
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6461.288                448                     361,842,432     2,019,210
00000.M2TS      4354 (0x1102)   0x81            AC3             jpn (Japanese)          6461.288                448                     361,842,432     2,019,210
00000.M2TS      4355 (0x1103)   0x81            AC3             eng (English)           6461.288                192                     155,075,328     1,009,605
00000.M2TS      4608 (0x1200)   0x90            PGS             jpn (Japanese)          6461.288                119                     95,713,629      543,458
00000.M2TS      4609 (0x1201)   0x90            PGS             jpn (Japanese)          6461.288                2                       1,515,533       8,560
00000.M2TS      4610 (0x1202)   0x90            PGS             jpn (Japanese)          6461.288                235                     189,697,183     1,063,021
PS3, WD TV Live
msgohan is offline
post #234 of 5099 Old 08-03-2009, 08:53 PM - Thread Starter
Cinema Squid's Avatar
Thanks for these. I'm working my way backwards through the last thread to put in the post links and I'm picking up the catchup strays along the way. After that's finished, I'll put in the rest of the catchup titles (which I expect there will still be quite a few).
Cinema Squid is offline
post #235 of 5099 Old 08-03-2009, 09:00 PM - Thread Starter
Code:
        Video                                           Total
 Region  Year   Title                                                           Codec   Display Aspect  Bitrate Length  Movie Size      Disc Size       Bitrate Primary Language Audio
ABC [CZ] 2008   10,000 BC                                                       VC-1    1080p24 2.40:1  16.42   1:48:55 21,807,962,112  29,195,609,964  26.70   TrueHD  5.1    48/16  1666
ABC [CZ] 2006   300                                                             VC-1    1080p24 2.40:1  16.58   1:56:38 22,607,075,328  31,757,127,836  25.84   TrueHD  5.1    48/16  1734  / AC3     5.1    48     640
    [UK] 2006   FIFA World Cup 2006: All The Goals                               MPEG-2  1080i50 1.78:1  39.66   2:00:14 38,923,431,936  42,615,439,158  43.16   AC3     2.0           192
ABC [US] 2005   The Amateurs                                                     VC-1    1080p24 1.85:1  14.99   1:38:21 13,276,342,272  20,790,383,032  18.00   DTS     5.1    48     768   / AC3     5.1    48     640   / AC3     2.0    48     192
ABC [US] 2008   An American Carol                                                AVC     1080p24 2.35:1  23.40   1:22:27 15,893,200,896  19,345,519,028  25.70   AC3     5.1    48     448   / AC3     2.0    48     384
ABC [US] 1996   The Beast                                                       MPEG-2  720p60  1.78:1  15.30   2:53:38 21,245,300,736  21,316,627,764  16.31   AC3     2.0    48     192
ABC [US] 2007   Donkey X                                                        AVC     1080p24 2.35:1  19.10   1:27:25 15,711,725,568  17,167,864,148  23.96   DTS-MA  2.0    48/16  1587
ABC [JP] 2004   Eternal Sunshine of the Spotless Mind                            AVC     1080p24 1.85:1  37.57   1:47:41 34,929,045,504  38,730,906,428  43.25   TrueHD  5.1    48/16  1163  / AC3     5.1    48     448
ABC [US] 2007   The Heartbreak Kid                                              AVC     1080p24 2.35:1  37.55   1:55:33 39,777,447,936  42,900,518,448  45.90   TrueHD  5.1    48/24  2885
 BC [CZ] 2007   Hitman                                                          AVC     1080p24 2.35:1  15.97   1:34:14 17,420,937,216  24,394,242,396  24.65   DTS-HR  5.1    48/24  3018
A   [US] 1996   Jingle All the Way: Extended (seamless)                          AVC     1080p24 1.85:1  28.21   1:33:44 25,126,115,328  45,176,078,817  35.74   DTS-MA  5.1    48/24  4450
                                    Theatrical (seamless)                        AVC     1080p24 1.85:1  28.04   1:29:31 23,848,200,192                  35.52   DTS-MA  5.1    48/24  4450
A   [US] 1980   Kagemusha                                                       AVC     1080p24 1.85:1  21.27   3:00:36 34,499,653,632  49,708,896,608  25.47   DTS-MA  4.0    48/24  2586
A   [US] 1961   Last Year at Marienbad                                           AVC     1080p24 2.35:1  34.62   1:34:43 29,234,737,152  49,237,323,332  41.15   LPCM    1.0    48/24  1152  / LPCM    1.0    48/24  1152
ABC [UK] 2006   Pan's Labyrinth                                                  VC-1    1080p24 1.85:1  29.45   1:58:56 28,573,224,960  36,599,330,132  32.03   AC3     5.1    48     640   / AC3     2.0    48     224
A   [US] 1967   Play Time                                                       AVC     1080p24 1.85:1  24.49   2:04:34 24,532,033,536  49,161,111,601  26.26   LPCM    2.0    48/24  2304  / AC3     2.0    48     192
A   [US] 1965   Repulsion                                                        AVC     1080p24 1.66:1  34.56   1:45:16 30,681,366,528  44,993,411,114  38.86   LPCM    1.0    48/24  1152
ABC [UK] 1957   The Seventh Seal                                           AVC     1080p24 1.33:1  21.99   1:36:13 16,988,663,808  16,988,663,808  23.54   AC3     2.0    48     224
A   [US] 1984   This Is Spinal Tap                                               AVC     1080p24 1.85:1  32.98   1:22:50 24,071,086,080  35,143,834,301  38.75   DTS-MA  5.1    48/24  3129  / AC3     2.0    48     224
A   [US] 1974   The Towering Inferno                                             AVC     1080p24 2.35:1  24.82   2:44:53 39,291,930,624  48,243,804,187  31.77   DTS-MA  5.1    48/24  3555  / AC3     4.0    48     448   / AC3     2.0    48     224
ABC [AU] 1998   The Truman Show                                                  AVC     1080p24 1.78:1  35.83   1:42:56 36,109,633,536  40,804,594,163  46.77   TrueHD  5.1    48/24  3672
post #236 of 5099 Old 08-04-2009, 12:18 PM
msgohan's Avatar
Yay, properly aligned single-region titles!
For what it's worth, the Canadian release of Final Destination is identical to the US release, including disc size. Just different cover and disc art.
Has anyone confirmed that the Firefly complete series set is really ABC like the list states? Cause the back cover claims Region AB. I don't own it, just noticed that on Whiggles' site.
Not sure if Crash has been posted with full specs (search was broken when I tried), but I just wanted to get you to list it as "Director's Cut Edition" since that's what the spine states.
Crash (Director's Cut) - United States - Lionsgate
Release: 2006-06-27
Code:
        Total   Video
Crash: Director's Cut Edition (2005)                            MPEG-2  1:55:00 20,942,321,664  21,736,091,712  24.28   20.78   DTS 6.1-ES 1509Kbps (48kHz/24-bit)        DD AC3 5.1-EX 640Kbps
Code:
DISC INFO:
Disc Title:     LOGICAL_VOLUME_ID (98828491_CRASH_BD)
Disc Size:      21,736,091,712 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:55:00 (h:m:s)
Total Bitrate:          24.28 Mbps
Description:
VIDEO:
MPEG-2 Video            20778 kbps          1080p / 23.976 fps / 16:9
AUDIO:
DTS-ES Audio                    English         1509 kbps       6.1-ES / 48 kHz / 1509 kbps / 24-bit
Dolby Digital EX Audio          English         640 kbps        5.1-EX / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         38.736 kbps
Presentation Graphics           Spanish         30.050 kbps
FILES:
00000.M2TS      0:00:00.000     1:55:00.894     20,942,321,664  24,278
CHAPTERS:
1               0:00:00.000     0:07:48.342     17,046 kbps     35,615 kbps     00:00:16.307    25,820 kbps     00:00:14.514    24,186 kbps     00:06:33.017    88,863 bytes    572,535 bytes   00:06:03.654
2               0:07:48.342     0:08:28.424     21,884 kbps     32,484 kbps     00:10:23.247    28,369 kbps     00:10:23.164    26,678 kbps     00:10:23.205    114,095 bytes   591,718 bytes   00:15:14.330
3               0:16:16.767     0:08:52.406     22,505 kbps     36,614 kbps     00:17:17.870    28,378 kbps     00:17:17.578    27,090 kbps     00:16:35.244    117,332 bytes   576,320 bytes   00:22:12.998
4               0:25:09.174     0:10:09.775     20,965 kbps     31,943 kbps     00:30:51.474    25,666 kbps     00:33:08.861    24,172 kbps     00:33:03.856    109,304 bytes   568,734 bytes   00:33:10.405
5               0:35:18.950     0:07:39.876     20,846 kbps     33,769 kbps     00:40:05.027    24,793 kbps     00:37:42.093    23,757 kbps     00:42:48.816    108,681 bytes   560,326 bytes   00:36:37.361
6               0:42:58.826     0:06:27.553     20,150 kbps     29,390 kbps     00:46:22.029    25,356 kbps     00:43:45.039    24,368 kbps     00:43:44.204    105,053 bytes   543,499 bytes   00:47:27.761
7               0:49:26.380     0:10:59.909     20,429 kbps     33,870 kbps     00:58:40.141    25,089 kbps     00:50:11.883    24,016 kbps     00:50:10.257    106,509 bytes   589,422 bytes   00:55:16.354
8               1:00:26.289     0:06:05.865     22,186 kbps     39,282 kbps     01:04:48.259    35,018 kbps     01:05:28.674    29,114 kbps     01:05:27.757    115,669 bytes   573,600 bytes   01:03:10.578
9               1:06:32.154     0:09:29.026     21,141 kbps     33,122 kbps     01:15:50.796    27,665 kbps     01:15:48.669    26,922 kbps     01:15:44.414    110,217 bytes   592,909 bytes   01:14:22.374
10              1:16:01.181     0:09:31.570     21,259 kbps     34,536 kbps     01:22:38.286    27,298 kbps     01:23:50.275    25,893 kbps     01:23:48.690    110,835 bytes   587,097 bytes   01:22:59.891
11              1:25:32.752     0:07:51.429     22,703 kbps     30,944 kbps     01:31:13.843    26,968 kbps     01:31:09.839    26,087 kbps     01:29:08.426    118,363 bytes   530,787 bytes   01:33:24.181
12              1:33:24.181     0:07:51.721     20,358 kbps     31,488 kbps     01:34:03.262    24,121 kbps     01:34:21.656    23,383 kbps     01:34:22.448    106,136 bytes   593,450 bytes   01:37:49.530
13              1:41:15.903     0:06:23.299     21,172 kbps     33,956 kbps     01:46:08.987    26,804 kbps     01:45:30.699    25,394 kbps     01:46:08.987    110,379 bytes   542,917 bytes   01:46:13.658
14              1:47:39.202     0:07:20.690     17,956 kbps     29,866 kbps     01:48:21.620    28,366 kbps     01:50:43.637    27,524 kbps     01:50:39.132    93,616 bytes    520,490 bytes   01:49:00.700
15              1:54:59.893     0:00:01.001     737 kbps        0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    4,011 bytes     43,989 bytes    01:55:00.435
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x02            MPEG-2                                  6900.769                20,778                  17,923,281,057  97,505,591
00000.M2TS      4352 (0x1100)   0x82            DTS-ES          eng (English)           6900.769                1,509                   1,301,681,508   7,763,508
00000.M2TS      4353 (0x1101)   0x81            AC3-EX          eng (English)           6900.769                640                     552,071,680     3,234,795
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6900.769                39                      33,413,769      190,148
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6900.769                30                      25,921,186      149,322
PS3, WD TV Live
msgohan is offline
post #237 of 5099 Old 08-04-2009, 01:38 PM
msgohan's Avatar
Hostage - Canada - Alliance
Release: 2009-01-06
Code:
        Total   Video
(CA) Hostage (1080i60)                                          AVC     1:53:12 17,967,495,168  18,046,318,404  21.16   15.00   DTS-HD Master 5.1 4032Kbps (48kHz/24-bit) DD AC3 5.1 448Kbps
Code:
DISC INFO:
Disc Title:     HOSTAGE
Disc Size:      18,046,318,404 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:53:12 (h:m:s)
Total Bitrate:          21.16 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        15000 kbps          1080i / 29.970 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4032 kbps       5.1 / 48 kHz / 4032 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             English         448 kbps        5.1 / 48 kHz / 448 kbps
SUBTITLES:
Presentation Graphics           French          0.119 kbps
FILES:
00003.M2TS      0:00:00.000     1:53:12.819     17,967,495,168  21,161
CHAPTERS:
1               0:00:00.000     0:03:21.167     11,767 kbps     33,847 kbps     00:00:02.135    27,157 kbps     00:00:01.034    22,657 kbps     00:00:23.790    49,069 bytes    296,958 bytes   00:00:04.804
2               0:03:21.167     0:07:28.881     17,775 kbps     33,734 kbps     00:04:38.778    29,254 kbps     00:08:20.766    26,705 kbps     00:07:58.711    74,138 bytes    294,115 bytes   00:08:33.312
3               0:10:50.049     0:07:53.940     17,625 kbps     32,760 kbps     00:10:52.618    28,203 kbps     00:13:34.647    26,856 kbps     00:13:33.245    73,509 bytes    297,802 bytes   00:17:35.354
4               0:18:43.989     0:03:54.033     16,315 kbps     28,999 kbps     00:19:12.384    23,876 kbps     00:19:08.747    21,584 kbps     00:19:06.211    68,045 bytes    290,013 bytes   00:18:47.593
5               0:22:38.023     0:04:20.994     18,332 kbps     33,247 kbps     00:25:38.637    28,890 kbps     00:25:37.536    25,878 kbps     00:25:34.299    76,459 bytes    296,703 bytes   00:26:02.561
6               0:26:59.017     0:03:10.623     13,520 kbps     28,952 kbps     00:27:12.797    23,504 kbps     00:27:08.927    21,764 kbps     00:27:08.927    56,389 bytes    285,248 bytes   00:28:00.645
7               0:30:09.641     0:05:42.542     13,886 kbps     32,957 kbps     00:33:11.622    24,888 kbps     00:33:08.753    19,883 kbps     00:33:03.781    57,915 bytes    299,591 bytes   00:30:17.282
8               0:35:52.183     0:03:43.556     15,598 kbps     29,680 kbps     00:37:57.842    27,518 kbps     00:37:57.241    25,660 kbps     00:37:54.772    65,055 bytes    295,864 bytes   00:39:26.163
9               0:39:35.740     0:07:12.899     15,181 kbps     34,977 kbps     00:41:41.966    33,348 kbps     00:41:40.130    31,949 kbps     00:41:39.964    63,315 bytes    298,217 bytes   00:42:10.661
10              0:46:48.639     0:04:48.621     15,869 kbps     35,568 kbps     00:49:09.813    31,923 kbps     00:49:06.276    25,023 kbps     00:49:02.606    66,186 bytes    298,131 bytes   00:48:43.720
11              0:51:37.260     0:10:21.420     14,846 kbps     32,232 kbps     00:58:31.207    28,227 kbps     00:58:27.203    23,847 kbps     00:58:28.238    61,922 bytes    292,683 bytes   00:56:01.658
12              1:01:58.681     0:04:46.319     12,636 kbps     26,620 kbps     01:03:27.637    19,168 kbps     01:03:38.681    16,661 kbps     01:03:33.609    52,704 bytes    286,559 bytes   01:03:26.469
13              1:06:45.001     0:04:56.195     12,880 kbps     28,176 kbps     01:08:16.692    22,855 kbps     01:08:15.424    20,047 kbps     01:08:13.422    53,720 bytes    270,368 bytes   01:09:34.203
14              1:11:41.196     0:08:24.303     14,627 kbps     27,696 kbps     01:19:00.736    23,662 kbps     01:18:58.100    22,297 kbps     01:18:57.833    61,009 bytes    294,462 bytes   01:14:55.123
15              1:20:05.500     0:07:41.394     13,654 kbps     33,337 kbps     01:25:17.579    23,659 kbps     01:20:13.275    21,342 kbps     01:20:08.703    56,948 bytes    296,758 bytes   01:22:17.399
16              1:27:46.894     0:09:50.323     16,813 kbps     35,926 kbps     01:32:42.557    31,113 kbps     01:37:08.155    28,331 kbps     01:37:03.484    70,125 bytes    295,807 bytes   01:32:43.357
17              1:37:37.218     0:10:04.770     16,037 kbps     34,458 kbps     01:44:14.381    29,262 kbps     01:44:13.547    27,778 kbps     01:44:07.241    66,888 bytes    295,716 bytes   01:44:12.379
18              1:47:41.988     0:05:30.830     8,034 kbps      15,362 kbps     01:52:22.302    14,110 kbps     01:52:20.500    11,952 kbps     01:52:18.031    33,512 bytes    150,937 bytes   01:52:24.137
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0x1B            AVC                                     6792.753                15,000                  12,736,408,827  69,440,681
00003.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6792.753                4,032                   3,423,647,748   19,666,303
00003.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6792.753                448                     380,400,384     2,122,770
00003.M2TS      4354 (0x1102)   0x81            AC3             fra (French)            6792.753                448                     380,400,384     2,122,770
00003.M2TS      4608 (0x1200)   0x90            PGS             fra (French)            6792.753                0                       101,368         587
Presented in 1.78:1, OAR is 2.35:1. I compared it to some DVD screenshots and it's opened up rather than cropped like some other Alliance titles.
I have no idea what the tiny French subtitle track is, if anything. The popup menu only allows you to change audio tracks.
PS3, WD TV Live
msgohan is offline
post #238 of 5099 Old 08-04-2009, 04:48 PM - Thread Starter
[US] Mutant Chronicles (Additional Details)
Region Free (ABC) (confirmed w/ PowerDVD 8)
Studio: Magnolia
Release Date: 2009-08-04
UPC: 876964001977
Subs: English (SDH), Spanish
Code:
        Total   Video
Mutant Chronicles                                               VC-1    1:40:49 28,420,159,488  40,422,392,524  37.59   31.20   DTS-HD Master 5.1 4232Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     MUTANT_CHRONICLES
Disc Size:      40,422,392,524 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:40:49 (h:m:s)
Total Bitrate:          37.59 Mbps
Description:
VIDEO:
VC-1 Video              31202 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         4232 kbps       5.1 / 48 kHz / 4232 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
SUBTITLES:
Presentation Graphics           English         27.680 kbps
Presentation Graphics           Spanish         24.947 kbps
FILES:
00000.M2TS      0:00:00.000     1:40:49.043     28,420,159,488  37,586
CHAPTERS:
1               0:00:00.000     0:15:23.631     33,384 kbps     53,786 kbps     00:13:58.212    42,055 kbps     00:07:17.353    39,826 kbps     00:05:45.386    174,041 bytes   743,217 bytes   00:11:33.567
2               0:15:23.631     0:03:42.513     32,780 kbps     55,670 kbps     00:17:23.459    42,310 kbps     00:18:04.792    39,967 kbps     00:17:32.176    170,900 bytes   696,613 bytes   00:18:09.671
3               0:19:06.145     0:04:56.129     32,161 kbps     52,980 kbps     00:20:37.402    41,439 kbps     00:19:44.266    39,438 kbps     00:21:35.210    167,672 bytes   716,915 bytes   00:23:43.088
4               0:24:02.274     0:06:08.618     32,805 kbps     56,126 kbps     00:26:39.139    40,145 kbps     00:24:22.794    38,706 kbps     00:24:22.377    171,028 bytes   676,219 bytes   00:28:32.001
5               0:30:10.892     0:07:46.257     34,164 kbps     57,094 kbps     00:30:43.716    43,466 kbps     00:31:48.281    41,296 kbps     00:30:48.388    178,118 bytes   715,572 bytes   00:37:17.234
6               0:37:57.149     0:08:33.346     33,509 kbps     57,540 kbps     00:43:08.168    41,742 kbps     00:43:34.403    39,337 kbps     00:43:30.816    174,984 bytes   810,499 bytes   00:44:01.639
7               0:46:30.496     0:06:32.642     33,716 kbps     49,927 kbps     00:51:03.977    41,271 kbps     00:46:46.178    39,324 kbps     00:48:19.688    175,779 bytes   645,696 bytes   00:52:15.590
8               0:53:03.138     0:14:11.100     33,661 kbps     56,903 kbps     01:01:03.326    42,267 kbps     00:59:17.804    40,613 kbps     00:59:14.717    175,493 bytes   620,869 bytes   00:58:19.078
9               1:07:14.238     0:05:27.201     32,128 kbps     59,967 kbps     01:10:32.227    42,212 kbps     01:08:45.663    38,520 kbps     01:08:22.389    167,498 bytes   573,594 bytes   01:09:16.694
10              1:12:41.440     0:11:14.340     32,564 kbps     60,958 kbps     01:12:45.360    42,889 kbps     01:12:41.440    39,517 kbps     01:15:32.110    169,774 bytes   696,903 bytes   01:19:10.245
11              1:23:55.780     0:09:12.802     33,411 kbps     58,486 kbps     01:25:08.728    42,311 kbps     01:32:08.689    39,441 kbps     01:32:07.021    174,520 bytes   676,863 bytes   01:27:06.220
12              1:33:08.583     0:07:39.417     6,609 kbps      14,403 kbps     01:37:28.551    13,979 kbps     01:37:26.131    13,546 kbps     01:37:23.295    35,687 bytes    215,543 bytes   01:40:34.028
13              1:40:48.000     0:00:01.042     200 kbps        209 kbps        01:40:48.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    2,174 bytes     9,236 bytes     01:40:49.001
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    6048.960                31,202                  23,592,555,309  128,308,115
00000.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           6048.960                4,232                   3,200,216,456   18,337,024
00000.M2TS      4353 (0x1101)   0x81            AC3             eng (English)           6048.960                224                     169,372,672     945,160
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           6048.960                28                      20,929,563      120,542
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           6048.960                25                      18,862,955      108,161
post #239 of 5099 Old 08-04-2009, 04:58 PM - Thread Starter
[US] Race to Witch Mountain (Additional Details)
Region Locked (AC) (confirmed w/ PowerDVD 8)
Studio: Disney
UPC: 786936787252
Aspect Ratio: 2.40:1
Subs: English (SDH), Chinese (Simplified), Chinese (Traditional), Chinese (Unknown), French, French (Text), Indonesian, Korean, Malay, Portuguese, Portuguese (Text), Spanish, Spanish (Text), Thai, Thai (Text)
Another Region AC title from Disney. There is a cool special feature on the disc - an HD trailer for Ponyo.
Code:
        Total   Video
Race to Witch Mountain                                          AVC     1:38:17 27,729,967,104  36,453,440,969  37.61   28.05   DTS-HD Master 5.1 3903Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Title:     WTM1NNE1
Disc Size:      36,453,440,969 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:38:17 (h:m:s)
Total Bitrate:          37.61 Mbps
Description:
VIDEO:
MPEG-4 AVC Video        28054 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         3903 kbps       5.1 / 48 kHz / 3903 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio             Chinese         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             French          640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48 kHz / 640 kbps
Dolby Digital Audio             Thai            640 kbps        5.1 / 48 kHz / 640 kbps
SUBTITLES:
Presentation Graphics           English         31.685 kbps
Presentation Graphics           Chinese         24.274 kbps
Presentation Graphics           Chinese         23.477 kbps
Presentation Graphics           Chinese         27.222 kbps
Presentation Graphics           Chinese         0.721 kbps
Presentation Graphics           French          29.837 kbps
Presentation Graphics           French          0.866 kbps
Presentation Graphics           Indonesian      30.636 kbps
Presentation Graphics           Korean          18.560 kbps
Presentation Graphics           Malay           34.703 kbps
Presentation Graphics           Portuguese      29.378 kbps
Presentation Graphics           Portuguese      0.856 kbps
Presentation Graphics           Spanish         27.054 kbps
Presentation Graphics           Spanish         0.811 kbps
Presentation Graphics           Thai            23.134 kbps
Presentation Graphics           Thai            0.421 kbps
FILES:
00125.M2TS      0:00:00.000     1:38:17.933     27,729,967,104  37,613
CHAPTERS:
1               0:00:00.000     0:09:08.548     29,376 kbps     48,603 kbps     00:01:56.324    37,945 kbps     00:08:05.776    37,126 kbps     00:08:00.771    153,142 bytes   711,810 bytes   00:01:46.106
2               0:09:08.548     0:03:58.237     33,072 kbps     41,078 kbps     00:11:53.170    36,489 kbps     00:10:47.104    36,263 kbps     00:10:19.493    172,421 bytes   417,350 bytes   00:13:06.452
3               0:13:06.785     0:04:19.592     31,397 kbps     45,839 kbps     00:16:19.770    36,740 kbps     00:14:48.721    36,473 kbps     00:13:07.036    163,688 bytes   430,778 bytes   00:13:17.046
4               0:17:26.378     0:10:02.101     26,200 kbps     42,714 kbps     00:26:53.737    36,926 kbps     00:17:55.949    35,599 kbps     00:27:18.470    136,597 bytes   440,247 bytes   00:26:54.571
5               0:27:28.480     0:08:20.666     28,422 kbps     41,806 kbps     00:30:46.803    36,501 kbps     00:34:01.622    36,388 kbps     00:33:57.952    148,181 bytes   390,877 bytes   00:31:48.656
6               0:35:49.147     0:05:50.600     25,439 kbps     38,333 kbps     00:41:14.388    33,768 kbps     00:35:52.483    31,844 kbps     00:36:59.550    132,627 bytes   324,564 bytes   00:39:08.387
7               0:41:39.747     0:06:52.703     23,960 kbps     40,450 kbps     00:44:18.030    36,118 kbps     00:46:44.593    36,081 kbps     00:46:39.296    124,919 bytes   367,440 bytes   00:46:12.686
8               0:48:32.451     0:09:11.842     26,469 kbps     39,518 kbps     00:54:24.219    36,680 kbps     00:53:48.475    36,005 kbps     00:49:55.242    138,000 bytes   408,920 bytes   00:53:48.934
9               0:57:44.294     0:09:01.374     30,446 kbps     41,150 kbps     01:03:49.200    36,299 kbps     01:05:49.111    35,903 kbps     01:05:45.066    158,730 bytes   393,179 bytes   01:04:12.431
10              1:06:45.668     0:06:16.334     30,080 kbps     43,725 kbps     01:12:40.898    37,583 kbps     01:12:36.894    36,571 kbps     01:09:14.692    156,821 bytes   520,731 bytes   01:09:51.103
11              1:13:02.002     0:20:42.366     29,237 kbps     47,006 kbps     01:26:00.780    37,222 kbps     01:30:15.993    36,356 kbps     01:21:38.852    152,431 bytes   508,291 bytes   01:14:26.920
12              1:33:44.368     0:04:33.564     21,097 kbps     38,369 kbps     01:38:06.171    35,062 kbps     01:34:32.333    28,371 kbps     01:34:30.206    110,007 bytes   360,323 bytes   01:34:32.375
STREAM DIAGNOSTICS:
00125.M2TS      4113 (0x1011)   0x1B            AVC                                     5897.767                28,055                  20,682,602,321  112,488,178
00125.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           5897.767                3,903                   2,877,485,576   16,557,686
00125.M2TS      4353 (0x1101)   0x81            AC3             fra (French)            5897.767                640                     471,836,160     2,764,665
00125.M2TS      4354 (0x1102)   0x81            AC3             spa (Spanish)           5897.767                640                     471,836,160     2,764,665
00125.M2TS      4355 (0x1103)   0x81            AC3             por (Portuguese)        5897.767                640                     471,836,160     2,764,665
00125.M2TS      4356 (0x1104)   0x81            AC3             zho (Chinese)           5897.767                640                     471,836,160     2,764,665
00125.M2TS      4357 (0x1105)   0x81            AC3             tha (Thai)              5897.767                640                     471,836,160     2,764,665
00125.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5897.767                32                      23,359,296      134,627
00125.M2TS      4609 (0x1201)   0x90            PGS             fra (French)            5897.767                30                      21,996,845      126,641
00125.M2TS      4610 (0x1202)   0x90            PGS             spa (Spanish)           5897.767                27                      19,945,351      115,375
00125.M2TS      4611 (0x1203)   0x90            PGS             por (Portuguese)        5897.767                29                      21,658,420      124,767
00125.M2TS      4612 (0x1204)   0x90            PGS             zho (Chinese)           5897.767                24                      17,896,103      104,441
00125.M2TS      4613 (0x1205)   0x90            PGS             zho (Chinese)           5897.767                23                      17,308,389      101,343
00125.M2TS      4614 (0x1206)   0x90            PGS             zho (Chinese)           5897.767                27                      20,069,080      116,817
00125.M2TS      4615 (0x1207)   0x90            PGS             tha (Thai)              5897.767                23                      17,055,562      99,906
00125.M2TS      4616 (0x1208)   0x90            PGS             kor (Korean)            5897.767                19                      13,683,173      81,358
00125.M2TS      4617 (0x1209)   0x90            PGS             ind (Indonesian)        5897.767                31                      22,585,788      129,906
00125.M2TS      4618 (0x120A)   0x90            PGS             msa (Malay)             5897.767                35                      25,584,372      146,452
00125.M2TS      4619 (0x120B)   0x90            PGS             fra (French)            5897.767                1                       638,760         3,659
00125.M2TS      4620 (0x120C)   0x90            PGS             spa (Spanish)           5897.767                1                       597,988         3,465
00125.M2TS      4621 (0x120D)   0x90            PGS             por (Portuguese)        5897.767                1                       631,134         3,638
00125.M2TS      4622 (0x120E)   0x90            PGS             zho (Chinese)           5897.767                1                       531,768         3,129
00125.M2TS      4623 (0x120F)   0x90            PGS             tha (Thai)              5897.767                0                       310,550         1,843
post #240 of 5099 Old 08-05-2009, 01:40 PM
Snowknight26's Avatar
Quoted: 26 Post(s)
Liked: 27
Delta Farce
US Release
Code:
        Total   Video
00000.MPLS                                                      VC-1    1:29:27 28,442,339,328  35,414,861,702  42.39   33.36   LPCM 7.1 6144Kbps (48kHz/16-bit)          DD AC3 5.1-EX 640Kbps
Code:
DISC INFO:
Disc Title:     03076588_DELTA_FARCE_BD
Disc Size:      35,414,861,702 bytes
Protection:     AACS
BD-Java:        No
BDInfo:         0.5.2
PLAYLIST REPORT:
Length:                 1:29:27 (h:m:s)
Total Bitrate:          42.39 Mbps
Description:
VIDEO:
VC-1 Video              33357 kbps          1080p / 23.976 fps / 16:9 / Advanced Profile 3
AUDIO:
LPCM Audio                      English         6144 kbps       7.1 / 48 kHz / 6144 kbps / 16-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics           English         43.188 kbps
Presentation Graphics           Spanish         47.628 kbps
FILES:
00000.M2TS      0:00:00.000     1:29:27.528     28,442,339,328  42,392
CHAPTERS:
1               0:00:00.000     0:07:59.270     34,141 kbps     50,071 kbps     00:06:48.783    39,140 kbps     00:05:17.692    37,639 kbps     00:03:48.770    178,963 bytes   416,971 bytes   00:07:59.270
2               0:07:59.270     0:04:05.703     35,115 kbps     45,522 kbps     00:11:24.225    39,526 kbps     00:10:39.305    37,715 kbps     00:10:34.300    183,072 bytes   456,121 bytes   00:11:55.756
3               0:12:04.974     0:07:17.478     34,787 kbps     50,330 kbps     00:14:04.426    41,120 kbps     00:12:41.719    38,419 kbps     00:12:10.938    181,363 bytes   457,130 bytes   00:15:05.112
4               0:19:22.452     0:04:59.007     35,084 kbps     44,062 kbps     00:23:19.981    39,104 kbps     00:23:16.812    37,452 kbps     00:23:29.491    182,912 bytes   456,479 bytes   00:22:41.234
5               0:24:21.460     0:05:41.674     35,018 kbps     44,422 kbps     00:29:48.119    38,940 kbps     00:29:18.506    37,537 kbps     00:29:13.877    182,570 bytes   491,618 bytes   00:28:08.770
6               0:30:03.134     0:05:06.014     35,301 kbps     48,464 kbps     00:31:41.566    39,104 kbps     00:31:37.604    37,750 kbps     00:31:34.559    184,043 bytes   496,010 bytes   00:31:11.578
7               0:35:09.148     0:07:33.244     34,377 kbps     46,296 kbps     00:37:13.898    38,969 kbps     00:35:29.669    37,495 kbps     00:37:22.990    179,227 bytes   540,814 bytes   00:36:10.126
8               0:42:42.393     0:04:29.227     31,371 kbps     43,848 kbps     00:43:05.958    39,206 kbps     00:44:33.420    37,529 kbps     00:42:47.231    163,553 bytes   455,587 bytes   00:43:11.630
9               0:47:11.620     0:06:28.721     34,557 kbps     44,525 kbps     00:47:22.506    39,711 kbps     00:47:20.462    37,697 kbps     00:47:33.892    180,166 bytes   624,316 bytes   00:53:24.117
10              0:53:40.342     0:07:18.896     35,071 kbps     47,369 kbps     00:59:33.778    40,136 kbps     01:00:35.214    37,697 kbps     00:59:15.385    182,843 bytes   502,615 bytes   00:59:11.589
11              1:00:59.238     0:07:56.517     31,536 kbps     47,617 kbps     01:03:37.813    39,625 kbps     01:03:34.101    37,660 kbps     01:08:43.911    164,416 bytes   552,647 bytes   01:02:29.954
12              1:08:55.756     0:01:34.761     33,531 kbps     40,734 kbps     01:09:17.528    38,831 kbps     01:09:16.777    37,172 kbps     01:09:16.110    174,817 bytes   352,177 bytes   01:09:30.833
13              1:10:30.517     0:03:04.142     33,794 kbps     47,478 kbps     01:11:51.265    38,672 kbps     01:12:40.981    37,269 kbps     01:10:41.654    176,184 bytes   399,104 bytes   01:11:43.841
14              1:13:34.660     0:02:35.780     29,717 kbps     42,948 kbps     01:14:13.157    40,416 kbps     01:14:09.153    33,822 kbps     01:14:05.858    154,932 bytes   404,450 bytes   01:14:13.949
15              1:16:10.440     0:03:04.976     33,980 kbps     48,797 kbps     01:17:13.712    39,756 kbps     01:18:06.098    37,450 kbps     01:17:07.414    177,156 bytes   455,531 bytes   01:18:11.061
16              1:19:15.417     0:10:12.111     28,393 kbps     47,963 kbps     01:24:44.079    39,209 kbps     01:26:20.175    37,683 kbps     01:26:20.175    148,401 bytes   434,299 bytes   01:26:52.749
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            VC-1                                    5367.404                33,357                  22,380,278,475  121,709,791
00000.M2TS      4352 (0x1100)   0x80            LPCM            eng (English)           5367.404                6,151                   4,126,557,064   22,543,626
00000.M2TS      4353 (0x1101)   0x81            AC3-EX          eng (English)           5367.404                640                     429,404,160     2,516,040
00000.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           5367.404                192                     128,821,248     838,680
00000.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           5367.404                43                      28,976,659      166,272
00000.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           5367.404                48                      31,955,649      182,920
Snowknight26 is offline
Reply Blu-ray Software
Blu Ray Movies , Enders Game Ultraviolet Digital Copy Blu Ray
