Ghostbusters comparison *PIX* - Page 8 - AVS Forum | Home Theater Discussions And Reviews
Old 10-03-2014, 06:33 PM
raoul_duke's Avatar
Liked: 32
No.
raoul_duke is offline
Old 10-04-2014, 07:55 AM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Yes it does. It's the same disc as the "4K" single release. I didn't hear anything about Sony doing another transfer.
home theater addict
saprano is offline
Old 10-04-2014, 11:04 AM
KMFDMvsEnya's Avatar
Quoted: 237 Post(s)
Liked: 395
It is a new encode, from the same 4K master/transfer used for the prior Mi4K release, the bitrate is a bit lower but the differences are not egregiously noticeable. If one desires the utmost quality currently available for BR pickup the Mi4K but again the differences are marginal.
Unlike another release that had a new encode with a lower bitrate that has various compressions artifacts that no one noticed but were quite apparent upon my viewing of STID IMAX edition.
Best regards,
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
Old 10-04-2014, 03:59 PM
Phantom Stranger's Avatar
Quoted: 380 Post(s)
Liked: 280
If you are watching on a gigantic screen, it's probably wise for videophiles to stick with the original 4K solo release.
AVSforum's Blu-ray Picture Quality Rankings (Updated through May 30, 2016)
Phantom Stranger is offline
Old 10-06-2014, 05:47 PM
raoul_duke's Avatar
Liked: 32
You're wrong. They did re-encode it.
Old 10-06-2014, 08:02 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
Had no idea it had a new encode. Are there any comparison pictures?
home theater addict
saprano is offline
Old 10-07-2014, 01:04 PM
Jason One's Avatar
http://screenshotcomparison.com/comparison.php?id=90204
Jason One is offline
Old 10-07-2014, 05:45 PM
saprano's Avatar
Quoted: 539 Post(s)
Liked: 527
It looks exactly the same.
home theater addict
saprano is offline
Old 10-07-2014, 10:38 PM
Jason One's Avatar
Nope. The MI4K version has ever-so-slightly finer detail and grain reproduction. The double-feature encode is comparatively smoother.
Old 10-08-2014, 11:26 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
Only visible when flipping back and forth between static screenshots. And even then, just barely. This is the very definition of a negligible difference.
Anyone who doesn't already have the prior Mi4k disc can safely buy the new two-pack and not worry about the video quality.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
Old 10-08-2014, 12:25 PM
Jason One's Avatar
Sure, but they are not "exactly the same."
Old 10-19-2014, 05:07 PM
RWetmore's Avatar
Quoted: 360 Post(s)
Liked: 198
I have both and the Mi4K version has an average bit rate about 8-10 mbps higher than the most recent release with GB 2, though they are clearly from the same master. The condition of the film elements or the original quality of the shooting is not particularly good for whatever reason; however, GB 2 looks really good overall.
RWetmore is offline
