Heat - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #571 of 580 Old 03-15-2015, 11:00 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5310 Post(s)
Liked: 4190
Originally Posted by Dan Hitchman View Post
It's the audio mix for this particular Blu-ray release I have a problem with. The dialog is so much lower than the background sound effects and music. Crank things up to hear the dialog, and then blow out your speakers when a gun battle happens.
Typical Michael Mann mix, right there.
Scott Simonian is online now
post #572 of 580 Old 03-16-2015, 10:18 AM
DavidHir's Avatar
Quoted: 1708 Post(s)
Liked: 1330
Originally Posted by 357mag View Post
Never seen Avatar. But Heat on Blu-ray looked brown and soft and fuzzy and unclear. That is opposite to what a high def Blu-ray should be.
You might want to get your display professionally calibrated as if anything it looked a bit more teal (per director's guidance) vs brown. I watched it at 124" on a JVC RS4810 paired with a Stewart ST100 screen and it was not fuzzy and unclear. Yes, it does have a bit of a softer look and a bit grainy but that is the way it was made. Not every movie is going to be or supposed to be razor sharp and grainless.
DavidHir is online now
post #573 of 580 Old 03-16-2015, 10:59 AM
Tompa's Avatar
Quoted: 32 Post(s)
Liked: 49
Not to sound like an ass but why don't you just raise the center channel?
Tompa is offline
post #574 of 580 Old 03-16-2015, 11:23 AM
Bass Enabler
Liked: 4190
Because that will not change the balance between dialog and music/sfx.
Dan Hitchman and tenthplanet like this.
post #575 of 580 Old 03-19-2015, 12:11 AM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 749 Post(s)
Liked: 663
It's not just this, there are a lot of movies where the dynamic range works in a large commerical theater but in a home setting you had better keep the remote for the volume handy. A prime offender would be Star Trek Into Darkness, love the movie but the dynamic range is just crazy for the average sized room.
Of course there is always crank it and go deaf option. Oblivion anyone?
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is online now
post #576 of 580 Old 03-19-2015, 12:20 AM
Bass Enabler
Liked: 4190
Actually, STID is just plain loud which is different from dynamic. Tons of clipping too which compounds the loudness effect.
post #577 of 580 Old 03-19-2015, 09:33 AM
DavidHir's Avatar
Liked: 1330
I run into this issue more likely than I want. I also suffer from Tinnitus (ear ringing) and anything over 85db or so is generally not recommended in terms of protecting your hearing, so I do have to turn it down then back up at times dependingon the movie. Some movies it's not an issue, but on others it can be pain. I think because my theater room is relatively small doesn't help either.
post #578 of 580 Old 12-14-2016, 04:56 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
Heat - Director's Cut - has received a 4K re-master courtesy of WB and will be released next year on BD and likely UHD-BD. The UK BD release has already been put out, for Feb 6th.
nathanddrews likes this.
LexInVA is online now
post #579 of 580 Old 12-14-2016, 06:24 PM
metalsaber's Avatar
Quoted: 963 Post(s)
Liked: 774
Want a UHD with Atmos or DTS:X
metalsaber is online now
post #580 of 580 Old 12-15-2016, 06:51 AM
nathanddrews's Avatar
Quoted: 349 Post(s)
Liked: 308
What mix was used for this?
http://www.oscars.org/events/heat
nathanddrews is offline
Reply Blu-ray Software
