In general, how many GB is a 45 minute TV show in 1080p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 08-29-2009, 08:46 AM - Thread Starter
b_scott's Avatar
Quoted: 37 Post(s)
Trying to get info for someone. Thanks if you know! Can't find it on google.
b_scott is offline
post #2 of 23 Old 08-29-2009, 08:48 AM
42041's Avatar
Liked: 55
Depends on the bitrate. Generally around 10-15GB.
42041 is offline
post #3 of 23 Old 08-29-2009, 08:53 AM - Thread Starter
b_scott's Avatar
Quoted: 37 Post(s)
thanks for the info
b_scott is offline
post #4 of 23 Old 08-29-2009, 08:59 AM
b.greenway's Avatar
1080p TV shows? I assume you mean 1080i.
b.greenway is offline
post #5 of 23 Old 08-29-2009, 09:00 AM - Thread Starter
b_scott's Avatar
Quoted: 37 Post(s)
no, i mean 1080p. on blu-ray.
b_scott is offline
post #6 of 23 Old 08-29-2009, 09:11 AM
Princess Aurora's Avatar
It doesn't matter. Resolution has nothing to do with the actual file size. Unless the video is uncompressed (or compressed losslessly), you can make any resolution pretty much any file size you want, within obvious reason. Codecs often have maximum and minimum bitrates, and you can never exceed the bitrate of uncompressed video anyway (although the lossy codecs, of course, don't come close to that). On Blu-ray, you're limited by the maximum bitrate of the format's specification.
And actually, on Blu-ray, 1080i has more information in it, since it has 60 interlaced fields corresponding to 30 frames. 1080p is always 24 frames on Blu-ray. The spec doesn't allow for 1080p video at 30 or 60 fps.
The answer to the original question is: it completely depends on the encode, and only on the bitrate (the codec is irrelevant when it comes to filesize). Some TV shows use VC-1 to get the average bitrate under 20 Mb/s to jam more episodes on a disc, while others use AVC encodes in the mid 30 Mb/s range (still others use AVC in the 20's). At 20 Mb/s, 45 min of video would take up 6750 MB. At 30 Mb/s, 45 min of video takes up 10125 MB.
That doesn't include the audio. Lossless audio takes up 2-4 Mb/s (depending on the codec), while lossy audio can be anywhere. The space taken up for a Dolby Digital track at 640 Kb/s is pretty much nothing in comparison to the video (about 210 MB for 45 min).
Princess Aurora is offline
post #7 of 23 Old 08-29-2009, 09:18 AM
FoxyMulder's Avatar
I think Warner shows like Smallville must be around 7gb in size since around 6 episodes are on each disc.
I am currently watching 24 Season 7 on Blu Ray and i note the frame rate says 23.976. Was 24 shot on film or is this a 30fps show being converted on Blu Ray to 23.976fps and if it's being converted what are the side effects ?
FoxyMulder is offline
post #8 of 23 Old 08-29-2009, 09:22 AM
42041's Avatar
Liked: 55
All properly mastered 24fps blu-rays should be 23.976 fps (24/1.001). I'm not familiar with the technical reason for it. The show 24 is show on 35mm as far as I know.
42041 is offline
post #9 of 23 Old 08-29-2009, 09:24 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Maybe they just shot in HD... In that case 23.976 fps is normal...
__________
Nicolas.
"Music expresses that which cannot be said and on which it is impossible to be silent."- Victor Hugo.
Morpheo is offline
post #10 of 23 Old 08-29-2009, 09:29 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
oops
__________
Nicolas.
Morpheo is offline
post #11 of 23 Old 08-29-2009, 09:30 AM
FoxyMulder's Avatar
I know that i was referring to the fact i thought American shows were shot 30fps.
If it's shot 35mm then that explains why it's 23.976.
I imagine shows shot on digital HD cameras could also be 23.976fps.
Kind of off topic but the Australian edition of The Descent is wrongly encoded at a pure 24fps instead of 23.976fps. Pity that as it's the best version of the movie around. I haven't noticed any issues during playback though.
post #12 of 23 Old 08-29-2009, 09:34 AM
42041's Avatar
Liked: 55
I don't watch much TV, but those would probably be the exceptions rather than the rule. Most American prime time TV series I've seen are in 24fps, even the stuff shot digitally like The Office.
42041 is offline
post #13 of 23 Old 08-29-2009, 10:30 AM
CRT Dude's Avatar
Your google-fu is weak. You must train harder.
Plug bitrate*runtime into google e.g. 20Mbps*22 minutes.
CRT Dude is offline
post #14 of 23 Old 08-29-2009, 10:45 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
There is no simple answer.
If you use as an ABR
8 mbs = 2,7 gb
16 mbs = 5,4 gb
32 mbs 10,8 gb
MovieSwede is offline
post #15 of 23 Old 08-29-2009, 10:51 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Yes 24fps gives an economic advantage. You need 25% more film if you shoot 30fps, computers need 25% more rendering. Its easier to use stock footage. Its easier to convert to PAL (with quality). You need 25% more storage.
post #16 of 23 Old 08-29-2009, 11:01 AM
Cinema Squid's Avatar
You can also check the specs thread to see many individual examples:
http://www.avsforum.com/avs-vb/showthread.php?t=1155731
There is often disc-by-disc variance even within a single season depending on the number of episodes on each, other extra features consuming space, etc. as can be seen in the Battlestar Galactica specs currently being posted by eric.exe.
Cinema Squid is offline
post #17 of 23 Old 08-29-2009, 02:11 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
BD only supports 1080i @60Hz.
William is offline
post #18 of 23 Old 08-29-2009, 02:16 PM
msgohan's Avatar
Good thing most shows are shot on film or digital video @ 24fps then.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #19 of 23 Old 08-29-2009, 02:18 PM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Most shows are recorded as 24P.
post #20 of 23 Old 08-29-2009, 02:24 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Well aware of that but that's not the OP's question or assertion. There are many "specials" that are shot at 60Hz (like concerts and almost all sporting events since 24Hz is too slow) that have and will find there way to BD.
My statement still stands and is correct that BD doesn't support 1080p 60Hz.
William is offline
post #21 of 23 Old 08-29-2009, 02:27 PM
FoxyMulder's Avatar
Well aware of that but that's not the OP question or assertion. There are many "specials" that are shot at 60Hz (like concerts and almost all sporting events since 24Hz is too slow) that have and will find there way to BD.
I assume when the new Panasonic Blu Ray players that support their new 3D format start arriving next year that have HDMI 1.4 and 120hz capability for 60hz each image ( 3D - 60hz per image and two separate images for 120hz total ) that 1080p 60hz will then be supported but it will be breaking away from the format as we currently know it.
post #22 of 23 Old 08-29-2009, 11:52 PM
troglobite's Avatar
You thought wrong. Most TV shows are shot using 24p HD cameras. There is no such thing as broadcasting in 24p, so the shows are converted to 1080i60SF or 720p60SF (segmented frame). When the show is released on Blu-ray, it's left in its original frame rate.
But to answer the OP's original question, the maximum bitrate allowed for Blu-ray is 54-mbit, so that means at most ~17.8 gigabyte. So it doesn't matter if it's 1080p, 1080i, 720p, etc. 17.8 gig is the maximum. The uncompressed size would be way more than that anyway even for 720p.
troglobite is offline
post #23 of 23 Old 08-29-2009, 11:55 PM
Blu-ray's maximum transfer rate is 54 Mb/s, but only 48 Mb/s of that can be used for audio and video combined. Further, the video can only be 40 Mb/s max (audio and video are demultiplexed), even if the audio is smaller than 8 Mb/s.
The absolute maximum is therefore 13500 MB, plus audio.
Reply Blu-ray Software
