Lionsgate's Crank 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 209 Old 09-08-2009, 02:32 PM - Thread Starter
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
Crank 2, released today, took over an hour for a AV and Computer expert to load this film. I would get a square of about 8" of actual video on a 60" display after waiting 2.5 minutes.
First I updated my Panasonic DMP-BD35K firmware via the internet, which to this day never hicupped on any movie. Restarted, no change.
OK so I left it hooked up the internet, restarted again and this time the movie said it was checking on updates. Still I would not get pass that 8" square of video.
Ok so I then put in my SD memory card, restarted, and after downloading, which also took at least two more minutes on a 16 Mbps internet line, now I get a EULA for Lionsgate BD-Live site. I selected "I disagree" and sure enough the movie would still not load.
OK one more time and I selected "I agree" and wouldn't you know it the movie actually started.
This is the bottom line on getting the movie to play:
It appears that this problem disc will not load on certain 2.0 profile players unless you use an external memory card.
All 1.0 and 1.1 profile players such as the Panasonic BD-30 or Sony's BDP-300 or 500 will not have a problem because they are not BD-Live capable.
All players that are 2.0 profile, that have built in memory, i.e. the PS3 or the OPPO 83 will not have this problem.
All of this would have been a walk in the park if the studios would put a simple system requirement notice on the back cover stating " 2.0 profile players must have either internal or external memory installed for this movie to load correctly."
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #2 of 209 Old 09-08-2009, 02:55 PM
dvdmike007's Avatar
Liked: 50
It has one of the best menus out there, its not their fault not everyone updates their players firmware
dvdmike007 is offline
post #3 of 209 Old 09-08-2009, 02:57 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
That's the point it was not a firmware issue.
You must be connected to the internet, have a SD memory card installed and agree to their EULA in order to update the java on the movie.
Hometheatergeek
aka AL
My Current System
post #4 of 209 Old 09-08-2009, 03:08 PM
dvdmike007's Avatar
Liked: 50
Fair point, still the best menu ever made, maybe next time buy a ps3
post #5 of 209 Old 09-08-2009, 03:14 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
You know I'm going to edit the orginal post.
Hometheatergeek
aka AL
My Current System
post #6 of 209 Old 09-08-2009, 03:25 PM
hiwind's Avatar
so if i buy this movie do i have to do anything special with my Sony Bdps350?
hiwind is offline
post #7 of 209 Old 09-08-2009, 03:47 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
I don't know. It was the stangest thing that I have ever done in order to watch a movie. YMMV
Hometheatergeek
aka AL
My Current System
post #8 of 209 Old 09-08-2009, 03:51 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
Originally Posted by Vader424242 View Post
Isn't this the same crap they pulled with "T2: Skynet"?
No in that case you could just hit cancel and the movie would start (I own it). This was different. It would not load and fill the entire screen until I allowed it to do what ever update it was trying to do.
Hometheatergeek
aka AL
My Current System
post #9 of 209 Old 09-08-2009, 03:52 PM
FoxyMulder's Avatar
So you are saying if you don't have your player connected to the internet and agree to download something then the film doesn't play ?
Or are you saying you have your player connected to the internet and it asked to download something before playing. Big difference if the latter.
If it was the latter then simply disconnecting the player from the internet would have surely fixed this issue.
If it's the former then i consider that bad.
FoxyMulder is offline
post #10 of 209 Old 09-08-2009, 03:57 PM
rboster's Avatar
Quoted: 893 Post(s)
Liked: 744
I watched a portion on the movie today using an OPPO 83 (without their latest firmware). I did not get prompted that I had to connect to the internet to play the BR. The movie played without issues.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #11 of 209 Old 09-08-2009, 04:04 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
What I am saying is , in my case, on my Panasonic BMP-35, which has never had a problem like this, is the movie would get to a point where the Java loading icon would not go completely away after starting to play a preview. You would see part of the preview and part of the icon and the rest of the screen was black.
This was before the player was connected to the internet. Not until I connected to the internet and allowed the movie to go to Lionsgate web site with a SD card installed and agreeing to their EULA, downloading their update to the SD card did the movie finally played filling the screen.
Hometheatergeek
aka AL
My Current System
post #12 of 209 Old 09-08-2009, 04:10 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
Follow thread here: http://forum.blu-ray.com/showthread.php?t=113491
It looks like you have to just have a SD card installed in players that have external cards in order to watch the movie that is 2.0 profile.
Hometheatergeek
aka AL
My Current System
post #13 of 209 Old 09-08-2009, 04:35 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
THe OPPO has internal memory. I think this is where the problem starts. If you do not have internal memory then you have to have a SD card installed in order for the movie to load properly.
Hometheatergeek
aka AL
My Current System
post #14 of 209 Old 09-08-2009, 04:58 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
Ok I just went back to the system and took the SD card out and it has the same original problem.
Bottom line should be that Lionsgate and all the other studios should put on the back of the cover that " This movie requires either internal memory or an external SD card in order for the movie to load properly." If they want this format to have a lifespan, then they need to start this procedure now.
Hometheatergeek
aka AL
My Current System
post #15 of 209 Old 09-08-2009, 05:12 PM
mzupeman's Avatar
Or perhaps you could turn off the BD-Live feature on your player if that's what's causing the issue.
mzupeman is offline
post #16 of 209 Old 09-08-2009, 05:24 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
It was off before all hell broke loose. I never have had BD-live on until this movie gave me problems. I hate BD-live. Worthless piece of ______.
Hometheatergeek
aka AL
My Current System
post #17 of 209 Old 09-08-2009, 05:37 PM
thebland's Avatar
Quoted: 1493 Post(s)
Liked: 846
I've said it many times.. One needs 2 BD players in their rack. If one hiccups, the other likely will play.... (I take no chances with my entertainment hours and have 3 BD players in my rack). Movies have to play immediately when I'm ready to watch.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #18 of 209 Old 09-08-2009, 05:45 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
Maybe I need to bring my older Sony s-500 down from the bedroom and add it to the rack because low and behold it played fine on the older machine. However I would have lost out on the DTS Master audio.
Hometheatergeek
aka AL
My Current System
post #19 of 209 Old 09-08-2009, 06:01 PM
357
357's Avatar
Quoted: 106 Post(s)
Liked: 45
Worked fine on my PS3.
357 is offline
post #20 of 209 Old 09-08-2009, 06:48 PM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Exactly! thats why I have 2 region A and 2 Region B. Its not the first time ive had movies play up on one player but work on the other.
_________________________
Franin is offline
post #21 of 209 Old 09-08-2009, 06:52 PM
Toe
Toe's Avatar
Quoted: 1473 Post(s)
Liked: 1837
Anyone try this on a BD30? Did it play fine?
Toe is offline
post #22 of 209 Old 09-08-2009, 06:54 PM
Hughmc's Avatar
Quoted: 13 Post(s)
Liked: 39
Does two PS3's count?
I was tempted to say the same as others regarding using a PS3, but truly it is the most dependable it seems.
Hughmc is offline
post #23 of 209 Old 09-08-2009, 07:08 PM
CIH USER
Franin's Avatar
Liked: 1311
My copy should arrive soon will give it a try on that player. But then again you could get it before me.
Franin is offline
post #24 of 209 Old 09-08-2009, 07:30 PM - Thread Starter
Quoted: 40 Post(s)
Liked: 43
Yes a forum member on Bluray.com said it loaded ok on the BD-30.
Ok, we sat down to watch this movie. We only lasted 55 minutes of the 85 minute run time. I can't believe people enjoyed this movie. It was a total spoof of the original Crank movie, more a comedy that an action flick. To each his own but if you have trouble with your player I wouldn't waste the time or effort to get it to load. My opinion and my wife but your YMMV.
Hometheatergeek
aka AL
My Current System
post #25 of 209 Old 09-08-2009, 07:35 PM
tomrich's Avatar
I tried playing Crank 2 on my Panasonic BD35 and I was only getting a small block of a screen.Hooked it to the internet same thing.No updates available.Added a 32 MB memory card,same.Turned on secondary audio.Nothing worked.I then inserted 4 Gig memory card finally played perfectly after pretty long loading time.Did not need to be hooked to internet.I don not know how big of a memory card you need but it must be a certain minimum.
tomrich is offline
post #26 of 209 Old 09-08-2009, 07:41 PM
Toe
Toe's Avatar
Liked: 1837
Yeah, I would bet you are safe with the PS3.....if all else fails, I will pull mine from upstairs and put it in the HT for this film
Thanks Franin.....if you dont hear some sort of report from me before you get it, let me know how it works out on the BD30 if you dont mind.
Nice. Thanks for that
Toe is offline
post #27 of 209 Old 09-08-2009, 07:55 PM
chucky08016's Avatar
OR... they can just buy one PS3.
So far I have not had ANY issue with ANY movie including Crank 2. Also, PS3 is controlled fully with my Harmony 890 so any objection about using a gamepad is rendered mute.
Last, so far, it's the only Blu-ray "player" that is fully upgradable to any of the newer profiles that may come down. So far... hopefully stays that way.
chucky08016 is offline
post #28 of 209 Old 09-08-2009, 08:05 PM
Partyslammer's Avatar
Quoted: 14 Post(s)
Liked: 43
This kind of nonsense where the consumer is the ongoing beta tester for a video format that's been on store shelves going on 3 years now is beyond ridiculous. That some consumers actually apologize for this sort of attitude from the movie industry is even more pathetic.
T.B.
Partyslammer is offline
post #29 of 209 Old 09-08-2009, 09:27 PM
spongyfungy's Avatar
I thought this thread would be about the boom cams
spongyfungy is offline
post #30 of 209 Old 09-08-2009, 09:42 PM
CIH USER
Franin's Avatar
Liked: 1311
have not seen it yet, I was hoping it will be good as the first.
Franin is offline
Reply Blu-ray Software
