Harry Potter: Ultimate Editions - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 203 Old 05-02-2011, 08:16 AM
ca1ore's Avatar
Originally Posted by Shaded Dogfood View Post
I think everybody is over-optomistic about footage left on the cutting-room floor with the Potter movies. I fear what we have now is all there is.
Yes, I think that may well be the case. My point is that they could have anticipated longer versions for the home theater market by filming essentailly two versions of each book. So, not cutting-room-floor stuff so much, rather extended versions. So much stuff was lost from the films in the service of runtime. Some of the films, notably Goblet and Half-Blood Prince, felt very rushed and choppy as a result. The film version of DH will end up being over 4 1/2 hours and all of it, I'd wager, put t good use.
Certainty and conviction are a sure sign you don't know what you're talking about! The world is not black and white, rather shades of grey!
ca1ore is offline
post #182 of 203 Old 06-07-2011, 08:22 AM
Rach's Avatar
So last night I finally performed an audio home test on the Chamber of Secrets Ultimate Edition. Switching back and forth on the inital PCM release and comparing to the new DTS-HDMA, it was no comparison even after volume matching. For whatever reason, the DTS MA was much fuller in comparison to the PCM. The quiddich match was ridiculously better.
Rach is offline
post #183 of 203 Old 06-07-2011, 07:31 PM
PeterTHX's Avatar
Quoted: 456 Post(s)
Liked: 332
Seeing as the DTS-MA is encoded from that same PCM it's obvious they weren't truly volume matched.
My opinions do not reflect the policies of my company
PeterTHX is online now
post #184 of 203 Old 06-08-2011, 07:43 AM
Rach's Avatar
I wish your snotty comment was correct but alas, you should research before posting. As I researched after posting, I found that Warner not only remixed the audio (not re-encoded) but increased the sampling rate on the DTS-MA as compared to the original PCM release. Either one would yield a more pleasing outcome...and I'm glad you opinions don't match the policies of your company as I rather like THX.
Rach is offline
post #185 of 203 Old 06-09-2011, 06:21 AM
PeterTHX's Avatar
Quoted: 456 Post(s)
Liked: 332
Snotty?
Somewhat immature response...
It's the same mix: both are from the 5.1 EX master and the differences between 16 and 24-bit are negligable, one isn't going to sound dramatically "fuller". The differences you cite are purely level based.
The "sampling" rate is still 48kHz by the way.
post #186 of 203 Old 09-29-2011, 09:28 AM
Mike_WI's Avatar
Quoted: 211 Post(s)
Liked: 143
http://www.hdtvetc.com/blu-ray/harry...well-kinda.php
It's also unclear as of yet how said moratorium will affect the (unannounced but obviously in-the-works) Deathly Hallows Parts 1 & 2 Ultimate Editions, which should hit shelves next year.
(And who knows whether or not they'll include the 3D versions? "Ultimate" doesn't mean what it used to.)
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is online now
post #187 of 203 Old 10-17-2011, 08:28 AM
Wolfe_CH's Avatar
Ultimate Double-Play Editions for the UK (not imported US versions) have appeared on Amazon.co.uk. They appear to contain both Blu-ray and DVD of the films. Not sure what else is in them. Release date is November 21.
Philosopher's Stone
Chamber of Secrets
Prisoner of Azkaban
Goblet of Fire
Order of the Phoenix
Half-Blood Prince
- Chris
Wolfe_CH is offline
post #188 of 203 Old 10-17-2011, 08:35 AM
dvdmike007's Avatar
Liked: 50
Wonder if they will finally be the extended cuts
dvdmike007 is offline
post #189 of 203 Old 10-17-2011, 08:22 PM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
Surprising there is so little information available this close to release.
Australia has had 2-disc Bluray Collectors Editions for movies 1-6 available for some time, including a Bluray disc of the Theatrical movie plus what seems to be the special features Bluray disc from the Ultimate Editions. It was very difficult determining whether the movie was the Theatrical or Extended as it was not explicitly spelled out in the merchandising.
Warner seems to be going all-out with multiple dips of this franchise and making it confusing. I realised they had lost the plot when they changed the Ultimate Editions range after the first 2 movies, destroying the consistency and value.
The UK has never had Ultimate Editions released before, so maybe these will be the USA Ultimate Editions with the inclusion of the movie on DVD.
Only movies 1 & 2 are extended in the Ultimate Editions, but it would be worth having those in a cheaper edition. I can't see Warner releasing extended versions of movies 3-6 without disenfranchising those customers who have already bought the Ultimate Editions.
IanD is offline
post #190 of 203 Old 10-19-2011, 08:02 AM
DavidHir's Avatar
Quoted: 1996 Post(s)
Liked: 1637
Are there any PQ improvements with these Ultimate versions vs the theatrical versions?
DavidHir is online now
post #191 of 203 Old 10-21-2011, 06:52 AM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
According to High-Def Digest, PQ is similar to the latest releases.
I think I read somewhere that the first Bluray release PQ was improved upon a little, but then we have had a few iterations since then.
Considering Theatrical and Extended versions are usually generated via seamless branching, they couldn't have better PQ for the extended bits without also improving the Theatrical elements or else the differences would be noticable. So, I guess you could say the Theatrical and Extended versions in the Ultimate Editions are equivalent. The Ultimate versions may have better PQ than the original Theatrical Bluray releases.
IanD is offline
post #192 of 203 Old 10-10-2012, 08:20 PM
Wolfe_CH's Avatar
Are these the DH Ultimate editions? I guess we'll find out next week. Ignore the aspect ratios; Amazon always seems to get those wrong.
Deathly Hallows I (4-disc) - Oct 16
Deathly Hallows II (4-disc) - Oct 16
Deathly Hallows I and II (6-disc) - Nov 13
- Chris
Wolfe_CH is offline
post #193 of 203 Old 10-11-2012, 12:55 AM
gonzalc3's Avatar
Quoted: 183 Post(s)
Liked: 154
- Chris
Nope. The Deathly Hallows movies come in a single ultimate edition box called Year 7. At the moment, they are exclusive at Target.
Yesterday, I received mine as a present... It doesn't seem to be an extended edition but I will watch them over the weekend to double check...
Chris. My DVD UHD Blu Ray and Blu Ray collection
JVC DLA-X750R (calibrated with calman 5 and c6 hdr meter), ST 130 (144") cinemascope screen, Carada Masquerade CIH masking system,B&W 803D2s mains, B&W HTM2D2 center channel, B&W 805D2 surrounds, B&W CCMM682s in-ceiling speakers (4), B&W DB1 subwoofer, Anthem AVM 60 processor, Parasound Halo A51+(2xA21)+(2xA23) amps, Oppo UDP 203 player, Roku Ultra and Harmony Elite remote.
gonzalc3 is offline
post #194 of 203 Old 10-11-2012, 01:07 AM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
As I understand it, only movies 1 & 2 were extended versions: all the others either had no deleted scenes or any deleted scenes were included as standalone extras and not integrated back into the movie.
IanD is offline
post #195 of 203 Old 10-11-2012, 04:58 AM
Franin's Avatar
Quoted: 2393 Post(s)
Liked: 1488
- Chris
Finally I can finish my collection.
_________________________
Franin is offline
post #196 of 203 Old 12-23-2012, 02:01 PM
BDD888's Avatar
Is the HP Wizard's Boxed Set the same as the "ultimate editions" sold individually? I haven't bought any HP blurays. Heard good things about the "ultimate editions". Wondered if I should buy the "wizards box set" or buy the movies individually. For best mastering quality and extras.
BDD888 is offline
post #197 of 203 Old 12-23-2012, 08:19 PM
Wolfe_CH's Avatar
I have the Ultimate Editions of the first two movies (the other movies don't have extended versions available at all, which is why I only went for the UE on the first two films). These two UEs have 3 discs: the BD with theatrical and extended versions, a Creating the World BD, and the same DVD bonus disc that was included with the previous 2-disc DVD release. The Ultimate Editions do NOT contain the DVD version of the film. There's also a 25-page Creating the World booklet with pictures from the films, and two character cards. The 4th disc only contains the digital copy of the film.
I don't have the 31-disc Wizard's collection, but looking at the description and pics on Amazon and Blu-ray.com, it appears you get the 2 BDs (theatrical and extended films, and Creating the World), the DVD (theatrical only), and bonus DVD second disc. I'm not sure if the Creating the World booklet is included, nor the character cards.
The Wizard's comes with Ultraviolet version of the films, and an exclusive 31st bonus BD. Pics might help with the comparison:
Sorcerer's Stone Ultimate
HP Wizard's Collection
http://www.blu-ray.com/movies/Harry-Potter-Wizards-Collection-Blu-ray/39646/
Hope that helps.
- Chris
Wolfe_CH is offline
post #198 of 203 Old 12-24-2012, 11:05 AM
BDD888's Avatar
The first 7 films are available on UE @ Amazon (I believe there are 8 films in total?). I'm sure they'll put out a "UE boxset"....probably after every one has bought the UE versions individually. Glad I haven't bought the films on bluray yet.. I'll wait and see if they put out a UE Boxset. Hope it's more cost effective than buying all UE versions separately.
BDD888 is offline
post #199 of 203 Old 12-24-2012, 08:55 PM
comixguru's Avatar
Any set that doesn't include the 3D versions of the movies available (last two films in their entirety, as well as portions of Order of the Phoenix and Half-Blood Prince) are probably going to be superseded in the future. I wouldn't be surprised if they release an uber-set with 3D editions in combination with the extended editions as that combo would yield significantly higher sales appealing to 3D lovers and Potter film fans.
It can only be a calculated move that the extended versions of movies 3 through 8 aren't included in the ultimate editions and also that that the last Ultimate set doesn't include 3D copies.
comixguru is offline
post #200 of 203 Old 01-03-2013, 09:24 AM
Mike_WI's Avatar
Quoted: 211 Post(s)
Liked: 143
Amazon "Harry Potter: The Complete 8 Film Collection [Blu-ray]" is now $50.
I was wondering if the ultimate editions are ever coming out or any new word on this?
Mike
HT Details: link
post #201 of 203 Old 01-06-2013, 07:30 PM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
Mike
So are these ultimate?
zoro is offline
post #202 of 203 Old 01-06-2013, 09:34 PM
IanD's Avatar
Quoted: 94 Post(s)
Liked: 56
The hallmark of each of the Ultimate Editions is extra features including a disc of "World Of Harry Potter" and special packaging.
The discs you quote are just the complete movie set with 1 disc for each movie and very limited extras.
IanD is offline
post #203 of 203 Old 12-17-2014, 03:22 AM
Mike_WI's Avatar
Quoted: 211 Post(s)
Liked: 143
Old thread, but anything new on this as Christmas is approaching?
I haven't seen any new collections on Amazon.
Mike
HT Details: link
Reply Blu-ray Software
