Blu ray HD audio question - DRC with Phantom Center? - AVS Forum | Home Theater Discussions And Reviews
Old 10-06-2009, 10:24 PM - Thread Starter
goonstopher's Avatar
Quoted: 301 Post(s)
Liked: 58
My reading suggests older dolby digital formats engage DRC with a Phantom center - Is this the case with newer HD codecs?
goonstopher is offline
Old 10-07-2009, 08:28 AM - Thread Starter
Quoted: 301 Post(s)
Liked: 58
Does anyone know this?
Mod Edit: Please do not bump your threads....if someone wants or knows the answer..they will post it.
Old 10-07-2009, 08:30 AM
Rach's Avatar
What's DRC. I run my setup with a phantom center...because of my wife.
Rach is offline
Old 10-07-2009, 08:48 AM - Thread Starter
Quoted: 301 Post(s)
Liked: 58
Dynamic Range Compression... Ruins the peaks in your audio by limiting dynamic range to "protect" the speakers.
Old 10-07-2009, 11:41 AM
Rach's Avatar
This is a good question. I would like to know the answer. Make no mistake though, HD audio codecs can be light years better than Dolby Digital...keyword "can".
Rach is offline
Old 07-28-2013, 11:17 AM
Eyleron's Avatar
Quoted: 252 Post(s)
Liked: 142
As a reference for others...yes, it did for me on Total Recall 2012: a disk from Netflix, DOlby TrueHD.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
