BluRay compatible files in DVD Architect. Help!! - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2010, 05:27 AM - Thread Starter
PlaasterLars's Avatar
Hi!
I'm having some problems understanding which files Sony DVD Architect will allow without re-compressing them...
Lets say I want to compress a Blu-Ray compatible H264-file from Adobe After Effects. Which settings to use? I've tried most profiles, resolutions and fps, but DVD Architect says it must be re-compressed, although the settings matches...
After Effects has a H264 BluRay-preset, theese files goes into Adobe Encore, but not into DVD Architect. Why?
The only files so far I've gotten into DVD Architect so far (except un-compressed files of course) are MPEG2 files from Sony Vegas (Settings 1440x1080 50i. 25 Mbps). But I want to use full res 1920x1280, and AVC/H264 codec...
I hope some of you have any wisdom on theese Blu-Ray codecs, I will appreciate it a lot!
Lars
PlaasterLars is offline
