Star Trek TNG Seasons Remastered on Blu-Ray - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #541 of 2474 Old 09-29-2011, 07:03 AM
nick_danger's Avatar
Originally Posted by Gareth Flynn View Post
Would I be right in saying that it was originally shot at 24fps and the 24->30fps (60i) conversion was done as part of the video transfer prior to editing?
So these should be 1080p24 since the (old) video stage no longer exists?
Correct. It will be just like TOS.
nick_danger is offline
post #542 of 2474 Old 09-29-2011, 08:26 AM
dragonyeuw's Avatar
Liked: 51
Great picture of the Enterprise-D there. Sold!!
Too many systems and games....not enough time or money!
dragonyeuw is offline
post #543 of 2474 Old 09-29-2011, 08:41 AM
dvdvision's Avatar
Yes, the trailer clearly says 24fps, AWESOME, but myself I want the 16/9 version. This is the future, not the past.
dvdvision is offline
post #544 of 2474 Old 09-29-2011, 08:58 AM
spectator's Avatar
Then why are you looking for an old show, in the first place?
I don't feel special...
spectator is offline
post #545 of 2474 Old 09-29-2011, 09:38 AM
Dave Mack's Avatar
Awesome
Dave Mack is offline
post #546 of 2474 Old 09-29-2011, 10:59 AM
Josh Z's Avatar
Quoted: 2145 Post(s)
Liked: 1441
These people don't take into account the ITU pixel aspect, which means in effect that it's the reverse, ie in ENT the TNG reused shots are unalterated, save shaving off a bit top and bottom, while all the original TNG DVDs shows the series squeezed, unless you display the episodes on an old CRT TV.
There are tons of TV series out on DVD that when displayed on a brand new HDTV, actually presents squeezed images (not the proper display). This can only be adjusted by ripping the episodes with handbrake, or similar software, and re-encoding them for proper display of the pixel ratio.
Pretty much every HDTV has a 4:3 viewing mode that will properly pillarbox the picture. Perhaps rather than ripping and re-encoding all of your DVDs, you should just hit the "Aspect Ratio" button on your TV's remote.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #547 of 2474 Old 09-29-2011, 11:41 AM
Joseph Goodman's Avatar
I wonder how they are going to handle cutting between the later model shots done at Image G, which were done for 30fps playback, and the 24fps principle photography?
Joseph Goodman is offline
post #548 of 2474 Old 09-29-2011, 11:48 AM
Fanboyz's Avatar
Quoted: 510 Post(s)
Liked: 159
I imagine all effects shots will have to be remade.
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #549 of 2474 Old 09-29-2011, 12:46 PM
Quoted: 21 Post(s)
This has probably been mentioned before, but I wonder if, for all the work it will take, they might re-release the entire series on HD-TV, whether before/during/after the BD packaging.
Laserfan is offline
post #550 of 2474 Old 09-29-2011, 03:41 PM
I'm sure they'll be available on Netflix and SyFy around the same time.
post #551 of 2474 Old 09-29-2011, 03:51 PM
dvdvision's Avatar
For the same reason I'm into Blu-ray, rather than VHS.
Concerning ITU ratio, no flat panel can correct. You have to reencode in Handbrake to specifications, or use an old CRT TV.
post #552 of 2474 Old 09-29-2011, 04:19 PM
spectator's Avatar
You're into old shows for the same reason you're into new formats?
I don't know how to interpret your thinking, but I can tell you, if you're looking for 16:9 because "this is the future, not the past", Terra Nova is certainly 16:9.
Star Trek: TNG, meanwhile, is 4:3 because it's most definitely "the past".
post #553 of 2474 Old 09-30-2011, 04:19 AM
DragonQ's Avatar
Do you mean the fact that 704x576 should really be 703.2x576 and 704x480 should be 706.2x480? If so, I can't imagine anyone would notice this difference and it certainly isn't the 5.8% claimed by the TNG vs ENT comparison shots. I'd also bet that most CRTs' aspect ratios aren't exact either.
DragonQ is offline
post #554 of 2474 Old 09-30-2011, 11:00 AM
Josh Z's Avatar
Liked: 1441
I really have no idea what he's talking about. Every HDTV has a pillarbox setting for watching 4:3 content in the correct aspect ratio.
Perhaps he's upconverting the show at the DVD player, and his TV locks out aspect ratio controls when it receives an HD signal? Best I can figure. If so, turn off upconversion and the TV will be able to adjust the aspect ratio again.
Josh Z
Josh Z is offline
post #555 of 2474 Old 09-30-2011, 08:14 PM
Maxwell Everett's Avatar
In ENT the TNG reused shots are unalterated, save shaving off a bit top and bottom, while all the original TNG DVDs shows the series squeezed, unless you display the episodes on an old CRT TV.
I thought this might be the case too at one point, but if you take a careful look at the TNG footage used in ENT, you'll notice that in the background the two small windows on the doors to Ten Forward -- the ones with the Starfleet emblem etched on them -- look elliptical or oval shaped. But those windows are supposed to be perfectly circular... so the footage has clearly been stretched horizontally.
On the TNG DVDs, they look correct.
Maxwell Everett is offline
post #556 of 2474 Old 10-03-2011, 01:23 AM
dvdvision's Avatar
I'm talking Nominal analogue blanking - could also varies from shot to shot, with more black bars on the side (I can point out a severe example in the opening of Wiseguy episode 2 for example). For TNG, we can't of course rule out the editor might have used a few tricks on a couple of shots according to the framing he wanted to achieve. Just saying you can't use this as a common rule for 4/3 to 16/9 conversion. (The widescreen Columbo for example do not look stretched).
post #557 of 2474 Old 10-03-2011, 03:45 AM
Monticello's Avatar
I've only ever seen TOS. Looking forward to watching TNG in even better quality than when they aired!
Monticello is offline
post #558 of 2474 Old 10-03-2011, 05:56 AM
Mr.D's Avatar
Originally Posted by Maxwell Everett View Post
Yep. That's because, on the pilot only, ILM used 35mm 8-perf VistaVision cameras for the VFX shots. 8-perf is just like the size of an exposure in 35mm still photography and has an aspect ratio of 1.47:1. It's roughly double the size of standard 4-perf motion picture film because the negative is run through the camera gate horizontally -- again, just like a 35mm still camera. This is why a few of these "Encounter at Farpoint" shots were deemed usable in Star Trek Generations.
Not the "shots". They used the vista vfx plates to create new shots for generations. ( and I have to say that the VFX work done on the TNG films is about the worst work ILM have done). DD did a much better job on nemesis; unfortunately the film was bleurgh.
digital film janitor
Mr.D is offline
post #559 of 2474 Old 10-03-2011, 06:21 AM
DragonQ's Avatar
The CGI in Nemesis was indeed pretty awesome.
DragonQ is offline
post #560 of 2474 Old 10-03-2011, 06:29 AM
XxDeadlyxX's Avatar
Plus Nemesis had FAR better space battles than any of the other Treks - Star Trek (2009) was terrible in that regard IMO. I hope the sequel is better.
XxDeadlyxX is offline
post #561 of 2474 Old 10-03-2011, 06:32 AM
Mr.D's Avatar
Ah but "Star Trek" was genuinely cool. I never thought I'd see a star trek film that had style and wit and was cool to the extent that ST was. Great surprise.
Mr.D is offline
post #562 of 2474 Old 10-03-2011, 06:34 AM
Mr.D's Avatar
Yes take that as a given. They could interpolate them back to 24p but the things are so mushy and simplistic in the first place that it would be much better to just redo them.
Mr.D is offline
post #563 of 2474 Old 10-03-2011, 02:11 PM
Sure. But that's kind of pedantic, don't you think? It's not like they combined the separate motion control passes with anything other than similar-looking starfields (possibly even the same ones) and then cropped them to 2.39:1. I think maybe the Captain's log shot perhaps had Q's barrier in it. For all intents and purposes, they're essentially the same "shots." Amusingly enough, I had "plates" in there at one point in the last sentence before I hit submit. I think I changed it for consistency.
( and I have to say that the VFX work done on the TNG films is about the worst work ILM have done) DD did a much better job on nemesis; unfortunately the film was bleurgh.
I think for the most part they did great... especially with the notoriously miniscule budgets they had to work with. They're certainly not as bad as some of the crap in Star Wars Trilogy - Special Edition, The Mummy Returns, E.T. 20th Anniversary, Hulk, THX 1138 Rerelease or Van Helsing.
post #564 of 2474 Old 10-03-2011, 02:17 PM
Osirus23's Avatar
Quoted: 102 Post(s)
Liked: 256
Not really. In Nemesis they just tried to rip off every previous 'good' Trek film and it failed miserably.
Osirus23 is offline
post #565 of 2474 Old 10-03-2011, 02:19 PM
dvdmike007's Avatar
Liked: 50
I like Nemesis
dvdmike007 is offline
post #566 of 2474 Old 10-03-2011, 02:33 PM
Mr.D's Avatar
No to everything.... in a nutshell.
And your point would be what ? Just because there are some other films out there that you think have worse VFX you are using that to refute that the vfx in Nemesis handled by DD are better than the previous films?
Mr.D is offline
post #567 of 2474 Old 10-03-2011, 02:59 PM
Josh Z's Avatar
Liked: 1441
I think he's just refuting your statement that: "the VFX work done on the TNG films is about the worst work ILM have done."
Josh Z
Josh Z is offline
post #568 of 2474 Old 10-03-2011, 07:12 PM
XxDeadlyxX's Avatar
I did not say Nemesis was a better FILM than the others, I said it is the best in terms of space battles. ie. the long 20-30 minute fight at the end.
What other Trek movie has anything remotely as good? For example the First Contact fight at the beginning is like 3 minutes long....
What I disliked about Star Trek (2009) was this. Ok I get the fact that most of the movie revolves around introducing characters and building storyline etc, but even towards the end when we should be getting into some meaty space action, it falls short. Even the phasers that ILM or whoever decided this 'new' Enterprise should have look poor.
The sequel will have no excuse not to be considerably better in this regard.
post #569 of 2474 Old 10-03-2011, 11:14 PM
Ghostface1701's Avatar
Hm, personally, I found the 3 minute battle scene in First Contact (especially the 20-second final barrage) to be more exciting than anything in Nemesis. To each his own...
Blu since '07
Ghostface1701 is offline
post #570 of 2474 Old 10-04-2011, 12:35 AM
MovieSwede's Avatar
Quoted: 116 Post(s)
Liked: 81
Its not really the effects fault, no matter what star trek movie you prefer. Its how the effect scene is constructed. If your into the story enough once the effect take place, you will not even notice that you actually watching an effect.
What that scene you mention fall short for me is actually the music. It doesnt evoke the emotions the scene needs. Compared to the music cues in "Ive got your gun" scene that fits almost perfect, or the opening scene for that matter.
MovieSwede is offline
Reply Blu-ray Software
Blu Ray Movies , Star Trek The Next Generation Motion Picture Collection First Contact Generations Insurrection Nemes
