Out Of Africa comparison *PIX* - AVS Forum | Home Theater Discussions And Reviews
post #1 of 79 Old 01-02-2011, 11:07 PM - Thread Starter
Xylon's Avatar
XylonHD, YouTube Channel, @XylonHD
Won Seven Academy awards including Best Art Direction, Best Cinematography and Best Picture.
This blu-ray transfer did not resemble that film whatsover. To Universal if you don't have the money to do decent transfers please don't bother releasing them. Its just a waste of time.
Xylon is offline
post #2 of 79 Old 01-02-2011, 11:08 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #3 of 79 Old 01-02-2011, 11:08 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #4 of 79 Old 01-02-2011, 11:09 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #5 of 79 Old 01-02-2011, 11:09 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #6 of 79 Old 01-02-2011, 11:10 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #7 of 79 Old 01-02-2011, 11:10 PM - Thread Starter
Xylon's Avatar
Xylon is offline
post #8 of 79 Old 01-02-2011, 11:10 PM - Thread Starter
Xylon's Avatar
reserved8
Xylon is offline
post #9 of 79 Old 01-02-2011, 11:10 PM - Thread Starter
Xylon's Avatar
....grit
Xylon is offline
post #10 of 79 Old 01-02-2011, 11:11 PM - Thread Starter
Xylon's Avatar
DVD Collector's Edition 2000
H.264 1080i broadcast: 12.23 GB
Bitrate: 10.71 mbps
Code:
Sequence Frame 415689(0-X) / Time 2:18:31 :
AudioError: Corrupted AC3 frame of 1534 payload bytes at file offset 11813088846
Sequence Frame 462688(0-X) / Time 2:34:07 :
Info: End of H.264 sequence
Sequence Summary:
File Size Processed: 12.23 GB, Play Time: 02h:34m:11s
50.01 FPS (Average), 10.71 Mbps (Average).
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
1 of 289112 audio frames found with errors.
0.000000 seconds of audio timestamp gaps.
End of Log
Blu-ray US file size: 36.60 GB
Bitrate: 25.58 mbps AVC
Code:
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track
   Secondary Audio Track
00000.MPLS                                                      AVC     2:41:02 39,306,504,192  44,439,278,163  32.54   25.58   DTS-HD Master 5.1 4173Kbps (48kHz/24-
bit)
Code:
DISC INFO:
Disc Title:     OUT_OF_AFRICA
Disc Size:      44,439,278,163 bytes
Protection:     AACS
BD-Java:        Yes
BDInfo:         0.5.4
PLAYLIST REPORT:
Length:                 2:41:02 (h:m:s)
Total Bitrate:          32.54 Mbps
VIDEO:
MPEG-4 AVC Video        25576 kbps          1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             English         4173 kbps       5.1 / 48 kHz / 4173 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS Audio                       French          768 kbps        5.1 / 48 kHz / 768 kbps / 24-bit
Dolby Digital Audio             English         192 kbps        2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
SUBTITLES:
Presentation Graphics           English         27.116 kbps
Presentation Graphics           Spanish         22.508 kbps
Presentation Graphics           French          25.458 kbps
Presentation Graphics           French          0.103 kbps
FILES:
00010.M2TS      0:00:00.000     2:41:02.694     39,306,504,192  32,543
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg
Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:04:33.481     25,197 kbps     37,080 kbps     00:03:40.553    36,002 kbps     00:03:36.507    35,906 kbps     00:03:31.377
131,344 bytes   499,485 bytes   00:04:28.476
2               0:04:33.481     0:02:59.637     22,752 kbps     29,876 kbps     00:06:31.265    27,592 kbps     00:04:43.074    27,329 kbps     00:04:40.446
118,617 bytes   384,126 bytes   00:05:56.064
3               0:07:33.119     0:03:52.899     27,905 kbps     37,287 kbps     00:08:33.930    35,717 kbps     00:09:16.973    35,158 kbps     00:09:14.262
145,483 bytes   438,068 bytes   00:08:21.375
4               0:11:26.018     0:05:51.934     23,577 kbps     36,835 kbps     00:11:34.735    34,208 kbps     00:11:30.731    32,073 kbps     00:11:26.519
122,922 bytes   477,307 bytes   00:12:50.311
5               0:17:17.953     0:05:12.395     22,307 kbps     38,316 kbps     00:21:52.019    36,202 kbps     00:21:47.973    35,639 kbps     00:21:45.220
116,301 bytes   477,959 bytes   00:21:40.924
6               0:22:30.349     0:05:34.751     28,104 kbps     38,210 kbps     00:27:37.238    36,180 kbps     00:26:20.120    35,405 kbps     00:26:17.117
146,520 bytes   520,563 bytes   00:27:38.198
7               0:28:05.100     0:09:06.754     22,928 kbps     38,344 kbps     00:29:20.717    36,303 kbps     00:29:16.755    35,476 kbps     00:29:12.792
119,535 bytes   515,567 bytes   00:29:24.721
8               0:37:11.854     0:06:15.541     27,886 kbps     38,484 kbps     00:41:09.884    36,310 kbps     00:41:07.631    35,977 kbps     00:41:34.408
145,383 bytes   486,927 bytes   00:41:12.636
9               0:43:27.396     0:14:09.265     26,669 kbps     37,622 kbps     00:54:33.937    36,149 kbps     00:54:32.143    35,857 kbps     00:45:58.505
139,041 bytes   462,941 bytes   00:44:06.310
10              0:57:36.661     0:21:50.309     24,573 kbps     38,058 kbps     01:11:52.349    36,303 kbps     01:18:01.677    35,414 kbps     01:03:08.951
128,110 bytes   528,136 bytes   01:11:47.511
11              1:19:26.970     0:09:03.626     27,235 kbps     38,542 kbps     01:26:25.889    36,230 kbps     01:25:41.886    35,722 kbps     01:25:52.981
141,990 bytes   496,225 bytes   01:25:46.558
12              1:28:30.596     0:17:33.093     26,829 kbps     38,766 kbps     01:33:10.418    36,477 kbps     01:35:13.416    36,072 kbps     01:35:07.618
139,872 bytes   588,726 bytes   01:35:18.421
13              1:46:03.690     0:05:59.484     25,366 kbps     38,565 kbps     01:51:24.886    36,239 kbps     01:51:20.882    34,299 kbps     01:51:18.713
132,245 bytes   502,424 bytes   01:51:51.955
14              1:52:03.174     0:19:02.099     25,430 kbps     37,842 kbps     02:00:07.783    35,847 kbps     02:01:51.637    35,452 kbps     02:01:46.549
132,578 bytes   564,170 bytes   02:00:09.660
15              2:11:05.274     0:14:12.977     25,533 kbps     37,750 kbps     02:11:07.442    36,069 kbps     02:11:06.316    35,064 kbps     02:11:05.357
133,116 bytes   503,236 bytes   02:13:20.701
16              2:25:18.251     0:07:22.483     27,301 kbps     38,945 kbps     02:31:45.513    36,217 kbps     02:32:08.994    35,864 kbps     02:32:05.116
142,336 bytes   489,765 bytes   02:29:30.002
17              2:32:40.734     0:05:24.907     27,141 kbps     38,134 kbps     02:33:01.380    36,229 kbps     02:33:01.380    36,020 kbps     02:33:01.130
141,503 bytes   534,430 bytes   02:33:45.591
18              2:38:05.642     0:02:57.051     18,233 kbps     28,891 kbps     02:40:59.274    27,553 kbps     02:40:55.520    22,394 kbps     02:40:52.601    95,082
bytes    407,734 bytes   02:40:58.565
STREAM DIAGNOSTICS:
00010.M2TS      4113 (0x1011)   0x1B            AVC                                     9662.570                25,576                  30,891,506,196  168,023,575
00010.M2TS      4352 (0x1100)   0x86            DTS-HD MA       eng (English)           9662.570                4,173                   5,040,387,420   28,908,258
00010.M2TS      4353 (0x1101)   0x82            DTS             fra (French)            9662.570                768                     927,619,072     5,435,268
00010.M2TS      4354 (0x1102)   0x81            AC3             eng (English)           9662.570                192                     231,905,280     1,509,800
00010.M2TS      4608 (0x1200)   0x90            PGS             eng (English)           9662.570                27                      32,752,084      188,382
00010.M2TS      4609 (0x1201)   0x90            PGS             spa (Spanish)           9662.570                23                      27,185,879      156,132
00010.M2TS      4610 (0x1202)   0x90            PGS             fra (French)            9662.570                25                      30,749,091      175,502
00010.M2TS      4611 (0x1203)   0x90            PGS             fra (French)            9662.570                0                       124,764         712
QUICK SUMMARY:
Protection: AACS
BD-Java: Yes
Playlist: 00000.MPLS
Length: 2:41:02
Video: MPEG-4 AVC Video / 25576 kbps / 1080p / 23.976 fps / 16:9 / High Profile 4.1
Audio: English / DTS-HD Master Audio / 5.1 / 48 kHz / 4173 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Audio: French / DTS Audio / 5.1 / 48 kHz / 768 kbps / 24-bit
Audio: English / Dolby Digital Audio / 2.0 / 48 kHz / 192 kbps / DN -4dB / Dolby Surround
Subtitle: English / 27.116 kbps
Subtitle: Spanish / 22.508 kbps
Subtitle: French / 25.458 kbps
Subtitle: French / 0.103 kbps
Xylon is offline
post #11 of 79 Old 01-03-2011, 02:46 AM
surap's Avatar
Uh-oh. That screenshot with Meryl on Blu-ray looked very DNR:ed. Very little grain in the background.
I dont know if it is the directors intent, but whats up with the cyan colorscheme on HD..?
Always nice to see your screenshot, xylon.
surap is offline
post #12 of 79 Old 01-03-2011, 03:04 AM
mhafner's Avatar
Quoted: 147 Post(s)
Liked: 55
Transfer is garbage and belongs in the dumpster. Should never have been released.
mhafner is offline
post #13 of 79 Old 01-03-2011, 03:05 AM
dododge's Avatar
If I'm seeing this right the church steeple has edge-enhanced chromatic aberration. Good grief.
dododge is offline
post #14 of 79 Old 01-03-2011, 03:06 AM
sumawo13's Avatar
Looks like a piece of crap, can't speak for the quality of the movie itself.
sumawo13 is offline
post #15 of 79 Old 01-03-2011, 04:39 PM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
Many Bluray releases seem to be pushed to Teal lately: it's an artistic flavour-of-the-month revisionism and whilst maybe being a directors current intent, does not honour the original film.
They've even cropped the Bluray slightly compared to the other releases and so removed picture information along with detail.
I've boycotted this release, along with way too many others because of these travesties.
IanD is offline
post #16 of 79 Old 01-03-2011, 06:20 PM
Sean_O's Avatar
Looks like deep fried S**T!
Sean_O is offline
post #17 of 79 Old 01-03-2011, 08:46 PM
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
Isn't this old news?
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #18 of 79 Old 01-03-2011, 10:26 PM
sirthx's Avatar
Some of the worst EE since the Phantom Menace DVD. Then look at the tin roof in the yard pics for some serious DNR. Just wow!!
sirthx is offline
post #19 of 79 Old 01-03-2011, 11:20 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
This is why I refused to buy this title. Really bad transfer. Might rank up there as one of the worst.
ack_bk is offline
post #20 of 79 Old 01-03-2011, 11:31 PM
msgohan's Avatar
Vudu's version doesn't appear to be hit with the EE stick. Same master as the broadcast I spose.
Don't know that I feel like spending 5 bucks to watch it beyond the preview though.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #21 of 79 Old 01-03-2011, 11:48 PM
Deviation's Avatar
Ugh. It really would be better if they just didn't release stuff like this. So sick of what Universal does to catalog titles.
Deviation is offline
post #22 of 79 Old 01-04-2011, 06:54 AM
R Harkness's Avatar
Quoted: 1928 Post(s)
Liked: 1628
Ugh. I have this Blu-Ray and have mean meaning to watch it recently. It's been known for a while it's a low-quality transfer but what bothers me most in the screen-caps is the color change. All that warmth in the image that says "Africa," which I've always loved in the film, seems drained out. A true bummer. What the hell goes through the minds of people who do this?
R Harkness is offline
post #23 of 79 Old 01-04-2011, 07:14 AM
HVisone's Avatar
I think they took a dvd master of a few years back, and uprezed it to blu-ray.
I don't know how they made it but that is my guess.
Whatever they did, they made it unwatchable, although everyone is an angel in the blu-ray, because the actors all have these beautiful halos around them........
While the screen caps do not show it very well, but my opp-83 does a better job of uprezing the older dvd of a number of years back and making it a better "viewing experience" than one can get from the blu-ray.
I have always loved the music combined with the photographic art of the movie.
This was first movie my wife and I saw together on our first date back many years ago. She cried a ton of tears at the end.
I got the BD for her birthday.
This time she cried a bunch of tears from the beginning until she said, "turn it off...where is the old dvd??"
Thanks Xylon for the screen shot comparisions--but what does H264 come from? Was this a master that was used or??
best move for Universal-Stop transferring, mastering.If not for the sake of the films, do it for our planet.-Harris;
TOO LATE; Out of Africa is out-the worst ever
HVisone is offline
post #24 of 79 Old 01-04-2011, 07:57 AM
snudley's Avatar
What a bitter disappointment this is for one of my all-time faves.
I would dearly love to have a pristine transfer of this film. I have visited the area where this was filmed several times, and always had the wonderful soundtrack playing in my mind during the trip.
I wish this botched transfer would compel enough people to complain to the studio to warrant a new disc, but I'm afraid it won't happen. Perhaps Criterion...
snudley is offline
post #25 of 79 Old 01-06-2011, 07:21 AM
HVisone's Avatar
how bad is the blu-ray?
Well, if you watch the beginning, you will see that they are in front of a blue screen when they portrayed the bird hunting scenes in Europe before she goes to Africa.
Or so some BD reviewers reasonably thought.......
However, they are wrong, completely.
The best transfer is my old laser disc, and it is clearly not blue screen.....and i remember an interview with Meryl Streep about an incident with one of the guns.......
How bad is the blu-ray transfer?
It is so bad that Ralph Potts has not done a review....too much of a gentleman with class
HVisone is offline
post #26 of 79 Old 01-06-2011, 07:27 AM
HVisone's Avatar
even the screen caps make it look like a blue screen......but it ain't
HVisone is offline
post #27 of 79 Old 01-06-2011, 04:46 PM
Dan Hitchman's Avatar
Quoted: 3413 Post(s)
Liked: 1766
Pure rubbish. What a shame. It's such a great movie.
A definite no-buy. Universal Home Video you truly do suck.
And unfortunately if Comcast buys NBC/Universal you can expect things to get even worse.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #28 of 79 Old 01-06-2011, 04:54 PM
Penman's Avatar
Agreed that this appears to be shiite.
But on the specific question of "blue screen," there are indeed a few shots in that hunting sequence of Meryl and Klaus next to a tree that are clearly an effect of some kind (rear-screen projection?).
I remember seeing those shots in the theater when the movie was released and being surprised that such a big-budget, big-name picture had such a cheesy effect in it. My guess is that those shots contained overlooked but necessary clarifying dialogue and thus had to be hastily shot. In any case, it's definitely an effect.
Penman is offline
post #29 of 79 Old 01-07-2011, 07:16 AM
HVisone's Avatar
Perhaps, but the big problem was they were trying to shoot on location in the winter. The light there during winter that far north, most of the time is very diffuse and gives everything a very gray color, and destroys or reduces depth perception that one would otherwise have. I am talking about actual vision, not film, but it has a similar effect on film. In some scenes they add lighting on the subjects, which causes a contrast between subject and background, that if one is not careful, gives the background a cheap blue screen type of effect.
If I had the ability I would post some photos taken with a flash that produces the effect.
The LD does not have much of this enhancement effect, but when they did the DVD, because everything was muted, they "enhanced" colors and contrast. The problem was that most of the background was grayish from the natural lighting, and so the more they enhanced, the more it became a cheap looking effect, as the clothes and faces being more "lighted" than the surroundings. These lighted subjects had their colors "enhanced" but the grayish, dull colors in the background remained the same as they responded far differently....
Bingo. Most of those scenes took on this blue screen effect.
Add in all the other 'enhancements" on the BD, and the effect.....is really bad
HVisone is offline
post #30 of 79 Old 01-07-2011, 08:15 AM
BenUK's Avatar
DNR, edge enhancement, contrast boosting, artificial sharpening. What a combination.
BenUK is offline
Reply Blu-ray Software
