2K masters for bluray, is the extra information cropped off? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #1 of 32 Old 07-07-2011, 08:13 AM - Thread Starter
PRO-630HD's Avatar
Quoted: 300 Post(s)
Liked: 192
Assuming the master is 2K which I think is the majority for the basic aspect ratios we have
1.37:1 = 1332 x 1828 scaled to 1080 x 1482 for obvious reasons
1.85:1 = 1080 x 1998 (rescaled to 1038 x 1920?)
2.39:1 = 858 x 2048 (rescaled to 804 x 1920?)
For 1.85:1 and 2.39:1 is the extra info simply being cropped off or is it being rescaled? I know we would be losing a bit of picture info on the sides, but I would think using pixel for pixel info would create less problems and better picture than rescaling.
PRO-630HD is offline
post #2 of 32 Old 07-07-2011, 09:11 AM
Josh Z's Avatar
Quoted: 2469 Post(s)
Liked: 1621
I've heard it claimed that some transfers do this, but I don't know how common it is.
This might explain why the Alien Blu-ray is visibly cropped on all four sides of the frame.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is online now
post #3 of 32 Old 07-07-2011, 10:39 AM
msgohan's Avatar
Posts on this topic, and correcting your scope resolution:
http://www.avsforum.com/avs-vb/showt...d#post20492653
http://www.avsforum.com/avs-vb/showt...d#post18298018
http://www.avsforum.com/avs-vb/showt...5#post17447495
LG B7 (OLED65B7P, 2017 -- bought 2017/05/31 & I couldn't be happier so far!) | Panasonic CX850 (TC-55CX850U, 2015 -- bought OLED to replace it due to poor off-angle, weird HDR colors, etc.)
UHD: Philips BDP7501 | HD: PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #4 of 32 Old 07-07-2011, 07:43 PM
celboy's Avatar
It depends on the scanner and how the optics are set. On Spirit scanners it depends on how your gate is. you can have a super 35 gate or an academy 35 gate. the 2k ccd's see's whatever the gate is. You can also get an optional (+expensive) electronic scaler which will do electronic blow-ups resizes so you still end up with a 2k file. Obviously you try and check the framing chart if they shot one so you see what they intended.
Since I work with Spirits, thats all I can comment on. But some machines could well scan 2k across full ap and 1828 across academy.
Marc Wielage likes this.
celboy is offline
post #5 of 32 Old 07-08-2011, 08:54 PM
AaronMK's Avatar
Quoted: 25 Post(s)
I'm curious how neatly digital cinema resolutions translate to our 1920x1080 fixed pixel displays and media. When reading about "2k" they usually just specify 2,048 horizontal lines, leaving the vertical resolution out. While pixels used for the image vary for different aspect ratios on blu-ray, they usually say "1920x1080" regardless. (Or "1080p" when wider movies may actually be 817p.)
In digital cinema, post production, digital intermediates, etc, are anamorphic images common? Are anamorphic lenses common in digital filming and projection, or are they working with "fixed" pixels as well? If they do in fact use anamorphic lenses to squeeze out every pixel, it seems some scaling will be unavoidable for blu-ray, at least for wider films.
(I've read that the digital master for Terminator 2 is anamorphic.)
AaronMK is offline
post #6 of 32 Old 07-08-2011, 09:01 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Just my $0.02 worth. They would have to be re-sized. If the image in mapped 1:1 and the edges simply cropped, how does a letter boxed 2.40:1 image become 1920 x 800 if the original is 2048 x 853? To preserve the 2.40:1 AR, the height would also need to be reduced to fit the width.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #7 of 32 Old 07-08-2011, 09:22 PM
celboy's Avatar
Anamorphic is definitely less common due to the availability of good anamorphic lenses. Anamorphic photography also requires more light.
pixels are pretty much fixed regardless of the lenses.
Since T2 was shot flat, I would think it was rendered flat and optically printed scope.
celboy is offline
post #8 of 32 Old 07-08-2011, 10:32 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
It won't upload, but I have an image of a (1K?) D-Cinema projector with two anamorphic lenses. If the projector was 1024 x 768 (12:9), then I guess they would be 1.33x and 1.78x for both 16:9 and 21:9.
ISCO made 1.25x lenses for 2K projectors (2048 x 1080) but AFAIK they aren't being used in D-Cinema projection. The 2K Christie I watched Transformers 3 on (in 3D) did not use an A-Lens. The REAL D 3D shutter panel was mounted on a sled that allowed it to move in and out of the light path, but there was no sign of an Anamorphic Lens in this cinema.
Mark Techer
CAVX is offline
post #9 of 32 Old 07-08-2011, 10:34 PM
CoreyM's Avatar
Quoted: 134 Post(s)
Liked: 138
When I worked for a big CG shop (mid-2000's) digital dailies were done with an anamorphic 3-chip DLP projector but nothing went final until it was shot on film at least once. At the time this was a big deal though because the tech was finally there that they could do what we called "digital film outs" with the anamorphic and a custom LUT that got us very close to film which saved tons of money (less stressful on the staff too since the deadlines for film by morning did not apply).
That was ages ago in terms of how rapidly technology has evolved since then and I haven't really kept up since I left.
XBox: King Nuthin
CoreyM is offline
post #10 of 32 Old 07-08-2011, 11:13 PM
nathan_h's Avatar
Quoted: 1629 Post(s)
Liked: 1074
Joe Kane wrote a piece a year or two ago about how dropping pixels from a 2k image to put it in 1080p resulted in a far better image than downscaling use any scaler available at the time.
My current setup.
My favorite movie review podcast, the Next Picture Show.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is online now
post #11 of 32 Old 07-09-2011, 12:04 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Originally Posted by benes View Post
It is.
So it can't be 1:1 then?
Mark Techer
CAVX is offline
post #12 of 32 Old 07-09-2011, 11:09 AM
Kram Sacul's Avatar
Here's an example I made awhile ago of how much is cropped out of a 2k 2.35:1 frame to get to 1080p:
Kram Sacul is offline
post #13 of 32 Old 07-09-2011, 11:31 AM
dvdmike007's Avatar
Liked: 50
interesting, wonder why they dont just change the ratio
dvdmike007 is offline
post #14 of 32 Old 07-09-2011, 12:13 PM
Fang Zei's Avatar
This raises a question in my mind.
For example, was Star Trek (2009) cropped for the blu-ray or was it resized?
That question goes for just about every new release Hollywood movie of the past several years, since most of them have been complete DI's, either 2K or 4K.
Fang Zei is offline
post #15 of 32 Old 07-09-2011, 01:53 PM
dvdmike007's Avatar
Liked: 50
I was able to see a comparison for a couple of films from last year. The Blu-rays were cropped compared to the 2k cinema version. Can't speak for all films but I wouldn't be surprised if its a standard procedure.
Of course it is. That's the whole reason for cropping it. Its just like masking the edges of the frame.
Can't you squeeze the image like an anamorphic image scan the whole thing and then unsqueeze it?
post #16 of 32 Old 07-09-2011, 06:25 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
And looking at the image of the re-frame, it makes perfect sense and still allows 1:1. As for that extra clipped bit, how many cinemas would actually have their projector framed to full show the bit outside the BD frame anyway?
Mark Techer
CAVX is offline
post #17 of 32 Old 07-09-2011, 06:33 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Whilst I would love to see true anamorphic titles, I don't think it would work at 2K without introducing a heap of artifacts. Maybe if the scans are 3K or more.
I found "wall paper" images that were 2560 x 1600, cropped them down to 2560 x 1080, H-Squeezed them to be 1920 x 1080 (anamorphic) and then displayed them 1:1 expanding them through my 1.33x A-Lens. Some looked great, others revealed some jaggies. Expanding electrically looked bad in every case.
Mark Techer
CAVX is offline
post #18 of 32 Old 07-09-2011, 09:15 PM
celboy's Avatar
I believe Anamorphic lenses for the most part are no longer used in d-cinema projection. DCI compliance requires flat images. But you can get anamorphics for special presentations--but I guess thats rare. I think digital anamorphics was deemed too expensive (to be added to the projector price).
I did see Bladerunner projected anamorphically in NYC and it was one of the best presentations I've ever seen.
celboy is offline
post #19 of 32 Old 07-09-2011, 09:54 PM
celboy's Avatar
I am confused on some of the comments I am seeing here.Can someone enlighten me.or cite a specific title that was "cropped"?
Most major motion pictures are resized down to hd resolution for blu-ray.If anything is cropped, it was intended to be. Star Trek 2009 was shot scope and I see a 2.40 movie on blu-ray.
I believe I usually see more on blu-ray than in theatres because so many cinemas projection practices are horrible throughout the industry.
celboy is offline
post #20 of 32 Old 07-09-2011, 10:18 PM
AaronMK's Avatar
Quoted: 25 Post(s)
Yea, that is why the picture does not bother me. It looks like the BD has everything that would be in the "safe area", and on current displays, overscan is really a non-issue.
AaronMK is offline
post #21 of 32 Old 07-09-2011, 10:56 PM
AaronMK's Avatar
Quoted: 25 Post(s)
Is it possible that the jaggies were caused from the H-Squeeze, and not using an anamorphic lens on digital image (as opposed to film)?
I was wondering why, if anamorphic lenses worked for film (light issues and all), they would not provide the same advantages when sending light into an image sensor and out from a DLP. I take it from this experiment and posts, the bigger issue is scaling artifacts, even if uniform, that would be required between formats.
After the scaling artifacts (even with a good scaler) from anamorphic DVDs had me racing to the service mode on my 4:3 TV back in the day, I would not doubt this.
AaronMK is offline
post #22 of 32 Old 07-10-2011, 12:19 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
I truly don't see the "cost" of an anamorphic lens being the real issue. The ISCO 1.25x lens is about $12K USD. When you consider the cost of the projector, the server and all the other hardware needed to make it run, the said $12k is but a ripple in the finance pond.
I bet. Running that film on my system looks pretty amazing and I only have it in BD, so one can only imagine the extra detail and colour from the DCI source.
Exactly. How much "story telling" information would be stored in the (approx) 53 pixels vertically and 128 horizontally?
Yeah, I would guess the jaggies came as a result of scaling it back from 2560 to 1920.
Interesting points. I ran a few experiments with a HD video camera capturing images through my A-Lens. The results varied and I was able to capture some "true anamorphic video" which I use as a demo for CIH systems. When projected back through the A-Lens, the image looks great. The catch it seems is, that because an cylindrical A-Lens has adjustable astigmatism correction that you set for the projector's throw distance, that focus is out past that point from the camera. I'm sure a better camera would have given a better result, but then again, maybe that is why parts of films shot on film with an anamorphic lens are also way out of focus.
Because the image captured by the imaging chip was optically squeezed by the A-Lens, there was no scaling artifacts. The 1920 x 1080 chip does not know if light is being bent out of shape or not. On playback, the reverse happened where the light projected was simply expanded to restore the geometry. Also because the SAME lens was used or both capture and projection, any "anamorphic mumps" issues are not present either. Even though this lens is corrected for grid distortion, you would (and I've seen this in some BDs where the film was originally captured with an A-Lens) see such an artifact on a lens that was not corrected or had a different optical expansion rate from the 1.33x of my lens.
Also because the projected image was a native 1920 x 1080 pixel, the image is dense. It has a feel to it that scaled BDs don't.
Mark Techer
CAVX is offline
post #23 of 32 Old 07-11-2011, 08:32 AM
Josh Z's Avatar
Liked: 1621
The recent Blu-ray of Alien is cropped in comparison to earlier video transfers. It still maintains a 2.40:1 aspect ratio, but is missing picture information on all four sides, more on the left and right than on the top or bottom. It has been speculated that this was a case of a 2k scan being cropped to maintain 1:1 pixel mapping. The amount of picture missing appears to be consistent with the example that Kram Sacul posted above.
DVDBeaver has screen shots here:
http://www.dvdbeaver.com/film/dvdcompare2/alien.htm
The first comparison (cryo-chambers opening) is the clearest.
Josh Z
post #24 of 32 Old 07-11-2011, 10:08 AM
celboy's Avatar
Thanks Josh,
I didn't realize that was being practiced for features.Its interesting this is happening since many of these features are anamorphic. So non-square images in square pixels are getting re-sampled to square square pixels anyway.
celboy is offline
post #25 of 32 Old 08-14-2014, 11:59 AM
Quoted: 55 Post(s)
Why not keep the vertical resolution of the master? Why hard matte 1080 to 1040 (only some titles) and 858 to 816/810/800? If the original framing is already lost, might as well change the ratio.
luca_frontino is offline
post #26 of 32 Old 08-14-2014, 02:57 PM
Phantom Stranger's Avatar
Quoted: 440 Post(s)
Liked: 334
I think that is done in some cases, it depends on the people supervising the transfer.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #27 of 32 Old 08-21-2014, 10:50 PM
Thebarnman's Avatar
Quoted: 40 Post(s)
Liked: 25
This is disappointing, really disappointing. There's lots of info cut off all away around!
Overscan is controllable on my set so when I watch a movie on Blu-ray, I set it to "Dot-to-Dot" thinking I'm getting the complete image originally captured for theatrical presentation. So what is it that a transfer house have to do to make sure where're getting the complete image? Is scanning at 2k the problem? If so, is scanning at 4, 6 or 8k the answer?
There's talk about scaling the image. Till now, I thought scaling the image was a way to fit a 2k (2048×1556) scan onto Blu-ray's resolution (1920×1080 pixels) so it would look correct (not cutting off any image area along with keeping the correct ratio even though the overall image would be a tiny bit smaller) on Blu-ray.
So as implied by the above post, if scans are being "cropped" to fit the resolution of a video format, then I would think a DVD would look horribly wrong. For example, DVD's resolution is 720x480. So does that mean even more significant image area is "cropped" to fit onto DVD?
Movies must be OAR, sports and movies must also have 5.1 audio, No EE or NO SALE!
Thebarnman is offline
post #28 of 32 Old 08-22-2014, 10:24 PM
nathan_h's Avatar
Liked: 1074
Losing 60 pixels off each side to avoid scaling and softening (losing resolution) across the whole image has been the higher fidelity choice to date.
Some industry people are saying that scaling is good enough with the current gen that that is no longer necessary.
post #29 of 32 Old 08-25-2014, 10:04 AM
Josh Z's Avatar
Liked: 1621
Going back to the example of Alien, what doesn't make sense is that the Blu-ray came from a new 4k scan, not 2k. It had to be scaled anyway. Why crop it?
Josh Z
post #30 of 32 Old 08-25-2014, 01:25 PM
nathan_h's Avatar
Liked: 1074
We know that sometimes the crop of a HD image is because of the desire to not scale from 2k down to 1080p.
But just because something is cropped when delivered as HD doesn't necessarily have anything to do with a choice to not scale. It might just be someone's interpretation of the "safe area" or intended projection.
(Then again, it might be because scaling from 4k to 2k was easier or higher fidelity than 4k to 1.9k.)
My current setup.
Reply Blu-ray Software
