Experiencing audio dropouts on Star Wars? - Page 19 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Audio or video issues with Star Wars? Please select your player and receiver.
Player: Panasonic 0 0%
Player: Pioneer 0 0%
Player: Samsung 0 0%
Player: Oppo 1 33.33%
Player: PS3 2 66.67%
Player: Other 0 0%
Receiver: Pioneer 0 0%
Receiver: Denon 1 33.33%
Receiver: Onkyo 0 0%
Receiver: Other 1 33.33%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
post #541 of 663 Old 12-21-2011, 09:15 AM
nismo604's Avatar
Onkyo just released a firmware update for xxx9 receivers that appears to resolve the DTS bomb issue when skipping chapters in episode IV.
nismo604 is offline
post #542 of 663 Old 12-21-2011, 09:59 AM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
But not for the 906, proving me right.
I do find it ironic that's THX approved DTS HD Master Audio track can't be bitstreamed to a THX approved receiver without issues...
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #543 of 663 Old 12-21-2011, 12:02 PM
Jacob305's Avatar
Quoted: 85 Post(s)
Liked: 48
bitstreams through THX fine on my rc270 onkyo receiver just fine.
Jacob
Jacob305 is online now
post #544 of 663 Old 12-21-2011, 02:32 PM
mr.kludge's Avatar
Quoted: 99 Post(s)
Liked: 115
Check the Samsung BD-P1400 thread starting at this link. Someone else in the UK with the UK set and I assume UK p1400 was having issues until they upgraded to the latest firmware which if I remember right is/was 2.5 and it fixed their issues. If you are relying on the player to update over the Internet via the network port you are out of luck. Samsung stopped providing the latest code over the network port several updates ago YMMV depending on model. You will need to download the update ISO and burn the ISO to a CD to update it. Don't just write the ISO file to a data CD, use the ISO to burn and create the disc. This will probably solve your issue. Many owners of the older Sammy players are running into issues like this with newer releases assuming their player is at the latest code. There is code out there on the server to update it, but it is not the newest.
To check what firmware you are running you press and hold the info button on the remote while the tray is ejected and it will show you the version. You have to compare the date stamp in the code to when the firmware was released and check it against the filename etc. that you download and are on the ISO you burn. I'm not sure of the correct string, but you should have code released late last year/early this to be current. ISO should be on the Sammy support site, but they have been mucking with it this week, so depending on when you check it may or may not be there or easy to find.
I just checked the Samsung.co.uk support website and they do have 2.5 posted released 8 April 2011.
http://www.samsung.com/uk/support/mo.../XEU-downloads
http://www.avsforum.com/avs-vb/showt...3#post20954343
Originally Posted by derekcfoley View Post
Hi mr Kludge - Sorry, originally got the model number wrong, I did correct it in the message body but forgot to edit the title. It is indeed the BD-p1400/XEU, and all other discs (non-Star Wars) all work fine, so its pretty clear its an issue with the way the discs have been encoded for the Complete Star Wars set, that the player just doesn't like.
I've since complained to Samsung, realising that like most people after read a lot of postings too on here and other forums all we can do is wait for an update. Presumably returning the discs to play.com isn't going to do any good.
So much for blu-ray being a standard! So it now makes me wonder how good Samsung are in terms of bothering to regularly update firmware on older players that regularly, or is it driven by the amounts of moaning from users?
Thanks for letting me know your BD-UP5000 machines are ok with the discs, could you tell me what the loading time like in terms of minutes on your model - I keep wanting to buy a faster more recent player, as mine often take 2-3 minutes to start up (presumably due to those lovely but unneccessary java animated menus)
mr.kludge is offline
post #545 of 663 Old 12-21-2011, 03:01 PM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
Better break open my set so I can vote.
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #546 of 663 Old 12-21-2011, 04:37 PM
azazel's Avatar
Yikes... where's the update for the Onkyo 3008/5008 . *sigh*
azazel is offline
post #547 of 663 Old 12-21-2011, 04:49 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
I told you Onkyo wouldn't fix anything before the xx09 models.
Fanboyz is offline
post #548 of 663 Old 12-29-2011, 12:54 PM
WSquared's Avatar
I have an Onkyo 876 AVR and have had the bomb several times tonight in Ep 4(ANH) when rewinding and then pressing play. (I haven't made it to chapter 16 yet, and I will switch my player to output PCM beforehand). I also had the bomb in Ep 2(AOTC) also when rewinding and then pressing play.
WSquared is offline
post #549 of 663 Old 12-29-2011, 05:18 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
I find this mess upsetting, deeply upsetting. DTS HD-Master Audio provides same quality as every other lossless encoding scheme, but is responsible for so many issues. The "continuous innovation" of Blu-Ray authoring is also a nightmare.
Fanboyz is offline
post #550 of 663 Old 12-29-2011, 05:33 PM
IanD's Avatar
Quoted: 108 Post(s)
Liked: 59
It's the reason I use HDMI LPCM for all material now: kinda negates the reason to own a complex AVR.
Isn't the real issue with the way DTS is authored and not the AVRs, since there are many DTS soundtracks already out there that don't create a bomb on susceptible equipment? I think it is up to the studios to fix this compatibility issue, not the manufacturers.
IanD is offline
post #551 of 663 Old 12-29-2011, 05:50 PM
KBMAN's Avatar
Quoted: 341 Post(s)
Liked: 171
I have an Integra DHC-40.1 preamp and a PS3. I've had ZERO issues with any bluray so far. I can imagine though, that in the not too distant future that some issue may come up. Thankfully, with the PS3, I can always do updates, with the Integra support dying soon...
KBMAN is offline
post #552 of 663 Old 12-29-2011, 06:16 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
You have an issue you don't know about.
When the PS3 decodes ROTJ to PCM, the 6th and 7th channels are mute.
Fanboyz is offline
post #553 of 663 Old 12-29-2011, 08:42 PM
ana_moo_ana's Avatar
Quoted: 64 Post(s)
Liked: 41
Same receiver same problem, at this point I don't think Onkyo bothered itself to do anything. Frustrating rally
ana_moo_ana is offline
post #554 of 663 Old 12-29-2011, 11:22 PM
LaoChe's Avatar
Just wanted to report no issues with my Pioneer Elite SC-07 using a Pioneer Elite BDP-09FD player (latest firmware, 2.72) bitstreaming Star Wars IV. No audio drop outs or DTS bomb at chapter 16.
LaoChe is offline
post #555 of 663 Old 01-08-2012, 08:04 AM
Quoted: 64 Post(s)
Liked: 41
any updates regarding Onkyo 876?
post #556 of 663 Old 01-08-2012, 04:27 PM
Jon S's Avatar
Quoted: 926 Post(s)
Liked: 303
Onkyo? Don't even bother buying another one... They have not been answering my emails or returning my phone calls. I have a 905 and a 906 and am still awaiting for a fix. It's been four long months since the issue arose and they are too incompetent or lazy to figure the problem out. I think Denon and Pioneer had fixed the issue about two months into the time frame. Basically, i think Onkyo is hanging us out to dry...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #557 of 663 Old 01-08-2012, 04:30 PM
Davinleeds's Avatar
Huh. Updating to latest TMT solved my issues. Onkyo 605
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #558 of 663 Old 01-08-2012, 04:30 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
I'll just get a Marantz pre-pro and an Outlaw Amp when the upgrade bug hits. Onkyo has lost me as a customer.
Fanboyz is offline
post #559 of 663 Old 01-08-2012, 11:25 PM
Quoted: 64 Post(s)
Liked: 41
Lesson learned indeed, relatively low price wasn’t so low after all
Is it compatible with 876? how to get this file?
post #560 of 663 Old 01-09-2012, 03:31 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Still no problems the Star Wars boxset, but had an audio drop out with Star Wars The Clone Wars Series 3 which is the first of the 3 seasons to be encoded in DTS HDMA. There was simply no sound until I stopped the disc, ejected and reloaded. All good after that.
Mark Techer
I love my Constant Image Height system!
CAVX is offline
post #561 of 663 Old 01-09-2012, 10:01 AM
dholmes54's Avatar
Quoted: 490 Post(s)
Liked: 142
Im still a fan of Onkyo & Onkyo pro but they havnt returned any of my calls or emails,cant we just set are players to pcm instead of bitstream to stop the dts bomb but not knowing when to would be the issue.
dholmes54 is offline
post #562 of 663 Old 01-09-2012, 07:32 PM
azazel's Avatar
I just got an email reply from Onkyo support. They said to retry the update for my 5008. There is no firmware posted on the website but my receiver IS downloading new firmware as I type this. Exciting even though it's 3 months late.
I'll reply later tonight to report if the bombs are gone.
again this is for the TX-NR5008 (which should be good for the 3008 as well), and it's NOT on the website, but online update is working.
azazel is offline
post #563 of 663 Old 01-10-2012, 03:30 AM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
For a time, I was having issues with Dolby True HD sound tracks and the quick fix solution was to set the player to PCM. Player at the time was a Samsung.
The issue raised with Star Wars is the fact that it is 6.1 and some people are concerned about losing the back surround channel. From experiments on my own system (Phillips player, Pioneer AVR), the back surround channel is not lost, rather folded back into the surrounds of the 5.1 system now delivered at PCM. You do lose the 'discrete' aspect of 6.1, but you still hear the full soundtrack if you have a 7.1 system through the use of matrix decoders like THX EX or Cinema 2. Not perfect, but way better than drop outs or buzzing.
Mark Techer
CAVX is offline
post #564 of 663 Old 01-10-2012, 04:35 PM
azazel's Avatar
Firmware version 1081-0600-0310-2101 does NOT fix the bitstream bombs for my TX-NR5008. It's in all the same places on each movie as before the update.
azazel is offline
post #565 of 663 Old 01-10-2012, 04:46 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
Yes but it still gets sent out as 6.1 cpm with a silent Back surround channel.
You can't add THX-Surround EX to something that the receiver already thinks is in 6/7.1. So yes back surround is folded into the rear surrounds but the Oppos and the PS3 still send out a 6.1 LPCM track with an empty back channel.
Fanboyz is offline
post #566 of 663 Old 01-10-2012, 05:30 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Had a play with my system and THX works, but Cinema 2 and EX modes are disabled because the AVR thinks the input is discrete all the time. All I can select is THX Cinema, THX Music or THX Game and all 8 channel lights are on. I got the same for my PC connected over HDMI as well even for 2CH music. All 8 lights are on yet sound comes from front L and R only.
So where does the OPPO and PS3 send the 6th channel to? If it is doing this properly, it should either send it to both back surrounds or simply fold it back into the surrounds of the main 5.1 mix. Mine appears to fold. The point I am making is that you don't lose that back surround info, you still hear it. Again, not perfect, but better than dropouts.
Mark Techer
CAVX is offline
post #567 of 663 Old 01-10-2012, 05:50 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
The Oppo/PS3 sends the 6th channel into the Rear Surrounds, but the signal coming into the receiver is still 6.1 PCM.
So yes you don't loose any audio information, but in this configuration you can never matrix out the 6th channel from the rear Surrounds.
Leaving you with a phantom Back Surround.
Fanboyz is offline
post #568 of 663 Old 01-10-2012, 05:51 PM
Fanboyz's Avatar
Quoted: 536 Post(s)
Liked: 162
Does Return of the Jedi have any "DTS Bombs"?
Fanboyz is offline
post #569 of 663 Old 01-10-2012, 07:28 PM
CAVX's Avatar
Quoted: 228 Post(s)
Liked: 121
Correct and what I system appears to be doing when set to PCM.
Mark Techer
CAVX is offline
post #570 of 663 Old 01-10-2012, 07:52 PM
bunkaroo's Avatar
Just wanted to post I watched through all 6 movies without issues with my Oppo 83 and Onkyo 605 which was previously patched for the DTS bomb years ago.
I will say I found the overall level of the audio to be quite low compared to other similar mixes and even the menu sound.
bunkaroo is offline
Reply Blu-ray Software
