Indiana Jones Trilogy - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 1202 Old 03-05-2012, 03:19 AM
amoergosum's Avatar
Originally Posted by TitusTroy View Post
I agree that the cover art is terrible...they did not need to have 4 shots of Indy from the different movies...just 1 iconic shot of him would have been perfect
I like this one here >>>
amoergosum is offline
post #272 of 1202 Old 03-05-2012, 07:30 AM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 364 Post(s)
Liked: 357
Over sentimentalizing a technical error that was easily missed in a time before large display video taps. Although I cannot recall at the moment whether they even had video tap on Raiders, assuming they did the display was rather tiny and easy to miss such errors, least of all through a viewfinder.
Interesting point. I don't know if the Panaflex of that day (quite early models) yet had a tap; and you are right that it would have been rather crude. Another factor is that Speilberg would sometimes operate shots himself...with various degrees of success and at risk of "missing" something that an experienced operator probably would not.
Cam Man is offline
post #273 of 1202 Old 03-05-2012, 07:44 AM
Evangelo2's Avatar
I might make a custom one that takes off of this poster...
Evangelo2 is offline
post #274 of 1202 Old 03-05-2012, 07:51 AM
spectator's Avatar
As far as the official cover goes, I think the indiscriminate combination of photographs and paintings looks very cheap and tacky (and not in a material-appropriate pulpy throwback way).
I don't feel special...
spectator is offline
post #275 of 1202 Old 03-05-2012, 09:32 AM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
Originally Posted by KMFDMvsEnya View Post
If I can distill our disagreement down to its essential points...
1) Intent vs. tolerances. You believe that unintended errors are fair game for correction. I believe films are full of unintended errors and only the ones that are outside the tolerances of the time are fixed, and they are fixed at the time. So by my definition, no films contain errors worth fixing because if they made it onto the final print, they are, by definition, within tolerances. Neither point is provable, and my position probably seems as naïve to you as yours does to me.
2) Historical value of errors. This is actually derived from the first point. I think errors have historical value because they show what the tolerances for error used to be at various points in history. If you don't think it was within tolerances, of course there's not much historical value.
3) Public right to art in the public space. I think once a piece of art enters the public space, the public has a right to see that this piece of art is preserved in the state in which they saw it (e.g. Library of Congress, etc). I'm not sure you care one way or the other about this.
CatBus is offline
post #276 of 1202 Old 03-05-2012, 10:53 AM
KMFDMvsEnya's Avatar
Quoted: 237 Post(s)
Liked: 397
Correct, for general public exhibition and consumption. Ideally those decisions would be supervised by the pertinent filmmakers; otherwise by individuals that have the appropriate appreciation for (the) film and understand the difference between scrubbing away film grain versus say unintended errors. Such as wires which more often than not were never intended to be visible to the audience.
This is a mistaken assumption that all errors were noted or observed at the time of the take and could be resolved by improving the next take. Even if reshoots are permitted and a particular mistake has been discovered, it may not be practical to get a better take or it is determined that it is tolerable enough to let slide and focus resources elsewhere.
Those who actually have worked on a film project, such as myself, know that errors occur and no one notices at the time but those mistake rear their heads down the road when it may not be feasible to redo. If the error is egregious enough then yes it would be a candidate for a reshoot.
Yet if you had an elaborate set and it has already been torn down and the hypothetical shot is fairly wide you go with the take that has the best performance, hopefully without any obvious issues. Especially before the advent of powerful digital tools.
That is one assumption and can be correct periodically but I disagree that it is the rule rather than the exception. Coming from experience being on actual shoots and film school.
This is a flawed premise, although it does retain a fair amount of truth to it. Again mistakes actually can be missed until the film is released or when it is too late in post-production, it happens and in order to meet deadlines the filmmakers must resign themselves to that state and hope no one notices.
In respects to archival copies I fully endorse retaining the highest quality versions possible, including errors. What I disagree with is retaining certain issues for home theater consumption.
A different animal but I agree with you partly here. As mentioned prior in this response and earlier in the thread. The highest quality archival copies should be retained for the sake of posterity, with the inclusion of various errors. I believe Library of Congress attempts to retain various versions of works that have been revised. Books that have been changed by the author for example or Star Wars where I believe they do have several versions.
I feel that for general public consumption certain issues can and should be addressed so long as they are subtle, organic, congruent, unintrusive, and complimentary to the suspension of disbelief. I do understand why some feel that corrections are inappropriate revisions. Although I believe the heighten sensitivity has more to do with the imprudent, incongruent, superfluous, inconsistent, and obnoxious changes Lucas applied to Star Wars.
I hope this provides clearer common ground.
Best Regards
KvE
PS I love those alternate cover suggestions, amoergosum and Evangelo2. Perfectly depicts the spirit of the series.
Why subtlety and simplicity escapes Lucasfilms these days is perplexing.
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
post #277 of 1202 Old 03-05-2012, 11:13 AM
CatBus's Avatar
Quoted: 23 Post(s)
Liked: 41
I think if someone sees the error, really wishes they could fix it, but budget, time, and logistical restrictions make it infeasible so they let it pass, then they've just made the call that it's within tolerances. And if they failed to see it at all, then it's within tolerances too. It's a subjective terminology disagreement at this point is what I'm saying, your terms and mine are not in accord, and I'm not sure there's much to be done about changing that.
CatBus is offline
post #278 of 1202 Old 03-05-2012, 12:12 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
What photos do ye speak of? That's all drawn poster art on the official cover.
Edit: Just double checked, yep, it's all drawn. Crystal Skull and Last Crusade are from Drew Struzan's posters, Temple of Doom is by Bruce Wolfe (got that one on my wall, it's badass) and Raiders is Richard Amsel's poster.
Geoff D is offline
post #279 of 1202 Old 03-05-2012, 12:19 PM
spectator's Avatar
The bottom left corner (Last Crusade?) image is either a photo or looks substantially more photo-realistic than the other images.
post #280 of 1202 Old 03-05-2012, 12:21 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
Such is the power of Drew Struzan.
http://www.impawards.com/1989/indian...sade_ver1.html
Geoff D is offline
post #281 of 1202 Old 03-05-2012, 01:09 PM
spectator's Avatar
Look again. The image on the cover mock-up is the photograph on which that Struzan art is based.
post #282 of 1202 Old 03-05-2012, 01:53 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
Hmmm. It's not Struzan's art, you're right, but it still doesn't look like a photograph to me, neither does this one which I presume is the same base image of Indy: http://www.amazon.co.uk/gp/product/B00147AK76
Actually, that larger Last Crusade cover kinda looks like a stylised head has been 'shopped onto the real torso from the photograph.
Geoff D is offline
post #283 of 1202 Old 03-05-2012, 02:59 PM
ZGibbs's Avatar
It's Stuzan's work, it's just been touched up for the cover.
ZGibbs is offline
post #284 of 1202 Old 03-05-2012, 03:02 PM
spectator's Avatar
Whatever the case, it looks incongruous with the other, more figural/representational images. It makes the cover look sloppy and thrown together, IMO.
post #285 of 1202 Old 03-05-2012, 04:01 PM
dvdmike007's Avatar
Liked: 50
Worlds biggest Struzan fan here, but never loved his original Raiders work.
dvdmike007 is offline
post #286 of 1202 Old 03-05-2012, 04:24 PM
Geoff D's Avatar
Quoted: 300 Post(s)
Liked: 326
The art he did for the Japanese poster was awesome.
Geoff D is offline
post #287 of 1202 Old 03-05-2012, 04:34 PM
dvdmike007's Avatar
Liked: 50
It was good, but the original one sheet was iconic
post #288 of 1202 Old 03-11-2012, 10:18 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
Classic. Richard Amsel. Bought a used folded poster a few months after the movie came out through a Canadian seller. In the 80's you bought posters from seller ads in publications, magazines, etc.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #289 of 1202 Old 03-11-2012, 02:50 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Mr.G,
your pic is not showing up.....
KBMAN is offline
post #290 of 1202 Old 03-11-2012, 04:09 PM
dvdmike007's Avatar
Liked: 50
This one?
post #291 of 1202 Old 03-11-2012, 06:56 PM
IanD's Avatar
Quoted: 82 Post(s)
Liked: 50
Just as we have the Hippocratic oath popularised as "first do no harm", I think we need an equivalent one for film "first ensure the original is preserved".
IanD is offline
post #292 of 1202 Old 03-11-2012, 07:32 PM
DavidHir's Avatar
Quoted: 1702 Post(s)
Liked: 1321
To me, that is the classic Raiders art and what I remember growing up around.^^^
DavidHir is online now
post #293 of 1202 Old 03-11-2012, 07:33 PM
dvdmike007's Avatar
Liked: 50
One of the very best one sheets ever produced
post #294 of 1202 Old 03-12-2012, 07:05 AM
nick_danger's Avatar
Originally Posted by davidhir View Post
to me, that is the classic raiders art and what i remember growing up around.^^^
one of the very best one sheets ever produced
+1
nick_danger is offline
post #295 of 1202 Old 03-14-2012, 04:23 PM
Mark Booth's Avatar
Quoted: 49 Post(s)
Liked: 61
That one-sheet has been hanging on display in our home theater room since 1989! It still looks great! And I agree it's one of the best one-sheets of all time!
Mark
Mark Booth is offline
post #296 of 1202 Old 03-14-2012, 04:49 PM
dvdmike007's Avatar
Liked: 50
Struzan got way better with raiders the more he tried, I am not a fan of the wind swept first version.
I own all the book collections of his work and a couple of original one sheets, but his later Raiders and the other movies became and embodied Jones as a series.
post #297 of 1202 Old 03-18-2012, 01:38 PM
Waboman's Avatar
Quoted: 4583 Post(s)
Liked: 10692
Blu-ray trailer.
Waboman is online now
post #298 of 1202 Old 03-18-2012, 08:39 PM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
Blu-ray trailer.
Good stuff looking forward to it.
_________________________
Franin is offline
post #299 of 1202 Old 03-18-2012, 09:06 PM
inspector's Avatar
Quoted: 36 Post(s)
I could care less what's on the front, I only see the spine when it's in my collection. Now LDs had some beautiful covers and those you could frame and hang. I have 2 framed, both autographed. Ann Robinson "War of the Worlds" and Paul Manti "Robinson Crusoe on Mars."
Never seen a BD cover hung on a wall...who'd want to?
...finally retired and spending time in my HT!!!
Equipment consists of: Epson 9500 UB Projector(Avical ISFd);110" 16x9 JKP Affinity Screen;Panny BD30 Player,Tosh HDA1 Player;Definitive Speakers (Center, Towers, Rears);Earthquake P12 sub;Onkyo 608 A/V Receiver;Nevo Q50 Remote;TWC-HD Cable Box;5 Bello chairs;Coaire Mini-split A/C.
inspector is offline
post #300 of 1202 Old 03-19-2012, 09:58 AM
Shaded Dogfood's Avatar
Quoted: 118 Post(s)
Liked: 83
Are we arguing that the poster in post #290 is the original one-sheet?
The original (cropped) is the one in post #271.
CW Hinkle
Shaded Dogfood is offline
Reply Blu-ray Software
