Hugo - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 183 Old 04-05-2012, 12:54 AM
tausifs's Avatar
Quoted: 12 Post(s)
Originally Posted by Alan G. View Post
Tausifs,
I just checked again and there is a very slight*, clean black border around the picture's top, sides and bottom. So I put in a Blu-ray copy of Beetlejuice where the aspect ratio is listed as 1.85:1 and it, too, has the same border. I hadn't noticed the border before as I sit back some and the TV's bezel is black.
Doesn't seem to be what you described.
*maybe 3-4mm, tops, at its widest.
Thank you, so sounds like 2D Hugo fills your screen as best it can. I think we in the UK are being short-changed with the 2D/3D disc release.
I used 1.1 overscan and it fills the screen so is a workaround.
tausifs is offline
post #182 of 183 Old 06-02-2012, 06:54 PM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
Is there much LFE in the train crash? I read that this is a high impact scene, as u would expect, but I heard nothing as if my sub was off.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #183 of 183 Old 06-02-2012, 11:52 PM
surap's Avatar
If there is, it is very little.
surap is offline
Reply Blu-ray Software
