BOARDWALK EMPIRE Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 02-01-2012, 02:18 PM - Thread Starter
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
Hard to believe there's not a single post about this. The new BD edition of BOARDWALK EMPIRE is plagued with problems....freezing, non-existent menus, etc., have been reported by numerous people who have purchased this set. Replacements have displayed similar problems. HBO has given this release the same care that they give to their cropped movies! It would seem that a recall should be in order for this item. Anyone else encountering issues?
cinema13 is offline
post #2 of 19 Old 02-01-2012, 02:29 PM
Semp1's Avatar
Quoted: 12 Post(s)
It's because it's clearly not an issue on HBOs side. It works flawlessly with the PS3. I'm assuming who ever has the issue is using a different player. Which means its most likely a firmware issue and needs to be corrected from the hardware side of things.
65VT60+55GT50+Onkyo TX-NR727+Denon AVR-1913+OPPO bdp-103+OPPO bdp-83=Heaven
Semp1 is offline
post #3 of 19 Old 02-01-2012, 02:42 PM
rdgrimes's Avatar
Quoted: 1993 Post(s)
Liked: 1321
I think there are several players having issues with this set due to some new JAVA programming. Recommend trying it with BD-Live turned off and be sure to erase persistent storage.
FWIW, Warner is actually responsible for disc authoring and distribution.
rdgrimes is online now
post #4 of 19 Old 02-01-2012, 02:57 PM
d3code's Avatar
Quoted: 98 Post(s)
Liked: 34
i have watched the whole the set and have no problem at all on my PS3.
sorry to hear it, because the serie is awesome.
d3code is offline
post #5 of 19 Old 02-01-2012, 03:24 PM
giantchicken's Avatar
No problems on my PS3.
PETER JACKSON: The theatrical versions are the definitive versions.
giantchicken is offline
post #6 of 19 Old 02-01-2012, 09:36 PM - Thread Starter
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
Yes, the PS3 units are the ONLY machines that seem to be able to play these. One would assume that pricey BD sets are authored to work on all (or at least the majority) of BD players, and not just only on the PS3 gaming consoles. From what I've heard/read so far, the problem has been reported by owners of players made by Sony, LG, Samsung (mine) and Panasonic. Turning BD-Live off does not make a difference. A set this widely defective should definitely be addressed by Warners. And anyone without a PS3 should NOT consider purchasing the BD edition of BOARDWALK.
cinema13 is offline
post #7 of 19 Old 02-02-2012, 09:58 AM
RY35AN's Avatar
I've played the first two episodes on my Panasonic 110 without any issues.
I don't have access to BD-Live though since I don't have the memory stick.
XBOX 360-RY35AN
PS3-RY35AN
RY35AN is offline
post #8 of 19 Old 02-02-2012, 10:05 AM - Thread Starter
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
First two discs were fine on my set also. Try Discs 3 and 4
cinema13 is offline
post #9 of 19 Old 02-02-2012, 11:04 AM
rdgrimes's Avatar
Liked: 1321
As I recall, this set uses a new JAVA Resume function, the first for HBO series. This is likely the source of the issue if it stops a disc from loading. One approach with these type errors is to erase persistent storage each time you eject a disc. Messed up code from one disc in the set could effect another disc in the set. But there are other examples where the resume programming is just broken. Also be sure to use the "stop" command during playback before hitting eject.
post #10 of 19 Old 02-02-2012, 03:25 PM
stumlad's Avatar
i watched the whole season on my Sony S470 without any issues.
stumlad is offline
post #11 of 19 Old 02-02-2012, 11:02 PM
RY35AN's Avatar
Crap, I was hoping I wouldn't get that type of response.
I'll throw them in and report back.
Happy to report no issues, all discs load up fine.
Sorry to those having problems.
XBOX 360-RY35AN
PS3-RY35AN
RY35AN is offline
post #12 of 19 Old 02-03-2012, 09:15 AM
djdmt's Avatar
Of course it wouldn't work, They didn't even have blu ray players back then! /joke
djdmt is offline
post #13 of 19 Old 02-03-2012, 09:29 AM
nick_danger's Avatar
Words to live by. Every disc just loads faster and has fewer problems this way.
nick_danger is offline
post #14 of 19 Old 02-03-2012, 10:27 AM - Thread Starter
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
Seem to have found a way to avoid the freezing. It seems to work okay if you press PLAY ALL, instead of selecting the individual episode.
cinema13 is offline
post #15 of 19 Old 02-12-2012, 11:38 AM
OldDog_NewTricks's Avatar
My spouse & I have a Toshiba BDX1100KU Blu-ray player (with the BR-live feature) and we have not been able to use the "episode selection" feature on this HBO set without the player locking up. The player seems to do its' version of a blue screen of death. (instead, it is a bright white screen). For those users that have tried to find a firmware update for this Toshiba model, Toshiba tells users in the FAQ section that no firmware update is available. None of my PC's have Blu-ray drives in them, so I can't tell folks if this method of watching the Blu-ray discs would work.
Turning the BR-live feature off has no effect. For a work around, we use the chapter advance key on the remote to advance to the next episode. The other main menu features of the discs work fine. There is a "biography feature" that is handy for insight into some of the characters.
The picture quality is stunning (in my opinion) and the audio is very good as well. I'm still glad that we bought this version (discounted, of course )
But if we paid the full MSRP at HBO for example, I'd be very angry.
Overall -I'd give this a thumbs up. BUT - to HBO: Guys, get this fixed! What would Nucky Thompson say?
OldDog_NewTricks is offline
post #16 of 19 Old 02-13-2012, 09:12 AM
stumlad's Avatar
Yeah I forgot to mention that with my Sony, I dont use BD Live at all - network cable unplugged.
stumlad is offline
post #17 of 19 Old 02-21-2012, 12:27 AM
BattleCat's Avatar
I had the same problem. I had bought a cheap BD player (Sony BDP-S380) at the same time as the Boardwalk Empire DVD's. I was online to see if there were any hardware updates that I needed as anything other than 'Play All' either froze the disc with a really loud piercing screech coming from the TV or dropped me back to the 'Home' menu. I exchanged the discs after checking other BD's in the machine. The second copy was exactly the same. Just annoying!
BattleCat is offline
post #18 of 19 Old 08-23-2012, 04:20 PM
BoardEmpWatcher's Avatar
I received Boardwalk Empire as a 2011 Christmas gift. I could watch the discs, but my new Sony BluRay would freeze up if I tried to fast forward to the next scene, or try to use the enhanced features. (My BluRay actually froze up for so long, that I had to unplug it just to turn it off. None of the buttons on my BluRay remote got a response from the BluRay.) As long as I watch the disc with all scenes in sequence I could get through it. Of course, this did not make me happy as I was missing some of the features on the discs. I had been updating my BluRay every 3 months or so, trying the Boardwalk Empire discs afterwards again only to encounter the same problems. Then just yesterday, (Aug. 23) after another software update on my BluRay-magically everything worked on the discs, fast forward, scene advance, and the enhanced features. Even the part where the disc says to push the red button, that worked! So Sony finally figured out what was wrong and corrected it.
BoardEmpWatcher is offline
post #19 of 19 Old 08-31-2013, 03:58 PM
dpogorelec's Avatar
I just got this release today (08/31/13) and encountered a problem-- on trying to watch the first disk my player freezes while watching "previews". You cannot get out of the previews with "top menu" or "popup" button. I did find out if I disconnect the network connect the disk worked. However the "next chapter" button sometimes again freezes the player.
dpogorelec is offline
Reply Blu-ray Software
