Total Recall Special Edition (1990) - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 548 Old 08-30-2012, 09:47 PM
IanD's Avatar
Quoted: 108 Post(s)
Liked: 59
Originally Posted by homogenic View Post
rolleyes.gif Current consumer displays are inferior.
By display chain I meant player, VP and display.
I really dislike studios dumbing down releases to the lowest common denominator, when they should be aiming for the highest and allowing the consumer to dumb it down to their individual tastes: you can't go the reverse path once entropy has done its work.
IanD is offline
post #542 of 548 Old 08-31-2012, 07:17 AM
DJ Mike TJG's Avatar
Originally Posted by Strevlac View Post
Inferior to what? What is your point?
In fairness, a lot of consumer displays come out of the box adjusted for shop-level lighting - which means massively inflated contrast/brightness/backlight/sharpness. Also means stuff like grain sticks out like a gigantic sore thumb, hence why studios end up DNR'ing the heck out of it - because Joe Average sees it through his eye-burning display and thinks "why the heck is this so fuzzy?"
That at the very least makes the majority of consumer displays inferior... Even if people can calibrate them to be better.
DJ Mike TJG is offline
post #543 of 548 Old 08-31-2012, 10:06 AM
dvdmike007's Avatar
Liked: 50
http://www.stoneaudio.co.uk/?google=13333
dvdmike007 is offline
post #544 of 548 Old 08-31-2012, 11:50 PM
homogenic's Avatar
Is this your early birthday gift to me? Thank you.
homogenic is offline
post #545 of 548 Old 06-06-2014, 01:46 PM
C*Tedesco's Avatar
Quoted: 48 Post(s)
Liked: 57
Yeah, i hate to bring up an old thread here, but I finally got the Mind Bending TR BR disc this week (4.99). I looked through the thread and saw most talk on color/dnr/lip sync, but my problem is there appears to be some studdering in some scenes on the disc. Or even yet, some slight fast forwarding that last but a second. Hard to explain, but never have seen this on a BR before.
The BR itself, I was expecting this look a tad better, but it's an old disc and not complaining about the actual transfer. Just wanted to know if anyone had issues with the studdering/fast forwarding issue? Not sure if that makes sense, but that's all I got.
C*Tedesco is offline
post #546 of 548 Old 06-06-2014, 05:58 PM
Jason One's Avatar
Quoted: 12 Post(s)
There was earlier discussion in this thread about the fact that this disc runs at 24.000 fps instead of the more common 23.976. This could cause dropped frames on some displays. Maybe that's what you're seeing.
See my earlier post and surrounding discussion.
Jason One is offline
post #547 of 548 Old 06-07-2014, 12:12 PM
KMFDMvsEnya's Avatar
Quoted: 262 Post(s)
Liked: 457
Yes the periodic stutter is due to the incorrect flagging of 24fps versus 23.976.
Picture wise I think it looks great.
Best regards,
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is offline
post #548 of 548 Old 12-11-2016, 07:43 PM
lqvnguyen's Avatar
Best regards,
KvE
Both 23.976fps and 24.000fps are valid frame rates for BD movies. Since TR MBE is the exact same encode as UK TR Rekall Edition, legacy U.S. displays suffer since StudioCanal simply choose to encode it at 24fps. Some people will see issues, other will not. It just depends on whether or not the playback device can output:
1) 24fps for displays that can accept 24Hz as an input signal and have the display either render the image in multiples (48Hz,72Hz,96Hz, 120Hz) or perform a proper IVTC from 24fps to 60fps
2) The playback device properly performs the IVTC from 24fps to 60fps and output that to a display capable of 60Hz.
If your display is not capable of accepting and processing 24hz or 60hz (read only 23.976hz or 59.95hz), you will experience frame playback hiccups and audio sync issues.
lqvnguyen is offline
Reply Blu-ray Software
Blu Ray Movies , Total Recall Mind Bending Edition Blu Ray , Robocop Blu Ray
