Gorgeous Timelapse Blu-ray and 4K "TimeScapes" now shipping - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 71 Old 10-24-2013, 12:49 AM
zebity's Avatar
Hi Dan,
LG 4K is 3840 x 2160p .
Hence need to down convert...
Any suggestions?
Cheers,
Zebity
zebity is offline
post #62 of 71 Old 10-24-2013, 08:58 AM
Dan Hitchman's Avatar
Quoted: 3561 Post(s)
Liked: 1904
Originally Posted by zebity View Post
Hi Dan,
Any suggestions?
Cheers,
Zebity
You originally made it sound like the 4k file worked with your LG UHDTV. You might have to contact the distributor of Timescapes and see what they recommend. Or at least suggest they conform their files to 2160p.
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #63 of 71 Old 10-24-2013, 09:49 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
TimeScape / 4kers,
I purchased the cineform hd version of TimeScapes movie so I could have some high quality 4k video to test my LG 84LM9600 Ultra HD TV.
The Cineform file is 4096 x 2304, but tv is 3840 x 2160.
I am using a MacBook Pro Retina Display with OS X Mavericks as my player and it is able to work at 4k @ 30 & 24 FPS with the LG.
My problem is how do I down convert 4096 x 2304 Cineform to a 3840 x 2160 format?
Zebity
Sorry to inform you that you bought the wrong version.
When you don't have a display or playback facility that can use the Cineform format, the Cineform version is unusable for you, unless you run it through a Transcoding process and render it to a format and a crop you can display.
The 4K UHD - H264 3840 x 2160, 25Gb file would have been the right choice for you, or maybe even the 4K UHD - Prores 3840 x 2160, 120Gb (if you can playback ProRes).
coolscan is offline
post #64 of 71 Old 11-06-2013, 11:40 AM
zebity's Avatar
Hi Coolscan & Co,
I have done some additional research and the combination of downloaded Cineform codec for QuickTime on Mac (the NeoPlayer for Mac, downloadable from Cineform web site) and Apples Compressor utility allow transcoding of 4K formats.
I tried ProRes 422HQ (3840 x 2160) , which turned 320 gb Cineform source to 280 gb mov file.
Playing this from MacBook Pro resulted in great image quality, but Mac could not keep up throughput and dropped sound. I tried to play with both QT and VLC, but both had problems with play back.
Now in process of transcoding to ProRes 422 and H.264 4k at 3840 x 2160 to see how these go.
The transcoding takes around 12 hours on 12 core Mac Pro, so testing different codecs is a slow process.
Cheers,
Zebity.
zebity is offline
post #65 of 71 Old 11-06-2013, 09:35 PM
Liked: 1904
MOV files are terribly slow and kludgey due to the Quicktime engine being only 32 bit and poorly written. There has to be a better wrapper to use. I read about complaints from video producers all the time.
post #66 of 71 Old 03-29-2016, 10:27 AM
dilipb's Avatar
Quoted: 22 Post(s)
According to
http://4k.com/news/a-complete-list-o...n-prime-12685/
Timescapes B00X50COB0 is available to buy on Amazon Video in UHD format for only $3.99 !!
http://www.amazon.com/TimeScapes-Ult.../dp/B00X50COB0
aaronwt and jdanforth like this.
dilipb is offline
post #67 of 71 Old 03-29-2016, 04:28 PM
Liked: 6
quite a revival of old thread - looks like I have some Amazon credits that will be expiring. all they give me now is Prime pantry credits, not as many video credits. This is one thing to use it on.
joeythesuper is offline
post #68 of 71 Old 03-29-2016, 07:38 PM
wuther's Avatar
Quoted: 643 Post(s)
Liked: 185
Originally Posted by dilipb View Post
According to
Streaming which means crushed to below BD quality. Do not know why you are posting in a blu-ray sub-forum.
wuther is offline
post #69 of 71 Old 03-30-2016, 06:42 AM
dilipb's Avatar
Quoted: 22 Post(s)
Apologies for posting this.
However this streaming quality using HEVC codec and at 4K, it is way better than a Blu Ray.
I thought people who may have a 4K TV with the Amazon app can enjoy this at a much more higher resolution than blu ray and at a cheap price.
Again did not want to hijack this thread, just posted since it was a related item.
dilipb is offline
post #70 of 71 Old 03-30-2016, 05:34 PM
wuther's Avatar
Quoted: 643 Post(s)
Liked: 185
There has not yet been demonstrated a 4K streaming even at par with the same content on BD. Crushing down a 180GB video to 10to15GB is not going to produce quality and does not matter if it is a UHD stream or what the codec is.
You really should be posting this in the streaming sub-forum where low quality is better received.
wuther is offline
post #71 of 71 Old 03-31-2016, 05:22 PM
UHD Addict
aaronwt's Avatar
Quoted: 6413 Post(s)
Liked: 3963
I just watched this from Amazon UHD streaming. I thought it looked very good for UHD streaming content. And for only $4 it was an excellent deal. I hope they plan to release it on the UHD BD format. That would really look superb. Has there been any news about it on UHD BD?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
Reply Blu-ray Software
