Transformers: Dark of the Moon NOT playing in Dolby TrueHD 7.1 (??) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-30-2012, 04:48 PM - Thread Starter
KtrainHurricane's Avatar
Quoted: 38 Post(s)
I have an Onkyo-709 receiver, PS3, and Panasonic ST30 television. My Playstation is updated, and I have not had problems like this before. Yes, I DID go to the Languages menu and select "English Dolby TrueHD 7.1" (had that "problem" with my copy of Blade Runner). When I scroll through the "Listening Modes" on my receiver I can choose PLIIx, DTS: Neo 6, all the THX options, Dolby Digital, Dolby EX, etc...but no TrueHD. Can somebody help me?!
KtrainHurricane is offline
post #2 of 14 Old 06-30-2012, 05:04 PM
KMFDMvsEnya's Avatar
Quoted: 237 Post(s)
Liked: 400
Under the audio setup of your PS3 is DTHD 7.1 enabled?
Personally prefer to have the player decode rather than bitstream, also I have a 5.1 system so I have to limit output to those channels.
Best Regards
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is offline
post #3 of 14 Old 06-30-2012, 06:05 PM - Thread Starter
Quoted: 38 Post(s)
Best Regards
KvE
Yes, Dolby TrueHD 7.1 is enabled on my PS3. I always allow the receiver to decode the audio itself; however, once I realized it wasn't outputting TrueHD I attempted to scroll through the options to manually select it...but that obviously was not possible.
post #4 of 14 Old 06-30-2012, 08:57 PM
daveshouse's Avatar
Is this the 3d version or regular? The 3d version won't play Dolby TrueHD and display in 3d at the same time on the Playstation. Only DTS-Master HD works with 3d at the moment
daveshouse is offline
post #5 of 14 Old 06-30-2012, 09:26 PM - Thread Starter
Quoted: 38 Post(s)
Ahh I see. Yes it it the 3D version, and I was not completely aware of the fact that Playstation won't play 3D and TrueHD at the same time - I did some searching on the internet and read that to be the case, but all the posts/threads I found were from February 2012 or prior...I thought there was a chance that a PS3 update had solved this issue since then. Thanks for the reply!
post #6 of 14 Old 07-01-2012, 01:53 PM
Dan Hitchman's Avatar
Quoted: 3414 Post(s)
Liked: 1767
You would make a great case study for the purchasing of a cheap standalone 3D Blu-ray player to compliment a PS3. wink.gif
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is offline
post #7 of 14 Old 07-01-2012, 11:15 PM - Thread Starter
Quoted: 38 Post(s)
I have one...but decided to leave it in the living room. I actually had the PS3 in the living room and my Panasonic Blu-ray player in my movie room, but wanted the option of playing video games (have been into Rocksmith lately) in the movie room.
post #8 of 14 Old 07-02-2012, 11:06 AM
Josh Z's Avatar
Quoted: 2143 Post(s)
Liked: 1439
The PS3 was updated to allow both 3D and DTS-HD Master Audio at the same time, but still cannot do TrueHD and 3D simultaneously.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #9 of 14 Old 07-02-2012, 07:34 PM
muffinmcfluffin's Avatar
Quoted: 223 Post(s)
Liked: 130
Do you happen to know off the top of your head which firmware it is that corrected this?
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is offline
post #10 of 14 Old 07-02-2012, 08:54 PM
QuiGonJosh's Avatar
Quoted: 245 Post(s)
Liked: 101
I think it's just 7.1 TrueHD and 3D. I think 5.1 TrueHD and 3D is okay, but I'm not 100% sure. My PS3 wouldn't play the 7.1 track on the 3D Transformers either.
QuiGonJosh is offline
post #11 of 14 Old 07-03-2012, 11:10 AM
Josh Z's Avatar
Liked: 1439
I believe it's any form of TrueHD and 3D, regardless of 5.1 or 7.1.
I don't know the exact firmware that fixed DTS-HD MA, but whatever is the latest on the network should take care of it, I'd think.
Josh Z
Josh Z is offline
post #12 of 14 Old 10-18-2012, 01:27 AM
sookymonster's Avatar
Its still having this problem. I was wondering why True HD only worked sometimes. Now I realise its the ps3's fault. I just confirmed it by trying my 2D Transformers. Thanks anyway, it does still suck. C'mon SOny!!mad.gif
sookymonster is offline
post #13 of 14 Old 11-05-2012, 01:51 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Is it correct to assume that the PS3 still cannot do TrueHD with 3D? Any rumors for when they will implement this?
lovingdvd is offline
post #14 of 14 Old 11-10-2012, 02:26 PM
PeterTHX's Avatar
Quoted: 329 Post(s)
Liked: 246
Probably if enough people write in about it they will get around to it.
Esepcially since TrueHD is much less CPU intensive to decode. If they can do DTS-MA & 3D then they can do TrueHD.
My opinions do not reflect the policies of my company
PeterTHX is offline
Reply Blu-ray Software
