Official Blu-ray Picture Quality Rankings: The PQ Tiers (updated through May 25, 2015 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #1 of 35 Old 08-20-2012, 04:59 PM - Thread Starter
SuprSlow's Avatar
Blu-Ray Picture Quality Rankings
"Oculi plus vident quam oculus" - "Several eyes see more than only one"
Latest Database Update: May 25, 2015 by the Phantom Stranger
THIS IS THE MASTER LIST FOR ALL PQ TIER RANKINGS. NO COMMENTS ARE ALLOWED.
USE THE FOLLOWING THREAD FOR DISCUSSION:
The New PQ Tier Thread for Blu-Ray - Discussion & Analysis)
Tier 0 (Blu) is ranked in order from the absolute best picture quality sitting at the top. Tiers 1 through 5 decline in picture quality from Tier 0 and are alphabetized within each sub-tier.
If you are looking for a particular movie, press (Ctrl + F) to search the entire PQ Tiers.
Please Read Before Making a Ranking or Specific Placement:
We honor all user feedback and discussion when considering the final placement of any title. We recommend your review in the following format:
Title of Film
Review which follows the guidelines set forth by the PQ Tiers.
Tier Recommendation
Noting your screen size and viewing distance is not necessary but helpful.
How it works:
We welcome opinions on all Blu-rays, no matter how controversial or how long a title has enjoyed its placement. Final placements are often the result of weighing a wide range of recommendations. Often there is no majority opinion on any given title and a certain level of disagreement is expected given the subjective tastes of each participant in the thread. Opinions and placements can change over time depending on group consensus and the evolution of the Blu-ray format. The best way to make sure your point of view is represented in the final decision is by writing a short review with an exact recommendation in the proper format.
Every few months, the moderator does an accounting of all new posts looking for reviews and recommendations. Using the format described above will ensure that your recommendation is counted. If there is a dispute about a specific placement, other reviewers may challenge you to support your recommendation with further debate and discussion. In these cases, the moderator may go deeper and read the debate. You are not obligated to defend your review nor to engage in debate, but it can help the moderator to further understand your recommendation. Every few weeks the moderator collects the reviews, reads the debates if necessary, and then titles are given one exact ranking at the moderator's discretion. Final placements can be challenged if there is noticeable support for a different assessment, though the final judgment is reserved at the discretion of the Phantom Stranger.
How each Tier is categorized and ranked
Notice: For the purposes of this system we do not take director's intent into consideration when evaluating the visual quality of each Blu-ray. This list represents an absolute ranking system, where every Blu-ray's picture quality and visual appeal is directly compared against every other release. Those interested may want to use the thread search feature to peruse the individual reviews that contributed to these placements, for further clarification. Tier placements can change over time as feedback warrants.
Tier Zero - Blu (Reference)
Blu-ray titles in this tier consistently offer reference level high-definition picture quality that continues to impress both at viewing distances approximately 1.5 screen widths from the display and on larger projection screens over 100”.
A Blu-ray in Tier Zero will generally exhibit the following characteristics:
A sharp image with a palpable sense of depth, clarity, and presence that will often appear nearly three-dimensional in nature.
Excellent contrast, superb shadow detail, and the deepest black levels without macroblocking or clipping.
Exquisite resolution of ultra-fine detail, fabric and surface textures, individual strands of hair, and human faces down to the imperfections and pores. Animated material will often exhibit photo-realistic qualities and will feature beautifully rendered environments.
Sophisticated color palettes will be completely resolved down to the most subtle gradations of each hue. Primary colors will appear striking and dynamic. Black-and-white material will exhibit top-notch and accurate grayscale reproduction.
A film-based title will exhibit natural grain structure free of excessive digital noise reduction (DNR) or filtering that results in a noticeable impact on the image, including waxy looking faces and missing high-frequency detail in general.
Halos and ringing artifacts are either absent or not visible enough to be distracting from standard viewing distances.
No alteration from the originally intended aspect ratio or viewable image area.
An artifact-free video compression encoding that shows virtually no signs of chroma noise, banding, posterization, aliasing, macroblocking, compression noise, and other encoding deficiencies.
The transfer of the Blu-ray will be sourced from a master with virtually no visible flaws. This entails an image free of print damage, dirt, specks, cue marks, and other flaws that should be absent from a new and pristine transfer of source material in excellent condition.
Tier 1 - Gold (Excellent)
Blu-rays in this tier are demo-worthy and exhibit many of the same image qualities as titles in tier zero, albeit with a few qualifications: May demonstrate reference picture quality but have brief periods of inconsistency; Or may exhibit excellent quality in general but ever so slightly rank below tier zero quality in terms of visual interest, detail, contrast, depth or clarity. Differences between titles in the top two tiers can be very subtle.
Tier 2 - Silver (Good)
The titles in this tier are representative of good picture quality that is above-average and a significant upgrade over standard definition. The image will demonstrate a sharp nature that begins to approach a stronger quality of depth and dimensionality not present in the lower ranked tiers. Typically the image will lack any of the major deficiencies seen in the lower tiers such as visible compression artifacts, inappropriate application of post-processing tools, master defects, etc. While the Blu-rays ranked here are not truly worthy of being demo quality, they are visually pleasing to a casual watcher of HD material and are strong upgrades over the equivalent dvd version.
Tier 3 - Bronze (Average)
The titles in this tier are representative of average picture quality considering all Blu-rays. Image quality characteristic of this tier will be superior to upscaled dvd but will lack any demo potential. Minor flaws or slight limitations in the source material may be present but these transfers are usually worth the upgrade over the dvd version. The picture will typically lack the depth and dimensionality exhibited in the higher tiers. Detail and clarity will be solid and present a pleasing image at standard viewing distances. In many cases the difference between this tier and the surrounding tiers is an issue of consistency to the picture quality.
Tier 4 - Copper (Below Average)
The titles in this tier typically represent below-average picture quality that is subpar for the Blu-ray format. While still visually better than upscaled standard definition material, the differences are less obvious upon casual inspection. The image may have deficiencies in one or more areas. The picture will look flat and lack the sharpness seen in higher tiers. Compression artifacts, softness, poor black levels, questionable source material, and poorly transferred masters are just some of the problems exhibited in tier four. Some Blu-rays in this tier are significant upgrades over the dvd but are constrained in image quality due to the limitations inherent in the source material or the director's intended look.
Tier 5 - Coal (Unacceptable)
The titles in this tier have severe limitations in their picture quality that is strongly underwhelming compared to the average Blu-ray. The image has deficiencies in multiple areas that would be obvious upon a casual viewing. Without question, the Blu-rays in tier five are among the worst looking selections available on the format. At various times, the picture quality is hard to distinguish from DVD content. Softness, artifacts, poor source material, limited resolution and clarity are general characteristics of titles in this tier.
Disclaimer:
Some of the Blu-rays ranked in the various tiers look as good as they possibly can on Blu-ray, given limitations in the original photography and the director's intended aesthetic. We recognize movies are not all created with the same intent and budget, and this is why certain titles can never achieve a tier zero or tier one ranking, even given a perfect transfer from the best possible source. Rankings as low as tier four can still constitute a worthy Blu-ray release, as long as the Blu-ray is visually transparent to the best available source for a particular title. This last point is beyond the scope of the tier system and should be investigated through other evaluations.
Phantom Stranger likes this.
SuprSlow is offline
post #2 of 35 Old 08-20-2012, 05:04 PM - Thread Starter
SuprSlow's Avatar
bb nf Big Hero 6 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Monsters University Video: AVC | Audio: 7.1 Dolby TrueHD | AR: 1.78:1 | Disney
bb nf Rio 2 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf The Smurfs 2 Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Toy Story 3 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Disney
bb nf Paddington Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf Madagascar 3: Europe's Most Wanted Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | DreamWorks
bb nf The Croods Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.35:1 | DreamWorks
bb nf Legend Of The Guardians: Owls Of Ga'Hoole Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf A Christmas Carol (2009) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Turbo Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.35:1 | DreamWorks
bb nf Black Sails: The Complete First Season Video: AVC | Audio: Dolby TrueHD 7.1 | AR: 1.78:1 | Starz / Anchor Bay
bb nf A Bug's Life Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Avatar Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Life Of Pi Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf The Adventures Of Tintin Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Paramount
bb nf The Thin Red Line Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Criterion
bb nf Avatar (Extended Collector's Edition) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf The Incredibles Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Cars 2 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Up Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Coraline Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Despicable Me 2 Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Finding Nemo Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | Disney
bb nf Astro Boy Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit Entertainment
bb nf Birdman Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Kung Fu Panda 2 Video: AVC | Audio: TrueHD 7.1 | AR: 2.35:1 | DreamWorks
bb nf Kung Fu Panda Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Frozen Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Disney
bb nf Get On Up Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Ratatouille Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Ice Age: Continental Drift Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Rio Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Planes Video: AVC | Audio: 7.1 DTS-HD MA | AR: 1.78:1 | Disney
bb nf Cars Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Tangled Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Disney | 2-D Version
bb nf Ninja II: Shadow of a Tear Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Millennium Media
bb nf Tai Chi Zero Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Well Go USA
bb nf Monsters, Inc. Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Toy Story 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Toy Story of Terror! Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf I, Robot Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Rise of the Guardians Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | DreamWorks
bb nf Meet the Robinsons Video: AVC | Audio: PCM | AR: 1.78:1 | Disney
bb nf Rango Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Hugo Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Paramount
bb nf Master, The (2012) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Weinstein
bb nf Tinker Bell And The Great Fairy Rescue Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Dr. Seuss' The Lorax (2012) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Despicable Me Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Hello, Dolly! Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox
bb nf Pirates of the Caribbean: Dead Man's Chest Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Rescue 3D Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment | IMAX
bb nf A Serious Man Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Escape From Planet Earth Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf Pirates of the Caribbean: At World's End Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Redline (2009) Video: AVC | Audio: TrueHD | AR: 1.78:1 | Starz / Anchor Bay
bb nf Chicken Little Video: AVC | Audio: PCM | AR: 1.78:1 | Disney
bb nf Samsara Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | MPI
bb nf Boss: Season One Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Lionsgate
bb nf Fantastic Mr. Fox Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Open Season Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Tree Of Life, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Fox
bb nf Puss In Boots Video: AVC | Audio: TrueHD 7.1 | AR: 2.35:1 | DreamWorks
bb nf The Wild Video: AVC | Audio: PCM | AR: 1.85:1 | Disney
bb nf Man on Fire Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Bee Movie Video: AVC | Audio: TrueHD | AR: 1.85:1 | Dreamworks
bb nf Penguins of Madagascar Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | DreamWorks
bb nf Tinker Bell Video: AVC | Audio: PCM | AR: 1.78:1 | Disney
bb nf Tinker Bell And The Lost Treasure Video: AVC | Audio: DTS-HD MA | AR: 1.78 | Disney
bb nf Arabia 3D (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment
bb nf Lone Survivor Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Monsters Vs. Aliens Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks
bb nf The Art Of Flight Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | Red Bull Media House
bb nf The Host Video: VC-1 | Audio: PCM | AR: 1.85:1 | Magnolia
bb nf Live Free or Die Hard Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Tell No One Video: VC-1 | Audio: PCM 2.0 | AR: 2.35:1 | MPI Media
bb nf Epic Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Exodus: Gods and Kings Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Sin City Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Wreck-It Ralph Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Company Men, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Starz / Anchor Bay
bb nf Mary And Max Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MPI Media
bb nf The Three Musketeers (2011) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit Entertainment
bb nf How to Train Your Dragon 2 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Fox
bb nf LEGO Batman: The Movie Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Youth Without Youth Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Secret World Of Arrietty, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Hot Fuzz Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Shrek Forever After Video: AVC | Audio: TrueHD 7.1 | AR: 2.35:1 | DreamWorks
bb nf The International Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf The Tale of Despereaux Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf TMNT Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Becoming Jane Video: VC-1 | Audio: PCM | AR: 2.35:1 | Disney
bb nf Pina (French Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | France Télévisions Dis. | Region B only?
bb nf Planet 51 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Red Cliff: The Special Edition (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Entertainment In Video | Parts I & II
bb nf Bait Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | Starz / Anchor Bay
bb nf Skyfall Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Alice In Wonderland (1951) Video: AVC | Audio: DTS-HD MA | AR: 1.33:1 | Disney
bb nf Book of Life, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Watchmen: Director's Cut (UK Import) Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Grand Canyon Adventure: River At Risk (IMAX 3-D Edition) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment
bb nf Transporter 2 (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf The Help Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Corpse Bride Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf Winnie The Pooh Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Wall-E Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Bolt Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Chronicles of Narnia: Prince Caspian Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Cloudy With A Chance Of Meatballs Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Hobbit, The: The Battle of the Five Armies Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Hotel Transylvania Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf In Time Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Alvin and the Chipmunks: The Squeakquel Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf The Ultimate Wave: Tahiti (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment
bb nf The Wind Rises Video: AVC | Audio: DTS-HD MA Mono | AR: 1.85:1 | Disney
bb nf Brave Video: AVC | Audio: Dolby TrueHD 7.1 | AR: 2.40:1 | Disney
bb nf Grand Canyon Adventure: River At Risk (IMAX) Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment
bb nf King Kong (2005) Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Noah Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Paramount
bb nf Planes: Fire and Rescue Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Wolf Creek 2 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Image Entertainment
bb nf Transporter 3 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Agora (French Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Warner | locked to Region B
bb nf Born To Be Wild (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Dragon Hunters Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Phase 4 Films
bb nf Gnomeo & Juliet Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Disney
bb nf Happy Feet Video: VC-1 | Audio: DD EX | AR: 2.40:1 | Warner
bb nf Toy Story Video: AVC | Audio: DTS-HD MA ES | AR: 1.78:1 | Disney
bb nf Baraka Video: VC-1 | Audio: DTS-HD MA | AR: 2.20:1 | MPI Media
bb nf A Woman, A Gun and A Noodle Shop Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Lonely Hearts (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Tokyo Motor Show Video: MPEG-2 | Audio: DD 2.0 | AR: 1.78:1 | Topics Entertainment | 1080i
bb nf How To Train Your Dragon Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Real Steel Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Disney
bb nf Wallace & Gromit: A Matter of Loaf and Death (UK Import) Video: AVC | Audio: TrueHD | AR: 1.78:1 | 2 Entertain | 1080i / 50Hz
bb nf 9 Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Domino (UK Import) Video: VC-1 | Audio: Dolby TrueHD 5.1 | AR: 2.40:1 | Warner | better PQ than domestic BD
bb nf Horton Hears A Who! Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Mars Needs Moms Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Transformers: Age of Extinction Video: AVC | Audio: Dolby Atmos | AR: 2.40:1 | Paramount
bb nf Braveheart Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf The LEGO Movie Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Arthur Christmas Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Crank 2: High Voltage Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Lionsgate
bb nf Lawrence of Arabia (4K Japanese Import) Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Sony | better than domestic BD
bb nf Lion King, The Video: avc | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Disney
bb nf Sword Of The Stranger Video: AVC | Audio: TrueHD | AR: 1.78:1 | Bandai
bb nf The Ides Of March Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Fighting Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Short Peace: Complete Collection Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sentai Filmworks
bb nf Sleeping Beauty Video: AVC | Audio: DTS-HD MA | AR: 2.55:1 | Disney
bb nf Batman: The Dark Knight Returns Part 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner | animated movie
bb nf Hobbit, The: An Unexpected Journey Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Warner
bb nf The Smurfs Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sony
bb nf Tinker Bell: Secret of the Wings Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Watchmen: Theatrical Version (UK Import) Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount
bb nf Gamer Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Lionsgate
bb nf I Spit On Your Grave (2010) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz / Anchor Bay
bb nf Lawrence of Arabia Video: AVC | Audio: DTS-HD MA | AR: 2:19:1 | Sony
bb nf Lucy Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Sabotage Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf The Nut Job Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Pirates of the Caribbean: The Curse of the Black Pearl Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Bayonetta: Bloody Fate Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Funimation
bb nf The Island Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Red Cliff: Part I Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Red Cliff: Part II Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Patton (remaster) Video: AVC | Audio: DTS-HD MA | AR: 2:19:1 | Fox | 2012 version with new transfer
bb nf Immortals Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Sex Drive Video: AVC | Audio: DD 5.1 | AR: 1.78:1 | Summit Entertainment
bb nf Domino Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Hop Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Rushmore Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Criterion
bb nf Spartacus: Blood And Sand - Season 1 Video: AVC | Audio: TrueHD | AR: 1.78:1 | Starz / Anchor Bay
bb nf Beauty And The Beast Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Disney
bb nf Transformers: Revenge Of The Fallen (IMAX) Video: AVC | Audio: DTS-HD MA | AR: mixed | Paramount
bb nf LEGO Justice League Vs. Bizarro League Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Gravity Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Transformers: Dark of the Moon Video: AVC | Audio: TrueHD 7.1 | AR: 2.40:1 | Paramount
bb nf Need for Speed Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf The Hobbit: The Desolation of Smaug Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Warner
bb nf Hobbit, The: An Unexpected Journey (Extended Edition) Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Warner
bb nf Interstellar Video: AVC | Audio: DTS-HD MA | AR: Various | Paramount
bb nf The Impossible Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit Entertainment
bb nf After Earth Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Great Gatsby, The (2013) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Host, The (2013) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Stand Up Guys Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf The Quiet Man Video: AVC | Audio: DTS-HD MA mono | AR: 1.37:1 | Olive Films
bb nf Frankenweenie Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Disney
bb nf Maleficent Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Ender's Game Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit
bb nf Batman: The Dark Knight Returns Part 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf TimeScapes Video: ? | Audio: ? | AR: ? | TimeScapes.org
bb nf House of Cards: Season One Video: AVC | Audio: DTS-HD MA | AR: 2.00:1 | Sony
bb nf The Sessions Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Begin Again Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Starz/Anchor Bay
bb nf The Agony and the Ecstasy Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox
bb nf Wolverine 3-D, The: Unleashed Extended Edition Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Fox
bb nf Archer: The Complete Season Four Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Need for Speed (UK) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Entertainment One | UK Region B release
bb nf Teenage Mutant Ninja Turtles (2014) Video: AVC | Audio: Dolby Atmos | AR: | Paramount
bb nf Still Mine Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Gone Girl Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Mickey's Twice Upon A Christmas Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney | double feature
bb nf The Wolf of Wall Street Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Admiral, The: Roaring Currents Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | CJ Entertainment
bb nf House of Cards: Season Two Video: AVC | Audio: DTS-HD MA | AR: 2.00:1 | Sony
bb nf Theory of Everything, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Lone Ranger, The (2013) Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Disney
bb nf Amazing Spider-Man 2, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf AnoHana: The Flower We Saw That Day: The Movie Video: AVC | Audio: | AR: 1.78:1 | ANIPLEX OF AMERICA
bb nf Imitation Game, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf Man of Tai Chi Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz/Anchor Bay
bb nf Equalizer, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Sony
bb nf Young Justice Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Warner Archive
bb nf Pawn Shop Chronicles Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Starz/Anchor Bay
mogrub and Phantom Stranger like this.
SuprSlow is offline
post #3 of 35 Old 08-20-2012, 05:25 PM - Thread Starter
SuprSlow's Avatar
bb nf 101 Dalmatians Video: AVC | Audio: DTS-HD MA | AR: | Disney | 1961 animated version
bb nf 2 Fast 2 Furious Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf All-Star Superman Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf Alvin and the Chipmunks Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf AnoHana: The Flower We Saw That Day (complete collection) Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | NIS America
bb nf Anonymous Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Apocalypto Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Arn: The Knight Templar Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | E ONE Entertainment | shorter theatrical version
bb nf Bambi Video: AVC | Audio: DTS-HD HR 7.1 | AR: 1.33:1 | Disney
bb nf Batman: The Brave and the Bold (The Complete Second Season) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Before Midnight Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Beowulf Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Beowulf (UK import) Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Beverly Hills Chihuahua Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Black Hawk Down Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Black Hawk Down (European Import) Video: AVC | Audio: PCM | AR: 2.40:1 | Sony | better PQ than domestic BD
bb nf Blind Side, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Blow Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line
bb nf Bored To Death: The Complete Third Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Bourne Legacy, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Universal
bb nf Boxtrolls, The Video: AVC | Audio: | AR: | Universal
bb nf Broken Embraces Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf C-Control: The Money and Soul of Possibility Video: AVC | Audio: | AR: | Funimation
bb nf Captain America: The Winter Soldier Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Captive, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Celeste and Jesse Forever Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Celine Dion: A New Day - Live In Las Vegas Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf CJ7 Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Cosmos: A Spacetime Odyssey Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Couples Retreat Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Deception Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Devil's Backbone, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Criterion
bb nf Devil's Rock, The (Canadian) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Entertainment One
bb nf Earth (Disney Nature) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Eastern Promises Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Excision Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf Fantastic Four: Rise of the Silver Surfer Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Fault in Our Stars, The Video: | Audio: | AR: | Fox
bb nf First Sunday Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Futurama: Bender's Game Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Futurama: Into The Wild Green Yonder Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Futurama: Volume 5 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Game Plan, The Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Garden of Words, The Video: AVC | Audio: DTS-HD MA | AR: | Sentai Filmworks
bb nf Gladiator (European Remaster) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount | better PQ than domestic BD
bb nf Gladiator (Remastered) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Gods And Generals Video: VC-1 | Audio: DD5.1 | AR: 2.40:1 | Warner
bb nf Green Lantern: First Flight Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Grindhouse: Planet Terror (Scratch-Free Version) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein
bb nf Guardians of the Galaxy Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Hannibal: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Happy Feet Two Video: | Audio: | AR: | Warner
bb nf Hellboy Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Hounddog Video: AVC | Audio: DD 5.1 | AR: 1.85:1 | Hannover House
bb nf How the West Was Won Video: VC-1 | Audio: TrueHD | AR: 2.89:1 | Warner
bb nf Ice Age: Dawn Of The Dinosaurs Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Fox
bb nf Jack the Giant Slayer Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf K: The Complete Series Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Viz Media
bb nf Kick-Ass 2 Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Kill Bill: Vol. 2 Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Kronk's New Groove Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Legends Of Flight (IMAX) Video: | Audio: | AR: |
bb nf Let's Be Cops Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Lost: The Complete Fifth Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Lost: The Complete Sixth Season Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Love Happens Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Madagascar: Escape 2 Africa Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks
bb nf Madea's Big Happy Family Video: | Audio: | AR: |
bb nf Man With The Iron Fists, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Marmaduke Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Megamind Video: AVC | Audio: TrueHD 7.1 | AR: 2.35:1 | DreamWorks | aliasing issues
bb nf Men In Black III Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Mesrine: Killer Instinct Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Music Box Films
bb nf Mesrine: Part 2: Public Enemy Number One Video: | Audio: | AR: |
bb nf Most Wanted Man, A Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Niagara Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Fox
bb nf Ninja Assassin Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf Notorious Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf OCULUS Video: | Audio: | AR: |
bb nf Our Family Wedding Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Oz the Great and Powerful Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf P.S. I Love You Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Pacific Rim Video: AVC | Audio: 7.1 DTS-HD MA | AR: 1.78:1 | Warner
bb nf Painted Skin II: The Resurrection Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Well Go USA
bb nf Pitch Perfect Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Prison Break: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Railway Man, The Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Ray Donovan: Season One Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Paramount
bb nf Reclaim Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Red Cliff (Hong Kong Import) Video: AVC | Audio: DTS-HD MA / TrueHD | AR: 2.35:1 | Mei Ah
bb nf Red Cliff II (Hong Kong Import) Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Mei Ah
bb nf Red State Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Rendition (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | EIV
bb nf Robbie Williams: Live At The Albert (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | EMI
bb nf Robocop (2014) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Rock Of Ages Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Saawariya Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Samurai Bride: Complete Collection Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sentai Filmworks
bb nf Samurai Girls Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Scanner Darkly, A Video: VC-1 | Audio: DD | AR: 1.85:1 | warner
bb nf Secret Life of Bees, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Shooter Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount
bb nf Silent Hill (French Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Metropolitan Video | 2-disc version
bb nf Sin City: A Dame To Kill For Video: AVC | Audio: | AR: | Starz/Anchor Bay
bb nf Snitch Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit
bb nf South Park: The Complete Fourteenth Season Video: AVC | Audio: TrueHD | AR: 1.85:1 | Paramount
bb nf Speed Racer Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Spider-Man 3 Video: AVC | Audio: PCM / TrueHD | AR: 2.35:1 | Sony
bb nf Spirit, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf St. Vincent Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Star Trek Into Darkness Video: AVC | Audio: 7.1 Dolby TrueHD | AR: 2.40:1 | Paramount
bb nf Stitches Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | MPI
bb nf Stoker Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Sunshine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Superman Vs. The Elite Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Superman: Unbound Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Total Recall (2012) 4K edition Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Transformers Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Transformers: Revenge Of The Fallen Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Paramount
bb nf Tron: Legacy Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Disney
bb nf Tropic Thunder Video: AVC | Audio: TrueHD | AR: 2.35:1 | Dreamworks
bb nf Trouble With Harry, The Video: AVC | Audio: DTS-HD MA | AR: | Universal
bb nf Tudors: Complete First Season (UK Import) Video: AVC | Audio: PCM | AR: 1.78:1 | Sony
bb nf Up In The Air Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf Waltz with Bashir Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Watchmen: Tales of the Black Freighter Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Watchmen: The Ultimate Cut Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Way of the Wicked Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf X-Men: Days of Future Past Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
SuprSlow is offline
post #4 of 35 Old 08-20-2012, 05:28 PM - Thread Starter
SuprSlow's Avatar
bb nf .hack//Quantum OVA Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf 21 Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf 3 Days To Kill Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf 300: Rise of an Empire Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Warner
bb nf A-Channel - The Animation Video: AVC | Audio: | AR: | Sentai Filmworks
bb nf About Time Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Alps, The: Climb Of Your Life (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf Amazing Spider-Man, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Amélie (Australian Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon Home Entertainment
bb nf American, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Annabelle Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Ant Bully, The Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf Asphyx, The Video: AVC | Audio: PCM 2.0 | AR: 2.35:1 | KINO / Redemption Films
bb nf Atlas Shrugged Part II: The Strike Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Avengers, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Disney
bb nf Batman: The Dark Knight Video: VC-1 | Audio: TrueHD | AR: 2.40/1.78:1 | Warner | Nolan
bb nf Batman: Year One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Battleship Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Bible, The: The Epic Miniseries Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Black Book Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Blood Lad: The Complete Series Video: AVC | Audio: | AR: | Viz Media
bb nf Book Thief, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Cat Planet Cuties: Complete Collection Video: AVC | Audio: TrueHD 5.1 | AR: 1.78:1 | Funimation
bb nf Chasing Mavericks Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Fox
bb nf Chronicles of Narnia: The Lion, the Witch and the Wardrobe Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Crank Video: MPEG-2 | Audio: PCM 6.1 | AR: 1.78:1 | Lionsgate
bb nf Dead Mine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | XLrator
bb nf Delhi Safari Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Arc Entertainment
bb nf Disappearance Of Alice Creed, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf Disappearance of Haruhi Suzumiya, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Bandai | If any of you are aliens, time-travelers or espers, please come see me
bb nf Django Unchained Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf Doomsday Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Duplicity Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal
bb nf Easy Virtue Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Emperor's New Groove, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Enchanted Video: AVC | Audio: TrueHD | AR: 2.35:1 | Disney
bb nf Exorcism of Emily Rose, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Extremely Loud And Incredibly Close Video: | Audio: | AR: | Warner
bb nf Eye, The Video: AVC | Audio: PCM | AR: 2.35:1 | Lionsgate
bb nf Fast and the Furious, The: Tokyo Drift Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Fast Five Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Fish Tank Video: AVC | Audio: DTS-HD MA | AR: 1.33:1 | Criterion
bb nf Friday Night Lights Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf From Up On Poppy Hill Video: AVC | Audio: DTS-HD MA 5.0 | AR: 1.85:1 | Cinedigm
bb nf Fury Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf G-Force Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Disney
bb nf G.I. Joe: The Rise Of Cobra Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Galapagos Video: VC-1 | Audio: DD | AR: 1.78:1 | BBC
bb nf Game Of Thrones: Season 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Girl With The Dragon Tattoo, The Video: AVC | Audio: DD 5.1 | AR: 2.35:1 | Music Box Films
bb nf Glory (4K) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Grand Budapest Hotel, The Video: AVC | Audio: DTS-HD MA | AR: Various | Fox
bb nf Ground Control to Psychoelectric Girl: Complete Series Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | NIS America
bb nf Haganai: Next Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Hell Ride Video: AVC | Audio: TrueHD | AR: 2.35:1 | Weinstein
bb nf Hellboy II: The Golden Army Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Hellraiser: Revelations Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Arc Entertainment
bb nf Hills Have Eyes 2, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox | 2007 sequel
bb nf Hitchcock Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Homeland: Season 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Ice Age: The Meltdown Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Identity Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Incredible Hulk, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Indiana Jones and the Kingdom of the Crystal Skull Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Inglourious Basterds Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Inkheart Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line
bb nf It's a Mad, Mad, Mad, Mad World Video: AVC | Audio: DTS-HD MA | AR: 2.74:1 | MGM
bb nf It's Complicated Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Jennifer's Body Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf John Wick Video: AVC | Audio: Dolby Atmos | AR: 2.40:1 | Lionsgate
bb nf Jungle Book, The (1967) Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.75:1 | Disney
bb nf Justice League: Doom Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Justice League: The Flashpoint Paradox Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Kill Bill: Vol. 1 Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Killer Joe Video: | Audio: | AR: | Lionsgate
bb nf Knowing Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit
bb nf Labor Day Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Lady And The Tramp Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.55:1 | Disney
bb nf Lady Gaga: The Monster Ball Tour Video: AVC | Audio: TrueHD | AR: 1.78:1 | Universal Music Group | 1080i
bb nf Last Airbender, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Leatherheads Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Life Before Her Eyes, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Lincoln Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Lord Of The Rings: Return Of The King, The (Extended Edition) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Lost: The Complete Third Season Video: AVC | Audio: PCM | AR: 1.78:1 | Disney
bb nf Lovely Bones, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Mama Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Man On A Ledge Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit Entertainment
bb nf Many Adventures of Winnie the Pooh, The Video: AVC | Audio: DTS-HD MA | AR: 1.66:1 | Disney
bb nf Maze Runner, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Mickey's Once Upon A Christmas Video: | Audio: | AR: | Disney | double feature
bb nf Mr. Nobody Video: AVC | Audio: | AR: | Magnolia
bb nf Muck Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Never Back Down Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit
bb nf Oblivion Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Universal
bb nf Odd Life of Timothy Green, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf One Chance (UK) Video: | Audio: | AR: | | Region B?
bb nf Orphanage, The Video: VC-1 | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | New Line
bb nf ParaNorman Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Passion of the Christ, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Patriot, The Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Penny Dreadful: The Complete First Season Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Paramount
bb nf Pinocchio Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.35:1 | Disney
bb nf Postal Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Vivendi Visual
bb nf Power: The Complete First Season Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Starz / Anchor Bay
bb nf Precious Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Prep & Landing: Totally Tinsel Collection Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Princess And The Frog, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Pushing Daisies: Season One Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner
bb nf Rambo Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate | Extended Cut
bb nf Reader, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein
bb nf Rescue Dawn Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Rocker, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Rocky Horror Picture Show, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1:66:1 | Fox
bb nf Saving Mr. Banks Video: | Audio: | AR: | Disney
bb nf Se7en Video: VC-1 | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Warner
bb nf Seabiscuit Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Secret Sunshine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Criterion
bb nf Seeking A Friend For The End Of The World Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Seraphim Falls (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon Home Entertainment
bb nf Shoot 'Em Up Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line
bb nf Signal, The Video: | Audio: | AR: |
bb nf Sin City (Canadian) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Alliance
bb nf Soloist, The Video: AVC | Audio: TrueHD | AR: 2.39:1 | DreamWorks
bb nf Sound Of Music, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.20:1 | Fox
bb nf Spice And Wolf: Season Two Video: AVC | Audio: TrueHD 5.1 | AR: 1.78:1 | Funimation
bb nf Spy Kids 4: All The Time In The World Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Stake Land Video: | Audio: | AR: | Dark Sky Films
bb nf Stalingrad Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Star Trek: The Next Generation: The Next Level Video: | Audio: | AR: | Paramount
bb nf Star Wars: Episode III - Revenge Of The Sith Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Star Wars: The Clone Wars Season 1 Video: VC-1 | Audio: DD 5.1 | AR: 2.35:1 | Warner
bb nf Step Up 3 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Disney
bb nf Stone Video: | Audio: | AR: | Sony
bb nf Street Kings Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Stuck In Love Video: AVC | Audio: TrueHD | AR: 1.78:1 | Millennium Media | O.A.R. is 2.35:1
bb nf Superman: Doomsday Video: VC-1 | Audio: DD5.1 | AR: 1.78:1 | Warner
bb nf Surf's Up Video: AVC | Audio: PCM / TrueHD | AR: 1.85:1 | Sony
bb nf Sympathy For Mr. Vengeance Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Palisades Tartan
bb nf That's My Boy Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf The Fall Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf The Professionals Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Tiger & Bunny: Volume 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Viz Media
bb nf Tigger Movie, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Titanic (1997) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf To Catch A Thief Video: AVC | Audio: Dolby TrueHD 2.0 | AR: 1.78:1 | Paramount
bb nf Triangle Video: AVC | Audio: TrueHD | AR: 2.35:1 | First Look Studios
bb nf Troy Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Under The Bed Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | XLrator
bb nf Underworld Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Uninvited, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | DreamWorks
bb nf Vertical Limit (UK Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Walk Among The Tombstones, A Video: AVC | Audio: | AR: |
bb nf Walk The Line Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Fox
bb nf Watchmen: Director's Cut Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Warner
bb nf Winnie the Pooh: Springtime With Roo Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Wonder Woman Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf World God Only Knows, The: Complete Season One Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf World God Only Knows, The: Complete Season Two Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Your Highness Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Zero Dark Thirty Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Zombieland Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
SuprSlow is offline
post #5 of 35 Old 08-20-2012, 05:44 PM - Thread Starter
SuprSlow's Avatar
bb nf 12 Years A Slave Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf 30 Days of Night Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf 300 Video: VC-1 | Audio: PCM / TrueHD | AR: 2.35:1 | Warner
bb nf 42 Video: | Audio: | AR: | Warner
bb nf 6 Degrees Of Hell Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Breaking Glass
bb nf A Passage To India Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony
bb nf Accel World: Set 2 Video: | Audio: | AR: | Viz Media
bb nf Adventures of Ichabod and Mr. Toad, The Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Disney | double feature
bb nf Alien Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Aliens In The Attic Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Alvin And The Chipmunks: Chip-Wrecked Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf America Mary Video: | Audio: | AR: | XLrator
bb nf And Soon The Darkness Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf Angel Beats! Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Arachnophobia Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Armageddon Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Armored Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Babylon A.D. Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Bank Job, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Batman vs. Robin Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner | animated
bb nf Batman: The Brave and the Bold - Season One Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Warner
bb nf Batman: The Complete Television Series (1966-1968) Video: AVC | Audio: DD mono | AR: 1.37:1 | Warner / Fox
bb nf Before I go to Sleep Video: | Audio: | AR: |
bb nf Ben-Hur Video: AVC | Audio: DTS-HD MA | AR: 2.76:1 | Warner
bb nf Best Of Soundstage, The Video: VC-1 | Audio: PCM | AR: 1.85:1 | WTTW National Prod.
bb nf Beware the Batman: Season One Part One Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Warner Archive
bb nf Bikini Destination: Triple Fantasy Video: MPEG-2 | Audio: DD / DTS | AR: 1.78:1 | Magnolia
bb nf Black Rock Video: AVC | Audio: DTS-HD MA | AR: | Lionsgate
bb nf Black Snake Moan Video: AVC | Audio: DD | AR: 2.35:1 | Paramount
bb nf Blade II Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Warner
bb nf Blue Ruin Video: AVC | Audio: | AR: | Starz/Anchor Bay
bb nf Boardwalk Empire: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Book Of Eli, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Warner
bb nf Book Of Eli, The (Germany) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Bounty Killer Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Arc Entetainment
bb nf Bourne Ultimatum, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Butterfly On A Wheel (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon Home Entertainment
bb nf Casino Royale Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Chaos; Head: The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Chitty Chitty Bang Bang Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Fox
bb nf Chloe Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Chronicles Of Riddick, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Company You Keep, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Conan The Barbarian (2011) Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Conjuring, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Da Vinci's Demons: The Complete Second Season Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Dark Skies Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Starz / Anchor Bay
bb nf Dawn of the Planet of the Apes (2014) Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Death At A Funeral Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Death Note Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Viz Media | part of the Death Note Collection
bb nf Descendants, The Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Dexter: The Complete First Season Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Dexter: The Complete Second Season Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Diary of a Wimpy Kid: Dog Days Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Doctor Who: Season 5 Video: VC-1 | Audio: DTS-HD HR | AR: 1.78:1 | Warner
bb nf Dorian Gray Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | National Entertainment
bb nf Doubt Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Draft Day Video: | Audio: | AR: | Lionsgate
bb nf DreamWorks' Spooky Stories Video: AVC | Audio: TrueHD 7.1 | AR: 1.78:1 | DreamWorks
bb nf Drive Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Drive Angry Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Summit Entertainment
bb nf Eagle Eye Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Edge of Tomorrow Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Warner
bb nf Ef: A Tale Of Memories Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Elegy (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | EiV | 1080i, suffers from PAL speed-up
bb nf Elysium Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Sony
bb nf Embrace of the Vampire (2013) Video: AVC | Audio: TrueHD | AR: 1.78:1 | Starz / Anchor Bay
bb nf Everything Must Go Video: | Audio: | AR: | Lionsgate
bb nf Faces In The Crowd Video: | Audio: | AR: | Millenium Media
bb nf Fast & Furious 6 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Faster Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 |
bb nf Fifth Element, The (Remastered) Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Final Fantasy: The Spirits Within Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Flight Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Flowers of Evil: The Complete Collection Video: AVC | Audio: | AR: 1.78:1 | Sentai Filmworks
bb nf Flowers Of War, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Flyboys Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Forbidden Kingdom, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Fright Night 2: New Blood Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Furry Vengeance Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Summit Entertainment
bb nf G.I. Joe: Retaliation Video: AVC | Audio: TrueHD 7.1 | AR: 2.40:1 | Paramount
bb nf Gangster Squad Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Ghost in the Shell 2: Innocence Video: AVC | Audio: DD 5.1 | AR: 1.85:1 | Bandai Visual
bb nf Ghost Town Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks
bb nf God's Not Dead Video: | Audio: | AR: | Pure Flix
bb nf Gone Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit Entertainment
bb nf Green Lantern: Emerald Knights Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf Guge: The Lost Kingdom Of Tibet Video: MPEG-2 | Audio: DD 5.1 | AR: 1.85:1 | Razor Digital
bb nf Hachi: A Dog's Tale Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Haganai: I Don't Have Many Friends Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf HAL The Movie Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Funimation
bb nf Hancock Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Happily N'Ever After Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Hard Candy Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Harry Potter and the Order of the Phoenix Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Herbert von Karajan: Memorial Concert Video: AVC | Audio: PCM | AR: 1.78:1 | Medici Arts
bb nf Home Run Video: AVC | Audio: TrueHD | AR: 1.78:1 | Millennium Media
bb nf Human Centipede (First Sequence), The Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | IFC
bb nf Hunger Games, The: Catching Fire Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Hunter, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Identity Thief Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Indiana Jones And The Last Crusade Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Into the Woods Video: | Audio: | AR: | Disney
bb nf Island, The (UK Import) Video: VC-1 | Audio: DD 5.1 | AR: 2.40:1 | Warner
bb nf It's A Very Merry Muppet Christmas Movie Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf J. Edgar Video: | Audio: | AR: | Warner
bb nf Jackie Brown Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf James Bond: Licence To Kill Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM
bb nf Jeff, Who Lives At Home Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Paramount
bb nf John Legend: Live at the House of Blues Video: MPEG-2 | Audio: PCM | AR: 1.78:1 | Sony Music
bb nf Julie & Julia Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Jumper Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Justice League: Crisis On Two Earths Video: VC-1 | Audio: DD 5.1 | AR: 1.78:1 | Warner
bb nf Justice League: Season Two Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf Justice League: The New Frontier Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner
bb nf Justice League: War Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf King of Thorn Video: AVC | Audio: TrueHD | AR: 1.85:1 | Funimation
bb nf Lawless Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf LCD Soundsystem: Shut Up and Play the Hits Video: | Audio: | AR: | Oscilloscope Pictures
bb nf Legends of Jazz: Showcase Video: MPEG-2 | Audio: TrueHD | AR: 1.78:1 | LRS
bb nf Lethal Weapon 4 Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Warner | Part of the Lethal Weapon Collection box set
bb nf Life During Wartime Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Criterion
bb nf Lincoln Lawyer, The Video: | Audio: | AR: | Lionsgate
bb nf Listen To Me, Girls. I Am Your Father!: Complete Collection Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sentai Filmworks
bb nf Little Fockers Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Lord Of The Rings: Fellowship Of The Ring, The (Extended Edition) Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.40:1 | Warner
bb nf Lost: The Complete First Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Lost: The Complete Fourth Season Video: AVC | Audio: PCM | AR: 1.78:1 | Disney
bb nf Lost: The Complete Second Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf Love And Other Drugs Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Love, Election and Chocolate: Complete Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf Machinist, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Madagascar Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks
bb nf Mariah Carey: Adventures Of Mimi Video: AVC | Audio: PCM | AR: 1.78:1 | Image
bb nf Messengers, The Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Mirrormask Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Mongol: The Rise of Genghis Khan Video: VC-1 | Audio: DD | AR: 2.39:1 | New Line
bb nf Monuments Men, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Moody Blues, The: Lovely to See You Live Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf Mortal Kombat Legacy Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf Mr. Brooks Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Mr. Magoo's Christmas Carol Video: AVC | Audio: TrueHD 5.1 | AR: 1.33:1 | Classic Media
bb nf Muppets, The (2011) Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.78:1 | Disney
bb nf My Bloody Valentine (2009) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Nanny McPhee Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Necessary Evil: Super-Villains of DC Comics Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Nightcrawler Video: | Audio: | AR: | Universal
bb nf Nightmare Before Christmas, The Video: AVC | Audio: TrueHD 7.1 | AR: 1.66:1 | Disney
bb nf No Country for Old Men Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf November Man, The Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Oliver & Company Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Other Boleyn Girl, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Pacific, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Pain & Gain Video: AVC | Audio: TrueHD 7.1 | AR: 2.40:1 | Paramount
bb nf Pan's Labyrinth (UK import) Video: VC-1 | Audio: DD 5.1 | AR: 1.85:1 | Optimum
bb nf Parade's End Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Paranoia Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Parkland Video: AVC | Audio: TrueHD | AR: 1.78:1 | Millennium Media
bb nf Passengers Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Polar Express, The Video: VC-1 | Audio: DD5.1 | AR: 2.35:1 | Warner
bb nf Ponyo Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Possession of Michael King, The Video: | Audio: | AR: | Starz/Anchor Bay
bb nf Possession, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Prestige, The Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Prometheus Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Proposition, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | First Look Studios
bb nf Puella Magi Madoka Magica: Complete Series Collection (UK Import) Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | Manga Entertainment | locked to Region B
bb nf Queen's Blade 2: The Evil Eye Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Anime Works
bb nf R.I.P.D. Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Rabbit Hole Video: | Audio: | AR: |
bb nf Red 2 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit
bb nf Red Dawn (2012) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Redbelt Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony
bb nf Remember the Titans Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Resident Evil: Degeneration Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Resident, The Video: | Audio: | AR: |
bb nf Return To Nuke 'Em High Volume 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Starz/Anchor Bay
bb nf Revanche Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Criterion
bb nf Revolutionary Road Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Revolver Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Riddick Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Rise Of The Planet Of The Apes Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Robin Hood (2010) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Robot Chicken: DC Comics Special Video: | Audio: | AR: | Warner
bb nf Rosewood Lane Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Rushlights Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Vertical Entertainment
bb nf Safe Haven Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Santa Clause 3: The Escape Clause Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Savages Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Schindler's List Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Seal: Soundstage Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | WTTW National Prod.
bb nf Seven Years in Tibet Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Shrek the Third Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks
bb nf Shutter Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Simpsons Movie, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Sisterhood of the Traveling Pants 2, The Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Smokin' Aces Video: | Audio: | AR: | Universal
bb nf Source Code Video: | Audio: | AR: | Summit Entertainment
bb nf Star Driver: Part 1 Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | Bandai
bb nf Star Driver: Part 2 Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | Bandai
bb nf Star Trek (2009) Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount
bb nf Street Kings 2: Motor City Video: | Audio: | AR: |
bb nf Strike Back: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Sunshine Cleaning Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Superman / Batman: Apocalypse Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Superman / Batman: Public Enemies Video: VC-1 | Audio: DD5.1 | AR: 1.78:1 | Warner
bb nf Sweeney Todd: The Demon Barber Of Fleet Street Video: AVC | Audio: TrueHD | AR: 1.85:1 | DreamWorks
bb nf Sweeney Todd: The Demon Barber Of Fleet Street (UK Import) Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Swimmer, The Video: AVC | Audio: | AR: | Grindhouse Releasing
bb nf Take Shelter Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Taken 2 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Taking Of Pelham 1 2 3, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Thin Red Line, The (UK import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox | different encode than domestic version
bb nf Thor: The Dark World Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Too Big To Fail Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Total Recall (2012) Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Tower Heist Video: | Audio: | AR: | Universal
bb nf Town, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf True Grit (2010) Video: | Audio: | AR: |
bb nf Twilight Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit
bb nf Twilight Saga, The: Breaking Dawn: Part 1 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit Entertainment
bb nf Unborn, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Unbroken Video: AVC | Audio: DTS-HD MA | AR: | Universal
bb nf Valkyrie Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Vantage Point Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Veep: The Complete First Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Veronica Mars Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf W. Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Wallace & Gromit: The Complete Collection Video: AVC | Audio: PCM | AR: 1.33:1 | Lionsgate
bb nf War Horse Video: | Audio: | AR: | Disney
bb nf Warrior's Way, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Water Horse, The: Legend of the Deep Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf We're The Millers Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf White House Down Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf White Ribbon, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf White Wedding Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image Entertainment
bb nf Wild Hogs Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Winter's Tale Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Wrath of the Titans Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Yes Man Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Zodiac Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
SuprSlow is offline
post #6 of 35 Old 08-20-2012, 06:56 PM - Thread Starter
SuprSlow's Avatar
bb nf 12 Rounds Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf 2001: A Space Odyssey Video: VC-1 | Audio: PCM | AR: 2.20:1 | Warner
bb nf 2012 Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf 30 Days Of Night: Dark Days Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf 47 Ronin Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Accel World: Set 1 Video: | Audio: | AR: | Viz Media
bb nf Act Of Valor Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Adventures of Baron Munchausen, The Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Aeon Flux Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount
bb nf African Cats Video: | Audio: | AR: | Disney
bb nf Akira Video: AVC | Audio: TrueHD | AR: 1.85:1 | Honneamise
bb nf Akira Video: AVC | Audio: | AR: | Funimation | differs from Bandai release
bb nf Alexander Revisited Video: VC-1 | Audio: DD 5.1 | AR: 2.40:1 | Warner
bb nf All Is Lost Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Amagami SS: Complete Collection Video: AVC | Audio: | AR: 1.78:1 | Sentai Filmworks
bb nf Amélie Video: | Audio: | AR: | Lionsgate
bb nf American Hustle Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf American Reunion Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Anchorman 2: The Legend Continues Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Angels & Demons Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Sony
bb nf Antarctica: An Adventure of a Different Nature (IMAX) Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Razor Digital
bb nf Atonement Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Australia Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Awake Video: AVC | Audio: TrueHD | AR: 2.35:1 | Weinstein
bb nf Babe Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Bad Words Video: | Audio: | AR: 2.40:1 | Universal
bb nf Barry Manilow: Manilow Live! Video: AVC | Audio: DTS-HD MA 5.0 | AR: 1.78:1 | Image | 1080i
bb nf Batman Begins Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Batman Beyond: Return Of The Joker Video: AVC | Audio: DTS-HD MA | AR: 1.33:1 | Warner
bb nf Batman: The Dark Knight Rises Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 - 2.4 | Warner
bb nf Batman: Under The Red Hood Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf Battle For Terra Video: AVC | Audio: PCM | AR: 2.35:1 | Lionsgate
bb nf Battle of The Bulge Video: VC-1 | Audio: DD | AR: 2.76:1 | Warner
bb nf Black Narcissus Video: AVC | Audio: PCM mono | AR: 1.37:1 | Criterion
bb nf Blazing Saddles: 40th Anniversary edition Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Blood-C: Complete Series Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf Boogie Nights Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Born To Raise Hell Video: | Audio: | AR: |
bb nf Brave One, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Breaking Bad: Season Two Video: | Audio: | AR: |
bb nf Broken Trail Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Brooklyn's Finest Video: AVC | Audio: PCM | AR: 2.40:1 | Starz / Anchor Bay
bb nf Brothers Bloom, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit Entertainment
bb nf Bruce Almighty (UK import) Video: AVC | Audio: PCM | AR: 1.85:1 | Disney
bb nf Burn After Reading Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Casino Jack Video: | Audio: | AR: | Fox
bb nf Catch .44 Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Catch Me If You Can Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf Cave, The (Japan Import) Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf CBGB Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | XLrator
bb nf Changeling Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Cinderella Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.33:1 | Disney
bb nf Clannad: Complete Collection Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sentai Filmworks
bb nf Closer Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Code, The Video: AVC | Audio: TrueHD | AR: 2.39:1 | First Look Studios
bb nf Collection, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Company, The Video: AVC | Audio: PCM | AR: 1.78:1 | Sony
bb nf Coral Reef Adventure (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf Curious Case of Benjamin Button, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Criterion
bb nf Curse of the Golden Flower Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Dallas Buyers Club Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Day of Anger Video: AVC | Audio: | AR: | Arrow Video
bb nf Death Race Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Death Race 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Defiance Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Deja Vu Video: VC-1 | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Dirty Harry Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Disappearance of Eleanor Rigby, The Video: AVC | Audio: | AR: | Weinstein Company
bb nf Disgrace Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Image Entertainment
bb nf District 9 Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Double, The Video: | Audio: | AR: | Image Entertainment
bb nf Drag Me To Hell Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Universal
bb nf Drillbit Taylor Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Drive (UK import) Video: | Audio: | AR: | Icon | 1080i / 50 Hz
bb nf Duchess, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Dusk Maiden of Amnesia: Complete Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf E.T. the Extra-Terrestrial Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Universal
bb nf Easy A Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Echoes Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Ef: A Tale Of Melodies Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks | Can you hear the melody of truth?
bb nf Elfie Hopkins (UK) Video: | Audio: | AR: | Kaleidoscope Entertainmen | Region B locked?
bb nf Ella Enchanted (Canadian import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Alliance
bb nf Elton 60 - Live at Madison Square Garden Video: AVC | Audio: PCM | AR: 1.78:1 | Universal Music
bb nf Emperor Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Everything Must Go Video: | Audio: | AR: | Roadside Attractions
bb nf Express, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Family Guy: Something, Something, Something Dark Side Video: AVC | Audio: DTS-HD MA | AR: 1.33:1 | Fox
bb nf Family, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Fast & Furious (2009) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Fast And The Furious, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal
bb nf Fight Club Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox | Tyler Durden was here
bb nf Fired Up Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Five-Year Engagement, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Flame And Citron (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.25:1 | Metrodome Video
bb nf Fool's Gold Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Fourth Kind, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Friends With Kids Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Fringe: The Complete First Season Video: VC-1 | Audio: DD5.1 | AR: 1.78:1 | Warner
bb nf From Russia with Love Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Frost/Nixon Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Frosty The Snowman Video: AVC | Audio: TrueHD | AR: 1.37:1 | Vivendi Visual
bb nf Game Of Death (2010) Video: | Audio: | AR: |
bb nf Get The Gringo Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Ghost Rider Video: AVC | Audio: PCM / TrueHD | AR: 2.40:1 | Sony
bb nf Ghost Writer, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit Entertainment
bb nf Girl Who Played With Fire, The Video: | Audio: | AR: |
bb nf Giver, The Video: | Audio: | AR: |
bb nf Godzilla (2014) Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Warner
bb nf Grace Unplugged Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Halo 4: Forward Unto Dawn Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Microsoft Films
bb nf Halt and Catch Fire: The Complete Season One Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Hangover, The: Part II Video: | Audio: | AR: | Warner
bb nf Hansel & Gretel: Witch Hunters Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Harry Potter and the Prisoner of Azkaban Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Haunting In Connecticut, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Lionsgate
bb nf Hemingway & Gellhorn Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Henry Poole is Here Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz
bb nf High School Of The Dead Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf History Of The World Part I Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Home of the Brave Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Hot Tub Time Machine Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf House of 1,000 Corpses Video: VC-1 | Audio: DTS-HD HR 7.1 | AR: 1.85:1 | Lionsgate
bb nf Hulk Vs. Thor / Hulk Vs. Wolverine Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Hunger Games, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Hunger Games, The: Mockingjay Part 1 Video: AVC | Audio: | AR: | Lionsgate
bb nf Hunt To Kill Video: | Audio: | AR: |
bb nf I Am Legend Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf I Am Legend (Ultimate Collector's Edition) Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf I Love You Phillip Morris Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 |
bb nf I Love You, Man Video: AVC | Audio: TrueHD | AR: 1.78:1 | DreamWorks
bb nf I, Frankenstein Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf In The Loop Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | IFC Films
bb nf In The Name of the King: A Dungeon Siege Tale Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Insomnia Video: | Audio: | AR: | Warner
bb nf Into the Wild Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Invictus Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Warner
bb nf Iron Man Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Ironclad: Battle For Blood Video: | Audio: | AR: |
bb nf Jack Reacher Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Paramount
bb nf Jack Ryan: Shadow Recruit Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Paramount
bb nf JFK Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf John Adams Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Journey 2: The Mysterious Island Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Joy Ride 3: Road Kill Video: | Audio: | AR: | Fox
bb nf Just Go With It Video: | Audio: | AR: |
bb nf Justice League: Season One Video: VC-1 | Audio: DD | AR: 1.33:1 | Warner
bb nf Kamisama Kiss: The Complete Series Video: AVC | Audio: | AR: 1.78:1 | Funimation
bb nf Karate Kid, The (2010) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Kick-Ass Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Kick-Ass (UK import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Kingdom of Heaven Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Kingdom, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Knight And Day Video: | Audio: | AR: |
bb nf Last Exorcism Part II, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Late Quartet, A Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Law Abiding Citizen Video: AVC | Audio: TrueHD | AR: 2.39:1 | Starz / Anchor Bay
bb nf League of Extraordinary Gentlemen, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Leave Her To Heaven Video: AVC | Audio: DTS-HD MA mono | AR: 1.37:1 | Twilight Time
bb nf Ledge, The Video: | Audio: | AR: |
bb nf LEGO Star Wars: The Padawan Menace Video: | Audio: | AR: | Fox
bb nf Lethal Weapon 3 (remastered) Video: VC-1 | Audio: DTS-HD MA | AR: | Warner | Part of the Lethal Weapon Collection box set
bb nf Letters To Juliet Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Summit Entertainment
bb nf Lives of Others, The Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Looper Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Lucky Number Slevin Video: AVC | Audio: TrueHD | AR: 2.40:1 | Weinstein
bb nf MacGruber Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Machete Video: | Audio: | AR: |
bb nf Mad Men: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Made Of Honor Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Magnolia Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Magnum Force Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Marley Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia
bb nf Marley & Me Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Matrix Revolutions, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf McLintock!: Authentic Collector's Edition Video: AVC | Audio: TrueHD Mono | AR: 2.40:1 | Paramount
bb nf Medaka Box Abnormal Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf Medium Cool Video: | Audio: | AR: | Criterion
bb nf Minority Report Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Paramount
bb nf Mission: Impossible III Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount
bb nf MM! Complete Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Mummy, The: Tomb of the Dragon Emperor Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Mystic River Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf National Treasure Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf National Treasure 2: Book of Secrets Video: AVC | Audio: TrueHD | AR: 2.35:1 | Disney
bb nf Natural Born Killers (director's cut) Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner | unrated
bb nf Needless: Collection 1 Video: VC-1 | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf New World, The Video: VC-1 | Audio: DTS-HD MA | AR: | Warner
bb nf Next Avengers: Heroes of Tomorrow Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Next Three Days, The Video: | Audio: | AR: |
bb nf Night At The Museum: Battle Of The Smithsonian Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Nixon Video: | Audio: | AR: | Disney
bb nf Non-Stop Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf North Face (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Metrodome Video
bb nf Now You See Me Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Summit
bb nf Nowhere Boy Video: | Audio: | AR: |
bb nf Old Dogs Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Our Idiot Brother Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Outlander Season One Volume One Video: AVC | Audio: | AR: | Sony
bb nf Pan's Labyrinth Video: VC-1 | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | New Line | DNR
bb nf Paul Video: | Audio: | AR: |
bb nf Paul Blart: Mall Cop Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Pearl Harbor Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Penguindrum: Collection 1 Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf Percy Jackson & The Olympians: The Lightning Thief Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Persepolis Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Peter Pan (Korean Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Pirates! Band Of Misfits, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Place Beyond The Pines, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Pompeii Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Preacher's Kid Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Predators Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Predestination Video: | Audio: | AR: | Sony
bb nf Priest Video: | Audio: | AR: | Sony
bb nf Prince Of Persia: The Sands Of Time Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Disney
bb nf Prisoners Video: AVC | Audio: DTS-HD MA | AR: | Warner
bb nf Produced By George Martin Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | Eagle Rock
bb nf Push Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Summit
bb nf Quantum of Solace Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Rage Video: | Audio: | AR: | Image Entertainment
bb nf Reaping, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Recruit, The (UK Import) Video: VC-1 | Audio: PCM | AR: 2.35:1 | Disney
bb nf Rescuers, The Video: AVC | Audio: DTS-HD MA | AR: 1.67:1 | Disney
bb nf Resident Evil: Extinction Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Robot Chicken: Season Five Video: VC-1 | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Cartoon Network | 1080i
bb nf Robotics; Notes: Part 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Rock, The Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Rover, The Video: | Audio: | AR: | Lionsgate
bb nf Royal Tenenbaums, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Criterion
bb nf Runner, Runner Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Rush Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Rush Hour Video: VC-1 | Audio: DTS-HD MA | AR: | Warner
bb nf Rush Hour 3 Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | New Line
bb nf Safe House Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Salt Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Sand Pebbles, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Secret Life of Walter Mitty, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Semi-Pro Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | New Line
bb nf Seven Pounds Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Shine A Light: The Rolling Stones Video: AVC | Audio: DTS-HD MA / TrueHD | AR: 1.78:1 | Paramount
bb nf Shutter Island Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Side Effects Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Silent Hill: Revelation Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Silver Linings Playbook Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Weinstein
bb nf Sin Nombre (UK import) Video: | Audio: | AR: | | Region B only
bb nf Smart People Video: AVC | Audio: PCM | AR: 2.39:1 | Disney
bb nf Snow White And The Huntsman Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Universal
bb nf Son of Batman Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Son Of No One, The Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Sopranos, The: Season 6, Part 2 Video: VC-1 | Audio: PCM | AR: 1.78:1 | Warner
bb nf Soul Eater: The Meister Collection Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf Soul Eater: The Weapon Collection Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf Soul Surfer Video: | Audio: | AR: |
bb nf South Pacific Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox
bb nf Spiderwick Chronicles, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Spread Video: AVC | Audio: TrueHD 7.1 | AR: 2.40:1 | Starz / Anchor Bay
bb nf Star Trek: The Original Series: Season One Video: VC-1 | Audio: DTS-HD MA 7.1 | AR: 1.33:1 | Paramount
bb nf Star Wars: The Clone Wars Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner | pilot movie for the series
bb nf State Of Play Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Stomp the Yard Video: AVC | Audio: PCM / TrueHD | AR: 2.40:1 | Sony
bb nf Straw Dogs (2011) Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Sugar Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Super Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | IFC
bb nf Superman: Brainiac Attacks Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Sweet Smell of Success (UK Import) Video: AVC | Audio: | AR: | Arrow Video | same master as Criterion
bb nf Synecdoche New York Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Taken Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Tanner Hall Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Tears of the Sun Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Tekkonkinkreet Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Terminator: Salvation Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf The Proposal Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Disney
bb nf Thompsons, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | XLrator
bb nf Thor Video: AVC | Audio: | AR: | Paramount
bb nf Three Stooges, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Time Traveler's Wife, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Tooth Fairy Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Town, The: Ultimate Collector's Edition Video: | Audio: | AR: | Warner
bb nf Transformers: The Movie (1986) (UK) Video: AVC | Audio: | AR: | Metrodome Video | region-free OOP UK
bb nf Tudors, The: Season 2 Uncut (CA Import) Video: AVC | Audio: DD5.1 | AR: 1.78:1 | Peace Arch Trinity
bb nf Twenty Feet From Stardom Video: AVC | Audio: Dolby TrueHD 5.1 | AR: 1.78:1 | Starz/Anchor Bay
bb nf Twilight Saga: New Moon Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit Entertainment
bb nf U-571 Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf UFC: Ultimate Comebacks Video: VC-1 | Audio: DD | AR: 1.78:1 | First Look Studios | 1080i
bb nf Underworld: Awakening Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Sony
bb nf Unstoppable Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Untraceable Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Van Helsing Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Vehicle 19 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Arc Entertainment
bb nf Vow, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Wanted Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Watch, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf White Christmas Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Paramount
bb nf Words, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf World's End, The Video: AVC | Audio: DTS-HD MA | AR: | Universal
bb nf X-Files, The: I Want To Believe Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf X-Men: First Class Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf You Again Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Young Victoria, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Youth In Revolt Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Zodiac (UK Import) Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner | represents all international Warner releases of the movie
SuprSlow is offline
post #7 of 35 Old 08-20-2012, 07:00 PM - Thread Starter
SuprSlow's Avatar
bb nf 30 Days of Night (Australian Import) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Icon
bb nf 30 Nights of Paranormal Activity with the Devil Inside the Girl With the Dragon Video: | Audio: | AR: | Fox
bb nf 300 Spartans, The Video: AVC | Audio: DTS-HD MA mono | AR: 2.35:1 | Fox
bb nf 50 / 50 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Summit Entertainment
bb nf A Time to Kill Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf A-Team, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Across the Universe Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Adjustment Bureau, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Aftershock (2012) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Starz / Anchor Bay
bb nf Air I Breathe, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image
bb nf Alex Cross Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit Entertainment
bb nf Aliens Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Animatrix Video: VC-1 | Audio: TrueHD | AR: | Warner | part of the Ultimate Matrix collection
bb nf Appleseed: Ex Machina Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner
bb nf Argo Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Aviator, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Baby Mama Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Bad Ass Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Bad Lieutenant: Port Of Call New Orleans Video: AVC | Audio: TrueHD | AR: 1.85:1 | First Look Studios
bb nf Batman: Assault On Arkham Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Batman: The Movie (1966) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Battle: Los Angeles (4K) Video: | Audio: | AR: | Sony
bb nf Bedtime Stories Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Before the Devil Knows You're Dead Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Image
bb nf Berserk: The Golden Age Arc I - The Egg of the King Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Blade Runner: The Final Cut Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner | part of the 5-Disc Complete Collector's edition
bb nf Blood & Chocolate Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Bourne Supremacy Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Breakfast At Tiffany's Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Paramount
bb nf Brothers Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Children of Men Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Chinatown Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Constantine Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf Corruption Video: AVC | Audio: DTS-HD MA mono | AR: 1.85:1 | Grindhouse Releasing
bb nf Courageous Video: | Audio: | AR: | Sony
bb nf Darkest Hour, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit Entertainment
bb nf Dave Matthews and Tim Reynolds: Live at Radio City Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony BMG
bb nf Day the Earth Stood Still, The (2008) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Dear John Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Deep Blue Sea Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Demon King Daimao Video: AVC | Audio: TrueHD 2.0 | AR: 1.78:1 | Sentai Filmworks
bb nf Descent, The Video: AVC | Audio: PCM | AR: 2.35:1 | Lionsgate | different video encodes exist for the domestic BD
bb nf Devil's Double, The (UK Import) Video: | Audio: | AR: | Icon | different encode than domestic version
bb nf Diary Of A Wimpy Kid: Rodrick Rules Video: | Audio: | AR: |
bb nf Die Another Day Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Die Hard with a Vengeance Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Dinner For Schmucks Video: | Audio: | AR: |
bb nf Discovery Atlas: Australia Video: AVC | Audio: DD | AR: 1.78:1 | Discovery
bb nf District 13: Ultimatum Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf DOA: Dead Or Alive Video: AVC | Audio: | AR: | Weinstein
bb nf DOA: Dead or Alive (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Alliance
bb nf Dogma Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Dolphin Tale Video: | Audio: | AR: | Warner
bb nf Donnie Brasco Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Dragon Ball Z: Broly / Broly: Second Coming Video: AVC | Audio: DTS | AR: 1.78:1 | FUNimation
bb nf Dragon Tiger Gate Video: AVC | Audio: PCM | AR: 2.35:1 | Tai Seng
bb nf Due Date Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Edge of Love, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Image
bb nf Enemy at the Gates Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Erased Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Eternal Sunshine Of The Spotless Mind Video: | Audio: | AR: |
bb nf Event Horizon Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Evil Dead (2013) Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Sony
bb nf Exam (UK Import) Video: | Audio: | AR: | Sony | 1080i / 50 Hz
bb nf Final Destination 5 In 3-D Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Warner
bb nf Five Element Ninjas Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Tokyo Shock
bb nf Forrest Gump Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Fright Night (2011) Video: | Audio: | AR: | Disney
bb nf Funny Games (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Tartan
bb nf Gambit Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Game, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Criterion
bb nf Get Him To The Greek Video: AVC | Audio: DTS-HD MA | AR: | Universal
bb nf Girl Who Leapt Through Time, The (UK) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Manga Entertainment | locked to Region B
bb nf Girl With The Dragon Tattoo, The (2011) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony | Fincher's version
bb nf Godfather: Part III, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Good Day To Die Hard, A Video: | Audio: | AR: | Fox
bb nf Good Luck Chuck: Unrated Video: AVC | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate
bb nf Good People Video: | Audio: | AR: |
bb nf Goon Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia
bb nf Grease Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount
bb nf Green Hornet, The Video: | Audio: | AR: | Sony
bb nf Green Lantern Video: AVC | Audio: | AR: | Warner
bb nf Gridiron Gang Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Gulliver's Travels (2010) Video: | Audio: | AR: | Fox
bb nf Hamlet Video: AVC | Audio: PCM 2.0 | AR: 1.78:1 | BBC | 1080i
bb nf Harold & Kumar: Escape From Guantanamo Bay Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | New Line
bb nf Harvey Video: AVC | Audio: DTS-HD MA mono | AR: 1.37:1 | Universal
bb nf Heartbreak Kid, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Her Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf High School Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Hitman: Unrated Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Hobo With A Shotgun Video: | Audio: | AR: |
bb nf Home Video: AVC | Audio: DTS-HD HR / DD EX | AR: 1.78:1 | Fox
bb nf Horns Video: AVC | Audio: | AR: |
bb nf Hunger Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Criterion
bb nf I Am Number Four Video: | Audio: | AR: |
bb nf I Spit On Your Grave 2 (2013) Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf I'm Not There (Canadian import) Video: | Audio: | AR: |
bb nf In Like Flint Video: AVC | Audio: | AR: | Twilight Time
bb nf In the Valley of Elah Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Inception Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf Initial D Video: AVC | Audio: PCM | AR: 2.35:1 | Tai Seng
bb nf Insidious Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Iron Man 2 Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Jarhead Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Jayne Mansfield's Car Video: | Audio: | AR: | Starz/Anchor Bay
bb nf John Carter Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Disney
bb nf Kagemusha Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Criterion
bb nf Killing Them Softly Video: | Audio: | AR: | Starz/Anchor Bay
bb nf Kite Runner, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Land Of The Lost Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Legion Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Léon: The Professional Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Les Misérables (2012) Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Universal
bb nf Lethal Weapon 2 (remastered) Video: VC-1 | Audio: DTS-HD MA | AR: | Warner | Part of the Lethal Weapon Collection box set
bb nf Limitless Video: | Audio: | AR: | Fox
bb nf Little Miss Sunshine Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Lord Of The Rings: Return Of The King, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Lord Of The Rings:Two Towers, The (Extended Edition) Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.40:1 | Warner
bb nf Lover, The (German Import) Video: | Audio: | AR: | | region-free
bb nf Machine Gun Preacher Video: | Audio: | AR: | Fox
bb nf Man Of Steel Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Warner
bb nf Maria Holic: Complete Collection Video: AVC | Audio: | AR: | Sentai Filmworks
bb nf Mary Poppins Video: AVC | Audio: 7.1 DTS-HD MA | AR: 1.66:1 | Disney
bb nf Masters of Horror: Season 1, Vol. 1 Video: AVC | Audio: PCM | AR: 1.77:1 | Starz
bb nf Matrix Reloaded, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Max Payne Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Mechanic, The (2011) Video: | Audio: | AR: | Sony
bb nf Melancholia Video: | Audio: | AR: | Magnolia
bb nf Memoirs of a Geisha Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Miral Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Starz / Anchor Bay
bb nf Mission: Impossible - Ghost Protocol Video: AVC | Audio: TrueHD 7.1 | AR: 2.40:1 | Paramount
bb nf Moneyball Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Mother's Day (2011) Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Mr. & Mrs. Smith Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Mr. Magorium's Wonder Emporium Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Nanny McPhee Returns Video: | Audio: | AR: | Universal
bb nf New Year's Eve Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Newsies Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Next Video: AVC | Audio: PCM | AR: 2.35:1 | Paramount
bb nf Next (UK Import) Video: VC-1 | Audio: DTS-HD HR | AR: 2.35:1 | EIV
bb nf Night at the Museum Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Nine Inch Nails: Beside You In Time Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Interscope
bb nf Nip/Tuck: The Complete Fourth Season Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf No Strings Attached Video: | Audio: | AR: |
bb nf Okamikakushi - Masque of the Wolf: Complete Collection Video: | Audio: | AR: | Sentai Filmworks
bb nf Oranges, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Order, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Out Of Sight Video: | Audio: | AR: |
bb nf Pale Rider Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Passchendaele (CA Import) Video: ? | Audio: ? | AR: 2.39:1 | Alliance
bb nf Pat Metheny Group: The Way Up – Live Video: VC-1 | Audio: DD+ / DTS-HD HR | AR: 1.78:1 | Eagle Rock
bb nf Pathfinder Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf People Like Us Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Perfect Getaway, A Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Pierrot Le Fou Video: AVC | Audio: PCM mono | AR: 2.35:1 | Criterion
bb nf Pillars Of The Earth, The Video: | Audio: | AR: |
bb nf Piranha (2010) Video: | Audio: | AR: |
bb nf Pirate Radio Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Pirates of the Caribbean: On Stranger Tides Video: AVC | Audio: DTS-HD MA | AR: | Disney
bb nf Premonition Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Primeval Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Princess Bride, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Prisoner, The: The Complete Series Video: AVC | Audio: DD 5.1 | AR: 1.33:1 | A & E Video
bb nf Punisher: War Zone Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Pursuit of Happyness, The Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Quiz Show (Australian Import) Video: ? | Audio: ? | AR: | Disney | region-free
bb nf Race To Witch Mountain Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Disney
bb nf Recoil Video: | Audio: | AR: | Vivendi
bb nf Red (Special Edition) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Summit Entertainment
bb nf Red Shoes, The Video: | Audio: | AR: | Criterion
bb nf Replacement Killers, The Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Repo Men Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Rescuers Down Under, The Video: AVC | Audio: DTS-HD MA | AR: 1.67:1 | Disney
bb nf Resident Evil: Retribution Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Robin Hood (1973) Video: AVC | Audio: DTS-HD MA | AR: 1.66:1 | Disney
bb nf Ruins, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Safe Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Lionsgate
bb nf Sahara Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount
bb nf Saving Private Ryan Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf Saw V Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Season Of The Witch Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Secretariat Video: | Audio: | AR: | Disney
bb nf Seven Swords Video: AVC | Audio: DD 5.1 | AR: 2.35:1 | Vivendi Visual
bb nf Sex and the City Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line
bb nf Shakira: Oral Fixation Video: AVC | Audio: PCM | AR: 1.78:1 | Sony / BMG
bb nf Shall We Dance? Video: AVC | Audio: PCM | AR: 1.85:1 | Disney
bb nf Shanghai Noon Video: AVC | Audio: DD 5.1 | AR: 2.35:1 | Disney | part of a double feature
bb nf Shinobi Video: AVC | Audio: TrueHD | AR: 2.35:1 | FUNimation
bb nf Showgirls Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Silent Hill (German Import) Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Sinister Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Sky Crawlers, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Sleuth Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Snowpiercer Video: | Audio: | AR: |
bb nf Solomon Kane (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Entertainment In Video | Region B-locked
bb nf Sopranos, The: Season 6, Part 1 Video: VC-1 | Audio: PCM | AR: 1.78:1 | Warner
bb nf Sorcerer's Apprentice, The Video: | Audio: | AR: | Disney
bb nf Star Trek II: Wrath of Khan, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Star Trek: Generations Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Star Trek: Nemesis Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount
bb nf Star Wars: Episode II - Attack Of The Clones Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Stardust (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Starship Troopers (UK Import) Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Steins; Gate: Part 1 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Stepfather, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Stonehearst Asylum Video: | Audio: | AR: | Millennium
bb nf Super 8 Video: | Audio: | AR: | Paramount
bb nf Super Speedway Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf Superheroes: A Never-ending Battle Video: AVC | Audio: Dolby Digital 5.1 | AR: 1.78:1 | PBS
bb nf Superman III Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner | only found in the Superman Motion Picture Anthology
bb nf Sweetie Video: | Audio: | AR: | Criterion
bb nf Takers Video: | Audio: | AR: |
bb nf Ted Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Ten Commandments, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf This Is Where I Leave You Video: | Audio: | AR: | Warner
bb nf Topaz Video: | Audio: | AR: | Universal
bb nf Tosh.0: Deep V's Video: AVC | Audio: TrueHD | AR: 1.78:1 | Comedy Central | 1080i
bb nf Traitor Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay
bb nf Transsiberian Video: VC-1 | Audio: DD | AR: 2.35:1 | First Look Studios
bb nf Twelve Chairs, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Twilight Saga: Eclipse Video: | Audio: | AR: |
bb nf U2: 360° at the Rose Bowl Video: avc | Audio: DTS-HD MA | AR: 1.78:1 | Universal Music | 1080i
bb nf Unbreakable Machine Doll: The Complete Series Video: AVC | Audio: | AR: | Funimation
bb nf Universal Soldier: Regeneration Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Vexille Video: AVC | Audio: TrueHD | AR: 1.78:1 | FUNimation
bb nf Visions of the Sea: Explorations Video: AVC | Audio: TrueHD | AR: 1.78:1 | DVD Intl.
bb nf Walk Hard: The Dewey Cox Story Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Wall Street: Money Never Sleeps Video: | Audio: | AR: | Fox
bb nf War Video: AVC | Audio: PCM (7.1) | AR: 2.35:1 | Lionsgate
bb nf Warlords, The (Hong Kong Import) Video: AVC | Audio: DTS-HD MA/TrueHD | AR: 2.35:1 | Mega Star
bb nf Warriors, The Video: AVC | Audio: DD | AR: 1.85:1 | Paramount
bb nf Water For Elephants Video: | Audio: | AR: | Fox
bb nf Way Back, The Video: | Audio: | AR: |
bb nf We Bought A Zoo Video: | Audio: | AR: | Fox
bb nf Weeds: Season One Video: MPEG-2 | Audio: DD EX5.1 | AR: 1.78:1 | Lionsgate
bb nf Wicker Tree, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz / Anchor Bay
bb nf Wild Strawberries Video: AVC | Audio: PCM Mono | AR: 1.33:1 | Criterion
bb nf Wolverine And The X-Men: The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Won't Back Down Video: | Audio: | AR: | Fox
bb nf World War Z Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Paramount
bb nf X-Men Origins: Wolverine Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Year One Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Young Adult Video: | Audio: | AR: | Paramount
bb nf Zulu (UK Import) Video: AVC | Audio: DD 2.0 | AR: 2.35:1 | Paramount | DNR
SuprSlow is offline
post #8 of 35 Old 08-20-2012, 07:02 PM - Thread Starter
SuprSlow's Avatar
bb nf 13 Sins Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Starz/Anchor Bay
bb nf 28 Weeks Later Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf 3:10 to Yuma Video: VC-1 | Audio: PCM (7.1) | AR: 2.40:1 | Lionsgate
bb nf 3:10 To Yuma (1957) Video: | Audio: | AR: | Criterion
bb nf 3:10 To Yuma (German Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf 61* Video: | Audio: | AR: | HBO
bb nf A River Runs Through It Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Adventurer, The: Curse Of The Midas Box Video: | Audio: | AR: |
bb nf Aliens vs. Predator: Requiem Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Alpha Dog (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon Home Entertainment
bb nf American Psycho (Australian Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Architect, The Video: MPEG-2 | Audio: DTS-HD HR | AR: 1.78:1 | Magnolia
bb nf ATL Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner
bb nf Baka and Test: Summon The Beasts: Season 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Band of Brothers Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | HBO | minor DNR
bb nf Batman: Mystery of the Batwoman Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Be Kind Rewind Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line
bb nf Black Narcissus (UK Import) Video: VC-1 | Audio: DD Mono | AR: 1.37:1 | ITV DVD
bb nf Blade Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.40:1 | Warner
bb nf Blood Diamond Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Blue Planet (IMAX) Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Body of Lies Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Bourne Identity, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Braveheart (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Breaking Bad: The Complete First Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sony
bb nf Bridesmaids Video: | Audio: | AR: |
bb nf Bridge to Terabithia Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Brief Encounter Video: | Audio: | AR: | Criterion
bb nf Brüno Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Cabin Fever Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Captain Phillips Video: | Audio: | AR: | Sony
bb nf Casanova Video: VC-1 | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Casino Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Cast Away Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Chernobyl Diaries Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Chronicle Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Cleopatra (1963) Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox
bb nf Cloverfield Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Paramount
bb nf Colombiana Video: | Audio: | AR: | Sony
bb nf Condemned, The Video: VC-1 | Audio: DTS-HD HR (7.1) | AR: 1.78:1 | Lionsgate
bb nf Contagion Video: | Audio: | AR: | Warner
bb nf Cool Hand Luke Video: VC-1 | Audio: DD1.0 | AR: 2.35:1 | Warner
bb nf Cowboys & Aliens Video: | Audio: | AR: | Universal
bb nf Crazies, The (2010) Video: VC-1 | Audio: PCM | AR: 2.40:1 | Starz / Anchor Bay
bb nf Cronos Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Criterion
bb nf Daredevil Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Day After Tomorrow, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Daybreakers Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Lionsgate
bb nf Departed, The Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Diary Of A Wimpy Kid Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Dilemma, The Video: | Audio: | AR: |
bb nf Discovery Atlas: Italy Revealed Video: VC-1 | Audio: DD | AR: 1.78:1 | Discovery
bb nf Disturbia Video: AVC | Audio: DTS | AR: 1.85:1 | Paramount
bb nf Divine Move, The Video: | Audio: | AR: | CJ Entertainment
bb nf Dr. No Video: AVC | Audio: DTS-HD MA | AR: 1.66:1 | MGM
bb nf East, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Easy Rider Video: AVC | Audio: TrueHD | AR: | Sony
bb nf Eight Below Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Elephant White Video: AVC | Audio: TrueHD | AR: 2.35:1 | Millenium Media
bb nf Erin Brockovich (Korean Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Everlasting Moments Video: | Audio: | AR: | Criterion
bb nf Expendables, The Video: | Audio: | AR: |
bb nf Fantasia 2000 Video: AVC | Audio: DTS-HD MA | AR: | Disney
bb nf Fargo Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Fat Girl Video: | Audio: | AR: | Criterion
bb nf Fate / stay night: Unlimited Blade Works Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Section 23
bb nf Fearless, Jet Li's Video: VC-1 | Audio: DTS-HD MA | AR: 2.39:1 | Universal
bb nf Few Good Men, A Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Final Destination 5 Video: | Audio: | AR: | Warner
bb nf Flags of Our Fathers Video: AVC | Audio: DD | AR: 2.40:1 | Dreamworks
bb nf Flags of Our Fathers (UK Import) Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Forbidden World Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Shout Factory
bb nf Friends With Benefits Video: | Audio: | AR: | Sony
bb nf From Beyond Video: | Audio: | AR: | Scream Factory
bb nf Frozen Ground, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf G.I. Jane Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Gandhi Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Gangs Of New York (remastered) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Disney
bb nf Get Smart Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf Ghost in the Shell 2.0 Video: AVC | Audio: DTS-HD MA 6.1 | AR: 1.78:1 | Starz/Anchor Bay
bb nf Girl Who Kicked The Hornet's Nest, The Video: AVC | Audio: DD 5.1 | AR: 1.78:1 | Music Box Films
bb nf Goal: The Dream Begins Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Goldfinger Video: AVC | Audio: DTS-HD MA | AR: 1.67:1 | MGM
bb nf Gray's Anatomy Video: | Audio: | AR: | Criterion
bb nf Great Mouse Detective, The Video: AVC | Audio: | AR: | Disney
bb nf Grey, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Hairspray Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | New Line
bb nf Hannie Caulder Video: | Audio: | AR: | Olive Films
bb nf Happening, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Harry Potter and the Chamber of Secrets Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Harry Potter And The Half-Blood Prince Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner
bb nf Haunted House, A Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Heat Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Hellsing Ultimate: Volumes I - IV Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation
bb nf Hereafter Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Heroes: Season Two Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Hidalgo Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Hidden (Caché) (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Artificial Eye
bb nf Hidden Fortress, The Video: | Audio: | AR: | Criterion
bb nf Hoffa Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Hollow Man: Director's Cut Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Holy Man Video: | Audio: | AR: | Mill Creek
bb nf House Bunny, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Howards End Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Criterion
bb nf Hulk (2003) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Ice Age Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf In Bruges Video: | Audio: | AR: | Universal
bb nf Indiana Jones And The Raiders Of The Lost Ark Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Indiana Jones And The Temple Of Doom Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Inglorious Bastards, The (1978) Video: AVC | Audio: Dolby Digital 5.1 | AR: 1.85:1 | Severin
bb nf Jacket, The (Japanese Import) Video: AVC | Audio: | AR: 2.40:1 |
bb nf Juno Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Jurassic Park 3 Video: | Audio: | AR: |
bb nf Killers, The: Live From The Royal Albert Hall Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Def Jam | 1080i
bb nf King Of Kings Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf Kiss of the Dragon Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf L.A. Confidential Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Ladder 49 Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Lagrange: The Flower of Rin-ne: Vol. 1 Video: AVC | Audio: | AR: | Viz Media
bb nf Lakeview Terrace Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Larry Crowne Video: | Audio: | AR: | Universal
bb nf Last Chance Harvey Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay
bb nf Last King Of Scotland, The Video: | Audio: | AR: |
bb nf Late Phases: Night of the Lone Wolf Video: AVC | Audio: | AR: | Dark Sky
bb nf Lawless (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Momentum Pictures | Region B locked?
bb nf Leap Year Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Left Behind (2014) Video: | Audio: | AR: | Entertainment One
bb nf Legend Of The Legendary Heroes, The: Part I Video: AVC | Audio: TrueHD 2.0 | AR: 1.78:1 | Funimation
bb nf Legend Of The Legendary Heroes, The: Part II Video: AVC | Audio: TrueHD 2.0 | AR: 1.78:1 | Funimation
bb nf Let the Right One In Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Lethal Weapon (remastered) Video: VC-1 | Audio: DTS-HD MA | AR: | Warner | Part of the Lethal Weapon Collection box set
bb nf Letters From Iwo Jima Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf Lockout Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Lookout, The Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Losers, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Magician, The Video: | Audio: | AR: | Criterion
bb nf Mamma Mia!: The Movie Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Marine 3: Homefront, The Video: AVC | Audio: DTS-HD MA | AR: | Fox
bb nf Marine, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Mark of the Devil Video: AVC | Audio: | AR: | Arrow Video
bb nf Marley And Me: The Puppy Years Video: | Audio: | AR: |
bb nf Matrix, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Memento (10th Anniversary) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Men in Black Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Men Who Stare At Goats, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz / Anchor Bay
bb nf Midnight Movie Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Phase 4 Films
bb nf Milk Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Mimic Video: AVC | Audio: DTS-HD MA 7.1 | AR: 1.85:1 | Lionsgate
bb nf Moonraker Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM
bb nf Moonrise Kingdom Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Morning Glory Video: | Audio: | AR: |
bb nf My Best Friend's Girl Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Mystery of the Nile (IMAX) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image
bb nf Never Let Me Go Video: | Audio: | AR: |
bb nf Nightmare On Elm Street, A (2010) Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Nim's Island Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Norbit Video: AVC | Audio: DD | AR: 1.85:1 | Paramount
bb nf North By Northwest Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Notebook, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | New Line
bb nf Nurse Jackie: Season One Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Observe And Report Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf Ocean's Eleven Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Odd Thomas Video: | Audio: | AR: |
bb nf On Her Majesty's Secret Service Video: AVC | Audio: | AR: | MGM
bb nf On The Waterfront Video: | Audio: | AR: | Criterion
bb nf One For The Money Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Originals, The: Season One Video: | Audio: | AR: | Warner
bb nf Orphan Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Ouran High School Host Club Video: AVC | Audio: TrueHD 2.0 | AR: 1.37:1 | Funimation
bb nf Outlaw Josey Wales, The Video: | Audio: | AR: |
bb nf Pandorum Video: AVC | Audio: TrueHD | AR: 2.35:1 | Starz / Anchor Bay
bb nf Pee-wee's Big Adventure Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Pillow Talk Video: | Audio: | AR: | Universal
bb nf Pixar Short Films Collection: Vol. 1 Video: AVC | Audio: PCM | AR: 1.85:1 | Disney
bb nf Planet Earth Video: AVC | Audio: DD | AR: 1.78:1 | Discovery
bb nf Play Time Video: AVC | Audio: PCM 2.0 | AR: 1.85:1 | Criterion
bb nf Police: Certifiable, The Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Universal Music
bb nf Private Lives Of Pippa Lee, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Screen Media
bb nf Rare Exports: A Christmas Tale Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Oscilloscope Pictures
bb nf Red Lights Video: AVC | Audio: TrueHD | AR: 2.35:1 | Millenium Media
bb nf Redemption Video: | Audio: | AR: | Lionsgate
bb nf Repulsion Video: AVC | Audio: PCM mono | AR: 1.66:1 | Criterion
bb nf Rescue Me: The Complete Third Season Video: AVC | Audio: PCM | AR: 1.78:1 | Sony
bb nf Resident Evil: Afterlife Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Reunion, The Video: | Audio: | AR: | Vivendi
bb nf Righteous Kill Video: ? | Audio: TrueHD | AR: 2.35:1 | Starz/Anchor Bay
bb nf Rise: Blood Hunter (UK Import) Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Rite, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf RockNRolla Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner
bb nf Rocky Balboa Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf RWBY: Volume 1 Video: AVC | Audio: 5.1 DD | AR: 1.78:1 | Cinedigm
bb nf Saw IV Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Scorpion King 2, The: Rise of a Warrior Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Scream 4 Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Shaun Of The Dead Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Universal
bb nf Silent Night Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf Smokin' Aces 2: Assassins' Ball Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf So I Married An Axe Murderer Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Solomon Kane Video: AVC | Audio: DTS-HD MA | AR: | Starz / Anchor Bay
bb nf Sorceror and the White Snake, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Magnolia
bb nf Spectacular Spider-Man, The: The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sony
bb nf Spider-Man 2 Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Spider-Man 2 (4K edition) Video: AVC | Audio: | AR: | Sony
bb nf Spirits Of The Dead (region-free UK) Video: AVC | Audio: PCM mono | AR: 1.85:1 | Arrow
bb nf Star Wars: Episode V - The Empire Strikes Back Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Star Wars: Episode VI - Return Of The Jedi Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Starship Troopers Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Steins; Gate: Part 2 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Funimation | more banding than Part 1
bb nf Student Council's Discretion: Season One Collection Video: AVC | Audio: | AR: | Sentai Filmworks
bb nf Superbad Video: AVC | Audio: PCM/TrueHD | AR: 1.78:1 | Sony
bb nf Superman / Shazam!: The Return Of Black Adam Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Warner
bb nf Swordfish Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner
bb nf Take Me Home Tonight Video: | Audio: | AR: | Fox
bb nf Terminator 3: Rise of the Machines Video: VC-1 | Audio: DD5.1 | AR: 2.35:1 | Warner
bb nf The Office: Season Five Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Thing, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf This Means War Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Three Outlaw Samurai Video: | Audio: | AR: | Criterion
bb nf Tin Man (UK Import) Video: AVC | Audio: DTS-HD HR | AR: 1.78:1 | Brightspark
bb nf Transcendence Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Transporter 2 Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Transporter, The (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Treme: Complete Third Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Twilight Zone, The: Season 1 Video: AVC | Audio: PCM mono | AR: 1.33:1 | Image Entertainment
bb nf Two Lovers Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Magnolia
bb nf Un-Go: Complete Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf Underdog Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Underworld: Evolution Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Underworld: Rise of the Lycans Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony
bb nf Unthinkable Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Venture Bros, The: Season 3 Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Vertigo Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Virgin Territory Video: VC-1 | Audio: DD 5.1 | AR: 1.85:1 | Starz / Anchor Bay
bb nf Visitor, The Video: AVC | Audio: PCM | AR: 1.85:1 | Starz/Anchor Bay
bb nf Warm Bodies Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit Entertainment
bb nf Watchmen: The Complete Motion Comic Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf What Happens in Vegas Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Whip It Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Willow Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Win Win Video: | Audio: | AR: |
bb nf World Trade Center Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount
bb nf X2: X-Men United (UK Import) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Yogi Bear Video: AVC | Audio: DTS-HD MA | AR: | Warner
bb nf Zack and Miri Make a Porno Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein
bb nf Zookeeper Video: | Audio: | AR: | Sony
SuprSlow is offline
post #9 of 35 Old 08-20-2012, 07:04 PM - Thread Starter
SuprSlow's Avatar
bb nf 21 Jump Street Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf 24: Season 7 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Abraham Lincoln: Vampire Hunter Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Fox
bb nf Africa's Elephant Kingdom (IMAX) Video: AVC | Audio: DD 2.0 | AR: 1.43:1 | Genius Entertainment
bb nf African Queen, The Video: AVC | Audio: DD Mono | AR: 1.37:1 | Paramount
bb nf Afro Samurai: Resurrection Video: AVC | Audio: DD 5.1 | AR: 1.78:1 | FUNimation Entertainment
bb nf Air Force One (UK Import) Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Alpha And Omega Video: | Audio: | AR: |
bb nf American Beauty Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Arlington Road Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Austin Powers: International Man of Mystery Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | New Line
bb nf Badlands Video: | Audio: | AR: | Criterion
bb nf Band of Outsiders Video: | Audio: | AR: | Criterion
bb nf Bang Bang Club, The Video: | Audio: | AR: | E1 Entertainment
bb nf Battle: Los Angeles Video: | Audio: | AR: |
bb nf Beautiful Creatures Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Being John Malkovich Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Criterion
bb nf Big Fish Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony
bb nf Big Gundown, The Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Grindhouse Releasing
bb nf Bigger Than Life Video: | Audio: | AR: | Criterion
bb nf Blob, The (1958) Video: | Audio: | AR: | Criterion
bb nf Boondock Saints II, The: All Saints Day Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Sony
bb nf Bride Of Frankenstein, The Video: | Audio: | AR: | | part of the Universal Classic Monsters box set
bb nf Brokeback Mountain Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Broken City Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf By The Gun Video: AVC | Audio: | AR: | Millennium
bb nf Campaign, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Captain America: The First Avenger Video: | Audio: | AR: | Paramount
bb nf Carrie (2013) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Casablanca Video: VC-1 | Audio: DD1.0 | AR: 1.37:1 | Warner | original version with older scan of the film elements
bb nf Cell, The (Canadian import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Alliance
bb nf Change-Up, The Video: | Audio: | AR: | Universal
bb nf Chariots Of Fire Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Chicago/Earth, Wind And Fire: Live At The Greek Theatre Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Image Entertainment | 1080i
bb nf Colorful: The Motion Picture Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Sentai Filmworks
bb nf Covenant, The Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Cowboys & Aliens (UK Import) Video: | Audio: | AR: | Paramount | different encode than domestic version
bb nf Crazy Heart Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Crimson Tide Video: AVC | Audio: PCM | AR: 2.40:1 | Disney
bb nf Crocodile Dundee Video: | Audio: | AR: | Fox | part of the Crocodile Dundee double feature
bb nf Cruel Intentions Video: AVC | Audio: PCM | AR: 1.85:1 | Sony
bb nf Day Watch (Japan Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Fox
bb nf Days of Glory (UK Import) Video: AVC | Audio: DTS | AR: 2.35:1 | Metrodome
bb nf Days Of Heaven Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Criterion
bb nf Dead Poets Society Video: | Audio: | AR: | Disney
bb nf Disconnect Video: | Audio: | AR: | Lionsgate
bb nf Divergent Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit Entertainment | retail edition
bb nf Dracula 2000 (Canadian Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Alliance | 1080i
bb nf Dream House Video: | Audio: | AR: | Universal
bb nf Dune Video: | Audio: | AR: |
bb nf Elektra Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Elvis Costello & the Imposters: Club Date - Live in Memphis Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.78:1 | Eagle Rock | 1080i
bb nf English Patient, The Video: | Audio: | AR: | Lionsgate
bb nf Ernest Hemingway's The Killers (1946) (UK Import) Video: AVC | Audio: | AR: | Arrow Video | Region B
bb nf Family Guy: It's A Trap! Video: | Audio: | AR: |
bb nf Fantastic 4 Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Flavia The Heretic Video: | Audio: | AR: | Scorpion Releasing
bb nf Fly Away Home Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf For Your Eyes Only Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MGM
bb nf Four Christmases Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line Cinema
bb nf Fresh Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Echo Bridge
bb nf From Dusk Til Dawn (CA Import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Alliance
bb nf From Paris With Love Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Lionsgate
bb nf Frozen Video: AVC | Audio: TrueHD | AR: 2.40:1 | Starz / Anchor Bay
bb nf Funny People Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Ghosbusters (remastered in 4K) Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony | 2013 remaster
bb nf Golden Compass, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | New Line | DNR
bb nf Gomorrah (UK import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Optimum
bb nf Gone With The Wind Video: VC-1 | Audio: TrueHD | AR: 1.37:1 | Warner
bb nf Good Night and Good Luck Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Warner
bb nf Gran Torino Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Guardian, The Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Guilt Trip, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Hall Pass Video: | Audio: | AR: |
bb nf Halloween: 35th Anniversary Edition Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.35:1 | Starz / Anchor Bay
bb nf Hangover, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Harold and Maude Video: | Audio: | AR: | Criterion
bb nf Harry Brown Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Harry Potter And The Deathly Hallows: Part 1 Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Harry Potter and the Sorcerer's Stone Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Here Comes The Devil Video: | Audio: | AR: |
bb nf How The Grinch Stole Christmas! (1966) Video: VC-1 | Audio: DD 2.0 | AR: 1.33:1 | Warner
bb nf Hurt Locker, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Summit Entertainment
bb nf I Am Bruce Lee Video: | Audio: | AR: | Shout Factory
bb nf I've Loved You So Long Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Illusionist, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf In Cold Blood Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony
bb nf In The Mouth Of Madness Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Incendiary Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Magnolia
bb nf Independence Day Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Informers, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Inherent Vice Video: AVC | Audio: | AR: | Warner
bb nf Into the Blue Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Invasion, The Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf Invention Of Lying, The Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Invincible Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Ip Man Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Well Go USA
bb nf Iron Man 3 Video: AVC | Audio: 7.1 DTS-HD MA | AR: 2.40:1 | Disney
bb nf Jaws Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Universal
bb nf John Mayer: Where The Light Is Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Sony
bb nf Justice League: Throne of Atlantis Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Justin Timberlake: FutureSex / LoveShow Video: VC-1 | Audio: PCM | AR: 1.78:1 | Sony Music
bb nf Killers Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.35:1 | Lionsgate
bb nf Kingpin Video: AVC | Audio: | AR: |
bb nf Knights of Badassdom Video: | Audio: | AR: | Entertainment One
bb nf Knocked Up Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Kokoro Connect: OVA Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Section 23
bb nf Kramer Vs. Kramer Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf La Grande Illusion Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.33:1 | Lionsgate
bb nf Last Emperor, The Video: AVC | Audio: DTS-HD MA | AR: 2.00:1 | Criterion
bb nf Last Unicorn, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Layer Cake Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Legend of Zorro, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Leonard Cohen: Songs From The Road Video: AVC | Audio: TrueHD | AR: 1.78:1 | Sony | 24-bit/96kHz
bb nf Little Big Soldier Video: | Audio: | AR: | Well Go USA
bb nf Lost Boys, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Lost City, The Video: MPEG-2 | Audio: DTS-HD MA / PCM | AR: 1.85:1 | Magnolia
bb nf Love Actually Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Man From Nowhere, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Well Go USA
bb nf Manchurian Candidate, The (2004) Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount
bb nf Marnie Video: | Audio: | AR: | Universal
bb nf Memento Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Michael Clayton Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Midnight In Paris Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Midnight Meat Train, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Misery Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Miss Fisher's Murder Mysteries: Series 1 Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Acorn media
bb nf Mummy, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Murder Obsession Video: | Audio: | AR: | Raro Video
bb nf My Neighbor Totoro Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf My Week With Marilyn Video: | Audio: | AR: | Starz / Anchor Bay
bb nf New Daughter, The Video: VC-1 | Audio: PCM | AR: 2.35:1 | Starz / Anchor Bay
bb nf Nick & Norah's Infinite Playlist Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Night Watch (Japan Import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Fox
bb nf Ninja Scroll Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.33:1 | Section 23
bb nf Ocean's Twelve Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Other Guys, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Outlander Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Vivendi Visual
bb nf Pale Flower Video: | Audio: | AR: | Criterion
bb nf Pandora and the Flying Dutchman Video: | Audio: | AR: | Kino
bb nf Papillon Video: | Audio: | AR: | Warner
bb nf Paranoiac! (UK Import) Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Eureka Entertainment
bb nf Payback (UK Import) Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner
bb nf Paycheck Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Perfect Game, The Video: | Audio: | AR: |
bb nf Phantom Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Phantom, The Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.39:1 | Lionsgate
bb nf Pierre Étaix Collector's Set Video: | Audio: | AR: | Criterion
bb nf Pineapple Express Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony
bb nf Pitch Black Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Planet Of The Apes (1968) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Poker Night Video: | Audio: | AR: | XLrator media
bb nf Post Grad Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Powder Blue Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Image
bb nf Pride and Glory Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Public Enemies Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Universal
bb nf Raven, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Reign of Fire Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Reign Over Me Video: AVC | Audio: PCM | AR: 2.35:1 | Sony
bb nf Road Trip Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf Role Models Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Romancing the Stone Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Rome: The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | HBO
bb nf Room with a View, A Video: VC-1 | Audio: DD EX | AR: 1.66:1 | BBC
bb nf Rosemary's Baby Video: AVC | Audio: PCM Mono | AR: 1.85:1 | Criterion
bb nf Ruby Sparks Video: | Audio: | AR: | Fox
bb nf Runaways, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Running With Scissors Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Samurai 7: The Complete Series Video: AVC | Audio: TrueHD | AR: 1.78:1 | FUNimation Entertainment
bb nf Samurai I: Musashi Miyamoto Video: | Audio: | AR: | Criterion | part of the Samurai Trilogy
bb nf Scenic Route Video: | Audio: | AR: | Vertical Entertainment
bb nf Scott Pilgrim Vs. The World Video: AVC | Audio: DTS-HD MA | AR: | Universal
bb nf Searchers, The Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner
bb nf Sentinel, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Serenity Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Sherlock Holmes Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Silverado Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Sitter, The Video: | Audio: | AR: | Fox
bb nf Spider-Man Video: AVC | Audio: PCM / TrueHD | AR: 1.85:1 | Sony
bb nf Spy Next Door, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Star Trek: First Contact Video: AVC | Audio: TrueHD | AR: 2.39:1 | Paramount
bb nf Star Wars: Episode IV - A New Hope Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Step Brothers Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Step Into Liquid Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Strangers, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Submarine Video: | Audio: | AR: |
bb nf Summer Hours Video: | Audio: | AR: | Criterion
bb nf Summer With Monika Video: | Audio: | AR: | Criterion
bb nf Supernatural: Season Nine Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Surrogates Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Sushi Girl Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Magnolia
bb nf Tales of Vesperia: The First Strike Video: AVC | Audio: | AR: | Funimation
bb nf Tell-Tale Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Vivendi
bb nf Texas Chainsaw Massacre, The (2003) Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | New Line
bb nf There Will Be Blood Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Thomas Crown Affair, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM
bb nf Total Recall (Dutch Import) Video: ? | Audio: ? | AR: 1.85:1 | ?
bb nf Toto: Live in Amsterdam Video: VC-1 | Audio: PCM(2.0) / DTS-HD HR | AR: 1.78:1 | Eagle Rock
bb nf Treasure Of The Sierra Madre, The Video: VC-1 | Audio: DTS-HD MA | AR: 1.37:1 | Warner
bb nf Twilight Saga, The: Breaking Dawn: Part 2 Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Summit Entertainment
bb nf Unknown Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf V for Vendetta Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Vampire Diaries, The: Season Five Video: | Audio: | AR: | Warner
bb nf Volver Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony
bb nf Warrior Video: AVC | Audio: DTS-HD MA | AR: | Lionsgate
bb nf West Side Story Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.20:1 | MGM
bb nf What Maisie Knew Video: | Audio: | AR: | Millennium Media
bb nf Where The Wild Things Are Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Whisper Of The Heart Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Whiteout Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Wicker Man, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Winter's Bone Video: | Audio: | AR: | Lionsgate
bb nf X-Men: The Last Stand Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf X2: X-Men United Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf You Only Live Twice Video: | Audio: | AR: | MGM
SuprSlow is offline
post #10 of 35 Old 08-20-2012, 07:06 PM - Thread Starter
SuprSlow's Avatar
bb nf (500) Days Of Summer Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf 10,000 BC Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf 127 Hours Video: | Audio: | AR: |
bb nf 30 Minutes Or Less Video: | Audio: | AR: | Sony
bb nf 6th Day, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf 7th Voyage of Sinbad, The Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony
bb nf A Very Harold And Kumar Christmas (3-D edition) Video: | Audio: | AR: | Warner
bb nf After.Life Video: AVC | Audio: PCM | AR: 2.40:1 | Starz / Anchor Bay
bb nf Alice In Wonderland (2010) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Disney
bb nf All Cheerleaders Die Video: AVC | Audio: | AR: | Image
bb nf Amelia Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf American Horror Story: The Complete First Season Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Arbitrage Video: | Audio: | AR: | Lionsgate
bb nf Assassination of Jesse James, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Babel Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Paramount
bb nf Bad Teacher Video: | Audio: | AR: | Sony
bb nf Batman Returns Video: VC-1 | Audio: TrueHD | AR: 1.78:1 | Warner
bb nf Behind Enemy Lines Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Berlin Concert, The: Live from the Waldbühne Video: ? | Audio: ? | AR: 1.78:1 | Deutsche Grammophon
bb nf Big Mommas: Like Father Like Son Video: | Audio: | AR: |
bb nf Big Year, The Video: | Audio: | AR: | Fox
bb nf Biutiful Video: | Audio: | AR: | Lionsgate
bb nf Black Moon Video: | Audio: | AR: | Criterion
bb nf Blithe Spirit Video: | Audio: | AR: | Criterion
bb nf Blitz Video: | Audio: | AR: | Millenium Media
bb nf Blood: The Last Vampire (animated 2000 version from digital scan) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Starz / Anchor Bay | telecine version has lower score
bb nf Bonnie and Clyde Video: VC-1 | Audio: DD1.0 | AR: 1.85:1 | Warner
bb nf Border Run Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Box, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Bridge On The River Kwai, The Video: AVC | Audio: | AR: | Sony
bb nf Bubble Video: MPEG-2 | Audio: DD3.0 | AR: 2.35:1 | Magnolia
bb nf Bucket List, The Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf Cabin In The Woods, The Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Cadillac Records Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Catch & Release Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Category 7: The End of the World Video: MPEG-2 | Audio: DD | AR: 1.78:1 | Echo Bridge
bb nf Chaos Video: AVC | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | Lionsgate
bb nf Chicago Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Chris Isaak: Beyond The Sun Live! Video: | Audio: | AR: | Vanguard
bb nf Cinderella Man (UK Import) Video: VC-1 | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Clear and Present Danger Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Clear History Video: | Audio: | AR: | HBO
bb nf Clerks II Video: AVC | Audio: TrueHD | AR: 1.85:1 | Weinstein
bb nf Clueless Video: | Audio: | AR: | Paramount
bb nf Con Air Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Contact Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Contraband Video: | Audio: | AR: | Universal
bb nf Country Strong Video: | Audio: | AR: |
bb nf Cowboys, The Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Coyote Ugly Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf Cube (Dutch Import) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | E1 Entertainment Benelux
bb nf Daimajin: Triple Feature Collection Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Mill Creek | contains all three Daimajin films
bb nf Dan in Real Life Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Dances With Wolves (UK Import) Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner
bb nf Day the Earth Stood Still, The (1951) Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Fox
bb nf Dead Snow Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MPI Media
bb nf Deadly Duo, The Video: | Audio: | AR: |
bb nf Devil Dog: The Hound of Hell Video: | Audio: | AR: | Media Blasters | out of print
bb nf Devil's Rejects, The Video: MPEG-2 | Audio: DTS-HD HR | AR: 1.85:1 | Lionsgate
bb nf Diamonds Are Forever Video: | Audio: | AR: | Fox
bb nf Dictator, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Did You Hear About The Morgans? Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Don't Be Afraid Of The Dark Video: | Audio: | AR: | Sony
bb nf Dreamgirls Video: MPEG-2 | Audio: DD | AR: 1.85:1 | Dreamgirls
bb nf Drownsman, The Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Eagle, The Video: | Audio: | AR: |
bb nf Edge Of Darkness Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Empire State (2013) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Entitled Video: | Audio: | AR: |
bb nf Exorcist III, The Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Extract Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Disney
bb nf Face/Off (UK Import) Video: AVC | Audio: PCM | AR: 2.35:1 | Buena Vista
bb nf Faculty, The (Canadian import) Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Alliance
bb nf Field of Dreams Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf First Squad: Moment Of Truth Video: AVC | Audio: TrueHD | AR: 1.78:1 | Starz / Anchor Bay
bb nf Flight of the Phoenix Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf For A Few Dollars More Video: | Audio: | AR: | MGM
bb nf Freelancers Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf Freezing Vibration: The Complete Second Season Video: AVC | Audio: | AR: 1.78:1 | Funimation
bb nf From Hell Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Gamera The Brave Video: | Audio: | AR: | Tokyo Shock
bb nf Gattaca Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Glory Road Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Godfather: Part II, The Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Gone Fishin' Video: | Audio: | AR: | Mill Creek
bb nf Graduate, The: StudioCanal Collection (UK import) Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Optimum | region-free
bb nf Gremlins 2: The New Batch Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Guard Post, The (UK Import) Video: AVC | Audio: DD5.1 | AR: 1.85:1 | Showbox
bb nf Harry Potter And The Deathly Hallows: Part 2 Video: AVC | Audio: DTS-HD MA | AR: | Warner
bb nf Harry Potter and the Goblet of Fire Video: VC-1 | Audio: PCM | AR: 2.40:1 | Warner
bb nf Hart's War Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Haywire Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Lionsgate
bb nf He's Just Not That Into You Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line
bb nf Heaven's Gate Video: | Audio: | AR: | Criterion
bb nf Here Comes The Boom Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf High Noon Video: AVC | Audio: | AR: | Olive Films
bb nf High School DxD Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf History of Violence, A Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | New Line | DNR
bb nf Hitchhiker's Guide to the Galaxy Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Hondo Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Housebound Video: | Audio: | AR: | XLrator media
bb nf Hudson Hawk Video: AVC | Audio: TrueHD | AR: 1.85:1 | Mill Creek | part of the Hollywood Homicide double-feature
bb nf Hunt for Red October, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Imaginarium Of Doctor Parnassus, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Immortal Beloved Video: MPEG-2 | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf In Bruges (Swedish Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Scanbox
bb nf Innkeepers, The Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | MPI
bb nf Inside Llewyn Davis Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Ipcress File, The (UK Import) Video: MPEG-2 | Audio: DD | AR: 2.35:1 | ITV DVD
bb nf Iron Lady, The Video: | Audio: | AR: | Weinstein Company
bb nf Jack And Jill Video: | Audio: | AR: | Sony
bb nf Jewel of the Nile, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Johnny English Reborn Video: | Audio: | AR: | Universal
bb nf Jonah Hex Video: VC-1 | Audio: | AR: | Warner
bb nf Joyful Noise Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Jurassic Park Video: | Audio: | AR: | Universal
bb nf K-19: The Widowmaker Video: AVC | Audio: TrueHD | AR: 2.35:1 | Paramount
bb nf Kelly's Heroes Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Warner
bb nf King Of Fighters, The Video: | Audio: | AR: | Well Go USA
bb nf Kung Fu Hustle Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf La Femme Nikita Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Last House On The Left, The (2009) Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Last Kiss, The Video: AVC | Audio: TrueHD | AR: 2.35:1 | DreamWorks
bb nf Last Love Video: | Audio: | AR: | Image
bb nf Life Video: VC-1 | Audio: | AR: | Warner
bb nf Live and Let Die Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf Lost Worlds: Life In The Balance (IMAX) Video: AVC | Audio: DD 5.1 | AR: 1.85:1 | Razor Digital
bb nf Lucky Number Slevin (UK Import) Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | EIV
bb nf Masters of Horror: Season 1, Vol. 4 Video: AVC | Audio: PCM | AR: 1.77:1 | Starz
bb nf Mimic 2: Hardshell Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Lionsgate
bb nf Miss March Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Moon Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Moulin Rouge! Video: | Audio: | AR: | Fox
bb nf Movie 43 Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Mr. Sardonicus Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Mill Creek | part of The Brotherhood of Satan double-feature
bb nf Mr. Woodcock Video: VC-1 | Audio: DTS-HD MA (7.1) | AR: 2.35:1 | New Line
bb nf Mrs. Doubtfire Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Mummies: Secrets Of The Pharoahs (IMAX) Video: | Audio: | AR: |
bb nf Mummy Returns, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf My Best Friend's Wedding (UK Import) Video: avc | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf My Soul To Take Video: | Audio: | AR: |
bb nf Mysteries Of Pittsburgh, The Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Phase 4 Films
bb nf Mysterious Island Video: AVC | Audio: DTS-HD MA | AR: | Twilight Time
bb nf Napoleon Dynamite Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Natural Born Killers (theatrical cut) Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Nausicaä of the Valley of the Wind Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.85:1 | Disney
bb nf Nights in Rodanthe Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Nine Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Obsessed Video: AVC | Audio: TrueHD | AR: 2.39:1 | Sony
bb nf One Missed Call Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Open House Video: AVC | Audio: | AR: | Lionsgate
bb nf Patton (Original edition) Video: AVC | Audio: DTS-HD MA | AR: 2.20:1 | Fox | contains bad DNR
bb nf Payback Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount
bb nf Peacemaker, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Phantom Of The Opera, The (1943) Video: | Audio: | AR: | Universal | part of the Universal Classic Monsters box set
bb nf Pink Floyd: The Story of Wish You Were Here Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Eagle Rock | 1080i
bb nf Piranha 3DD Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Starz / Anchor Bay
bb nf Planet Hulk Video: AVC | Audio: DTS-HD MA 7.1 | AR: | Lionsgate
bb nf Postman, The Video: VC-1 | Audio: | AR: | Warner
bb nf Psycho (1960) Video: | Audio: | AR: | Universal
bb nf Pulp Fiction Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Puppet Masters, The Video: AVC | Audio: DTS-HD MA 2.0 | AR: 2.35:1 | Mill Creek | part of the Deep Rising / The Puppet Masters double feature
bb nf Quest, The Video: | Audio: | AR: | Universal
bb nf Quo Vadis Video: VC-1 | Audio: DD Mono | AR: 1.37:1 | Warner
bb nf Rambo III Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Rambo: First Blood Part II Video: VC-1 | Audio: DTS-HD MA | AR: 2.20:1 | Lionsgate
bb nf Rear Window Video: VC-1 | Audio: DTS-HD MA mono | AR: 1.66:1 | Universal
bb nf Red Riding Hood Video: AVC | Audio: DTS-HD MA | AR: | Warner
bb nf Resident Evil Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Ring, The Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Paramount
bb nf Ritual: Tales From The Crypt Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Echo Bridge
bb nf Rock 'n' Roll High School Video: AVC | Audio: DD 2.0 | AR: 1.78:1 | Shout Factory
bb nf Rollerball (UK Import) Video: AVC | Audio: | AR: | Arrow Video | 1975; Region B
bb nf Runaways, The (German Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 |
bb nf Rush: Snakes and Arrows Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Zoe
bb nf Saat po long aka SPL (Hong Kong Import) Video: AVC | Audio: DTS-HD MA/TrueHD | AR: 1.85:1 | Deltamac | DNR/EE
bb nf Safety Not Guaranteed Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Sanjuro Video: AVC | Audio: PCM mono | AR: 2.35:1 | Criterion
bb nf Sarah's Key Video: | Audio: | AR: | Weinstein Company
bb nf Saw III Video: AVC | Audio: DTS-HD HR | AR: 1.78:1 | Lionsgate
bb nf Say Anything... Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Scary Movie Video: AVC | Audio: PCM | AR: 2.35:1 | Dimension | DNR/EE
bb nf Scooby Doo Video: VC-1 | Audio: DD | AR: 1.78:1 | Warner
bb nf Scribbler, The Video: | Audio: | AR: | XLrator media
bb nf Secret Window Video: MPEG-2 | Audio: PCM | AR: 2.40:1 | Sony
bb nf Sekirei: Pure Engagement Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf Senseless Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Echo Bridge
bb nf Shanghai Knights Video: AVC | Audio: DD 5.1 | AR: 2.35:1 | Disney | part of a double feature
bb nf Shawshank Redemption, The Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Sherlock Holmes: A Game Of Shadows Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Slumdog Millionaire Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Snow White and the Seven Dwarfs Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.37:1 | Disney
bb nf Species Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | MGM
bb nf Spy Who Loved Me, The Video: AVC | Audio: DTS-HD MA | AR: | MGM
bb nf Star Trek IV: Voyage Home, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Star Trek VI: Undiscovered Country, The Video: AVC | Audio: TrueHD | AR: 2.40:1 | Paramount
bb nf Star Wars: Episode I - The Phantom Menace Video: AVC | Audio: DTS-HD MA 6.1 | AR: 2.35:1 | Fox
bb nf Starman Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Stranger than Fiction Video: MPEG-2 | Audio: PCM | AR: 1.85:1 | Sony
bb nf Strangers On A Train Video: AVC | Audio: DTS-HD MA mono | AR: 1.37:1 | Warner
bb nf Street Fighter Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Universal
bb nf Sunday Bloody Sunday Video: | Audio: | AR: | Criterion
bb nf Superman II (theatrical version) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Switch, The Video: | Audio: | AR: |
bb nf Tank Girl Video: | Audio: | AR: | Shout Factory
bb nf Texas Killing Fields Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Thing, The (2011) Video: | Audio: | AR: | Universal
bb nf Thumbelina Video: | Audio: | AR: | Fox
bb nf Thunderball Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM
bb nf Tidal Wave Video: VC-1 | Audio: DTS-HD MA | AR: 2.35:1 | Magnolia
bb nf Tinker, Tailor, Soldier, Spy (UK import) Video: | Audio: | AR: | Optimum | Region B only
bb nf To Kill a King Video: AVC | Audio: PCM | AR: 2.35:1 | Starz
bb nf Tommy Boy Video: AVC | Audio: TrueHD | AR: 1.78:1 | Paramount
bb nf Topsy-Turvy Video: | Audio: | AR: | Criterion
bb nf Torn Curtain Video: | Audio: | AR: | Universal
bb nf Total Recall: Mind-bending edition Video: AVC | Audio: DTS-HD MA | AR: | Lionsgate
bb nf Tourist, The Video: | Audio: | AR: |
bb nf Trading Places Video: AVC | Audio: DD | AR: 1.85:1 | Paramount
bb nf Trespass Video: | Audio: | AR: |
bb nf Trick 'r Treat Video: VC-1 | Audio: TrueHD | AR: 2.39:1 | Warner
bb nf Ugly Truth, The Video: AVC | Audio: DTS-HD MA | AR: 2.39:1 | Sony
bb nf Ultimate Avengers: The Movie Video: MPEG-2 | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate
bb nf Ultimate G's: Zak's Flying Dreams Video: | Audio: | AR: |
bb nf Undefeated, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Untouchables, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Paramount
bb nf Vacancy Video: AVC | Audio: PCM | AR: 2.40:1 | Sony
bb nf Valentine's Day Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Vengeance Video: AVC | Audio: DD 5.1 | AR: 2.35:1 | BCI
bb nf Violet & Daisy Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | New Video Group
bb nf Wages of Fear Video: AVC | Audio: PCM | AR: 1.37:1 | Criterion
bb nf Walk the Line (Dutch Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Walking Dead, The: Season 1 Video: | Audio: | AR: |
bb nf Wanderlust Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf War Of The Worlds Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | DreamWorks
bb nf Way Of The Gun, The Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.85:1 | Lionsgate
bb nf We Were Soldiers (Aus. Import) Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Icon
bb nf Weeds Season 2 Video: AVC | Audio: PCM (7.1) | AR: 1.78:1 | Lionsgate
bb nf Weekend (1967) Video: | Audio: | AR: | Criterion
bb nf What's Your Number? Video: | Audio: | AR: | Fox
bb nf When We Left Earth: The NASA Missions Video: AVC | Audio: DD | AR: 1.78:1 | Discovery
bb nf Willy Wonka And The Chocolate Factory Video: VC-1 | Audio: TrueHD | AR: | Warner
bb nf Winnie the Pooh: A Very Merry Pooh Year Video: AVC | Audio: DD 2.0 | AR: 1.33:1 | Disney
bb nf Winter's Bone Video: AVC | Audio: | AR: 1.78:1 | Lionsgate
bb nf Within Temptation: Black Symphony Video: VC-1 | Audio: PCM | AR: 1.78:1 | Sony / BMG
bb nf World Is Not Enough, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | MGM
bb nf World's Fastest Indian, The Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia
bb nf Wrecked Video: | Audio: | AR: | MPI
bb nf X-Men Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Year Without A Santa Claus, The Video: VC-1 | Audio: DD 5.1 | AR: 1.37:1 | Warner
bb nf Yojimbo Video: AVC | Audio: PCM mono | AR: 2.35:1 | Criterion
bb nf Zazie dans le Métro Video: | Audio: | AR: | Criterion
bb nf Zombie Killers: Elephant's Graveyard
SuprSlow is offline
post #11 of 35 Old 08-20-2012, 07:09 PM - Thread Starter
SuprSlow's Avatar
bb nf 2001 Maniacs Video: AVC | Audio: | AR: 1.85:1 | Lionsgate
bb nf 2010: The Year We Make Contact Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf 27 Dresses Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf 7 Below Video: | Audio: | AR: | Arc Entertainment
bb nf A Certain Magical Index: Season One Video: AVC | Audio: | AR: | Funimation
bb nf Abduction Video: | Audio: | AR: | Lionsgate
bb nf Air Force One Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Alien 2: On Earth Video: | Audio: | AR: |
bb nf Alien Resurrection Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf All About Eve Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Fox
bb nf All Good Things Video: | Audio: | AR: |
bb nf Almost Famous (UK import) Video: AVC | Audio: TrueHD | AR: 1.85:1 | Sony
bb nf Amadeus Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner | Disc only includes extended version
bb nf Antichrist Video: | Audio: | AR: | Criterion
bb nf Any Given Sunday Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | Warner
bb nf Appaloosa Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Aria the Scarlet Ammo: Complete Series Video: AVC | Audio: | AR: | Funimation
bb nf Arthur (2011) Video: | Audio: | AR: |
bb nf Back-up Plan, The Video: AVC | Audio: DTS-HD MA | AR: | Sony
bb nf Barbarella Video: AVC | Audio: TrueHD 2.0 | AR: 2.35:1 | Paramount
bb nf Batman: Gotham Knight Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf Beastly Video: | Audio: | AR: | Sony
bb nf Beetlejuice Video: VC-1 | Audio: TrueHD | AR: 1.85:1 | Warner
bb nf Beverly Hills Cop Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Paramount
bb nf Beyond Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Bird With the Crystal Plumage, The Video: AVC | Audio: | AR: | Blue Underground
bb nf Black Dynamite Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Sony
bb nf Black Rain Video: MPEG-2 | Audio: DD | AR: 2.40:1 | Paramount
bb nf Black Swan Video: | Audio: | AR: |
bb nf Blazing Saddles Video: VC-1 | Audio: DD | AR: 2.40:1 | Warner
bb nf Blood (2012) Video: | Audio: | AR: | Image
bb nf Blood Out Video: | Audio: | AR: |
bb nf Bone Collector, The (UK Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Bounty Hunter, The Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Sony
bb nf Bring Me The Head of the Machine Gun Woman (UK Import) Video: | Audio: | AR: | | Region B-locked
bb nf Brothers Grimm, The Video: AVC | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Cabin Fever: Patient Zero Video: | Audio: | AR: | Image Entertainment
bb nf Carnage Video: AVC | Audio: DTS-HD MA 5.0 | AR: 2.35:1 | Sony
bb nf Centurion Video: AVC | Audio: | AR: | Magnolia
bb nf Charlie and the Chocolate Factory Video: VC-1 | Audio: | AR: | Warner
bb nf Chocolate Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Magnolia
bb nf Chris Botti: Live (With Orchestra and Special Guests) Video: AVC | Audio: PCM | AR: 1.78:1 | Sony BMG
bb nf Chronicles Of Narnia: The Voyage Of The Dawn Treader Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Citizen Kane Video: AVC | Audio: | AR: | Warner
bb nf Clash Of The Titans (2010) Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Cop Land Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Lionsgate
bb nf Cop Out Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Courage Under Fire Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Crack In The World Video: | Audio: | AR: | Olive Films
bb nf Crocodile Dundee II Video: | Audio: | AR: | Fox | part of the Crocodile Dundee double feature
bb nf Dance In The Vampire Bund Video: AVC | Audio: TrueHD 2.0 | AR: 1.78:1 | Funimation
bb nf Daughters Of Darkness Video: AVC | Audio: DTS-HD MA 1.0 | AR: | Blue Underground
bb nf Deep Rising Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Mill Creek | part of the Deep Rising / The Puppet Masters double feature
bb nf Dial M For Murder 3D Video: AVC | Audio: DTS-HD MA mono | AR: 1.78:1 | Warner
bb nf Die Hard Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf District B13 Video: MPEG-2 | Audio: DTS-HD | AR: 2.35:1 | Magnolia
bb nf Divergent (Rental Edition) Video: | Audio: | AR: | | differs from retail edition with lower PQ
bb nf Divide, The Video: | Audio: | AR: | Starz / Anchor Bay
bb nf Doctor Strange: The Sorcerer Supreme Video: AVC | Audio: DTS-HD MA (7.1) | AR: 1.77:1 | Lionsgate
bb nf Dr. Strangelove Video: AVC | Audio: TrueHD | AR: 1.66:1 | Sony
bb nf Dredd Video: AVC | Audio: DTS-HD MA 7.1 | AR: 2.40:1 | Lionsgate
bb nf Eat Pray Love Video: | Audio: | AR: |
bb nf Eating Raoul Video: | Audio: | AR: | Criterion
bb nf Edward Scissorhands Video: MPEG-2 | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Enemy Video: AVC | Audio: | AR: |
bb nf Equilibrium (CA import) Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Alliance
bb nf Eragon Video: MPEG-2 | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Escape from the Planet of the Apes Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Fox
bb nf Ferngully: The Last Rainforest Video: | Audio: | AR: | Fox
bb nf Fighter, The (2010) Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Paramount
bb nf Firefly - The Complete Series Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Fox
bb nf Fly, The (1958) Video: | Audio: | AR: | Fox
bb nf Flypaper Video: | Audio: | AR: | IFC
bb nf Foreign Correspondent Video: AVC | Audio: | AR: | Criterion
bb nf Forgetting Sarah Marshall Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Universal
bb nf Freezing: The Complete Series Video: AVC | Audio: TrueHD | AR: 1.78:1 | Funimation
bb nf Friday the 13th (2009) Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | New Line
bb nf Galaxy Of Terror Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.78:1 | Shout Factory
bb nf Ganges Video: VC-1 | Audio: DTS-HD HR 5.1 | AR: 1.78:1 | BBC
bb nf Garden State Video: | Audio: | AR: | Fox
bb nf General, The Video: AVC | Audio: DTS-HD MA | AR: 1.33:1 | Kino Video
bb nf Ghostbusters Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Godzilla (1998) (4K) Video: AVC | Audio: | AR: | Sony
bb nf Going The Distance Video: | Audio: | AR: |
bb nf Gojira Video: | Audio: | AR: | Criterion
bb nf Gomorrah Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Criterion
bb nf Gone Baby Gone Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Grace Video: VC-1 | Audio: PCM | AR: 2.35:1 | Starz / Anchor Bay
bb nf Halloween (1978) Video: AVC | Audio: PCM | AR: 2.35:1 | Starz | 2007 master
bb nf Halo Legends Video: VC-1 | Audio: DD 5.1 | AR: 1.78:1 | Warner
bb nf Hanna Video: | Audio: | AR: | Universal
bb nf Harold & Kumar Go to White Castle Video: VC-1 | Audio: DTS-HD MA | AR: 1.85:1 | New Line
bb nf Harpoon: Whale Watching Massacre Video: | Audio: | AR: |
bb nf Hatchet Video: AVC | Audio: | AR: | Starz / Anchor Bay
bb nf Hellboy: Sword Of Storms / Blood & Iron Video: VC-1 | Audio: DD 5.1 | AR: 1.78:1 | Starz / Anchor Bay
bb nf Hero Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Disney
bb nf Heroes: Season One Video: VC-1 | Audio: DTS-HD MA | AR: 1.78:1 | Universal
bb nf Horrible Bosses Video: | Audio: | AR: | Warner
bb nf Hostel (UK Import) Video: AVC | Audio: TrueHD | AR: 2.35:1 | Sony
bb nf Humbling, The Video: | Audio: | AR: | Millennium
bb nf Hung: The Complete First Season Video: | Audio: | AR: | HBO
bb nf I Know What You Did Last Summer Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf Igor Video: | Audio: | AR: |
bb nf In the Line of Fire Video: AVC | Audio: TrueHD | AR: 2.40:1 | Sony
bb nf In the Mood For Love Video: | Audio: | AR: | Criterion
bb nf Incredible Burt Wonderstone, The Video: | Audio: | AR: | New Line / Warner
bb nf Invisible, The Video: AVC | Audio: PCM | AR: 2.35:1 | Disney
bb nf James And The Giant Peach Video: AVC | Audio: DTS-HD MA | AR: | Disney
bb nf Jeff Dunham: Controlled Chaos Video: | Audio: | AR: | Comedy Central
bb nf Killer Nun Video: | Audio: | AR: | Blue Underground
bb nf Killing Season Video: | Audio: | AR: | Millennium Media
bb nf King Arthur Video: AVC | Audio: PCM | AR: 2.40:1 | Buena Vista
bb nf Knight's Tale, A Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Koyaanisqatsi: Life Out of Balance Video: AVC | Audio: | AR: | Criterion
bb nf Leaves Of Grass Video: AVC | Audio: | AR: | First Look Studios
bb nf Logan's Run Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Looney Tunes Mouse Chronicles: The Chuck Jones Collection Video: AVC | Audio: DD mono | AR: 1.33:1 | Warner
bb nf Lord Of The Rings:Two Towers, The Video: VC-1 | Audio: DTS-HD MA | AR: 2.40:1 | Warner
bb nf Lost Weekend, The (UK) Video: AVC | Audio: DTS-HD MA 2.0 | AR: 1.33:1 | Eureka | Region B only
bb nf Master and Commander: The Far Side of the World Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox
bb nf Meet The Parents Video: | Audio: | AR: |
bb nf Million Dollar Baby Video: VC-1 | Audio: DD | AR: 2.35:1 | Warner
bb nf Miracle On 34th Street (1947) Video: AVC | Audio: DTS-HD MA | AR: 1.37:1 | Fox
bb nf Mission Impossible 2 Video: MPEG-2 | Audio: DD | AR: 2.35:1 | Paramount
bb nf Monster House Video: MPEG-2 | Audio: PCM | AR: 2.35:1 | Sony
bb nf Monster's Ball Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Monty Python's Life of Brian Video: AVC | Audio: TrueHD/PCM | AR: 1.85:1 | Sony
bb nf Mule, The Video: AVC | Audio: | AR: | Millennium
bb nf Music and Lyrics Video: VC-1 | Audio: DD | AR: 1.85:1 | Warner
bb nf New Police Story Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Lionsgate
bb nf Night of the Hunter, The Video: AVC | Audio: | AR: | Criterion
bb nf Nightbreed: Director's Cut Video: AVC | Audio: | AR: | Scream Factory
bb nf Office Space Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Fox
bb nf Olympus Has Fallen Video: AVC | Audio: DTS-HD MA | AR: 2.40:1 | Sony
bb nf Omega Man, The Video: VC-1 | Audio: DD1.0 | AR: 2.35:1 | Warner
bb nf Ong Bak 3 Video: | Audio: | AR: |
bb nf Only God Forgives Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | Starz / Anchor Bay
bb nf Paris, Texas Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Criterion
bb nf Pelican Brief, The Video: VC-1 | Audio: TrueHD | AR: 2.40:1 | Warner
bb nf Person of Interest: Season Three Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Planet Of The Apes 2: Beneath the Planet of the Apes Video: AVC | Audio: DTS-HD MA | AR: 2.35:1 | Fox | only found as part of the box set
bb nf Priceless Video: VC-1 | Audio: TrueHD | AR: 2.35:1 | First Look Studios
bb nf Project X Video: AVC | Audio: DTS-HD MA | AR: 1.78:1 | Warner
bb nf Puncture Video: | Audio: | AR: | Millennium Media
bb nf Quadrophenia Video: | Audio: | AR: | Criterion
bb nf Queen, The Video: VC-1 | Audio: PCM | AR: 1.85:1 | Buena Vista
bb nf Raging Bull Video: AVC | Audio: DTS-HD MA | AR: 1.85:1 | MGM
bb nf
