blue ray burning software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-30-2012, 06:57 AM - Thread Starter
micaaronfl's Avatar
Hi all,
Can anyone recommend a blu ray burning software? any good freeware? i am currently using make .mkv 30 day trial. i think 50 bucks is a little pricey for something i will hardly use.
micaaronfl is offline
post #2 of 3 Old 12-30-2012, 07:15 AM
nathanddrews's Avatar
Quoted: 349 Post(s)
Liked: 307
MakeMKV is not Blu-ray "burning" software, it is a software tool designed to copy (rip) the audio and video streams of DVD and Blu-ray discs into MKV containers. Are you trying to create (burn) Blu-ray discs or are you trying to copy the contents of (rip) Blu-ray discs?
As far as I know, nothing free is any good.
nathanddrews is offline
post #3 of 3 Old 12-30-2012, 09:49 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 284 Post(s)
Liked: 3948
There's a whole thread dedicated to BD burning: http://www.avsforum.com/t/815296/my-blu-ray-movie-burning-experiences/0_50
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
Closed Thread Blu-ray Software
