Zodiac which version? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-02-2013, 08:14 AM - Thread Starter
Mojogypson's Avatar
Quoted: 49 Post(s)
I notice there are 2 versions in Amazon.
One is:
Run Time: 158
Aspect Ratio: 1.77:1
2 discs
$11
The other is a Director's cut (All region Import)
Run Time: 162
Aspect Ratio: 2.40:1
2 discs
$22
Which one is the preferred?
same transfer?
Mojogypson is offline
post #2 of 4 Old 03-02-2013, 08:52 AM
Morpheo's Avatar
Quoted: 1054 Post(s)
Liked: 897
Apparently amazon got the specs wrong (once again...) the $11 version is the same director's cut as before, only it's a reissue, I doubt it's a new transfer though. If you look at the screenshots it does have the new UPC (I have the previous edition with the other UPC) but the specs are the same. 162mn director's cut, with Dolby TrueHD. I wouldn't bother with the import then. I'm think the 1.77:1 AR is a mistake.
__________
Nicolas.
"Music expresses that which cannot be said and on which it is impossible to be silent."- Victor Hugo.
Morpheo is offline
post #3 of 4 Old 03-07-2013, 06:37 PM
tenthplanet's Avatar
Location: North of Mexico, South of Oregon, West of desert
Quoted: 946 Post(s)
Liked: 904
This sounds like the Warner's reissuing the original Parmount Home Video title. Get it the price is right. Also the import is Dolby Digtal not True HD. I got the import when the domestic copies were out of print and prices were way up there. And yes, some of Amazon's info is wrong.
"Oooh a puzzle box, I love puzzles"/ "Are you familiar with 'The Lament Configuration"/ "Actually I'm lousy at puzzles..."
tenthplanet is offline
post #4 of 4 Old 03-08-2013, 08:03 AM
raoul_duke's Avatar
Liked: 33
Yes, it's the exact same release.
raoul_duke is offline
Reply Blu-ray Software
