How can you tell if Ultraviolet code is in HD or SD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-21-2013, 05:39 PM - Thread Starter
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
Is there any possible way to find out if a UV code is in HD or standard def? I don't use them and want to start selling.
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #2 of 8 Old 03-21-2013, 06:29 PM
cinema13's Avatar
Quoted: 177 Post(s)
Liked: 139
They don't tell you. In the beginning, it was SD...but now, if it's included on an HD purchase, they all seem to be HD. At least that's the case with all of the ones I've gotten. Of course, I've never used them but I do check them once applied to see..
cinema13 is offline
post #3 of 8 Old 03-21-2013, 07:08 PM
Phantom Stranger's Avatar
Quoted: 442 Post(s)
Liked: 335
It depends on what studio released the movie and from what format(Blu-ray or DVD) the UV code came from. Universal frequently only gives out an SD version for their UV codes, even if the code came from a Blu-ray package. The others studios largely only give out HD digital copies for UV codes from a Blu-ray package. For anyone wanting to dump their UV codes, I will accept them.smile.gif
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
post #4 of 8 Old 03-22-2013, 02:11 PM
Kris Deering's Avatar
Quoted: 2222 Post(s)
Liked: 3416
Really? I can't think of a single UV code I've got from Universal that is SD, all of them have been HD with BD releases. The only studio that I notice that gives out SD codes is Warner, and even they are hit or miss. Disney still gives out SD digital copies for iTunes for all their movies, which is annoying as crap.
My Home Theater
Kris Deering is offline
post #5 of 8 Old 03-22-2013, 07:29 PM
Quoted: 442 Post(s)
Liked: 335
You must not be purchasing any of Universal's catalog titles or their new releases from last year. I am only referring to UV redemption on Amazon, Vudu or Flixster. I don't really use iTunes, so my knowledge is very limited for that service provider. I do believe that Universal has partially started changing their ways on this, the latest UV codes from Universal found at Walmart do redeem in HD.
post #6 of 8 Old 03-22-2013, 11:46 PM
Liked: 3416
I've been redeeming UV from the beginning including the majority of Universals day and date titles. Most are HD in my library. Early on I used Flixster but I typically use VUDU for my redemptions now.
My Home Theater
post #7 of 8 Old 03-23-2013, 07:57 AM
Mr.G's Avatar
Quoted: 767 Post(s)
Liked: 442
When you're talking about UV code redemption on VUDU I think it's important to note that the movies are HDX not HD. You'll get HD elsewhere which are lower quality IMO. I know most people here are using HD as a catch-all for high definition versus SD.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #8 of 8 Old 03-23-2013, 09:26 AM
Quoted: 442 Post(s)
Liked: 335
Universal did start getting better about the practice, but almost all of their codes before a certain date were redeeming in SD only on Vudu:
Paul
8 Mile
Scarface
Your Highness
the list goes on and on...
Basically any UV code from a Blu-ray release before the latter half of 2012, only redeemed in SD.
Reply Blu-ray Software
