Question about Blu-Ray versions: Which to buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-23-2013, 12:35 AM - Thread Starter
limp003's Avatar
After looking for new "reference quality" blu-rays and looking though the PQ Tier thread (http://www.avsforum.com/t/1168342/the-new-pq-tier-thread-for-blu-ray-rankings) a question came up. Hopefully someone can answer this for me. If a blu-ray is considered to be (or near) reference quality in all aspects does this only apply to that specific version? For example I notice some blu-rays get released then re-released a few years later in a "special edition" or "extended edition" and then re-released in a "bundle." Lets say one is released in 2005 then re-released in 2010 in a "collectors edition" or whatever, so is the reference quality version to buy the 2005 release or the 2010 re-release?? Or does the blu-ray disc it self remain "reference quality" no matter how many times it is released? Hope I haven't confused anyone and my question makes sense.
The only example I can think of are the blu-rays that are "bundled" like this (http://www.amazon.com/Action-Collection-Tomorrow-Terminator-Blu-ray/dp/B001U4186K/ref=br_lf_m_1000232811_1_1_img/178-3709440-4880652?_encoding=UTF8&m=ATVPDKIKX0DER&s=movies-tv&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=1QCQ6C0DWY2WCFC5R7EN&pf_rd_t=1401&pf_rd_p=477598651&pf_rd_i=1000232811) and so on.
limp003 is offline
post #2 of 4 Old 03-23-2013, 10:06 PM
JSUL's Avatar
Liked: 41
I try and read reviews that provide specific details on PQ, aspect ratio, and source material used for the transfer before making a buying decision.
All blurays are not created equal unfortunately.
You can read numerous accounts of poor transfer, incorrect framing, incorrect aspect ratios... Just to name a few.
There are many forum discussions on any of these topics, which add to the fun when buying a new film on bluray to add to your collection.
JSUL is offline
post #3 of 4 Old 03-25-2013, 01:27 AM - Thread Starter
limp003's Avatar
Oh wow. I didn't know so much went into it. The information you provided has spawned much intrigue. Do you have any specific sites you frequent that you would like to share? Thanks in advance.
limp003 is offline
post #4 of 4 Old 03-25-2013, 10:36 AM
JSUL's Avatar
Liked: 41
Pick a film title you want to check out....google for example:
Dark Knight Rises bluray review
Then simply open up the threads and read the info.
Also: Dark Knight rises bluray customer reviews
Enjoy your search...it can be fun, but also quite troubling.....but interesting.
JSUL is offline
Reply Blu-ray Software
