LOTR Extended Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-07-2013, 03:24 AM - Thread Starter
somelogin's Avatar
Someone can't get LOTR extended edition blu rays to play in their blu ray player. Any likely reason other than maybe needing some sort of firmware update onn their player? I really thought it was updated, but maybe not.
somelogin is offline
post #2 of 4 Old 04-07-2013, 10:45 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Haven't any problems with mine nor heard of any. Might help to know what the specific player in question is and then look for issues with that particular player perhaps. Quick google got this http://forum.blu-ray.com/showthread.php?t=176189
lovinthehd is offline
post #3 of 4 Old 04-08-2013, 03:24 AM
LexInVA's Avatar
Quoted: 674 Post(s)
Liked: 279
Check your discs. The first copy I bought had discs that were messed up and scratched at the packing stage. Had to swap it out disc-by-disc with a few other sets to get a set that was playable.
LexInVA is online now
post #4 of 4 Old 04-08-2013, 05:48 PM - Thread Starter
somelogin's Avatar
I'll tell them to check it out if they haven't. As far as the player, though, although I don't know the specific one, it's a Samsung from 2010, I believe, and these discs came out in 2011, so it's definitely not a player you'd think would have issues with a soon after released set.
Reply Blu-ray Software
