AVS Can't-Wait Special—"Mastered in 4K" Blu-Ray Releases - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
Old 02-10-2014, 03:11 AM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 334
Originally Posted by helvetica bold View Post
Geoff which test pattern are you using for x.v.Color? I have the 2nd edition disk and I would love to test the PS4 on my new Sony display. I thought there wasn't a test pattern
ftor xvColor. But if there is I would love to know.
I forget the name of it, I'll check it for you later.
Geoff D is offline
Old 02-10-2014, 07:36 AM
helvetica bold's Avatar
Quoted: 395 Post(s)
Liked: 243
Thanks Geoff
It here's a thread on BluRay.com where Stacy Spears posts and she said you can't test for xvYCC on the disk.
Below is her response.
"xvColor is not officially part of the BD Spec, so there was no way, at the time of authoring, to signal it.
Most displays have xvColor disabled in the TVs UI if its not present. You can check and see if they enable it when you are playing a know title that claims to support it. At least my Panasonic VT20 was like that."
helvetica bold is online now
Old 02-10-2014, 12:49 PM
Milt99's Avatar
Quoted: 239 Post(s)
Liked: 247
Thanks Geoff
FYI, Stacey is a "He".
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is offline
Old 02-10-2014, 02:19 PM
Quoted: 395 Post(s)
Liked: 243
HA, thanks Milt!!
noted!
Old 02-10-2014, 03:02 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 334
Thanks Geoff
I could be wrong, but I get the impression from Stacey's response that the test pattern itself is genuine but it doesn't 'signal' the display in any way to tell it that it's passing xv colour. I have to actually turn it on in my TV menu to get the xvYCC pattern to display properly.
BTW it's under Advanced Video -> Evaluation -> Clipping.
helvetica bold likes this.
Geoff D is offline
Old 02-10-2014, 05:50 PM
inspector's Avatar
Quoted: 36 Post(s)
I just watched the newest "ROBOCOP" and I have to tell you that it is a step up in clarity, but is it worth the $8 to do so??? Yes, it is and it will fit perfectly with all the other copies of the same movie...the only one I don't have anymore is the LD...time ,to move on, as they say!
...finally retired and spending time in my HT!!!
Equipment consists of: Epson 9500 UB Projector(Avical ISFd);110" 16x9 JKP Affinity Screen;Panny BD30 Player,Tosh HDA1 Player;Definitive Speakers (Center, Towers, Rears);Earthquake P12 sub;Onkyo 608 A/V Receiver;Nevo Q50 Remote;TWC-HD Cable Box;5 Bello chairs;Coaire Mini-split A/C.
inspector is offline
Old 02-10-2014, 07:34 PM
Quoted: 395 Post(s)
Liked: 243
Thanks so much Geoff! I'll give it a try. I'll manually set my W9 to xvColor. I have Captain Phillips to watch on my PS4 but don't know if if will output xvColor. Even if it does the difference might not be noticeable.
Edit: I ran the clipping pattern you are correct! PS4 will output x.v Color!
Unfortunately the Xbox one will not. In fact the Xbox one video output is a mess.
When RGB full is selected it clips the color range. If I'm describing it correctly.
All the boxes were solid viewing that pattern. If I set it to limited then it displays correctly.
That makes no sense to me. PS4 worked perfectly with RGB full.
Old 02-15-2014, 05:58 PM
Phantom Stranger's Avatar
Quoted: 384 Post(s)
Liked: 280
The Smurfs 2 Blu-ray, mastered in 4K by Sony, is possibly the best-looking Blu-ray I've ever seen.eek.gif And trust me, I have seen too many to count. I have never seen live-action video blended so well with CGI, including Avatar. This is the definition of pure eye candy.
David Susilo likes this.
AVSforum's Blu-ray Picture Quality Rankings (Updated through May 30, 2016)
Phantom Stranger is offline
Old 02-19-2014, 06:30 PM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
If Smurfs 2 had Kate Upton and Scarlett Johansson naked and making out with each other there still wouldn't be enough eye candy to make me watch the rest of it.
Andreas21 likes this.
ElJimador is offline
Old 02-20-2014, 07:49 AM
Zenyatto's Avatar
Quoted: 27 Post(s)
Duly noted...
Zenyatto is offline
Old 02-20-2014, 08:09 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
To draw it into an actual point though, it would easier to get excited about 4k (both true 4k and these Mi4k titles) if more of these were actual, you know, good movies. Glory, sure. Captain Phillips, Taxi Driver. Most of these others are just garbage though. This is seriously how Hollywood wants to turn people on to this new format? By using it to squeeze a few more bucks out of a bunch of CGI craptaculars and pointless remakes?
Old 02-20-2014, 09:41 AM
Josh Z's Avatar
Quoted: 2146 Post(s)
Liked: 1442
This is the same thing Sony did with SuperBit DVDs. The mentality from the studio is that the new branding is a way to move some copies of properties that have otherwise gone stale. How else could Sony make any money off Johnny Mnemonic? Nobody's going to buy that title for the movie itself, but some suckers might pay to check out the whiz-bang "SuperBit" thing.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Old 02-20-2014, 09:42 AM
Josh Z's Avatar
Liked: 1442
Who said anything about watching the rest of it? That's what chapter stops are for! smile.gif
Josh Z
Josh Z is offline
Old 02-21-2014, 08:54 AM
Taranteacher's Avatar
Liked: 92
Taranteacher is offline
Old 04-23-2014, 05:55 AM
Zenyatto's Avatar
Quoted: 27 Post(s)
I ordered Spider-man 3 4K which was released yesterday. I am hoping Walmart sends me the correct one.
Zenyatto is offline
Old 04-27-2014, 10:49 AM
Kascnef82's Avatar
Liked: 43
I'd like to see Sony do a 4k version of "The Fifth Element" for BD release. The first release i heard had issues but the reissue fixed it. For the film's 20th anniversary they should add tons of extras including the marketing campaign used to advertise the film not to mention the french version of the film.
Kascnef82 is offline
Old 04-27-2014, 11:36 AM
homogenic's Avatar
How does the French version differ from the American release?
homogenic is offline
Old 04-27-2014, 07:58 PM
nathanddrews's Avatar
Quoted: 349 Post(s)
Liked: 309
The recent Japanese re-release might be the one to get. It uses the newer Gaumont transfer with a very healthy bit rate. No edge enhancement, but some brightness boosting... Check the Fifth Element thread for comparisons.
nathanddrews is offline
Old 04-27-2014, 08:06 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 04-27-2014, 11:20 PM
homogenic's Avatar
Originally Posted by David Susilo View Post
All the best Blu-rays have had their levels adjusted. It's standard practice.
Old 04-28-2014, 06:11 AM
Quoted: 349 Post(s)
Liked: 309
While I agree with this, the improvements of the transfer are significant.
Old 05-06-2014, 11:27 AM
Zenyatto's Avatar
Quoted: 27 Post(s)
¡I got the right one!
Zenyatto is offline
Old 05-06-2014, 01:09 PM
MSchu18's Avatar
Quoted: 166 Post(s)
Liked: 359
why waste your money on that tripe.
My Name is Nobody...
Klipsch x11i - Klipsch x20i - Oppo HA2
Pioneer SC85 - Bel Canto REF 500M
Klipsch La Scala II - Klipsch Cornwall/Crites/Aletheia Audio - Klipsch RC64II - SW-115
Wyred 4 Sound DAC2 DSDse - OPPO BDP-93
Samsung PN64D8000
MSchu18 is offline
Old 05-06-2014, 03:26 PM
Quoted: 612 Post(s)
Liked: 584
my home theatre
Old 05-10-2014, 12:48 PM
Super Moderator
teachsac's Avatar
Quoted: 659 Post(s)
Liked: 991
Ok. Back on track.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Oppo UDP-203 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 05-10-2014, 05:55 PM
AVfile's Avatar
Quoted: 244 Post(s)
Liked: 126
Any improvement?
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
Old 05-13-2014, 03:07 PM
Big C's Avatar
Quoted: 62 Post(s)
Liked: 38
My players have color space choices of YCbCr4:2:2, YCbCr4:4:4, RGB 16-235, and RGB 0-255. Also, some of my players have Deep Color choices of Off, 30 Bit, and 36 Bit. What color space and color bitrate is the Mastered in 4K series recorded at?
Big C is offline
Old 05-13-2014, 03:41 PM
LexInVA's Avatar
Quoted: 529 Post(s)
Liked: 219
The information about the Mi4K titles is rather sketchy but Sony claims that they only look proper when used with current Sony Blu-Ray and HDTV products as the proprietary decoding techniques are supposedly baked into the firmware of those products and activated when using the "Cinema" picture settings. Boolean logic - and some earlier blurbs about the Sony Mi4K products from last year - suggest that they work as intended with any Blu-Ray player and TV that supports "xvycc", so I guess that means you should use the "Auto" setting if you have one. If you don't have an "Auto" choice, you just play around with the settings on your TV and player, and settle on whatever looks best to you.
LexInVA is online now
Old 05-14-2014, 12:43 PM
Fanboyz's Avatar
Quoted: 510 Post(s)
Liked: 160
XVycc is Deep Color right?
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
Old 05-14-2014, 05:12 PM
Geoff D's Avatar
Quoted: 303 Post(s)
Liked: 334
No they're completely different things. XV colour relates to the colour gamut, Deep Colour relates to bit depth.
Geoff D is offline
Blu Ray Movies
