Inception Steel box question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-01-2013, 07:06 AM - Thread Starter
bokes's Avatar
Quoted: 13 Post(s)
I picked this up from BB for $9.99
When I opened the box- there is no booklet.
I mention this because the inside cover has booklet clips.
Should there a book with this version?
bokes is offline
post #2 of 4 Old 05-01-2013, 07:25 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 799
I have this steelbook as well, there's no booklet. The clips are just part of the case, just in case... wink.gif
__________
Nicolas.
"Music expresses that which cannot be said and on which it is impossible to be silent."- Victor Hugo.
Morpheo is offline
post #3 of 4 Old 05-01-2013, 12:44 PM
raoul_duke's Avatar
Liked: 32
Booklets? You're joking. Lucky if we get a pamphlet included, these days.
raoul_duke is offline
post #4 of 4 Old 05-01-2013, 02:32 PM
Josh Z's Avatar
Quoted: 2146 Post(s)
Liked: 1442
With SteelBooks, I usually fold the cardboard backer and store it inside the case under those clips.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
Reply Blu-ray Software
