Blu-ray Burner - High Quality Production of HD Discs with editing software - AVS Forum | Home Theater Discussions And Reviews
Old 05-05-2013, 12:29 AM - Thread Starter
Noobavs1434's Avatar
Could do with the assistance of others out there.
I am looking to either hire someone to burn raw footage to blu-ray discs or alternatively obtaining a blu ray burner that will produce very high quality discs that are not region locked and can be played on a Mac laptop.
The footage is currently 4 hours long and is in .MOV format with the codec in Apple ProRes 422 (LT) Linear PCM Timecode
The File Size is over 128GB
Also what kind of software would I need to split a 4 hour movie into segmented parts to put on separate blu rays so that the quality of the film is not impacted due to high compression rates?
Any help with this would be fantastic
Noobavs1434 is offline
Old 05-05-2013, 05:40 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 4099
A whole thread on burning BDs: http://www.avsforum.com/t/815296/my-blu-ray-movie-burning-experiences/50_50#post_10020318
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
