Blu Rays with incorrectly encoded for RGB PC Levels. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 103 Old 08-06-2014, 11:34 AM - Thread Starter
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
They are
LG OLED65B6P. Klipsch: RF82, RC62, RS52, RB61, RP-140SA. SVS PB-U13. Denon 6300H. Oppo 103D. Oppo UPD 203.
Fanboyz is offline
post #92 of 103 Old 08-06-2014, 12:53 PM
EddieLarkin's Avatar
What makes you think that? Looks like plenty of true black to me:
http://www.blu-ray.com/movies/screen...84&position=13
http://www.blu-ray.com/movies/screen...439&position=1
http://www.blu-ray.com/movies/screen...440&position=6
I just checked my Destoroyah disc and sure enough, switching to PC levels causes shadow detail to vanish.
EddieLarkin is offline
post #93 of 103 Old 09-20-2014, 04:00 AM
The new Yojimbo & Sanjuro discs from the BFI (which annoyingly use transfers that are otherwise far superior to what Criterion used).
post #94 of 103 Old 09-21-2014, 10:47 AM
norliss's Avatar
Interesting thread.
Severin's "Santa Sangre" looks like a candidate of this error, to me. The small amount of letterboxing (it's 1.85:1) look milky grey rather than black...
norliss is offline
post #95 of 103 Old 09-21-2014, 11:31 AM
That definitely appears to be the case when you compare caps against the UK edition:
UK: http://www.blu-ray.com/movies/screen...786&position=5
US: http://www.blu-ray.com/movies/screen...178&position=3
UK: http://www.blu-ray.com/movies/screen...786&position=8
US: http://www.blu-ray.com/movies/screen...178&position=6
I'd say the US version is actually superior in every other regard though. Probably best to have that one and just correct for it.
post #96 of 103 Old 09-21-2014, 07:41 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Originally Posted by Fanboyz View Post
I'm making a list for titles sent to market with RGB PC Levels as opposed to RGB Video Level standard. This results in blacks never dipping below medium gray. As of yet no recalls have been made.<br><br>
*<b>The Arrival</b>: Lionsgate, 2009 US<br>
*<b>Maniac</b>: Blue Underground. 2010 US<br>
*<b>Double Impact</b> 20th Century Fox, 2012 US<br>
*<b>Margin Call</b> Lionsgate, 2011 US<br>
*<b>All Ladies Do It</b> Arrow Video, 2013 UK<br>
*<b>The Key</b> Arrow Video, 2013 UK<br>
*<b>Frankenstein's Army</b> MPI, 2013 US<br>
*<b>Dawn of the Dead (U.S. Theatrical &amp; Extended Cannes cuts)</b> Happinet, 2013 JP
The Godzilla movies that were not released as part of the TOHO SONY Collection (the latter look quite good from what I've peeked at). The two they got separate releases are awful. The levels are way off it looks like they fit things between range 80 and 130 or something .
skibum5000 is offline
post #97 of 103 Old 09-21-2014, 07:49 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Almost all Japanese masters are encoded for PC Level...
Not at all. In fact, some seem to be encoded in double or triple reverse of that! They don't store black as 0 (as with PC levels) or even as 16 (as with video levels) but as 32 or even 48 like with those dumb two Godzilla releases.
post #98 of 103 Old 09-21-2014, 07:53 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Originally Posted by Alkaline View Post
You forgot to stick out your tongue and say nanny-boo-boo! That's important, you know.
First, I will first admit for the record that I have gotten my threads confused. I read back through this one and see there is little to no discussion of JP releases with regard to black level disparity. No, that discussion transpired on another thread--I think one dedicated to a specific JP release (a Godzilla film maybe?). I'll have to look for it. That said, I'm not a total mouthbreather and understand that the ntsc-j black level disparity SHOULDN'T apply to digital tv standards or digital media, hd or otherwise. But what I do know is that some JP dvd/bd releases (as with some north american releases of JP content) are plagued with an anemic black level that requires a small brightness adjustment to look right but an otherwise correct color space, which yes, I still suspect some are mistaking for a completely incorrect color space--as discussed here--in the case of some releases. Whether it's ntsc-j black level mistakenly applied or unnecessary compensation for such deliberately applied, I've almost ceased caring at this point. Though irritating it's a trivial annoyance in the grand scheme with an easy fix.
It is NOT a trivial fix. The two Godzilla titles in reference are complete mess. Also some people have programmed internal LUTs and you can't just change the brightness dial (which does NOT fix it anyway). One of the titles has so little difference between black and white signal that it seems like it is maybe 5bits per channel instead of near 8! The blacks are bright gray and the brights are not proper either, they are weak. Everything about them violates any known BD mastering standard.
post #99 of 103 Old 09-21-2014, 07:55 PM
skibum5000's Avatar
Quoted: 48 Post(s)
Liked: 49
Originally Posted by EddieLarkin View Post
Do you mean to say the Sony Toho Godzilla discs (as in, the new Blu-rays) have an incorrect colour space? I don't believe that's the case.
Agreed. The SOny TOHO ones are the ones that get it right, when it comes to Godzilla.
post #100 of 103 Old 09-22-2014, 10:42 PM
Alkaline's Avatar
Sigh. Actually, in some (many) cases the fix is, in fact, highly trivial. That would be because there are two issues afoot with the various releases plagued with weak blacks--some are authored with full-on incorrect colorspace as discussed here, others have correct colorspace save for a elevated gamma/black level, the latter case being easily remedied in precisely the way I described...well for those lowly plebeians without programmed internal LUTs anyhow. Good chat!
Alkaline is offline
post #101 of 103 Old 10-25-2014, 06:12 PM
The Burmese Harp from Masters of Cinema
Vengeance is Mine from Masters of Cinema
All 3 films in the Herschell Gordon Lewis Blood Trilogy set from Image.
post #102 of 103 Old 10-29-2014, 09:07 AM - Thread Starter
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
Rumble In the Bronx from StudioCanal.
Fanboyz is offline
post #103 of 103 Old 12-21-2014, 03:03 PM - Thread Starter
Fanboyz's Avatar
Quoted: 506 Post(s)
Liked: 158
I added the Twilight Samurai.
Fanboyz is offline
Reply Blu-ray Software
