The Hobbit: The Desolation of Smaug Blu-ray announced - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 04-21-2014, 06:50 PM
R Harkness's Avatar
Quoted: 2115 Post(s)
Liked: 1823
Is anyone else experiencing the pop up menu problem with this title? That is: the pop up menu stays on the bottom of the screen through the whole movie and you can't get rid of it.
I have this issue and not only is the pop up menu stuck on screen, I can't fast forward or rewind on the title. I have the Oppo BDP-93 blu ray player.
I see from another forum that others have experienced it. Anyone know of solution? is it Blu-Ray player based, or a defect in the these new Blu-Rays?
Wow, this title has got amazingly few posts.
R Harkness is online now
post #32 of 43 Old 04-21-2014, 09:28 PM
blastermaster's Avatar
Quoted: 500 Post(s)
Liked: 629
Just watched it. I'm not a die hard Tolkien fan, so I wasn't bothered by any inconsistencies or whatnot. I found it to be very enjoyable. I use full FI mode on my projector for all my 3D since it makes it easier to resolve and it does give it that sped up look, yes, but it makes action way less nauseating. That said, I thought the 3D in this movie was fantastic - like looking through a window. FWIW, I haven't had the problem of menu popup...
blastermaster is offline
post #33 of 43 Old 04-22-2014, 08:26 AM
Stinky-Dinkins's Avatar
Ugh, how obnoxious. Is your firmware up to date? Are you watching the regular version of the 3D version?
When does it occur, right away? Let me know and I'll check. I have the same BD player and the BD (haven't watched it yet.)
The only time I've ever had that problem (well, a similar one at least) was with the original release of Sunshine.The PiP commentary extra popped up in the corner of the screen and couldn't be disabled. It ended up having to be recalled to fix the problem.
Stinky-Dinkins is offline
post #34 of 43 Old 04-22-2014, 02:15 PM
Just to follow up on that, I popped the 2D Blu into my BDP 93. I let it play for a couple minutes, I skipped forward a couple chapters, and i used FF and rewind. it played perfectly fine, no pop up menu issues to speak of.
I'm using the latest firmware: BDP9x-79-0910. You're probably using a firmware version that's way out of date.
post #35 of 43 Old 04-22-2014, 04:24 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3036
FWIW, 2D plays perfectly on the OPPO 83.
oink is offline
post #36 of 43 Old 04-22-2014, 06:02 PM
R Harkness's Avatar
Liked: 1823
Thanks...weird stuff. The work around has been pressing "stop" and then choosing "return to previously viewed scene," at which point the menu disappears.
post #37 of 43 Old 04-23-2014, 08:28 AM - Thread Starter
Rod#S's Avatar
Quoted: 387 Post(s)
Liked: 55
I absolutely love this, have watched it 3 times since getting it. I have a Denon DVD-A1 and the 2D version plays fine for me, no issues with menu pop ups. It also plays fine on a PS3 as well. So it might be a 3D disc issue or player specific perhaps.
Rod#S is offline
post #38 of 43 Old 04-23-2014, 11:02 AM
General Kenobi's Avatar
Quoted: 369 Post(s)
Liked: 669
I'd like to see this but really don't feel like sitting through the first one after what I'd read about it. Can I jump into this and pretty much get the jist of what what is going on without having seen the last film?
Kenobi's 31 Days of Horror:
2012
2011
2010
2009
General Kenobi is offline
post #39 of 43 Old 04-23-2014, 04:13 PM
oink's Avatar
Liked: 3036
Yeah, I think so.
Did you read the book?
oink is offline
post #40 of 43 Old 04-23-2014, 04:24 PM
Quoted: 369 Post(s)
Liked: 669
Originally Posted by oink View Post
Yeah, I think so.
No, they don't look good on my HT.
Toe, Schils and lordcloud like this.
2012
2011
2010
2009
post #41 of 43 Old 04-24-2014, 12:12 AM
oink's Avatar
Liked: 3036
oink is offline
post #42 of 43 Old 04-26-2014, 03:39 PM
metalsaber's Avatar
Quoted: 1029 Post(s)
Liked: 844
Anyone else notice lip sync issues in the movie? I was watching it on my ps4 which has never had issues prior.
metalsaber is online now
post #43 of 43 Old 11-26-2014, 07:01 AM
spaceflows's Avatar
Was having the same issue with the same Disc & BD player. Upgrading the firmware did the job. Hope this helps.
spaceflows is offline
Reply Blu-ray Software
