Beware Speed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 48 Old 11-17-2006, 03:58 PM - Thread Starter
billymerritt's Avatar
Quoted: 35 Post(s)
Liked: 27
Originally Posted by Roger Mathus
SPEED is the first Blu-ray disc that I have encountered that will not load. It tries then the tray opens. I have tried cleaning and re-boot of the Samsung player. No help. I have the latest firmware and five other Fox titles and all previous purchases load and play fine.
Anyone else having problems with SPEED?
YES!
Also Speed won't play for me either, tried unplug, cleaned disc, and have latest firmware on the Sammy. Sammy reads disc and returns message saying this disc will not play. I will return disc to Amazon.com. It looks to me like the disc was never burn at factory, just looks like a blank disc when compared to other BD discs, also was no insert of any kind on left side of case when opened which all the others like Behind E.L. have upcoming Fox titles.
Bill
billymerritt is offline
post #2 of 48 Old 11-17-2006, 04:08 PM
Roger Mathus's Avatar
Quoted: 63 Post(s)
Liked: 45
I got a second copy from Amazon with the same result. Both discs from Amazon had no insert on left side and there was no security stickers on the package. It was, however, shrink wrapped. Some people are reporting no problems other than slow load. It appears that a bad batch got out the door and arrived at Amazon. Your analysis that it is blank disc seems very likely as there are no product or lot marks on the reverse side near the center.
Roger Mathus is offline
post #3 of 48 Old 11-17-2006, 07:22 PM
calvin c's Avatar
Mine is from Amazon, but did play fine on my panny. No sleeve either. Seemed a little slow to load too, almost like KOH.
calvin c is offline
post #4 of 48 Old 11-17-2006, 07:24 PM
Video Engineer's Avatar
Make sure latest firmware is installed.
Video Engineer is offline
post #5 of 48 Old 11-17-2006, 08:38 PM
ThePrisoner's Avatar
Quoted: 286 Post(s)
Liked: 202
Picked up The Transporter today. Loaded about the same time it takes my other BD's to load. Looks like this problem is being narrowed down to The Speed disc itself.
Dolby Atmos/DTS:X 5.2.4
Samsung 65JS8500 (calibrated by Gregg Loewen); Marantz SR6010 + Onkyo M-5010; Oppo UDP-203; Apple TV (4th Gen); PS4; Definitive Technology BP-8060ST, CS-8060HD, SR-8040BP, ProMonitor 800; SVS PC12-NSD (2)
ThePrisoner is offline
post #6 of 48 Old 11-17-2006, 09:16 PM
Quoted: 63 Post(s)
Liked: 45
Yes, I have the latest firmware. No problem with all the other Fox discs. Just SPEED.
post #7 of 48 Old 11-18-2006, 06:17 AM
Quoted: 286 Post(s)
Liked: 202
Maybe during the week we'll get more info as to what happened with certain copies of Speed. Some people get the disc to play after about 4-5min. Looks like I'll pass on buying t for now, bummer.
post #8 of 48 Old 11-18-2006, 06:31 AM
palofex's Avatar
It seems that everyone having issues not being able to load discs is using the Sammy...
palofex is offline
post #9 of 48 Old 11-19-2006, 06:33 AM
paulbh's Avatar
No problems playing Speed last night on the Panasonic with FW 1.2. It looked very nice. Maybe this thread should be "Beware Speed on Samsung"?
paulbh is offline
post #10 of 48 Old 11-19-2006, 07:04 AM
gas_leak's Avatar
No problem with Speed here, I'm using a Sammy with latest firmware. Got mine from Circuit City and the box came with an insert and a firmware upgrade warning card.
gas_leak is offline
post #11 of 48 Old 11-19-2006, 07:36 AM
joerod's Avatar
Quoted: 724 Post(s)
Liked: 655
No problem here either. Of course I am using the DTHEATER version...
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #12 of 48 Old 11-19-2006, 04:26 PM
Earz's Avatar
I was hoping the Philips version had the newer firmware for this problem....but it does not.
I had to start the movie 4-5 times to get the circle swirls...and finally have it play.
Looks pretty good though...with nice sound also.
I only watched the D-theater version once...so I can't recall if this version is some what better....or the same.
Earz is offline
post #13 of 48 Old 11-20-2006, 09:15 AM
Quoted: 63 Post(s)
Liked: 45
I called Fox Consumer Department and the person I talked to indicated that they had no other inquiries regarding problems with SPEED. They told me I could return the product to Fox and that they would evaluate and send replacement disc in about 4-6 weeks.
The phone number that I obtained from the Fox Home Video website is 1-888-223-2FOX.
post #14 of 48 Old 11-20-2006, 09:18 AM
patrick99's Avatar
Apparently both Speed and League of Extraordinary Gentlement require the update to play on Samsung, because of Java features.
patrick99 is offline
post #15 of 48 Old 11-20-2006, 10:50 AM
clarkbar911's Avatar
I cannot get Speed to work on Sammy with upgraded firmware. No problem with X3, Transporter, LXG. I don't think it had a security seal or insert. Received mine from DVDEmpire.
clarkbar911 is offline
post #16 of 48 Old 11-20-2006, 02:03 PM - Thread Starter
Quoted: 35 Post(s)
Liked: 27
I got second Speed disc from Amazon, same problem, Sammy ejects disc and says disc will not play. Will call Fox as you did and let them know there are more of us with this disc problem! Guess I will just get refund from Amazon for this title!
Bill
post #17 of 48 Old 11-20-2006, 03:42 PM
HomerJay's Avatar
I saw some Fox titles the other day (I don't believe it was Speed) and couldn't believe my eyes when I saw 18Mbps listed as the bitrate. Aren't new technologies supposed to improve on the old? The D-VHS copy I have (assuming all Fox titles are the same; only a few are marked) is 28.2Mbps. All I can say is wow, way to go Fox. Just over 1/2 the bitrate of D-VHS...YEAH!!
HomerJay is offline
post #18 of 48 Old 11-21-2006, 06:33 AM
Brajesh's Avatar
Quoted: 306 Post(s)
Liked: 131
Mine won't play either. I have the latest firmware installed on my Sammy.
Hi-deft Media Keen Videosaurus
Brajesh is offline
post #19 of 48 Old 11-21-2006, 07:21 AM
JOHNnDENVER's Avatar
I was going to pick this up tonight too.. Not so sure now.
JOHNnDENVER is offline
post #20 of 48 Old 11-21-2006, 01:26 PM
Vern Dias's Avatar
No problem on my Panasonic.....
Vern
Vern Dias is offline
post #21 of 48 Old 11-21-2006, 08:49 PM
hammer99's Avatar
Mine finally arrived from Amazon, no problems on my Sammy (latest firmware).
hammer99 is offline
post #22 of 48 Old 11-21-2006, 09:35 PM
StuDBaker's Avatar
So, just how did you stick a DVHS tape into a DVD slot?
StuDBaker is offline
post #23 of 48 Old 11-22-2006, 06:12 AM
Blu-ray Reviewer
Moderator
Ralph Potts's Avatar
Quoted: 1136 Post(s)
Liked: 3610
Greetings,
I watched Speed on my Panasonic with no problem other than a longer load time. Pic and sound quality are very decent.
Ralph C. Potts
Blu-ray Reviews
AVS Forum
My Home Theater
My DVD/HD DVD/Blu-ray Collection
Follow me on Twitter @RalphAVSreviews
Ralph Potts is offline
post #24 of 48 Old 11-22-2006, 08:47 AM
Well, I gave it a miss for now. I picked up a few titltes after work, after my FW update completed n my Sammy.
post #25 of 48 Old 11-22-2006, 11:39 AM
uscjordan23's Avatar
Looks good on PS3
uscjordan23 is offline
post #26 of 48 Old 11-22-2006, 03:15 PM
dvdguru's Avatar
UPDATE: After receiving the most current firmware disc and loading it on the Sammy today, both Speed and Behind Enemy Lines now play for me. Before the firmware update they both would sputter along with the whole screen going green every few seconds...
Elite PRO-70X5FD!
dvdguru
Xbox Live Gamertag: AVS Steve
dvdguru is offline
post #27 of 48 Old 11-29-2006, 06:17 AM - Thread Starter
Quoted: 35 Post(s)
Liked: 27
I received email from Amazon today giving me 100% refund for Speed, it seems they have had many of these returned. I had 2 discs from them and neither one would play as other members have also. Message on Sammy was "this disc will not play" and yes have latest firmware installed. I read on other posts random discs from different studios will not play, so???? is it the Sammy or the disc? This is the question?
Bill
post #28 of 48 Old 11-29-2006, 04:33 PM
chipvideo's Avatar
I have the same problem with Ice Age 2 and another one from netflix. Both discs were brand new with zero scratches. The other disc of the 3 played fine. Using the sammy BD1000. Not sure what to think of that. I also have the latest firmware installed.
chipvideo is offline
post #29 of 48 Old 11-29-2006, 05:06 PM
Quoted: 63 Post(s)
Liked: 45
I had two copies of SPEED from Amazon and neither would load on the Samsung player. I returned one to Fox. No problem with other Fox titles but several did slow load.
Today, I got new Sony BDP-S1 player and it was able to load and play SPEED but the load process took a very long time.
My take on the problem is that perhaps both the player and the disc contribute to the problem. Note that it appears that SPEED causes no problems to many Samsung players
There was a similar problem in early days of DVD where the disc was at the edge of spec limit. When a player was also within but at edge of spec the disc would not read. I think that the problem was corrected by more careful production of the disc. As I recall, this involved a number of early Anchor Bay discs.
This is from memory, so if someone who is more of expert on disc production and specs please correct or supplement.
post #30 of 48 Old 11-30-2006, 12:49 AM
Jules343's Avatar
Now how did you get that to load in the Sammy?
Damn I'm slow today. First the MPAA thread and now this.
PSN ID: Ass
Jules343 is offline
Reply Blu-ray Software
