Unofficial Blu-ray Audio and Video Specifications Thread - Page 19 - AVS Forum
post #541 of 1971 Old 07-25-2008, 07:33 PM
Phantom Stranger's Avatar
Quoted: 13 Post(s)
Liked: 75
We are simply not worthy, Cinema Squid. That new addition looks to be a powerful tool. Bravo
Phantom Stranger is offline
post #542 of 1971 Old 07-26-2008, 10:59 AM
Patsfan123's Avatar
I have been doing this over the past few days, I am not sure how to format them for the list though so I am just gonna attach the raw scans.
lost s3.zip 9.208984375k . file
Michael
Collection: DVD | High-def
Patsfan123 is offline
post #543 of 1971 Old 07-26-2008, 04:29 PM
Quoted: 13 Post(s)
Liked: 75
I'm putting in a request for someone to do Rescue Me season three.
post #544 of 1971 Old 07-26-2008, 08:39 PM
Cinema Squid's Avatar
BDInfo v.0.4.0 is now available. As always, let me know if you run into any problems.
The average bitrate numbers should be identical to the previous version, so it's just a matter of new features.
Cinema Squid is offline
post #545 of 1971 Old 07-26-2008, 10:29 PM
Patsfan123's Avatar
Hi Cinema-
I like the bitrate peaks and charts alot. The only bug I have encountered is that if you set it to automatically save the report upon completion, it overwrites the past report. I would like it if it named the txt file as the disc label or the root folder name in the case of discs saved to the hard drive. Then you wouldn't have to worry about it being over written.
Michael
post #546 of 1971 Old 07-26-2008, 10:34 PM
Patsfan123's Avatar
Shutter's 1 sec video bitrate
Michael
post #547 of 1971 Old 07-26-2008, 11:18 PM
Good point - I'll look at that. I had thought about creating a unique name for each autosave, but didn't want to create too much clutter (although if you want to make some clutter, try the CSV export with no playlists selected ). Thinking about it though, different filenames would also be good for the case of running multiple simultaneous scans (which I do frequently).
I also scanned Shutter today and it's kind of interesting in that it really holds steady to its median bitrate at a point only slightly above its average and dips downward instead of upward to maintain its high average. Most releases seem to be a little bit more variant without such a clear visual indication of the average. I'm sure we'll have many conversations about "what it all means" and in the end it probably doesn't mean too much, but I like numbers and graphs so it's all just fun to me. Disc analysis - my favorite bonus feature!
post #548 of 1971 Old 07-27-2008, 09:19 AM
msgohan's Avatar
"Disc analysis - my favorite bonus feature!" I like that!
Will try out the new version shortly, but those Lost S3 scans got me thinking of a feature request. It looks like the 2nd set of subs for each language are really there, but some of the bitrates are reported as 0 kbps. Would it be possible to increase the precision to less than 1 kbps in such cases? Or just report the sizes for subtitles instead, if that's possible?
This would be good, for example, to see whether the phantom Fox subs really have some data to them after all?
msgohan is offline
post #549 of 1971 Old 07-27-2008, 12:03 PM
Patsfan123's Avatar
I have a feature request! Can we make custom playlists to scan, most usefully for TV shows without a play all playlist. So we can get an overall average for the disc rather than having to calculate it ourselves.
Michael
post #550 of 1971 Old 07-27-2008, 04:54 PM
Patsfan123's Avatar
Michael
post #551 of 1971 Old 07-27-2008, 09:24 PM
That's a good suggestion - I'll put this in. You can kind of get this info from the list of streams in the stream diagnostics section, but since I neglected to label the stream entries with the language code, this might be kind of difficult as it currently stands.
I had hoped to put that into the current version, but I passed on it since it was a little trickier than I first anticipated - i.e. handling the cases where the selected playlists don't have the same stream contents. This is actually legitimate in some cases (e.g. where some TV episode have extra commentary tracks). I definitely want to add this though, since it would be really nice to have.
Originally Posted by Phantom Stranger View Post
Can anyone scan the budget title "The Curse of King Tut's Tomb"?
For reasons beyond my own understanding, I ordered eleven Echo Bridge titles from J&R.com over the weekend including The Curse of King Tut's Tomb, so hopefully I will get those before too long and I'll make sure I scan Tut first. Kids, don't drink and go shopping online...
post #552 of 1971 Old 07-27-2008, 09:31 PM
Fool's Gold - Dolby Digital AC3 (lossy compression)
Code:
        Total   Video
Fool's Gold                                                     VC-1    1:52:26 20,011,499,520  20,400,199,718  23.73   20.51   DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      20,400,199,718 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:52:26 (h:m:s)
Total Bitrate:  23.73 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00000.M2TS      20,011,499,520  1:52:26.531     0:00:00.000     1:52:26.531
VIDEO:
Codec               Bitrate         Description
VC-1 Video          20512 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby Digital Audio             English         640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             French          640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             Spanish         640 kbps        5.1 / 48kHz / 640kbps
SUBTITLES:
Presentation Graphics           English         31 kbps
Presentation Graphics           French          21 kbps
Presentation Graphics           French          0 kbps
Presentation Graphics           Spanish         29 kbps
Presentation Graphics           Spanish         1 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:06:51.411     23,074 kbps     45,739 kbps     00:01:50.652    35,435 kbps     00:01:29.423    33,345 kbps     00:06:24.926    120,299 bytes   433,118 bytes   00:01:54.781
2               0:06:51.411     0:02:37.491     19,410 kbps     25,219 kbps     00:06:53.121    24,055 kbps     00:06:52.996    23,505 kbps     00:07:01.671    101,195 bytes   263,728 bytes   00:06:55.540
3               0:09:28.902     0:05:38.671     22,109 kbps     38,953 kbps     00:14:37.460    34,637 kbps     00:14:51.682    33,958 kbps     00:14:48.012    115,264 bytes   351,856 bytes   00:14:38.336
4               0:15:07.573     0:06:28.555     22,394 kbps     40,683 kbps     00:17:28.965    34,583 kbps     00:17:31.717    33,404 kbps     00:17:26.629    116,752 bytes   410,134 bytes   00:19:20.242
5               0:21:36.128     0:03:57.237     16,494 kbps     25,170 kbps     00:21:42.384    22,342 kbps     00:21:55.940    20,582 kbps     00:22:59.545    85,991 bytes    375,153 bytes   00:23:01.880
6               0:25:33.365     0:05:22.155     17,677 kbps     24,896 kbps     00:26:22.539    22,363 kbps     00:26:10.277    20,273 kbps     00:26:11.236    92,160 bytes    262,162 bytes   00:28:53.023
7               0:30:55.520     0:04:28.268     21,015 kbps     39,514 kbps     00:35:04.185    30,549 kbps     00:35:04.185    28,935 kbps     00:35:00.223    109,564 bytes   437,054 bytes   00:31:19.336
8               0:35:23.788     0:03:34.047     18,767 kbps     29,063 kbps     00:35:29.669    25,497 kbps     00:35:29.502    23,656 kbps     00:35:28.668    97,843 bytes    358,158 bytes   00:37:12.605
9               0:38:57.835     0:08:13.160     18,389 kbps     22,827 kbps     00:39:23.236    21,577 kbps     00:39:22.277    20,696 kbps     00:39:22.318    95,871 bytes    298,671 bytes   00:42:11.154
10              0:47:10.995     0:04:23.430     20,371 kbps     39,964 kbps     00:48:09.303    32,386 kbps     00:48:05.508    27,799 kbps     00:48:00.544    106,207 bytes   398,354 bytes   00:48:09.345
11              0:51:34.425     0:04:28.601     22,428 kbps     47,095 kbps     00:51:47.980    36,545 kbps     00:52:17.634    32,934 kbps     00:52:16.300    116,931 bytes   416,440 bytes   00:51:48.522
12              0:56:03.026     0:04:23.096     17,350 kbps     25,473 kbps     00:59:17.471    23,603 kbps     00:59:15.719    21,450 kbps     00:59:11.757    90,455 bytes    265,733 bytes   00:59:26.021
13              1:00:26.122     0:02:22.476     18,248 kbps     21,612 kbps     01:00:27.499    20,318 kbps     01:02:14.230    19,866 kbps     01:02:13.229    95,139 bytes    236,318 bytes   01:00:37.676
14              1:02:48.598     0:05:38.338     21,795 kbps     38,752 kbps     01:06:49.339    35,435 kbps     01:06:49.339    32,242 kbps     01:06:49.339    113,630 bytes   301,064 bytes   01:06:52.926
15              1:08:26.936     0:05:01.301     19,734 kbps     32,613 kbps     01:08:57.967    29,087 kbps     01:08:57.925    28,075 kbps     01:08:57.925    102,885 bytes   336,897 bytes   01:10:07.328
16              1:13:28.237     0:05:17.984     21,925 kbps     37,185 kbps     01:15:41.370    32,262 kbps     01:15:39.118    31,343 kbps     01:15:22.727    114,308 bytes   381,243 bytes   01:16:15.112
17              1:18:46.221     0:06:43.070     19,991 kbps     31,151 kbps     01:19:13.874    29,496 kbps     01:19:10.079    27,630 kbps     01:19:04.865    104,226 bytes   544,586 bytes   01:19:10.287
18              1:25:29.291     0:02:56.843     22,860 kbps     47,031 kbps     01:27:39.212    34,817 kbps     01:27:39.212    32,250 kbps     01:27:37.502    119,182 bytes   415,512 bytes   01:27:39.254
19              1:28:26.134     0:03:52.566     20,784 kbps     46,090 kbps     01:31:23.645    33,295 kbps     01:31:12.717    31,353 kbps     01:31:14.761    108,359 bytes   489,243 bytes   01:31:18.682
20              1:32:18.700     0:04:10.917     24,074 kbps     42,732 kbps     01:36:12.475    35,686 kbps     01:35:27.513    32,733 kbps     01:35:24.802    125,511 bytes   366,638 bytes   01:34:03.888
21              1:36:29.617     0:03:20.867     26,225 kbps     44,829 kbps     01:38:12.470    36,816 kbps     01:38:34.700    33,803 kbps     01:38:12.220    136,724 bytes   389,034 bytes   01:38:12.845
22              1:39:50.484     0:03:37.885     24,655 kbps     44,760 kbps     01:39:57.658    33,794 kbps     01:39:55.406    32,476 kbps     01:40:05.333    128,538 bytes   355,819 bytes   01:40:06.417
23              1:43:28.369     0:03:17.697     26,566 kbps     49,221 kbps     01:45:18.646    36,424 kbps     01:43:45.302    32,499 kbps     01:43:31.997    138,503 bytes   511,496 bytes   01:45:18.687
24              1:46:46.066     0:01:19.413     20,130 kbps     27,020 kbps     01:47:01.540    25,045 kbps     01:46:58.912    23,578 kbps     01:46:53.574    104,948 bytes   429,135 bytes   01:47:40.496
25              1:48:05.479     0:04:21.052     7,673 kbps      18,057 kbps     01:52:19.816    10,915 kbps     01:52:06.053    10,226 kbps     01:52:03.133    40,004 bytes    313,977 bytes   01:52:20.692
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00000.M2TS      4113 (0x1011)   0xEA            6746.53         17,298,226,903  94,109,762      20,512
00000.M2TS      4352 (0x1100)   0x81            6746.53         539,724,800     3,162,450       640
00000.M2TS      4353 (0x1101)   0x81            6746.53         539,724,800     3,162,450       640
00000.M2TS      4354 (0x1102)   0x81            6746.53         539,724,800     3,162,450       640
00000.M2TS      4608 (0x1200)   0x90            6746.53         26,126,702      150,764         31
00000.M2TS      4609 (0x1201)   0x90            6746.53         18,017,524      104,808         21
00000.M2TS      4610 (0x1202)   0x90            6746.53         24,875,621      143,180         29
00000.M2TS      4611 (0x1203)   0x90            6746.53         283,788         1,608           0
00000.M2TS      4612 (0x1204)   0x90            6746.53         536,365         3,036           1
post #553 of 1971 Old 07-27-2008, 09:50 PM
Patsfan123's Avatar
Btw, Fools Gold has a pretty nice bitrate graph. I have been waiting on it from netflix.
Michael
post #554 of 1971 Old 07-28-2008, 05:39 AM
House's Avatar
Bitrate junkies, hold on to your butts :>
Toki o Kakeru Shoujo (aka Girl who Leapt Through Time)
Code:
        Total   Video
The Girl Who Leapt Through Time                                 AVC     1:38:19 34,024,267,776  36,985,030,068  46.14   36.07   DTS-HD Master 5.1 1957Kbps (48kHz/16-bit) Dolby TrueHD 5.1 1970Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      36,985,030,068 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:38:19 (h:m:s)
Total Bitrate:  46.14 Mbps
Description:
FILES:
00000.M2TS      34,024,267,776  1:38:19.393     0:00:00.000     1:38:19.393
VIDEO:
MPEG-4 AVC Video    36073 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
DTS-HD Master Audio             Japanese        1957 kbps       5.1 / 48kHz / 16-bit / 1957kbps (DTS Core: 5.1 / 48kHz / 16-bit / 1536kbps)
Dolby TrueHD Audio              Japanese        1970 kbps       5.1 / 48kHz / 24-bit / 1970kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
LPCM Audio                      Japanese        1536 kbps       2.0 / 48kHz / 16-bit / 1536kbps
Dolby Digital Audio             Japanese        192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           Japanese        35 kbps
CHAPTERS:
1               0:00:00.000     0:06:24.217     32,841 kbps     43,383 kbps     00:01:55.407    38,219 kbps     00:03:54.025    37,927 kbps     00:03:49.020    171,216 bytes   595,361 bytes   00:03:05.477
2               0:06:24.217     0:05:04.971     36,673 kbps     42,024 kbps     00:09:41.289    38,046 kbps     00:10:52.694    37,858 kbps     00:08:43.148    191,194 bytes   517,975 bytes   00:10:57.699
3               0:11:29.188     0:03:59.239     37,144 kbps     40,446 kbps     00:13:55.460    38,154 kbps     00:13:38.985    37,924 kbps     00:13:40.069    193,652 bytes   582,178 bytes   00:13:49.203
4               0:15:28.427     0:02:10.130     37,147 kbps     39,876 kbps     00:17:21.749    38,083 kbps     00:17:17.745    37,855 kbps     00:17:12.740    193,666 bytes   476,882 bytes   00:15:31.430
5               0:17:38.557     0:05:44.511     36,388 kbps     40,402 kbps     00:17:59.412    38,040 kbps     00:21:11.228    37,838 kbps     00:19:11.108    189,709 bytes   540,686 bytes   00:17:59.745
6               0:23:23.068     0:04:52.960     37,345 kbps     40,610 kbps     00:24:02.983    38,132 kbps     00:24:03.317    37,957 kbps     00:23:58.270    194,702 bytes   584,412 bytes   00:24:03.776
7               0:28:16.028     0:02:43.997     37,058 kbps     41,789 kbps     00:28:43.889    38,186 kbps     00:30:54.519    37,861 kbps     00:30:49.514    193,205 bytes   560,573 bytes   00:30:59.524
8               0:31:00.025     0:04:56.129     36,760 kbps     39,511 kbps     00:33:33.178    37,992 kbps     00:33:33.136    37,808 kbps     00:33:37.015    191,651 bytes   473,826 bytes   00:33:35.138
9               0:35:56.154     0:04:17.424     37,242 kbps     41,825 kbps     00:38:29.140    38,250 kbps     00:38:25.136    37,833 kbps     00:36:15.548    194,163 bytes   662,093 bytes   00:39:17.188
10              0:40:13.578     0:06:00.193     36,943 kbps     43,221 kbps     00:40:31.179    38,157 kbps     00:44:26.998    37,870 kbps     00:41:09.759    192,606 bytes   654,370 bytes   00:44:27.290
11              0:46:13.771     0:03:26.373     36,934 kbps     39,645 kbps     00:46:29.370    38,027 kbps     00:46:25.324    37,779 kbps     00:48:43.170    192,556 bytes   503,059 bytes   00:46:26.409
12              0:49:40.144     0:06:22.882     37,181 kbps     40,522 kbps     00:54:35.814    38,081 kbps     00:54:50.412    37,802 kbps     00:55:49.930    193,844 bytes   569,408 bytes   00:54:36.732
13              0:56:03.026     0:05:25.158     37,040 kbps     41,033 kbps     00:59:57.385    38,302 kbps     00:59:53.340    37,927 kbps     00:59:51.171    193,110 bytes   607,191 bytes   00:59:59.304
14              1:01:28.184     0:05:17.484     34,837 kbps     40,805 kbps     01:05:00.271    38,316 kbps     01:04:56.184    37,895 kbps     01:04:51.262    181,625 bytes   583,769 bytes   01:05:01.147
15              1:06:45.668     0:06:58.752     36,396 kbps     40,105 kbps     01:08:15.508    38,032 kbps     01:08:18.219    37,736 kbps     01:11:09.599    189,750 bytes   666,800 bytes   01:11:01.090
16              1:13:44.420     0:04:08.582     37,074 kbps     43,788 kbps     01:17:27.810    38,101 kbps     01:17:23.806    37,820 kbps     01:14:25.336    193,289 bytes   513,804 bytes   01:14:53.364
17              1:17:53.002     0:03:35.381     36,495 kbps     51,451 kbps     01:20:05.300    40,182 kbps     01:20:01.296    38,695 kbps     01:19:56.291    190,267 bytes   590,319 bytes   01:20:50.345
18              1:21:28.383     0:03:10.190     36,620 kbps     40,352 kbps     01:22:49.131    38,147 kbps     01:22:49.006    37,889 kbps     01:22:49.006    190,919 bytes   573,957 bytes   01:22:56.013
19              1:24:38.573     0:06:43.904     36,473 kbps     42,681 kbps     01:25:39.968    38,086 kbps     01:26:20.258    37,851 kbps     01:26:21.760    190,152 bytes   484,193 bytes   01:26:22.803
20              1:31:22.477     0:02:19.139     34,278 kbps     39,302 kbps     01:32:00.724    37,944 kbps     01:31:56.678    37,776 kbps     01:31:51.673    178,708 bytes   498,627 bytes   01:31:57.971
21              1:33:41.616     0:04:37.777     29,542 kbps     40,268 kbps     01:36:27.532    37,809 kbps     01:35:14.876    37,694 kbps     01:35:08.453    154,020 bytes   652,908 bytes   01:34:27.996
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0x1B            5899.39         26,600,762,401  144,652,105     36,073
00000.M2TS      4352 (0x1100)   0x83            5899.39         1,924,781,412   15,448,114      2,610
00000.M2TS      4353 (0x1101)   0x86            5899.39         1,443,357,312   8,753,547       1,957
00000.M2TS      4354 (0x1102)   0x80            5899.39         1,133,644,800   7,085,280       1,537
00000.M2TS      4355 (0x1103)   0x81            5899.39         141,705,984     922,565         192
00000.M2TS      4608 (0x1200)   0x90            5899.39         25,847,441      150,272         35
House is offline
post #555 of 1971 Old 07-28-2008, 05:52 AM
lgans316's Avatar
Thanks House. Looks like you know Japanese. Time to update these stats at amazon.co.jp. Sitting in Japan it's quite natural for me rave about bit rates.
Blu-ray : 340
lgans316 is online now
post #556 of 1971 Old 07-28-2008, 07:30 AM
House's Avatar
Macross Frontier Vol. 1.
There's three versions of episode 1 on the disc. Yack Deculture (32mins), Deculture (27mins), and TV (24mins). There is actually a fourth file which is the "commentary" version of Yack Deculture, why it's a full fledged m2ts (of 8GB+!) and not simply an extra audio track I have no idea. Don't know why they all decide to route back to a 1 second m2ts at the end either.
Code:
DISC INFO:
Disc Size:      34,314,469,792 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:32:10 (h:m:s)
Total Bitrate:  38.71 Mbps
Description:    Episode 01 (Yack Deculture)
FILES:
00007.M2TS      9,327,562,752   0:32:09.427     0:00:00.000     0:32:09.427
00002.M2TS      14,395,392      0:00:01.001     0:32:09.427     0:32:10.428
VIDEO:
MPEG-4 AVC Video    35204 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:07:10.430     36,273 kbps     46,077 kbps     00:00:43.293    39,449 kbps     00:06:16.960    38,493 kbps     00:05:38.964    189,109 bytes   840,918 bytes   00:05:14.272
2               0:07:10.430     0:01:30.090     36,676 kbps     43,565 kbps     00:08:30.051    38,461 kbps     00:07:17.395    38,014 kbps     00:07:50.720    191,210 bytes   579,579 bytes   00:07:26.279
3               0:08:40.520     0:08:19.332     33,962 kbps     45,897 kbps     00:13:08.871    39,652 kbps     00:15:25.007    38,820 kbps     00:15:17.208    177,064 bytes   934,731 bytes   00:15:28.094
4               0:16:59.852     0:00:15.015     36,417 kbps     39,681 kbps     00:17:10.363    38,462 kbps     00:17:00.186    38,213 kbps     00:17:01.103    189,863 bytes   453,917 bytes   00:17:13.908
5               0:17:14.867     0:12:47.267     36,767 kbps     46,658 kbps     00:21:45.930    39,872 kbps     00:21:41.926    38,531 kbps     00:29:28.934    191,685 bytes   920,815 bytes   00:27:07.835
6               0:30:02.134     0:02:07.293     26,121 kbps     39,413 kbps     00:31:14.706    36,088 kbps     00:30:13.186    33,417 kbps     00:31:09.951    136,181 bytes   637,771 bytes   00:31:42.275
7               0:32:09.427     0:00:01.001     1,263 kbps      0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    6,586 bytes     6,586 bytes     00:32:09.511
STREAM DIAGNOSTICS:
00007.M2TS      4113 (0x1011)   0x1B            1929.43         8,494,799,632   46,194,919      35,222
00007.M2TS      4352 (0x1100)   0x80            1929.43         371,411,520     2,321,322       1,540
00002.M2TS      4113 (0x1011)   0x1B            1.00            158,144         865             1,264
00002.M2TS      4352 (0x1100)   0x80            1.00            11,531,520      72,072          92,160
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:27:35 (h:m:s)
Total Bitrate:  38.89 Mbps
Description:    Episode 01 (Deculture)
FILES:
00005.M2TS      8,035,135,488   0:27:34.653     0:00:00.000     0:27:34.653
00002.M2TS      14,395,392      0:00:01.001     0:27:34.653     0:27:35.654
VIDEO:
MPEG-4 AVC Video    35367 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:02:38.033     36,906 kbps     46,066 kbps     00:00:30.197    38,823 kbps     00:00:26.193    38,362 kbps     00:01:19.871    192,413 bytes   701,902 bytes   00:01:51.987
2               0:02:38.033     0:10:10.068     35,256 kbps     45,841 kbps     00:09:39.871    39,947 kbps     00:02:46.708    38,769 kbps     00:11:48.249    183,810 bytes   934,711 bytes   00:11:58.092
3               0:12:48.101     0:12:04.098     36,822 kbps     52,989 kbps     00:13:04.951    40,264 kbps     00:13:00.989    39,225 kbps     00:12:56.025    191,973 bytes   920,394 bytes   00:21:57.900
4               0:24:52.199     0:02:05.417     26,011 kbps     40,461 kbps     00:25:14.680    35,452 kbps     00:25:02.418    33,535 kbps     00:25:57.806    135,608 bytes   582,983 bytes   00:26:19.328
5               0:26:57.616     0:00:37.037     34,734 kbps     42,728 kbps     00:27:21.515    38,594 kbps     00:27:25.477    37,696 kbps     00:26:59.535    181,087 bytes   714,565 bytes   00:27:22.432
6               0:27:34.653     0:00:01.001     1,263 kbps      0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    6,586 bytes     6,586 bytes     00:27:34.736
STREAM DIAGNOSTICS:
00005.M2TS      4113 (0x1011)   0x1B            1654.65         7,319,320,884   39,802,448      35,388
00005.M2TS      4352 (0x1100)   0x80            1654.65         318,654,720     1,991,592       1,541
Code:
DISC INFO:
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         0:24:10 (h:m:s)
Total Bitrate:  39.27 Mbps
Description:    Episode 01 (TV)
FILES:
00006.M2TS      7,104,798,720   0:24:09.281     0:00:00.000     0:24:09.281
00002.M2TS      14,395,392      0:00:01.001     0:24:09.281     0:24:10.282
VIDEO:
MPEG-4 AVC Video    35717 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
CHAPTERS:
1               0:00:00.000     0:00:52.052     37,153 kbps     42,270 kbps     00:00:01.627    38,684 kbps     00:00:06.506    38,322 kbps     00:00:09.968    193,699 bytes   670,800 bytes   00:00:08.133
2               0:00:52.052     0:01:30.090     36,592 kbps     43,787 kbps     00:02:11.715    38,505 kbps     00:00:59.059    38,007 kbps     00:01:32.342    190,775 bytes   577,485 bytes   00:01:07.025
3               0:02:22.142     0:09:16.055     34,228 kbps     46,477 kbps     00:02:46.375    39,904 kbps     00:10:15.031    38,913 kbps     00:10:10.026    178,447 bytes   934,731 bytes   00:10:18.117
4               0:11:38.197     0:00:15.015     37,404 kbps     40,240 kbps     00:11:50.960    38,449 kbps     00:11:47.081    38,298 kbps     00:11:41.951    195,008 bytes   552,834 bytes   00:11:52.253
5               0:11:53.212     0:11:12.839     36,731 kbps     46,796 kbps     00:16:08.050    39,911 kbps     00:16:04.046    38,439 kbps     00:16:33.409    191,499 bytes   897,764 bytes   00:15:55.538
6               0:23:06.051     0:00:47.214     35,878 kbps     44,839 kbps     00:23:22.568    38,868 kbps     00:23:22.818    38,023 kbps     00:23:21.692    187,054 bytes   502,398 bytes   00:23:38.125
7               0:23:53.265     0:00:16.016     35,308 kbps     40,373 kbps     00:24:01.982    38,099 kbps     00:23:57.936    37,494 kbps     00:23:53.265    184,080 bytes   401,514 bytes   00:23:53.307
8               0:24:09.281     0:00:01.001     1,263 kbps      0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    6,586 bytes     6,586 bytes     00:24:09.365
STREAM DIAGNOSTICS:
00006.M2TS      4113 (0x1011)   0x1B            1449.28         6,474,891,972   35,210,274      35,741
00006.M2TS      4352 (0x1100)   0x80            1449.28         279,223,680     1,745,148       1,541
House is offline
post #557 of 1971 Old 07-28-2008, 08:54 AM
bplewis24's Avatar
It's too bad this isn't a higher profile movie or in english, as I'd like to hear sound comparison reviews and wave analysis for the TrueHD and DTS HD audio tracks. One is in 24-bit and one is 16-bit.
Brandon
bplewis24 is offline
post #558 of 1971 Old 07-28-2008, 09:08 AM
House's Avatar
GitS: SAC boxset next...
Code:
        Total   Video
Ghost in the Shell: Stand Alone Complex - The Laughing Man      AVC     2:40:15 40,411,742,208  40,674,509,540  33.62   25.82   Dolby TrueHD 5.1 1557Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Size:      40,674,509,540 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:40:15 (h:m:s)
Total Bitrate:  33.62 Mbps
Description:
FILES:
00002.M2TS      40,411,742,208  2:40:15.372     0:00:00.000     2:40:15.372
VIDEO:
MPEG-4 AVC Video    25820 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1557 kbps       5.1 / 48kHz / 16-bit / 1557kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              Japanese        1534 kbps       5.1 / 48kHz / 16-bit / 1534kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
SUBTITLES:
Presentation Graphics           English         48 kbps
Presentation Graphics           Japanese        31 kbps
CHAPTERS:
1               0:00:00.000     0:01:59.953     27,091 kbps     54,598 kbps     00:00:11.645    36,805 kbps     00:01:31.892    34,939 kbps     00:00:11.645    112,992 bytes   555,324 bytes   00:00:34.067
2               0:01:59.953     0:02:49.937     26,057 kbps     43,886 kbps     00:03:27.340    37,402 kbps     00:03:29.743    35,337 kbps     00:03:55.969    108,678 bytes   511,896 bytes   00:02:32.853
3               0:04:49.890     0:03:58.938     26,078 kbps     52,551 kbps     00:07:24.711    36,569 kbps     00:07:24.711    35,362 kbps     00:07:24.711    108,766 bytes   491,603 bytes   00:07:20.006
4               0:08:48.828     0:02:42.930     21,449 kbps     48,342 kbps     00:08:51.998    36,417 kbps     00:11:17.510    31,816 kbps     00:09:04.744    89,460 bytes    632,762 bytes   00:08:50.563
5               0:11:31.758     0:04:41.714     28,282 kbps     41,406 kbps     00:13:06.185    36,384 kbps     00:13:15.261    35,891 kbps     00:12:03.289    117,961 bytes   604,457 bytes   00:11:36.963
6               0:16:13.472     0:04:06.914     27,397 kbps     42,982 kbps     00:17:04.857    34,645 kbps     00:18:05.885    31,934 kbps     00:16:30.823    114,269 bytes   563,810 bytes   00:17:50.069
7               0:20:20.386     0:04:25.298     29,083 kbps     39,688 kbps     00:21:23.215    34,262 kbps     00:22:33.319    32,037 kbps     00:22:33.252    121,301 bytes   518,294 bytes   00:22:17.903
8               0:24:45.684     0:04:26.199     25,655 kbps     53,790 kbps     00:27:20.839    37,081 kbps     00:28:27.272    34,185 kbps     00:28:26.438    107,001 bytes   635,331 bytes   00:24:48.287
9               0:29:11.883     0:13:25.171     26,624 kbps     49,973 kbps     00:39:52.123    36,754 kbps     00:38:01.412    36,127 kbps     00:38:01.412    111,044 bytes   639,903 bytes   00:29:24.963
10              0:42:37.054     0:05:55.422     22,601 kbps     53,551 kbps     00:42:58.009    37,230 kbps     00:44:01.873    34,086 kbps     00:47:24.041    94,264 bytes    629,916 bytes   00:46:38.829
11              0:48:32.476     0:05:01.401     28,427 kbps     55,102 kbps     00:48:32.910    38,122 kbps     00:48:59.870    36,833 kbps     00:48:54.832    118,562 bytes   657,569 bytes   00:48:33.110
12              0:53:33.877     0:07:25.812     26,186 kbps     58,661 kbps     00:56:03.727    37,769 kbps     00:58:22.733    36,403 kbps     00:57:58.975    109,216 bytes   512,206 bytes   00:57:18.001
13              1:00:59.689     0:03:00.247     23,913 kbps     47,329 kbps     01:01:00.257    36,353 kbps     01:01:46.570    35,098 kbps     01:01:42.766    99,736 bytes    673,684 bytes   01:03:57.801
14              1:03:59.936     0:01:07.034     19,676 kbps     57,193 kbps     01:04:22.192    33,204 kbps     01:04:22.192    30,973 kbps     01:04:16.252    82,067 bytes    637,856 bytes   01:05:05.602
15              1:05:06.970     0:02:02.422     26,626 kbps     58,660 kbps     01:05:07.637    37,250 kbps     01:05:07.537    35,585 kbps     01:05:07.570    111,054 bytes   645,300 bytes   01:06:46.369
16              1:07:09.392     0:01:55.115     20,456 kbps     48,490 kbps     01:08:30.306    31,757 kbps     01:08:56.399    29,507 kbps     01:07:12.262    85,320 bytes    681,987 bytes   01:08:40.049
17              1:09:04.507     0:01:40.667     29,986 kbps     38,241 kbps     01:09:06.109    35,725 kbps     01:09:04.507    34,738 kbps     01:09:04.807    125,067 bytes   424,445 bytes   01:10:45.208
18              1:10:45.174     0:05:38.839     25,951 kbps     55,434 kbps     01:13:04.780    38,013 kbps     01:11:32.822    34,582 kbps     01:11:32.688    108,236 bytes   683,107 bytes   01:10:46.909
19              1:16:24.013     0:02:02.088     24,174 kbps     49,242 kbps     01:16:24.914    36,497 kbps     01:17:50.232    35,852 kbps     01:17:45.227    100,827 bytes   594,957 bytes   01:16:56.712
20              1:18:26.101     0:10:08.775     27,907 kbps     53,668 kbps     01:19:22.324    37,298 kbps     01:19:47.216    36,554 kbps     01:19:42.211    116,395 bytes   560,733 bytes   01:28:05.680
21              1:28:34.876     0:02:48.402     23,161 kbps     48,326 kbps     01:28:59.601    37,542 kbps     01:30:02.530    36,217 kbps     01:29:58.893    96,599 bytes    679,967 bytes   01:31:09.898
22              1:31:23.278     0:05:31.030     23,544 kbps     57,706 kbps     01:32:47.028    37,883 kbps     01:31:31.986    36,426 kbps     01:31:29.918    98,198 bytes    642,546 bytes   01:34:19.787
23              1:36:54.308     0:03:20.234     27,711 kbps     43,175 kbps     01:39:55.356    33,266 kbps     01:37:18.800    30,690 kbps     01:39:57.625    115,576 bytes   525,912 bytes   01:37:43.491
24              1:40:14.542     0:12:59.412     22,950 kbps     57,774 kbps     01:50:21.815    38,047 kbps     01:44:12.513    35,463 kbps     01:52:45.692    95,723 bytes    685,159 bytes   01:40:25.219
25              1:53:13.954     0:03:03.483     22,687 kbps     52,409 kbps     01:53:14.821    37,668 kbps     01:54:15.916    35,858 kbps     01:54:53.954    94,625 bytes    629,572 bytes   01:55:41.535
26              1:56:17.437     0:07:45.532     27,192 kbps     49,158 kbps     02:03:47.387    37,106 kbps     02:01:22.075    36,199 kbps     02:01:22.075    113,414 bytes   698,526 bytes   02:03:39.545
27              2:04:02.969     0:02:15.435     28,031 kbps     39,202 kbps     02:04:25.491    34,593 kbps     02:04:23.756    33,220 kbps     02:04:19.085    116,912 bytes   562,321 bytes   02:04:39.572
28              2:06:18.404     0:08:50.230     28,839 kbps     52,846 kbps     02:12:28.908    34,521 kbps     02:10:37.897    32,816 kbps     02:10:37.897    120,284 bytes   579,538 bytes   02:06:20.740
29              2:15:08.634     0:04:45.352     28,110 kbps     52,938 kbps     02:15:37.129    36,415 kbps     02:15:47.639    35,499 kbps     02:16:29.214    117,242 bytes   677,492 bytes   02:15:19.478
30              2:19:53.986     0:03:49.395     27,227 kbps     57,157 kbps     02:23:10.015    36,056 kbps     02:21:53.071    34,192 kbps     02:21:50.268    113,561 bytes   583,865 bytes   02:23:10.749
31              2:23:43.381     0:04:27.000     26,345 kbps     46,524 kbps     02:25:13.638    37,374 kbps     02:25:13.638    35,071 kbps     02:25:13.638    109,880 bytes   630,424 bytes   02:24:01.700
32              2:28:10.381     0:07:35.022     26,273 kbps     51,387 kbps     02:33:19.023    36,307 kbps     02:30:00.191    34,428 kbps     02:29:58.690    109,582 bytes   585,083 bytes   02:32:33.277
33              2:35:45.403     0:04:29.969     16,975 kbps     48,637 kbps     02:36:44.161    37,045 kbps     02:36:44.161    34,039 kbps     02:36:40.925    70,799 bytes    358,646 bytes   02:36:55.206
STREAM DIAGNOSTICS:
00002.M2TS      4113 (0x1011)   0x1B            9615.37         31,033,229,849  168,972,011     25,820
00002.M2TS      4352 (0x1100)   0x83            9615.37         2,612,625,964   20,187,933      2,174
00002.M2TS      4353 (0x1101)   0x83            9615.37         2,641,115,158   20,453,223      2,197
00002.M2TS      4608 (0x1200)   0x90            9615.37         57,764,919      327,553         48
00002.M2TS      4609 (0x1201)   0x90            9615.37         37,350,505      214,962         31
House is offline
post #559 of 1971 Old 07-28-2008, 10:52 AM
House's Avatar
Code:
        Total   Video
Ghost in the Shell: Stand Alone Complex - The Individual Eleven AVC     2:41:46 43,531,044,864  43,817,782,040  35.88   27.71   Dolby TrueHD 5.1 1688Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Size:      43,817,782,040 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         2:41:46 (h:m:s)
Total Bitrate:  35.88 Mbps
Description:
FILES:
00008.M2TS      43,531,044,864  2:41:46.430     0:00:00.000     2:41:46.430
VIDEO:
MPEG-4 AVC Video    27714 kbps      1080i / 29.970fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1688 kbps       5.1 / 48kHz / 16-bit / 1688kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              Japanese        1547 kbps       5.1 / 48kHz / 16-bit / 1547kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
SUBTITLES:
CHAPTERS:
1               0:00:00.000     0:06:05.465     27,978 kbps     55,815 kbps     00:04:54.594    35,780 kbps     00:02:35.155    32,490 kbps     00:02:35.155    116,691 bytes   564,472 bytes   00:02:23.777
2               0:06:05.465     0:02:49.937     28,887 kbps     39,931 kbps     00:07:44.297    31,280 kbps     00:06:25.452    30,002 kbps     00:07:44.297    120,485 bytes   380,962 bytes   00:08:55.435
3               0:08:55.402     0:03:01.981     28,586 kbps     36,459 kbps     00:11:36.396    31,516 kbps     00:09:06.579    30,217 kbps     00:09:06.579    119,228 bytes   557,142 bytes   00:08:58.004
4               0:11:57.383     0:07:48.769     27,953 kbps     48,108 kbps     00:17:14.367    33,151 kbps     00:13:51.497    30,815 kbps     00:17:14.367    116,589 bytes   540,006 bytes   00:19:17.023
5               0:19:46.152     0:05:58.658     26,302 kbps     52,575 kbps     00:23:39.451    35,177 kbps     00:23:42.154    32,990 kbps     00:23:37.683    109,702 bytes   619,012 bytes   00:24:12.985
6               0:25:44.810     0:04:42.883     28,601 kbps     40,495 kbps     00:29:44.116    35,535 kbps     00:29:44.116    35,042 kbps     00:29:44.116    119,289 bytes   465,344 bytes   00:30:27.726
7               0:30:27.693     0:05:17.884     26,348 kbps     46,007 kbps     00:33:26.338    31,057 kbps     00:33:56.935    30,021 kbps     00:33:29.574    109,893 bytes   595,725 bytes   00:31:13.305
8               0:35:45.577     0:10:14.380     28,306 kbps     54,163 kbps     00:36:26.084    37,289 kbps     00:36:26.017    30,763 kbps     00:36:26.084    118,061 bytes   582,636 bytes   00:35:55.654
9               0:45:59.957     0:01:06.400     23,730 kbps     49,035 kbps     00:46:30.488    36,621 kbps     00:46:47.238    35,586 kbps     00:46:47.238    98,974 bytes    461,619 bytes   00:46:16.474
10              0:47:06.357     0:04:57.964     28,861 kbps     45,286 kbps     00:49:15.286    33,811 kbps     00:47:07.124    31,724 kbps     00:47:06.691    120,376 bytes   479,190 bytes   00:50:56.687
11              0:52:04.321     0:08:09.990     28,707 kbps     47,206 kbps     00:57:02.886    35,605 kbps     00:57:02.886    32,510 kbps     00:57:02.886    119,732 bytes   569,872 bytes   00:55:22.286
12              1:00:14.311     0:14:28.100     28,828 kbps     40,588 kbps     01:05:45.275    34,062 kbps     01:11:18.241    33,063 kbps     01:11:17.573    120,238 bytes   399,977 bytes   01:10:51.948
13              1:14:42.411     0:04:20.127     27,964 kbps     41,064 kbps     01:14:42.878    32,348 kbps     01:15:03.532    29,846 kbps     01:15:32.228    116,632 bytes   629,226 bytes   01:14:56.625
14              1:19:02.538     0:01:29.022     27,628 kbps     40,890 kbps     01:19:31.567    31,007 kbps     01:19:28.664    29,538 kbps     01:20:10.005    115,232 bytes   472,172 bytes   01:19:35.771
15              1:20:31.560     0:11:44.137     28,274 kbps     41,998 kbps     01:29:47.015    35,492 kbps     01:24:22.157    35,139 kbps     01:24:21.857    117,925 bytes   575,255 bytes   01:29:44.846
16              1:32:15.697     0:07:41.961     28,366 kbps     39,380 kbps     01:34:07.442    33,542 kbps     01:34:47.682    31,263 kbps     01:34:47.315    118,311 bytes   591,771 bytes   01:33:54.128
17              1:39:57.658     0:06:56.850     28,627 kbps     54,541 kbps     01:45:45.973    33,141 kbps     01:42:56.871    31,217 kbps     01:42:57.204    119,400 bytes   519,037 bytes   01:41:36.290
18              1:46:54.508     0:03:51.798     28,325 kbps     44,573 kbps     01:49:22.356    34,269 kbps     01:48:21.929    32,009 kbps     01:48:21.595    118,139 bytes   501,770 bytes   01:49:06.173
19              1:50:46.306     0:01:17.978     28,336 kbps     47,402 kbps     01:50:48.275    30,841 kbps     01:50:48.275    29,524 kbps     01:51:06.960    118,183 bytes   471,337 bytes   01:50:48.041
20              1:52:04.284     0:03:35.215     28,155 kbps     44,661 kbps     01:53:35.742    37,123 kbps     01:55:20.647    33,527 kbps     01:53:35.742    117,428 bytes   491,802 bytes   01:52:04.318
21              1:55:39.499     0:04:19.393     27,749 kbps     45,239 kbps     01:59:09.009    35,337 kbps     01:59:48.214    34,642 kbps     01:59:42.976    115,734 bytes   485,079 bytes   01:58:34.774
22              1:59:58.892     0:04:16.956     28,186 kbps     45,676 kbps     02:01:35.255    35,946 kbps     02:01:35.255    32,762 kbps     02:02:07.053    117,561 bytes   523,768 bytes   02:01:00.520
23              2:04:15.848     0:07:16.670     27,533 kbps     45,586 kbps     02:05:54.447    34,826 kbps     02:06:21.941    31,950 kbps     02:06:21.941    114,834 bytes   567,275 bytes   02:11:31.484
24              2:11:32.518     0:06:00.727     28,408 kbps     39,151 kbps     02:11:33.119    34,583 kbps     02:16:25.411    31,234 kbps     02:16:25.878    118,485 bytes   606,450 bytes   02:12:14.827
25              2:17:33.245     0:14:31.104     27,511 kbps     58,793 kbps     02:28:52.223    37,738 kbps     02:29:46.711    37,229 kbps     02:29:41.573    114,745 bytes   601,114 bytes   02:20:36.295
26              2:32:04.349     0:03:52.732     26,463 kbps     48,250 kbps     02:32:05.416    36,968 kbps     02:34:26.791    35,898 kbps     02:34:21.786    110,372 bytes   540,387 bytes   02:34:44.108
27              2:35:57.081     0:02:32.819     28,210 kbps     47,903 kbps     02:35:58.249    35,922 kbps     02:36:41.993    31,792 kbps     02:36:38.689    117,658 bytes   540,317 bytes   02:36:07.625
28              2:38:29.900     0:03:16.530     11,944 kbps     33,730 kbps     02:39:18.349    32,751 kbps     02:39:14.979    32,157 kbps     02:39:11.509    49,817 bytes    253,044 bytes   02:41:34.685
STREAM DIAGNOSTICS:
00008.M2TS      4113 (0x1011)   0x1B            9706.43         33,625,604,313  183,062,992     27,714
00008.M2TS      4352 (0x1100)   0x83            9706.43         2,653,537,522   20,598,782      2,187
00008.M2TS      4353 (0x1101)   0x83            9706.43         2,824,582,038   22,188,829      2,328
00008.M2TS      4608 (0x1200)   0x90            9706.43         58,668,204      333,026         48
00008.M2TS      4609 (0x1201)   0x90            9706.43         37,413,788      215,363         31
House is offline
post #560 of 1971 Old 07-28-2008, 10:58 AM
Phloyd's Avatar
Those bitrate peak graphs are cool.
Does anyone have one handy for a Warner recycled HD DVD encode?
It would be really interesting to see how the peaks are for the dual purpose encodes vs Fool's Gold for example.
Phloyd is offline
post #561 of 1971 Old 07-28-2008, 12:14 PM
House's Avatar
Code:
        Total   Video
Ghost in the Shell: Stand Alone Complex - Solid State Society   AVC     1:48:34 31,098,636,288  31,468,634,008  38.19   29.96   Dolby TrueHD 5.1 1667Kbps (48kHz/16-bit)
Code:
DISC INFO:
Disc Size:      31,468,634,008 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:48:34 (h:m:s)
Total Bitrate:  38.19 Mbps
Description:
FILES:
00008.M2TS      31,098,636,288  1:48:34.508     0:00:00.000     1:48:34.508
VIDEO:
MPEG-4 AVC Video    29957 kbps      1080p / 23.976fps / 16:9 / High Profile 4.1
AUDIO:
Dolby TrueHD Audio              English         1667 kbps       5.1 / 48kHz / 16-bit / 1667kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby TrueHD Audio              Japanese        1548 kbps       5.1 / 48kHz / 16-bit / 1548kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
SUBTITLES:
Presentation Graphics           English         44 kbps
Presentation Graphics           Japanese        26 kbps
CHAPTERS:
1               0:00:00.000     0:05:16.525     30,790 kbps     41,577 kbps     00:03:14.986    33,895 kbps     00:00:21.647    32,508 kbps     00:00:21.688    160,523 bytes   480,109 bytes   00:02:47.793
2               0:05:16.525     0:01:30.507     30,791 kbps     45,595 kbps     00:06:28.013    37,635 kbps     00:06:27.345    35,435 kbps     00:06:26.928    160,530 bytes   461,746 bytes   00:06:32.142
3               0:06:47.032     0:08:17.705     30,913 kbps     36,503 kbps     00:12:05.558    32,228 kbps     00:12:15.193    31,509 kbps     00:06:47.032    161,167 bytes   474,716 bytes   00:07:17.479
4               0:15:04.737     0:06:32.642     30,889 kbps     54,913 kbps     00:15:06.322    34,358 kbps     00:16:13.181    32,823 kbps     00:16:13.181    161,039 bytes   515,057 bytes   00:15:07.281
5               0:21:37.379     0:01:29.632     30,871 kbps     37,031 kbps     00:22:51.412    32,277 kbps     00:22:47.408    31,585 kbps     00:22:42.403    160,947 bytes   477,205 bytes   00:22:59.128
6               0:23:07.011     0:01:49.901     30,955 kbps     37,362 kbps     00:23:26.405    32,466 kbps     00:23:55.100    31,751 kbps     00:23:55.267    161,388 bytes   520,171 bytes   00:24:37.935
7               0:24:56.912     0:04:18.175     30,929 kbps     36,561 kbps     00:28:29.583    31,868 kbps     00:25:12.511    31,420 kbps     00:25:07.506    161,249 bytes   545,492 bytes   00:27:05.541
8               0:29:15.087     0:03:28.374     30,866 kbps     37,458 kbps     00:29:16.046    32,387 kbps     00:29:24.680    31,476 kbps     00:31:39.731    160,920 bytes   466,402 bytes   00:32:18.728
9               0:32:43.461     0:05:25.993     30,780 kbps     53,061 kbps     00:35:04.686    37,080 kbps     00:35:04.728    34,042 kbps     00:35:04.644    160,471 bytes   563,399 bytes   00:33:23.668
10              0:38:09.454     0:03:16.780     30,901 kbps     35,277 kbps     00:40:44.484    31,639 kbps     00:40:06.529    31,320 kbps     00:40:44.484    161,105 bytes   347,379 bytes   00:41:20.395
11              0:41:26.234     0:02:03.790     30,833 kbps     38,131 kbps     00:42:33.176    32,222 kbps     00:42:33.009    31,597 kbps     00:43:00.745    160,751 bytes   509,997 bytes   00:41:34.492
12              0:43:30.024     0:05:03.136     30,941 kbps     44,153 kbps     00:46:04.220    37,699 kbps     00:46:03.803    34,630 kbps     00:46:03.803    161,310 bytes   566,720 bytes   00:47:02.028
13              0:48:33.160     0:04:18.300     30,953 kbps     39,795 kbps     00:49:29.592    33,997 kbps     00:49:28.841    32,492 kbps     00:49:28.632    161,373 bytes   502,213 bytes   00:49:52.323
14              0:52:51.460     0:04:43.700     30,883 kbps     40,207 kbps     00:53:03.806    33,661 kbps     00:53:03.806    32,305 kbps     00:53:03.555    161,011 bytes   518,551 bytes   00:55:22.236
15              0:57:35.160     0:03:37.300     30,908 kbps     42,913 kbps     00:58:46.773    34,160 kbps     01:00:31.670    32,913 kbps     01:00:11.358    161,141 bytes   520,372 bytes   01:00:51.690
16              1:01:12.460     0:03:21.368     30,925 kbps     45,498 kbps     01:02:42.217    34,164 kbps     01:02:42.217    32,501 kbps     01:02:42.217    161,229 bytes   519,283 bytes   01:02:38.296
17              1:04:33.828     0:02:57.219     30,892 kbps     40,484 kbps     01:07:12.820    32,650 kbps     01:07:08.816    31,864 kbps     01:07:03.811    161,055 bytes   523,485 bytes   01:06:36.784
18              1:07:31.047     0:03:32.546     30,962 kbps     39,635 kbps     01:08:27.478    32,590 kbps     01:08:27.687    31,761 kbps     01:08:18.469    161,423 bytes   464,643 bytes   01:07:37.470
19              1:11:03.593     0:02:38.658     30,866 kbps     42,911 kbps     01:12:20.169    36,099 kbps     01:13:04.297    33,331 kbps     01:13:03.963    160,921 bytes   505,755 bytes   01:12:36.435
20              1:13:42.251     0:04:34.941     30,889 kbps     41,995 kbps     01:17:05.538    37,145 kbps     01:17:04.829    33,500 kbps     01:17:05.204    161,040 bytes   446,823 bytes   01:16:58.405
21              1:18:17.192     0:03:10.816     30,874 kbps     39,951 kbps     01:21:00.522    32,833 kbps     01:19:04.615    32,011 kbps     01:20:51.263    160,964 bytes   616,595 bytes   01:20:59.313
22              1:21:28.008     0:03:01.181     30,943 kbps     41,150 kbps     01:22:09.383    33,237 kbps     01:22:18.851    32,387 kbps     01:22:12.553    161,322 bytes   513,504 bytes   01:22:34.116
23              1:24:29.189     0:02:09.922     30,849 kbps     37,451 kbps     01:25:29.124    34,140 kbps     01:24:51.753    32,493 kbps     01:24:51.169    160,831 bytes   466,203 bytes   01:24:39.866
24              1:26:39.111     0:02:28.815     30,898 kbps     37,734 kbps     01:26:46.410    32,226 kbps     01:26:42.656    31,525 kbps     01:28:56.706    161,091 bytes   447,658 bytes   01:26:56.837
25              1:29:07.926     0:07:53.848     30,664 kbps     57,026 kbps     01:34:23.449    38,529 kbps     01:34:23.449    34,965 kbps     01:34:23.449    159,866 bytes   534,792 bytes   01:34:23.491
26              1:37:01.774     0:02:00.079     30,671 kbps     50,957 kbps     01:37:03.985    34,881 kbps     01:37:03.109    32,610 kbps     01:37:02.859    159,903 bytes   480,864 bytes   01:37:28.634
27              1:39:01.853     0:04:35.316     30,909 kbps     38,579 kbps     01:42:26.766    33,521 kbps     01:42:29.685    32,008 kbps     01:42:29.352    161,143 bytes   616,760 bytes   01:39:21.372
28              1:43:37.169     0:04:57.339     10,896 kbps     37,472 kbps     01:43:59.066    31,556 kbps     01:43:40.923    31,141 kbps     01:43:38.712    56,809 bytes    469,802 bytes   01:43:59.233
STREAM DIAGNOSTICS:
00008.M2TS      4113 (0x1011)   0x1B            6514.51         24,394,344,324  132,669,641     29,957
00008.M2TS      4352 (0x1100)   0x83            6514.51         1,781,971,958   13,906,469      2,188
00008.M2TS      4353 (0x1101)   0x83            6514.51         1,878,817,290   14,856,596      2,307
00008.M2TS      4608 (0x1200)   0x90            6514.51         35,500,984      200,504         44
00008.M2TS      4609 (0x1201)   0x90            6514.51         20,950,959      120,586         26
House is offline
post #562 of 1971 Old 07-28-2008, 05:05 PM
msgohan's Avatar
Code:
        Total   Video
Hmm so is the THD really 24-bit? Why is the 16-bit track listed first? And are the 2.0 tracks still the regular movie audio?
Still not the highest TBR or AVBR.
Code:
        Total   Video
Batman Begins                                                   VC-1    2:20:02 23,792,474,112  35,125,025,347  22.65   13.69   Dolby TrueHD 5.1 1551Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      35,125,025,347 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         2:20:02 (h:m:s)
Total Bitrate:  22.65 Mbps
Description:
FILES:
00000.M2TS      23,792,474,112  2:20:02.852     0:00:00.000     2:20:02.852
VIDEO:
VC-1 Video          13692 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
VC-1 Video          634 kbps        480p / 23.976fps / 4:3 / Advanced Profile 2
AUDIO:
Dolby TrueHD Audio              English         1551 kbps       5.1 / 48kHz / 16-bit / 1551kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             Japanese        640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Audio             Portuguese      640 kbps        5.1 / 48kHz / 640kbps
Dolby Digital Plus Audio        English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         37 kbps
Presentation Graphics           English         28 kbps
Presentation Graphics           Chinese         23 kbps
Presentation Graphics           Chinese         30 kbps
Presentation Graphics           French          32 kbps
Presentation Graphics           French          17 kbps
Presentation Graphics           Japanese        20 kbps
Presentation Graphics           Japanese        0 kbps
Presentation Graphics           Japanese        21 kbps
Presentation Graphics           Korean          15 kbps
Presentation Graphics           Korean          22 kbps
Presentation Graphics           Portuguese      25 kbps
Presentation Graphics           Portuguese      34 kbps
Presentation Graphics           Portuguese      17 kbps
Presentation Graphics           Spanish         25 kbps
Presentation Graphics           Spanish         33 kbps
Presentation Graphics           Spanish         16 kbps
CHAPTERS:
1               0:00:00.000     0:03:39.219     14,333 kbps     27,142 kbps     00:00:21.897    21,301 kbps     00:00:18.018    19,242 kbps     00:01:14.783    74,728 bytes    277,762 bytes   00:01:15.659
2               0:03:39.219     0:03:51.898     15,709 kbps     25,754 kbps     00:07:21.024    20,938 kbps     00:07:20.940    19,850 kbps     00:07:12.807    81,901 bytes    341,630 bytes   00:05:28.954
3               0:07:31.117     0:04:02.910     15,366 kbps     26,640 kbps     00:07:47.300    21,039 kbps     00:10:14.823    20,025 kbps     00:07:50.845    80,111 bytes    360,799 bytes   00:07:48.009
4               0:11:34.027     0:04:41.614     15,725 kbps     25,010 kbps     00:16:04.630    21,383 kbps     00:15:48.614    20,246 kbps     00:16:03.671    81,981 bytes    318,760 bytes   00:12:32.377
5               0:16:15.641     0:03:28.709     15,657 kbps     24,141 kbps     00:17:32.385    20,317 kbps     00:18:37.450    19,270 kbps     00:18:37.408    81,630 bytes    326,622 bytes   00:16:58.809
6               0:19:44.350     0:04:34.941     16,038 kbps     22,757 kbps     00:22:52.204    20,149 kbps     00:22:39.817    19,389 kbps     00:23:57.686    83,614 bytes    330,054 bytes   00:21:01.385
7               0:24:19.291     0:04:05.412     12,703 kbps     22,880 kbps     00:25:38.412    18,310 kbps     00:25:36.869    17,308 kbps     00:25:29.486    66,230 bytes    311,187 bytes   00:24:43.774
8               0:28:24.703     0:03:00.680     12,516 kbps     19,294 kbps     00:31:13.705    18,435 kbps     00:31:13.371    18,343 kbps     00:31:13.371    65,253 bytes    262,447 bytes   00:31:22.756
9               0:31:25.383     0:04:28.435     14,879 kbps     22,819 kbps     00:35:10.942    20,010 kbps     00:35:10.692    18,947 kbps     00:34:58.430    77,575 bytes    302,369 bytes   00:35:06.062
10              0:35:53.818     0:02:30.818     15,182 kbps     19,306 kbps     00:37:59.277    17,812 kbps     00:38:08.411    16,882 kbps     00:38:03.364    79,150 bytes    314,440 bytes   00:37:59.319
11              0:38:24.636     0:02:50.003     15,698 kbps     27,268 kbps     00:39:39.294    21,404 kbps     00:39:38.042    20,109 kbps     00:40:02.609    81,840 bytes    302,446 bytes   00:39:38.751
12              0:41:14.639     0:01:53.613     12,948 kbps     19,120 kbps     00:41:16.516    18,540 kbps     00:41:14.639    17,431 kbps     00:41:14.639    67,506 bytes    186,881 bytes   00:41:29.904
13              0:43:08.252     0:03:49.730     15,363 kbps     26,729 kbps     00:44:21.284    21,623 kbps     00:46:51.600    19,842 kbps     00:46:46.804    80,096 bytes    363,179 bytes   00:44:21.325
14              0:46:57.982     0:02:45.999     14,025 kbps     19,185 kbps     00:48:58.561    17,305 kbps     00:48:56.142    16,927 kbps     00:48:55.266    73,119 bytes    290,768 bytes   00:48:09.303
15              0:49:43.981     0:03:42.222     14,041 kbps     23,139 kbps     00:52:41.408    18,496 kbps     00:52:26.226    17,870 kbps     00:52:26.018    73,203 bytes    331,110 bytes   00:50:15.471
16              0:53:26.203     0:02:28.815     16,165 kbps     23,459 kbps     00:55:25.239    21,419 kbps     00:55:21.735    20,108 kbps     00:55:17.064    84,277 bytes    319,600 bytes   00:55:36.959
17              0:55:55.018     0:02:07.127     12,578 kbps     25,145 kbps     00:57:25.651    19,097 kbps     00:57:10.677    18,697 kbps     00:57:09.760    65,576 bytes    332,725 bytes   00:57:12.054
18              0:58:02.145     0:05:29.663     12,584 kbps     19,683 kbps     00:59:56.843    18,027 kbps     00:59:53.507    16,519 kbps     00:59:48.335    65,608 bytes    327,905 bytes   00:59:57.719
19              1:03:31.808     0:02:21.308     14,022 kbps     20,726 kbps     01:05:37.600    19,345 kbps     01:05:32.011    18,296 kbps     01:05:32.011    73,105 bytes    310,156 bytes   01:05:34.389
20              1:05:53.116     0:02:45.665     14,475 kbps     21,845 kbps     01:07:32.298    20,515 kbps     01:07:27.627    18,164 kbps     01:07:27.585    75,467 bytes    317,916 bytes   01:07:29.420
21              1:08:38.781     0:02:47.000     9,982 kbps      15,961 kbps     01:09:53.439    14,151 kbps     01:08:39.115    12,852 kbps     01:08:38.781    52,043 bytes    211,884 bytes   01:08:43.995
22              1:11:25.781     0:01:53.781     13,894 kbps     19,247 kbps     01:11:36.209    17,700 kbps     01:11:33.289    17,264 kbps     01:11:28.034    72,435 bytes    289,748 bytes   01:11:37.418
23              1:13:19.562     0:02:56.676     12,541 kbps     25,369 kbps     01:14:52.530    17,456 kbps     01:16:11.108    16,710 kbps     01:15:41.954    65,383 bytes    290,243 bytes   01:13:52.803
24              1:16:16.238     0:03:34.047     15,390 kbps     27,255 kbps     01:16:39.303    21,067 kbps     01:16:39.303    19,608 kbps     01:16:38.886    80,235 bytes    289,080 bytes   01:17:04.662
25              1:19:50.285     0:04:04.078     13,708 kbps     20,995 kbps     01:22:38.370    19,399 kbps     01:22:47.045    18,325 kbps     01:22:42.457    71,466 bytes    303,067 bytes   01:20:26.447
26              1:23:54.363     0:05:08.308     14,134 kbps     23,305 kbps     01:27:57.772    18,959 kbps     01:27:33.373    18,048 kbps     01:27:10.851    73,690 bytes    211,393 bytes   01:24:02.496
27              1:29:02.671     0:03:34.047     16,487 kbps     29,470 kbps     01:32:30.462    21,615 kbps     01:32:26.958    19,680 kbps     01:32:21.786    85,957 bytes    281,909 bytes   01:30:00.103
28              1:32:36.718     0:05:12.312     16,767 kbps     30,920 kbps     01:33:32.690    21,175 kbps     01:34:42.760    20,383 kbps     01:36:05.093    87,418 bytes    245,659 bytes   01:33:29.354
29              1:37:49.030     0:02:44.664     12,096 kbps     17,252 kbps     01:38:20.978    15,281 kbps     01:38:25.149    14,171 kbps     01:38:50.258    63,063 bytes    226,177 bytes   01:37:55.411
30              1:40:33.694     0:04:35.275     11,940 kbps     22,111 kbps     01:41:17.989    20,814 kbps     01:41:17.989    18,108 kbps     01:41:15.152    62,251 bytes    210,476 bytes   01:40:40.076
31              1:45:08.969     0:04:23.096     12,031 kbps     26,256 kbps     01:48:33.257    19,194 kbps     01:48:32.631    18,282 kbps     01:48:25.666    62,723 bytes    236,466 bytes   01:48:51.900
32              1:49:32.065     0:01:57.117     15,626 kbps     22,479 kbps     01:50:30.040    20,204 kbps     01:49:40.157    18,394 kbps     01:49:36.069    81,468 bytes    305,769 bytes   01:49:34.943
33              1:51:29.182     0:03:19.867     13,887 kbps     23,175 kbps     01:54:40.040    19,874 kbps     01:54:39.790    17,604 kbps     01:52:18.023    72,400 bytes    263,416 bytes   01:52:42.714
34              1:54:49.049     0:03:22.035     14,997 kbps     29,376 kbps     01:56:24.352    20,703 kbps     01:56:49.502    19,515 kbps     01:56:15.302    78,186 bytes    333,672 bytes   01:57:58.780
35              1:58:11.084     0:03:43.890     15,737 kbps     26,082 kbps     02:00:22.048    20,745 kbps     01:59:21.738    19,967 kbps     02:00:06.991    82,047 bytes    311,017 bytes   02:01:45.340
36              2:01:54.974     0:03:06.186     15,940 kbps     25,105 kbps     02:02:51.739    21,148 kbps     02:02:49.028    19,859 kbps     02:02:02.482    83,104 bytes    342,261 bytes   02:04:30.838
37              2:05:01.160     0:01:05.733     13,969 kbps     24,466 kbps     02:05:29.439    20,703 kbps     02:05:28.312    18,261 kbps     02:05:23.850    72,829 bytes    221,065 bytes   02:06:06.768
38              2:06:06.893     0:03:11.524     16,436 kbps     23,974 kbps     02:09:00.232    20,329 kbps     02:08:57.897    18,572 kbps     02:07:20.341    85,692 bytes    310,397 bytes   02:08:59.690
39              2:09:18.417     0:01:38.599     16,880 kbps     21,707 kbps     02:09:31.305    20,243 kbps     02:10:02.712    19,724 kbps     02:09:59.792    88,003 bytes    247,520 bytes   02:09:31.806
40              2:10:57.016     0:09:05.837     2,913 kbps      18,387 kbps     02:19:56.346    10,983 kbps     02:19:55.887    6,001 kbps      02:19:50.924    15,185 bytes    305,367 bytes   02:19:56.513
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            8402.85         14,381,704,800  78,282,149      13,692
00000.M2TS      4352 (0x1100)   0x81            8402.85         672,232,960     3,938,865       640
00000.M2TS      4353 (0x1101)   0x83            8402.85         2,301,765,556   17,729,867      2,191
00000.M2TS      4354 (0x1102)   0x81            8402.85         672,232,960     3,938,865       640
00000.M2TS      4355 (0x1103)   0x81            8402.85         672,232,960     3,938,865       640
00000.M2TS      4356 (0x1104)   0x81            8402.85         672,232,960     3,938,865       640
00000.M2TS      4357 (0x1105)   0x81            8402.85         672,232,960     3,938,865       640
00000.M2TS      4608 (0x1200)   0x90            8402.85         21,105,301      123,764         20
00000.M2TS      4609 (0x1201)   0x90            8402.85         29,417,205      169,168         28
00000.M2TS      4610 (0x1202)   0x90            8402.85         22,205,804      129,314         21
00000.M2TS      4611 (0x1203)   0x90            8402.85         23,708,392      137,644         23
00000.M2TS      4612 (0x1204)   0x90            8402.85         15,439,834      92,224          15
00000.M2TS      4613 (0x1205)   0x90            8402.85         25,972,036      149,913         25
00000.M2TS      4614 (0x1206)   0x90            8402.85         26,399,577      152,142         25
00000.M2TS      4615 (0x1207)   0x90            8402.85         109,035         764             0
00000.M2TS      4616 (0x1208)   0x90            8402.85         36,736,453      213,449         35
00000.M2TS      4617 (0x1209)   0x90            8402.85         39,315,820      224,289         37
00000.M2TS      4618 (0x120A)   0x90            8402.85         33,412,563      192,058         32
00000.M2TS      4619 (0x120B)   0x90            8402.85         31,911,190      184,037         30
00000.M2TS      4620 (0x120C)   0x90            8402.85         23,177,491      136,149         22
00000.M2TS      4621 (0x120D)   0x90            8402.85         34,537,128      198,286         33
00000.M2TS      4622 (0x120E)   0x90            8402.85         35,773,455      204,972         34
00000.M2TS      4623 (0x120F)   0x90            8402.85         22,357,821      129,193         21
00000.M2TS      4624 (0x1210)   0x90            8402.85         18,163,434      103,220         17
00000.M2TS      4625 (0x1211)   0x90            8402.85         16,691,035      95,244          16
00000.M2TS      4626 (0x1212)   0x90            8402.85         17,579,196      100,077         17
00000.M2TS      6656 (0x1A00)   0xA1            8402.85         201,668,352     1,312,945       192
00000.M2TS      6912 (0x1B00)   0xEA            8402.85         666,271,767     3,793,014       634
Cinema Squid: Why do the graphs default to JPEG? PNG is actually smaller from my test, not to mention devoid of the artifacts. Also would it be possible to add the disc ID label to the disc info when the source is a real/virtual drive?
Oh, and I see what you mean about the stream diagnostics showing the subtitle info i.e. for the "0kbps" Japanese track here. Don't forget to increase the precision there as well.
msgohan is offline
post #563 of 1971 Old 07-28-2008, 06:36 PM
Patsfan123's Avatar
Originally Posted by lgans316 View Post
Cinema Squid,
With reference to this post, may I know how Dolby TrueHD 5.1 @ 1970Kbps was conditionally analyzed as 48kHz/24-bit ?
http://www.avsforum.com/avs-vb/showt...0#post14382180
That is no doubt 16-bit. It would need to be at least 2800kbps to be 24-bit.
Michael
post #564 of 1971 Old 07-28-2008, 07:18 PM
Cinema Squid,
The current bit depth guess works off of one second audio peaks (as of 0.3+ and unchanged in 0.4 - the 0.2 series used averages), so that must have crossed the threshold which currently is set to 3456 kbps. I am kind of tempted to just punt on tagging these entirely since it is just a guess and, as madshi pointed out, perhaps not a realistic representation of the true bit depth even when the guess is "correct".
However, one piece of evidence that lends support to the argument that this title's TrueHD track might be > 16-bit is that it is bigger than the DTS-MA track which I wouldn't think would ever happen in an apples-to-apples comparison. A more definitive answer could be supplied by eac3to.
post #565 of 1971 Old 07-28-2008, 11:33 PM
Xylon's Avatar
Xylon is offline
post #566 of 1971 Old 07-29-2008, 04:42 PM
Patsfan123's Avatar
Code:
DTS-HD Master Audio (lossless compression) 24-bit/48kHz
        Advertised
        Total   Video   Video
Title                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Bitrate Main Audio Track                                Secondary Audio Track
Doomsday                                        VC-1    1:52:50 23,526,979,584  24,428,481,128  27.80   20.09           DTS-HD Master 5.1 4681Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      24,428,481,128 bytes
Protection:     AACS
BD-Java:        Yes
PLAYLIST REPORT:
Length:         1:52:50 (h:m:s)
Total Bitrate:  27.80 Mbps
Description:
FILES:
00000.M2TS      23,526,979,584  1:52:50.805     0:00:00.000     1:52:50.805
VIDEO:
VC-1 Video          20088 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
VC-1 Video          861 kbps        480p / 23.976fps / 4:3 / Advanced Profile 2
VC-1 Video          145 kbps        480p / 23.976fps / 16:9 / Advanced Profile 2
AUDIO:
DTS-HD Master Audio             English         4681 kbps       5.1 / 48kHz / 24-bit / 4681kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
Dolby Digital Audio             English         192 kbps        2.0 / 48kHz / 192kbps
DTS-HD Audio                    English         192 kbps        2.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         27 kbps
Presentation Graphics           French          24 kbps
Presentation Graphics           Spanish         22 kbps
CHAPTERS:
1               0:00:00.000     0:06:13.123     23,003 kbps     51,536 kbps     00:02:21.266    35,823 kbps     00:00:44.628    34,423 kbps     00:00:39.623    119,928 bytes   526,765 bytes   00:03:23.245
2               0:06:13.123     0:07:12.515     19,515 kbps     38,309 kbps     00:06:28.013    32,220 kbps     00:06:24.301    29,263 kbps     00:06:23.133    101,743 bytes   494,867 bytes   00:06:32.142
3               0:13:25.638     0:04:31.438     17,972 kbps     40,454 kbps     00:13:48.703    32,998 kbps     00:13:45.742    27,531 kbps     00:13:45.742    93,696 bytes    386,028 bytes   00:13:47.535
4               0:17:57.076     0:07:30.325     22,127 kbps     45,025 kbps     00:19:40.971    37,832 kbps     00:21:17.067    32,582 kbps     00:21:15.483    115,359 bytes   471,721 bytes   00:22:40.025
5               0:25:27.401     0:05:25.742     18,082 kbps     39,349 kbps     00:26:49.399    30,882 kbps     00:26:33.467    29,004 kbps     00:26:42.768    94,270 bytes    347,496 bytes   00:26:59.827
6               0:30:53.143     0:05:48.640     16,373 kbps     53,587 kbps     00:34:11.174    28,621 kbps     00:34:07.128    24,744 kbps     00:34:03.625    85,363 bytes    386,549 bytes   00:34:07.754
7               0:36:41.783     0:07:51.262     21,923 kbps     50,018 kbps     00:38:34.103    34,624 kbps     00:38:47.617    31,024 kbps     00:38:47.200    114,297 bytes   532,551 bytes   00:38:34.646
8               0:44:33.045     0:05:38.338     17,681 kbps     26,032 kbps     00:44:34.130    22,281 kbps     00:46:48.931    20,647 kbps     00:45:05.828    92,181 bytes    294,771 bytes   00:48:50.970
9               0:50:11.383     0:07:06.969     23,631 kbps     46,377 kbps     00:56:23.839    38,574 kbps     00:56:23.255    33,638 kbps     00:56:22.212    123,201 bytes   457,594 bytes   00:56:23.880
10              0:57:18.352     0:02:54.132     20,917 kbps     38,371 kbps     00:59:51.379    28,265 kbps     00:59:49.211    27,466 kbps     00:59:41.995    109,051 bytes   352,846 bytes   00:59:51.713
11              1:00:12.484     0:06:29.264     21,455 kbps     49,266 kbps     01:02:04.596    36,113 kbps     01:03:05.365    34,317 kbps     01:03:03.738    111,859 bytes   477,785 bytes   01:02:04.804
12              1:06:41.748     0:06:35.937     17,976 kbps     47,311 kbps     01:08:09.961    32,215 kbps     01:08:08.418    29,597 kbps     01:08:10.044    93,721 bytes    515,073 bytes   01:06:53.218
13              1:13:17.685     0:03:41.096     18,086 kbps     50,932 kbps     01:16:05.352    36,266 kbps     01:16:03.559    31,359 kbps     01:15:59.013    94,292 bytes    562,856 bytes   01:16:05.519
14              1:16:58.781     0:06:01.027     20,336 kbps     54,187 kbps     01:19:47.700    36,383 kbps     01:19:01.195    31,894 kbps     01:20:55.726    106,020 bytes   665,376 bytes   01:21:39.895
15              1:22:59.808     0:05:33.875     22,919 kbps     48,742 kbps     01:24:24.226    36,129 kbps     01:24:23.433    33,585 kbps     01:24:24.226    119,492 bytes   658,526 bytes   01:24:54.798
16              1:28:33.683     0:03:58.155     25,642 kbps     47,383 kbps     01:30:25.295    37,427 kbps     01:30:25.295    35,803 kbps     01:30:49.235    133,683 bytes   514,694 bytes   01:31:26.481
17              1:32:31.838     0:05:16.483     27,580 kbps     53,130 kbps     01:37:17.498    38,312 kbps     01:35:16.252    35,627 kbps     01:35:33.478    143,790 bytes   606,240 bytes   01:37:02.734
18              1:37:48.321     0:03:43.640     19,515 kbps     45,249 kbps     01:38:03.419    36,709 kbps     01:37:59.415    33,442 kbps     01:37:54.452    101,742 bytes   476,321 bytes   01:37:52.075
19              1:41:31.961     0:03:33.880     19,271 kbps     43,286 kbps     01:43:13.479    38,480 kbps     01:43:13.062    32,188 kbps     01:43:13.062    100,471 bytes   672,418 bytes   01:43:20.111
20              1:45:05.841     0:07:44.965     10,152 kbps     30,332 kbps     01:45:06.175    26,694 kbps     01:45:05.925    24,158 kbps     01:45:05.841    52,928 bytes    347,358 bytes   01:47:16.096
STREAM DIAGNOSTICS:
00000.M2TS      4113 (0x1011)   0xEA            6770.81         17,001,654,651  92,498,399      20,088
00000.M2TS      4352 (0x1100)   0x86            6770.81         3,961,786,844   22,587,249      4,681
00000.M2TS      4353 (0x1101)   0x81            6770.81         162,499,584     1,057,940       192
00000.M2TS      4608 (0x1200)   0x90            6770.81         23,190,177      132,679         27
00000.M2TS      4609 (0x1201)   0x90            6770.81         18,537,515      106,395         22
00000.M2TS      4610 (0x1202)   0x90            6770.81         20,632,688      117,853         24
00000.M2TS      6912 (0x1B00)   0xEA            6770.81         728,388,105     4,071,141       861
00000.M2TS      6913 (0x1B01)   0xEA            6770.81         122,956,295     785,695         145
00000.M2TS      6656 (0x1A00)   0xA2            6770.81         162,500,608     952,152         192
Michael
post #567 of 1971 Old 07-29-2008, 09:19 PM
Thanks for the Doomsday specs - I'll probably just be renting this one, but it looks intriguing. Two PiP video tracks - yikes. At least the tool seems to be surviving the U-Control gauntlet thus far...
Also, this remind me. I was thinking of labeling the DTS-HD PiP audio tracks for these Profile 1.1 titles as "DTS Express" instead of DTS-HD since that seems to be the accepted marketing term for them. That should make them stand out a little bit more (like the DD+ tracks which serve a similar role). They do have a separate stream type identification code from DTS-HD HR and MA, although I'm not sure if they're actually internally different from a regular DTS-HD Hi-Res track.
post #568 of 1971 Old 07-30-2008, 06:40 AM
Aaron*C's Avatar
Code:
        Total   Video
The Lost Boys                                                   VC-1    1:37:26 17,221,939,200  26,668,952,324  23.57   16.58   Dolby TrueHD 5.1 1778Kbps (48kHz/16-bit)  DD AC3 5.1 640Kbps
Code:
DISC INFO:
Disc Size:      26,668,952,324 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:37:26 (h:m:s)
Total Bitrate:  23.57 Mbps
Description:
FILES:
00056.M2TS      17,221,939,200  1:37:26.507     0:00:00.000     1:37:26.507
VIDEO:
VC-1 Video          16581 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
Dolby TrueHD Audio              English         1778 kbps       5.1 / 48kHz / 16-bit / 1778kbps (AC3 Core: 5.1 / 48kHz / 640kbps)
Dolby Digital Audio             French          192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             German          192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             Italian         192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             Spanish         192 kbps        2.0 / 48kHz / 192kbps
Dolby Digital Audio             Spanish         192 kbps        1.0 / 48kHz / 192kbps
SUBTITLES:
Presentation Graphics           English         30 kbps
Presentation Graphics           Danish          19 kbps
Presentation Graphics           Dutch           19 kbps
Presentation Graphics           Finnish         19 kbps
Presentation Graphics           French          18 kbps
Presentation Graphics           German          26 kbps
Presentation Graphics           Italian         20 kbps
Presentation Graphics           Italian         23 kbps
Presentation Graphics           Japanese        17 kbps
Presentation Graphics           Japanese        34 kbps
Presentation Graphics           Norwegian       19 kbps
Presentation Graphics           Portuguese      22 kbps
Presentation Graphics           Portuguese      21 kbps
Presentation Graphics           Spanish         23 kbps
Presentation Graphics           Spanish         19 kbps
Presentation Graphics           Swedish         19 kbps
CHAPTERS:
1               0:00:00.000     0:03:09.022     15,503 kbps     26,446 kbps     00:00:58.141    22,986 kbps     00:00:56.223    21,201 kbps     00:02:01.496    80,825 bytes    212,268 bytes   00:00:59.935
2               0:03:09.022     0:03:14.528     17,718 kbps     33,448 kbps     00:05:11.478    25,999 kbps     00:06:04.364    25,628 kbps     00:06:03.780    92,373 bytes    293,600 bytes   00:05:52.018
3               0:06:23.550     0:03:14.861     15,989 kbps     29,704 kbps     00:06:53.413    27,965 kbps     00:06:51.161    23,931 kbps     00:08:04.943    83,360 bytes    309,863 bytes   00:06:54.122
4               0:09:38.411     0:04:17.924     17,376 kbps     29,731 kbps     00:12:16.569    26,703 kbps     00:12:15.985    23,518 kbps     00:12:15.985    90,588 bytes    268,093 bytes   00:12:16.027
5               0:13:56.335     0:01:46.941     16,444 kbps     23,665 kbps     00:14:51.015    19,373 kbps     00:14:40.546    18,703 kbps     00:14:00.339    85,730 bytes    278,330 bytes   00:14:58.773
6               0:15:43.276     0:01:23.583     15,121 kbps     21,179 kbps     00:16:22.440    19,176 kbps     00:16:19.145    17,157 kbps     00:16:19.228    78,835 bytes    265,041 bytes   00:15:43.901
7               0:17:06.859     0:01:53.447     14,676 kbps     25,314 kbps     00:18:55.718    21,972 kbps     00:18:53.382    19,517 kbps     00:18:26.564    76,515 bytes    232,848 bytes   00:18:58.387
8               0:19:00.306     0:02:16.970     17,539 kbps     28,840 kbps     00:19:26.457    24,731 kbps     00:20:08.958    24,222 kbps     00:20:05.162    91,440 bytes    280,749 bytes   00:19:21.744
9               0:21:17.276     0:02:26.646     15,918 kbps     28,192 kbps     00:22:45.781    24,137 kbps     00:22:42.069    21,053 kbps     00:22:37.022    82,987 bytes    243,678 bytes   00:23:43.922
10              0:23:43.922     0:04:10.084     14,652 kbps     30,747 kbps     00:26:10.569    28,585 kbps     00:26:08.817    27,030 kbps     00:26:05.898    76,390 bytes    264,985 bytes   00:24:07.780
11              0:27:54.006     0:02:27.814     12,322 kbps     19,143 kbps     00:28:04.808    16,453 kbps     00:28:01.054    15,130 kbps     00:27:58.677    64,244 bytes    175,572 bytes   00:27:59.928
12              0:30:21.820     0:04:49.789     15,128 kbps     25,761 kbps     00:30:30.787    21,208 kbps     00:30:59.232    19,862 kbps     00:30:54.561    78,871 bytes    218,409 bytes   00:35:11.526
13              0:35:11.609     0:06:26.887     15,418 kbps     27,162 kbps     00:39:18.856    22,632 kbps     00:39:16.479    21,091 kbps     00:39:13.393    80,383 bytes    278,685 bytes   00:38:49.035
14              0:41:38.496     0:05:08.975     18,377 kbps     29,972 kbps     00:44:49.437    28,393 kbps     00:45:07.747    27,447 kbps     00:45:07.747    95,810 bytes    297,069 bytes   00:46:47.513
15              0:46:47.471     0:01:12.072     19,795 kbps     29,200 kbps     00:46:50.141    27,249 kbps     00:46:48.014    26,462 kbps     00:46:48.014    103,201 bytes   298,982 bytes   00:47:05.031
16              0:47:59.543     0:02:51.839     16,605 kbps     23,094 kbps     00:48:23.275    21,056 kbps     00:50:19.099    19,996 kbps     00:48:23.359    86,569 bytes    279,138 bytes   00:50:51.382
17              0:50:51.382     0:01:19.245     13,640 kbps     30,441 kbps     00:51:47.730    25,115 kbps     00:52:03.829    23,445 kbps     00:52:00.617    71,112 bytes    333,127 bytes   00:51:47.855
18              0:52:10.627     0:02:30.484     18,271 kbps     29,361 kbps     00:54:21.258    27,042 kbps     00:54:19.715    25,438 kbps     00:54:19.715    95,256 bytes    279,532 bytes   00:52:22.639
19              0:54:41.111     0:04:55.796     21,208 kbps     34,397 kbps     00:57:29.905    27,767 kbps     00:55:14.728    26,499 kbps     00:57:17.309    110,566 bytes   307,671 bytes   00:58:33.176
20              0:59:36.907     0:03:49.896     20,343 kbps     38,099 kbps     01:02:22.364    31,007 kbps     01:02:19.694    28,075 kbps     01:02:19.361    106,061 bytes   352,264 bytes   01:02:22.989
21              1:03:26.803     0:02:42.996     19,506 kbps     29,270 kbps     01:04:29.866    25,599 kbps     01:05:42.897    25,248 kbps     01:05:36.683    101,694 bytes   283,115 bytes   01:03:36.479
22              1:06:09.799     0:06:06.032     16,358 kbps     39,344 kbps     01:06:10.675    32,802 kbps     01:06:09.799    30,333 kbps     01:06:09.799    85,281 bytes    362,073 bytes   01:07:03.895
23              1:12:15.831     0:02:31.151     18,021 kbps     37,718 kbps     01:12:25.299    28,480 kbps     01:12:22.129    26,840 kbps     01:12:17.124    93,952 bytes    345,212 bytes   01:12:36.644
24              1:14:46.982     0:03:23.537     18,299 kbps     30,566 kbps     01:16:05.269    27,031 kbps     01:17:56.547    25,589 kbps     01:16:03.392    95,404 bytes    288,127 bytes   01:17:59.216
25              1:18:10.519     0:01:55.949     18,132 kbps     26,474 kbps     01:19:57.376    23,767 kbps     01:19:33.102    21,382 kbps     01:19:28.097    94,534 bytes    284,950 bytes   01:19:58.293
26              1:20:06.468     0:01:23.751     20,747 kbps     33,924 kbps     01:20:46.383    29,077 kbps     01:20:46.383    26,157 kbps     01:21:03.025    108,163 bytes   317,761 bytes   01:21:08.363
27              1:21:30.219     0:01:50.610     18,921 kbps     34,435 kbps     01:23:03.937    26,863 kbps     01:23:11.069    25,645 kbps     01:23:03.937    98,643 bytes    291,671 bytes   01:22:12.678
28              1:23:20.829     0:01:26.587     18,694 kbps     29,256 kbps     01:23:43.227    23,985 kbps     01:23:33.884    21,947 kbps     01:23:34.176    97,459 bytes    279,761 bytes   01:23:43.769
29              1:24:47.416     0:02:43.830     20,345 kbps     41,021 kbps     01:25:37.466    31,141 kbps     01:26:48.120    29,600 kbps     01:26:40.153    106,071 bytes   388,689 bytes   01:25:37.758
30              1:27:31.246     0:02:38.825     16,272 kbps     28,469 kbps     01:28:11.411    26,327 kbps     01:28:27.886    23,618 kbps     01:28:25.217    84,835 bytes    298,263 bytes   01:28:49.366
31              1:30:10.071     0:02:48.168     18,666 kbps     41,331 kbps     01:31:12.509    28,895 kbps     01:31:09.506    25,770 kbps     01:31:04.918    97,318 bytes    278,303 bytes   01:31:12.550
32              1:32:58.239     0:04:28.268     2,773 kbps      19,706 kbps     01:32:59.407    19,268 kbps     01:32:58.656    12,671 kbps     01:32:58.281    14,457 bytes    174,483 bytes   01:33:00.033
STREAM DIAGNOSTICS:
00056.M2TS      4113 (0x1011)   0xEA            5846.51         12,117,386,958  65,939,514      16,581
00056.M2TS      4352 (0x1100)   0x81            5846.51         467,722,240     2,740,560       640
00056.M2TS      4353 (0x1101)   0x83            5846.51         1,766,801,596   13,815,231      2,418
00056.M2TS      4354 (0x1102)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4355 (0x1103)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4356 (0x1104)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4357 (0x1105)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4358 (0x1106)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4359 (0x1107)   0x81            5846.51         140,316,672     913,520         192
00056.M2TS      4608 (0x1200)   0x90            5846.51         12,294,574      72,600          17
00056.M2TS      4609 (0x1201)   0x90            5846.51         21,868,182      126,062         30
00056.M2TS      4610 (0x1202)   0x90            5846.51         12,931,773      75,687          18
00056.M2TS      4611 (0x1203)   0x90            5846.51         19,095,073      110,843         26
00056.M2TS      4612 (0x1204)   0x90            5846.51         14,268,431      82,791          20
00056.M2TS      4613 (0x1205)   0x90            5846.51         16,850,999      97,657          23
00056.M2TS      4614 (0x1206)   0x90            5846.51         16,478,852      95,348          23
00056.M2TS      4615 (0x1207)   0x90            5846.51         13,572,569      79,001          19
00056.M2TS      4616 (0x1208)   0x90            5846.51         13,572,246      78,734          19
00056.M2TS      4617 (0x1209)   0x90            5846.51         16,082,397      92,544          22
00056.M2TS      4618 (0x120A)   0x90            5846.51         13,765,853      80,053          19
00056.M2TS      4619 (0x120B)   0x90            5846.51         13,802,753      80,295          19
00056.M2TS      4620 (0x120C)   0x90            5846.51         13,585,722      79,114          19
00056.M2TS      4621 (0x120D)   0x90            5846.51         15,479,779      89,352          21
00056.M2TS      4622 (0x120E)   0x90            5846.51         13,958,972      80,869          19
00056.M2TS      4623 (0x120F)   0x90            5846.51         24,868,888      142,130         34
Code:
        Total   Video
Harold and Kumar Go to White Castle                             VC-1    1:28:23 22,538,164,224  35,123,532,920  34.00   25.93   DTS-HD Master 6.1 5383Kbps (48kHz/24-bit) DTS 2.0 0Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      35,123,532,920 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:28:23 (h:m:s)
Total Bitrate:  34.00 Mbps
Description:
FILES:
00003.M2TS      22,538,164,224  1:28:23.298     0:00:00.000     1:28:23.298
VIDEO:
VC-1 Video          25931 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         5383 kbps       6.1 / 48kHz / 24-bit / 5383kbps (DTS-ES Core: 5.1-ES / 48kHz / 24-bit / 1536kbps)
DTS Audio                       English         0 kbps          2.0 / 48kHz / 24-bit / 0kbps
SUBTITLES:
Presentation Graphics           English         76 kbps
Presentation Graphics           Spanish         57 kbps
CHAPTERS:
1               0:00:00.000     0:05:44.052     23,353 kbps     56,384 kbps     00:00:27.444    35,421 kbps     00:00:02.711    33,022 kbps     00:04:50.332    121,751 bytes   909,280 bytes   00:00:27.486
2               0:05:44.052     0:04:37.360     26,292 kbps     40,187 kbps     00:06:18.753    32,672 kbps     00:07:37.290    30,302 kbps     00:05:50.267    137,073 bytes   429,049 bytes   00:07:26.780
3               0:10:21.412     0:04:53.168     26,881 kbps     45,530 kbps     00:13:50.747    35,279 kbps     00:11:22.640    34,283 kbps     00:11:19.220    140,148 bytes   546,528 bytes   00:13:13.626
4               0:15:14.580     0:03:12.025     26,311 kbps     42,924 kbps     00:18:06.544    36,819 kbps     00:18:02.540    34,089 kbps     00:17:59.078    137,174 bytes   455,145 bytes   00:18:00.621
5               0:18:26.605     0:08:09.239     25,075 kbps     39,930 kbps     00:18:26.897    34,543 kbps     00:18:52.006    33,914 kbps     00:18:53.507    130,727 bytes   508,908 bytes   00:26:19.661
6               0:26:35.844     0:04:54.544     28,288 kbps     40,064 kbps     00:30:08.348    34,692 kbps     00:30:06.930    33,481 kbps     00:29:38.902    147,481 bytes   476,709 bytes   00:30:20.235
7               0:31:30.388     0:04:32.314     25,165 kbps     38,237 kbps     00:33:59.537    34,055 kbps     00:33:56.076    32,645 kbps     00:33:54.574    131,200 bytes   432,283 bytes   00:34:14.135
8               0:36:02.702     0:02:47.000     29,640 kbps     40,277 kbps     00:37:03.054    35,291 kbps     00:37:19.279    33,261 kbps     00:36:02.702    154,530 bytes   414,970 bytes   00:36:39.906
9               0:38:49.702     0:07:12.224     24,884 kbps     45,603 kbps     00:39:27.824    36,487 kbps     00:40:20.126    35,218 kbps     00:41:28.444    129,736 bytes   461,524 bytes   00:39:41.713
10              0:46:01.926     0:06:15.542     28,694 kbps     40,633 kbps     00:46:46.095    35,913 kbps     00:46:17.358    34,582 kbps     00:47:26.594    149,596 bytes   534,633 bytes   00:49:45.691
11              0:52:17.468     0:02:36.948     23,999 kbps     37,768 kbps     00:54:46.200    32,152 kbps     00:54:43.530    30,191 kbps     00:54:43.530    125,121 bytes   389,297 bytes   00:52:55.589
12              0:54:54.416     0:05:26.868     23,979 kbps     42,713 kbps     01:00:16.446    36,755 kbps     01:00:16.279    33,214 kbps     00:58:35.137    125,016 bytes   507,280 bytes   00:57:53.637
13              1:00:21.284     0:05:18.652     28,241 kbps     45,452 kbps     01:03:27.262    35,500 kbps     01:03:37.564    33,760 kbps     01:03:35.186    147,237 bytes   461,210 bytes   01:03:06.324
14              1:05:39.936     0:03:45.016     29,876 kbps     41,622 kbps     01:08:18.594    34,920 kbps     01:08:15.091    33,535 kbps     01:08:16.134    155,761 bytes   455,168 bytes   01:06:47.128
15              1:09:24.952     0:04:33.065     28,956 kbps     46,563 kbps     01:09:51.646    36,584 kbps     01:12:09.283    34,855 kbps     01:09:43.679    150,965 bytes   650,120 bytes   01:13:03.629
16              1:13:58.017     0:05:24.074     24,580 kbps     35,506 kbps     01:18:57.316    33,403 kbps     01:18:54.146    32,478 kbps     01:18:49.141    128,148 bytes   524,839 bytes   01:19:22.091
17              1:19:22.091     0:03:40.678     28,093 kbps     44,120 kbps     01:20:06.468    33,779 kbps     01:20:02.589    32,691 kbps     01:22:15.180    146,464 bytes   473,248 bytes   01:21:38.227
18              1:23:02.769     0:05:20.529     18,489 kbps     29,450 kbps     01:23:22.915    27,536 kbps     01:23:18.994    27,255 kbps     01:23:14.823    96,392 bytes    407,443 bytes   01:23:26.710
STREAM DIAGNOSTICS:
00003.M2TS      4113 (0x1011)   0xEA            5303.30         17,189,671,694  93,498,833      25,931
00003.M2TS      4352 (0x1100)   0x86            5303.30         3,568,759,788   20,221,597      5,383
00003.M2TS      4608 (0x1200)   0x90            5303.30         50,452,114      288,332         76
00003.M2TS      4609 (0x1201)   0x90            5303.30         37,807,018      216,709         57
00003.M2TS      4353 (0x1101)   0x82            5303.30         169,042,900     994,370         255
00003.M2TS      4354 (0x1102)   0x82            5303.30         169,042,900     994,370         255
00003.M2TS      4355 (0x1103)   0x82            5303.30         169,042,900     994,370         255
Code:
        Total   Video
Harold and Kumar Escape From Guantanamo Bay                     VC-1    1:47:42 21,801,904,128  48,794,752,532  26.99   19.01   DTS-HD Master 5.1 5294Kbps (48kHz/24-bit) DTS-HD Master 2.0 745Kbps (48kHz/24-bit)
Code:
DISC INFO:
Disc Size:      48,794,752,532 bytes
Protection:     AACS
BD-Java:        No
PLAYLIST REPORT:
Length:         1:47:42 (h:m:s)
Total Bitrate:  26.99 Mbps
Description:
FILES:
Name            Size            Length          Time In         Time Out
00003.M2TS      2,141,362,176   0:10:22.955     0:00:00.000     0:10:22.955
00004.M2TS      204,761,088     0:00:59.684     0:10:22.955     0:11:22.640
00007.M2TS      83,331,072      0:00:25.442     0:11:22.640     0:11:48.082
00008.M2TS      209,338,368     0:00:59.309     0:11:48.082     0:12:47.391
00010.M2TS      1,451,452,416   0:07:04.257     0:12:47.391     0:19:51.648
00011.M2TS      205,664,256     0:00:58.975     0:19:51.648     0:20:50.624
00012.M2TS      362,852,352     0:01:39.724     0:20:50.624     0:22:30.348
00013.M2TS      1,200,611,328   0:05:50.224     0:22:30.348     0:28:20.573
00015.M2TS      3,642,286,080   0:16:41.792     0:28:20.573     0:45:02.366
00016.M2TS      210,972,672     0:01:03.313     0:45:02.366     0:46:05.679
00017.M2TS      546,484,224     0:02:39.951     0:46:05.679     0:48:45.630
00018.M2TS      75,565,056      0:00:23.982     0:48:45.630     0:49:09.613
00019.M2TS      436,869,120     0:02:15.135     0:49:09.613     0:51:24.748
00020.M2TS      2,016,301,056   0:09:40.496     0:51:24.748     1:01:05.244
00021.M2TS      239,800,320     0:00:59.976     1:01:05.244     1:02:05.221
00022.M2TS      90,630,144      0:00:19.894     1:02:05.221     1:02:25.116
00023.M2TS      565,665,792     0:02:54.382     1:02:25.116     1:05:19.498
00024.M2TS      182,747,136     0:00:59.851     1:05:19.498     1:06:19.350
00025.M2TS      2,615,703,552   0:13:28.307     1:06:19.350     1:19:47.657
00026.M2TS      198,623,232     0:01:00.185     1:19:47.657     1:20:47.842
00027.M2TS      3,268,085,760   0:16:05.381     1:20:47.842     1:36:53.223
00028.M2TS      182,396,928     0:01:00.101     1:36:53.223     1:37:53.325
00029.M2TS      61,980,672      0:00:18.184     1:37:53.325     1:38:11.510
00030.M2TS      241,281,024     0:01:13.573     1:38:11.510     1:39:25.083
00031.M2TS      194,168,832     0:00:56.973     1:39:25.083     1:40:22.057
00032.M2TS      1,172,969,472   0:07:20.440     1:40:22.057     1:47:42.497
VIDEO:
Codec               Bitrate         Description
VC-1 Video          19008 kbps      1080p / 23.976fps / 16:9 / Advanced Profile 3
AUDIO:
DTS-HD Master Audio             English         5294 kbps       5.1 / 48kHz / 24-bit / 5278kbps (DTS Core: 5.1 / 48kHz / 24-bit / 1536kbps)
DTS-HD Master Audio             English         745 kbps        2.0 / 48kHz / 24-bit / 760kbps (DTS Core: 2.0 / 48kHz / 24-bit / 256kbps)
DTS Audio                       English         256 kbps        2.0 / 48kHz / 24-bit / 256kbps
SUBTITLES:
Presentation Graphics           English         73 kbps
Presentation Graphics           Spanish         58 kbps
GRAPHICS:
Interactive Graphics            English         0 kbps
CHAPTERS:
Number          Time            Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:04:12.752     18,068 kbps     46,272 kbps     00:01:06.191    33,941 kbps     00:03:39.094    30,531 kbps     00:03:33.630    94,199 bytes    674,735 bytes   00:00:01.627
2               0:04:12.752     0:04:08.666     17,959 kbps     30,780 kbps     00:06:02.445    26,866 kbps     00:05:53.645    25,264 kbps     00:05:54.646    93,629 bytes    386,037 bytes   00:06:11.746
3               0:08:21.418     0:04:35.900     22,110 kbps     36,498 kbps     00:12:07.894    33,487 kbps     00:09:26.483    32,321 kbps     00:09:24.731    115,274 bytes   453,407 bytes   00:12:07.393
4               0:12:57.318     0:03:54.318     20,467 kbps     36,526 kbps     00:16:25.693    34,004 kbps     00:16:25.234    30,444 kbps     00:16:41.500    106,708 bytes   446,633 bytes   00:16:14.557
5               0:16:51.636     0:06:20.088     18,468 kbps     49,235 kbps     00:21:28.537    31,583 kbps     00:21:28.078    29,067 kbps     00:21:24.950    96,283 bytes    447,012 bytes   00:18:08.254
6               0:23:11.724     0:05:40.214     19,484 kbps     32,477 kbps     00:28:11.189    28,928 kbps     00:23:20.399    28,324 kbps     00:23:19.231    101,580 bytes   411,511 bytes   00:28:51.480
7               0:28:51.938     0:02:49.545     28,057 kbps     37,135 kbps     00:31:09.326    34,394 kbps     00:31:19.461    32,137 kbps     00:30:32.831    146,276 bytes   548,665 bytes   00:29:23.845
8               0:31:41.483     0:04:30.270     21,184 kbps     41,369 kbps     00:34:04.209    34,520 kbps     00:32:27.112    28,987 kbps     00:35:04.477    110,442 bytes   569,573 bytes   00:34:04.251
9               0:36:11.753     0:05:20.612     18,126 kbps     33,568 kbps     00:36:41.783    29,795 kbps     00:36:40.031    27,776 kbps     00:36:33.942    94,501 bytes    522,759 bytes   00:37:37.589
10              0:41:32.365     0:07:29.199     19,812 kbps     34,691 kbps     00:44:23.536    30,769 kbps     00:43:57.218    29,027 kbps     00:43:56.843    103,290 bytes   636,941 bytes   00:42:22.623
11              0:49:01.564     0:03:09.522     17,729 kbps     25,425 kbps     00:51:21.245    23,697 kbps     00:49:11.365    23,503 kbps     00:49:09.947    92,431 bytes    274,426 bytes   00:52:10.586
12              0:52:11.086     0:07:43.547     19,051 kbps     40,330 kbps     00:56:44.693    34,254 kbps     00:54:25.387    28,405 kbps     00:53:59.611    99,321 bytes    367,227 bytes   00:58:37.764
13              0:59:54.633     0:02:30.483     25,810 kbps     45,122 kbps     01:01:11.751    35,036 kbps     01:02:09.517    31,787 kbps     01:00:41.346    134,561 bytes   472,496 bytes   01:00:32.838
14              1:02:25.116     0:03:54.234     18,805 kbps     37,108 kbps     01:04:58.103    27,546 kbps     01:04:56.601    23,626 kbps     01:04:51.679    98,042 bytes    642,517 bytes   01:04:58.186
15              1:06:19.350     0:03:06.812     19,008 kbps     30,014 kbps     01:08:42.493    27,396 kbps     01:09:02.805    25,050 kbps     01:09:13.316    99,102 bytes    401,201 bytes   01:09:12.815
16              1:09:26.162     0:07:25.653     18,114 kbps     28,084 kbps     01:12:58.416    26,153 kbps     01:12:58.082    23,285 kbps     01:12:56.581    94,440 bytes    437,732 bytes   01:10:26.722
17              1:16:51.815     0:05:35.919     18,595 kbps     28,850 kbps     01:22:08.465    26,387 kbps     01:17:03.869    24,016 kbps     01:21:03.776    96,946 bytes    506,225 bytes   01:17:08.499
18              1:22:27.734     0:05:45.387     19,682 kbps     31,337 kbps     01:28:01.485    26,095 kbps     01:22:52.843    24,316 kbps     01:22:52.634    102,614 bytes   501,590 bytes   01:28:01.526
19              1:28:13.121     0:05:37.212     19,447 kbps     37,420 kbps     01:32:12.819    32,092 kbps     01:33:28.978    29,081 kbps     01:31:50.380    101,385 bytes   409,708 bytes   01:32:14.904
20              1:33:50.333     0:04:31.604     16,951 kbps     38,127 kbps     01:38:05.171    25,922 kbps     01:38:01.167    22,902 kbps     01:38:03.961    88,376 bytes    411,141 bytes   01:37:58.539
21              1:38:21.937     0:05:04.471     21,359 kbps     41,128 kbps     01:42:56.962    33,116 kbps     01:42:55.378    31,526 kbps     01:40:30.566    111,354 bytes   554,471 bytes   01:42:55.419
22              1:43:26.408     0:04:16.089     4,846 kbps      32,887 kbps     01:47:33.447    31,240 kbps     01:47:31.320    21,191 kbps     01:47:27.524    25,263 bytes    344,102 bytes   01:47:31.654
STREAM DIAGNOSTICS:
File            PID             Type            Seconds         Bytes           Packets         Bitrate
00003.M2TS      4113 (0x1011)   0xEA            622.96          1,518,244,461   8,260,475       19,497
00003.M2TS      4352 (0x1100)   0x86            622.96          410,993,580     2,330,851       5,278
00003.M2TS      4353 (0x1101)   0x86            622.96          59,189,956      365,474         760
00003.M2TS      4354 (0x1102)   0x82            622.96          19,857,020      116,806         255
00003.M2TS      5120 (0x1400)   0x91            622.96          0               0               0
00003.M2TS      4608 (0x1200)   0x90            622.96          5,847,411       33,252          75
00003.M2TS      4609 (0x1201)   0x90            622.96          4,387,136       25,169          56
00004.M2TS      4113 (0x1011)   0xEA            59.68           147,288,816     801,356         19,742
00004.M2TS      4352 (0x1100)   0x86            59.68           37,163,032      211,255         4,981
00004.M2TS      4353 (0x1101)   0x86            59.68           5,600,348       34,574          751
00004.M2TS      4354 (0x1102)   0x82            59.68           1,902,640       11,192          255
00004.M2TS      5120 (0x1400)   0x91            59.68           0               0               0
00004.M2TS      4608 (0x1200)   0x90            59.68           620,415         3,500           83
00004.M2TS      4609 (0x1201)   0x90            59.68           453,273         2,582           61
00007.M2TS      4113 (0x1011)   0xEA            25.44           58,534,395      318,490         18,406
00007.M2TS      4352 (0x1100)   0x86            25.44           16,498,360      93,619          5,188
00007.M2TS      4353 (0x1101)   0x86            25.44           2,387,976       14,747          751
00007.M2TS      4354 (0x1102)   0x82            25.44           811,240         4,772           255
00007.M2TS      4608 (0x1200)   0x90            25.44           147,409         852             46
00007.M2TS      4609 (0x1201)   0x90            25.44           116,586         672             37
00007.M2TS      5120 (0x1400)   0x91            25.44           0               0               0
00008.M2TS      4113 (0x1011)   0xEA            59.31           145,494,693     791,598         19,625
00008.M2TS      4352 (0x1100)   0x86            59.31           43,699,728      246,703         5,894
00008.M2TS      4353 (0x1101)   0x86            59.31           5,480,668       33,913          739
00008.M2TS      4354 (0x1102)   0x82            59.31           1,890,740       11,122          255
00008.M2TS      4608 (0x1200)   0x90            59.31           462,165         2,653           62
00008.M2TS      4609 (0x1201)   0x90            59.31           404,171         2,307           55
00008.M2TS      5120 (0x1400)   0x91            59.31           0               0               0
00010.M2TS      4113 (0x1011)   0xEA            424.26          1,028,105,272   5,593,677       19,386
00010.M2TS      4352 (0x1100)   0x86            424.26          280,142,500     1,588,612       5,283
00010.M2TS      4353 (0x1101)   0x86            424.26          39,953,160      246,706         753
00010.M2TS      4354 (0x1102)   0x82            424.26          13,523,500      79,550          255
00010.M2TS      5120 (0x1400)   0x91            424.26          0               0               0
00010.M2TS      4608 (0x1200)   0x90            424.26          3,441,352       19,606          65
00010.M2TS      4609 (0x1201)   0x90            424.26          3,030,200       17,282          57
00011.M2TS      4113 (0x1011)   0xEA            58.98           142,431,828     774,960         19,321
00011.M2TS      4352 (0x1100)   0x86            58.98           42,747,376      241,479         5,799
00011.M2TS      4353 (0x1101)   0x86            58.98           5,623,640       34,665          763
00011.M2TS      4354 (0x1102)   0x82            58.98           1,879,860       11,058          255
00011.M2TS      4608 (0x1200)   0x90            58.98           706,716         4,023           96
00011.M2TS      4609 (0x1201)   0x90            58.98           525,464         2,995           71
00011.M2TS      5120 (0x1400)   0x91            58.98           0               0               0
00012.M2TS      4113 (0x1011)   0xEA            99.72           247,608,171     1,347,140       19,863
00012.M2TS      4352 (0x1100)   0x86            99.72           80,239,720      451,618         6,437
00012.M2TS      4353 (0x1101)   0x86            99.72           9,838,972       60,589          789
00012.M2TS      4354 (0x1102)   0x82            99.72           3,179,000       18,700          255
00012.M2TS      4608 (0x1200)   0x90            99.72           798,451         4,596           64
00012.M2TS      4609 (0x1201)   0x90            99.72           670,970         3,874           54
00012.M2TS      5120 (0x1400)   0x91            99.72           0               0               0
00013.M2TS      4113 (0x1011)   0xEA            350.22          832,464,292     4,529,378       19,016
00013.M2TS      4352 (0x1100)   0x86            350.22          248,803,752     1,406,859       5,683
00013.M2TS      4353 (0x1101)   0x86            350.22          32,096,548      198,882         733
00013.M2TS      4354 (0x1102)   0x82            350.22          11,163,560      65,668          255
00013.M2TS      4608 (0x1200)   0x90            350.22          4,036,833       22,941          92
00013.M2TS      4609 (0x1201)   0x90            350.22          3,086,865       17,726          71
00013.M2TS      5120 (0x1400)   0x91            350.22          0               0               0
00015.M2TS      4113 (0x1011)   0xEA            1001.79         2,643,056,424   14,379,077      21,107
00015.M2TS      4352 (0x1100)   0x86            1001.79         651,491,620     3,696,920       5,203
00015.M2TS      4353 (0x1101)   0x86            1001.79         91,591,856      567,523         731
00015.M2TS      4354 (0x1102)   0x82            1001.79         31,932,460      187,838         255
00015.M2TS      4608 (0x1200)   0x90            1001.79         10,198,389      57,982          81
00015.M2TS      4609 (0x1201)   0x90            1001.79         8,270,549       47,315          66
00015.M2TS      5120 (0x1400)   0x91            1001.79         0               0               0
00016.M2TS      4113 (0x1011)   0xEA            63.31           151,218,528     822,746         19,107
00016.M2TS      4352 (0x1100)   0x86            63.31           39,236,752      223,103         4,958
00016.M2TS      4353 (0x1101)   0x86            63.31           5,564,496       34,650          703
00016.M2TS      4354 (0x1102)   0x82            63.31           2,018,240       11,872          255
00016.M2TS      4608 (0x1200)   0x90            63.31           458,650         2,616           58
00016.M2TS      4609 (0x1201)   0x90            63.31           297,450         1,705           38
00016.M2TS      5120 (0x1400)   0x91            63.31           0               0               0
00017.M2TS      4113 (0x1011)   0xEA            159.95          392,050,993     2,133,041       19,609
00017.M2TS      4352 (0x1100)   0x86            159.95          100,510,120     571,299         5,027
00017.M2TS      4353 (0x1101)   0x86            159.95          14,545,464      90,287          727
00017.M2TS      4354 (0x1102)   0x82            159.95          5,098,640       29,992          255
00017.M2TS      4608 (0x1200)   0x90            159.95          1,668,121       9,489           83
00017.M2TS      4609 (0x1201)   0x90            159.95          1,187,351       6,792           59
00017.M2TS      5120 (0x1400)   0x91            159.95          0               0               0
00018.M2TS      4113 (0x1011)   0xEA            23.98           54,190,703      294,866         18,077
00018.M2TS      4352 (0x1100)   0x86            23.98           13,684,696      78,164          4,565
00018.M2TS      4353 (0x1101)   0x86            23.98           2,121,480       13,211          708
00018.M2TS      4354 (0x1102)   0x82            23.98           764,660         4,498           255
00018.M2TS      4608 (0x1200)   0x90            23.98           209,947         1,204           70
00018.M2TS      4609 (0x1201)   0x90            23.98           141,275         809             47
00018.M2TS      5120 (0x1400)   0x91            23.98           0               0               0
00019.M2TS      4113 (0x1011)   0xEA            135.14          296,967,291     1,615,952       17,580
00019.M2TS      4352 (0x1100)   0x86            135.14          95,422,664      539,689         5,649
00019.M2TS      4353 (0x1101)   0x86            135.14          12,918,524      79,862          765
00019.M2TS      4354 (0x1102)   0x82            135.14          4,307,460       25,338          255
00019.M2TS      4608 (0x1200)   0x90            135.14          1,005,955       5,745           60
00019.M2TS      4609 (0x1201)   0x90            135.14          729,206         4,220           43
00019.M2TS      5120 (0x1400)   0x91            135.14          0               0               0
00020.M2TS      4113 (0x1011)   0xEA            580.50          1,445,249,140   7,863,126       19,917
00020.M2TS      4352 (0x1100)   0x86            580.50          375,215,672     2,129,643       5,171
00020.M2TS      4353 (0x1101)   0x86            580.50          53,472,328      331,079         737
00020.M2TS      4354 (0x1102)   0x82            580.50          18,503,480      108,844         255
00020.M2TS      4608 (0x1200)   0x90            580.50          4,976,553       28,412          69
00020.M2TS      4609 (0x1201)   0x90            580.50          3,653,119       20,998          50
00020.M2TS      5120 (0x1400)   0x91            580.50          0               0               0
00021.M2TS      4113 (0x1011)   0xEA            59.98           181,640,047     988,056         24,228
00021.M2TS      4352 (0x1100)   0x86            59.98           36,818,756      209,479         4,911
00021.M2TS      4353 (0x1101)   0x86            59.98           5,387,424       33,541          719
00021.M2TS      4354 (0x1102)   0x82            59.98           1,911,820       11,246          255
00021.M2TS      4608 (0x1200)   0x90            59.98           439,217         2,519           59
00021.M2TS      4609 (0x1201)   0x90            59.98           365,222         2,102           49
00021.M2TS      5120 (0x1400)   0x91            59.98           0               0               0
00022.M2TS      4113 (0x1011)   0xEA            19.89           71,480,630      388,783         28,743
00022.M2TS      4352 (0x1100)   0x86            19.89           11,549,092      65,891          4,644
00022.M2TS      4353 (0x1101)   0x86            19.89           1,806,372       11,180          726
00022.M2TS      4354 (0x1102)   0x82            19.89           634,440         3,732           255
00022.M2TS      4608 (0x1200)   0x90            19.89           176,430         1,002           71
00022.M2TS      4609 (0x1201)   0x90            19.89           134,285         766             54
00022.M2TS      5120 (0x1400)   0x91            19.89           0               0               0
00023.M2TS      4113 (0x1011)   0xEA            174.38          417,192,081     2,269,914       19,139
00023.M2TS      4352 (0x1100)   0x86            174.38          91,337,088      523,558         4,190
00023.M2TS      4353 (0x1101)   0x86            174.38          16,136,132      99,801          740
00023.M2TS      4354 (0x1102)   0x82            174.38          5,558,660       32,698          255
00023.M2TS      4608 (0x1200)   0x90            174.38          1,321,926       7,543           61
00023.M2TS      4609 (0x1201)   0x90            174.38          1,192,280       6,819           55
00023.M2TS      5120 (0x1400)   0x91            174.38          0               0               0
00024.M2TS      4113 (0x1011)   0xEA            59.85           133,761,690     727,799         17,879
00024.M2TS      4352 (0x1100)   0x86            59.85           30,085,444      172,940         4,021
00024.M2TS      4353 (0x1101)   0x86            59.85           5,208,696       32,582          696
00024.M2TS      4354 (0x1102)   0x82            59.85           1,908,080       11,224          255
00024.M2TS      4608 (0x1200)   0x90            59.85           489,754         2,802           65
00024.M2TS      4609 (0x1201)   0x90            59.85           426,728         2,450           57
00024.M2TS      5120 (0x1400)   0x91            59.85           0               0               0
00025.M2TS      4113 (0x1011)   0xEA            808.31          1,834,404,148   9,981,344       18,156
00025.M2TS      4352 (0x1100)   0x86            808.31          516,692,976     2,934,423       5,114
00025.M2TS      4353 (0x1101)   0x86            808.31          73,847,160      457,764         731
00025.M2TS      4354 (0x1102)   0x82            808.31          25,764,860      151,558         255
00025.M2TS      4608 (0x1200)   0x90            808.31          6,849,848       39,111          68
00025.M2TS      4609 (0x1201)   0x90            808.31          5,598,756       32,171          55
00025.M2TS      5120 (0x1400)   0x91            808.31          0               0               0
00026.M2TS      4113 (0x1011)   0xEA            60.19           140,510,288     764,515         18,677
00026.M2TS      4352 (0x1100)   0x86            60.19           38,286,492      217,435         5,089
00026.M2TS      4353 (0x1101)   0x86            60.19           5,411,144       33,641          719
00026.M2TS      4354 (0x1102)   0x82            60.19           1,918,620       11,286          255
00026.M2TS      4608 (0x1200)   0x90            60.19           536,270         3,062           71
00026.M2TS      4609 (0x1201)   0x90            60.19           439,467         2,529           58
00026.M2TS      5120 (0x1400)   0x91            60.19           0               0               0
00027.M2TS      4113 (0x1011)   0xEA            965.38          2,303,388,603   12,532,537      19,088
00027.M2TS      4352 (0x1100)   0x86            965.38          640,986,804     3,634,250       5,312
00027.M2TS      4353 (0x1101)   0x86            965.38          89,060,472      551,278         738
00027.M2TS      4354 (0x1102)   0x82            965.38          30,771,700      181,010         255
00027.M2TS      4608 (0x1200)   0x90            965.38          8,952,925       51,011          74
00027.M2TS      4609 (0x1201)   0x90            965.38          6,782,954       38,838          56
00027.M2TS      5120 (0x1400)   0x91            965.38          0               0               0
00028.M2TS      4113 (0x1011)   0xEA            60.10           127,621,300     694,474         16,987
00028.M2TS      4352 (0x1100)   0x86            60.10           35,966,808      204,790         4,787
00028.M2TS      4353 (0x1101)   0x86            60.10           5,293,964       32,951          705
00028.M2TS      4354 (0x1102)   0x82            60.10           1,915,900       11,270          255
00028.M2TS      4608 (0x1200)   0x90            60.10           445,004         2,520           59
00028.M2TS      4609 (0x1201)   0x90            60.10           343,885         1,960           46
00028.M2TS      5120 (0x1400)   0x91            60.10           0               0               0
00029.M2TS      4113 (0x1011)   0xEA            18.18           42,512,504      231,297         18,702
00029.M2TS      4352 (0x1100)   0x86            18.18           13,582,032      76,635          5,975
00029.M2TS      4353 (0x1101)   0x86            18.18           1,684,728       10,368          741
00029.M2TS      4354 (0x1102)   0x82            18.18           579,700         3,410           255
00029.M2TS      4608 (0x1200)   0x90            18.18           50,362          300             22
00029.M2TS      4609 (0x1201)   0x90            18.18           27,225          173             12
00029.M2TS      5120 (0x1400)   0x91            18.18           0               0               0
00030.M2TS      4113 (0x1011)   0xEA            73.57           162,381,208     883,568         17,656
00030.M2TS      4352 (0x1100)   0x86            73.57           54,768,740      309,160         5,955
00030.M2TS      4353 (0x1101)   0x86            73.57           6,940,436       42,934          755
00030.M2TS      4354 (0x1102)   0x82            73.57           2,345,320       13,796          255
00030.M2TS      4608 (0x1200)   0x90            73.57           432,365         2,472           47
00030.M2TS      4609 (0x1201)   0x90            73.57           396,027         2,265           43
00030.M2TS      5120 (0x1400)   0x91            73.57           0               0               0
00031.M2TS      4113 (0x1011)   0xEA            56.97           134,681,565     732,824         18,911
00031.M2TS      4352 (0x1100)   0x86            56.97           40,011,892      226,348         5,618
00031.M2TS      4353 (0x1101)   0x86            56.97           5,249,372       32,455          737
00031.M2TS      4354 (0x1102)   0x82            56.97           1,816,280       10,684          255
00031.M2TS      4608 (0x1200)   0x90            56.97           710,263         4,042           100
00031.M2TS      4609 (0x1201)   0x90            56.97           525,279         3,018           74
00031.M2TS      5120 (0x1400)   0x91            56.97           0               0               0
00032.M2TS      4113 (0x1011)   0xEA            440.44          702,061,847     3,821,909       12,752
00032.M2TS      4352 (0x1100)   0x86            440.44          330,411,952     1,864,386       6,001
00032.M2TS      4353 (0x1101)   0x86            440.44          45,647,692      279,359         829
00032.M2TS      4354 (0x1102)   0x82            440.44          14,039,280      82,584          255
00032.M2TS      4608 (0x1200)   0x90            440.44          4,250,908       24,093          77
00032.M2TS      4609 (0x1201)   0x90            440.44          3,896,137       22,117          71
00032.M2TS      5120 (0x1400)   0x91            440.44          0               0               0
Aaron*C is offline
post #569 of 1971 Old 07-30-2008, 12:47 PM
bplewis24's Avatar
Originally Posted by Patsfan123 View Post
So, the video bitrate information is taken from BDinfo, right? I noticed on the PS3 last night that the bitrate spiked into the high 40s and hit 50.0 once during the battle between Eden and the executioner. If I'm interpreting the charts correctly that corresponds to the information in the chart to within a few Mbps? Basically what I'm asking is how accurate is BDinfo and how accurate is the PS3 meter in relation to that.
Brandon
bplewis24 is offline
post #570 of 1971 Old 07-30-2008, 02:32 PM
Cinema Squid's Avatar
I think the peaks measured by BDInfo are fairly accurate, although any instantaneous bitrate measurement is tricky business with the overall trend lines probably being more significant than any single data point.
As far as how accurate the PS3 (or something else like PowerDVD) are, it's hard to say. I'm not sure how makes its measurement, although I think I did see someone say that it might use a 3-second rolling window which would likely place its measurements somewhere between BDInfo's 1- and 5-second window measurements (generally the larger the measurement window, the lower the peaks will be).
You can use the per-chapter peak time stamps listed in the BDinfo reports to spot check areas in the disc to see how things correspond. While the numbers might not be exactly the same, there should still be "spikes" in the same spots. I'd be interested to hear about any discrepancies or correspondences.
Cinema Squid is offline
Closed Thread Blu-ray Software
User Tag List
