Blu-Ray Custom Cover Art (huge files) - Page 103 - AVS Forum | Home Theater Discussions And Reviews
 80Likes
post #3061 of 6054 Old 08-29-2009, 11:14 PM
sonydude1966's Avatar
Quoted: 14 Post(s)
Originally Posted by BallsDeepX View Post
All of a sudden Infraview stopped printing my covers properly. Its cutting off the left side a little bit, a little more than 1/4 is being cut off. I did get a new printer but not sure why this would effect how Infraview. Any ideas?
In the preview section of Infraview its showing it properly but when I print its cutting the left side off a little bit.
This is for Blu-ray covers, correct? If it were DVD covers, I would say each printer can have a slightly larger or smaller printing area.
Are you using 8.5 x 11? Do you have larger paper, to see if it's the paper size with your new printer? Or, maybe your printing size could be adjusted. If it's "letter", change to "A4."
I just started printing covers, and my printer does the same as yours with DVD covers, a little less than 1/4 inch missing. It just barely fits a blu-ray with 8.5 x 11 paper. I'm glad because I bought my photo paper just for a few Blu-rays I wanted.
You could also try undercoverxp, and see if that helps. That's what I use.
sonydude1966 is offline
post #3062 of 6054 Old 08-30-2009, 10:42 AM
BallsDeepX's Avatar
Yes Bluray covers. 8.5 x 11 and no I don't have any larger paper.
I'll have to keep banging away on this thing maybe remove and reinstall. Still haven't figured out whats wrong with it.
BallsDeepX is offline
post #3063 of 6054 Old 08-30-2009, 05:06 PM
BallsDeepX's Avatar
Well I got it working. I had to add a inch to the top margin which doesn't make any sense. Because it was the left margin that was being cut off. But oh well its printing my covers properly now. And beggars cant be choosers.
*I added a inch to the left margin in attempt to fix it and that should of fixed it. But what did it do it cut off even more of the cover on the left side. Doh weirdo stuff. Then added an inch to the top margin which shouldn't of done anything but move the cover down a bit and what happens, it works.
post #3064 of 6054 Old 08-30-2009, 09:00 PM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Some logos are still missing and a few things here and there, but I'm almost done... Here's a preview
...I'm doing this for the trilogy+salvation...
__________
Nicolas.
"Music expresses that which cannot be said and on which it is impossible to be silent."- Victor Hugo.
Morpheo is offline
post #3065 of 6054 Old 08-31-2009, 06:39 AM
boxterduke's Avatar
... snip pic snip ...
Very nice indeed, looking forward to this.
boxterduke is offline
post #3066 of 6054 Old 08-31-2009, 10:24 PM
Wesker's Avatar
Awesome! Finally I've waited years for someone to do a proper Terminator cover. Great job so far. Only thing is it's called The Terminator. Need to add "The" to the header and spine.
Wesker is offline
post #3067 of 6054 Old 08-31-2009, 10:36 PM
novimihai's Avatar
I have a request for Hannibal and The Damned United!
Thank you!
novimihai is offline
post #3068 of 6054 Old 09-01-2009, 04:40 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Yeah I know, that bothers me as well. But I got rid of "the" because of the other films... When I imagine all 3 (and 4) side by side, I think it's better if it reads "Terminator", then "Terminator 2", "Terminator 3", etc... "The" isn't used in the other films. Anyway, I'll add it and there will be 2 options.
__________
Nicolas.
Morpheo is offline
post #3069 of 6054 Old 09-01-2009, 05:23 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
[edit]
Since the original title is "The Terminator", there's actually no room for debate, so here's the final-final version. Typos and missing "the" corrected on the back.
Gallery updated. High Res version below (sig).
__________
Nicolas.
Morpheo is offline
post #3070 of 6054 Old 09-01-2009, 08:21 AM
boxterduke's Avatar
Very nice, I can't wait for the other 3, if they all match I might have to pick up the old 3 Terminators.
post #3071 of 6054 Old 09-01-2009, 09:56 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
They will. ...I just noticed some "the" still missing on the "the" version (credits and synopsis) I will correct them as well, sorry!
__________
Nicolas.
Morpheo is offline
post #3072 of 6054 Old 09-01-2009, 11:23 AM
BenUK's Avatar
Would anyone be interested in producing a new Bourne artwork set?
Specifically The Bourne Identity, as I think that artwork is really quite bad.
BenUK is offline
post #3073 of 6054 Old 09-01-2009, 08:36 PM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
And now for T2...
__________
Nicolas.
Morpheo is offline
post #3074 of 6054 Old 09-01-2009, 10:48 PM
Wesker's Avatar
[edit]
Fantastic. Your finished piece is perfect.
Wesker is offline
post #3075 of 6054 Old 09-01-2009, 11:33 PM
HoNuts's Avatar
[edit]
There's a typo on the back - "asrenal" should be "arsenal"
HoNuts is offline
post #3076 of 6054 Old 09-02-2009, 02:56 AM
BallsDeepX's Avatar
When you guys quote someones post that has a case cover on it. Remove the image please. If its on a different page then I can understand it. But why do we need 3/4/5 posts all with the same exact picture on it? It just makes the thread crazy.
post #3077 of 6054 Old 09-02-2009, 05:19 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
okay... I've checked for typos and they both seem fine now, sorry guys. Cleaned up the previews on flickr as well...
Hi Res versions.
...T3 on its way
__________
Nicolas.
Morpheo is offline
post #3078 of 6054 Old 09-02-2009, 07:48 AM
PeterTHX's Avatar
Quoted: 329 Post(s)
Liked: 246
...T3 on its way
RE: Terminator 2
You need to replace the "DTS-HD High Resolution" with "DTS-HD Master Audio", as well as annotate the spec to "DTS-HD MA", since DTS-HD could mean either HR or MA.
DTS-HD HR is lossy audio, like Dolby Digital Plus. Some of Lionsgate's early releases used it, like Total Recall and the original version of "Stargate".
My opinions do not reflect the policies of my company
PeterTHX is offline
post #3079 of 6054 Old 09-02-2009, 08:00 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Originally Posted by PeterTHX View Post
RE: Terminator 2
hm, sorry, I missed that one. Thanks! Will do the correction later today.
__________
Nicolas.
Morpheo is offline
post #3080 of 6054 Old 09-02-2009, 11:38 AM
PeterTHX's Avatar
Quoted: 329 Post(s)
Liked: 246
No problem, very nice covers BTW.
One small request if you could replace the old "Dolby Digital" logos with the spiffy new ones like this one:
And for Terminator 1 and 3:
PeterTHX is offline
post #3081 of 6054 Old 09-02-2009, 11:52 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
No problem. Thanks.
[edit] previews above have been updated with proper logos... Hi res as well...
__________
Nicolas.
Morpheo is offline
post #3082 of 6054 Old 09-02-2009, 08:06 PM
HoNuts's Avatar
Awesome job Morpheo on the Terminator covers!!!!
HoNuts is offline
post #3083 of 6054 Old 09-02-2009, 11:09 PM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Thank you
btw, here's where I am with T3, should be done by tomorrow. I'm still not sure if I put something behind Arnold's face or leave it black. And maybe "rise of the machines" on front is too big. Oh, well, time to go to sleep anyway
...oh and I've also started this; waiting for the final specs though. That's really a first draft, but that poster is too cool!...
__________
Nicolas.
Morpheo is offline
post #3084 of 6054 Old 09-03-2009, 12:07 AM
PeterTHX's Avatar
Quoted: 329 Post(s)
Liked: 246
No problem. Thanks.
Shhweeet! Kudos.
PeterTHX is offline
post #3085 of 6054 Old 09-03-2009, 05:44 AM
ouatia's Avatar
Hello everybody!
I am looking for a good scan of the Sand Pebbles US blu-ray cover. So I can replace the ugly french one I have....
Thank you
ouatia is offline
post #3086 of 6054 Old 09-03-2009, 07:00 AM
boxterduke's Avatar
Dang Morpheo, these are wonderful, great work.
post #3087 of 6054 Old 09-03-2009, 07:46 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Originally Posted by ouatia View Post
Hello everybody!
Thank you
Check your PMs...
__________
Nicolas.
Morpheo is offline
post #3088 of 6054 Old 09-03-2009, 07:51 AM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Thank you. These are fun to do As I will put Salvation on hold until we know the official specs, I'm gonna give the Bourne trilogy a new spin once T3 is done!
__________
Nicolas.
Morpheo is offline
post #3089 of 6054 Old 09-03-2009, 07:54 PM
Wesker's Avatar
Thank you
Please leave it black. Looks great. I'd love to see what other stuff you can come up with. You did a great job with the Underworld films and I like the fact that you use a lot of the original theatrical posters. If you need any high quality source material, Movie Poster Database is where I go.
Wesker is offline
post #3090 of 6054 Old 09-03-2009, 08:02 PM
Wesker's Avatar
Hi Res versions.
...T3 on its way
Staying with your theme, I just noticed, have you thought about replacing the T-800 on the back of the Terminator 2 slip cover for one of the T-1000? You've got the T-X on Rise of the Machines. Just thought it would fit the theme of the covers.
Wesker is offline
Reply Blu-ray Software
Man Of Steel Blu Ray 3d Blu Ray Dvd Ultraviolet Combo Pack
