Blu-ray HD movie screenshot thread... - Page 99 - AVS Forum | Home Theater Discussions And Reviews
post #2941 of 4061 Old 03-15-2011, 03:11 PM
Gamereviewgod's Avatar
Gamereviewgod is offline
post #2942 of 4061 Old 03-16-2011, 09:01 AM
post #2943 of 4061 Old 03-16-2011, 11:13 PM
ces18769's Avatar
Tron Legacy
ces18769 is offline
post #2944 of 4061 Old 03-17-2011, 06:49 AM
foughman's Avatar
A Dirty Carnival (Korean)
Haevnen (Swedish)
Cornelis (Sweden)
Anonyma: The Downfall of Berlin (UK)
foughman is offline
post #2945 of 4061 Old 03-17-2011, 07:39 AM
post #2946 of 4061 Old 03-18-2011, 08:41 AM
post #2947 of 4061 Old 03-18-2011, 08:44 AM
post #2948 of 4061 Old 03-18-2011, 02:20 PM
mbernstein's Avatar
Quoted: 28 Post(s)
Originally Posted by foughman View Post
He uses his computer to capture screens.
I did some search in the forum, but couldn't find an answer, maybe one of you can help, sorry if this is the wrong thread (if so, pls direct me to the right one). The post above made me write here.
I need to capture frames from some of my BDs discs for a research I'm doing. Is there any software that capture from the BD disc in a PC without having to convert the whole BD to the hard disk (and a new format)? I tried with PowerDVD 9 and 10 and Total Media Theater 5 to no avail (I use windows 7).
mbernstein is offline
post #2949 of 4061 Old 03-19-2011, 07:59 AM
I use Media Player Classic Home Cinema. The copy protection needs cracked in order to do so though. For that you can use DVD Fab Passkey which I believe stilll has a free trial period.
19 screens added to Uncle Buck:
Attachment 205862 Attachment 205863
Attachment 205864 Attachment 205865
Attachment 205866
http://www.doblu.com/2011/03/19/uncle-buck-review/
post #2950 of 4061 Old 03-19-2011, 09:22 AM
mbernstein's Avatar
Quoted: 28 Post(s)
I'm trying to do what you suggested. I'm following the instructions on the first post in this thread http://www.avsforum.com/avs-vb/showt...4#post11341294 , but I didn't manage to find the Sonic Cinemaster Audio Decoder v 4.3 codecs. Are these the most updated instructions on how to paly BD discs on MPC? If so, where can I find these codecs? The others I have. If there are newer and easier ways to use MPC, what should I do? I do appreciate the help.
If this is too much off topic, can I PM you? Thanks so much again.
post #2951 of 4061 Old 03-19-2011, 12:31 PM
mbernstein's Avatar
Quoted: 28 Post(s)
Gamereviewgod,
After using AnyDVD HD I was able to play the m2ts files directly from MPC and PowerDVD 9 and grab screen captures. DVD Passkey Free didn't do the trick. Maybe I'll try DVDPasskey for BD because it is a little bit less expensive than AnyDVD HD, but now I know the trick.
Thanks again.
post #2952 of 4061 Old 03-19-2011, 02:58 PM
BsRoz's Avatar
15 Screenshots of Equilibrium - Dutch release
BsRoz is offline
post #2953 of 4061 Old 03-20-2011, 09:40 PM
Cinema Squid's Avatar
40 screen captures from The Lord of the Rings: The Fellowship of the Ring (Theatrical) (2001)
[Entertainment in Video - UK Region B].
40 screen captures from The Lord of the Rings: The Two Towers (Theatrical) (2002)
40 screen captures from The Lord of the Rings: The Return of the King (Theatrical) (2003)
Just in case anyone was wondering, these UK releases of the theatrical editions of the trilogy from last year have the same video and audio as the U.S. and other releases.
Cinema Squid is offline
post #2954 of 4061 Old 03-21-2011, 10:43 AM
Jojos's Avatar
40 screenshots of The Transporter (FR release - Europa Corp) :
UPDATE 03-25-2011: I have redone them with the correct color space (old ones under spoiler).
Spoiler
Old screenshots with incorrect color space:
Jojos is offline
post #2955 of 4061 Old 03-21-2011, 12:21 PM
SteveMo's Avatar
Man On Fire (2004)
SteveMo is offline
post #2956 of 4061 Old 03-22-2011, 02:52 PM
post #2957 of 4061 Old 03-23-2011, 09:43 AM
post #2958 of 4061 Old 03-23-2011, 09:52 AM
jimjimmyjones85's Avatar
This is a great shot. I only have the imported HD-DVD, I wonder how they compare.
jimjimmyjones85 is offline
post #2959 of 4061 Old 03-23-2011, 11:21 PM
35 screen captures from Summer Wars (2009)
[Funimation - US Region A].
post #2960 of 4061 Old 03-24-2011, 04:40 AM
BsRoz's Avatar
21 Screenshots of Sleepers
BsRoz is offline
post #2961 of 4061 Old 03-24-2011, 06:10 AM
You've been sitting there thinking, "Damn, I sure wish someone would post 20 screens of the Yogi Bear Blu-ray!" Your wish is granted:
Attachment 206468 Attachment 206469
Attachment 206470 Attachment 206471
Attachment 206472
http://www.doblu.com/2011/03/24/yogi-bear-review/
post #2962 of 4061 Old 03-24-2011, 11:31 AM
foughman's Avatar
Sleepers just got DNR:ed!
foughman is offline
post #2963 of 4061 Old 03-25-2011, 05:53 AM
Jojos's Avatar
32 screenshots of And Soon the Darkness (UK release - Optimum):
Unlike the US release (2.40:1), this one has an aspect ratio of 1.78:1 (framing comparisons: 1; 2). Most screenshots match those previously taken by Cinema Squid.
Jojos is offline
post #2964 of 4061 Old 03-25-2011, 07:35 AM
post #2965 of 4061 Old 03-26-2011, 03:35 AM
SteveMo's Avatar
Behind Enemy Lines (2001)
SteveMo is offline
post #2966 of 4061 Old 03-26-2011, 07:26 AM
post #2967 of 4061 Old 03-26-2011, 02:56 PM
BsRoz's Avatar
21 Screenshots of Flight of the Navigator - German release
BsRoz is offline
post #2968 of 4061 Old 03-27-2011, 06:14 PM
post #2969 of 4061 Old 03-28-2011, 10:22 AM
SteveMo's Avatar
Let Me In (2011)
SteveMo is offline
Reply Blu-ray Software
Blu Ray Movies
