My Blu-Ray Movie Burning Experiences... - Page 78 - AVS Forum | Home Theater Discussions And Reviews
Old 01-06-2011, 10:58 AM
LatheOfHeaven's Avatar
Oh, one other thing too... The free version of DVDFab HD also has a 'Movie Only' option that simply extracts just the movie if that is what you want and then you just burn it. REAL simple. I would suggest that... You don't get any of the menus but you do have the main film. I hope that helps.
LatheOfHeaven is offline
Old 01-06-2011, 11:33 AM
darthemma's Avatar
Thanks for the advice. I use the BD-R and movie only setting in BD-RB. I tried burning another copy today and set imgburn to burn at 1X. Same result. Anybody need a blue coaster?
I just checked for a firmware update for my BR burner (PLDS BD-RE DH-8B2SHATA) and there is no update, so I think I have the most recent driver.
I am going to wait until my other discs come to try again. I think I have it down to either being the media or the burner. I ordere Verbatim BD-R 4x discs (NOT LTH discs) and I ordered some Ridata discs. If those don't work, then I'll try the Ritek discs you suggested. If it's not the media, then I think it has to be the burner. I'll buy a new burner after trying new media. But, it seems to me the problem is not the burner because the computer can play the movies.
Thanks, I'll let you know if the new media resolve the issue.
darthemma is offline
Old 01-06-2011, 11:52 AM
seggers's Avatar
Quoted: 99 Post(s)
Liked: 52
DarthEmma,
Any thoughts on buying a 25 or 50Gb BD-RE, just to ensure that the porject actually burns and maybe saving yourself from some more snazzy coasters?
Seggers
Vizio M80-C3, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet, an ASUS ChromeBox running Kodi, a TiVo Series 3 and a Philips BDP7501 UHD . There's also a Wii, but we don't talk about that...
seggers is offline
Old 01-06-2011, 12:05 PM
darthemma's Avatar
Originally Posted by seggers View Post
DarthEmma,
Seggers
If I can't the discs I just ordered to work, then I'll try a BD-RE before replacing the burner. I know it's burning the discs because they play fine in my computer. They just don't work in either BR player.
The last time this happened to me, it was the media (it was a cheap Imation DVD+R that time).
What's odd is that other folks with the Oppo BDP-83 seem to find that Maxells work for them.
I'm also a tad suspicious that perhaps the Maxells I bought in the spindle (cake) container may not actually be the same as Maxells that come in the jewel cases.
In any case, I'll try the Ridata and the Verbatim discs I ordered next. I should have them by Saturday. If neither of those work, then I'll get a BD-RE to play with. Can you recommend a good brand for the BD-RE? Verbatim?
My only other thought is that I am using Windows 7 Home Premium 64bit. Could that be the problem? I just bought this new computer with Win7 64 on it and it came with this BR burner. It's a PLDS BD-RE DH-8B2SHATA. I can't find drivers anywhere for this burner. Even the driver download section for my computer's service tag on Dells website doesn't list a driver for this model.
Old 01-06-2011, 02:38 PM
bourke's Avatar
Originally Posted by Wryker View Post
You missed the deadline for lifetime subscription but I say get Slysoft ANYDVD HD - unless you're JUST looking for DVD. It handles every BD format and works flawlessly w/HD audio and no compression.
Actually so far every day this year the lifetime subscription has still be available to order from the Slysoft web site :-P They've said the lifetime subscriptions would end many times before... it's an ancient marketing ruse used to suck suckers into buying something they don't need!
AnyDVD HD is a great product for what it does - however it does not do what I said I was after in my post - it does not re-compress and re-build the entire disc like DVD Shrink does for DVD.
That is why DVD Fab seems better value - it does all of that for about $80, whereas AnyDVD does none of that and is about $140.
Does anyone know if DVD Fab re-compresses VC-1 - rather than converting VC-1 to AVC (MPEG-4 H264)?
Cheers,
Bourkie
2008: BD+ hacked... payback time for Warner, Fox and Disney!
bourke is offline
Old 01-06-2011, 02:45 PM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Cheers,
Bourkie
Why do you want to re-compress the BD? You can use ANYDVD HD along with imgBurn (which is free) to make an exact copy of the BD. Or use ANYDVD HD and ClownBD (which is free) which allows you to rip what you want (just the movie, select the audio streams, etc). I use AnyDVD HD and ToNMT to rip just the movie and HD audio. I use imgBurn to burn it to BD if I want. Has never failed (even on 3D BDs) where DVDFab will fail on 3D BDs (two coasters to prove it).
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
Old 01-06-2011, 03:12 PM
darthemma's Avatar
I used anyDVDHD to rip the movie to the harddrive. Then I used BD-RB just to a movie only version. It actually said it didn't compress the video stream at all. And I did use imgburn to burn it.
I really think it has nothing to do with anyDVD, BD-RB, or imgburn. I think it's the media or the burner. I have been able to compress some movies to DVD5 (blu-ray format) and the discs play perfectly in both of my players.
The reason I used BD-rebuilder was because I'm using a BR-R 25GB disc, not a 50GB disc, so I couldn't be sure it would all fit on the disc. I know BD-rebuilder with take care of that.
I just started authoring blu-ray 2 days ago. I'm still learning. Thanks for all your suggestions. I'll try an anyDVDHD rip of just the movie too.
Old 01-06-2011, 08:26 PM
bourke's Avatar
For >23GB discs I'm not paying for a BD50 blank - the BD25s are only a $2 each.
Does ClownBD re-compress VC-1 (i.e. does it have a VC-1 encoder), or does it only convert it to AVC (MPEG4 h264)?
Is this a known problem with 3D BDs? Seems like a simple fix if it's just a format structure issue - 3D BDs don't possess any extra copy protection.
I still fail to see why AnyDVD is worth $60 more than DVD Fab?
bourke is offline
Old 01-07-2011, 09:37 AM
mtallent's Avatar
I don't believe you have a blank disk or burning problem. I think the disk is not authored correctly. A simple test is to re-author the disk using TsmuxeR, a free program. Find it here-
http://www.smlabs.net/tsMuxer/tsMuxeR_1.10.6.zip
Just go to the stream folder of your movie, and add the main movie .m2ts file to tsmuxer, running the tsmuxer GUI , then select Blu-Ray as the output format and save it to a new folder. Then run the mux, it should not take long as it is not doing any re-encoding.
I then strongly suggest you get some BD-RE erasable disks to burn with using the latest ImgBurn program. You can also use tsmuxer to correct any audio sync problems that may arise, or remove any unwanted audio or subtitle track by un-checking the track before the re-mux.
Mike T
mtallent is offline
Old 01-07-2011, 10:07 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
50GB can be had for $7-8. True it's much more than $2 but it allows a full disc with no compression.
I am not sure since I've only done @15 movies but whatever format the BD is in - it's burned the same format.
It was probably something I did considering I rarely use DVDFab. On a different forum website I posted and got this response: That's probably because you didn't tell it to make a disc copy in DVDFab, if you don't it just makes an ISO from the files it reads off the disc rather than a sector by sector ISO. Anyway if you have AnyDVD HD running you can just make an ISO using Imgburn then burn it back to DL disc after
Guess I paid for AnyDVDHD and not DVDFab so for me - I just use what I'm 'used to'.
Wryker is offline
Old 01-07-2011, 10:50 AM
darthemma's Avatar
Mike T
Thanks for the suggestion. I've ordered a BD-RE disc and will have it in a day or two. I am trying your suggestion with tsMuxeR right now. I'm just trying to eliminate possible problems one by one.
Old 01-09-2011, 03:24 PM
bourke's Avatar
So you definitetly confirmed that originals in VC-1 are re-compressed in VC-1 (or did you only ever do 1:1 copies)?
Does anyone else knof if DVD Fab. Blu-ray Copy does that as well, or does it transcode into AVC?
bourke is offline
Old 01-10-2011, 05:05 PM
darthemma's Avatar
Mike T
I thought I'd follow up with my case of the BD-R burning mystery. It has become even more mysterious.
I initially bought Maxell BD-R discs (which apparently are actually Ritek, according to Imgburn) and those did not play in either of my BR players (see my previous posts for details, if you wish).
So, I bought new discs. This time I got a Verbatim BD-RE to test my settings with. I burned the same files on the same settings to that disc and it plays perfectly. I had the burn speed set at max and when I checked the logs, Imgburn said it had burned the disc at 2X.
Convinced I had the settings right at this point, I then tried the Verbatim BD-R discs with the same settings. Unfortunately, that disc will not play in my blu-ray players. I had the burn speed set at MAX (AWS) in Imgburn.
I am at a loss to understand what is wrong. The only thing I can think to try is a new burner.
Old 01-13-2011, 05:08 PM
darthemma's Avatar
I thought I'd report back here to wrap up my saga.
I got my new LG drive today (WH10LS30). Burned a BD-R and it plays flawlessly in my BR players. So, it was the drive that came with my computer. The new drive works great.
I also hacked the firmware in the drive with MediaCodeSpeedEdit to remove the dang Riplock in the drive and was able to apply RPC2 Auto Reset.
I'm very happy. The drive was on sale for under $80 this week.
Thanks to those who gave me helpful advice. Much appreciated.
Old 01-21-2011, 12:16 PM
kevinokev's Avatar
I recently bought a media converter for a mac (iMedia Converter) which allows me to rip a BD into any type of movie format of my choosing (literally).
I've chosen the path of directly copying the m2ts files off of the disc (while iMedia Converter strips out the disc protection).
Once I have the m2ts file(s), I take them into tsMuxer (Snow Leopard build by vox...).
Once in tsMuxer, I remove all of the streams I do not want (ac3, 720 video, etc). So I am only left with English DTS-MA and 1080p video. I select the file output to be blu-ray and click the mux button (or whatever it says as I am not on that system currently). It then creates the BDMV and Certificate folders and populates them accordingly.
At this point I go and burn a data blu-ray using apple's OS burn option. However, once burned the disc does not work.
The reason for my post is to see what I am doing wrong (besides trying to do this on a mac). Any input would be greatly appreciated as I've been trying to make this work for about 3 weeks now.
Is it a setting, am I burning the disc incorrectly? I would like to continue using this software, but am doing it blindly at this point. Any input would greatly be appreciated.
kevinokev is offline
Old 01-21-2011, 01:18 PM
Morpheo's Avatar
Quoted: 945 Post(s)
Liked: 798
Data Blu-ray? There's your problem ...The Finder can *only* burn data discs, whether it's CD, DVD, or Blu-ray for that matter. But you want a "Blu-ray Video" disc (just like DVD-Video), and then your best option would be Toast. You'll need the $19.99 Blu-ray plugin though for the regular Toast Titanium (it's included in Toast Pro).
__________
Nicolas.
"Music expresses that which cannot be said and on which it is impossible to be silent."- Victor Hugo.
Morpheo is offline
Old 01-21-2011, 02:13 PM
kevinokev's Avatar
My concern is that Toast might possibly re-encode the m2ts files upon output. I have the HD plugin for the app. So should I just drag all of the files that tsMuxer created (BDMV and CERTIFICATE) into toast under the Blu-ray video option or simply the m2ts files ??
Will toast preserve the 5.1 channel audio??
I haven't had too much luck with Toast while testing.
If you can lend anymore help, please do so.
Old 01-22-2011, 11:42 PM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 64
I suppose it's possible, but since there are a number of steps listed, it's hard to say. One thing you don't mention is, what are you trying to play the disc on? While most recent players can play Blu-ray writable discs, not all Blu-ray players will play Blu-ray writable media. There is a list in the link below that generally covers writable media playback from a number of Blu-ray players.
Assuming the Blu-ray player is capable of playing writable media, the disc file system has to be set correctly. By default I think Blu-ray writable discs should use either UDF 2.5 or UDF 2.6, but I believe some software may allow for other file systems. I don't use Mac, so I can't say if the software would be using the correct file system. I have used ImgBurn with Wine in Linux, and it's capable of burning data to either a UDF 2.5 or UDF 2.6 file system.
alluringreality is offline
Old 02-06-2011, 07:03 PM
Starman58's Avatar
Guys and Gals,
I am sure this is in here but I am lazy watching the superbowl. I just need a simple editing program for all the NASCAR, FOOTBALL and whatever else programs I use my Hauppauge PVR for recording to my WD 1B Black HD?
All I want to do is edit the commercials nothing fancy. Mind you my HD DVR downloads in H.294. I use Arcsoft which was included with the Hauppauge HD PVR external box. So I believe I need to work with MP4.
Starman
Starman58 is offline
Old 02-06-2011, 09:30 PM
Quoted: 57 Post(s)
Liked: 64
I bought VideoReDo a few years ago for editing out commercials from over-the-air recordings. I think it only works with Mpeg-2 video. The main benefit is that it's quick and doesn't transcode, and I never had any out of sync audio using the program. Anyway, I believe they probably offer a trial.
Old 02-07-2011, 03:29 PM
Quoted: 21 Post(s)
Originally Posted by alluringreality View Post
I bought VideoReDo...think it only works with Mpeg-2 video. I believe they probably offer a trial.
They now have a version that does h264, though I dunno if they offer a trial version of that or not.
If they do, it's important to know that to get a full working software for the two weeks of the trial, you need to register the trial with them first (free of course). Unless you do that, the output is limited maybe to a half-hour or even 15 minutes.
Laserfan is offline
Old 02-07-2011, 03:42 PM
Quoted: 57 Post(s)
Liked: 64
I'm not familiar with the TVSuite products. VideoReDo Plus is what I used for editing ATSC recordings.
Old 02-21-2011, 09:06 AM
theshadow1234's Avatar
Whats the fastest software to convert blu-ray to mkv?
Sorry if i put this in the wrong section.
theshadow1234 is offline
Old 02-21-2011, 09:25 AM
Super_DAD's Avatar
I have great luck with makemkv and tue automated version autoripncompress. Usually takes about 45 minutes. Depends on the movie transformers 2 took about an hour 15 minutes. Terminator 1 took about half hour. I'm running a dual core amd phenom 2.85. With 4 gb ram and an 8 speed blu-ray drive. I put my pc specs in because ad we all know that makes a huge difference in rip speeds.
Super_DAD is offline
Old 02-23-2011, 04:24 PM
spaldingclan's Avatar
agreed, makemkv is the best
spaldingclan is offline
Old 03-05-2011, 04:32 PM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
I have 10 short videos that I stripped from MKV with tsmuxer as m2ts and because they are AVC DTS my PS3 won't play them unless they are in AVCHD or blu-ray structure, is there any application that creates blu-ray structure for multiple m2ts files as playlist without having to re-encode or transcode the files like roxio or nero does? I just want to be able to skip within those files with next chapter button, no menus needed, One solution is I can join them with tsmuxer and set the chapter marker according to the files lengths and output as blu-ray but too much work, is there an option to just drop the files in stream folder and edit the file list so any bd player can recognize the tracks?
latreche34 is offline
Old 03-05-2011, 05:43 PM
MozartMan's Avatar
You can try multiAVCHD http://www.videohelp.com/tools/multiAVCHD
MozartMan is offline
Old 03-07-2011, 02:06 AM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
Great software, I liked it and I donated after the first use, was just wondering how to change the display title on the BD icon, my PS3 displays multiavchd... on the disc icon ??
Old 03-07-2011, 04:41 AM
MozartMan's Avatar
After you hit big Start button to compile your project, go to General output section (in the right half at the bottom) and replace multiAVCHD text in Compilation name text field with anything you want. This should do it.
Old 03-09-2011, 02:44 AM
latreche34's Avatar
Quoted: 115 Post(s)
Liked: 57
Does multiavchd edit movies in 7.1 without transcoding, meaning removing unwanted scenes from the movie while keeping the original quality and original multichanel audio? I used both SolveigMM Video Splitter and Smart Cutter and they both suck.
